commit 5d26a105b5a73e5635eae0629b42fa0a90e07b7b upstream.
This prefixes all crypto module loading with "crypto-" so we never run
the risk of exposing module auto-loading to userspace via a crypto API,
as demonstrated by Mathias Krause:
https://lkml.org/lkml/2013/3/4/70
This patch changes michael_mic to the new shash interface.
Signed-off-by: Adrian-Ken Rueegsegger <ken@codelabs.ch>
After 13 years of use, it looks like my email address is finally going
to disappear. While this is likely to drop the amount of incoming spam
greatly ;-), it may also affect more appropriate messages, so let's
update my email address in various places. In addition, Host AP mailing
list is subscribers-only and linux-wireless can also be used for
discussing issues related to this driver which is now shown in
MAINTAINERS.
Signed-off-by: Jouni Malinen <j@w1.fi>
Now that the tfm is passed directly to setkey instead of the ctx, we no
longer need to pass the &tfm->crt_flags pointer.
This patch also gets rid of a few unnecessary checks on the key length
for ciphers as the cipher layer guarantees that the key length is within
the bounds specified by the algorithm.
Rather than testing dia_setkey every time, this patch does it only once
during crypto_alloc_tfm. The redundant check from crypto_digest_setkey
is also removed.
Up until now algorithms have been happy to get a context pointer since
they know everything that's in the tfm already (e.g., alignment, block
size).
However, once we have parameterised algorithms, such information will
be specific to each tfm. So the algorithm API needs to be changed to
pass the tfm structure instead of the context pointer.
This patch is basically a text substitution. The only tricky bit is
the assembly routines that need to get the context pointer offset
through asm-offsets.h.
Some hash modules load/store data words directly. The digest layer
should pass properly aligned buffer to update()/final() method. This
patch also add cra_alignmask to some hash modules.
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
A lot of crypto code needs to read/write a 32-bit/64-bit words in a
specific gender. Many of them open code them by reading/writing one
byte at a time. This patch converts all the applicable usages over
to use the standard byte order macros.
This is based on a previous patch by Denis Vlasenko.
infrastructure for it.
Let it rip!
