path: root/crypto
2012-12-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto update from Herbert Xu: - Added aesni/avx/x86_64 implementations for camellia. - Optimised AVX code for cast5/serpent/twofish/cast6. - Fixed vmac bug with unaligned input. - Allow compression algorithms in FIPS mode. - Optimised crc32c implementation for Intel. - Misc fixes. * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (32 commits) crypto: caam - Updated SEC-4.0 device tree binding for ERA information. crypto: testmgr - remove superfluous initializers for xts(aes) crypto: testmgr - allow compression algs in fips mode crypto: testmgr - add larger crc32c test vector to test FPU path in crc32c_intel crypto: testmgr - clean alg_test_null entries in alg_test_descs[] crypto: testmgr - remove fips_allowed flag from camellia-aesni null-tests crypto: cast5/cast6 - move lookup tables to shared module padata: use __this_cpu_read per-cpu helper crypto: s5p-sss - Fix compilation error crypto: picoxcell - Add terminating entry for platform_device_id table crypto: omap-aes - select BLKCIPHER2 crypto: camellia - add AES-NI/AVX/x86_64 assembler implementation of camellia cipher crypto: camellia-x86_64 - share common functions and move structures and function definitions to header file crypto: tcrypt - add async speed test for camellia cipher crypto: tegra-aes - fix error-valued pointer dereference crypto: tegra - fix missing unlock on error case crypto: cast5/avx - avoid using temporary stack buffers crypto: serpent/avx - avoid using temporary stack buffers crypto: twofish/avx - avoid using temporary stack buffers crypto: cast6/avx - avoid using temporary stack buffers ...
2012-12-06crypto: testmgr - remove superfluous initializers for xts(aes)Mathias Krause
The test vectors for 'xts(aes)' contain superfluous initializers. Remove them. Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Jarod Wilson <jarod@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-12-06crypto: testmgr - allow compression algs in fips modeMilan Broz
When in fips mode, compression algoritms fails to initialize, e.g. modprobe ubifs returns UBIFS error: compr_init: cannot initialize compressor lzo, error -2 FIPS mode should not care about compression algoritms at all. Patch just set fips_enabled flag to 1 to all compression algorithms managed by testmgr. Signed-off-by: Milan Broz <mbroz@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-12-06crypto: testmgr - add larger crc32c test vector to test FPU path in crc32c_intelJussi Kivilinna
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-12-06crypto: testmgr - clean alg_test_null entries in alg_test_descs[]Jussi Kivilinna
Currently alg_test_null entries set .suite values to zero, which is unneeded. So perform clean-up of null test entries. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-12-06crypto: testmgr - remove fips_allowed flag from camellia-aesni null-testsJussi Kivilinna
Remove incorrect fips_allowed from camellia null-test entries. Caused by incorrect copy-paste of aes-aesni null-tests into camellia-aesni null-tests. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-12-06crypto: cast5/cast6 - move lookup tables to shared moduleJussi Kivilinna
CAST5 and CAST6 both use same lookup tables, which can be moved shared module 'cast_common'. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-11-09crypto: camellia - add AES-NI/AVX/x86_64 assembler implementation of ↵Jussi Kivilinna
camellia cipher This patch adds AES-NI/AVX/x86_64 assembler implementation of Camellia block cipher. Implementation process data in sixteen block chunks, which are byte-sliced and AES SubBytes is reused for Camellia s-box with help of pre- and post-filtering. Patch has been tested with tcrypt and automated filesystem tests. tcrypt test results: Intel Core i5-2450M: camellia-aesni-avx vs camellia-asm-x86_64-2way: 128bit key: (lrw:256bit) (xts:256bit) size ecb-enc ecb-dec cbc-enc cbc-dec ctr-enc ctr-dec lrw-enc lrw-dec xts-enc xts-dec 16B 0.98x 0.96x 0.99x 0.96x 0.96x 0.95x 0.95x 0.94x 0.97x 0.98x 64B 0.99x 0.98x 1.00x 0.98x 0.98x 0.99x 0.98x 0.93x 0.99x 0.98x 256B 2.28x 2.28x 1.01x 2.29x 2.25x 2.24x 1.96x 1.97x 1.91x 1.90x 1024B 2.57x 2.56x 1.00x 2.57x 2.51x 2.53x 2.19x 2.17x 2.19x 2.22x 8192B 2.49x 2.49x 1.00x 2.53x 2.48x 2.49x 2.17x 2.17x 2.22x 2.22x 256bit key: (lrw:384bit) (xts:512bit) size ecb-enc ecb-dec cbc-enc cbc-dec ctr-enc ctr-dec lrw-enc lrw-dec xts-enc xts-dec 16B 0.97x 0.98x 0.99x 0.97x 0.97x 0.96x 0.97x 0.98x 0.98x 0.99x 64B 1.00x 1.00x 1.01x 0.99x 0.98x 0.99x 0.99x 0.99x 0.99x 0.99x 256B 2.37x 2.37x 1.01x 2.39x 2.35x 2.33x 2.10x 2.11x 1.99x 2.02x 1024B 2.58x 2.60x 1.00x 2.58x 2.56x 2.56x 2.28x 2.29x 2.28x 2.29x 8192B 2.50x 2.52x 1.00x 2.56x 2.51x 2.51x 2.24x 2.25x 2.26x 2.29x Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-11-09crypto: tcrypt - add async speed test for camellia cipherJussi Kivilinna
2012-10-24crypto: cryptd - disable softirqs in cryptd_queue_worker to prevent data ↵Jussi Kivilinna
