path: root/crypto
2017-06-17Merge tag 'v4.1.41' into 4.1-2.0.x-imxOtavio Salvador
Linux 4.1.41 * tag 'v4.1.41': (473 commits) Linux 4.1.41 mm/huge_memory.c: respect FOLL_FORCE/FOLL_COW for thp xc2028: Fix use-after-free bug properly iio: proximity: as3935: fix as3935_write ipx: call ipxitf_put() in ioctl error path sched/fair: Initialize throttle_count for new task-groups lazily sched/fair: Do not announce throttled next buddy in dequeue_task_fair() iio: dac: ad7303: fix channel description mwifiex: pcie: fix cmd_buf use-after-free in remove/reset rtlwifi: rtl8821ae: setup 8812ae RFE according to device type ARM: tegra: paz00: Mark panel regulator as enabled on boot fs/xattr.c: zero out memory copied to userspace in getxattr vfio/type1: Remove locked page accounting workqueue crypto: algif_aead - Require setkey before accept(2) staging: gdm724x: gdm_mux: fix use-after-free on module unload drm/ttm: fix use-after-free races in vm fault handling f2fs: sanity check segment count ipv6: reorder ip6_route_dev_notifier after ipv6_dev_notf ipv6: initialize route null entry in addrconf_init() rtnetlink: NUL-terminate IFLA_PHYS_PORT_NAME string ... Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2017-06-13crypto: algif_aead - Require setkey before accept(2)Stephan Mueller
[ Upstream commit 2a2a251f110576b1d89efbd0662677d7e7db21a8 ] Some cipher implementations will crash if you try to use them without calling setkey first. This patch adds a check so that the accept(2) call will fail with -ENOKEY if setkey hasn't been done on the socket yet. Fixes: 400c40cf78da ("crypto: algif - add AEAD support") Cc: <stable@vger.kernel.org> Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-06-13crypto: testmgr - fix out of bound read in __test_aead()Jerome Marchand
[ Upstream commit abfa7f4357e3640fdee87dfc276fd0f379fb5ae6 ] __test_aead() reads MAX_IVLEN bytes from template[i].iv, but the actual length of the initialisation vector can be shorter. The length of the IV is already calculated earlier in the function. Let's just reuses that. Also the IV length is currently calculated several time for no reason. Let's fix that too. This fix an out-of-bound error detected by KASan. Signed-off-by: Jerome Marchand <jmarchan@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-05-17crypto: ahash - Fix EINPROGRESS notification callbackHerbert Xu
[ Upstream commit ef0579b64e93188710d48667cb5e014926af9f1b ] The ahash API modifies the request's callback function in order to clean up after itself in some corner cases (unaligned final and missing finup). When the request is complete ahash will restore the original callback and everything is fine. However, when the request gets an EBUSY on a full queue, an EINPROGRESS callback is made while the request is still ongoing. In this case the ahash API will incorrectly call its own callback. This patch fixes the problem by creating a temporary request object on the stack which is used to relay EINPROGRESS back to the original completion function. This patch also adds code to preserve the original flags value. Fixes: ab6bf4e5e5e4 ("crypto: hash - Fix the pointer voodoo in...") Cc: <stable@vger.kernel.org> Reported-by: Sabrina Dubroca <sd@queasysnail.net> Tested-by: Sabrina Dubroca <sd@queasysnail.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2017-03-17Merge tag 'v4.1.39' into 4.1-2.0.x-imxOtavio Salvador
Linux 4.1.39 * tag 'v4.1.39': (138 commits) Linux 4.1.39 KVM: x86: remove data variable from kvm_get_msr_common KVM: VMX: Fix host initiated access to guest MSR_TSC_AUX KVM: x86: pass host_initiated to functions that read MSRs perf/core: Fix the perf_cpu_time_max_percent check perf/core: Make sysctl_perf_cpu_time_max_percent conform to documentation perf/core: Fix implicitly enable dynamic interrupt throttle perf/core: Fix dynamic interrupt throttle Fix missing sanity check in /dev/sg printk: use rcuidle console tracepoint vfs: fix uninitialized flags in splice_to_pipe() drm/radeon: Use mode h/vdisplay fields to hide out of bounds HW cursor ARM: 8658/1: uaccess: fix zeroing of 64-bit get_user() drm/dp/mst: fix kernel oops when turning off secondary monitor [media] siano: make it work again with CONFIG_VMAP_STACK mmc: core: fix multi-bit bus width without high-speed mode futex: Move futex_init() to core_initcall xen-netfront: Delete rx_refill_timer in xennet_disconnect_backend() scsi: aacraid: Fix INTx/MSI-x issue with older controllers cpumask: use nr_cpumask_bits for parsing functions ... Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2017-03-06crypto: api - Clear CRYPTO_ALG_DEAD bit before registering an algSalvatore Benedetto
