path: root/crypto/lrw.c
2011-11-09crypto: lrw - add interface for parallelized cipher implementionsJussi Kivilinna
Export gf128mul table initialization routines and add lrw_crypt() function that can be used by cipher implementations that can benefit from parallelized cipher operations. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-09crypto: lrw - split gf128mul table initialization from setkeyJussi Kivilinna
Split gf128mul initialization from setkey so that it can be used outside lrw-module. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-09crypto: lrw - use blocksize constantJussi Kivilinna
LRW has fixed blocksize of 16. Define LRW_BLOCK_SIZE and use in place of crypto_cipher_blocksize(). Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-09crypto: lrw - fix memleakJussi Kivilinna
LRW module leaks child cipher memory when init_tfm() fails because of child block size not being 16. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-02-17crypto: lrw - Fix big endian supportHerbert Xu
It turns out that LRW has never worked properly on big endian. This was never discussed because nobody actually used it that way. In fact, it was only discovered when Geert Uytterhoeven loaded it through tcrypt which failed the test on it. The fix is straightforward, on big endian the to find the nth bit we should be grouping them by words instead of bytes. So setbit128_bbe should xor with 128 - BITS_PER_LONG instead of 128 - BITS_PER_BYTE == 0x78. Tested-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-04-21[CRYPTO] lrw: Replace all adds to big endians variables with be*_add_cpuMarcin Slusarz
replace all: big_endian_variable = cpu_to_beX(beX_to_cpu(big_endian_variable) + expression_in_cpu_byteorder); with: beX_add_cpu(&big_endian_variable, expression_in_cpu_byteorder); Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: David S. Miller <davem@davemloft.net> Cc: Roel Kluin <12o3l@tiscali.nl> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-02-07Convert ERR_PTR(PTR_ERR(p)) instances to ERR_CAST(p)David Howells
Convert instances of ERR_PTR(PTR_ERR(p)) to ERR_CAST(p) using: perl -spi -e 's/ERR_PTR[(]PTR_ERR[(](.*)[)][)]/ERR_CAST(\1)/' `grep -rl 'ERR_PTR[(]*PTR_ERR' fs crypto net security` Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-02[CRYPTO] templates: Pass type/mask when creating instancesHerbert Xu
This patch passes the type/mask along when constructing instances of templates. This is in preparation for templates that may support multiple types of instances depending on what is requested. For example, the planned software async crypto driver will use this construct. For the moment this allows us to check whether the instance constructed is of the correct type and avoid returning success if the type does not match. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-02-07[CRYPTO] api: Add type-safe spawnsHerbert Xu
This patch allows spawns of specific types (e.g., cipher) to be allocated. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-12-06[CRYPTO] lrw: round --> lrw_roundDavid S. Miller
Fixes: crypto/lrw.c:99: warning: conflicting types for built-in function ‘round’ Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-06[CRYPTO] lrw: Liskov Rivest Wagner, a tweakable narrow block cipher modeRik Snel
Main module, this implements the Liskov Rivest Wagner block cipher mode in the new blockcipher API. The implementation is based on ecb.c. The LRW-32-AES specification I used can be found at: http://grouper.ieee.org/groups/1619/email/pdf00017.pdf It implements the optimization specified as optional in the specification, and in addition it uses optimized multiplication routines from gf128mul.c. Since gf128mul.[ch] is not tested on bigendian, this cipher mode may currently fail badly on bigendian machines. Signed-off-by: Rik Snel <rsnel@cube.dyndns.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
