skcipher_check_key
commit 1822793a523e5d5730b19cc21160ff1717421bc8 upstream.
We need to lock the child socket in skcipher_check_key as otherwise
two simultaneous calls can cause the parent socket to be freed.
Cc: stable@vger.kernel.org
commit d7b65aee1e7b4c87922b0232eaba56a8a143a4a0 upstream.
This patch removes the custom release parent function as the
generic af_alg_release_parent now works for nokey sockets too.
commit a0fa2d037129a9849918a92d91b79ed6c7bd2818 upstream.
This patch adds a compatibility path to support old applications
that do acept(2) before setkey.
commit dd504589577d8e8e70f51f997ad487a4cb6c026f upstream.
Some cipher implementations will crash if you try to use them
without calling setkey first. This patch adds a check so that
the accept(2) call will fail with -ENOKEY if setkey hasn't been
done on the socket yet.
Tested-by: Dmitry Vyukov <dvyukov@google.com>
[backported to 4.1 by Milan Broz <gmazyland@gmail.com>]
[ Upstream commit 63e41ebc6630f39422d87f8a4bade1e793f37a01 ]
We miss to take the crypto_alg_sem semaphore when traversing the
crypto_alg_list for CRYPTO_MSG_GETALG dumps. This allows a race with
crypto_unregister_alg() removing algorithms from the list while we're
still traversing it, thereby leading to a use-after-free as show below:
[ 3482.071639] general protection fault: 0000 [#1] SMP
[ 3482.075639] Modules linked in: aes_x86_64 glue_helper lrw ablk_helper cryptd gf128mul ipv6 pcspkr serio_raw virtio_net microcode virtio_pci virtio_ring virtio sr_mod cdrom [last unloaded: aesni_intel]
[ 3482.075639] CPU: 1 PID: 11065 Comm: crconf Not tainted 4.3.4-grsec+ #126
[ 3482.075639] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.7.5-20140531_083030-gandalf 04/01/2014
[ 3482.075639] task: ffff88001cd41a40 ti: ffff88001cd422c8 task.ti: ffff88001cd422c8
[ 3482.075639] RIP: 0010:[<ffffffff93722bd3>] [<ffffffff93722bd3>] strncpy+0x13/0x30
[ 3482.075639] RSP: 0018:ffff88001f713b60 EFLAGS: 00010202
[ 3482.075639] RAX: ffff88001f6c4430 RBX: ffff88001f6c43a0 RCX: ffff88001f6c4430
[ 3482.075639] RDX: 0000000000000040 RSI: fefefefefefeff16 RDI: ffff88001f6c4430
[ 3482.075639] RBP: ffff88001f713b60 R08: ffff88001f6c4470 R09: ffff88001f6c4480
[ 3482.075639] R10: 0000000000000002 R11: 0000000000000246 R12: ffff88001ce2aa28
[ 3482.075639] R13: ffff880000093700 R14: ffff88001f5e4bf8 R15: 0000000000003b20
[ 3482.075639] FS: 0000033826fa2700(0000) GS:ffff88001e900000(0000) knlGS:0000000000000000
[ 3482.075639] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 3482.075639] CR2: ffffffffff600400 CR3: 00000000139ec000 CR4: 00000000001606f0
[ 3482.075639] Stack:
[ 3482.075639] ffff88001f713bd8 ffffffff936ccd00 ffff88001e5c4200 ffff880000093700
[ 3482.075639] ffff88001f713bd0 ffffffff938ef4bf 0000000000000000 0000000000003b20
[ 3482.075639] ffff88001f5e4bf8 ffff88001f5e4848 0000000000000000 0000000000003b20
[ 3482.075639] Call Trace:
[ 3482.075639] [<ffffffff936ccd00>] crypto_report_alg+0xc0/0x3e0
[ 3482.075639] [<ffffffff938ef4bf>] ? __alloc_skb+0x16f/0x300
[ 3482.075639] [<ffffffff936cd08a>] crypto_dump_report+0x6a/0x90
[ 3482.075639] [<ffffffff93935707>] netlink_dump+0x147/0x2e0
[ 3482.075639] [<ffffffff93935f99>] __netlink_dump_start+0x159/0x190
[ 3482.075639] [<ffffffff936ccb13>] crypto_user_rcv_msg+0xc3/0x130
