commit acdb04d0b36769b3e05990c488dc74d8b7ac8060 upstream.
When we need to allocate a temporary blkcipher_walk_next and it
fails, the code is supposed to take the slow path of processing
the data block by block. However, due to an unrelated change
we instead end up dereferencing the NULL pointer.
This patch fixes it by moving the unrelated bsize setting out
of the way so that we enter the slow path as inteded.
Fixes: 7607bd8ff03b ("[CRYPTO] blkcipher: Added blkcipher_walk_virt_block")
Reported-by: xiakaixu <xiakaixu@huawei.com>
Reported-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Tested-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Some ciphers actually support encrypting zero length plaintexts. For
example, many AEAD modes support this. The resulting ciphertext for
those winds up being only the authentication tag, which is a result of
the key, the iv, the additional data, and the fact that the plaintext
had zero length. The blkcipher constructors won't copy the IV to the
right place, however, when using a zero length input, resulting in
some significant problems when ciphers call their initialization
routines, only to find that the ->iv parameter is uninitialized. One
such example of this would be using chacha20poly1305 with a zero length
input, which then calls chacha20, which calls the key setup routine,
which eventually OOPSes due to the uninitialized ->iv member.
Signed-off-by: Jason A. Donenfeld <Jason@zx2c4.com>
Cc: <stable@vger.kernel.org>
All users of AEAD should include crypto/aead.h instead of
include/linux/crypto.h.
This adds the function blkcipher_aead_walk_virt_block, which allows the caller
to use the blkcipher walk API to handle the input and output scatterlists.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
In order to allow other uses of the blkcipher walk API than the blkcipher
algos themselves, this patch copies some of the transform data members to the
walk struct so the transform is only accessed at walk init time.
Three errors resulting in kernel memory disclosure:
1/ The structures used for the netlink based crypto algorithm report API
are located on the stack. As snprintf() does not fill the remainder of
the buffer with null bytes, those stack bytes will be disclosed to users
of the API. Switch to strncpy() to fix this.
2/ crypto_report_one() does not initialize all field of struct
crypto_user_alg. Fix this to fix the heap info leak.
3/ For the module name we should copy only as many bytes as
module_name() returns -- not as much as the destination buffer could
hold. But the current code does not and therefore copies random data
from behind the end of the module name, as the module name is always
shorter than CRYPTO_MAX_ALG_NAME.
Also switch to use strncpy() to copy the algorithm's name and
driver_name. They are strings, after all.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Cc: Steffen Klassert <steffen.klassert@secunet.com>
Replace PTR_ERR followed by ERR_PTR by ERR_CAST, to be more concise.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
expression err,x;
- err = PTR_ERR(x);
if (IS_ERR(x))
- return ERR_PTR(err);
+ return ERR_CAST(x);
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
These macros contain a hidden goto, and are thus extremely error
prone and make code hard to audit.
Signed-off-by: Cong Wang <amwang@redhat.com>
The report functions use NLA_PUT so we need to ensure that NET
is enabled.
Reported-by: Luis Henriques <henrix@camandro.org>
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
Ensure kmap_atomic() usage is strictly nested
Acked-by: Chris Metcalf <cmetcalf@tilera.com>
When an skcipher constructed through crypto_givcipher_default fails
its selftest, we'll loop forever trying to construct new skcipher
objects but failing because it already exists.
The crux of the issue is that once a givcipher fails the selftest,
we'll ignore it on the next run through crypto_skcipher_lookup and
attempt to construct a new givcipher.
We should instead return an error to the caller if we find a
givcipher that has failed the test.
When we get left-over bits from a slow walk, it means that the
underlying cipher has gone troppo. However, as we're handling
that case we should ensure that the caller terminates the walk.
This patch does this by setting walk->nbytes to zero.
Reported-by: Roel Kluin <roel.kluin@gmail.com>
Reported-by: Huang Ying <ying.huang@intel.com>
This patch moves the default IV generators into their own modules
in order to break a dependency loop between cryptomgr, rng, and
blkcipher.
For compatibility with dm-crypt initramfs setups it is useful to merge
chainiv/seqiv into the crypto_blkcipher module. Since they're required
by most algorithms anyway this is an acceptable trade-off.
This patch makes crypto_alloc_ablkcipher/crypto_grab_skcipher always
return algorithms that are capable of generating their own IVs through
givencrypt and givdecrypt. Each algorithm may specify its default IV
generator through the geniv field.
For algorithms that do not set the geniv field, the blkcipher layer will
pick a default. Currently it's chainiv for synchronous algorithms and
eseqiv for asynchronous algorithms. Note that if these wrappers do not
work on an algorithm then that algorithm must specify its own geniv or
it can't be used at all.
This patch creates the infrastructure to help the construction of givcipher
templates that wrap around existing blkcipher/ablkcipher algorithms by adding
an IV generator to them.
