[ Upstream commit baae03a0e2497f49704628fd0aaf993cf98e1b99 ]
The DMA_PREP_FENCE is to be used when preparing Tx descriptor if output
of Tx descriptor is to be used by next/dependent Tx descriptor.
The DMA_PREP_FENSE will not be set correctly in do_async_gen_syndrome()
when calling dma->device_prep_dma_pq() under following conditions:
1. ASYNC_TX_FENCE not set in submit->flags
2. DMA_PREP_FENCE not set in dma_flags
3. src_cnt (= (disks - 2)) is greater than dma_maxpq(dma, dma_flags)
This patch fixes DMA_PREP_FENCE usage in do_async_gen_syndrome() taking
inspiration from do_async_xor() implementation.
Signed-off-by: Anup Patel <anup.patel@broadcom.com>
Reviewed-by: Ray Jui <ray.jui@broadcom.com>
Reviewed-by: Scott Branden <scott.branden@broadcom.com>
Acked-by: Dan Williams <dan.j.williams@intel.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
commit 900a081f6912a8985dc15380ec912752cb66025a upstream.
When we have an unaligned SG list entry where there is no leftover
aligned data, the hash walk code will incorrectly return zero as if
the entire SG list has been processed.
This patch fixes it by moving onto the next page instead.
Reported-by: Eli Cooper <elicooper@gmx.com>
Cc: <stable@vger.kernel.org>
commit a16e772e664b9a261424107784804cffc8894977 upstream.
Since Poly1305 requires a nonce per invocation, the Linux kernel
implementations of Poly1305 don't use the crypto API's keying mechanism
and instead expect the key and nonce as the first 32 bytes of the data.
But ->setkey() is still defined as a stub returning an error code. This
prevents Poly1305 from being used through AF_ALG and will also break it
completely once we start enforcing that all crypto API users (not just
AF_ALG) call ->setkey() if present.
Fix it by removing crypto_poly1305_setkey(), leaving ->setkey as NULL.
commit 841a3ff329713f796a63356fef6e2f72e4a3f6a3 upstream.
When the cryptd template is used to wrap an unkeyed hash algorithm,
don't install a ->setkey() method to the cryptd instance. This change
is necessary for cryptd to keep working with unkeyed hash algorithms
once we start enforcing that ->setkey() is called when present.
commit cd6ed77ad5d223dc6299fb58f62e0f5267f7e2ba upstream.
Templates that use an shash spawn can use crypto_shash_alg_has_setkey()
to determine whether the underlying algorithm requires a key or not.
But there was no corresponding function for ahash spawns. Add it.
Note that the new function actually has to support both shash and ahash
algorithms, since the ahash API can be used with either.
commit 5c6ac1d4f8fbdbed65dbeb8cf149d736409d16a1 upstream.
In case buffer length is a multiple of PAGE_SIZE,
the S/G table is incorrectly generated.
Fix this by handling buflen = k * PAGE_SIZE separately.
Signed-off-by: Robert Baronescu <robert.baronescu@nxp.com>
Signed-off-by: Horia Geantă <horia.geanta@nxp.com>
commit bb30b8848c85e18ca7e371d0a869e94b3e383bdf upstream.
The user space interface allows specifying the type and mask field used
to allocate the cipher. Only a subset of the possible flags are intended
for user space. Therefore, white-list the allowed flags.
In case the user space caller uses at least one non-allowed flag, EINVAL
is returned.
Reported-by: syzbot <syzkaller@googlegroups.com>
Signed-off-by: Stephan Mueller <smueller@chronox.de>
commit 9a00674213a3f00394f4e3221b88f2d21fc05789 upstream.
syzkaller triggered a NULL pointer dereference in crypto_remove_spawns()
via a program that repeatedly and concurrently requests AEADs
"authenc(cmac(des3_ede-asm),pcbc-aes-aesni)" and hashes "cmac(des3_ede)"
through AF_ALG, where the hashes are requested as "untested"
(CRYPTO_ALG_TESTED is set in ->salg_mask but clear in ->salg_feat; this
causes the template to be instantiated for every request).
Although AF_ALG users really shouldn't be able to request an "untested"
algorithm, the NULL pointer dereference is actually caused by a
longstanding race condition where crypto_remove_spawns() can encounter
an instance which has had spawn(s) "grabbed" but hasn't yet been
registered, resulting in ->cra_users still being NULL.
We probably should properly initialize ->cra_users earlier, but that
would require updating many templates individually. For now just fix
the bug in a simple way that can easily be backported: make
crypto_remove_spawns() treat a NULL ->cra_users list as empty.
commit d76c68109f37cb85b243a1cf0f40313afd2bae68 upstream.
pcrypt is using the old way of freeing instances, where the ->free()
method specified in the 'struct crypto_template' is passed a pointer to
the 'struct crypto_instance'. But the crypto_instance is being
kfree()'d directly, which is incorrect because the memory was actually
allocated as an aead_instance, which contains the crypto_instance at a
nonzero offset. Thus, the wrong pointer was being kfree()'d.
Fix it by switching to the new way to free aead_instance's where the
->free() method is specified in the aead_instance itself.
Fixes: 0496f56065e0 ("crypto: pcrypt - Add support for new AEAD interface")
commit e57121d08c38dabec15cf3e1e2ad46721af30cae upstream.
If the rfc7539 template was instantiated with a hash algorithm with
digest size larger than 16 bytes (POLY1305_DIGEST_SIZE), then the digest
overran the 'tag' buffer in 'struct chachapoly_req_ctx', corrupting the
subsequent memory, including 'cryptlen'. This caused a crash during
crypto_skcipher_decrypt().
Fix it by, when instantiating the template, requiring that the
underlying hash algorithm has the digest size expected for Poly1305.