corruption cryptd_queue_worker attempts to prevent simultaneous accesses to crypto workqueue by cryptd_enqueue_request using preempt_disable/preempt_enable. However cryptd_enqueue_request might be called from softirq context, so add local_bh_disable/local_bh_enable to prevent data corruption and panics. Bug report at http://marc.info/?l=linux-crypto-vger&m=134858649616319&w=2 v2: - Disable software interrupts instead of hardware interrupts Cc: stable@vger.kernel.org Reported-by: Gurucharan Shetty <gurucharan.shetty@gmail.com> Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-10-24crypto: testmgr - add new larger DES3_EDE testvectorsJussi Kivilinna
Most DES3_EDE testvectors are short and do not test parallelised codepaths well. Add larger testvectors to test large crypto operations and to test multi-page crypto with DES3_EDE. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-10-24crypto: testmgr - add new larger DES testvectorsJussi Kivilinna
Most DES testvectors are short and do not test parallelised codepaths well. Add larger testvectors to test large crypto operations and to test multi-page crypto with DES. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-10-24crypto: testmgr - add new larger AES testvectorsJussi Kivilinna
Most AES testvectors are short and do not test parallelised codepaths well. Add larger testvectors to test large crypto operations and to test multi-page crypto with AES. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-10-24crypto: testmgr - expand serpent test vectorsJussi Kivilinna
AVX2 implementation of serpent cipher processes 16 blocks parallel, so we need to make test vectors larger to check parallel code paths. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-10-24crypto: testmgr - expand blowfish test vectorsJussi Kivilinna
AVX2 implementation of blowfish cipher processes 32 blocks parallel, so we need to make test vectors larger to check parallel code paths. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-10-24crypto: testmgr - expand camellia test vectorsJussi Kivilinna
AVX/AES-NI implementation of camellia cipher processes 16 blocks parallel, so we need to make test vectors larger to check parallel code paths. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-10-15crypto: vmac - Make VMAC work when blocks aren't alignedSalman Qazi
VMAC implementation, as it is, does not work with blocks that are not multiples of 128-bytes. Furthermore, this is a problem when using the implementation on scatterlists, even when the complete plain text is 128-byte multiple, as the pieces that get passed to vmac_update can be pretty much any size. I also added test cases for unaligned blocks. Signed-off-by: Salman Qazi <sqazi@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-10-15crypto: tcrypt - Added speed test in tcrypt for crc32cTim Chen
This patch adds a test case in tcrypt to perform speed test for crc32c checksum calculation. Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-10-15crypto: crc32c - Optimize CRC32C calculation with PCLMULQDQ instructionTim Chen
This patch adds the crc_pcl function that calculates CRC32C checksum using the PCLMULQDQ instruction on processors that support this feature. This will provide speedup over using CRC32 instruction only. The usage of PCLMULQDQ necessitate the invocation of kernel_fpu_begin and kernel_fpu_end and incur some overhead. So the new crc_pcl function is only invoked for buffer size of 512 bytes or more. Larger sized buffers will expect to see greater speedup. This feature is best used coupled with eager_fpu which reduces the kernel_fpu_begin/end overhead. For buffer size of 1K the speedup is around 1.6x and for buffer size greater than 4K, the speedup is around 3x compared to original implementation in crc32c-intel module. Test was performed on Sandy Bridge based platform with constant frequency set for cpu. A white paper detailing the algorithm can be found here: http://download.intel.com/design/intarch/papers/323405.pdf Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-10-14Merge branch 'modules-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module signing support from Rusty Russell: "module signing is the highlight, but it's an all-over David Howells frenzy..." Hmm "Magrathea: Glacier signing key". Somebody has been reading too much HHGTTG. * 'modules-next' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (37 commits) X.509: Fix indefinite length element skip error handling X.509: Convert some printk calls to pr_devel asymmetric keys: fix printk format warning MODSIGN: Fix 32-bit overflow in X.509 certificate validity date checking MODSIGN: Make mrproper should remove generated files. MODSIGN: Use utf8 strings in signer's name in autogenerated X.509 certs MODSIGN: Use the same digest for the autogen key sig as for the module sig MODSIGN: Sign modules during the build process MODSIGN: Provide a script for generating a key ID from an X.509 cert MODSIGN: Implement module signature checking MODSIGN: Provide module signing public keys to the kernel MODSIGN: Automatically generate module signing keys if missing MODSIGN: Provide Kconfig options MODSIGN: Provide gitignore and make clean rules for extra files MODSIGN: Add FIPS policy module: signature checking hook X.509: Add a crypto key parser for binary (DER) X.509 certificates MPILIB: Provide a function to read raw data into an MPI X.509: Add an ASN.1 decoder X.509: Add simple ASN.1 grammar compiler ...