[ Upstream commit d6040764adcb5cb6de1489422411d701c158bb69 ] Make sure CRYPTO_ALG_DEAD bit is cleared before proceeding with the algorithm registration. This fixes qat-dh registration when driver is restarted Cc: <stable@vger.kernel.org> Signed-off-by: Salvatore Benedetto <salvatore.benedetto@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-10-26Merge tag 'v4.1.35' into 4.1-2.0.x-imxOtavio Salvador
Linux 4.1.35 * tag 'v4.1.35': (98 commits) Linux 4.1.35 xhci: fix usb2 resume timing and races. mm: remove gup_flags FOLL_WRITE games from __get_user_pages() timekeeping: Fix __ktime_get_fast_ns() regression time: Add cycles to nanoseconds translation Linux 4.1.34 openrisc: fix the fix of copy_from_user() avr32: fix 'undefined reference to `___copy_from_user' fix memory leaks in tracing_buffers_splice_read() tracing: Move mutex to protect against resetting of seq data MIPS: SMP: Fix possibility of deadlock when bringing CPUs online MIPS: Fix pre-r6 emulation FPU initialisation btrfs: ensure that file descriptor used with subvol ioctls is a dir fix fault_in_multipages_...() on architectures with no-op access_ok() ocfs2: fix start offset to ocfs2_zero_range_for_truncate() fanotify: fix list corruption in fanotify_get_response() fsnotify: add a way to stop queueing events on group shutdown autofs: use dentry flags to block walks during expire autofs races ocfs2/dlm: fix race between convert and migration ... Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2016-10-05Merge tag 'v4.1.33' into 4.1-2.0.x-imxOtavio Salvador
Linux 4.1.33 * tag 'v4.1.33': (1760 commits) Linux 4.1.33 Revert "ARC: mm: don't loose PTE_SPECIAL in pte_modify()" x86/AMD: Apply erratum 665 on machines without a BIOS fix x86/paravirt: Do not trace _paravirt_ident_*() functions ovl: listxattr: use strnlen() ovl: remove posix_acl_default from workdir serial: 8250: added acces i/o products quad and octal serial cards sysfs: correctly handle read offset on PREALLOC attrs sysfs: correctly handle short reads on PREALLOC attrs. kernfs: don't depend on d_find_any_alias() when generating notifications dm crypt: fix free of bad values after tfm allocation failure dm crypt: fix error with too large bios dm log writes: fix check of kthread_run() return value dm log writes: fix bug with too large bios dm log writes: move IO accounting earlier to fix error path NFSv4.x: Fix a refcount leak in nfs_callback_up_net xfs: prevent dropping ioend completions during buftarg wait xfs: fix superblock inprogress check USB: serial: option: add WeTelecom 0x6802 and 0x6803 products USB: avoid left shift by -1 ... Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2016-10-02crypto: skcipher - Fix blkcipher walk OOM crashHerbert Xu
[ Upstream commit acdb04d0b36769b3e05990c488dc74d8b7ac8060 ] When we need to allocate a temporary blkcipher_walk_next and it fails, the code is supposed to take the slow path of processing the data block by block. However, due to an unrelated change we instead end up dereferencing the NULL pointer. This patch fixes it by moving the unrelated bsize setting out of the way so that we enter the slow path as inteded. Fixes: 7607bd8ff03b ("[CRYPTO] blkcipher: Added blkcipher_walk_virt_block") Cc: stable@vger.kernel.org Reported-by: xiakaixu <xiakaixu@huawei.com> Reported-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Tested-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-10-02crypto: cryptd - initialize child shash_desc on importArd Biesheuvel
[ Upstream commit 0bd2223594a4dcddc1e34b15774a3a4776f7749e ] When calling .import() on a cryptd ahash_request, the structure members that describe the child transform in the shash_desc need to be initialized like they are when calling .init() Cc: stable@vger.kernel.org Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-08-19crypto: scatterwalk - Fix test in scatterwalk_doneHerbert Xu
[ Upstream commit 5f070e81bee35f1b7bd1477bb223a873ff657803 ] When there is more data to be processed, the current test in scatterwalk_done may prevent us from calling pagedone even when we should. In particular, if we're on an SG entry spanning multiple pages where the last page is not a full page, we will incorrectly skip calling pagedone on the second last page. This patch fixes this by adding a separate test for whether we've reached the end of a page. Cc: stable@vger.kernel.org Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-08-16crypto: gcm - Filter out async ghash if necessaryHerbert Xu
