path: root/crypto/des_generic.c
2008-04-21[CRYPTO] all: Clean up init()/fini()Kamalesh Babulal
On Thu, Mar 27, 2008 at 03:40:36PM +0100, Bodo Eggert wrote: > Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> wrote: > > > This patch cleanups the crypto code, replaces the init() and fini() > > with the <algorithm name>_init/_fini > > This part ist OK. > > > or init/fini_<algorithm name> (if the > > <algorithm name>_init/_fini exist) > > Having init_foo and foo_init won't be a good thing, will it? I'd start > confusing them. > > What about foo_modinit instead? Thanks for the suggestion, the init() is replaced with <algorithm name>_mod_init () and fini () is replaced with <algorithm name>_mod_fini. Signed-off-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] hifn_795x: Detect weak keysEvgeniy Polyakov
HIFN driver update to use DES weak key checks (exported in this patch). Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] des: Create header file for common macrosEvgeniy Polyakov
This patch creates include/crypto/des.h for common macros shared between DES implementations. Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-10-10[CRYPTO] des: Rename des to des-genericSebastian Siewior
Loading the crypto algorithm by the alias instead of by module directly has the advantage that all possible implementations of this algorithm are loaded automatically and the crypto API can choose the best one depending on its priority. Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
