commit d6040764adcb5cb6de1489422411d701c158bb69 upstream.
Make sure CRYPTO_ALG_DEAD bit is cleared before proceeding with
the algorithm registration. This fixes qat-dh registration when
driver is restarted
Signed-off-by: Salvatore Benedetto <salvatore.benedetto@intel.com>
commit 57891633eeef60e732e045731cf20e50ee80acb4 upstream.
Both asn1 headers are included by rsa_helper.c, so rsa_helper.o
should explicitly depend on them.
Signed-off-by: David Michael <david.michael@coreos.com>
Cc: Tuomas Tynkkynen <tuomas@tuxera.com>
commit 48a992727d82cb7db076fa15d372178743b1f4cd upstream.
Algorithms not compatible with mcryptd could be spawned by mcryptd
with a direct crypto_alloc_tfm invocation using a "mcryptd(alg)" name
construct. This causes mcryptd to crash the kernel if an arbitrary
"alg" is incompatible and not intended to be used with mcryptd. It is
an issue if AF_ALG tries to spawn mcryptd(alg) to expose it externally.
But such algorithms must be used internally and not be exposed.
We added a check to enforce that only internal algorithms are allowed
with mcryptd at the time mcryptd is spawning an algorithm.
Link: http://marc.info/?l=linux-crypto-vger&m=148063683310477&w=2
Reported-by: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com>
commit 50d2e6dc1f83db0563c7d6603967bf9585ce934b upstream.
The cipher block size for GCM is 16 bytes, and thus the CTR transform
used in crypto_gcm_setkey() will also expect a 16-byte IV. However,
the code currently reserves only 8 bytes for the IV, causing
an out-of-bounds access in the CTR transform. This patch fixes
the issue by setting the size of the IV buffer to 16 bytes.
Fixes: 84c911523020 ("[CRYPTO] gcm: Add support for async ciphers")
Signed-off-by: Ondrej Mosnacek <omosnacek@gmail.com>
commit 7ee7014d0eb6bcac679c0bd5fe9ce65bc4325648 upstream.
Dave Young reported:
> Hi,
> I saw the warning "Missing required AuthAttr" when testing kexec,
> known issue? Idea about how to fix it?
> The kernel is latest linus tree plus sevral patches from Toshi to
> cleanup io resource structure.
> in function pkcs7_sig_note_set_of_authattrs():
> if (!test_bit(sinfo_has_content_type, &sinfo->aa_set) ||
> !test_bit(sinfo_has_message_digest, &sinfo->aa_set) ||
> (ctx->msg->data_type == OID_msIndirectData &&
> !test_bit(sinfo_has_ms_opus_info, &sinfo->aa_set))) {
> pr_warn("Missing required AuthAttr\n");
> return -EBADMSG;
> The third condition below is true:
> I signed the kernel with redhat test key like below:
> pesign -c 'Red Hat Test Certificate' -i arch/x86/boot/bzImage -o /boot/vmlinuz-4.4.0-rc8+ -s --force
And right he is! The Authenticode specification is a paragon amongst
technical documents, and has this pearl of wisdom to offer:
Authenticode-Specific SignerInfo UnauthenticatedAttributes Structures
The following Authenticode-specific data structures are present in
SignerInfo authenticated attributes.
SpcSpOpusInfo
SpcSpOpusInfo is identified by SPC_SP_OPUS_INFO_OBJID
(1.3.6.1.4.1.311.2.1.12) and is defined as follows:
SpcSpOpusInfo ::= SEQUENCE {
programName [0] EXPLICIT SpcString OPTIONAL,
moreInfo [1] EXPLICIT SpcLink OPTIONAL,
} --#public--
SpcSpOpusInfo has two fields:
programName
This field contains the program description:
If publisher chooses not to specify a description, the SpcString
structure contains a zero-length program name.
If the publisher chooses to specify a
description, the SpcString structure contains a Unicode string.
moreInfo
This field is set to an SPCLink structure that contains a URL for
a Web site with more information about the signer. The URL is an
ASCII string.