[ 3482.075639] [<ffffffff936cd020>] ? crypto_report_alg+0x3e0/0x3e0
[ 3482.075639] [<ffffffff936cc4b0>] ? alg_test_crc32c+0x120/0x120
[ 3482.075639] [<ffffffff93933145>] ? __netlink_lookup+0xd5/0x120
[ 3482.075639] [<ffffffff936cca50>] ? crypto_add_alg+0x1d0/0x1d0
[ 3482.075639] [<ffffffff93938141>] netlink_rcv_skb+0xe1/0x130
[ 3482.075639] [<ffffffff936cc4f8>] crypto_netlink_rcv+0x28/0x40
[ 3482.075639] [<ffffffff939375a8>] netlink_unicast+0x108/0x180
[ 3482.075639] [<ffffffff93937c21>] netlink_sendmsg+0x541/0x770
[ 3482.075639] [<ffffffff938e31e1>] sock_sendmsg+0x21/0x40
[ 3482.075639] [<ffffffff938e4763>] SyS_sendto+0xf3/0x130
[ 3482.075639] [<ffffffff93444203>] ? bad_area_nosemaphore+0x13/0x20
[ 3482.075639] [<ffffffff93444470>] ? __do_page_fault+0x80/0x3a0
[ 3482.075639] [<ffffffff939d80cb>] entry_SYSCALL_64_fastpath+0x12/0x6e
[ 3482.075639] Code: 88 4a ff 75 ed 5d 48 0f ba 2c 24 3f c3 66 66 2e 0f 1f 84 00 00 00 00 00 55 48 85 d2 48 89 f8 48 89 f9 4c 8d 04 17 48 89 e5 74 15 <0f> b6 16 80 fa 01 88 11 48 83 de ff 48 83 c1 01 4c 39 c1 75 eb
[ 3482.075639] RIP [<ffffffff93722bd3>] strncpy+0x13/0x30
To trigger the race run the following loops simultaneously for a while:
$ while : ; do modprobe aesni-intel; rmmod aesni-intel; done
$ while : ; do crconf show all > /dev/null; done
Fix the race by taking the crypto_alg_sem read lock, thereby preventing
crypto_unregister_alg() from modifying the algorithm list during the
dump.
This bug has been detected by the PaX memory sanitize feature.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Cc: Steffen Klassert <steffen.klassert@secunet.com>
Cc: PaX Team <pageexec@freemail.hu>
[ Upstream commit e7c87bef7de2417b219d4dbfe8d33a0098a8df54 ]
Don't strip leading zeros from the crypto key ID when using it to construct
the struct key description as the signature in kernels up to and including
4.2 matched this aspect of the key. This means that 1 in 256 keys won't
actually match if their key ID begins with 00.
The key ID is stored in the module signature as binary and so must be
converted to text in order to invoke request_key() - but it isn't stripped
at this point.
Something like this is likely to be observed in dmesg when the key is loaded:
[ 1.572423] Loaded X.509 cert 'Build time autogenerated kernel
key: 62a7c3d2da278be024da4af8652c071f3fea33'
followed by this when we try and use it:
[ 1.646153] Request for unknown module key 'Build time autogenerated
kernel key: 0062a7c3d2da278be024da4af8652c071f3fea33' err -11
The 'Loaded' line should show an extra '00' on the front of the hex string.
This problem should not affect 4.3-rc1 and onwards because there the key
should be matched on one of its auxiliary identities rather than the key
struct's description string.
Reported-by: Arjan van de Ven <arjan@linux.intel.com>
Reported-by: Andy Whitcroft <apw@canonical.com>
[ Upstream commit fe09786178f9df713a4b2dd6b93c0a722346bf5e ]
hash_sendmsg/sendpage() need to wait for the completion
of crypto_ahash_init() otherwise it can cause panic.
Signed-off-by: Rui Wang <rui.y.wang@intel.com>
[ Upstream commit 00420a65fa2beb3206090ead86942484df2275f3 ]
The has_key logic is wrong for shash algorithms as they always
have a setkey function. So we should instead be testing against
shash_no_setkey.
