path: root/crypto
2014-11-07MLK-9710-9 Fix for tcrypt test_ahash_speed functionWinston Hudson
This patch adds a null pointer check and explicitly frees memory in the tcrypt.c function test_ahash_speed. Signed-off-by: Winston Hudson <winston.hudson@freescale.com> (cherry picked from commit 9bea544c31565260e5cbec2da14f4b2e89d21656)
2014-11-07MLK-9710-8 tcrypt: change memory allocation for test_ahash_speed output bufferVictoria Milhoan
Change allocation of the tcrypt module's test_ahash_speed() output buffer to use kmalloc(). This avoids a segmentation fault when the buffer is used in a dma_map_*() call. Signed-off-by: Victoria Milhoan <vicki.milhoan@freescale.com> (cherry picked from commit 3c8c56d1bd82433af6a565d183bdb632fd01a13a)
2014-11-07MLK-9710-7 AEAD CBC DES DES3_EDE SHA* SupportWinston Hudson (b45308)
This patch has been backported to the 3.5.7 kernel for use with i.MX6. Note that CAAM also goes by sec-4.0 or sec-5.0 in other product families (such as QorIQ). Thus the property names are often tied to the sec-4.0+ nomenclature. The original patch can be found at the following link: http://marc.info/?l=linux-crypto-vger&m=135771601829617&w=2 Test vectors were taken from existing test for CBC(DES3_EDE). Associated data has been added to test vectors. HMAC computed with Crypto++ has been used. Following algos have been covered. (a) "authenc(hmac(sha1),cbc(des))" (b) "authenc(hmac(sha1),cbc(des3_ede))" (c) "authenc(hmac(sha224),cbc(des))" (d) "authenc(hmac(sha224),cbc(des3_ede))" (e) "authenc(hmac(sha256),cbc(des))" (f) "authenc(hmac(sha256),cbc(des3_ede))" (g) "authenc(hmac(sha384),cbc(des))" (h) "authenc(hmac(sha384),cbc(des3_ede))" (i) "authenc(hmac(sha512),cbc(des))" (j) "authenc(hmac(sha512),cbc(des3_ede))" Signed-off-by: Vakul Garg <vakul@freescale.com> Signed-off-by: Winston Hudson (b45308) <winston.h.hudson@freescale.com> (cherry picked from commit 486265888badc647ef4d386310f0c1d895211d00)
2014-11-07MLK-9710-6 AEAD CBC AES MD5 Test SupportWinston Hudson (b45308)
This patch adds support for the following tcrypt test: (a) "authenc(hmac(md5),cbc(aes))" Note that CAAM also goes by sec-4.0 or sec-5.0 in other product families (such as QorIQ). Thus the property names are often tied to the sec-4.0+ nomenclature. Signed-off-by: Winston Hudson (b45308) <winston.h.hudson@freescale.com> (cherry picked from commit a8ad8329282f7381c7768b7f3d544864b8e9df33)
2014-11-07crypto: authenc - Export key parsing helper functionMathias Krause
AEAD key parsing is duplicated to multiple places in the kernel. Add a common helper function to consolidate that functionality. Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Mathias Krause <mathias.krause@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit bc6e2bdb71056607141ada309a185f0a50b1aeaf) (cherry picked from commit e04ea19d6744a2eaaed0cef3400c590e790b0827)
2014-11-07crypto: caam - fix aead sglen for case 'dst != src'Horia Geanta
For aead case when source and destination buffers are different, there is an incorrect assumption that the source length includes the ICV length. Fix this, since it leads to an oops when using sg_count() to find the number of nents in the scatterlist: Unable to handle kernel paging request for data at address 0x00000004 Faulting instruction address: 0xf91f7634 Oops: Kernel access of bad area, sig: 11 [#1] SMP NR_CPUS=8 P4080 DS Modules linked in: caamalg(+) caam_jr caam CPU: 1 PID: 1053 Comm: cryptomgr_test Not tainted 3.11.0 #16 task: eeb24ab0 ti: eeafa000 task.ti: eeafa000 NIP: f91f7634 LR: f91f7f24 CTR: f91f7ef0 REGS: eeafbbc0 TRAP: 0300 Not tainted (3.11.0) MSR: 00029002 <CE,EE,ME> CR: 44044044 XER: 00000000 DEAR: 00000004, ESR: 00000000 GPR00: f91f7f24 eeafbc70 eeb24ab0 00000002 ee8e0900 ee8e0800 00000024 c45c4462 GPR08: 00000010 00000000 00000014 0c0e4000 24044044 00000000 00000000 c0691590 GPR16: eeab0000 eeb23000 00000000 00000000 00000000 00000001 00000001 eeafbcc8 GPR24: 000000d1 00000010 ee2d5000 ee49ea10 ee49ea10 ee46f640 ee46f640 c0691590 NIP [f91f7634] aead_edesc_alloc.constprop.14+0x144/0x780 [caamalg] LR [f91f7f24] aead_encrypt+0x34/0x288 [caamalg] Call Trace: [eeafbc70] [a1004000] 