path: root/crypto/pcrypt.c
2014-11-26crypto: include crypto- module prefix in templateKees Cook
This adds the module loading prefix "crypto-" to the template lookup as well. For example, attempting to load 'vfat(blowfish)' via AF_ALG now correctly includes the "crypto-" prefix at every level, correctly rejecting "vfat": net-pf-38 algif-hash crypto-vfat(blowfish) crypto-vfat(blowfish)-all crypto-vfat Reported-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-12-05crypto: pcrypt - Fix wrong usage of rcu_dereference()Mathias Krause
A kernel with enabled lockdep complains about the wrong usage of rcu_dereference() under a rcu_read_lock_bh() protected region. =============================== [ INFO: suspicious RCU usage. ] 3.13.0-rc1+ #126 Not tainted ------------------------------- linux/crypto/pcrypt.c:81 suspicious rcu_dereference_check() usage! other info that might help us debug this: rcu_scheduler_active = 1, debug_locks = 1 1 lock held by cryptomgr_test/153: #0: (rcu_read_lock_bh){.+....}, at: [<ffffffff812c8075>] pcrypt_do_parallel.isra.2+0x5/0x200 Fix that by using rcu_dereference_bh() instead. Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-07-03drivers: avoid format strings in names passed to alloc_workqueue()Kees Cook
For the workqueue creation interfaces that do not expect format strings, make sure they cannot accidently be parsed that way. Additionally, clean up calls made with a single parameter that would be handled as a format string. Many callers are passing potentially dynamic string content, so use "%s" in those cases to avoid any potential accidents. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-29crypto: pcrypt - Use the online cpumask as the defaultSteffen Klassert
We use the active cpumask to determine the superset of cpus to use for parallelization. However, the active cpumask is for internal usage of the scheduler and therefore not the appropriate cpumask for these purposes. So use the online cpumask instead. Reported-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-01-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (46 commits) hwrng: via_rng - Fix memory scribbling on some CPUs crypto: padlock - Move padlock.h into include/crypto hwrng: via_rng - Fix asm constraints crypto: n2 - use __devexit not __exit in n2_unregister_algs crypto: mark crypto workqueues CPU_INTENSIVE crypto: mv_cesa - dont return PTR_ERR() of wrong pointer crypto: ripemd - Set module author and update email address crypto: omap-sham - backlog handling fix crypto: gf128mul - Remove experimental tag crypto: af_alg - fix af_alg memory_allocated data type crypto: aesni-intel - Fixed build with binutils 2.16 crypto: af_alg - Make sure sk_security is initialized on accept()ed sockets net: Add missing lockdep class names for af_alg include: Install linux/if_alg.h for user-space crypto API crypto: omap-aes - checkpatch --file warning fixes crypto: omap-aes - initialize aes module once per request crypto: omap-aes - unnecessary code removed crypto: omap-aes - error handling implementation improved crypto: omap-aes - redundant locking is removed crypto: omap-aes - DMA initialization fixes for OMAP off mode ...
2011-01-04crypto: mark crypto workqueues CPU_INTENSIVETejun Heo
kcrypto_wq and pcrypt->wq's are used to run ciphers and may consume considerable amount of CPU cycles. Mark both as CPU_INTENSIVE so that they don't block other work items. As the workqueues are primarily used to burn CPU cycles, concurrency levels shouldn't matter much and are left at 1. A higher value may be beneficial and needs investigation. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-11-12crypto: pcrypt - Fix use after free on padata_freeSteffen Klassert
kobject_put is called from padata_free for the padata kobject. The kobject's release function frees the padata instance, so don't call kobject_put for the padata kobject from pcrypt. Reported-and-tested-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-07-31crypto: pcrypt - Update pcrypt cpumask according to the padata cpumask notifierSteffen Klassert
The padata cpumask change notifier passes a padata_cpumask to the notifier chain. So we use this cpumask instead of asking padata for the cpumask. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-07-31crypto: pcrypt - Rename pcrypt_instanceSteffen Klassert
In the crypto-layer an instance refers usually to a crypto instance. The struct pcrypt_instance is not related to a crypto instance. It rather contains the padata informations, so we rename it to padata_pcrypt. The functions that handle this struct are renamed accordingly. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-07-31padata: Rename padata_alloc functionsSteffen Klassert
We rename padata_alloc to padata_alloc_possible because this function allocates a padata_instance and uses the cpu_possible mask for parallel and serial workers. Also we rename __padata_alloc to padata_alloc to avoid to export underlined functions. Underlined functions are considered to be private to padata. Users are updated accordingly. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-07-26crypto: pcrypt - Dont calulate a callback cpu on empty callback cpumaskSteffen Klassert
If the callback cpumask is empty, we crash with a division by zero when we try to calculate a callback cpu. So we don't update the callback cpu in pcrypt_do_parallel if the callback cpumask is empty. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-07-19pcrypt: Added sysfs interface to pcryptDan Kruchinin
Added sysfs interface to pcrypt. Now pcrypt subsystem creates two sysfs directories with corresponding padata sysfs objects: /sys/kernel/pcrypt/[pencrypt|pdecrypt] Signed-off-by: Dan Kruchinin <dkruchinin@acm.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-07-19padata: Make two separate cpumasksDan Kruchinin
The aim of this patch is to make two separate cpumasks for padata parallel and serial workers respectively. It allows user to make more thin and sophisticated configurations of padata framework. For example user may bind parallel and serial workers to non-intersecting CPU groups to gain better performance. Also each padata instance has notifiers chain for its cpumasks now. If either parallel or serial or both masks were changed all interested subsystems will get notification about that. It's especially useful if padata user uses algorithm for callback CPU selection according to serial cpumask. Signed-off-by: Dan Kruchinin <dkruchinin@acm.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-07-14padata: make padata_do_parallel to return zero on successSteffen Klassert
To return -EINPROGRESS on success in padata_do_parallel was considered to be odd. This patch changes this to return zero on success. Also the only user of padata, pcrypt is adapted to convert a return of zero to -EINPROGRESS within the crypto layer. This also removes the pcrypt fallback if padata_do_parallel was called on a not running padata instance as we can't handle it anymore. This fallback was unused, so it's save to remove it. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-07-14padata: Check for valid padata instance on startSteffen Klassert
This patch introduces the PADATA_INVALID flag which is checked on padata start. This will be used to mark a padata instance as invalid, if the padata cpumask does not intersect with the active cpumask. we change padata_start to return an error if the PADATA_INVALID is set. Also we adapt the only padata user, pcrypt to this change. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-03-24crypto: pcrypt - Handle crypto_get_attr_type errorsDan Carpenter
I was concerned about the error handling for crypto_get_attr_type() in pcrypt_alloc_aead(). Steffen Klassert pointed out that we could simply avoid calling crypto_get_attr_type() if we passed the type and mask as a parameters. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-02-04crypto: pcrypt - call the complete function on errorSteffen Klassert
This fixes three forgotten calls to the complete function in the error case. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-01-07crypto: pcrypt - Add pcrypt crypto parallelization wrapperSteffen Klassert
This patch adds a parallel crypto template that takes a crypto algorithm and converts it to process the crypto transforms in parallel. For the moment only aead algorithms are supported. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
