path: root/crypto/rng.c
2015-06-22crypto: rng - Do not free default RNG when it becomes unusedHerbert Xu
Currently we free the default RNG when its use count hits zero. This was OK when the IV generators would latch onto the RNG at instance creation time and keep it until the instance is torn down. Now that IV generators only keep the RNG reference during init time this scheme causes the default RNG to come and go at a high frequencey. This is highly undesirable as we want to keep a single RNG in use unless the admin wants it to be removed. This patch changes the scheme so that the system RNG once allocated is never removed unless a specifically requested. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-04-22crypto: rng - Zero seed in crypto_rng_resetHerbert Xu
If we allocate a seed on behalf ot the user in crypto_rng_reset, we must ensure that it is zeroed afterwards or the RNG may be compromised. Reported-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-04-22crypto: rng - Remove old low-level rng interfaceHerbert Xu
Now that all rng implementations have switched over to the new interface, we can remove the old low-level interface. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-04-22crypto: rng - Add multiple algorithm registration interfaceHerbert Xu
This patch adds the helpers that allow the registration and removal of multiple RNG algorithms. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-04-22crypto: rng - Convert low-level crypto_rng to new styleHerbert Xu
This patch converts the low-level crypto_rng interface to the "new" style. This allows existing implementations to be converted over one- by-one. Once that is complete we can then remove the old rng interface. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-04-22crypto: rng - Mark crypto_rng_reset seed as constHerbert Xu
There is no reason why crypto_rng_reset should modify the seed so this patch marks it as const. Since our algorithms don't export a const seed function yet we have to go through some contortions for now. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-04-21crypto: rng - Introduce crypto_rng_generateHerbert Xu
This patch adds the new top-level function crypto_rng_generate which generates random numbers with additional input. It also extends the mid-level rng_gen_random function to take additional data as input. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-04-21crypto: rng - Convert crypto_rng to new style crypto_typeHerbert Xu
This patch converts the top-level crypto_rng to the "new" style. It was the last algorithm type added before we switched over to the new way of doing things exemplified by shash. All users will automatically switch over to the new interface. Note that this patch does not touch the low-level interface to rng implementations. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-02-19crypto: user - fix info leaks in report APIMathias Krause
Three errors resulting in kernel memory disclosure: 1/ The structures used for the netlink based crypto algorithm report API are located on the stack. As snprintf() does not fill the remainder of the buffer with null bytes, those stack bytes will be disclosed to users of the API. Switch to strncpy() to fix this. 2/ crypto_report_one() does not initialize all field of struct crypto_user_alg. Fix this to fix the heap info leak. 3/ For the module name we should copy only as many bytes as module_name() returns -- not as much as the destination buffer could hold. But the current code does not and therefore copies random data from behind the end of the module name, as the module name is always shorter than CRYPTO_MAX_ALG_NAME. Also switch to use strncpy() to copy the algorithm's name and driver_name. They are strings, after all. Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-04-02crypto: Stop using NLA_PUT*().David S. Miller
These macros contain a hidden goto, and are thus extremely error prone and make code hard to audit. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-11crypto: algapi - Fix build problem with NET disabledHerbert Xu
The report functions use NLA_PUT so we need to ensure that NET is enabled. Reported-by: Luis Henriques <henrix@camandro.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-10-21crypto: Add userspace report for rng type algorithmsSteffen Klassert
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-08-13crypto: rng - Fix typoChristian Kujau
Correct a typo in crypto/rng.c Signed-off-by: Christian Kujau <lists@nerdbynature.de> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: rng - RNG interface and implementationNeil Horman
This patch adds a random number generator interface as well as a cryptographic pseudo-random number generator based on AES. It is meant to be used in cases where a deterministic CPRNG is required. One of the first applications will be as an input in the IPsec IV generation process. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