[ Upstream commit b30bdfa86431afbafe15284a3ad5ac19b49b88e3 ] As it is if you ask for a sync gcm you may actually end up with an async one because it does not filter out async implementations of ghash. This patch fixes this by adding the necessary filter when looking for ghash. Cc: stable@vger.kernel.org Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-07-10PKCS#7: pkcs7_validate_trust(): initialize the _trusted output argumentNicolai Stange
[ Upstream commit e54358915d0a00399c11c2c23ae1be674cba188a ] Despite what the DocBook comment to pkcs7_validate_trust() says, the *_trusted argument is never set to false. pkcs7_validate_trust() only positively sets *_trusted upon encountering a trusted PKCS#7 SignedInfo block. This is quite unfortunate since its callers, system_verify_data() for example, depend on pkcs7_validate_trust() clearing *_trusted on non-trust. Indeed, UBSAN splats when attempting to load the uninitialized local variable 'trusted' from system_verify_data() in pkcs7_validate_trust(): UBSAN: Undefined behaviour in crypto/asymmetric_keys/pkcs7_trust.c:194:14 load of value 82 is not a valid value for type '_Bool' [...] Call Trace: [<ffffffff818c4d35>] dump_stack+0xbc/0x117 [<ffffffff818c4c79>] ? _atomic_dec_and_lock+0x169/0x169 [<ffffffff8194113b>] ubsan_epilogue+0xd/0x4e [<ffffffff819419fa>] __ubsan_handle_load_invalid_value+0x111/0x158 [<ffffffff819418e9>] ? val_to_string.constprop.12+0xcf/0xcf [<ffffffff818334a4>] ? x509_request_asymmetric_key+0x114/0x370 [<ffffffff814b83f0>] ? kfree+0x220/0x370 [<ffffffff818312c2>] ? public_key_verify_signature_2+0x32/0x50 [<ffffffff81835e04>] pkcs7_validate_trust+0x524/0x5f0 [<ffffffff813c391a>] system_verify_data+0xca/0x170 [<ffffffff813c3850>] ? top_trace_array+0x9b/0x9b [<ffffffff81510b29>] ? __vfs_read+0x279/0x3d0 [<ffffffff8129372f>] mod_verify_sig+0x1ff/0x290 [...] The implication is that pkcs7_validate_trust() effectively grants trust when it really shouldn't have. Fix this by explicitly setting *_trusted to false at the very beginning of pkcs7_validate_trust(). Cc: <stable@vger.kernel.org> Signed-off-by: Nicolai Stange <nicstange@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-06-17crypto: public_key: select CRYPTO_AKCIPHERArnd Bergmann
[ Upstream commit bad6a185b4d6f81d0ed2b6e4c16307969f160b95 ] In some rare randconfig builds, we can end up with ASYMMETRIC_PUBLIC_KEY_SUBTYPE enabled but CRYPTO_AKCIPHER disabled, which fails to link because of the reference to crypto_alloc_akcipher: crypto/built-in.o: In function `public_key_verify_signature': :(.text+0x110e4): undefined reference to `crypto_alloc_akcipher' This adds a Kconfig 'select' statement to ensure the dependency is always there. Cc: <stable@vger.kernel.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-05-17crypto: hash - Fix page length clamping in hash walkHerbert Xu
[ Upstream commit 13f4bb78cf6a312bbdec367ba3da044b09bf0e29 ] The crypto hash walk code is broken when supplied with an offset greater than or equal to PAGE_SIZE. This patch fixes it by adjusting walk->pg and walk->offset when this happens. Cc: <stable@vger.kernel.org> Reported-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-04-18X.509: Fix leap year handling againDavid Howells
[ Upstream commit ac4cbedfdf55455b4c447f17f0fa027dbf02b2a6 ] There are still a couple of minor issues in the X.509 leap year handling: (1) To avoid doing a modulus-by-400 in addition to a modulus-by-100 when determining whether the year is a leap year or not, I divided the year by 100 after doing the modulus-by-100, thereby letting the compiler do one instruction for both, and then did a modulus-by-4. Unfortunately, I then passed the now-modified year value to mktime64() to construct a time value. Since this isn't a fast path and since mktime64() does a bunch of divisions, just condense down to "% 400". It's also easier to read. (2) The default month length for any February where the year doesn't divide by four exactly is obtained from the month_length[] array where the value is 29, not 28. This is fixed by altering the table. Reported-by: Rudolf Polzer <rpolzer@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: David Woodhouse <David.Woodhouse@intel.com> Acked-by: Arnd Bergmann <arnd@arndb.de> cc: stable@vger.kernel.org Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-04-18PKCS#7: Improve and export the X.509 ASN.1 time object decoderDavid Howells