0xa1004000 (unreliable) [eeafbcc0] [f91f7f24] aead_encrypt+0x34/0x288 [caamalg] [eeafbcf0] [c020d77c] __test_aead+0x3ec/0xe20 [eeafbe20] [c020f35c] test_aead+0x6c/0xe0 [eeafbe40] [c020f420] alg_test_aead+0x50/0xd0 [eeafbe60] [c020e5e4] alg_test+0x114/0x2e0 [eeafbee0] [c020bd1c] cryptomgr_test+0x4c/0x60 [eeafbef0] [c0047058] kthread+0xa8/0xb0 [eeafbf40] [c000eb0c] ret_from_kernel_thread+0x5c/0x64 Instruction dump: 69084321 7d080034 5508d97e 69080001 0f080000 81290024 552807fe 0f080000 3a600001 5529003a 2f8a0000 40dd0028 <80e90004> 3ab50001 8109000c 70e30002 ---[ end trace b3c3e23925c7484e ]--- While here, add a tcrypt mode for making it easy to test authenc (needed for triggering case above). Signed-off-by: Horia Geanta <horia.geanta@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> (cherry picked from commit bbf9c8934ba2bfd5fd809562f945deaf5a565898) (cherry picked from commit 48105e67f0d23809fa65fb2ca814c23a74316643)
2014-09-18crypto: testmgr - avoid DMA mapping from text, rodata, stackHoria Geanta
With DMA_API_DEBUG set, following warnings are emitted (tested on CAAM accelerator): DMA-API: device driver maps memory from kernel text or rodata DMA-API: device driver maps memory from stack and the culprits are: -key in __test_aead and __test_hash -result in __test_hash MAX_KEYLEN is changed to accommodate maximum key length from existing test vectors in crypto/testmgr.h (131 bytes) and rounded. Signed-off-by: Horia Geanta <horia.geanta@freescale.com> Acked-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-09-18crypto: testmgr - Fix DMA-API warningTadeusz Struk
With DMA-API debug enabled testmgr triggers a "DMA-API: device driver maps memory from stack" warning, when tested on a crypto HW accelerator. Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-08-07crypto: af_alg - properly label AF_ALG socketMilan Broz
commit 4c63f83c2c2e16a13ce274ee678e28246bd33645 upstream. Th AF_ALG socket was missing a security label (e.g. SELinux) which means that socket was in "unlabeled" state. This was recently demonstrated in the cryptsetup package (cryptsetup v1.6.5 and later.) See https://bugzilla.redhat.com/show_bug.cgi?id=1115120 This patch clones the sock's label from the parent sock and resolves the issue (similar to AF_BLUETOOTH protocol family). Signed-off-by: Milan Broz <gmazyland@gmail.com> Acked-by: Paul Moore <paul@paul-moore.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-26net: Use netlink_ns_capable to verify the permisions of netlink messagesEric W. Biederman
[ Upstream commit 90f62cf30a78721641e08737bda787552428061e ] It is possible by passing a netlink socket to a more privileged executable and then to fool that executable into writing to the socket data that happens to be valid netlink message to do something that privileged executable did not intend to do. To keep this from happening replace bare capable and ns_capable calls with netlink_capable, netlink_net_calls and netlink_ns_capable calls. Which act the same as the previous calls except they verify that the opener of the socket had the desired permissions as well. Reported-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07crypto: crypto_wq - Fix late crypto work queue initializationTim Chen
commit 130fa5bc81b44b6cc1fbdea3abf6db0da22964e0 upstream. The crypto algorithm modules utilizing the crypto daemon could be used early when the system start up. Using module_init does not guarantee that the daemon's work queue is initialized when the cypto alorithm depending on crypto_wq starts. It is necessary to initialize the crypto work queue earlier at the subsystem init time to make sure that it is initialized when used. Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-20Revert "net: update consumers of MSG_MORE to recognize MSG_SENDPAGE_NOTLAST"Greg Kroah-Hartman
It turns out that commit: d3f7d56a7a4671d395e8af87071068a195257bf6 was applied to the tree twice, which didn't hurt anything, but it's good to fix this up. Reported-by: Veaceslav Falico <veaceslav@falico.eu> Cc: David S. Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Richard Weinberger <richard@nod.at> Cc: Shawn Landden <shawnlandden@gmail.com> Cc: Tom Herbert <therbert@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-11net: update consumers of MSG_MORE to recognize MSG_SENDPAGE_NOTLASTShawn Landden