Fixes: a5596d633278 ("crypto: hash - Add crypto_ahash_has_setkey")
Reported-by: Stephan Mueller <smueller@chronox.de>
Tested-by: Stephan Mueller <smueller@chronox.de>
[ Upstream commit 202736d99b7f29279db9da61587f11a08a04a9c6 ]
We mark the end of the SG list in sendmsg and sendpage and unmark
it on the next send call. Unfortunately the unmarking in sendmsg
is off-by-one, leading to an SG list that is too short.
Fixes: 0f477b655a52 ("crypto: algif - Mark sgl end at the end of data")
[ Upstream commit fd7f6727102a1ccf6b4c1dfcc631f9b546526b26 ]
I don't think it makes sense for a module to have a soft dependency
on itself. This seems quite cyclic by nature and I can't see what
purpose it could serve.
OTOH libcrc32c calls crypto_alloc_shash("crc32c", 0, 0) so it pretty
much assumes that some incarnation of the "crc32c" hash algorithm has
been loaded. Therefore it makes sense to have the soft dependency
there (as crc-t10dif does.)
Cc: Tim Chen <tim.c.chen@linux.intel.com>
Signed-off-by: Jean Delvare <jdelvare@suse.de>
[ Upstream commit ad46d7e33219218605ea619e32553daf4f346b9f ]
We need to lock the child socket in hash_check_key as otherwise
[ Upstream commit a6a48c565f6f112c6983e2a02b1602189ed6e26e ]
This patch forbids the calling of bind(2) when there are child
sockets created by accept(2) in existence, even if they are created
on the nokey path.
This is needed as those child sockets have references to the tfm
object which bind(2) will destroy.
[ Upstream commit f1d84af1835846a5a2b827382c5848faf2bb0e75 ]
[ Upstream commit 6a935170a980024dd29199e9dbb5c4da4767a1b9 ]
This patch allows af_alg_release_parent to be called even for
nokey sockets.
[ Upstream commit 6de62f15b581f920ade22d758f4c338311c2f0d4 ]
Hash implementations that require a key may crash if you use
them without setting a key. This patch adds the necessary checks
so that if you do attempt to use them without a key that we return
-ENOKEY instead of proceeding.
This patch also adds a compatibility path to support old applications
[ Upstream commit a5596d6332787fd383b3b5427b41f94254430827 ]
This patch adds a way for ahash users to determine whether a key
is required by a crypto_ahash transform.
[ Upstream commit 37766586c965d63758ad542325a96d5384f4a8c9 ]
[ Upstream commit a383292c86663bbc31ac62cc0c04fc77504636a6 ]
When we fail an accept(2) call we will end up freeing the socket
twice, once due to the direct sk_free call and once again through
newsock.
This patch fixes this by removing the sk_free call.
[ Upstream commit c840ac6af3f8713a71b4d2363419145760bd6044 ]
Each af_alg parent socket obtained by socket(2) corresponds to a
tfm object once bind(2) has succeeded. An accept(2) call on that
parent socket creates a context which then uses the tfm object.
Therefore as long as any child sockets created by accept(2) exist
the parent socket must not be modified or freed.
This patch guarantees this by using locks and a reference count
on the parent socket. Any attempt to modify the parent socket will
fail with EBUSY.
commit 3fc89adb9fa4beff31374a4bf50b3d099d88ae83 upstream.
Currently a number of Crypto API operations may fail when a signal
occurs. This causes nasty problems as the caller of those operations
are often not in a good position to restart the operation.
In fact there is currently no need for those operations to be
interrupted by user signals at all. All we need is for them to
be killable.
This patch replaces the relevant calls of signal_pending with
fatal_signal_pending, and wait_for_completion_interruptible with
wait_for_completion_killable, respectively.
commit 8996eafdcbad149ac0f772fb1649fbb75c482a6a upstream.
Unlike shash algorithms, ahash drivers must implement export
and import as their descriptors may contain hardware state and
cannot be exported as is. Unfortunately some ahash drivers did
not provide them and end up causing crashes with algif_hash.
This patch adds a check to prevent these drivers from registering
ahash algorithms until they are fixed.
commit f2b3dee484f9cee967a54ef05a66866282337519 upstream.
The call to asymmetric_key_hex_to_key_id() from ca_keys_setup()
silently fails with -ENOMEM. Instead of dynamically allocating
memory from a __setup function, this patch defines a variable
and calls __asymmetric_key_hex_to_key_id(), a new helper function,
directly.