2012-10-13Merge tag 'md-3.7' of git://neil.brown.name/mdLinus Torvalds
Pull md updates from NeilBrown: - "discard" support, some dm-raid improvements and other assorted bits and pieces. * tag 'md-3.7' of git://neil.brown.name/md: (29 commits) md: refine reporting of resync/reshape delays. md/raid5: be careful not to resize_stripes too big. md: make sure manual changes to recovery checkpoint are saved. md/raid10: use correct limit variable md: writing to sync_action should clear the read-auto state. Subject: [PATCH] md:change resync_mismatches to atomic64_t to avoid races md/raid5: make sure to_read and to_write never go negative. md: When RAID5 is dirty, force reconstruct-write instead of read-modify-write. md/raid5: protect debug message against NULL derefernce. md/raid5: add some missing locking in handle_failed_stripe. MD: raid5 avoid unnecessary zero page for trim MD: raid5 trim support md/bitmap:Don't use IS_ERR to judge alloc_page(). md/raid1: Don't release reference to device while handling read error. raid: replace list_for_each_continue_rcu with new interface add further __init annotations to crypto/xor.c DM RAID: Fix for "sync" directive ineffectiveness DM RAID: Fix comparison of index and quantity for "rebuild" parameter DM RAID: Add rebuild capability for RAID10 DM RAID: Move 'rebuild' checking code to its own function ...
2012-10-11add further __init annotations to crypto/xor.cJan Beulich
Allow particularly do_xor_speed() to be discarded post-init. Signed-off-by: Jan Beulich <jbeulich@suse.com> Signed-off-by: NeilBrown <neilb@suse.de>
2012-10-10X.509: Convert some printk calls to pr_develDavid Howells
Some debugging printk() calls should've been converted to pr_devel() calls. Do that now. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-10-10asymmetric keys: fix printk format warningRandy Dunlap
Fix printk format warning in x509_cert_parser.c: crypto/asymmetric_keys/x509_cert_parser.c: In function 'x509_note_OID': crypto/asymmetric_keys/x509_cert_parser.c:113:3: warning: format '%zu' expects type 'size_t', but argument 2 has type 'long unsigned int' Builds cleanly on i386 and x86_64. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Cc: David Howells <dhowells@redhat.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: linux-crypto@vger.kernel.org Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-10-10MODSIGN: Fix 32-bit overflow in X.509 certificate validity date checkingDavid Howells
The current choice of lifetime for the autogenerated X.509 of 100 years, putting the validTo date in 2112, causes problems on 32-bit systems where a 32-bit time_t wraps in 2106. 64-bit x86_64 systems seem to be unaffected. This can result in something like: Loading module verification certificates X.509: Cert 6e03943da0f3b015ba6ed7f5e0cac4fe48680994 has expired MODSIGN: Problem loading in-kernel X.509 certificate (-127) Or: X.509: Cert 6e03943da0f3b015ba6ed7f5e0cac4fe48680994 is not yet valid MODSIGN: Problem loading in-kernel X.509 certificate (-129) Instead of turning the dates into time_t values and comparing, turn the system clock and the ASN.1 dates into tm structs and compare those piecemeal instead. Reported-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Josh Boyer <jwboyer@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-10-08X.509: Add a crypto key parser for binary (DER) X.509 certificatesDavid Howells
Add a crypto key parser for binary (DER) encoded X.509 certificates. The certificate is parsed and, if possible, the signature is verified. An X.509 key can be added like this: # keyctl padd crypto bar @s </tmp/x509.cert 15768135 and displayed like this: # cat /proc/keys 00f09a47 I--Q--- 1 perm 39390000 0 0 asymmetri bar: X509.RSA e9fd6d08 [] Note that this only works with binary certificates. PEM encoded certificates are ignored by the parser. Note also that the X.509 key ID is not congruent with the PGP key ID, but for the moment, they will match. If a NULL or "" name is given to add_key(), then the parser will generate a key description from the CertificateSerialNumber and Name fields of the TBSCertificate: 00aefc4e I--Q--- 1 perm 39390000 0 0 asymmetri bfbc0cd76d050ea4:/C=GB/L=Cambridge/O=Red Hat/CN=kernel key: X509.RSA 0c688c7b [] Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-10-08RSA: Fix signature verification for shorter signaturesDavid Howells
gpg can produce a signature file where length of signature is less than the modulus size because the amount of space an MPI takes up is kept as low as possible by discarding leading zeros. This regularly happens for several modules during the build. Fix it by relaxing check in RSA verification code. Thanks to Tomas Mraz and Miloslav Trmac for help. Signed-off-by: Milan Broz <mbroz@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-10-08RSA: Implement signature verification algorithm [PKCS#1 / RFC3447]David Howells