Reproducer:
#include <linux/if_alg.h>
#include <sys/socket.h>
#include <unistd.h>
int main()
int algfd, reqfd;
struct sockaddr_alg addr = {
.salg_type = "aead",
.salg_name = "rfc7539(chacha20,sha256)",
unsigned char buf[32] = { 0 };
algfd = socket(AF_ALG, SOCK_SEQPACKET, 0);
bind(algfd, (void *)&addr, sizeof(addr));
setsockopt(algfd, SOL_ALG, ALG_SET_KEY, buf, sizeof(buf));
reqfd = accept(algfd, 0, 0);
write(reqfd, buf, 16);
read(reqfd, buf, 16);
Fixes: 71ebc4d1b27d ("crypto: chacha20poly1305 - Add a ChaCha20-Poly1305 AEAD construction, RFC7539")
commit 9abffc6f2efe46c3564c04312e52e07622d40e51 upstream.
mcryptd_enqueue_request() grabs the per-CPU queue struct and protects
access to it with disabled preemption. Then it schedules a worker on the
same CPU. The worker in mcryptd_queue_worker() guards access to the same
per-CPU variable with disabled preemption.
If we take CPU-hotplug into account then it is possible that between
queue_work_on() and the actual invocation of the worker the CPU goes
down and the worker will be scheduled on _another_ CPU. And here the
preempt_disable() protection does not work anymore. The easiest thing is
to add a spin_lock() to guard access to the list.
Another detail: mcryptd_queue_worker() is not processing more than
MCRYPTD_BATCH invocation in a row. If there are still items left, then
it will invoke queue_work() to proceed with more later. *I* would
suggest to simply drop that check because it does not use a system
workqueue and the workqueue is already marked as "CPU_INTENSIVE". And if
preemption is required then the scheduler should do it.
However if queue_work() is used then the work item is marked as CPU
unbound. That means it will try to run on the local CPU but it may run
on another CPU as well. Especially with CONFIG_DEBUG_WQ_FORCE_RR_CPU=y.
Again, the preempt_disable() won't work here but lock which was
introduced will help.
In order to keep work-item on the local CPU (and avoid RR) I changed it
to queue_work_on().
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
[ Upstream commit 7aacbfcb331ceff3ac43096d563a1f93ed46e35e ]
Fix the way the length of the buffers used for
encryption / decryption are computed.
For e.g. in case of encryption, input buffer does not contain
an authentication tag.
commit ecaaab5649781c5a0effdaf298a925063020500e upstream.
When asked to encrypt or decrypt 0 bytes, both the generic and x86
implementations of Salsa20 crash in blkcipher_walk_done(), either when
doing 'kfree(walk->buffer)' or 'free_page((unsigned long)walk->page)',
because walk->buffer and walk->page have not been initialized.
The bug is that Salsa20 is calling blkcipher_walk_done() even when
nothing is in 'walk.nbytes'. But blkcipher_walk_done() is only meant to
be called when a nonzero number of bytes have been provided.
The broken code is part of an optimization that tries to make only one
call to salsa20_encrypt_bytes() to process inputs that are not evenly
divisible by 64 bytes. To fix the bug, just remove this "optimization"
and use the blkcipher_walk API the same way all the other users do.
Reproducer:
#include <unistd.h>
int main()
int algfd, reqfd;
.salg_type = "skcipher",
.salg_name = "salsa20",
char key[16] = { 0 };
setsockopt(algfd, SOL_ALG, ALG_SET_KEY, key, sizeof(key));
read(reqfd, key, sizeof(key));
Fixes: eb6f13eb9f81 ("[CRYPTO] salsa20_generic: Fix multi-page processing")
commit af3ff8045bbf3e32f1a448542e73abb4c8ceb6f1 upstream.
Because the HMAC template didn't check that its underlying hash
algorithm is unkeyed, trying to use "hmac(hmac(sha3-512-generic))"
through AF_ALG or through KEYCTL_DH_COMPUTE resulted in the inner HMAC
being used without having been keyed, resulting in sha3_update() being
called without sha3_init(), causing a stack buffer overflow.
This is a very old bug, but it seems to have only started causing real
problems when SHA-3 support was added (requires CONFIG_CRYPTO_SHA3)
because the innermost hash's state is ->import()ed from a zeroed buffer,
and it just so happens that other hash algorithms are fine with that,
but SHA-3 is not. However, there could be arch or hardware-dependent
hash algorithms also affected; I couldn't test everything.
Fix the bug by introducing a function crypto_shash_alg_has_setkey()
which tests whether a shash algorithm is keyed. Then update the HMAC
template to require that its underlying hash algorithm is unkeyed.
Here is a reproducer:
int main()
int algfd;
.salg_type = "hash",
.salg_name = "hmac(hmac(sha3-512-generic))",
char key[4096] = { 0 };
bind(algfd, (const struct sockaddr *)&addr, sizeof(addr));
Here was the KASAN report from syzbot:
BUG: KASAN: stack-out-of-bounds in memcpy include/linux/string.h:341 [inline]
BUG: KASAN: stack-out-of-bounds in sha3_update+0xdf/0x2e0 crypto/sha3_generic.c:161
Write of size 4096 at addr ffff8801cca07c40 by task syzkaller076574/3044
CPU: 1 PID: 3044 Comm: syzkaller076574 Not tainted 4.14.0-mm1+ #25
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:17 [inline]
dump_stack+0x194/0x257 lib/dump_stack.c:53
print_address_description+0x73/0x250 mm/kasan/report.c:252
kasan_report_error mm/kasan/report.c:351 [inline]
kasan_report+0x25b/0x340 mm/kasan/report.c:409
check_memory_region_inline mm/kasan/kasan.c:260 [inline]
check_memory_region+0x137/0x190 mm/kasan/kasan.c:267
memcpy+0x37/0x50 mm/kasan/kasan.c:303
crypto_shash_update+0xcb/0x220 crypto/shash.c:109
shash_finup_unaligned+0x2a/0x60 crypto/shash.c:151
crypto_shash_finup+0xc4/0x120 crypto/shash.c:165
hmac_finup+0x182/0x330 crypto/hmac.c:152
shash_digest_unaligned+0x9e/0xd0 crypto/shash.c:172
crypto_shash_digest+0xc4/0x120 crypto/shash.c:186
hmac_setkey+0x36a/0x690 crypto/hmac.c:66
crypto_shash_setkey+0xad/0x190 crypto/shash.c:64
shash_async_setkey+0x47/0x60 crypto/shash.c:207
crypto_ahash_setkey+0xaf/0x180 crypto/ahash.c:200
hash_setkey+0x40/0x90 crypto/algif_hash.c:446
alg_setkey crypto/af_alg.c:221 [inline]
alg_setsockopt+0x2a1/0x350 crypto/af_alg.c:254
SYSC_setsockopt net/socket.c:1851 [inline]
SyS_setsockopt+0x189/0x360 net/socket.c:1830
entry_SYSCALL_64_fastpath+0x1f/0x96
commit 0f30cbea005bd3077bd98cd29277d7fc2699c1da upstream.
