path: root/crypto/cryptd.c
2010-09-20crypto: cryptd - Adding the AEAD interface type support to cryptdAdrian Hoban
This patch adds AEAD support into the cryptd framework. Having AEAD support in cryptd enables crypto drivers that use the AEAD interface type (such as the patch for AEAD based RFC4106 AES-GCM implementation using Intel New Instructions) to leverage cryptd for asynchronous processing. Signed-off-by: Adrian Hoban <adrian.hoban@intel.com> Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com> Signed-off-by: Gabriele Paoloni <gabriele.paoloni@intel.com> Signed-off-by: Aidan O'Mahony <aidan.o.mahony@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-02-17percpu: add __percpu sparse annotations to what's leftTejun Heo
Add __percpu sparse annotations to places which didn't make it in one of the previous patches. All converions are trivial. These annotations are to make sparse consider percpu variables to be in a different address space and warn if accessed without going through percpu accessors. This patch doesn't affect normal builds. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Borislav Petkov <borislav.petkov@amd.com> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Huang Ying <ying.huang@intel.com> Cc: Len Brown <lenb@kernel.org> Cc: Neil Brown <neilb@suse.de>
2009-12-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (34 commits) m68k: rename global variable vmalloc_end to m68k_vmalloc_end percpu: add missing per_cpu_ptr_to_phys() definition for UP percpu: Fix kdump failure if booted with percpu_alloc=page percpu: make misc percpu symbols unique percpu: make percpu symbols in ia64 unique percpu: make percpu symbols in powerpc unique percpu: make percpu symbols in x86 unique percpu: make percpu symbols in xen unique percpu: make percpu symbols in cpufreq unique percpu: make percpu symbols in oprofile unique percpu: make percpu symbols in tracer unique percpu: make percpu symbols under kernel/ and mm/ unique percpu: remove some sparse warnings percpu: make alloc_percpu() handle array types vmalloc: fix use of non-existent percpu variable in put_cpu_var() this_cpu: Use this_cpu_xx in trace_functions_graph.c this_cpu: Use this_cpu_xx for ftrace this_cpu: Use this_cpu_xx in nmi handling this_cpu: Use this_cpu operations in RCU this_cpu: Use this_cpu ops for VM statistics ... Fix up trivial (famous last words) global per-cpu naming conflicts in arch/x86/kvm/svm.c mm/slab.c
2009-10-19crypto: ghash - Add PCLMULQDQ accelerated implementationHuang Ying
PCLMULQDQ is used to accelerate the most time-consuming part of GHASH, carry-less multiplication. More information about PCLMULQDQ can be found at: http://software.intel.com/en-us/articles/carry-less-multiplication-and-its-usage-for-computing-the-gcm-mode/ Because PCLMULQDQ changes XMM state, its usage must be enclosed with kernel_fpu_begin/end, which can be used only in process context, the acceleration is implemented as crypto_ahash. That is, request in soft IRQ context will be defered to the cryptd kernel thread. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-10-03this_cpu: Use this_cpu_ptr in crypto subsystemChristoph Lameter
Just a slight optimization that removes one array lookup. The processor number is needed for other things as well so the get/put_cpu cannot be removed. Acked-by: Tejun Heo <tj@kernel.org> Cc: Huang Ying <ying.huang@intel.com> Signed-off-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Tejun Heo <tj@kernel.org>
2009-08-06crypto: cryptd - Add support to access underlaying shashHuang Ying
cryptd_alloc_ahash() will allocate a cryptd-ed ahash for specified algorithm name. The new allocated one is guaranteed to be cryptd-ed ahash, so the shash underlying can be gotten via cryptd_ahash_child(). Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-22crypto: cryptd - Add finup/export/import for hashHerbert Xu
This patch adds the finup/export/import functions to the cryptd ahash implementation. We simply invoke the underlying shash operations. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-15crypto: cryptd - Fix uninitialized return valueSteffen Klassert
If cryptd_alloc_instance() fails, the return value is uninitialized. This patch fixes this by setting the return value. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: cryptd - Switch to new style ahashHerbert Xu
This patch changes cryptd to use the new style ahash type. In particular, the instance is enlarged to encapsulate the new ahash_alg structure. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: cryptd - Switch to template create APIHerbert Xu
