path: root/crypto/testmgr.h
2010-11-13crypto: rfc4106 - Extending the RC4106 AES-GCM test vectorsAdrian Hoban
Updated RFC4106 AES-GCM testing. Some test vectors were taken from http://csrc.nist.gov/groups/ST/toolkit/BCM/documents/proposedmodes/ gcm/gcm-test-vectors.tar.gz Signed-off-by: Adrian Hoban <adrian.hoban@intel.com> Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com> Signed-off-by: Gabriele Paoloni <gabriele.paoloni@intel.com> Signed-off-by: Aidan O'Mahony <aidan.o.mahony@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-03-18crypto: vmac - Fix big-endian supportShane Wang
This patch is to fix the vmac algorithm, add more test cases for vmac, and fix the test failure on some big endian system like s390. Signed-off-by: Shane Wang <shane.wang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-11-23crypto: testmgr - Add ghash algorithm test before provide to usersYouquan, Song
Add ghash algorithm test before provide it to users Signed-off-by: Youquan, Song <youquan.song@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-09-02crypto: vmac - New hash algorithm for intel_txt supportShane Wang
This patch adds VMAC (a fast MAC) support into crypto framework. Signed-off-by: Shane Wang <shane.wang@intel.com> Signed-off-by: Joseph Cihula <joseph.cihula@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-06-02crypto: testmgr - Add ctr(aes) test vectorsJarod Wilson
Now with multi-block test vectors, all from SP800-38A, Appendix F.5. Also added ctr(aes) to case 10 in tcrypt. Signed-off-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-06-02crypto: testmgr - Add ansi_cprng test vectorsJarod Wilson
Add ANSI X9.31 Continuous Pseudo-Random Number Generator (AES mode), aka 'ansi_cprng' test vectors, taken from Appendix B.2.9 and B.2.10 of the NIST RNGVS document, found here: http://csrc.nist.gov/groups/STM/cavp/documents/rng/RNGVS.pdf Successfully tested against both the cryptodev-2.6 tree and a Red Hat Enterprise Linux 5.4 kernel, via 'modprobe tcrypt mode=150'. The selection of 150 was semi-arbitrary, didn't seem like it should go any place in particular, so I started a new range for rng tests. Signed-off-by: Jarod Wilson <jarod@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-06-02crypto: testmgr - Add infrastructure for ansi_cprng self-testsJarod Wilson
Add some necessary infrastructure to make it possible to run self-tests for ansi_cprng. The bits are likely very specific to the ANSI X9.31 CPRNG in AES mode, and thus perhaps should be named more specifically if/when we grow additional CPRNG support... Successfully tested against the cryptodev-2.6 tree and a Red Hat Enterprise Linux 5.x kernel with the follow-on patch that adds the actual test vectors. Signed-off-by: Jarod Wilson <jarod@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-06-02crypto: testmgr - Add self-tests for rfc4309(ccm(aes))Jarod Wilson
Add an array of encryption and decryption + verification self-tests for rfc4309(ccm(aes)). Test vectors all come from sample FIPS CAVS files provided to Red Hat by a testing lab. Unfortunately, all the published sample vectors in RFC 3610 and NIST Special Publication 800-38C contain nonce lengths that the kernel's rfc4309 implementation doesn't support, so while using some public domain vectors would have been preferred, its not possible at this time. Signed-off-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-06-02crypto: testmgr - Handle AEAD test vectors expected to fail verificationJarod Wilson
Add infrastructure to tcrypt/testmgr to support handling ccm decryption test vectors that are expected to fail verification. Signed-off-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-03-04crypto: testmgr - add zlib testGeert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-03-04crypto: testmgr - Add support for the pcomp interfaceGeert Uytterhoeven
2008-12-25crypto: testmgr - Correct comment about deflate parametersGeert Uytterhoeven
The comment for the deflate test vectors says the winbits parameter is 11, while the deflate module actually uses -11 (a negative window bits parameter enables the raw deflate format instead of the zlib format). Correct this, to avoid confusion about the format used. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: cryptomgr - Add test infrastructureHerbert Xu
This patch moves the newly created alg_test infrastructure into cryptomgr. This shall allow us to use it for testing at algorithm registrations. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