commit d3f7d56a7a4671d395e8af87071068a195257bf6 upstream. Commit 35f9c09fe (tcp: tcp_sendpages() should call tcp_push() once) added an internal flag MSG_SENDPAGE_NOTLAST, similar to MSG_MORE. algif_hash, algif_skcipher, and udp used MSG_MORE from tcp_sendpages() and need to see the new flag as identical to MSG_MORE. This fixes sendfile() on AF_ALG. v3: also fix udp Cc: Tom Herbert <therbert@google.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: David S. Miller <davem@davemloft.net> Reported-and-tested-by: Shawn Landden <shawnlandden@gmail.com> Original-patch: Richard Weinberger <richard@nod.at> Signed-off-by: Shawn Landden <shawn@churchofgit.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-11crypto: authenc - Find proper IV address in ablkcipher callbackTom Lendacky
commit fc019c7122dfcd69c50142b57a735539aec5da95 upstream. When performing an asynchronous ablkcipher operation the authenc completion callback routine is invoked, but it does not locate and use the proper IV. The callback routine, crypto_authenc_encrypt_done, is updated to use the same method of calculating the address of the IV as is done in crypto_authenc_encrypt function which sets up the callback. Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-11crypto: ccm - Fix handling of zero plaintext when computing macHoria Geanta
commit 5638cabf3e4883f38dfb246c30980cebf694fbda upstream. There are cases when cryptlen can be zero in crypto_ccm_auth(): -encryptiom: input scatterlist length is zero (no plaintext) -decryption: input scatterlist contains only the mac plus the condition of having different source and destination buffers (or else scatterlist length = max(plaintext_len, ciphertext_len)). These are not handled correctly, leading to crashes like: root@p4080ds:~/crypto# insmod tcrypt.ko mode=45 ------------[ cut here ]------------ kernel BUG at crypto/scatterwalk.c:37! Oops: Exception in kernel mode, sig: 5 [#1] SMP NR_CPUS=8 P4080 DS Modules linked in: tcrypt(+) crc32c xts xcbc vmac pcbc ecb gcm ghash_generic gf128mul ccm ctr seqiv CPU: 3 PID: 1082 Comm: cryptomgr_test Not tainted 3.11.0 #14 task: ee12c5b0 ti: eecd0000 task.ti: eecd0000 NIP: c0204d98 LR: f9225848 CTR: c0204d80 REGS: eecd1b70 TRAP: 0700 Not tainted (3.11.0) MSR: 00029002 <CE,EE,ME> CR: 22044022 XER: 20000000 GPR00: f9225c94 eecd1c20 ee12c5b0 eecd1c28 ee879400 ee879400 00000000 ee607464 GPR08: 00000001 00000001 00000000 006b0000 c0204d80 00000000 00000002 c0698e20 GPR16: ee987000 ee895000 fffffff4 ee879500 00000100 eecd1d58 00000001 00000000 GPR24: ee879400 00000020 00000000 00000000 ee5b2800 ee607430 00000004 ee607460 NIP [c0204d98] scatterwalk_start+0x18/0x30 LR [f9225848] get_data_to_compute+0x28/0x2f0 [ccm] Call Trace: [eecd1c20] [f9225974] get_data_to_compute+0x154/0x2f0 [ccm] (unreliable) [eecd1c70] [f9225c94] crypto_ccm_auth+0x184/0x1d0 [ccm] [eecd1cb0] [f9225d40] crypto_ccm_encrypt+0x60/0x2d0 [ccm] [eecd1cf0] [c020d77c] __test_aead+0x3ec/0xe20 [eecd1e20] [c020f35c] test_aead+0x6c/0xe0 [eecd1e40] [c020f420] alg_test_aead+0x50/0xd0 [eecd1e60] [c020e5e4] alg_test+0x114/0x2e0 [eecd1ee0] [c020bd1c] cryptomgr_test+0x4c/0x60 [eecd1ef0] [c0047058] kthread+0xa8/0xb0 [eecd1f40] [c000eb0c] ret_from_kernel_thread+0x5c/0x64 Instruction dump: 0f080000 81290024 552807fe 0f080000 5529003a 4bffffb4 90830000 39400000 39000001 8124000c 2f890000 7d28579e <0f090000> 81240008 91230004 4e800020 ---[ end trace 6d652dfcd1be37bd ]--- Cc: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Horia Geanta <horia.geanta@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-08net: update consumers of MSG_MORE to recognize MSG_SENDPAGE_NOTLASTShawn Landden
