commit e8d998264bffade3cfe0536559f712ab9058d654 upstream.
We should not be modifying the original request's MAY_SLEEP flag
upon completion. It makes no sense to do so anyway.
Reported-by: Eric Biggers <ebiggers@kernel.org>
Fixes: 5068c7a883d1 ("crypto: pcrypt - Add pcrypt crypto...")
Tested-by: Eric Biggers <ebiggers@kernel.org>
[ Upstream commit 07bfd9bdf568a38d9440c607b72342036011f727 ]
On module unload of pcrypt we must unregister the crypto algorithms
first and then tear down the padata structure. As otherwise the
crypto algorithms are still alive and can be used while the padata
structure is being freed.
Cc: <stable@vger.kernel.org>
[ Upstream commit b1e3874c75ab15288f573b3532e507c37e8e7656 ]
Passing string 'name' as the format specifier is potentially hazardous
because name could (although very unlikely to) have a format specifier
embedded in it causing issues when parsing the non-existent arguments
to these. Follow best practice by using the "%s" format string for
the string 'name'.
Cleans up clang warning:
crypto/pcrypt.c:397:40: warning: format string is not a string literal
(potentially insecure) [-Wformat-security]
Fixes: a3fb1e330dd2 ("pcrypt: Added sysfs interface to pcrypt")
commit d76c68109f37cb85b243a1cf0f40313afd2bae68 upstream.
pcrypt is using the old way of freeing instances, where the ->free()
method specified in the 'struct crypto_template' is passed a pointer to
the 'struct crypto_instance'. But the crypto_instance is being
kfree()'d directly, which is incorrect because the memory was actually
allocated as an aead_instance, which contains the crypto_instance at a
nonzero offset. Thus, the wrong pointer was being kfree()'d.
Fix it by switching to the new way to free aead_instance's where the
->free() method is specified in the aead_instance itself.
Reported-by: syzbot <syzkaller@googlegroups.com>
Fixes: 0496f56065e0 ("crypto: pcrypt - Add support for new AEAD interface")
This patch removes the CRYPTO_ALG_AEAD_NEW flag now that everyone
has been converted.
This patch allows the CRYPTO_ALG_AEAD_NEW flag to be propagated.
It also restores the ASYNC bit that went missing during the AEAD
conversion.
This patch converts pcrypt over to the new AEAD interface.
The variable tfm_count is accessed by multiple threads without
locking. This patch converts it to an atomic_t.
As AEAD has switched over to using frontend types, the function
crypto_init_spawn must not be used since it does not specify a
frontend type. Otherwise it leads to a crash when the spawn is
used.
This patch fixes it by switching over to crypto_grab_aead instead.
Fixes: 5d1d65f8bea6 ("crypto: aead - Convert top level interface to new style")
This patch uses the crypto_aead_set_reqsize helper to avoid directly
touching the internals of aead.
This adds the module loading prefix "crypto-" to the template lookup
as well.
For example, attempting to load 'vfat(blowfish)' via AF_ALG now correctly
includes the "crypto-" prefix at every level, correctly rejecting "vfat":
net-pf-38
algif-hash
crypto-vfat(blowfish)
crypto-vfat(blowfish)-all
crypto-vfat
Reported-by: Mathias Krause <minipli@googlemail.com>
Acked-by: Mathias Krause <minipli@googlemail.com>
A kernel with enabled lockdep complains about the wrong usage of
rcu_dereference() under a rcu_read_lock_bh() protected region.
[ INFO: suspicious RCU usage. ]
3.13.0-rc1+ #126 Not tainted
linux/crypto/pcrypt.c:81 suspicious rcu_dereference_check() usage!
rcu_scheduler_active = 1, debug_locks = 1
1 lock held by cryptomgr_test/153:
#0: (rcu_read_lock_bh){.+....}, at: [<ffffffff812c8075>] pcrypt_do_parallel.isra.2+0x5/0x200
Fix that by using rcu_dereference_bh() instead.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Acked-by: Steffen Klassert <steffen.klassert@secunet.com>
For the workqueue creation interfaces that do not expect format strings,
make sure they cannot accidently be parsed that way. Additionally, clean
up calls made with a single parameter that would be handled as a format
string. Many callers are passing potentially dynamic string content, so
use "%s" in those cases to avoid any potential accidents.
We use the active cpumask to determine the superset of cpus
to use for parallelization. However, the active cpumask is
for internal usage of the scheduler and therefore not the
appropriate cpumask for these purposes. So use the online
cpumask instead.