This bug was introduced by 'commit 46963b774d44 ("KEYS: Overhaul
key identification when searching for asymmetric keys")'.
Changelog:
- for clarification, rename hexlen to asciihexlen in
- add size argument to __asymmetric_key_hex_to_key_id() - David Howells
- inline __asymmetric_key_hex_to_key_id() - David Howells
- remove duplicate strlen() calls
Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
Pull crypto fix from Herbert Xu:
"This disables the newly (4.1) added user-space AEAD interface so that
we can fix issues in the underlying kernel AEAD interface. Once the
new kernel AEAD interface is ready we can then reenable the user-space
AEAD interface"
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6:
crypto: algif_aead - Disable AEAD user-space for now
The newly added AEAD user-space isn't quite ready for prime time
just yet. In particular it is conflicting with the AEAD single
SG list interface change so this patch disables it now.
Once the SG list stuff is completely done we can then renable
this interface.
"This fixes a the crash in the newly added algif_aead interface when it
tries to link SG lists"
crypto: algif_aead - fix invalid sgl linking
This patch fixes it.
Also minor updates to comments.
Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com>
Pull md updates from Neil Brown:
"More updates that usual this time. A few have performance impacts
which hould mostly be positive, but RAID5 (in particular) can be very
work-load ensitive... We'll have to wait and see.
Highlights:
- "experimental" code for managing md/raid1 across a cluster using
DLM. Code is not ready for general use and triggers a WARNING if
used. However it is looking good and mostly done and having in
mainline will help co-ordinate development.
- RAID5/6 can now batch multiple (4K wide) stripe_heads so as to
handle a full (chunk wide) stripe as a single unit.
- RAID6 can now perform read-modify-write cycles which should help
performance on larger arrays: 6 or more devices.
- RAID5/6 stripe cache now grows and shrinks dynamically. The value
set is used as a minimum.
- Resync is now allowed to go a little faster than the 'mininum' when
there is competing IO. How much faster depends on the speed of the
devices, so the effective minimum should scale with device speed to
some extent"
* tag 'md/4.1' of git://neil.brown.name/md: (58 commits)
md/raid5: don't do chunk aligned read on degraded array.
md/raid5: allow the stripe_cache to grow and shrink.
md/raid5: change ->inactive_blocked to a bit-flag.
md/raid5: move max_nr_stripes management into grow_one_stripe and drop_one_stripe
md/raid5: pass gfp_t arg to grow_one_stripe()
md/raid5: introduce configuration option rmw_level
md/raid5: activate raid6 rmw feature
md/raid6 algorithms: xor_syndrome() for SSE2
md/raid6 algorithms: xor_syndrome() for generic int
md/raid6 algorithms: improve test program
md/raid6 algorithms: delta syndrome functions
raid5: handle expansion/resync case with stripe batching
raid5: handle io error of batch list
RAID5: batch adjacent full stripe write
raid5: track overwrite disk count
raid5: add a new flag to track if a stripe can be batched
raid5: use flex_array for scribble data
md raid0: access mddev->queue (request queue member) conditionally because it is not set when accessed from dm-raid
md: allow resync to go faster when there is competing IO.
md: remove 'go_faster' option from ->sync_request()
Glue it altogehter. The raid6 rmw path should work the same as the
already existing raid5 logic. So emulate the prexor handling/flags
and split functions as needed.
1) Enable xor_syndrome() in the async layer.
2) Split ops_run_prexor() into RAID4/5 and RAID6 logic. Xor the syndrome
at the start of a rmw run as we did it before for the single parity.
3) Take care of rmw run in ops_run_reconstruct6(). Again process only
the changed pages to get syndrome back into sync.
4) Enhance set_syndrome_sources() to fill NULL pages if we are in a rmw
run. The lower layers will calculate start & end pages from that and
call the xor_syndrome() correspondingly.
5) Adapt the several places where we ignored Q handling up to now.