[ Upstream commit d3f7d56a7a4671d395e8af87071068a195257bf6 ] Commit 35f9c09fe (tcp: tcp_sendpages() should call tcp_push() once) added an internal flag MSG_SENDPAGE_NOTLAST, similar to MSG_MORE. algif_hash, algif_skcipher, and udp used MSG_MORE from tcp_sendpages() and need to see the new flag as identical to MSG_MORE. This fixes sendfile() on AF_ALG. v3: also fix udp Reported-and-tested-by: Shawn Landden <shawnlandden@gmail.com> Cc: Tom Herbert <therbert@google.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: David S. Miller <davem@davemloft.net> Original-patch: Richard Weinberger <richard@nod.at> Signed-off-by: Shawn Landden <shawn@churchofgit.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-08net: rework recvmsg handler msg_name and msg_namelen logicHannes Frederic Sowa
[ Upstream commit f3d3342602f8bcbf37d7c46641cb9bca7618eb1c ] This patch now always passes msg->msg_namelen as 0. recvmsg handlers must set msg_namelen to the proper size <= sizeof(struct sockaddr_storage) to return msg_name to the user. This prevents numerous uninitialized memory leaks we had in the recvmsg handlers and makes it harder for new code to accidentally leak uninitialized memory. Optimize for the case recvfrom is called with NULL as address. We don't need to copy the address at all, so set it to NULL before invoking the recvmsg handler. We can do so, because all the recvmsg handlers must cope with the case a plain read() is called on them. read() also sets msg_name to NULL. Also document these changes in include/linux/net.h as suggested by David Miller. Changes since RFC: Set msg->msg_name = NULL if user specified a NULL in msg_name but had a non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't affect sendto as it would bail out earlier while trying to copy-in the address. It also more naturally reflects the logic by the callers of verify_iovec. With this change in place I could remove " if (!uaddr || msg_sys->msg_namelen == 0) msg->msg_name = NULL ". This change does not alter the user visible error logic as we ignore msg_namelen as long as msg_name is NULL. Also remove two unnecessary curly brackets in ___sys_recvmsg and change comments to netdev style. Cc: David Miller <davem@davemloft.net> Suggested-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04X.509: Remove certificate date checksDavid Howells
commit 124df926090b32a998483f6e43ebeccdbe5b5302 upstream. Remove the certificate date checks that are performed when a certificate is parsed. There are two checks: a valid from and a valid to. The first check is causing a lot of problems with system clocks that don't keep good time and the second places an implicit expiry date upon the kernel when used for module signing, so do we really need them? Signed-off-by: David Howells <dhowells@redhat.com> cc: David Woodhouse <dwmw2@infradead.org> cc: Rusty Russell <rusty@rustcorp.com.au> cc: Josh Boyer <jwboyer@redhat.com> cc: Alexander Holler <holler@ahsoftware.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-29crypto: ansi_cprng - Fix off by one error in non-block size requestNeil Horman
commit 714b33d15130cbb5ab426456d4e3de842d6c5b8a upstream. Stephan Mueller reported to me recently a error in random number generation in the ansi cprng. If several small requests are made that are less than the instances block size, the remainder for loop code doesn't increment rand_data_valid in the last iteration, meaning that the last bytes in the rand_data buffer gets reused on the subsequent smaller-than-a-block request for random data. The fix is pretty easy, just re-code the for loop to make sure that rand_data_valid gets incremented appropriately Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Reported-by: Stephan Mueller <stephan.mueller@atsec.com> CC: Stephan Mueller <stephan.mueller@atsec.com> CC: Petr Matousek <pmatouse@redhat.com> CC: Herbert Xu <herbert@gondor.apana.org.au> CC: "David S. Miller" <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Cc: Luis Henriques <luis.henriques@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-26crypto: api - Fix race condition in larval lookupHerbert Xu
commit 77dbd7a95e4a4f15264c333a9e9ab97ee27dc2aa upstream. crypto_larval_lookup should only return a larval if it created one. Any larval created by another entity must be processed through crypto_larval_wait before being returned. Otherwise this will lead to a larval being killed twice, which will most likely lead to a crash. Reported-by: Kees Cook <keescook@chromium.org> Tested-by: Kees Cook <keescook@chromium.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-13crypto: sanitize argument for format stringKees Cook
