path: root/crypto/proc.c
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: hwrng: core - Prevent too-small buffer sizes hwrng: virtio-rng - Convert to new API hwrng: core - Replace u32 in driver API with byte array crypto: ansi_cprng - Move FIPS functions under CONFIG_CRYPTO_FIPS crypto: testmgr - Add ghash algorithm test before provide to users crypto: ghash-clmulni-intel - Put proper .data section in place crypto: ghash-clmulni-intel - Use gas macro for PCLMULQDQ-NI and PSHUFB crypto: aesni-intel - Use gas macro for AES-NI instructions x86: Generate .byte code for some new instructions via gas macro crypto: ghash-intel - Fix irq_fpu_usable usage crypto: ghash-intel - Add PSHUFB macros crypto: ghash-intel - Hard-code pshufb crypto: ghash-intel - Fix building failure on x86_32 crypto: testmgr - Fix warning crypto: ansi_cprng - Fix test in get_prng_bytes crypto: hash - Remove cra_u.{digest,hash} crypto: api - Remove digest case from procfs show handler crypto: hash - Remove legacy hash/digest code crypto: ansi_cprng - Add FIPS wrapper crypto: ghash - Add PCLMULQDQ accelerated implementation
2009-11-18sysctl: Drop & in front of every proc_handler.Eric W. Biederman
For consistency drop & in front of every proc_handler. Explicity taking the address is unnecessary and it prevents optimizations like stubbing the proc_handlers to NULL. Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Joe Perches <joe@perches.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-11-12sysctl crypto: Remove dead binary sysctl supportEric W. Biederman
Now that sys_sysctl is a generic wrapper around /proc/sys .ctl_name and .strategy members of sysctl tables are dead code. Remove them. Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-10-19crypto: api - Remove digest case from procfs show handlerBenjamin Gilbert
Remove special handling of old-style digest algorithms from the procfs show handler. Signed-off-by: Benjamin Gilbert <bgilbert@cs.cmu.edu> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: api - Call type show function before legacy for procHerbert Xu
This patch makes /proc/crypto call the type-specific show function if one is present before calling the legacy show functions for cipher/digest/compress. This allows us to reuse the type values for those legacy types. In particular, hash and digest will share one type value while shash is phased in as the default hash type. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: api - Add fips_enable flagNeil Horman
Add the ability to turn FIPS-compliant mode on or off at boot In order to be FIPS compliant, several check may need to be preformed that may be construed as unusefull in a non-compliant mode. This patch allows us to set a kernel flag incating that we are running in a fips-compliant mode from boot up. It also exports that mode information to user space via a sysctl (/proc/sys/crypto/fips_enabled). Tested successfully by me. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: api - Use test infrastructureHerbert Xu
This patch makes use of the new testing infrastructure by requiring algorithms to pass a run-time test before they're made available to users. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: api - Display larval objects properlyHerbert Xu
Rather than displaying larval objects as real objects, this patch makes them show up under /proc/crypto as of type larval. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-04-21[CRYPTO] api: Constify function pointer tablesJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-04-21[CRYPTO] api: Switch to proc_create()Alexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-07-16Make crypto API use seq_list_xxx helpersPavel Emelianov
Simple and stupid - just use the same code from another place in the kernel. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct file_operations const 3Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-21[CRYPTO] api: Added crypto_type supportHerbert Xu
This patch adds the crypto_type structure which will be used for all new crypto algorithm types, beginning with block ciphers. The primary purpose of this abstraction is to allow different crypto_type objects for crypto algorithms of the same type, in particular, there will be a different crypto_type objects for asynchronous algorithms. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-09-21[CRYPTO] api: Split out low-level APIHerbert Xu
The crypto API is made up of the part facing users such as IPsec and the low-level part which is used by cryptographic entities such as algorithms. This patch splits out the latter so that the two APIs are more clearly delineated. As a bonus the low-level API can now be modularised if all algorithms are built as modules. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-09-21[CRYPTO] api: Add crypto_alg reference countingHerbert Xu
Up until now we've relied on module reference counting to ensure that the crypto_alg structures don't disappear from under us. This was good enough as long as each crypto_alg came from exactly one module. However, with parameterised crypto algorithms a crypto_alg object may need two or more modules to operate. This means that we need to count the references to the crypto_alg object directly. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-09[CRYPTO] Allow multiple implementations of the same algorithmHerbert Xu
This is the first step on the road towards asynchronous support in the Crypto API. It adds support for having multiple crypto_alg objects for the same algorithm registered in the system. For example, each device driver would register a crypto_alg object for each algorithm that it supports. While at the same time the user may load software implementations of those same algorithms. Users of the Crypto API may then select a specific implementation by name, or choose any implementation for a given algorithm with the highest priority. The priority field is a 32-bit signed integer. In future it will be possible to modify it from user-space. This also provides a solution to the problem of selecting amongst various AES implementations, that is, aes vs. aes-i586 vs. aes-padlock. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