Which is to say that this is an optional *unauthenticated* field which
may be present in the Authenticated Attribute list. This is not how
pkcs7 is supposed to work, so when David implemented this, he didn't
appreciate the subtlety the original spec author was working with, and
missed the part of the sublime prose that says this Authenticated
Attribute is an Unauthenticated Attribute. As a result, the code in
question simply takes as given that the Authenticated Attributes should
be authenticated.
But this one should not, individually. Because it says it's not
authenticated.
It still has to hash right so the TBS digest is correct. So it is both
authenticated and unauthenticated, all at once. Truly, a wonder of
technical accomplishment.
Additionally, pesign's implementation has always attempted to be
compatible with the signatures emitted from contemporary versions of
Microsoft's signtool.exe. During the initial implementation, Microsoft
signatures always produced the same values for SpcSpOpusInfo -
{U"Microsoft Windows", "http://www.microsoft.com"} - without regard to
who the signer was.
Sometime between Windows 8 and Windows 8.1 they stopped including the
field in their signatures altogether, and as such pesign stopped
producing them in commits c0c4da6 and d79cb0c, sometime around June of
2012. The theory here is that anything that breaks with
pesign signatures would also be breaking with signtool.exe sigs as well,
and that'll be a more noticed problem for firmwares parsing it, so it'll
get fixed. The fact that we've done exactly this bug in Linux code is
first class, grade A irony.
So anyway, we should not be checking this field for presence or any
particular value: if the field exists, it should be at the right place,
but aside from that, as long as the hash matches the field is good.
Signed-off-by: Peter Jones <pjones@redhat.com>
Tested-by: Dave Young <dyoung@redhat.com>
Signed-off-by: Juerg Haefliger <juerg.haefliger@hpe.com>
commit a397ba829d7f8aff4c90af3704573a28ccd61a59 upstream.
Move common values and types used by ghash-generic to a new header file
so drivers can directly use ghash-generic as a fallback implementation.
Fixes: cc333cd68dfa ("crypto: vmx - Adding GHASH routines for VMX module")
Signed-off-by: Marcelo Cerri <marcelo.cerri@canonical.com>
commit c84750906b4818d4929fbf73a4ae6c113b94f52b upstream.
Add missing dmaengine_unmap_put(), so we don't OOM during RAID6 sync.
Fixes: 1786b943dad0 ("async_pq_val: convert to dmaengine_unmap_data")
Signed-off-by: Justin Maggard <jmaggard@netgear.com>
Reviewed-by: Dan Williams <dan.j.williams@intel.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
commit 53a5d5ddccf849dbc27a8c1bba0b43c3a45fb792 upstream.
The current implementation uses a global per-cpu array to store
data which are used to derive the next IV. This is insecure as
the attacker may change the stored data.
This patch removes all traces of chaining and replaces it with
multiplication of the salt and the sequence number.
Fixes: a10f554fa7e0 ("crypto: echainiv - Add encrypted chain IV...")
Reported-by: Mathias Krause <minipli@googlemail.com>
commit acdb04d0b36769b3e05990c488dc74d8b7ac8060 upstream.
When we need to allocate a temporary blkcipher_walk_next and it
fails, the code is supposed to take the slow path of processing
the data block by block. However, due to an unrelated change
we instead end up dereferencing the NULL pointer.
This patch fixes it by moving the unrelated bsize setting out
of the way so that we enter the slow path as inteded.
Fixes: 7607bd8ff03b ("[CRYPTO] blkcipher: Added blkcipher_walk_virt_block")
Reported-by: xiakaixu <xiakaixu@huawei.com>
Reported-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Tested-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
commit 0bd2223594a4dcddc1e34b15774a3a4776f7749e upstream.
When calling .import() on a cryptd ahash_request, the structure members
that describe the child transform in the shash_desc need to be initialized
like they are when calling .init()
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
commit 5f070e81bee35f1b7bd1477bb223a873ff657803 upstream.
When there is more data to be processed, the current test in
scatterwalk_done may prevent us from calling pagedone even when
we should.
In particular, if we're on an SG entry spanning multiple pages
where the last page is not a full page, we will incorrectly skip
calling pagedone on the second last page.