Adding a specially crafted X.509 certificate whose subjectPublicKey
ASN.1 value is zero-length caused x509_extract_key_data() to set the
public key size to SIZE_MAX, as it subtracted the nonexistent BIT STRING
metadata byte. Then, x509_cert_parse() called kmemdup() with that bogus
size, triggering the WARN_ON_ONCE() in kmalloc_slab().
This appears to be harmless, but it still must be fixed since WARNs are
never supposed to be user-triggerable.
Fix it by updating x509_cert_parse() to validate that the value has a
BIT STRING metadata byte, and that the byte is 0 which indicates that
the number of bits in the bitstring is a multiple of 8.
It would be nice to handle the metadata byte in asn1_ber_decoder()
instead. But that would be tricky because in the general case a BIT
STRING could be implicitly tagged, and/or could legitimately have a
length that is not a whole number of bytes.
Here was the WARN (cleaned up slightly):
WARNING: CPU: 1 PID: 202 at mm/slab_common.c:971 kmalloc_slab+0x5d/0x70 mm/slab_common.c:971
Modules linked in:
CPU: 1 PID: 202 Comm: keyctl Tainted: G B 4.14.0-09238-g1d3b78bbc6e9 #26
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.11.0-20171110_100015-anatol 04/01/2014
task: ffff880033014180 task.stack: ffff8800305c8000
Call Trace:
__do_kmalloc mm/slab.c:3706 [inline]
__kmalloc_track_caller+0x22/0x2e0 mm/slab.c:3726
kmemdup+0x17/0x40 mm/util.c:118
kmemdup include/linux/string.h:414 [inline]
x509_cert_parse+0x2cb/0x620 crypto/asymmetric_keys/x509_cert_parser.c:106
x509_key_preparse+0x61/0x750 crypto/asymmetric_keys/x509_public_key.c:174
asymmetric_key_preparse+0xa4/0x150 crypto/asymmetric_keys/asymmetric_type.c:388
key_create_or_update+0x4d4/0x10a0 security/keys/key.c:850
SYSC_add_key security/keys/keyctl.c:122 [inline]
SyS_add_key+0xe8/0x290 security/keys/keyctl.c:62
Fixes: 42d5ec27f873 ("X.509: Add an ASN.1 decoder")
Reviewed-by: James Morris <james.l.morris@oracle.com>
This reverts commit 6145171a6bc0abdc3eca7a4b795ede467d2ba569.
The commit fixes a bug that was only introduced in 4.10, thus is
irrelevant for <=4.9.
commit 06aae592425701851e02bb850cb9f4997f0ae163 upstream.
The boolean want is not initialized and hence garbage. The default should
be false (later it is only set to true on tne sinfo->authattrs check).
Found with static analysis using CoverityScan
Cc: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit 68a1fdbbf8bd3378325e45c19e167a165f9ffc3a upstream.
The ASN.1 parser does not necessarily set the sinfo field,
this patch prevents a NULL pointer dereference on broken
input.
Fixes: 99db44350672 ("PKCS#7: Appropriately restrict authenticated attributes and content type")
Signed-off-by: Eric Sesterhenn <eric.sesterhenn@x41-dsec.de>
[ Upstream commit 12cb3a1c4184f891d965d1f39f8cfcc9ef617647 ]
Since the
commit f1c131b45410a202eb45cc55980a7a9e4e4b4f40
crypto: xts - Convert to skcipher
the XTS mode is based on ECB, so the mode must select
ECB otherwise it can fail to initialize.
Signed-off-by: Milan Broz <gmazyland@gmail.com>
commit b61907bb42409adf9b3120f741af7c57dd7e3db2 upstream.
The shash ahash digest adaptor function may crash if given a
zero-length input together with a null SG list. This is because
it tries to read the SG list before looking at the length.
This patch fixes it by checking the length first.
Reported-by: Stephan Müller<smueller@chronox.de>
Tested-by: Stephan Müller <smueller@chronox.de>
Fixed differently upstream as commit 2d97591ef43d ("crypto: af_alg - consolidation of duplicate code")
The SGL is MAX_SGL_ENTS + 1 in size. The last SG entry is used for the
chaining and is properly updated with the sg_chain invocation. During
the filling-in of the initial SG entries, sg_mark_end is called for each
SG entry. This is appropriate as long as no additional SGL is chained
with the current SGL. However, when a new SGL is chained and the last
SG entry is updated with sg_chain, the last but one entry still contains
the end marker from the sg_mark_end. This end marker must be removed as
otherwise a walk of the chained SGLs will cause a NULL pointer
dereference at the last but one SG entry, because sg_next will return
NULL.