This patch changes cryptd to use the template->create function instead of alloc in anticipation for the switch to new style ahash algorithms. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: cryptd - Use crypto_ahash_set_reqsizeHerbert Xu
This patch makes cryptd use crypto_ahash_set_reqsize to avoid accessing crypto_ahash directly. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: cryptd - Use shash algorithmsHerbert Xu
This patch changes cryptd to use shash algorithms instead of the legacy hash interface. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-06-02crypto: cryptd - Use nivcipher in cryptd_alloc_ablkcipher Huang Ying
Use crypto_alloc_base() instead of crypto_alloc_ablkcipher() to allocate underlying tfm in cryptd_alloc_ablkcipher. Because crypto_alloc_ablkcipher() prefer GENIV encapsulated crypto instead of raw one, while cryptd_alloc_ablkcipher needed the raw one. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-02-19crypto: cryptd - Per-CPU thread implementation based on kcrypto_wqHuang Ying
Original cryptd thread implementation has scalability issue, this patch solve the issue with a per-CPU thread implementation. struct cryptd_queue is defined to be a per-CPU queue, which holds one struct cryptd_cpu_queue for each CPU. In struct cryptd_cpu_queue, a struct crypto_queue holds all requests for the CPU, a struct work_struct is used to run all requests for the CPU. Testing based on dm-crypt on an Intel Core 2 E6400 (two cores) machine shows 19.2% performance gain. The testing script is as follow: -------------------- script begin --------------------------- #!/bin/sh dmc_create() { # Create a crypt device using dmsetup dmsetup create $2 --table "0 `blockdev --getsize $1` crypt cbc(aes-asm)?cryptd?plain:plain babebabebabebabebabebabebabebabe 0 $1 0" } dmsetup remove crypt0 dmsetup remove crypt1 dd if=/dev/zero of=/dev/ram0 bs=1M count=4 >& /dev/null dd if=/dev/zero of=/dev/ram1 bs=1M count=4 >& /dev/null dmc_create /dev/ram0 crypt0 dmc_create /dev/ram1 crypt1 cat >tr.sh <<EOF #!/bin/sh for n in \$(seq 10); do dd if=/dev/dm-0 of=/dev/null >& /dev/null & dd if=/dev/dm-1 of=/dev/null >& /dev/null & done wait EOF for n in $(seq 10); do /usr/bin/time sh tr.sh done rm tr.sh -------------------- script end --------------------------- The separator of dm-crypt parameter is changed from "-" to "?", because "-" is used in some cipher driver name too, and cryptds need to specify cipher driver name instead of cipher name. The test result on an Intel Core2 E6400 (two cores) is as follow: without patch: -----------------wo begin -------------------------- 0.04user 0.38system 0:00.39elapsed 107%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (0major+6566minor)pagefaults 0swaps 0.07user 0.35system 0:00.35elapsed 121%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (0major+6567minor)pagefaults 0swaps 0.06user 0.34system 0:00.30elapsed 135%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (0major+6562minor)pagefaults 0swaps 0.05user 0.37system 0:00.36elapsed 119%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (0major+6607minor)pagefaults 0swaps 0.06user 0.36system 0:00.35elapsed 120%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (0major+6562minor)pagefaults 0swaps 0.05user 0.37system 0:00.31elapsed 136%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (0major+6594minor)pagefaults 0swaps 0.04user 0.34system 0:00.30elapsed 126%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (0major+6597minor)pagefaults 0swaps 0.06user 0.32system 0:00.31elapsed 125%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (0major+6571minor)pagefaults 0swaps 0.06user 0.34system 0:00.31elapsed 134%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (0major+6581minor)pagefaults 0swaps 0.05user 0.38system 0:00.31elapsed 138%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (0major+6600minor)pagefaults 0swaps -----------------wo end -------------------------- with patch: ------------------w begin -------------------------- 0.02user 0.31system 0:00.24elapsed 141%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (0major+6554minor)pagefaults 0swaps 0.05user 0.34system 0:00.31elapsed 127%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (0major+6606minor)pagefaults 0swaps 0.07user 0.33system 0:00.26elapsed 155%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (0major+6559minor)pagefaults 0swaps 0.07user 0.32system 0:00.26elapsed 151%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (0major+6562minor)pagefaults 0swaps 0.05user 0.34system 0:00.26elapsed 150%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (0major+6603minor)pagefaults 0swaps 0.03user 0.36system 