This patch fixes this by adding a separate test for whether we've
reached the end of a page.
commit b30bdfa86431afbafe15284a3ad5ac19b49b88e3 upstream.
As it is if you ask for a sync gcm you may actually end up with
an async one because it does not filter out async implementations
of ghash.
This patch fixes this by adding the necessary filter when looking
for ghash.
commit 055ddaace03580455a7b7dbea8e93d62acee61fc upstream.
Commit 9aa867e46565 ("crypto: user - Add CRYPTO_MSG_DELRNG")
accidentally removed the minimum size check for CRYPTO_MSG_GETALG
netlink messages. This allows userland to send a truncated
CRYPTO_MSG_GETALG message as short as a netlink header only making
crypto_report() operate on uninitialized memory by accessing data
beyond the end of the netlink message.
Fix this be re-adding the minimum required size of CRYPTO_MSG_GETALG
messages to the crypto_msg_min[] array.
Fixes: 9aa867e46565 ("crypto: user - Add CRYPTO_MSG_DELRNG")
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Cc: Steffen Klassert <steffen.klassert@secunet.com>
commit bad6a185b4d6f81d0ed2b6e4c16307969f160b95 upstream.
In some rare randconfig builds, we can end up with
ASYMMETRIC_PUBLIC_KEY_SUBTYPE enabled but CRYPTO_AKCIPHER disabled,
which fails to link because of the reference to crypto_alloc_akcipher:
crypto/built-in.o: In function `public_key_verify_signature':
:(.text+0x110e4): undefined reference to `crypto_alloc_akcipher'
This adds a Kconfig 'select' statement to ensure the dependency
is always there.
commit df27b26f04ed388ff4cc2b5d8cfdb5d97678816f upstream.
As akcipher uses an SG interface, you must not use vmalloc memory
as input for it. This patch fixes testmgr to copy the vmalloc
test vectors to kmalloc memory before running the test.
This patch also removes a superfluous sg_virt call in do_test_rsa.
Reported-by: Anatoly Pugachev <matorola@gmail.com>
commit 13f4bb78cf6a312bbdec367ba3da044b09bf0e29 upstream.
The crypto hash walk code is broken when supplied with an offset
greater than or equal to PAGE_SIZE. This patch fixes it by adjusting
walk->pg and walk->offset when this happens.
Reported-by: Steffen Klassert <steffen.klassert@secunet.com>
commit e54358915d0a00399c11c2c23ae1be674cba188a upstream.
Despite what the DocBook comment to pkcs7_validate_trust() says, the
*_trusted argument is never set to false.
pkcs7_validate_trust() only positively sets *_trusted upon encountering
a trusted PKCS#7 SignedInfo block.
This is quite unfortunate since its callers, system_verify_data() for
example, depend on pkcs7_validate_trust() clearing *_trusted on non-trust.
Indeed, UBSAN splats when attempting to load the uninitialized local
variable 'trusted' from system_verify_data() in pkcs7_validate_trust():
UBSAN: Undefined behaviour in crypto/asymmetric_keys/pkcs7_trust.c:194:14
load of value 82 is not a valid value for type '_Bool'
Call Trace:
[<ffffffff818c4d35>] dump_stack+0xbc/0x117
[<ffffffff818c4c79>] ? _atomic_dec_and_lock+0x169/0x169
[<ffffffff8194113b>] ubsan_epilogue+0xd/0x4e
[<ffffffff819419fa>] __ubsan_handle_load_invalid_value+0x111/0x158
[<ffffffff819418e9>] ? val_to_string.constprop.12+0xcf/0xcf
[<ffffffff818334a4>] ? x509_request_asymmetric_key+0x114/0x370
[<ffffffff814b83f0>] ? kfree+0x220/0x370
[<ffffffff818312c2>] ? public_key_verify_signature_2+0x32/0x50
[<ffffffff81835e04>] pkcs7_validate_trust+0x524/0x5f0
[<ffffffff813c391a>] system_verify_data+0xca/0x170
[<ffffffff813c3850>] ? top_trace_array+0x9b/0x9b
[<ffffffff81510b29>] ? __vfs_read+0x279/0x3d0
[<ffffffff8129372f>] mod_verify_sig+0x1ff/0x290
The implication is that pkcs7_validate_trust() effectively grants trust
when it really shouldn't have.