[ Upstream commit fd19a3d195be23e8d9d0d66576b96ea25eea8323 ] Make the X.509 ASN.1 time object decoder fill in a time64_t rather than a struct tm to make comparison easier (unfortunately, this makes readable display less easy) and export it so that it can be used by the PKCS#7 code too. Further, tighten up its parsing to reject invalid dates (eg. weird characters, non-existent hour numbers) and unsupported dates (eg. timezones other than 'Z' or dates earlier than 1970). Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-04-18X.509: Extract both parts of the AuthorityKeyIdentifierDavid Howells
[ Upstream commit b92e6570a992c7d793a209db282f68159368201c ] Extract both parts of the AuthorityKeyIdentifier, not just the keyIdentifier, as the second part can be used to match X.509 certificates by issuer and serialNumber. Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-03-11crypto: testmgr - Disable rfc4543 testHerbert Xu
Because the old rfc4543 implementation always injected an IV into the AD, while the new one does not, we have to disable the test while it is converted over to the new AEAD interface. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-02-28Backport fix for crypto: algif_skcipher - Fix race condition in ↵Herbert Xu
skcipher_check_key commit 1822793a523e5d5730b19cc21160ff1717421bc8 upstream. We need to lock the child socket in skcipher_check_key as otherwise two simultaneous calls can cause the parent socket to be freed. Cc: stable@vger.kernel.org Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-02-28Backport fix for crypto: algif_skcipher - Remove custom release parent functionHerbert Xu
commit d7b65aee1e7b4c87922b0232eaba56a8a143a4a0 upstream. This patch removes the custom release parent function as the generic af_alg_release_parent now works for nokey sockets too. Cc: stable@vger.kernel.org Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-02-28Backport fix for crypto: algif_skcipher - Add nokey compatibility pathHerbert Xu
commit a0fa2d037129a9849918a92d91b79ed6c7bd2818 upstream. This patch adds a compatibility path to support old applications that do acept(2) before setkey. Cc: stable@vger.kernel.org Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-02-28Backport fix for crypto: algif_skcipher - Require setkey before accept(2)Herbert Xu
commit dd504589577d8e8e70f51f997ad487a4cb6c026f upstream. Some cipher implementations will crash if you try to use them without calling setkey first. This patch adds a check so that the accept(2) call will fail with -ENOKEY if setkey hasn't been done on the socket yet. Cc: stable@vger.kernel.org Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Tested-by: Dmitry Vyukov <dvyukov@google.com> [backported to 4.1 by Milan Broz <gmazyland@gmail.com>] Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-02-28crypto: user - lock crypto_alg_list on alg dumpMathias Krause
[ Upstream commit 63e41ebc6630f39422d87f8a4bade1e793f37a01 ] We miss to take the crypto_alg_sem semaphore when traversing the crypto_alg_list for CRYPTO_MSG_GETALG dumps. This allows a race with crypto_unregister_alg() removing algorithms from the list while we're still traversing it, thereby leading to a use-after-free as show below: [ 3482.071639] general protection fault: 0000 [#1] SMP [ 3482.075639] Modules linked in: aes_x86_64 glue_helper lrw ablk_helper cryptd gf128mul ipv6 pcspkr serio_raw virtio_net microcode virtio_pci virtio_ring virtio sr_mod cdrom [last unloaded: aesni_intel] [ 3482.075639] CPU: 1 PID: 11065 Comm: crconf Not tainted 4.3.4-grsec+ #126 [ 3482.075639] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.7.5-20140531_083030-gandalf 04/01/2014 [ 3482.075639] task: ffff88001cd41a40 ti: ffff88001cd422c8 task.ti: ffff88001cd422c8 [ 3482.075639] RIP: 0010:[<ffffffff93722bd3>] [<ffffffff93722bd3>] strncpy+0x13/0x30 [ 3482.075639] RSP: 0018:ffff88001f713b60 EFLAGS: 00010202 [ 3482.075639] RAX: ffff88001f6c4430 RBX: ffff88001f6c43a0 RCX: ffff88001f6c4430 [ 3482.075639] RDX: 0000000000000040 RSI: fefefefefefeff16 RDI: ffff88001f6c4430 [ 3482.075639] RBP: ffff88001f713b60 R08: ffff88001f6c4470 R09: ffff88001f6c4480 [ 3482.075639] R10: 0000000000000002 R11: 0000000000000246 R12: ffff88001ce2aa28 [ 3482.075639] R13: ffff880000093700 R14: ffff88001f5e4bf8 R15: 0000000000003b20 [ 3482.075639] FS: 0000033826fa2700(0000) GS:ffff88001e900000(0000) knlGS:0000000000000000 [ 3482.075639] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 3482.075639] CR2: ffffffffff600400 CR3: 00000000139ec000 CR4: 00000000001606f0 [ 3482.075639] Stack: [ 3482.075639] ffff88001f713bd8 ffffffff936ccd00 ffff88001e5c4200 ffff880000093700 [ 3482.075639] ffff88001f713bd0 ffffffff938ef4bf 0000000000000000 0000000000003b20 [ 3482.075639] ffff88001f5e4bf8 ffff88001f5e4848 