path: root/crypto/rsa_helper.c
2015-10-14crypto: akcipher - Changes to asymmetric key APITadeusz Struk
Setkey function has been split into set_priv_key and set_pub_key. Akcipher requests takes sgl for src and dst instead of void *. Users of the API i.e. two existing RSA implementation and test mgr code have been updated accordingly. Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-07-21crypto: rsa - fix invalid check for keylen in fips modeTadeusz Struk
The condition checking allowed key length was invalid. Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-06-17crypto: rsa - add a new rsa generic implementationTadeusz Struk
Add a new rsa generic SW implementation. This implements only cryptographic primitives. Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com> Added select on ASN1. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