commit 1c8fca1d92e14859159a82b8a380d220139b7344 upstream. The template lookup interface does not provide a way to use format strings, so make sure that the interface cannot be abused accidentally. Signed-off-by: Kees Cook <keescook@chromium.org> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-25crypto: algboss - Hold ref count on larvalHerbert Xu
On Thu, Jun 20, 2013 at 10:00:21AM +0200, Daniel Borkmann wrote: > After having fixed a NULL pointer dereference in SCTP 1abd165e ("net: > sctp: fix NULL pointer dereference in socket destruction"), I ran into > the following NULL pointer dereference in the crypto subsystem with > the same reproducer, easily hit each time: > > BUG: unable to handle kernel NULL pointer dereference at (null) > IP: [<ffffffff81070321>] __wake_up_common+0x31/0x90 > PGD 0 > Oops: 0000 [#1] SMP > Modules linked in: padlock_sha(F-) sha256_generic(F) sctp(F) libcrc32c(F) [..] > CPU: 6 PID: 3326 Comm: cryptomgr_probe Tainted: GF 3.10.0-rc5+ #1 > Hardware name: Dell Inc. PowerEdge T410/0H19HD, BIOS 1.6.3 02/01/2011 > task: ffff88007b6cf4e0 ti: ffff88007b7cc000 task.ti: ffff88007b7cc000 > RIP: 0010:[<ffffffff81070321>] [<ffffffff81070321>] __wake_up_common+0x31/0x90 > RSP: 0018:ffff88007b7cde08 EFLAGS: 00010082 > RAX: ffffffffffffffe8 RBX: ffff88003756c130 RCX: 0000000000000000 > RDX: 0000000000000000 RSI: 0000000000000003 RDI: ffff88003756c130 > RBP: ffff88007b7cde48 R08: 0000000000000000 R09: ffff88012b173200 > R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000282 > R13: ffff88003756c138 R14: 0000000000000000 R15: 0000000000000000 > FS: 0000000000000000(0000) GS:ffff88012fc60000(0000) knlGS:0000000000000000 > CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b > CR2: 0000000000000000 CR3: 0000000001a0b000 CR4: 00000000000007e0 > DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 > DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 > Stack: > ffff88007b7cde28 0000000300000000 ffff88007b7cde28 ffff88003756c130 > 0000000000000282 ffff88003756c128 ffffffff81227670 0000000000000000 > ffff88007b7cde78 ffffffff810722b7 ffff88007cdcf000 ffffffff81a90540 > Call Trace: > [<ffffffff81227670>] ? crypto_alloc_pcomp+0x20/0x20 > [<ffffffff810722b7>] complete_all+0x47/0x60 > [<ffffffff81227708>] cryptomgr_probe+0x98/0xc0 > [<ffffffff81227670>] ? crypto_alloc_pcomp+0x20/0x20 > [<ffffffff8106760e>] kthread+0xce/0xe0 > [<ffffffff81067540>] ? kthread_freezable_should_stop+0x70/0x70 > [<ffffffff815450dc>] ret_from_fork+0x7c/0xb0 > [<ffffffff81067540>] ? kthread_freezable_should_stop+0x70/0x70 > Code: 41 56 41 55 41 54 53 48 83 ec 18 66 66 66 66 90 89 75 cc 89 55 c8 > 4c 8d 6f 08 48 8b 57 08 41 89 cf 4d 89 c6 48 8d 42 e > RIP [<ffffffff81070321>] __wake_up_common+0x31/0x90 > RSP <ffff88007b7cde08> > CR2: 0000000000000000 > ---[ end trace b495b19270a4d37e ]--- > > My assumption is that the following is happening: the minimal SCTP > tool runs under ``echo 1 > /proc/sys/net/sctp/auth_enable'', hence > it's making use of crypto_alloc_hash() via sctp_auth_init_hmacs(). > It forks itself, heavily allocates, binds, listens and waits in > accept on sctp sockets, and then randomly kills some of them (no > need for an actual client in this case to hit this). Then, again, > allocating, binding, etc, and then killing child processes. > > The problem that might be happening here is that cryptomgr requests > the module to probe/load through cryptomgr_schedule_probe(), but > before the thread handler cryptomgr_probe() returns, we return from > the wait_for_completion_interruptible() function and probably already > have cleared up larval, thus we run into a NULL pointer dereference > when in cryptomgr_probe() complete_all() is being called. > > If we wait with wait_for_completion() instead, this panic will not > occur anymore. This is valid, because in case a signal is pending, > cryptomgr_probe() returns from probing anyway with properly calling > complete_all(). The use of wait_for_completion_interruptible is intentional so that we don't lock up the thread if a bug causes us to never wake up. This bug is caused by the helper thread using the larval without holding a reference count on it. If the helper thread completes after the original thread requesting for help has gone away and destroyed the larval, then we get the crash above. So the fix is to hold a reference count on the larval. Cc: <stable@vger.kernel.org> # 3.6+ Reported-by: Daniel Borkmann <dborkman@redhat.com> Tested-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-06-05crypto: blowfish - disable AVX2 implementationJussi Kivilinna
It appears that the performance of 'vpgatherdd' is suboptimal for this kind of workload (tested on Core i5-4570) and causes blowfish-avx2 to be significantly slower than blowfish-amd64. So disable the AVX2 implementation to avoid performance regressions. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-06-05crypto: twofish - disable AVX2 implementationJussi Kivilinna
It appears that the performance of 'vpgatherdd' is suboptimal for this kind of workload (tested on Core i5-4570) and causes twofish_avx2 to be significantly slower than twofish_avx. So disable the AVX2 implementation to avoid performance regressions. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-05-05Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull mudule updates from Rusty Russell: "We get rid of the general module prefix confusion with a binary config option, fix a remove/insert race which Never Happens, and (my favorite) handle the case when we have too many modules for a single commandline. Seriously, the kernel is full, please go away!" * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: modpost: fix unwanted VMLINUX_SYMBOL_STR expansion X.509: Support parse long form of length octets in Authority Key Identifier module: don't unlink the module until we've removed all exposure. kernel: kallsyms: memory override issue, need check destination buffer length MODSIGN: do not send garbage to stderr when enabling modules signature modpost: handle huge numbers of modules. modpost: add -T option to read module names from file/stdin. modpost: minor cleanup. genksyms: pass symbol-prefix instead of arch module: fix symbol versioning with symbol prefixes CONFIG_SYMBOL_PREFIX: cleanup.
2013-05-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto update from Herbert Xu: - XTS mode optimisation for twofish/cast6/camellia/aes on x86 - AVX2/x86_64 implementation for blowfish/twofish/serpent/camellia - SSSE3/AVX/AVX2 optimisations for sha256/sha512 - Added driver for SAHARA2 crypto accelerator - Fix for GMAC when used in non-IPsec secnarios - Added generic CMAC implementation (including IPsec glue) - IP update for crypto/atmel - Support for more than one device in hwrng/timeriomem - Added Broadcom BCM2835 RNG driver - Misc fixes * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (59 commits) crypto: caam - fix job ring cleanup code crypto: camellia - add AVX2/AES-NI/x86_64 assembler implementation of camellia cipher crypto: serpent - add AVX2/x86_64 assembler implementation of serpent cipher crypto: twofish - add AVX2/x86_64 assembler implementation of twofish cipher crypto: blowfish - add AVX2/x86_64 implementation of blowfish cipher crypto: tcrypt - add async cipher speed tests for blowfish crypto: testmgr - extend camellia test-vectors for camellia-aesni/avx2 crypto: aesni_intel - fix Kconfig problem with CRYPTO_GLUE_HELPER_X86 crypto: aesni_intel - add more optimized XTS mode for x86-64 crypto: x86/camellia-aesni-avx - add more optimized XTS code crypto: cast6-avx: use new optimized XTS code crypto: x86/twofish-avx - use optimized XTS code crypto: x86 - add more optimized XTS-mode for serpent-avx xfrm: add rfc4494 AES-CMAC-96 support crypto: add CMAC support to CryptoAPI crypto: testmgr - add empty test vectors for null ciphers crypto: testmgr - add AES GMAC test vectors crypto: gcm - fix rfc4543 to handle async crypto correctly crypto: gcm - make GMAC work when dst and src are different hwrng: timeriomem - added devicetree hooks ...