0000000000000000 0000000000003b20 [ 3482.075639] Call Trace: [ 3482.075639] [<ffffffff936ccd00>] crypto_report_alg+0xc0/0x3e0 [ 3482.075639] [<ffffffff938ef4bf>] ? __alloc_skb+0x16f/0x300 [ 3482.075639] [<ffffffff936cd08a>] crypto_dump_report+0x6a/0x90 [ 3482.075639] [<ffffffff93935707>] netlink_dump+0x147/0x2e0 [ 3482.075639] [<ffffffff93935f99>] __netlink_dump_start+0x159/0x190 [ 3482.075639] [<ffffffff936ccb13>] crypto_user_rcv_msg+0xc3/0x130 [ 3482.075639] [<ffffffff936cd020>] ? crypto_report_alg+0x3e0/0x3e0 [ 3482.075639] [<ffffffff936cc4b0>] ? alg_test_crc32c+0x120/0x120 [ 3482.075639] [<ffffffff93933145>] ? __netlink_lookup+0xd5/0x120 [ 3482.075639] [<ffffffff936cca50>] ? crypto_add_alg+0x1d0/0x1d0 [ 3482.075639] [<ffffffff93938141>] netlink_rcv_skb+0xe1/0x130 [ 3482.075639] [<ffffffff936cc4f8>] crypto_netlink_rcv+0x28/0x40 [ 3482.075639] [<ffffffff939375a8>] netlink_unicast+0x108/0x180 [ 3482.075639] [<ffffffff93937c21>] netlink_sendmsg+0x541/0x770 [ 3482.075639] [<ffffffff938e31e1>] sock_sendmsg+0x21/0x40 [ 3482.075639] [<ffffffff938e4763>] SyS_sendto+0xf3/0x130 [ 3482.075639] [<ffffffff93444203>] ? bad_area_nosemaphore+0x13/0x20 [ 3482.075639] [<ffffffff93444470>] ? __do_page_fault+0x80/0x3a0 [ 3482.075639] [<ffffffff939d80cb>] entry_SYSCALL_64_fastpath+0x12/0x6e [ 3482.075639] Code: 88 4a ff 75 ed 5d 48 0f ba 2c 24 3f c3 66 66 2e 0f 1f 84 00 00 00 00 00 55 48 85 d2 48 89 f8 48 89 f9 4c 8d 04 17 48 89 e5 74 15 <0f> b6 16 80 fa 01 88 11 48 83 de ff 48 83 c1 01 4c 39 c1 75 eb [ 3482.075639] RIP [<ffffffff93722bd3>] strncpy+0x13/0x30 To trigger the race run the following loops simultaneously for a while: $ while : ; do modprobe aesni-intel; rmmod aesni-intel; done $ while : ; do crconf show all > /dev/null; done Fix the race by taking the crypto_alg_sem read lock, thereby preventing crypto_unregister_alg() from modifying the algorithm list during the dump. This bug has been detected by the PaX memory sanitize feature. Cc: stable@vger.kernel.org Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Steffen Klassert <steffen.klassert@secunet.com> Cc: PaX Team <pageexec@freemail.hu> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-02-15X.509: Don't strip leading 00's from key ID when constructing key descriptionDavid Howells
[ Upstream commit e7c87bef7de2417b219d4dbfe8d33a0098a8df54 ] Don't strip leading zeros from the crypto key ID when using it to construct the struct key description as the signature in kernels up to and including 4.2 matched this aspect of the key. This means that 1 in 256 keys won't actually match if their key ID begins with 00. The key ID is stored in the module signature as binary and so must be converted to text in order to invoke request_key() - but it isn't stripped at this point. Something like this is likely to be observed in dmesg when the key is loaded: [ 1.572423] Loaded X.509 cert 'Build time autogenerated kernel key: 62a7c3d2da278be024da4af8652c071f3fea33' followed by this when we try and use it: [ 1.646153] Request for unknown module key 'Build time autogenerated kernel key: 0062a7c3d2da278be024da4af8652c071f3fea33' err -11 The 'Loaded' line should show an extra '00' on the front of the hex string. This problem should not affect 4.3-rc1 and onwards because there the key should be matched on one of its auxiliary identities rather than the key struct's description string. Reported-by: Arjan van de Ven <arjan@linux.intel.com> Reported-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-02-15crypto: algif_hash - wait for crypto_ahash_init() to completeWang, Rui Y
[ Upstream commit fe09786178f9df713a4b2dd6b93c0a722346bf5e ] hash_sendmsg/sendpage() need to wait for the completion of crypto_ahash_init() otherwise it can cause panic. Cc: stable@vger.kernel.org Signed-off-by: Rui Wang <rui.y.wang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-02-15crypto: shash - Fix has_key settingHerbert Xu
[ Upstream commit 00420a65fa2beb3206090ead86942484df2275f3 ] The has_key logic is wrong for shash algorithms as they always have a setkey function. So we should instead be testing against shash_no_setkey. Fixes: a5596d633278 ("crypto: hash - Add crypto_ahash_has_setkey") Cc: stable@vger.kernel.org Reported-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Tested-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-02-03crypto: algif_skcipher - sendmsg SG marking is off by oneHerbert Xu