Performance numbers for a single E5630 system with a mix of 10 7200k
desktop/server disks. 300 seconds random write with 8 threads onto a
3,2TB (10*400GB) RAID6 64K chunk without spare (group_thread_cnt=4)
bsize rmw_level=1 rmw_level=0 rmw_level=1 rmw_level=0
skip_copy=1 skip_copy=1 skip_copy=0 skip_copy=0
4K 115 KB/s 141 KB/s 165 KB/s 140 KB/s
8K 225 KB/s 275 KB/s 324 KB/s 274 KB/s
16K 434 KB/s 536 KB/s 640 KB/s 534 KB/s
32K 751 KB/s 1,051 KB/s 1,234 KB/s 1,045 KB/s
64K 1,339 KB/s 1,958 KB/s 2,282 KB/s 1,962 KB/s
128K 2,673 KB/s 3,862 KB/s 4,113 KB/s 3,898 KB/s
256K 7,685 KB/s 7,539 KB/s 7,557 KB/s 7,638 KB/s
512K 19,556 KB/s 19,558 KB/s 19,652 KB/s 19,688 Kb/s
Signed-off-by: Markus Stockhausen <stockhausen@collogia.de>
Signed-off-by: NeilBrown <neilb@suse.de>
Commit 9c521a200bc3 ("crypto: api - remove instance when test failed")
tried to grab a module reference count before the module was even set.
Worse, it then goes on to free the module reference count after it is
set so you quickly end up with a negative module reference count which
prevents people from using any instances belonging to that module.
This patch moves the module initialisation before the reference
count.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
The networking updates from David Miller removed the iocb argument from
sendmsg and recvmsg (in commit 1b784140474e: "net: Remove iocb argument
from sendmsg and recvmsg"), but the crypto code had added new instances
of them.
When I pulled the crypto update, it was a silent semantic mis-merge, and
I overlooked the new warning messages in my test-build. I try to fix
those in the merge itself, but that relies on me noticing. Oh well.
Pull crypto update from Herbert Xu:
"Here is the crypto update for 4.1:
New interfaces:
- user-space interface for AEAD
- user-space interface for RNG (i.e., pseudo RNG)
New hashes:
- ARMv8 SHA1/256
- ARMv8 AES
- ARMv8 GHASH
- ARM assembler and NEON SHA256
- MIPS OCTEON SHA1/256/512
- MIPS img-hash SHA1/256 and MD5
- Power 8 VMX AES/CBC/CTR/GHASH
- PPC assembler AES, SHA1/256 and MD5
- Broadcom IPROC RNG driver
Cleanups/fixes:
- prevent internal helper algos from being exposed to user-space
- merge common code from assembly/C SHA implementations
- misc fixes"
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (169 commits)
crypto: arm - workaround for building with old binutils
crypto: arm/sha256 - avoid sha256 code on ARMv7-M
crypto: x86/sha512_ssse3 - move SHA-384/512 SSSE3 implementation to base layer
crypto: x86/sha256_ssse3 - move SHA-224/256 SSSE3 implementation to base layer
crypto: x86/sha1_ssse3 - move SHA-1 SSSE3 implementation to base layer
crypto: arm64/sha2-ce - move SHA-224/256 ARMv8 implementation to base layer
crypto: arm64/sha1-ce - move SHA-1 ARMv8 implementation to base layer
crypto: arm/sha2-ce - move SHA-224/256 ARMv8 implementation to base layer
crypto: arm/sha256 - move SHA-224/256 ASM/NEON implementation to base layer
crypto: arm/sha1-ce - move SHA-1 ARMv8 implementation to base layer
crypto: arm/sha1_neon - move SHA-1 NEON implementation to base layer
crypto: arm/sha1 - move SHA-1 ARM asm implementation to base layer
crypto: sha512-generic - move to generic glue implementation
crypto: sha256-generic - move to generic glue implementation
crypto: sha1-generic - move to generic glue implementation
crypto: sha512 - implement base layer for SHA-512
crypto: sha256 - implement base layer for SHA-256
crypto: sha1 - implement base layer for SHA-1
crypto: api - Move alg ref count init to crypto_check_alg
convert open-coded instances
This updated the generic SHA-512 implementation to use the
generic shared SHA-512 glue code.
It also implements a .finup hook crypto_sha512_finup() and exports
it to other modules. The import and export() functions and the
.statesize member are dropped, since the default implementation
is perfectly suitable for this module.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
This updates the generic SHA-256 implementation to use the
new shared SHA-256 glue code.
It also implements a .finup hook crypto_sha256_finup() and exports
This updated the generic SHA-1 implementation to use the generic
shared SHA-1 glue code.