2013-04-29raid6test: use prandom_bytes()Akinobu Mita
Use prandom_bytes() to generate random bytes for test data. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Dan Williams <djbw@fb.com> Cc: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-25crypto: camellia - add AVX2/AES-NI/x86_64 assembler implementation of ↵Jussi Kivilinna
camellia cipher Patch adds AVX2/AES-NI/x86-64 implementation of Camellia cipher, requiring 32 parallel blocks for input (512 bytes). Compared to AVX implementation, this version is extended to use the 256-bit wide YMM registers. For AES-NI instructions data is split to two 128-bit registers and merged afterwards. Even with this additional handling, performance should be higher compared to the AES-NI/AVX implementation. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-25crypto: serpent - add AVX2/x86_64 assembler implementation of serpent cipherJussi Kivilinna
Patch adds AVX2/x86-64 implementation of Serpent cipher, requiring 16 parallel blocks for input (256 bytes). Implementation is based on the AVX implementation and extends to use the 256-bit wide YMM registers. Since serpent does not use table look-ups, this implementation should be close to two times faster than the AVX implementation. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-25crypto: twofish - add AVX2/x86_64 assembler implementation of twofish cipherJussi Kivilinna
Patch adds AVX2/x86-64 implementation of Twofish cipher, requiring 16 parallel blocks for input (256 bytes). Table look-ups are performed using vpgatherdd instruction directly from vector registers and thus should be faster than earlier implementations. Implementation also uses 256-bit wide YMM registers, which should give additional speed up compared to the AVX implementation. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-25crypto: blowfish - add AVX2/x86_64 implementation of blowfish cipherJussi Kivilinna
Patch adds AVX2/x86-64 implementation of Blowfish cipher, requiring 32 parallel blocks for input (256 bytes). Table look-ups are performed using vpgatherdd instruction directly from vector registers and thus should be faster than earlier implementations. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-25crypto: tcrypt - add async cipher speed tests for blowfishJussi Kivilinna
2013-04-25crypto: testmgr - extend camellia test-vectors for camellia-aesni/avx2Jussi Kivilinna
2013-04-25crypto: aesni_intel - fix Kconfig problem with CRYPTO_GLUE_HELPER_X86Jussi Kivilinna
The Kconfig setting for glue helper module is CRYPTO_GLUE_HELPER_X86, but recent change for aesni_intel used CRYPTO_GLUE_HELPER instead. Patch corrects this issue. Cc: kbuild-all@01.org Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-25crypto: aesni_intel - add more optimized XTS mode for x86-64Jussi Kivilinna
Add more optimized XTS code for aesni_intel in 64-bit mode, for smaller stack usage and boost for speed. tcrypt results, with Intel i5-2450M: 256-bit key enc dec 16B 0.98x 0.99x 64B 0.64x 0.63x 256B 1.29x 1.32x 1024B 1.54x 1.58x 8192B 1.57x 1.60x 512-bit key enc dec 16B 0.98x 0.99x 64B 0.60x 0.59x 256B 1.24x 1.25x 1024B 1.39x 1.42x 8192B 1.38x 1.42x I chose not to optimize smaller than block size of 256 bytes, since XTS is practically always used with data blocks of size 512 bytes. This is why performance is reduced in tcrypt for 64 byte long blocks. Cc: Huang Ying <ying.huang@intel.com> Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-25crypto: add CMAC support to CryptoAPIJussi Kivilinna
Patch adds support for NIST recommended block cipher mode CMAC to CryptoAPI. This work is based on Tom St Denis' earlier patch, http://marc.info/?l=linux-crypto-vger&m=135877306305466&w=2 Cc: Tom St Denis <tstdenis@elliptictech.com> Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-25crypto: testmgr - add empty test vectors for null ciphersJussi Kivilinna
Without these, kernel log shows: [ 5.984881] alg: No test for cipher_null (cipher_null-generic) [ 5.985096] alg: No test for ecb(cipher_null) (ecb-cipher_null) [ 5.985170] alg: No test for compress_null (compress_null-generic) [ 5.985297] alg: No test for digest_null (digest_null-generic) Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-25crypto: testmgr - add AES GMAC test vectorsJussi Kivilinna
2013-04-25crypto: gcm - fix rfc4543 to handle async crypto correctlyJussi Kivilinna
If the gcm cipher used by rfc4543 does not complete request immediately, the authentication tag is not copied to destination buffer. Patch adds correct async logic for this case. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-25crypto: gcm - make GMAC work when dst and src are differentJussi Kivilinna
The GMAC code assumes that dst==src, which causes problems when trying to add rfc4543(gcm(aes)) test vectors. So fix this code to work when source and destination buffer are different. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-25crypto: sha512 - Create module providing optimized SHA512 routines using ↵Tim Chen
