path: root/crypto/crypto_null.c
2018-07-09crypto: shash - remove useless setting of type flagsEric Biggers
Many shash algorithms set .cra_flags = CRYPTO_ALG_TYPE_SHASH. But this is redundant with the C structure type ('struct shash_alg'), and crypto_register_shash() already sets the type flag automatically, clearing any type flag that was already there. Apparently the useless assignment has just been copy+pasted around. So, remove the useless assignment from all the shash algorithms. This patch shouldn't change any actual behavior. Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-07-18crypto: null - Remove default null blkcipherHerbert Xu
The default null blkcipher is no longer used and can now be removed. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-07-18crypto: null - Add new default null skcipherHerbert Xu
Current the default null skcipher is actually a crypto_blkcipher. This patch creates a synchronous crypto_skcipher version of the null cipher which unfortunately has to settle for the name skcipher2. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-05-22crypto: null - Add default null skcipherHerbert Xu
This patch adds a default null skcipher for users such as gcm to perform copies on SG lists. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-11-24crypto: prefix module autoloading with "crypto-"Kees Cook
This prefixes all crypto module loading with "crypto-" so we never run the risk of exposing module auto-loading to userspace via a crypto API, as demonstrated by Mathias Krause: https://lkml.org/lkml/2013/3/4/70 Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-03-21crypto: export NULL algorithms definesHoria Geanta
These defines might be needed by crypto drivers. Signed-off-by: Horia Geanta <horia.geanta@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-08-01crypto: crypto_null - use crypto_[un]register_algsJussi Kivilinna
Combine all crypto_alg to be registered and use new crypto_[un]register_algs functions. This simplifies init/exit code. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-02-16crypto: crypto_null - Fix checkpatch errorsRichard Hartmann
Signed-off-by: Richard Hartmann <richih.mailinglist@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: null - Switch to shashHerbert Xu
This patch changes digest_null to the new shash interface. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-04-21[CRYPTO] all: Clean up init()/fini()Kamalesh Babulal
On Thu, Mar 27, 2008 at 03:40:36PM +0100, Bodo Eggert wrote: > Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> wrote: > > > This patch cleanups the crypto code, replaces the init() and fini() > > with the <algorithm name>_init/_fini > > This part ist OK. > > > or init/fini_<algorithm name> (if the > > <algorithm name>_init/_fini exist) > > Having init_foo and foo_init won't be a good thing, will it? I'd start > confusing them. > > What about foo_modinit instead? Thanks for the suggestion, the init() is replaced with <algorithm name>_mod_init () and fini () is replaced with <algorithm name>_mod_fini. Signed-off-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] null: Allow setkey on digest_null Herbert Xu
We need to allow setkey on digest_null if it is to be used directly by authenc instead of through hmac. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] null: Add null blkcipher algorithmHerbert Xu
This patch adds a null blkcipher algorithm called ecb(cipher_null) for backwards compatibility. Previously the null algorithm when used by IPsec copied the data byte by byte. This new algorithm optimises that to a straight memcpy which lets us better measure inherent overheads in our IPsec code. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-11-02cleanup asm/scatterlist.h includesAdrian Bunk
Not architecture specific code should not #include <asm/scatterlist.h>. This patch therefore either replaces them with #include <linux/scatterlist.h> or simply removes them if they were unused. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-09-21[CRYPTO] api: Get rid of flags argument to setkeyHerbert Xu
Now that the tfm is passed directly to setkey instead of the ctx, we no longer need to pass the &tfm->crt_flags pointer. This patch also gets rid of a few unnecessary checks on the key length for ciphers as the cipher layer guarantees that the key length is within the bounds specified by the algorithm. Rather than testing dia_setkey every time, this patch does it only once during crypto_alloc_tfm. The redundant check from crypto_digest_setkey is also removed. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-06-26[CRYPTO] all: Pass tfm instead of ctx to algorithmsHerbert Xu
Up until now algorithms have been happy to get a context pointer since they know everything that's in the tfm already (e.g., alignment, block size). However, once we have parameterised algorithms, such information will be specific to each tfm. So the algorithm API needs to be changed to pass the tfm structure instead of the context pointer. This patch is basically a text substitution. The only tricky bit is the assembly routines that need to get the context pointer offset through asm-offsets.h. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2005-05-17[PATCH] crypto: fix null encryption/compressionPatrick McHardy
null_encrypt() needs to copy the data in case src and dst are disjunct, null_compress() needs to copy the data in any case as far as I can tell. I joined compress/decompress and encrypt/decrypt to avoid duplicating code. Without this patch ESP null_enc packets look like this: IP (tos 0x0, ttl 64, id 23130, offset 0, flags [DF], length: 128) 10.0.0.1 > 10.0.0.2: ESP(spi=0x0f9ca149,seq=0x4) 0x0000: 4500 0080 5a5a 4000 4032 cbef 0a00 0001 E...ZZ@.@2...... 0x0010: 0a00 0002 0f9c a149 0000 0004 0000 0000 .......I........ 0x0020: 0000 0000 0000 0000 0000 0000 0000 0000 ................ 0x0030: 0000 0000 0000 0000 0000 0000 0000 0000 ................ 0x0040: 0000 0000 0000 0000 0000 0000 0000 0000 ................ 0x0050: 0000 .. IP (tos 0x0, ttl 64, id 256, offset 0, flags [DF], length: 128) 10.0.0.2 > 10.0.0.1: ESP(spi=0x0e4f7b51,seq=0x2) 0x0000: 4500 0080 0100 4000 4032 254a 0a00 0002 E.....@.@2%J.... 0x0010: 0a00 0001 0e4f 7b51 0000 0002 a8a8 a8a8 .....O{Q........ 0x0020: a8a8 a8a8 a8a8 a8a8 a8a8 a8a8 a8a8 a8a8 ................ 0x0030: a8a8 a8a8 a8a8 a8a8 a8a8 a8a8 a8a8 a8a8 ................ 0x0040: a8a8 a8a8 a8a8 a8a8 a8a8 a8a8 a8a8 a8a8 ................ 0x0050: a8a8 .. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