It also implements a .finup hook crypto_sha1_finup() and exports
A cipher instance is added to the list of instances unconditionally
regardless of whether the associated test failed. However, a failed
test implies that during another lookup, the cipher instance will
be added to the list again as it will not be found by the lookup
code.
That means that the list can be filled up with instances whose tests
failed.
Note: tests only fail in reality in FIPS mode when a cipher is not
marked as fips_allowed=1. This can be seen with cmac(des3_ede) that does
not have a fips_allowed=1. When allocating the cipher, the allocation
fails with -ENOENT due to the missing fips_allowed=1 flag (which
causes the testmgr to return EINVAL). Yet, the instance of
cmac(des3_ede) is shown in /proc/crypto. Allocating the cipher again
fails again, but a 2nd instance is listed in /proc/crypto.
The patch simply de-registers the instance when the testing failed.
Signed-off-by: Stephan Mueller <smueller@chronox.de>
We currently initialise the crypto_alg ref count in the function
__crypto_register_alg. As one of the callers of that function
crypto_register_instance needs to obtain a ref count before it
calls __crypto_register_alg, we need to move the initialisation
out of there.
Since both callers of __crypto_register_alg call crypto_check_alg,
this is the logical place to perform the initialisation.
Acked-by: Stephan Mueller <smueller@chronox.de>
trivial conflict in net/socket.c and non-trivial one in crypto -
that one had evaded aio_complete() removal.
The function crypto_alg_match returns an algorithm without taking
any references on it. This means that the algorithm can be freed
at any time, therefore all users of crypto_alg_match are buggy.
This patch fixes this by taking a reference count on the algorithm
to prevent such races.
This patch fix a spelling typo in crypto/Kconfig.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
This patch makes crypto_unregister_instance take a crypto_instance
instead of a crypto_alg. This allows us to remove a duplicate
CRYPTO_ALG_INSTANCE check in crypto_unregister_instance.
There are multiple problems in crypto_unregister_instance:
1) The cra_refcnt BUG_ON check is racy and can cause crashes.
2) The cra_refcnt check shouldn't exist at all.
3) There is no reference on tmpl to protect the tmpl->free call.
This patch rewrites the function using crypto_remove_spawn which
now morphs into crypto_remove_instance.
After the TX sgl is expanded we need to explicitly mark end of data
at the last buffer that contains data.
Changes in v2
- use type 'bool' and true/false for 'mark'.
No need to use kzalloc to allocate sgls as the structure is initialized anyway.
Use EXPORT_SYMBOL_GPL instead of EXPORT_SYMBOL.
The mcryptd is used as a wrapper around internal ciphers. Therefore,
the mcryptd must process the internal cipher by marking mcryptd as
internal if the underlying cipher is an internal cipher.
With ciphers that now cannot be accessed via the kernel crypto API,
callers shall be able to identify the ciphers that are not callable. The
/proc/crypto file is added a boolean field identifying that such
internal ciphers.
The cryptd is used as a wrapper around internal ciphers. Therefore, the
cryptd must process the internal cipher by marking cryptd as internal if
Allocate the ciphers irrespectively if they are marked as internal
or not. As all ciphers, including the internal ciphers will be
processed by the testmgr, it needs to be able to allocate those
ciphers.
Several hardware related cipher implementations are implemented as
follows: a "helper" cipher implementation is registered with the
kernel crypto API.
Such helper ciphers are never intended to be called by normal users. In
some cases, calling them via the normal crypto API may even cause
failures including kernel crashes. In a normal case, the "wrapping"
ciphers that use the helpers ensure that these helpers are invoked
such that they cannot cause any calamity.
Considering the AF_ALG user space interface, unprivileged users can
call all ciphers registered with the crypto API, including these
helper ciphers that are not intended to be called directly. That
means, with AF_ALG user space may invoke these helper ciphers
and may cause undefined states or side effects.
To avoid any potential side effects with such helpers, the patch
prevents the helpers to be called directly. A new cipher type
flag is added: CRYPTO_ALG_INTERNAL. This flag shall be used
to mark helper ciphers. These ciphers can only be used if the
caller invoke the cipher with CRYPTO_ALG_INTERNAL in the type and
mask field.
