path: root/crypto/chacha20poly1305.c
2019-06-11crypto: chacha20poly1305 - set cra_name correctlyEric Biggers
commit 5e27f38f1f3f45a0c938299c3a34a2d2db77165a upstream. If the rfc7539 template is instantiated with specific implementations, e.g. "rfc7539(chacha20-generic,poly1305-generic)" rather than "rfc7539(chacha20,poly1305)", then the implementation names end up included in the instance's cra_name. This is incorrect because it then prevents all users from allocating "rfc7539(chacha20,poly1305)", if the highest priority implementations of chacha20 and poly1305 were selected. Also, the self-tests aren't run on an instance allocated in this way. Fix it by setting the instance's cra_name from the underlying algorithms' actual cra_names, rather than from the requested names. This matches what other templates do. Fixes: 71ebc4d1b27d ("crypto: chacha20poly1305 - Add a ChaCha20-Poly1305 AEAD construction, RFC7539") Cc: <stable@vger.kernel.org> # v4.2+ Cc: Martin Willi <martin@strongswan.org> Signed-off-by: Eric Biggers <ebiggers@google.com> Reviewed-by: Martin Willi <martin@strongswan.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-10crypto: chacha20poly1305 - validate the digest sizeEric Biggers
commit e57121d08c38dabec15cf3e1e2ad46721af30cae upstream. If the rfc7539 template was instantiated with a hash algorithm with digest size larger than 16 bytes (POLY1305_DIGEST_SIZE), then the digest overran the 'tag' buffer in 'struct chachapoly_req_ctx', corrupting the subsequent memory, including 'cryptlen'. This caused a crash during crypto_skcipher_decrypt(). Fix it by, when instantiating the template, requiring that the underlying hash algorithm has the digest size expected for Poly1305. Reproducer: #include <linux/if_alg.h> #include <sys/socket.h> #include <unistd.h> int main() { int algfd, reqfd; struct sockaddr_alg addr = { .salg_type = "aead", .salg_name = "rfc7539(chacha20,sha256)", }; unsigned char buf[32] = { 0 }; algfd = socket(AF_ALG, SOCK_SEQPACKET, 0); bind(algfd, (void *)&addr, sizeof(addr)); setsockopt(algfd, SOL_ALG, ALG_SET_KEY, buf, sizeof(buf)); reqfd = accept(algfd, 0, 0); write(reqfd, buf, 16); read(reqfd, buf, 16); } Reported-by: syzbot <syzkaller@googlegroups.com> Fixes: 71ebc4d1b27d ("crypto: chacha20poly1305 - Add a ChaCha20-Poly1305 AEAD construction, RFC7539") Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-08-17crypto: aead - Remove CRYPTO_ALG_AEAD_NEW flagHerbert Xu
This patch removes the CRYPTO_ALG_AEAD_NEW flag now that everyone has been converted. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-07-17crypto: poly1305 - Export common Poly1305 helpersMartin Willi
As architecture specific drivers need a software fallback, export Poly1305 init/update/final functions together with some helpers in a header file. Signed-off-by: Martin Willi <martin@strongswan.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-07-17crypto: chacha20 - Export common ChaCha20 helpersMartin Willi
As architecture specific drivers need a software fallback, export a ChaCha20 en-/decryption function together with some helpers in a header file. Signed-off-by: Martin Willi <martin@strongswan.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-07-17crypto: chacha20poly1305 - Convert to new AEAD interfaceHerbert Xu
This patch converts rfc7539 and rfc7539esp to the new AEAD interface. The test vectors for rfc7539esp have also been updated to include the IV. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Tested-by: Martin Willi <martin@strongswan.org>
2015-06-17crypto: poly1305 - Pass key as first two message blocks to each desc_ctxMartin Willi
The Poly1305 authenticator requires a unique key for each generated tag. This implies that we can't set the key per tfm, as multiple users set individual keys. Instead we pass a desc specific key as the first two blocks of the message to authenticate in update(). Signed-off-by: Martin Willi <martin@strongswan.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-06-04crypto: chacha20poly1305 - Add an IPsec variant for RFC7539 AEADMartin Willi
draft-ietf-ipsecme-chacha20-poly1305 defines the use of ChaCha20/Poly1305 in ESP. It uses additional four byte key material as a salt, which is then used with an 8 byte IV to form the ChaCha20 nonce as defined in the RFC7539. Signed-off-by: Martin Willi <martin@strongswan.org> Acked-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-06-04crypto: chacha20poly1305 - Add a ChaCha20-Poly1305 AEAD construction, RFC7539Martin Willi
This AEAD uses a chacha20 ablkcipher and a poly1305 ahash to construct the ChaCha20-Poly1305 AEAD as defined in RFC7539. It supports both synchronous and asynchronous operations, even if we currently have no async chacha20 or poly1305 drivers. Signed-off-by: Martin Willi <martin@strongswan.org> Acked-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