[ Upstream commit 202736d99b7f29279db9da61587f11a08a04a9c6 ] We mark the end of the SG list in sendmsg and sendpage and unmark it on the next send call. Unfortunately the unmarking in sendmsg is off-by-one, leading to an SG list that is too short. Fixes: 0f477b655a52 ("crypto: algif - Mark sgl end at the end of data") Cc: stable@vger.kernel.org Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-02-03crypto: crc32c - Fix crc32c soft dependencyJean Delvare
[ Upstream commit fd7f6727102a1ccf6b4c1dfcc631f9b546526b26 ] I don't think it makes sense for a module to have a soft dependency on itself. This seems quite cyclic by nature and I can't see what purpose it could serve. OTOH libcrc32c calls crypto_alloc_shash("crc32c", 0, 0) so it pretty much assumes that some incarnation of the "crc32c" hash algorithm has been loaded. Therefore it makes sense to have the soft dependency there (as crc-t10dif does.) Cc: stable@vger.kernel.org Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-02-03crypto: algif_hash - Fix race condition in hash_check_keyHerbert Xu
[ Upstream commit ad46d7e33219218605ea619e32553daf4f346b9f ] We need to lock the child socket in hash_check_key as otherwise two simultaneous calls can cause the parent socket to be freed. Cc: stable@vger.kernel.org Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-02-03crypto: af_alg - Forbid bind(2) when nokey child sockets are presentHerbert Xu
[ Upstream commit a6a48c565f6f112c6983e2a02b1602189ed6e26e ] This patch forbids the calling of bind(2) when there are child sockets created by accept(2) in existence, even if they are created on the nokey path. This is needed as those child sockets have references to the tfm object which bind(2) will destroy. Cc: stable@vger.kernel.org Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-02-03crypto: algif_hash - Remove custom release parent functionHerbert Xu
[ Upstream commit f1d84af1835846a5a2b827382c5848faf2bb0e75 ] This patch removes the custom release parent function as the generic af_alg_release_parent now works for nokey sockets too. Cc: stable@vger.kernel.org Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-02-03crypto: af_alg - Allow af_af_alg_release_parent to be called on nokey pathHerbert Xu
[ Upstream commit 6a935170a980024dd29199e9dbb5c4da4767a1b9 ] This patch allows af_alg_release_parent to be called even for nokey sockets. Cc: stable@vger.kernel.org Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-02-03crypto: algif_hash - Require setkey before accept(2)Herbert Xu
[ Upstream commit 6de62f15b581f920ade22d758f4c338311c2f0d4 ] Hash implementations that require a key may crash if you use them without setting a key. This patch adds the necessary checks so that if you do attempt to use them without a key that we return -ENOKEY instead of proceeding. This patch also adds a compatibility path to support old applications that do acept(2) before setkey. Cc: stable@vger.kernel.org Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-02-03crypto: hash - Add crypto_ahash_has_setkeyHerbert Xu
[ Upstream commit a5596d6332787fd383b3b5427b41f94254430827 ] This patch adds a way for ahash users to determine whether a key is required by a crypto_ahash transform. Cc: stable@vger.kernel.org Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-02-03crypto: af_alg - Add nokey compatibility pathHerbert Xu
[ Upstream commit 37766586c965d63758ad542325a96d5384f4a8c9 ] This patch adds a compatibility path to support old applications that do acept(2) before setkey. Cc: stable@vger.kernel.org Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-02-03crypto: af_alg - Fix socket double-free when accept failsHerbert Xu
[ Upstream commit a383292c86663bbc31ac62cc0c04fc77504636a6 ] When we fail an accept(2) call we will end up freeing the socket twice, once due to the direct sk_free call and once again through newsock. This patch fixes this by removing the sk_free call. Cc: stable@vger.kernel.org Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-02-03crypto: af_alg - Disallow bind/setkey/... after accept(2)Herbert Xu
[ Upstream commit c840ac6af3f8713a71b4d2363419145760bd6044 ] Each af_alg parent socket obtained by socket(2) corresponds to a tfm object once bind(2) has succeeded. An accept(2) call on that parent socket creates a context which then uses the tfm object. Therefore as long as any child sockets created by accept(2) exist the parent socket must not be modified or freed. This patch guarantees this by using locks and a reference count on the parent socket. Any attempt to modify the parent socket will fail with EBUSY. Cc: stable@vger.kernel.org Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-01-25crypto: tcrypt - avoid mapping from module image addressesHoria Geant?
