path: root/crypto/async_tx/async_memcpy.c
2008-07-17async_tx: remove depend_tx from async_tx_sync_epilogDan Williams
All callers of async_tx_sync_epilog have called async_tx_quiesce on the depend_tx, so async_tx_sync_epilog need only call the callback to complete the operation. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2008-07-17async_tx: export async_tx_quiesceDan Williams
Replace open coded "wait and acknowledge" instances with async_tx_quiesce. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2008-04-17dmaengine: ack to flags: make use of the unused bits in the 'ack' fieldDan Williams
'ack' is currently a simple integer that flags whether or not a client is done touching fields in the given descriptor. It is effectively just a single bit of information. Converting this to a flags parameter allows the other bits to be put to use to control completion actions, like dma-unmap, and capture results, like xor-zero-sum == 0. Changes are one of: 1/ convert all open-coded ->ack manipulations to use async_tx_ack and async_tx_test_ack. 2/ set the ack bit at prep time where possible 3/ make drivers store the flags at prep time 4/ add flags to the device_prep_dma_interrupt prototype Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2008-03-13async_tx: checkpatch says s/__FUNCTION__/__func__/gDan Williams
2008-02-06async_tx: allow architecture specific async_tx_find_channel implementationsDan Williams
The source and destination addresses are included to allow channel selection based on address alignment. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Reviewed-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2008-02-06async_tx: replace 'int_en' with operation preparation flagsDan Williams
Pass a full set of flags to drivers' per-operation 'prep' routines. Currently the only flag passed is DMA_PREP_INTERRUPT. The expectation is that arch-specific async_tx_find_channel() implementations can exploit this capability to find the best channel for an operation. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Acked-by: Shannon Nelson <shannon.nelson@intel.com> Reviewed-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2008-02-06async_tx: kill tx_set_src and tx_set_dest methodsDan Williams
The tx_set_src and tx_set_dest methods were originally implemented to allow an array of addresses to be passed down from async_xor to the dmaengine driver while minimizing stack overhead. Removing these methods allows drivers to have all transaction parameters available at 'prep' time, saves two function pointers in struct dma_async_tx_descriptor, and reduces the number of indirect branches.. A consequence of moving this data to the 'prep' routine is that multi-source routines like async_xor need temporary storage to convert an array of linear addresses into an array of dma addresses. In order to keep the same stack footprint of the previous implementation the input array is reused as storage for the dma addresses. This requires that sizeof(dma_addr_t) be less than or equal to sizeof(void *). As a consequence CONFIG_DMADEVICES now depends on !CONFIG_HIGHMEM64G. It also requires that drivers be able to make descriptor resources available when the 'prep' routine is polled. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Acked-by: Shannon Nelson <shannon.nelson@intel.com>
2008-02-06async_tx: kill ASYNC_TX_ASSUME_COHERENTDan Williams
Remove the unused ASYNC_TX_ASSUME_COHERENT flag. Async_tx is meant to hide the difference between asynchronous hardware and synchronous software operations, this flag requires clients to understand cache coherency consequences of the async path. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Reviewed-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-07-20async_tx: fix kmap_atomic usage in async_memcpyDan Williams
Andrew Morton: [async_memcpy] is very wrong if both ASYNC_TX_KMAP_DST and ASYNC_TX_KMAP_SRC can ever be set. We'll end up using the same kmap slot for both src add dest and we get either corrupted data or a BUG. Evgeniy Polyakov: Btw, shouldn't it always be kmap_atomic() even if flag is not set. That pages are usual one returned by alloc_page(). So fix the usage of kmap_atomic and kill the ASYNC_TX_KMAP_DST and ASYNC_TX_KMAP_SRC flags. Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-13async_tx: add the async_tx apiDan Williams
