This reverts commit 2afef0391f30a2831f8beed6a89351682c8a81f6.
Change-Id: Ieef8fd28ba78334a4a0a1b7c64ba6fd4d0f4cb05
Reviewed-on: http://git-master/r/90082
Reviewed-by: Mallikarjun Kasoju <mkasoju@nvidia.com>
Tested-by: Mallikarjun Kasoju <mkasoju@nvidia.com>
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
the fix add testcase for testing aes ofb mode.
Signed-off-by: Puneet Saxena <puneets@nvidia.com>
Bug 787628
cherry picked the following commit
http://git.kernel.org/?p=linux/kernel/git/herbert/
cryptodev-2.6.git;a=commit;h=ba0e14acc417eceb895efda1ff46366f4d1728f8
Reviewed-on: http://git-master/r/30339
Reviewed-on: http://git-master/r/54441
(cherry picked from commit b6a86d94028d57884b85179a641a6275d6708c70)
Change-Id: I5bbd3e8a04f0281ff5c22ffcf7522ac3d4a31e30
Reviewed-on: http://git-master/r/68150
Tested-by: Puneet Saxena <puneets@nvidia.com>
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Added ofb(aes) and cmac(aes) tests
Original-Change-Id: Ia79b0f979af88d337e91164f0b8b6d0eba18cd03
Reviewed-on: http://git-master/r/34701
Reviewed-by: Hanumanth Venkateswa Moganty <vmoganty@nvidia.com>
Rebase-Id: R383d7f642cab41350f54367687861615f9484cf3
FIPS compliance requires a known-answer self-test for all approved
cipher and mode combinations, for all valid key sizes. Presently,
there are only self-tests for xts-aes-128. This adds a 256-bit one,
pulled from the same reference document, which should satisfy the
requirement.
Signed-off-by: Jarod Wilson <jarod@redhat.com>
In light of the recent discovery of the bug with partial block
processing on s390, we need best test coverage for that. This
patch adds a test vector for SHA1 that should catch such problems.
Updated RFC4106 AES-GCM testing. Some test vectors were taken from
http://csrc.nist.gov/groups/ST/toolkit/BCM/documents/proposedmodes/
gcm/gcm-test-vectors.tar.gz
Signed-off-by: Adrian Hoban <adrian.hoban@intel.com>
Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com>
Signed-off-by: Gabriele Paoloni <gabriele.paoloni@intel.com>
Signed-off-by: Aidan O'Mahony <aidan.o.mahony@intel.com>
This patch is to fix the vmac algorithm, add more test cases for vmac,
and fix the test failure on some big endian system like s390.
Signed-off-by: Shane Wang <shane.wang@intel.com>
Add ghash algorithm test before provide it to users
Signed-off-by: Youquan, Song <youquan.song@intel.com>
This patch adds VMAC (a fast MAC) support into crypto framework.
Signed-off-by: Joseph Cihula <joseph.cihula@intel.com>
Now with multi-block test vectors, all from SP800-38A, Appendix F.5.
Also added ctr(aes) to case 10 in tcrypt.
Add ANSI X9.31 Continuous Pseudo-Random Number Generator (AES mode),
aka 'ansi_cprng' test vectors, taken from Appendix B.2.9 and B.2.10
of the NIST RNGVS document, found here:
http://csrc.nist.gov/groups/STM/cavp/documents/rng/RNGVS.pdf
Successfully tested against both the cryptodev-2.6 tree and a Red
Hat Enterprise Linux 5.4 kernel, via 'modprobe tcrypt mode=150'.
The selection of 150 was semi-arbitrary, didn't seem like it should
go any place in particular, so I started a new range for rng tests.
Add some necessary infrastructure to make it possible to run
self-tests for ansi_cprng. The bits are likely very specific
to the ANSI X9.31 CPRNG in AES mode, and thus perhaps should
be named more specifically if/when we grow additional CPRNG
support...
Successfully tested against the cryptodev-2.6 tree and a
Red Hat Enterprise Linux 5.x kernel with the follow-on
patch that adds the actual test vectors.
Add an array of encryption and decryption + verification self-tests
for rfc4309(ccm(aes)).
Test vectors all come from sample FIPS CAVS files provided to
Red Hat by a testing lab. Unfortunately, all the published sample
vectors in RFC 3610 and NIST Special Publication 800-38C contain nonce
lengths that the kernel's rfc4309 implementation doesn't support, so
while using some public domain vectors would have been preferred, its
not possible at this time.
Add infrastructure to tcrypt/testmgr to support handling ccm decryption
test vectors that are expected to fail verification.
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
The comment for the deflate test vectors says the winbits parameter is 11,
while the deflate module actually uses -11 (a negative window bits parameter
enables the raw deflate format instead of the zlib format).
Correct this, to avoid confusion about the format used.
This patch moves the newly created alg_test infrastructure into
cryptomgr. This shall allow us to use it for testing at algorithm
registrations.