0:00.31elapsed 124%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (0major+6562minor)pagefaults 0swaps 0.04user 0.35system 0:00.26elapsed 147%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (0major+6586minor)pagefaults 0swaps 0.03user 0.37system 0:00.27elapsed 146%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (0major+6562minor)pagefaults 0swaps 0.04user 0.36system 0:00.26elapsed 154%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (0major+6594minor)pagefaults 0swaps 0.04user 0.35system 0:00.26elapsed 154%CPU (0avgtext+0avgdata 0maxresident)k 0inputs+0outputs (0major+6557minor)pagefaults 0swaps ------------------w end -------------------------- The middle value of elapsed time is: wo cryptwq: 0.31 w cryptwq: 0.26 The performance gain is about (0.31-0.26)/0.26 = 0.192. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-02-18crypto: cryptd - Add support to access underlying blkcipherHuang Ying
cryptd_alloc_ablkcipher() will allocate a cryptd-ed ablkcipher for specified algorithm name. The new allocated one is guaranteed to be cryptd-ed ablkcipher, so the blkcipher underlying can be gotten via cryptd_ablkcipher_child(). Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10crypto: hash - Move ahash functions into crypto/hash.hHerbert Xu
All new crypto interfaces should go into individual files as much as possible in order to ensure that crypto.h does not collapse under its own weight. This patch moves the ahash code into crypto/hash.h and crypto/internal/hash.h respectively. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10[CRYPTO] cryptd: Add asynchronous hash supportLoc Ho
This patch adds asynchronous hash support to crypto daemon. Signed-off-by: Loc Ho <lho@amcc.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10[CRYPTO] cryptd: Fix EINPROGRESS notification contextHerbert Xu
The EINPROGRESS notifications should be done just like the final call-backs, i.e., with BH off. This patch fixes the call in cryptd since previously it was called with BH on. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-05-01[CRYPTO] cryptd: Correct kzalloc error testJulia Lawall
Normally, kzalloc returns NULL or a valid pointer value, not a value to be tested using IS_ERR. Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-02-07Convert ERR_PTR(PTR_ERR(p)) instances to ERR_CAST(p)David Howells
Convert instances of ERR_PTR(PTR_ERR(p)) to ERR_CAST(p) using: perl -spi -e 's/ERR_PTR[(]PTR_ERR[(](.*)[)][)]/ERR_CAST(\1)/' `grep -rl 'ERR_PTR[(]*PTR_ERR' fs crypto net security` Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-11[CRYPTO] cryptd: Use geniv of the underlying algorithmHerbert Xu
If the underlying algorithm specifies a specific geniv algorithm then we should use it for the cryptd version as well. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] ablkcipher: Add distinct ABLKCIPHER typeHerbert Xu
Up until now we have ablkcipher algorithms have been identified as type BLKCIPHER with the ASYNC bit set. This is suboptimal because ablkcipher refers to two things. On the one hand it refers to the top-level ablkcipher interface with requests. On the other hand it refers to and algorithm type underneath. As it is you cannot request a synchronous block cipher algorithm with the ablkcipher interface on top. This is a problem because we want to be able to eventually phase out the blkcipher top-level interface. This patch fixes this by making ABLKCIPHER its own type, just as we have distinct types for HASH and DIGEST. The type it associated with the algorithm implementation only. Which top-level interface is used for synchronous block ciphers is then determined by the mask that's used. If it's a specific mask then the old blkcipher interface is given, otherwise we go with the new ablkcipher interface. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-10-10[CRYPTO] ablkcipher: Remove queue pointer from common alg objectHerbert Xu
Since not everyone needs a queue pointer and those who need it can always get it from the context anyway the queue pointer in the common alg object is redundant. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-05-31[CRYPTO] cryptd: Fix problem with cryptd and the freezerRafael J. Wysocki
Make sure that cryptd is marked as nonfreezable and does not hold up the freezer. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-05-02[CRYPTO] cryptd: Add software async crypto daemonHerbert Xu
This patch adds the cryptd module which is a template that takes a synchronous software crypto algorithm and converts it to an asynchronous one by executing it in a kernel thread. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
