path: root/crypto/rmd160.c
2014-11-24crypto: prefix module autoloading with "crypto-"Kees Cook
This prefixes all crypto module loading with "crypto-" so we never run the risk of exposing module auto-loading to userspace via a crypto API, as demonstrated by Mathias Krause: https://lkml.org/lkml/2013/3/4/70 Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-01-04crypto: ripemd - Set module author and update email addressAdrian-Ken Rueegsegger
Signed-off-by: Adrian-Ken Rueegsegger <ken@codelabs.ch> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: rmd160 - Switch to shashHerbert Xu
This patch changes rmd160 to the new shash interface. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10crypto: rmd - sparse annotationsHarvey Harrison
Similar to the rmd128.c annotations, significantly cuts down on the noise. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10[CRYPTO] rmd: Use pointer form of endian swapping operationsHerbert Xu
This patch converts the relevant code in the rmd implementations to use the pointer form of the endian swapping operations. This allows certain architectures to generate more optimised code. For example, on sparc64 this more than halves the CPU cycles on a typical hashing operation. Based on a patch by David Miller. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10[CRYPTO] rmd160: Fix endian issuesAdrian-Ken Rueegsegger
This patch fixes endian issues making rmd160 work properly on big-endian machines. Signed-off-by: Adrian-Ken Rueegsegger <rueegsegger@swiss-it.ch> Acked-by: Sebastian Siewior <sebastian@breakpoint.cc> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10[CRYPTO] ripemd: Put all common RIPEMD values in header fileAdrian-Ken Rueegsegger
This patch puts all common RIPEMD values in the appropriate header file. Initial values and constants are the same for all variants of RIPEMD. Signed-off-by: Adrian-Ken Rueegsegger <rueegsegger@swiss-it.ch> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10[CRYPTO] ripemd: Add support for RIPEMD hash algorithmsAdrian-Ken Rueegsegger
This patch adds support for RIPEMD-128 and RIPEMD-160 hash algorithms. Signed-off-by: Adrian-Ken Rueegsegger <rueegsegger@swiss-it.ch> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