The patch only applies to all kernels up to and including 4.13. The
patch 2d97591ef43d0587be22ad1b0d758d6df4999a0b added to 4.14-rc1
introduced a complete new code base which addresses this bug in
a different way. Yet, that patch is too invasive for stable kernels
and was therefore not marked for stable.
Fixes: 8ff590903d5fc ("crypto: algif_skcipher - User-space interface for skcipher operations")
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
commit 445a582738de6802669aeed9c33ca406c23c3b1f upstream.
For asynchronous operation, SGs are allocated without a page mapped to
them or with a page that is not used (ref-counted). If the SGL is freed,
the code must only call put_page for an SG if there was a page assigned
and ref-counted in the first place.
This fixes a kernel crash when using io_submit with more than one iocb
using the sendmsg and sendpage (vmsplice/splice) interface.
commit 41cdf7a45389e01991ee31e3301ed83cb3e3f7dc upstream.
When authencesn is used together with digest_null a crash will
occur on the decrypt path. This is because normally we perform
a special setup to preserve the ESN, but this is skipped if there
is no authentication. However, on the post-authentication path
it always expects the preservation to be in place, thus causing
a crash when digest_null is used.
This patch fixes this by also skipping the post-processing when
there is no authentication.
Fixes: 104880a6b470 ("crypto: authencesn - Convert to new AEAD...")
Reported-by: Jan Tluka <jtluka@redhat.com>
commit f3ad587070d6bd961ab942b3fd7a85d00dfc934b upstream.
crypto_gcm_setkey() was using wait_for_completion_interruptible() to
wait for completion of async crypto op but if a signal occurs it
may return before DMA ops of HW crypto provider finish, thus
corrupting the data buffer that is kfree'ed in this case.
Resolve this by using wait_for_completion() instead.
Reported-by: Eric Biggers <ebiggers3@gmail.com>
Signed-off-by: Gilad Ben-Yossef <gilad@benyossef.com>
commit 2a2a251f110576b1d89efbd0662677d7e7db21a8 upstream.
Some cipher implementations will crash if you try to use them
without calling setkey first. This patch adds a check so that
the accept(2) call will fail with -ENOKEY if setkey hasn't been
done on the socket yet.
Fixes: 400c40cf78da ("crypto: algif - add AEAD support")
commit abfa7f4357e3640fdee87dfc276fd0f379fb5ae6 upstream.
__test_aead() reads MAX_IVLEN bytes from template[i].iv, but the
actual length of the initialisation vector can be shorter.
The length of the IV is already calculated earlier in the
function. Let's just reuses that. Also the IV length is currently
calculated several time for no reason. Let's fix that too.
This fix an out-of-bound error detected by KASan.
Signed-off-by: Jerome Marchand <jmarchan@redhat.com>
Cc: Julia Lawall <julia.lawall@lip6.fr>
commit ef0579b64e93188710d48667cb5e014926af9f1b upstream.
The ahash API modifies the request's callback function in order
to clean up after itself in some corner cases (unaligned final
and missing finup).
When the request is complete ahash will restore the original
callback and everything is fine. However, when the request gets
an EBUSY on a full queue, an EINPROGRESS callback is made while
the request is still ongoing.
In this case the ahash API will incorrectly call its own callback.
This patch fixes the problem by creating a temporary request
object on the stack which is used to relay EINPROGRESS back to
the original completion function.
This patch also adds code to preserve the original flags value.
Fixes: ab6bf4e5e5e4 ("crypto: hash - Fix the pointer voodoo in...")
Reported-by: Sabrina Dubroca <sd@queasysnail.net>
Tested-by: Sabrina Dubroca <sd@queasysnail.net>
commit 6207119444595d287b1e9e83a2066c17209698f3 upstream.
With this reproducer:
struct sockaddr_alg alg = {
.salg_family = 0x26,
.salg_feat = 0xf,
.salg_mask = 0x5,
.salg_name = "digest_null",
int sock, sock2;
sock = socket(AF_ALG, SOCK_SEQPACKET, 0);
bind(sock, (struct sockaddr *)&alg, sizeof(alg));
sock2 = accept(sock, NULL, NULL);
setsockopt(sock, SOL_ALG, ALG_SET_KEY, "\x9b\xca", 2);
accept(sock2, NULL, NULL);
==== 8< ======== 8< ======== 8< ======== 8< ====
one can immediatelly see an UBSAN warning:
UBSAN: Undefined behaviour in crypto/algif_hash.c:187:7
variable length array bound value 0 <= 0
CPU: 0 PID: 15949 Comm: syz-executor Tainted: G E 4.4.30-0-default #1
Call Trace:
[<ffffffff81d598fd>] ? __ubsan_handle_vla_bound_not_positive+0x13d/0x188
[<ffffffff81d597c0>] ? __ubsan_handle_out_of_bounds+0x1bc/0x1bc
[<ffffffffa0e2204d>] ? hash_accept+0x5bd/0x7d0 [algif_hash]
[<ffffffffa0e2293f>] ? hash_accept_nokey+0x3f/0x51 [algif_hash]
[<ffffffffa0e206b0>] ? hash_accept_parent_nokey+0x4a0/0x4a0 [algif_hash]
[<ffffffff8235c42b>] ? SyS_accept+0x2b/0x40
It is a correct warning, as hash state is propagated to accept as zero,
but creating a zero-length variable array is not allowed in C.
Fix this as proposed by Herbert -- do "?: 1" on that site. No sizeof or
similar happens in the code there, so we just allocate one byte even
though we do not use the array.
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: "David S. Miller" <davem@davemloft.net> (maintainer:CRYPTO API)
Reported-by: Sasha Levin <sasha.levin@oracle.com>
commit ddef482420b1ba8ec45e6123a7e8d3f67b21e5e3 upstream.
mcryptd_create_hash() fails by returning -EINVAL, causing any
driver using mcryptd to fail to load. It is because it needs
to set its statesize properly.
