We are going to use this for TCP/IP sequence number and fragment ID
generation.
This patch changes md5 to the new shash interface.
Signed-off-by: Adrian-Ken Rueegsegger <ken@codelabs.ch>
On Thu, Mar 27, 2008 at 03:40:36PM +0100, Bodo Eggert wrote:
> Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> wrote:
> > This patch cleanups the crypto code, replaces the init() and fini()
> > with the <algorithm name>_init/_fini
> This part ist OK.
> > or init/fini_<algorithm name> (if the
> > <algorithm name>_init/_fini exist)
> Having init_foo and foo_init won't be a good thing, will it? I'd start
> confusing them.
> What about foo_modinit instead?
Thanks for the suggestion, the init() is replaced with
<algorithm name>_mod_init ()
and fini () is replaced with <algorithm name>_mod_fini.
Signed-off-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com>
Up until now algorithms have been happy to get a context pointer since
they know everything that's in the tfm already (e.g., alignment, block
size).
However, once we have parameterised algorithms, such information will
be specific to each tfm. So the algorithm API needs to be changed to
pass the tfm structure instead of the context pointer.
This patch is basically a text substitution. The only tricky bit is
the assembly routines that need to get the context pointer offset
through asm-offsets.h.
A lot of crypto code needs to read/write a 32-bit/64-bit words in a
specific gender. Many of them open code them by reading/writing one
byte at a time. This patch converts all the applicable usages over
to use the standard byte order macros.
This is based on a previous patch by Denis Vlasenko.
infrastructure for it.
Let it rip!
