path: root/crypto/authenc.c
2008-01-11[CRYPTO] authenc: Add givencrypt operationHerbert Xu
This patch implements the givencrypt function for authenc. It simply calls the givencrypt operation on the underlying cipher instead of encrypt. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] authenc: Use crypto_grab_skcipherHerbert Xu
This patch converts the authenc algorithm over to crypto_grab_skcipher which is a prerequisite for IV generation. This patch also changes authenc to set its ASYNC status depending on the ASYNC status of the underlying skcipher. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] authenc: Merge common hashing codeHerbert Xu
This patch merges the common hashing code between encryption and decryption. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] authenc: Use RTA_OK to check lengthHerbert Xu
This patch changes setkey to use RTA_OK to check the validity of the setkey request. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] authenc: Fix typo in ivsizeHerbert Xu
The ivsize should be fetched from ablkcipher, not blkcipher. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] scatterwalk: Move scatterwalk.h to linux/cryptoHerbert Xu
The scatterwalk infrastructure is used by algorithms so it needs to move out of crypto for future users that may live in drivers/crypto or asm/*/crypto. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] aead: Return EBADMSG for ICV mismatchHerbert Xu
This patch changes gcm/authenc to return EBADMSG instead of EINVAL for ICV mismatches. This convention has already been adopted by IPsec. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] authenc: Fix hash verificationHerbert Xu
The previous code incorrectly included the hash in the verification which also meant that we'd crash and burn when it comes to actually verifying the hash since we'd go past the end of the SG list. This patch fixes that by subtracting authsize from cryptlen at the start. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] authenc: Move enckeylen into key itselfHerbert Xu
Having enckeylen as a template parameter makes it a pain for hardware devices that implement ciphers with many key sizes since each one would have to be registered separately. Since the authenc algorithm is mainly used for legacy purposes where its key is going to be constructed out of two separate keys, we can in fact embed this value into the key itself. This patch does this by prepending an rtnetlink header to the key that contains the encryption key length. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] aead: Make authsize a run-time parameterHerbert Xu
As it is authsize is an algorithm paramter which cannot be changed at run-time. This is inconvenient because hardware that implements such algorithms would have to register each authsize that they support separately. Since authsize is a property common to all AEAD algorithms, we can add a function setauthsize that sets it at run-time, just like setkey. This patch does exactly that and also changes authenc so that authsize is no longer a parameter of its template. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] authenc: Use or instead of max on alignment masksHerbert Xu
Since alignment masks are always one less than a power of two, we can use binary or to find their maximum. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] ablkcipher: Add distinct ABLKCIPHER typeHerbert Xu
Up until now we have ablkcipher algorithms have been identified as type BLKCIPHER with the ASYNC bit set. This is suboptimal because ablkcipher refers to two things. On the one hand it refers to the top-level ablkcipher interface with requests. On the other hand it refers to and algorithm type underneath. As it is you cannot request a synchronous block cipher algorithm with the ablkcipher interface on top. This is a problem because we want to be able to eventually phase out the blkcipher top-level interface. This patch fixes this by making ABLKCIPHER its own type, just as we have distinct types for HASH and DIGEST. The type it associated with the algorithm implementation only. Which top-level interface is used for synchronous block ciphers is then determined by the mask that's used. If it's a specific mask then the old blkcipher interface is given, otherwise we go with the new ablkcipher interface. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-11-23[CRYPTO] authenc: Move initialisations up to shut up gccHerbert Xu
It seems that newer versions of gcc have regressed in their abilities to analyse initialisations. This patch moves the initialisations up to avoid the warnings. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-10-10[CRYPTO] authenc: Kill spaces in algorithm namesHerbert Xu
We do not allow spaces in algorithm names or parameters. Thanks to Joy Latten for pointing this out. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-10-10[CRYPTO] aead: Add authencHerbert Xu
This patch adds the authenc algorithm which constructs an AEAD algorithm from an asynchronous block cipher and a hash. The construction is done by concatenating the encrypted result from the cipher with the output from the hash, as is used by the IPsec ESP protocol. The authenc algorithm exists as a template with four parameters: authenc(auth, authsize, enc, enckeylen). The authentication algorithm, the authentication size (i.e., truncating the output of the authentication algorithm), the encryption algorithm, and the encryption key length. Both the size field and the key length field are in bytes. For example, AES-128 with SHA1-HMAC would be represented by authenc(hmac(sha1), 12, cbc(aes), 16) The key for the authenc algorithm is the concatenation of the keys for the authentication algorithm with the encryption algorithm. For the above example, if a key of length 36 bytes is given, then hmac(sha1) would receive the first 20 bytes while the last 16 would be given to cbc(aes). Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