Signed-off-by: Rui Wang <rui.y.wang@intel.com>
Cc: Sumit Semwal <sumit.semwal@linaro.org>
commit 1a07834024dfca5c4bed5de8f8714306e0a11836 upstream.
cryptd_create_hash() fails by returning -EINVAL. It is because after
8996eafdc ("crypto: ahash - ensure statesize is non-zero") all ahash
drivers must have a non-zero statesize.
This patch fixes the problem by properly assigning the statesize.
commit 7d6e9105026788c497f0ab32fa16c82f4ab5ff61 upstream.
An ancient gcc bug (first reported in 2003) has apparently resurfaced
on MIPS, where kernelci.org reports an overly large stack frame in the
whirlpool hash algorithm:
crypto/wp512.c:987:1: warning: the frame size of 1112 bytes is larger than 1024 bytes [-Wframe-larger-than=]
With some testing in different configurations, I'm seeing large
variations in stack frames size up to 1500 bytes for what should have
around 300 bytes at most. I also checked the reference implementation,
which is essentially the same code but also comes with some test and
benchmarking infrastructure.
It seems that recent compiler versions on at least arm, arm64 and powerpc
have a partial fix for this problem, but enabling "-fsched-pressure", but
even with that fix they suffer from the issue to a certain degree. Some
testing on arm64 shows that the time needed to hash a given amount of
data is roughly proportional to the stack frame size here, which makes
sense given that the wp512 implementation is doing lots of loads for
table lookups, and the problem with the overly large stack is a result
of doing a lot more loads and stores for spilled registers (as seen from
inspecting the object code).
Disabling -fschedule-insns consistently fixes the problem for wp512,
in my collection of cross-compilers, the results are consistently better
or identical when comparing the stack sizes in this function, though
some architectures (notable x86) have schedule-insns disabled by
default.
The four columns are:
default: -O2
press: -O2 -fsched-pressure
nopress: -O2 -fschedule-insns -fno-sched-pressure
nosched: -O2 -no-schedule-insns (disables sched-pressure)
default press nopress nosched
alpha-linux-gcc-4.9.3 1136 848 1136 176
am33_2.0-linux-gcc-4.9.3 2100 2076 2100 2104
arm-linux-gnueabi-gcc-4.9.3 848 848 1048 352
cris-linux-gcc-4.9.3 272 272 272 272
frv-linux-gcc-4.9.3 1128 1000 1128 280
hppa64-linux-gcc-4.9.3 1128 336 1128 184
hppa-linux-gcc-4.9.3 644 308 644 276
i386-linux-gcc-4.9.3 352 352 352 352
m32r-linux-gcc-4.9.3 720 656 720 268
microblaze-linux-gcc-4.9.3 1108 604 1108 256
mips64-linux-gcc-4.9.3 1328 592 1328 208
mips-linux-gcc-4.9.3 1096 624 1096 240
powerpc64-linux-gcc-4.9.3 1088 432 1088 160
powerpc-linux-gcc-4.9.3 1080 584 1080 224
s390-linux-gcc-4.9.3 456 456 624 360
sh3-linux-gcc-4.9.3 292 292 292 292
sparc64-linux-gcc-4.9.3 992 240 992 208
sparc-linux-gcc-4.9.3 680 592 680 312
x86_64-linux-gcc-4.9.3 224 240 272 224
xtensa-linux-gcc-4.9.3 1152 704 1152 304
aarch64-linux-gcc-7.0.0 224 224 1104 208
arm-linux-gnueabi-gcc-7.0.1 824 824 1048 352
mips-linux-gcc-7.0.0 1120 648 1120 272
x86_64-linux-gcc-7.0.1 240 240 304 240
arm-linux-gnueabi-gcc-4.4.7 840 392
arm-linux-gnueabi-gcc-4.5.4 784 728 784 320
arm-linux-gnueabi-gcc-4.6.4 736 728 736 304
arm-linux-gnueabi-gcc-4.7.4 944 784 944 352
arm-linux-gnueabi-gcc-4.8.5 464 464 760 352
arm-linux-gnueabi-gcc-5.3.1 824 824 1064 336
arm-linux-gnueabi-gcc-6.1.1 808 808 1056 344
Trying the same test for serpent-generic, the picture is a bit different,
and while -fno-schedule-insns is generally better here than the default,
-fsched-pressure wins overall, so I picked that instead.
alpha-linux-gcc-4.9.3 1392 864 1392 960
am33_2.0-linux-gcc-4.9.3 536 524 536 528
arm-linux-gnueabi-gcc-4.9.3 552 552 776 536
cris-linux-gcc-4.9.3 528 528 528 528
frv-linux-gcc-4.9.3 536 400 536 504
hppa64-linux-gcc-4.9.3 524 208 524 480
hppa-linux-gcc-4.9.3 768 472 768 508
i386-linux-gcc-4.9.3 564 564 564 564
m32r-linux-gcc-4.9.3 712 576 712 532
microblaze-linux-gcc-4.9.3 724 392 724 512
mips64-linux-gcc-4.9.3 720 384 720 496
mips-linux-gcc-4.9.3 728 384 728 496
powerpc64-linux-gcc-4.9.3 704 304 704 480
powerpc-linux-gcc-4.9.3 704 296 704 480
s390-linux-gcc-4.9.3 560 560 592 536
sh3-linux-gcc-4.9.3 540 540 540 540
sparc64-linux-gcc-4.9.3 544 352 544 496
sparc-linux-gcc-4.9.3 544 344 544 496
x86_64-linux-gcc-4.9.3 528 536 576 528
xtensa-linux-gcc-4.9.3 752 544 752 544
aarch64-linux-gcc-7.0.0 432 432 656 480
arm-linux-gnueabi-gcc-7.0.1 616 616 808 536
mips-linux-gcc-7.0.0 720 464 720 488
x86_64-linux-gcc-7.0.1 536 528 600 536
arm-linux-gnueabi-gcc-4.4.7 592 440
arm-linux-gnueabi-gcc-4.5.4 776 448 776 544
arm-linux-gnueabi-gcc-4.6.4 776 448 776 544
arm-linux-gnueabi-gcc-4.7.4 768 448 768 544
arm-linux-gnueabi-gcc-4.8.5 488 488 776 544
arm-linux-gnueabi-gcc-5.3.1 552 552 776 536
arm-linux-gnueabi-gcc-6.1.1 560 560 776 536
I did not do any runtime tests with serpent, so it is possible that stack
frame size does not directly correlate with runtime performance here and
it actually makes things worse, but it's more likely to help here, and
the reduced stack frame size is probably enough reason to apply the patch,
especially given that the crypto code is often used in deep call chains.