This patch introduces the geniv field which indicates the default IV
generator for each algorithm. It should point to a string that is not
freed as long as the algorithm is registered.
The scatterwalk infrastructure is used by algorithms so it needs to
move out of crypto for future users that may live in drivers/crypto
or asm/*/crypto.
Up until now we have ablkcipher algorithms have been identified as
type BLKCIPHER with the ASYNC bit set. This is suboptimal because
ablkcipher refers to two things. On the one hand it refers to the
top-level ablkcipher interface with requests. On the other hand it
refers to and algorithm type underneath.
As it is you cannot request a synchronous block cipher algorithm
with the ablkcipher interface on top. This is a problem because
we want to be able to eventually phase out the blkcipher top-level
interface.
This patch fixes this by making ABLKCIPHER its own type, just as
we have distinct types for HASH and DIGEST. The type it associated
with the algorithm implementation only.
Which top-level interface is used for synchronous block ciphers is
then determined by the mask that's used. If it's a specific mask
then the old blkcipher interface is given, otherwise we go with the
new ablkcipher interface.
This patch adds the helper blkcipher_walk_virt_block which is similar to
blkcipher_walk_virt but uses a supplied block size instead of the block
size of the block cipher. This is useful for CTR where the block size is
1 but we still want to walk by the block size of the underlying cipher.
Now that the block size is no longer a multiple of the alignment, we need to
increase the kmalloc amount in blkcipher_next_slow to use the aligned block
size.
Previously we assumed for convenience that the block size is a multiple of
the algorithm's required alignment. With the pending addition of CTR this
will no longer be the case as the block size will be 1 due to it being a
stream cipher. However, the alignment requirement will be that of the
underlying implementation which will most likely be greater than 1.
Use max in blkcipher_get_spot() instead of open coding it.
Signed-off-by: Ingo Oeser <ioe-lkml@rameria.de>
This patch ensures that kernel.h and slab.h are included for
the setkey_unaligned function. It also breaks a couple of
long lines.
The previous patch had the conditional inverted. This patch fixes it
so that we return the original position if it does not straddle a page.
Thanks to Bob Gilligan for spotting this.
The function blkcipher_get_spot tries to return a buffer of
the specified length that does not straddle a page. It has
an off-by-one bug so it may advance a page unnecessarily.
What's worse, one of its callers doesn't provide a buffer
that's sufficiently long for this operation.
This patch fixes both problems. Thanks to Bob Gilligan for
diagnosing this problem and providing a fix.
setkey_unaligned() commited in ca7c39385ce1a7b44894a4b225a4608624e90730
overwrites unallocated memory in the following memset() because
I used the wrong buffer length.
Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc>
setkey() in {cipher,blkcipher,ablkcipher,hash}.c does not respect the
requested alignment by the algorithm. This patch fixes it. The extra
memory is allocated by kmalloc() with GFP_ATOMIC flag.
Signed-off-by: Sebastian Siewior <linux-crypto@ml.breakpoint.cc>
This patch adds the frontend interface for asynchronous block ciphers.
In addition to the usual block cipher parameters, there is a callback
function pointer and a data pointer. The callback will be invoked only
if the encrypt/decrypt handlers return -EINPROGRESS. In other words,
if the return value of zero the completion handler (or the equivalent
code) needs to be invoked by the caller.
The request structure is allocated and freed by the caller. Its size
is determined by calling crypto_ablkcipher_reqsize(). The helpers
ablkcipher_request_alloc/ablkcipher_request_free can be used to manage
the memory for a request.
The proc functions were incorrectly marked as used rather than unused.
They may be unused if proc is disabled.
This patch adds support for multiple frontend types for each backend
algorithm by passing the type and mask through to the backend type
init function.
Using blkcipher/hash crypto operations in hard IRQ context can lead
to random memory corruption due to the reuse of kmap_atomic slots.
Since crypto operations were never meant to be used in hard IRQ
contexts, this patch checks for such usage and returns an error
before kmap_atomic is performed.
Remove useless includes of linux/io.h, don't even try to build iomap_copy
on uml (it doesn't have readb() et.al., so...)
Acked-by: Jeff Dike <jdike@addtoit.com>
This patch adds the new type of block ciphers. Unlike current cipher
algorithms which operate on a single block at a time, block ciphers
operate on an arbitrarily long linear area of data. As it is block-based,
it will skip any data remaining at the end which cannot form a block.
The block cipher has one major difference when compared to the existing
block cipher implementation. The sg walking is now performed by the
algorithm rather than the cipher mid-layer. This is needed for drivers
that directly support sg lists. It also improves performance for all
algorithms as it reduces the total number of indirect calls by one.
In future the existing cipher algorithm will be converted to only have
a single-block interface. This will be done after all existing users
have switched over to the new block cipher type.