Fix this by explicitly setting *_trusted to false at the very beginning
of pkcs7_validate_trust().
Signed-off-by: Nicolai Stange <nicstange@gmail.com>
commit ac4cbedfdf55455b4c447f17f0fa027dbf02b2a6 upstream.
There are still a couple of minor issues in the X.509 leap year handling:
(1) To avoid doing a modulus-by-400 in addition to a modulus-by-100 when
determining whether the year is a leap year or not, I divided the year
by 100 after doing the modulus-by-100, thereby letting the compiler do
one instruction for both, and then did a modulus-by-4.
Unfortunately, I then passed the now-modified year value to mktime64()
to construct a time value.
Since this isn't a fast path and since mktime64() does a bunch of
divisions, just condense down to "% 400". It's also easier to read.
(2) The default month length for any February where the year doesn't
divide by four exactly is obtained from the month_length[] array where
the value is 29, not 28.
This is fixed by altering the table.
Reported-by: Rudolf Polzer <rpolzer@google.com>
Acked-by: David Woodhouse <David.Woodhouse@intel.com>
commit 2b8b28fd232233c22fb61009dd8b0587390d2875 upstream.
We're clearing the wrong memory. The memory corruption is likely
harmless because we weren't going to use that stack memory again but not
zeroing is a potential information leak.
Fixes: e28facde3c39 ('crypto: keywrap - add key wrapping block chaining mode')
Acked-by: Stephan Mueller <smueller@chronox.de>
commit dad41997063723eaf5f77bc2015606a5a9bce320 upstream.
The async path cannot use MAY_BACKLOG because it is not meant to
block, which is what MAY_BACKLOG does. On the other hand, both
the sync and async paths can make use of MAY_SLEEP.
commit 6454c2b83f719057069777132b13949e4c6b6350 upstream.
Any access to non-constant bits of the private context must be
done under the socket lock, in particular, this includes ctx->req.
This patch moves such accesses under the lock, and fetches the
tfm from the parent socket which is guaranteed to be constant,
rather than from ctx->req.
commit ec69bbfb9902c32a5c1492f2b1b8ad032a66d724 upstream.
The async path in algif_skcipher assumes that the crypto completion
function will be called with the original request. This is not
necessarily the case. In fact there is no need for this anyway
since we already embed information into the request with struct
skcipher_async_req.
This patch adds a pointer to that struct and then passes it as
the data to the callback function.
Tested-by: Tadeusz Struk <tadeusz.struk@intel.com>
commit 63e41ebc6630f39422d87f8a4bade1e793f37a01 upstream.
We miss to take the crypto_alg_sem semaphore when traversing the
crypto_alg_list for CRYPTO_MSG_GETALG dumps. This allows a race with
crypto_unregister_alg() removing algorithms from the list while we're
still traversing it, thereby leading to a use-after-free as show below:
[ 3482.071639] general protection fault: 0000 [#1] SMP
[ 3482.075639] Modules linked in: aes_x86_64 glue_helper lrw ablk_helper cryptd gf128mul ipv6 pcspkr serio_raw virtio_net microcode virtio_pci virtio_ring virtio sr_mod cdrom [last unloaded: aesni_intel]
[ 3482.075639] CPU: 1 PID: 11065 Comm: crconf Not tainted 4.3.4-grsec+ #126