Link: https://kernelci.org/build/id/58797d7559b5149efdf6c3a9/logs/
Link: http://www.larc.usp.br/~pbarreto/WhirlpoolPage.html
Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=11488
Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=79149
commit 1c68bb0f62bf8de8bb30123ea840d5168f25abea upstream.
Running with KASAN and crypto tests currently gives
BUG: KASAN: global-out-of-bounds in __test_aead+0x9d9/0x2200 at addr ffffffff8212fca0
Read of size 16 by task cryptomgr_test/1107
Address belongs to variable 0xffffffff8212fca0
CPU: 0 PID: 1107 Comm: cryptomgr_test Not tainted 4.10.0+ #45
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.9.1-1.fc24 04/01/2014
Call Trace:
dump_stack+0x63/0x8a
kasan_report.part.1+0x4a7/0x4e0
? __test_aead+0x9d9/0x2200
? crypto_ccm_init_crypt+0x218/0x3c0 [ccm]
kasan_report+0x20/0x30
check_memory_region+0x13c/0x1a0
memcpy+0x23/0x50
? kasan_unpoison_shadow+0x35/0x50
? alg_test_akcipher+0xf0/0xf0
? crypto_skcipher_init_tfm+0x2e3/0x310
? crypto_spawn_tfm2+0x37/0x60
? crypto_ccm_init_tfm+0xa9/0xd0 [ccm]
? crypto_aead_init_tfm+0x7b/0x90
? crypto_alloc_tfm+0xc4/0x190
test_aead+0x28/0xc0
alg_test_aead+0x54/0xd0
alg_test+0x1eb/0x3d0
? alg_find_test+0x90/0x90
? __sched_text_start+0x8/0x8
? __wake_up_common+0x70/0xb0
cryptomgr_test+0x4d/0x60
kthread+0x173/0x1c0
? crypto_acomp_scomp_free_ctx+0x60/0x60
? kthread_create_on_node+0xa0/0xa0
ret_from_fork+0x2c/0x40
Memory state around the buggy address:
ffffffff8212fb80: 00 00 00 00 01 fa fa fa fa fa fa fa 00 00 00 00
ffffffff8212fc00: 00 01 fa fa fa fa fa fa 00 00 00 00 01 fa fa fa
>ffffffff8212fc80: fa fa fa fa 00 05 fa fa fa fa fa fa 00 00 00 00
ffffffff8212fd00: 01 fa fa fa fa fa fa fa 00 00 00 00 01 fa fa fa
ffffffff8212fd80: fa fa fa fa 00 00 00 00 00 05 fa fa fa fa fa fa
This always happens on the same IV which is less than 16 bytes.
Per Ard,
"CCM IVs are 16 bytes, but due to the way they are constructed
internally, the final couple of bytes of input IV are dont-cares.
Apparently, we do read all 16 bytes, which triggers the KASAN errors."
Fix this by padding the IV with null bytes to be at least 16 bytes.
Fixes: 0bc5a6c5c79a ("crypto: testmgr - Disable rfc4309 test and convert test vectors")
Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Signed-off-by: Laura Abbott <labbott@redhat.com>
commit d6040764adcb5cb6de1489422411d701c158bb69 upstream.
Make sure CRYPTO_ALG_DEAD bit is cleared before proceeding with
the algorithm registration. This fixes qat-dh registration when
driver is restarted
Signed-off-by: Salvatore Benedetto <salvatore.benedetto@intel.com>
commit 57891633eeef60e732e045731cf20e50ee80acb4 upstream.
Both asn1 headers are included by rsa_helper.c, so rsa_helper.o
should explicitly depend on them.
Signed-off-by: David Michael <david.michael@coreos.com>
Cc: Tuomas Tynkkynen <tuomas@tuxera.com>
commit 48a992727d82cb7db076fa15d372178743b1f4cd upstream.
Algorithms not compatible with mcryptd could be spawned by mcryptd
with a direct crypto_alloc_tfm invocation using a "mcryptd(alg)" name
construct. This causes mcryptd to crash the kernel if an arbitrary
"alg" is incompatible and not intended to be used with mcryptd. It is
an issue if AF_ALG tries to spawn mcryptd(alg) to expose it externally.
But such algorithms must be used internally and not be exposed.
We added a check to enforce that only internal algorithms are allowed
with mcryptd at the time mcryptd is spawning an algorithm.
Link: http://marc.info/?l=linux-crypto-vger&m=148063683310477&w=2
Reported-by: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com>
commit 50d2e6dc1f83db0563c7d6603967bf9585ce934b upstream.
The cipher block size for GCM is 16 bytes, and thus the CTR transform
used in crypto_gcm_setkey() will also expect a 16-byte IV. However,
the code currently reserves only 8 bytes for the IV, causing
an out-of-bounds access in the CTR transform. This patch fixes
the issue by setting the size of the IV buffer to 16 bytes.
