path: root/crypto/seqiv.c
2008-08-29crypto: skcipher - Use RNG interface instead of get_random_bytesHerbert Xu
This patch makes the IV generators use the new RNG interface so that the user can pick an RNG other than the default get_random_bytes. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] seqiv: Add AEAD supportHerbert Xu
This patch adds support for using seqiv with AEAD algorithms. This is useful for those AEAD algorithms that performs authentication before encryption because the IV generated by the underlying encryption algorithm won't be available for authentication. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-01-11[CRYPTO] seqiv: Add Sequence Number IV GeneratorHerbert Xu
This generator generates an IV based on a sequence number by xoring it with a salt. This algorithm is mainly useful for CTR and similar modes. This patch also sets it as the default IV generator for ctr. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