[ 3482.075639] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.7.5-20140531_083030-gandalf 04/01/2014
[ 3482.075639] task: ffff88001cd41a40 ti: ffff88001cd422c8 task.ti: ffff88001cd422c8
[ 3482.075639] RIP: 0010:[<ffffffff93722bd3>] [<ffffffff93722bd3>] strncpy+0x13/0x30
[ 3482.075639] RSP: 0018:ffff88001f713b60 EFLAGS: 00010202
[ 3482.075639] RAX: ffff88001f6c4430 RBX: ffff88001f6c43a0 RCX: ffff88001f6c4430
[ 3482.075639] RDX: 0000000000000040 RSI: fefefefefefeff16 RDI: ffff88001f6c4430
[ 3482.075639] RBP: ffff88001f713b60 R08: ffff88001f6c4470 R09: ffff88001f6c4480
[ 3482.075639] R10: 0000000000000002 R11: 0000000000000246 R12: ffff88001ce2aa28
[ 3482.075639] R13: ffff880000093700 R14: ffff88001f5e4bf8 R15: 0000000000003b20
[ 3482.075639] FS: 0000033826fa2700(0000) GS:ffff88001e900000(0000) knlGS:0000000000000000
[ 3482.075639] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 3482.075639] CR2: ffffffffff600400 CR3: 00000000139ec000 CR4: 00000000001606f0
[ 3482.075639] Stack:
[ 3482.075639] ffff88001f713bd8 ffffffff936ccd00 ffff88001e5c4200 ffff880000093700
[ 3482.075639] ffff88001f713bd0 ffffffff938ef4bf 0000000000000000 0000000000003b20
[ 3482.075639] ffff88001f5e4bf8 ffff88001f5e4848 0000000000000000 0000000000003b20
[ 3482.075639] Call Trace:
[ 3482.075639] [<ffffffff936ccd00>] crypto_report_alg+0xc0/0x3e0
[ 3482.075639] [<ffffffff938ef4bf>] ? __alloc_skb+0x16f/0x300
[ 3482.075639] [<ffffffff936cd08a>] crypto_dump_report+0x6a/0x90
[ 3482.075639] [<ffffffff93935707>] netlink_dump+0x147/0x2e0
[ 3482.075639] [<ffffffff93935f99>] __netlink_dump_start+0x159/0x190
[ 3482.075639] [<ffffffff936ccb13>] crypto_user_rcv_msg+0xc3/0x130
[ 3482.075639] [<ffffffff936cd020>] ? crypto_report_alg+0x3e0/0x3e0
[ 3482.075639] [<ffffffff936cc4b0>] ? alg_test_crc32c+0x120/0x120
[ 3482.075639] [<ffffffff93933145>] ? __netlink_lookup+0xd5/0x120
[ 3482.075639] [<ffffffff936cca50>] ? crypto_add_alg+0x1d0/0x1d0
[ 3482.075639] [<ffffffff93938141>] netlink_rcv_skb+0xe1/0x130
[ 3482.075639] [<ffffffff936cc4f8>] crypto_netlink_rcv+0x28/0x40
[ 3482.075639] [<ffffffff939375a8>] netlink_unicast+0x108/0x180
[ 3482.075639] [<ffffffff93937c21>] netlink_sendmsg+0x541/0x770
[ 3482.075639] [<ffffffff938e31e1>] sock_sendmsg+0x21/0x40
[ 3482.075639] [<ffffffff938e4763>] SyS_sendto+0xf3/0x130
[ 3482.075639] [<ffffffff93444203>] ? bad_area_nosemaphore+0x13/0x20
[ 3482.075639] [<ffffffff93444470>] ? __do_page_fault+0x80/0x3a0
[ 3482.075639] [<ffffffff939d80cb>] entry_SYSCALL_64_fastpath+0x12/0x6e
[ 3482.075639] Code: 88 4a ff 75 ed 5d 48 0f ba 2c 24 3f c3 66 66 2e 0f 1f 84 00 00 00 00 00 55 48 85 d2 48 89 f8 48 89 f9 4c 8d 04 17 48 89 e5 74 15 <0f> b6 16 80 fa 01 88 11 48 83 de ff 48 83 c1 01 4c 39 c1 75 eb
[ 3482.075639] RIP [<ffffffff93722bd3>] strncpy+0x13/0x30
To trigger the race run the following loops simultaneously for a while:
$ while : ; do modprobe aesni-intel; rmmod aesni-intel; done
$ while : ; do crconf show all > /dev/null; done
Fix the race by taking the crypto_alg_sem read lock, thereby preventing
crypto_unregister_alg() from modifying the algorithm list during the
dump.
This bug has been detected by the PaX memory sanitize feature.