The output buffer in test_ahash_speed will point to an address located within the tcrypt module image. This causes problems when trying to DMA map the buffer. For e.g. on ARM-based LS1021A, a page fault occurs within the DMA API when trying to access the struct page returned by virt_to_page(output): insmod tcrypt.ko mode=403 testing speed of async sha1 (sha1-caam) test 0 ( 16 byte blocks, 16 bytes per update, 1 updates): Unable to handle kernel paging request at virtual address f07e9080 pgd = e58d0e00 [f07e9080] *pgd=80000080007003, *pmd=00000000 Internal error: Oops: 206 [#1] SMP THUMB2 Modules linked in: tcrypt(+) CPU: 1 PID: 1119 Comm: insmod Not tainted 4.2.0-rc1-256134-gbf433416e675 #1 Hardware name: Freescale LS1021A task: ea063900 ti: e5a34000 task.ti: e5a34000 PC is at dma_cache_maint_page+0x38/0xd0 LR is at __dma_page_cpu_to_dev+0x15/0x64 pc : [<800155a0>] lr : [<8001564d>] psr: 000f0033 sp : e5a35ca0 ip : 8063df00 fp : f07e9080 r10: 00000cd0 r9 : 8063df00 r8 : 805a2f04 r7 : 0017f804 r6 : 00000002 r5 : ee7f9000 r4 : 00000014 r3 : 80612d40 r2 : 01ff0080 r1 : 00000380 r0 : ee7f9000 Flags: nzcv IRQs on FIQs on Mode SVC_32 ISA Thumb Segment user Control: 70c5387d Table: e58d0e00 DAC: 9b7ede70 Process insmod (pid: 1119, stack limit = 0xe5a34210) Stack: (0xe5a35ca0 to 0xe5a36000) [...] [<800155a0>] (dma_cache_maint_page) from [<8001564d>] (__dma_page_cpu_to_dev+0x15/0x64) [<8001564d>] (__dma_page_cpu_to_dev) from [<800156eb>] (arm_dma_map_page+0x1f/0x44) [<800156eb>] (arm_dma_map_page) from [<802935e3>] (ahash_digest+0x35f/0x510) [<802935e3>] (ahash_digest) from [<7f800d03>] (test_ahash_speed.constprop.6+0x24a/0x4e4 [tcrypt]) [<7f800d03>] (test_ahash_speed.constprop.6 [tcrypt]) from [<7f802fd5>] (do_test+0x1898/0x2058 [tcrypt]) [<7f802fd5>] (do_test [tcrypt]) from [<7f80802f>] (tcrypt_mod_init+0x2e/0x63 [tcrypt]) [<7f80802f>] (tcrypt_mod_init [tcrypt]) from [<80009517>] (do_one_initcall+0xb3/0x134) [<80009517>] (do_one_initcall) from [<80351ec7>] (do_init_module+0x3b/0x13c) [<80351ec7>] (do_init_module) from [<8005cc3f>] (load_module+0x97b/0x9dc) [<8005cc3f>] (load_module) from [<8005cd8d>] (SyS_finit_module+0x35/0x3e) [<8005cd8d>] (SyS_finit_module) from [<8000d101>] (ret_fast_syscall+0x1/0x4c) Code: 1aba 0152 eb00 0b02 (5882) 0f92 addr2line -f -i -e vmlinux 800155a0 page_zonenum include/linux/mm.h:728 page_zone include/linux/mm.h:881 dma_cache_maint_page arch/arm/mm/dma-mapping.c:822 Signed-off-by: Horia Geant? <horia.geanta@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-11-09crypto: api - Only abort operations on fatal signalHerbert Xu
commit 3fc89adb9fa4beff31374a4bf50b3d099d88ae83 upstream. Currently a number of Crypto API operations may fail when a signal occurs. This causes nasty problems as the caller of those operations are often not in a good position to restart the operation. In fact there is currently no need for those operations to be interrupted by user signals at all. All we need is for them to be killable. This patch replaces the relevant calls of signal_pending with fatal_signal_pending, and wait_for_completion_interruptible with wait_for_completion_killable, respectively. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-27crypto: ahash - ensure statesize is non-zeroRussell King
commit 8996eafdcbad149ac0f772fb1649fbb75c482a6a upstream. Unlike shash algorithms, ahash drivers must implement export and import as their descriptors may contain hardware state and cannot be exported as is. Unfortunately some ahash drivers did not provide them and end up causing crashes with algif_hash. This patch adds a check to prevent these drivers from registering ahash algorithms until they are fixed. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-08-03KEYS: fix "ca_keys=" partial key matchingMimi Zohar
commit f2b3dee484f9cee967a54ef05a66866282337519 upstream. The call to asymmetric_key_hex_to_key_id() from ca_keys_setup() silently fails with -ENOMEM. Instead of dynamically allocating memory from a __setup function, this patch defines a variable and calls __asymmetric_key_hex_to_key_id(), a new helper function, directly. This bug was introduced by 'commit 46963b774d44 ("KEYS: Overhaul key identification when searching for asymmetric keys")'. Changelog: - for clarification, rename hexlen to asciihexlen in asymmetric_key_hex_to_key_id() - add size argument to __asymmetric_key_hex_to_key_id() - David Howells - inline __asymmetric_key_hex_to_key_id() - David Howells - remove duplicate strlen() calls Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto fix from Herbert Xu: "This disables the newly (4.1) added user-space AEAD interface so that we can fix issues in the underlying kernel AEAD interface. Once the new kernel AEAD interface is ready we can then reenable the user-space AEAD interface" * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: algif_aead - Disable AEAD user-space for now
2015-05-26crypto: algif_aead - Disable AEAD user-space for nowHerbert Xu
The newly added AEAD user-space isn't quite ready for prime time just yet. In particular it is conflicting with the AEAD single SG list interface change so this patch disables it now. Once the SG list stuff is completely done we can then renable this interface. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-05-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto fix from Herbert Xu: "This fixes a the crash in the newly added algif_aead interface when it tries to link SG lists" * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: algif_aead - fix invalid sgl linking