The async_tx api provides methods for describing a chain of asynchronous bulk memory transfers/transforms with support for inter-transactional dependencies. It is implemented as a dmaengine client that smooths over the details of different hardware offload engine implementations. Code that is written to the api can optimize for asynchronous operation and the api will fit the chain of operations to the available offload resources. I imagine that any piece of ADMA hardware would register with the 'async_*' subsystem, and a call to async_X would be routed as appropriate, or be run in-line. - Neil Brown async_tx exploits the capabilities of struct dma_async_tx_descriptor to provide an api of the following general format: struct dma_async_tx_descriptor * async_<operation>(..., struct dma_async_tx_descriptor *depend_tx, dma_async_tx_callback cb_fn, void *cb_param) { struct dma_chan *chan = async_tx_find_channel(depend_tx, <operation>); struct dma_device *device = chan ? chan->device : NULL; int int_en = cb_fn ? 1 : 0; struct dma_async_tx_descriptor *tx = device ? device->device_prep_dma_<operation>(chan, len, int_en) : NULL; if (tx) { /* run <operation> asynchronously */ ... tx->tx_set_dest(addr, tx, index); ... tx->tx_set_src(addr, tx, index); ... async_tx_submit(chan, tx, flags, depend_tx, cb_fn, cb_param); } else { /* run <operation> synchronously */ ... <operation> ... async_tx_sync_epilog(flags, depend_tx, cb_fn, cb_param); } return tx; } async_tx_find_channel() returns a capable channel from its pool. The channel pool is organized as a per-cpu array of channel pointers. The async_tx_rebalance() routine is tasked with managing these arrays. In the uniprocessor case async_tx_rebalance() tries to spread responsibility evenly over channels of similar capabilities. For example if there are two copy+xor channels, one will handle copy operations and the other will handle xor. In the SMP case async_tx_rebalance() attempts to spread the operations evenly over the cpus, e.g. cpu0 gets copy channel0 and xor channel0 while cpu1 gets copy channel 1 and xor channel 1. When a dependency is specified async_tx_find_channel defaults to keeping the operation on the same channel. A xor->copy->xor chain will stay on one channel if it supports both operation types, otherwise the transaction will transition between a copy and a xor resource. Currently the raid5 implementation in the MD raid456 driver has been converted to the async_tx api. A driver for the offload engines on the Intel Xscale series of I/O processors, iop-adma, is provided in a later commit. With the iop-adma driver and async_tx, raid456 is able to offload copy, xor, and xor-zero-sum operations to hardware engines. On iop342 tiobench showed higher throughput for sequential writes (20 - 30% improvement) and sequential reads to a degraded array (40 - 55% improvement). For the other cases performance was roughly equal, +/- a few percentage points. On a x86-smp platform the performance of the async_tx implementation (in synchronous mode) was also +/- a few percentage points of the original implementation. According to 'top' on iop342 CPU utilization drops from ~50% to ~15% during a 'resync' while the speed according to /proc/mdstat doubles from ~25 MB/s to ~50 MB/s. The tiobench command line used for testing was: tiobench --size 2048 --block 4096 --block 131072 --dir /mnt/raid --numruns 5 * iop342 had 1GB of memory available Details: * if CONFIG_DMA_ENGINE=n the asynchronous path is compiled away by making async_tx_find_channel a static inline routine that always returns NULL * when a callback is specified for a given transaction an interrupt will fire at operation completion time and the callback will occur in a tasklet. if the the channel does not support interrupts then a live polling wait will be performed * the api is written as a dmaengine client that requests all available channels * In support of dependencies the api implicitly schedules channel-switch interrupts. The interrupt triggers the cleanup tasklet which causes pending operations to be scheduled on the next channel * Xor engines treat an xor destination address differently than a software xor routine. To the software routine the destination address is an implied source, whereas engines treat it as a write-only destination. This patch modifies the xor_blocks routine to take a an explicit destination address to mirror the hardware. Changelog: * fixed a leftover debug print * don't allow callbacks in async_interrupt_cond * fixed xor_block changes * fixed usage of ASYNC_TX_XOR_DROP_DEST * drop dma mapping methods, suggested by Chris Leech * printk warning fixups from Andrew Morton * don't use inline in C files, Adrian Bunk * select the API when MD is enabled * BUG_ON xor source counts <= 1 * implicitly handle hardware concerns like channel switching and interrupts, Neil Brown * remove the per operation type list, and distribute operation capabilities evenly amongst the available channels * simplify async_tx_find_channel to optimize the fast path * introduce the channel_table_initialized flag to prevent early calls to the api * reorganize the code to mimic crypto * include mm.h as not all archs include it in dma-mapping.h * make the Kconfig options non-user visible, Adrian Bunk * move async_tx under crypto since it is meant as 'core' functionality, and the two may share algorithms in the future * move large inline functions into c files * checkpatch.pl fixes * gpl v2 only correction Cc: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Acked-By: NeilBrown <neilb@suse.de>
