path: root/crypto/dh.c
2017-11-24crypto: dh - Fix double free of ctx->pEric Biggers
commit 12d41a023efb01b846457ccdbbcbe2b65a87d530 upstream. When setting the secret with the software Diffie-Hellman implementation, if allocating 'g' failed (e.g. if it was longer than MAX_EXTERN_MPI_BITS), then 'p' was freed twice: once immediately, and once later when the crypto_kpp tfm was destroyed. Fix it by using dh_free_ctx() (renamed to dh_clear_ctx()) in the error paths, as that correctly sets the pointers to NULL. KASAN report: MPI: mpi too large (32760 bits) ================================================================== BUG: KASAN: use-after-free in mpi_free+0x131/0x170 Read of size 4 at addr ffff88006c7cdf90 by task reproduce_doubl/367 CPU: 1 PID: 367 Comm: reproduce_doubl Not tainted 4.14.0-rc7-00040-g05298abde6fe #7 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011 Call Trace: dump_stack+0xb3/0x10b ? mpi_free+0x131/0x170 print_address_description+0x79/0x2a0 ? mpi_free+0x131/0x170 kasan_report+0x236/0x340 ? akcipher_register_instance+0x90/0x90 __asan_report_load4_noabort+0x14/0x20 mpi_free+0x131/0x170 ? akcipher_register_instance+0x90/0x90 dh_exit_tfm+0x3d/0x140 crypto_kpp_exit_tfm+0x52/0x70 crypto_destroy_tfm+0xb3/0x250 __keyctl_dh_compute+0x640/0xe90 ? kasan_slab_free+0x12f/0x180 ? dh_data_from_key+0x240/0x240 ? key_create_or_update+0x1ee/0xb20 ? key_instantiate_and_link+0x440/0x440 ? lock_contended+0xee0/0xee0 ? kfree+0xcf/0x210 ? SyS_add_key+0x268/0x340 keyctl_dh_compute+0xb3/0xf1 ? __keyctl_dh_compute+0xe90/0xe90 ? SyS_add_key+0x26d/0x340 ? entry_SYSCALL_64_fastpath+0x5/0xbe ? trace_hardirqs_on_caller+0x3f4/0x560 SyS_keyctl+0x72/0x2c0 entry_SYSCALL_64_fastpath+0x1f/0xbe RIP: 0033:0x43ccf9 RSP: 002b:00007ffeeec96158 EFLAGS: 00000246 ORIG_RAX: 00000000000000fa RAX: ffffffffffffffda RBX: 000000000248b9b9 RCX: 000000000043ccf9 RDX: 00007ffeeec96170 RSI: 00007ffeeec96160 RDI: 0000000000000017 RBP: 0000000000000046 R08: 0000000000000000 R09: 0248b9b9143dc936 R10: 0000000000001000 R11: 0000000000000246 R12: 0000000000000000 R13: 0000000000409670 R14: 0000000000409700 R15: 0000000000000000 Allocated by task 367: save_stack_trace+0x16/0x20 kasan_kmalloc+0xeb/0x180 kmem_cache_alloc_trace+0x114/0x300 mpi_alloc+0x4b/0x230 mpi_read_raw_data+0xbe/0x360 dh_set_secret+0x1dc/0x460 __keyctl_dh_compute+0x623/0xe90 keyctl_dh_compute+0xb3/0xf1 SyS_keyctl+0x72/0x2c0 entry_SYSCALL_64_fastpath+0x1f/0xbe Freed by task 367: save_stack_trace+0x16/0x20 kasan_slab_free+0xab/0x180 kfree+0xb5/0x210 mpi_free+0xcb/0x170 dh_set_secret+0x2d7/0x460 __keyctl_dh_compute+0x623/0xe90 keyctl_dh_compute+0xb3/0xf1 SyS_keyctl+0x72/0x2c0 entry_SYSCALL_64_fastpath+0x1f/0xbe Fixes: 802c7f1c84e4 ("crypto: dh - Add DH software implementation") Signed-off-by: Eric Biggers <ebiggers@google.com> Reviewed-by: Tudor Ambarus <tudor.ambarus@microchip.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-24crypto: dh - fix memleak in setkeyTudor-Dan Ambarus
commit ee34e2644a78e2561742bea8c4bdcf83cabf90a7 upstream. setkey can be called multiple times during the existence of the transformation object. In case of multiple setkey calls, the old key was not freed and we leaked memory. Free the old MPI key if any. Signed-off-by: Tudor Ambarus <tudor.ambarus@microchip.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-07-01crypto: rsa - Generate fixed-length outputHerbert Xu
Every implementation of RSA that we have naturally generates output with leading zeroes. The one and only user of RSA, pkcs1pad wants to have those leading zeroes in place, in fact because they are currently absent it has to write those zeroes itself. So we shouldn't be stripping leading zeroes in the first place. In fact this patch makes rsa-generic produce output with fixed length so that pkcs1pad does not need to do any extra work. This patch also changes DH to use the new interface. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-06-23crypto: dh - Add DH software implementationSalvatore Benedetto
* Implement MPI based Diffie-Hellman under kpp API * Test provided uses data generad by OpenSSL Signed-off-by: Salvatore Benedetto <salvatore.benedetto@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