Cc: PaX Team <pageexec@freemail.hu>
commit fe09786178f9df713a4b2dd6b93c0a722346bf5e upstream.
hash_sendmsg/sendpage() need to wait for the completion
of crypto_ahash_init() otherwise it can cause panic.
Signed-off-by: Rui Wang <rui.y.wang@intel.com>
commit 00420a65fa2beb3206090ead86942484df2275f3 upstream.
The has_key logic is wrong for shash algorithms as they always
have a setkey function. So we should instead be testing against
shash_no_setkey.
Fixes: a5596d633278 ("crypto: hash - Add crypto_ahash_has_setkey")
Reported-by: Stephan Mueller <smueller@chronox.de>
Tested-by: Stephan Mueller <smueller@chronox.de>
commit 202736d99b7f29279db9da61587f11a08a04a9c6 upstream.
We mark the end of the SG list in sendmsg and sendpage and unmark
it on the next send call. Unfortunately the unmarking in sendmsg
is off-by-one, leading to an SG list that is too short.
Fixes: 0f477b655a52 ("crypto: algif - Mark sgl end at the end of data")
commit 4f0414e54e4d1893c6f08260693f8ef84c929293 upstream.
We need to load the TX SG list in sendmsg(2) after waiting for
incoming data, not before.
Tested-by: Dmitry Vyukov <dvyukov@google.com>
commit fd7f6727102a1ccf6b4c1dfcc631f9b546526b26 upstream.
I don't think it makes sense for a module to have a soft dependency
on itself. This seems quite cyclic by nature and I can't see what
purpose it could serve.
OTOH libcrc32c calls crypto_alloc_shash("crc32c", 0, 0) so it pretty
much assumes that some incarnation of the "crc32c" hash algorithm has
been loaded. Therefore it makes sense to have the soft dependency
there (as crc-t10dif does.)
Cc: Tim Chen <tim.c.chen@linux.intel.com>
Signed-off-by: Jean Delvare <jdelvare@suse.de>
commit 1822793a523e5d5730b19cc21160ff1717421bc8 upstream.
We need to lock the child socket in skcipher_check_key as otherwise
two simultaneous calls can cause the parent socket to be freed.
commit ad46d7e33219218605ea619e32553daf4f346b9f upstream.
We need to lock the child socket in hash_check_key as otherwise
commit a6a48c565f6f112c6983e2a02b1602189ed6e26e upstream.
This patch forbids the calling of bind(2) when there are child
sockets created by accept(2) in existence, even if they are created
on the nokey path.
This is needed as those child sockets have references to the tfm
object which bind(2) will destroy.
commit d7b65aee1e7b4c87922b0232eaba56a8a143a4a0 upstream.
This patch removes the custom release parent function as the
generic af_alg_release_parent now works for nokey sockets too.
commit f1d84af1835846a5a2b827382c5848faf2bb0e75 upstream.
commit 6a935170a980024dd29199e9dbb5c4da4767a1b9 upstream.
This patch allows af_alg_release_parent to be called even for
nokey sockets.
commit 6e8d8ecf438792ecf7a3207488fb4eebc4edb040 upstream.
This patch adds an exception to the key check so that cipher_null
users may continue to use algif_skcipher without setting a key.
commit a1383cd86a062fc798899ab20f0ec2116cce39cb upstream.
This patch adds a way for skcipher users to determine whether a key
is required by a transform.
commit 6de62f15b581f920ade22d758f4c338311c2f0d4 upstream.
Hash implementations that require a key may crash if you use
them without setting a key. This patch adds the necessary checks
so that if you do attempt to use them without a key that we return
-ENOKEY instead of proceeding.
This patch also adds a compatibility path to support old applications
that do acept(2) before setkey.
commit a5596d6332787fd383b3b5427b41f94254430827 upstream.
This patch adds a way for ahash users to determine whether a key
is required by a crypto_ahash transform.
commit a0fa2d037129a9849918a92d91b79ed6c7bd2818 upstream.
This patch adds a compatibility path to support old applications
commit 37766586c965d63758ad542325a96d5384f4a8c9 upstream.
commit a383292c86663bbc31ac62cc0c04fc77504636a6 upstream.