Fixes: 84c911523020 ("[CRYPTO] gcm: Add support for async ciphers")
Signed-off-by: Ondrej Mosnacek <omosnacek@gmail.com>
commit 7ee7014d0eb6bcac679c0bd5fe9ce65bc4325648 upstream.
Dave Young reported:
> Hi,
> I saw the warning "Missing required AuthAttr" when testing kexec,
> known issue? Idea about how to fix it?
> The kernel is latest linus tree plus sevral patches from Toshi to
> cleanup io resource structure.
> in function pkcs7_sig_note_set_of_authattrs():
> if (!test_bit(sinfo_has_content_type, &sinfo->aa_set) ||
> !test_bit(sinfo_has_message_digest, &sinfo->aa_set) ||
> (ctx->msg->data_type == OID_msIndirectData &&
> !test_bit(sinfo_has_ms_opus_info, &sinfo->aa_set))) {
> pr_warn("Missing required AuthAttr\n");
> return -EBADMSG;
> The third condition below is true:
> I signed the kernel with redhat test key like below:
> pesign -c 'Red Hat Test Certificate' -i arch/x86/boot/bzImage -o /boot/vmlinuz-4.4.0-rc8+ -s --force
And right he is! The Authenticode specification is a paragon amongst
technical documents, and has this pearl of wisdom to offer:
Authenticode-Specific SignerInfo UnauthenticatedAttributes Structures
The following Authenticode-specific data structures are present in
SignerInfo authenticated attributes.
SpcSpOpusInfo
SpcSpOpusInfo is identified by SPC_SP_OPUS_INFO_OBJID
(1.3.6.1.4.1.311.2.1.12) and is defined as follows:
SpcSpOpusInfo ::= SEQUENCE {
programName [0] EXPLICIT SpcString OPTIONAL,
moreInfo [1] EXPLICIT SpcLink OPTIONAL,
} --#public--
SpcSpOpusInfo has two fields:
programName
This field contains the program description:
If publisher chooses not to specify a description, the SpcString
structure contains a zero-length program name.
If the publisher chooses to specify a
description, the SpcString structure contains a Unicode string.
moreInfo
This field is set to an SPCLink structure that contains a URL for
a Web site with more information about the signer. The URL is an
ASCII string.
Which is to say that this is an optional *unauthenticated* field which
may be present in the Authenticated Attribute list. This is not how
pkcs7 is supposed to work, so when David implemented this, he didn't
appreciate the subtlety the original spec author was working with, and
missed the part of the sublime prose that says this Authenticated
Attribute is an Unauthenticated Attribute. As a result, the code in
question simply takes as given that the Authenticated Attributes should
be authenticated.
But this one should not, individually. Because it says it's not
authenticated.
It still has to hash right so the TBS digest is correct. So it is both
authenticated and unauthenticated, all at once. Truly, a wonder of
technical accomplishment.
Additionally, pesign's implementation has always attempted to be
compatible with the signatures emitted from contemporary versions of
Microsoft's signtool.exe. During the initial implementation, Microsoft
signatures always produced the same values for SpcSpOpusInfo -
{U"Microsoft Windows", "http://www.microsoft.com"} - without regard to
who the signer was.
Sometime between Windows 8 and Windows 8.1 they stopped including the
field in their signatures altogether, and as such pesign stopped
producing them in commits c0c4da6 and d79cb0c, sometime around June of
2012. The theory here is that anything that breaks with
pesign signatures would also be breaking with signtool.exe sigs as well,
and that'll be a more noticed problem for firmwares parsing it, so it'll
get fixed. The fact that we've done exactly this bug in Linux code is
first class, grade A irony.
So anyway, we should not be checking this field for presence or any
particular value: if the field exists, it should be at the right place,
but aside from that, as long as the hash matches the field is good.
Signed-off-by: Peter Jones <pjones@redhat.com>
Tested-by: Dave Young <dyoung@redhat.com>
Signed-off-by: Juerg Haefliger <juerg.haefliger@hpe.com>
commit a397ba829d7f8aff4c90af3704573a28ccd61a59 upstream.
Move common values and types used by ghash-generic to a new header file
so drivers can directly use ghash-generic as a fallback implementation.
Fixes: cc333cd68dfa ("crypto: vmx - Adding GHASH routines for VMX module")
Signed-off-by: Marcelo Cerri <marcelo.cerri@canonical.com>
commit c84750906b4818d4929fbf73a4ae6c113b94f52b upstream.
Add missing dmaengine_unmap_put(), so we don't OOM during RAID6 sync.
Fixes: 1786b943dad0 ("async_pq_val: convert to dmaengine_unmap_data")
Signed-off-by: Justin Maggard <jmaggard@netgear.com>
Reviewed-by: Dan Williams <dan.j.williams@intel.com>
commit 53a5d5ddccf849dbc27a8c1bba0b43c3a45fb792 upstream.
The current implementation uses a global per-cpu array to store
data which are used to derive the next IV. This is insecure as
the attacker may change the stored data.
This patch removes all traces of chaining and replaces it with
multiplication of the salt and the sequence number.
Fixes: a10f554fa7e0 ("crypto: echainiv - Add encrypted chain IV...")
Reported-by: Mathias Krause <minipli@googlemail.com>
commit acdb04d0b36769b3e05990c488dc74d8b7ac8060 upstream.
When we need to allocate a temporary blkcipher_walk_next and it
fails, the code is supposed to take the slow path of processing
the data block by block. However, due to an unrelated change
we instead end up dereferencing the NULL pointer.
This patch fixes it by moving the unrelated bsize setting out
of the way so that we enter the slow path as inteded.
Fixes: 7607bd8ff03b ("[CRYPTO] blkcipher: Added blkcipher_walk_virt_block")
Reported-by: xiakaixu <xiakaixu@huawei.com>
Reported-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Tested-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
commit 0bd2223594a4dcddc1e34b15774a3a4776f7749e upstream.