SSSE3, AVX or AVX2 instructions. We added glue code and config options to create crypto module that uses SSE/AVX/AVX2 optimized SHA512 x86_64 assembly routines. Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-25crypto: sha512 - Expose generic sha512 routine to be callable from other modulesTim Chen
Other SHA512 routines may need to use the generic routine when FPU is not available. Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-25crypto: sha256 - Create module providing optimized SHA256 routines using ↵Tim Chen
SSSE3, AVX or AVX2 instructions. We added glue code and config options to create crypto module that uses SSE/AVX/AVX2 optimized SHA256 x86_64 assembly routines. Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto fix from Herbert Xu: "This fixes a kernel memory leak in the algif interface" * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: algif - suppress sending source address information in recvmsg
2013-04-22X.509: Support parse long form of length octets in Authority Key IdentifierChun-Yi Lee
Per X.509 spec in 4.2.1.1 section, the structure of Authority Key Identifier Extension is: AuthorityKeyIdentifier ::= SEQUENCE { keyIdentifier [0] KeyIdentifier OPTIONAL, authorityCertIssuer [1] GeneralNames OPTIONAL, authorityCertSerialNumber [2] CertificateSerialNumber OPTIONAL } KeyIdentifier ::= OCTET STRING When a certificate also provides authorityCertIssuer and authorityCertSerialNumber then the length of AuthorityKeyIdentifier SEQUENCE is likely to long form format. e.g. The example certificate demos/tunala/A-server.pem in openssl source: X509v3 Authority Key Identifier: keyid:49:FB:45:72:12:C4:CC:E1:45:A1:D3:08:9E:95:C4:2C:6D:55:3F:17 DirName:/C=NZ/L=Wellington/O=Really Irresponsible Authorisation Authority (RIAA)/OU=Cert-stamping/CN=Jackov al-Trades/emailAddress=none@fake.domain serial:00 Current parsing rule of OID_authorityKeyIdentifier only take care the short form format, it causes load certificate to modsign_keyring fail: [ 12.061147] X.509: Extension: 47 [ 12.075121] MODSIGN: Problem loading in-kernel X.509 certificate (-74) So, this patch add the parsing rule for support long form format against Authority Key Identifier. v3: Changed the size check in "Short Form length" case, we allow v[3] smaller then (vlen - 4) because authorityCertIssuer and authorityCertSerialNumber are also possible attach in AuthorityKeyIdentifier sequence. v2: - Removed comma from author's name. - Moved 'Short Form length' comment inside the if-body. - Changed the type of sub to size_t. - Use ASN1_INDEFINITE_LENGTH rather than writing 0x80 and 127. - Moved the key_len's value assignment before alter v. - Fixed the typo of octets. - Add 2 to v before entering the loop for calculate the length. - Removed the comment of check vlen. Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Josh Boyer <jwboyer@redhat.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Chun-Yi Lee <jlee@suse.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-04-10crypto: algif - suppress sending source address information in recvmsgMathias Krause
The current code does not set the msg_namelen member to 0 and therefore makes net/socket.c leak the local sockaddr_storage variable to userland -- 128 bytes of kernel stack memory. Fix that. Cc: <stable@vger.kernel.org> # 2.6.38 Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto fixes from Herbert Xu: "This fixes a GCM bug that breaks IPsec and a compile problem in ux500." * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: ux500 - add missing comma crypto: gcm - fix assumption that assoc has one segment
2013-04-03crypto: sha256 - Expose SHA256 generic routine to be callable externally.Tim Chen
Other SHA256 routine may need to use the generic routine when FPU is not available. Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-02crypto: gcm - fix assumption that assoc has one segmentJussi Kivilinna
rfc4543(gcm(*)) code for GMAC assumes that assoc scatterlist always contains only one segment and only makes use of this first segment. However ipsec passes assoc with three segments when using 'extended sequence number' thus in this case rfc4543(gcm(*)) fails to function correctly. Patch fixes this issue. Reported-by: Chaoxing Lin <Chaoxing.Lin@ultra-3eti.com> Tested-by: Chaoxing Lin <Chaoxing.Lin@ultra-3eti.com> Cc: stable@vger.kernel.org Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-03-10crypto: user - constify netlink dispatch tableMathias Krause
There is no need to modify the netlink dispatch table at runtime and making it const even makes the resulting object file slightly smaller. Cc: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