When we fail an accept(2) call we will end up freeing the socket
twice, once due to the direct sk_free call and once again through
newsock.
This patch fixes this by removing the sk_free call.
commit c840ac6af3f8713a71b4d2363419145760bd6044 upstream.
Each af_alg parent socket obtained by socket(2) corresponds to a
tfm object once bind(2) has succeeded. An accept(2) call on that
parent socket creates a context which then uses the tfm object.
Therefore as long as any child sockets created by accept(2) exist
the parent socket must not be modified or freed.
This patch guarantees this by using locks and a reference count
on the parent socket. Any attempt to modify the parent socket will
fail with EBUSY.
commit dd504589577d8e8e70f51f997ad487a4cb6c026f upstream.
Some cipher implementations will crash if you try to use them
without calling setkey first. This patch adds a check so that
the accept(2) call will fail with -ENOKEY if setkey hasn't been
done on the socket yet.
These async_XX functions are called from md/raid5 in an atomic
section, between get_cpu() and put_cpu(), so they must not sleep.
So use GFP_NOWAIT rather than GFP_IO.
Dan Williams writes: Longer term async_tx needs to be merged into md
directly as we can allocate this unmap data statically per-stripe
rather than per request.
Fixed: 7476bd79fc01 ("async_pq: convert to dmaengine_unmap_data")
Cc: stable@vger.kernel.org (v3.13+)
Reported-and-tested-by: Stanislav Samsonov <slava@annapurnalabs.com>
Acked-by: Dan Williams <dan.j.williams@intel.com>
Signed-off-by: NeilBrown <neilb@suse.com>
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6
Pull crypto fix from Herbert Xu:
"This fixes a bug in the algif_skcipher interface that can trigger a
kernel WARN_ON from user-space. It does so by using the new skcipher
interface which unlike the previous ablkcipher does not need to create
extra geniv objects which is what was used to trigger the WARN_ON"
* 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6:
crypto: algif_skcipher - Use new skcipher interface
This patch replaces uses of ablkcipher with the new skcipher
interface.
Tested-by: <smueller@chronox.de>
"This fixes a boundary condition in the blkcipher SG walking code that
can lead to a crash when used with the new chacha20 algorithm"
crypto: skcipher - Copy iv from desc even for 0-len walks
Some ciphers actually support encrypting zero length plaintexts. For
example, many AEAD modes support this. The resulting ciphertext for
those winds up being only the authentication tag, which is a result of
the key, the iv, the additional data, and the fact that the plaintext
had zero length. The blkcipher constructors won't copy the IV to the
right place, however, when using a zero length input, resulting in
some significant problems when ciphers call their initialization
routines, only to find that the ->iv parameter is uninitialized. One
such example of this would be using chacha20poly1305 with a zero length
input, which then calls chacha20, which calls the key setup routine,
which eventually OOPSes due to the uninitialized ->iv member.
Signed-off-by: Jason A. Donenfeld <Jason@zx2c4.com>
Cc: <stable@vger.kernel.org>
This patch is a cleanup to make following patch easier to
review.
Goal is to move SOCK_ASYNC_NOSPACE and SOCK_ASYNC_WAITDATA
from (struct socket)->flags to a (struct socket_wq)->flags
to benefit from RCU protection in sock_wake_async()
To ease backports, we rename both constants.
Two new helpers, sk_set_bit(int nr, struct sock *sk)
and sk_clear_bit(int net, struct sock *sk) are added so that
following patch can change their implementation.
This fixes CVE-2015-5327. It affects kernels from 4.3-rc1 onwards.
Fix the X.509 time validation to use month number-1 when looking up the
number of days in that month. Also put the month number validation before
doing the lookup so as not to risk overrunning the array.
This can be tested by doing the following:
cat <<EOF | openssl x509 -outform DER | keyctl padd asymmetric "" @s
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
EOF
If it works, it emit a key ID; if it fails, it should give a bad message
error.
Reported-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
Tested-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
Signed-off-by: James Morris <james.l.morris@oracle.com>