When calling .import() on a cryptd ahash_request, the structure members
that describe the child transform in the shash_desc need to be initialized
like they are when calling .init()
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
commit 5f070e81bee35f1b7bd1477bb223a873ff657803 upstream.
When there is more data to be processed, the current test in
scatterwalk_done may prevent us from calling pagedone even when
we should.
In particular, if we're on an SG entry spanning multiple pages
where the last page is not a full page, we will incorrectly skip
calling pagedone on the second last page.
This patch fixes this by adding a separate test for whether we've
reached the end of a page.
commit b30bdfa86431afbafe15284a3ad5ac19b49b88e3 upstream.
As it is if you ask for a sync gcm you may actually end up with
an async one because it does not filter out async implementations
of ghash.
This patch fixes this by adding the necessary filter when looking
for ghash.
commit 055ddaace03580455a7b7dbea8e93d62acee61fc upstream.
Commit 9aa867e46565 ("crypto: user - Add CRYPTO_MSG_DELRNG")
accidentally removed the minimum size check for CRYPTO_MSG_GETALG
netlink messages. This allows userland to send a truncated
CRYPTO_MSG_GETALG message as short as a netlink header only making
crypto_report() operate on uninitialized memory by accessing data
beyond the end of the netlink message.
Fix this be re-adding the minimum required size of CRYPTO_MSG_GETALG
messages to the crypto_msg_min[] array.
Fixes: 9aa867e46565 ("crypto: user - Add CRYPTO_MSG_DELRNG")
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Cc: Steffen Klassert <steffen.klassert@secunet.com>
commit bad6a185b4d6f81d0ed2b6e4c16307969f160b95 upstream.
In some rare randconfig builds, we can end up with
ASYMMETRIC_PUBLIC_KEY_SUBTYPE enabled but CRYPTO_AKCIPHER disabled,
which fails to link because of the reference to crypto_alloc_akcipher:
crypto/built-in.o: In function `public_key_verify_signature':
:(.text+0x110e4): undefined reference to `crypto_alloc_akcipher'
This adds a Kconfig 'select' statement to ensure the dependency
is always there.
commit df27b26f04ed388ff4cc2b5d8cfdb5d97678816f upstream.
As akcipher uses an SG interface, you must not use vmalloc memory
as input for it. This patch fixes testmgr to copy the vmalloc
test vectors to kmalloc memory before running the test.
This patch also removes a superfluous sg_virt call in do_test_rsa.
Reported-by: Anatoly Pugachev <matorola@gmail.com>
commit 13f4bb78cf6a312bbdec367ba3da044b09bf0e29 upstream.
The crypto hash walk code is broken when supplied with an offset
greater than or equal to PAGE_SIZE. This patch fixes it by adjusting
walk->pg and walk->offset when this happens.
Reported-by: Steffen Klassert <steffen.klassert@secunet.com>
commit e54358915d0a00399c11c2c23ae1be674cba188a upstream.
Despite what the DocBook comment to pkcs7_validate_trust() says, the
*_trusted argument is never set to false.
pkcs7_validate_trust() only positively sets *_trusted upon encountering
a trusted PKCS#7 SignedInfo block.
This is quite unfortunate since its callers, system_verify_data() for
example, depend on pkcs7_validate_trust() clearing *_trusted on non-trust.
Indeed, UBSAN splats when attempting to load the uninitialized local
variable 'trusted' from system_verify_data() in pkcs7_validate_trust():
UBSAN: Undefined behaviour in crypto/asymmetric_keys/pkcs7_trust.c:194:14
load of value 82 is not a valid value for type '_Bool'
Call Trace:
[<ffffffff818c4d35>] dump_stack+0xbc/0x117
[<ffffffff818c4c79>] ? _atomic_dec_and_lock+0x169/0x169
[<ffffffff8194113b>] ubsan_epilogue+0xd/0x4e
[<ffffffff819419fa>] __ubsan_handle_load_invalid_value+0x111/0x158
[<ffffffff819418e9>] ? val_to_string.constprop.12+0xcf/0xcf
[<ffffffff818334a4>] ? x509_request_asymmetric_key+0x114/0x370
[<ffffffff814b83f0>] ? kfree+0x220/0x370
[<ffffffff818312c2>] ? public_key_verify_signature_2+0x32/0x50
[<ffffffff81835e04>] pkcs7_validate_trust+0x524/0x5f0
[<ffffffff813c391a>] system_verify_data+0xca/0x170
[<ffffffff813c3850>] ? top_trace_array+0x9b/0x9b
[<ffffffff81510b29>] ? __vfs_read+0x279/0x3d0
[<ffffffff8129372f>] mod_verify_sig+0x1ff/0x290
The implication is that pkcs7_validate_trust() effectively grants trust
when it really shouldn't have.
Fix this by explicitly setting *_trusted to false at the very beginning
of pkcs7_validate_trust().
Signed-off-by: Nicolai Stange <nicstange@gmail.com>
commit ac4cbedfdf55455b4c447f17f0fa027dbf02b2a6 upstream.
There are still a couple of minor issues in the X.509 leap year handling:
(1) To avoid doing a modulus-by-400 in addition to a modulus-by-100 when
determining whether the year is a leap year or not, I divided the year
by 100 after doing the modulus-by-100, thereby letting the compiler do
one instruction for both, and then did a modulus-by-4.
Unfortunately, I then passed the now-modified year value to mktime64()
to construct a time value.
Since this isn't a fast path and since mktime64() does a bunch of
divisions, just condense down to "% 400". It's also easier to read.
(2) The default month length for any February where the year doesn't
divide by four exactly is obtained from the month_length[] array where
the value is 29, not 28.
This is fixed by altering the table.
Reported-by: Rudolf Polzer <rpolzer@google.com>
Acked-by: David Woodhouse <David.Woodhouse@intel.com>