2015-05-18crypto: algif_aead - fix invalid sgl linkingTadeusz Struk
This patch fixes it. Also minor updates to comments. Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-04-24Merge tag 'md/4.1' of git://neil.brown.name/mdLinus Torvalds
Pull md updates from Neil Brown: "More updates that usual this time. A few have performance impacts which hould mostly be positive, but RAID5 (in particular) can be very work-load ensitive... We'll have to wait and see. Highlights: - "experimental" code for managing md/raid1 across a cluster using DLM. Code is not ready for general use and triggers a WARNING if used. However it is looking good and mostly done and having in mainline will help co-ordinate development. - RAID5/6 can now batch multiple (4K wide) stripe_heads so as to handle a full (chunk wide) stripe as a single unit. - RAID6 can now perform read-modify-write cycles which should help performance on larger arrays: 6 or more devices. - RAID5/6 stripe cache now grows and shrinks dynamically. The value set is used as a minimum. - Resync is now allowed to go a little faster than the 'mininum' when there is competing IO. How much faster depends on the speed of the devices, so the effective minimum should scale with device speed to some extent" * tag 'md/4.1' of git://neil.brown.name/md: (58 commits) md/raid5: don't do chunk aligned read on degraded array. md/raid5: allow the stripe_cache to grow and shrink. md/raid5: change ->inactive_blocked to a bit-flag. md/raid5: move max_nr_stripes management into grow_one_stripe and drop_one_stripe md/raid5: pass gfp_t arg to grow_one_stripe() md/raid5: introduce configuration option rmw_level md/raid5: activate raid6 rmw feature md/raid6 algorithms: xor_syndrome() for SSE2 md/raid6 algorithms: xor_syndrome() for generic int md/raid6 algorithms: improve test program md/raid6 algorithms: delta syndrome functions raid5: handle expansion/resync case with stripe batching raid5: handle io error of batch list RAID5: batch adjacent full stripe write raid5: track overwrite disk count raid5: add a new flag to track if a stripe can be batched raid5: use flex_array for scribble data md raid0: access mddev->queue (request queue member) conditionally because it is not set when accessed from dm-raid md: allow resync to go faster when there is competing IO. md: remove 'go_faster' option from ->sync_request() ...
2015-04-22md/raid5: activate raid6 rmw featureMarkus Stockhausen
Glue it altogehter. The raid6 rmw path should work the same as the already existing raid5 logic. So emulate the prexor handling/flags and split functions as needed. 1) Enable xor_syndrome() in the async layer. 2) Split ops_run_prexor() into RAID4/5 and RAID6 logic. Xor the syndrome at the start of a rmw run as we did it before for the single parity. 3) Take care of rmw run in ops_run_reconstruct6(). Again process only the changed pages to get syndrome back into sync. 4) Enhance set_syndrome_sources() to fill NULL pages if we are in a rmw run. The lower layers will calculate start & end pages from that and call the xor_syndrome() correspondingly. 5) Adapt the several places where we ignored Q handling up to now. Performance numbers for a single E5630 system with a mix of 10 7200k desktop/server disks. 300 seconds random write with 8 threads onto a 3,2TB (10*400GB) RAID6 64K chunk without spare (group_thread_cnt=4) bsize rmw_level=1 rmw_level=0 rmw_level=1 rmw_level=0 skip_copy=1 skip_copy=1 skip_copy=0 skip_copy=0 4K 115 KB/s 141 KB/s 165 KB/s 140 KB/s 8K 225 KB/s 275 KB/s 324 KB/s 274 KB/s 16K 434 KB/s 536 KB/s 640 KB/s 534 KB/s 32K 751 KB/s 1,051 KB/s 1,234 KB/s 1,045 KB/s 64K 1,339 KB/s 1,958 KB/s 2,282 KB/s 1,962 KB/s 128K 2,673 KB/s 3,862 KB/s 4,113 KB/s 3,898 KB/s 256K 7,685 KB/s 7,539 KB/s 7,557 KB/s 7,638 KB/s 512K 19,556 KB/s 19,558 KB/s 19,652 KB/s 19,688 Kb/s Signed-off-by: Markus Stockhausen <stockhausen@collogia.de> Signed-off-by: NeilBrown <neilb@suse.de>
2015-04-15crypto: fix broken crypto_register_instance() module handlingHerbert Xu
Commit 9c521a200bc3 ("crypto: api - remove instance when test failed") tried to grab a module reference count before the module was even set. Worse, it then goes on to free the module reference count after it is set so you quickly end up with a negative module reference count which prevents people from using any instances belonging to that module. This patch moves the module initialisation before the reference count. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-15crypto: fix mis-merge with the networking mergeLinus Torvalds
The networking updates from David Miller removed the iocb argument from sendmsg and recvmsg (in commit 1b784140474e: "net: Remove iocb argument from sendmsg and recvmsg"), but the crypto code had added new instances of them. When I pulled the crypto update, it was a silent semantic mis-merge, and I overlooked the new warning messages in my test-build. I try to fix those in the merge itself, but that relies on me noticing. Oh well. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