Reported-by: Peter Zijlstra <peterz@infradead.org>
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (46 commits)
hwrng: via_rng - Fix memory scribbling on some CPUs
crypto: padlock - Move padlock.h into include/crypto
hwrng: via_rng - Fix asm constraints
crypto: n2 - use __devexit not __exit in n2_unregister_algs
crypto: mark crypto workqueues CPU_INTENSIVE
crypto: mv_cesa - dont return PTR_ERR() of wrong pointer
crypto: ripemd - Set module author and update email address
crypto: omap-sham - backlog handling fix
crypto: gf128mul - Remove experimental tag
crypto: af_alg - fix af_alg memory_allocated data type
crypto: aesni-intel - Fixed build with binutils 2.16
crypto: af_alg - Make sure sk_security is initialized on accept()ed sockets
net: Add missing lockdep class names for af_alg
include: Install linux/if_alg.h for user-space crypto API
crypto: omap-aes - checkpatch --file warning fixes
crypto: omap-aes - initialize aes module once per request
crypto: omap-aes - unnecessary code removed
crypto: omap-aes - error handling implementation improved
crypto: omap-aes - redundant locking is removed
crypto: omap-aes - DMA initialization fixes for OMAP off mode
kcrypto_wq and pcrypt->wq's are used to run ciphers and may consume
considerable amount of CPU cycles. Mark both as CPU_INTENSIVE so that
they don't block other work items.
As the workqueues are primarily used to burn CPU cycles, concurrency
levels shouldn't matter much and are left at 1. A higher value may be
beneficial and needs investigation.
kobject_put is called from padata_free for the padata kobject.
The kobject's release function frees the padata instance,
so don't call kobject_put for the padata kobject from pcrypt.
Reported-and-tested-by: Randy Dunlap <randy.dunlap@oracle.com>
The padata cpumask change notifier passes a padata_cpumask to the
notifier chain. So we use this cpumask instead of asking padata for
the cpumask.
In the crypto-layer an instance refers usually to a crypto instance.
The struct pcrypt_instance is not related to a crypto instance.
It rather contains the padata informations, so we rename it to
padata_pcrypt. The functions that handle this struct are renamed
accordingly.
We rename padata_alloc to padata_alloc_possible because this
function allocates a padata_instance and uses the cpu_possible
mask for parallel and serial workers. Also we rename __padata_alloc
to padata_alloc to avoid to export underlined functions. Underlined
functions are considered to be private to padata. Users are updated
accordingly.
If the callback cpumask is empty, we crash with a division by zero
when we try to calculate a callback cpu. So we don't update the callback
cpu in pcrypt_do_parallel if the callback cpumask is empty.
Added sysfs interface to pcrypt. Now pcrypt subsystem creates two
sysfs directories with corresponding padata sysfs objects:
/sys/kernel/pcrypt/[pencrypt|pdecrypt]
Signed-off-by: Dan Kruchinin <dkruchinin@acm.org>
The aim of this patch is to make two separate cpumasks
for padata parallel and serial workers respectively.
It allows user to make more thin and sophisticated configurations
of padata framework. For example user may bind parallel and serial workers to non-intersecting
CPU groups to gain better performance. Also each padata instance has notifiers chain for its
cpumasks now. If either parallel or serial or both masks were changed all
interested subsystems will get notification about that. It's especially useful
if padata user uses algorithm for callback CPU selection according to serial cpumask.
To return -EINPROGRESS on success in padata_do_parallel was
considered to be odd. This patch changes this to return zero
on success. Also the only user of padata, pcrypt is adapted to
convert a return of zero to -EINPROGRESS within the crypto layer.
This also removes the pcrypt fallback if padata_do_parallel
was called on a not running padata instance as we can't handle it
anymore. This fallback was unused, so it's save to remove it.
This patch introduces the PADATA_INVALID flag which is
checked on padata start. This will be used to mark a padata
instance as invalid, if the padata cpumask does not intersect
with the active cpumask. we change padata_start to return an
error if the PADATA_INVALID is set. Also we adapt the only
padata user, pcrypt to this change.
I was concerned about the error handling for crypto_get_attr_type() in
pcrypt_alloc_aead(). Steffen Klassert pointed out that we could simply
avoid calling crypto_get_attr_type() if we passed the type and mask as a
parameters.
This fixes three forgotten calls to the complete function
in the error case.
This patch adds a parallel crypto template that takes a crypto
algorithm and converts it to process the crypto transforms in
parallel. For the moment only aead algorithms are supported.
