path: root/crypto/gcm.c
2010-01-17crypto: gcm - Add RFC4543 wrapper for GCMTobias Brunner
This patch adds the RFC4543 (GMAC) wrapper for GCM similar to the existing RFC4106 wrapper. The main differences between GCM and GMAC are the contents of the AAD and that the plaintext is empty for the latter. Signed-off-by: Tobias Brunner <tobias@strongswan.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-11-16crypto: gcm - fix another complete call in complete fuctionHuang Ying
The flow of the complete function (xxx_done) in gcm.c is as follow: void complete(struct crypto_async_request *areq, int err) { struct aead_request *req = areq->data; if (!err) { err = async_next_step(); if (err == -EINPROGRESS || err == -EBUSY) return; } complete_for_next_step(areq, err); } But *areq may be destroyed in async_next_step(), this makes complete_for_next_step() can not work properly. To fix this, one of following methods is used for each complete function. - Add a __complete() for each complete(), which accept struct aead_request *req instead of areq, so avoid using areq after it is destroyed. - Expand complete_for_next_step(). The fixing method is based on the idea of Herbert Xu. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-08-06crypto: gcm - Use GHASH digest algorithmHuang Ying
Remove the dedicated GHASH implementation in GCM, and uses the GHASH digest algorithm instead. This will make GCM uses hardware accelerated GHASH implementation automatically if available. ahash instead of shash interface is used, because some hardware accelerated GHASH implementation needs asynchronous interface. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] gcm: Introduce rfc4106Herbert Xu
This patch introduces the rfc4106 wrapper for GCM just as we have an rfc4309 wrapper for CCM. The purpose of the wrapper is to include part of the IV in the key so that it can be negotiated by IPsec. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] gcm: Use crypto_grab_skcipherHerbert Xu
This patch converts the gcm algorithm over to crypto_grab_skcipher which is a prerequisite for IV generation. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] gcm: Allow block cipher parameterHerbert Xu
This patch adds the gcm_base template which takes a block cipher parameter instead of cipher. This allows the user to specify a specific CTR implementation. This also fixes a leak of the cipher algorithm that was previously looked up but never freed. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] gcm: Add support for async ciphersHerbert Xu
This patch adds the necessary changes for GCM to be used with async ciphers. This would allow it to be used with hardware devices that support CTR. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] ctr: Refactor into ctr and rfc3686Herbert Xu
As discussed previously, this patch moves the basic CTR functionality into a chainable algorithm called ctr. The IPsec-specific variant of it is now placed on top with the name rfc3686. So ctr(aes) gives a chainable cipher with IV size 16 while the IPsec variant will be called rfc3686(ctr(aes)). This patch also adjusts gcm accordingly. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] gcm: Fix request context alignmentHerbert Xu
This patch fixes the request context alignment so that it is actually aligned to the value required by the algorithm. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] gcm: Put abreq in private context instead of on stackHerbert Xu
The abreq structure is currently allocated on the stack. This is broken if the underlying algorithm is asynchronous. This patch changes it so that it's taken from the private context instead which has been enlarged accordingly. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] scatterwalk: Restore custom sg chaining for nowHerbert Xu
Unfortunately the generic chaining hasn't been ported to all architectures yet, and notably not s390. So this patch restores the chainging that we've been using previously which does work everywhere. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] scatterwalk: Move scatterwalk.h to linux/cryptoHerbert Xu
The scatterwalk infrastructure is used by algorithms so it needs to move out of crypto for future users that may live in drivers/crypto or asm/*/crypto. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] aead: Return EBADMSG for ICV mismatchHerbert Xu
This patch changes gcm/authenc to return EBADMSG instead of EINVAL for ICV mismatches. This convention has already been adopted by IPsec. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] gcm: Fix ICV handlingHerbert Xu
The crypto_aead convention for ICVs is to include it directly in the output. If we decided to change this in future then we would make the ICV (if the algorithm has an explicit one) available in the request itself. For now no algorithm needs this so this patch changes gcm to conform to this convention. It also adjusts the tcrypt aead tests to take this into account. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] aead: Make authsize a run-time parameterHerbert Xu
As it is authsize is an algorithm paramter which cannot be changed at run-time. This is inconvenient because hardware that implements such algorithms would have to register each authsize that they support separately. Since authsize is a property common to all AEAD algorithms, we can add a function setauthsize that sets it at run-time, just like setkey. This patch does exactly that and also changes authenc so that authsize is no longer a parameter of its template. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] gcm: New algorithmMikko Herranen
Add GCM/GMAC support to cryptoapi. GCM (Galois/Counter Mode) is an AEAD mode of operations for any block cipher with a block size of 16. The typical example is AES-GCM. Signed-off-by: Mikko Herranen <mh1@iki.fi> Reviewed-by: Mika Kukkonen <mika.kukkonen@nsn.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