Implement RSA public key cryptography [PKCS#1 / RFC3447]. At this time, only the signature verification algorithm is supported. This uses the asymmetric public key subtype to hold its key data. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-10-08KEYS: Provide signature verification with an asymmetric keyDavid Howells
Provide signature verification using an asymmetric-type key to indicate the public key to be used. The API is a single function that can be found in crypto/public_key.h: int verify_signature(const struct key *key, const struct public_key_signature *sig) The first argument is the appropriate key to be used and the second argument is the parsed signature data: struct public_key_signature { u8 *digest; u16 digest_size; enum pkey_hash_algo pkey_hash_algo : 8; union { MPI mpi[2]; struct { MPI s; /* m^d mod n */ } rsa; struct { MPI r; MPI s; } dsa; }; }; This should be filled in prior to calling the function. The hash algorithm should already have been called and the hash finalised and the output should be in a buffer pointed to by the 'digest' member. Any extra data to be added to the hash by the hash format (eg. PGP) should have been added by the caller prior to finalising the hash. It is assumed that the signature is made up of a number of MPI values. If an algorithm becomes available for which this is not the case, the above structure will have to change. It is also assumed that it will have been checked that the signature algorithm matches the key algorithm. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-10-08KEYS: Asymmetric public-key algorithm crypto key subtypeDavid Howells
Add a subtype for supporting asymmetric public-key encryption algorithms such as DSA (FIPS-186) and RSA (PKCS#1 / RFC1337). Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-10-08KEYS: Asymmetric key pluggable data parsersDavid Howells
The instantiation data passed to the asymmetric key type are expected to be formatted in some way, and there are several possible standard ways to format the data. The two obvious standards are OpenPGP keys and X.509 certificates. The latter is especially useful when dealing with UEFI, and the former might be useful when dealing with, say, eCryptfs. Further, it might be desirable to provide formatted blobs that indicate hardware is to be accessed to retrieve the keys or that the keys live unretrievably in a hardware store, but that the keys can be used by means of the hardware. From userspace, the keys can be loaded using the keyctl command, for example, an X.509 binary certificate: keyctl padd asymmetric foo @s <dhowells.pem or a PGP key: keyctl padd asymmetric bar @s <dhowells.pub or a pointer into the contents of the TPM: keyctl add asymmetric zebra "TPM:04982390582905f8" @s Inside the kernel, pluggable parsers register themselves and then get to examine the payload data to see if they can handle it. If they can, they get to: (1) Propose a name for the key, to be used it the name is "" or NULL. (2) Specify the key subtype. (3) Provide the data for the subtype. The key type asks the parser to do its stuff before a key is allocated and thus before the name is set. If successful, the parser stores the suggested data into the key_preparsed_payload struct, which will be either used (if the key is successfully created and instantiated or updated) or discarded. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-10-08KEYS: Implement asymmetric key typeDavid Howells
Create a key type that can be used to represent an asymmetric key type for use in appropriate cryptographic operations, such as encryption, decryption, signature generation and signature verification. The key type is "asymmetric" and can provide access to a variety of cryptographic algorithms. Possibly, this would be better as "public_key" - but that has the disadvantage that "public key" is an overloaded term. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-10-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto update from Herbert Xu: - Optimised AES/SHA1 for ARM. - IPsec ESN support in talitos and caam. - x86_64/avx implementation of cast5/cast6. - Add/use multi-algorithm registration helpers where possible. - Added IBM Power7+ in-Nest support. - Misc fixes. Fix up trivial conflicts in crypto/Kconfig due to the sparc64 crypto config options being added next to the new ARM ones. [ Side note: cut-and-paste duplicate help texts make those conflicts harder to read than necessary, thanks to git being smart about minimizing conflicts and maximizing the common parts... ] * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (71 commits) crypto: x86/glue_helper - fix storing of new IV in CBC encryption crypto: cast5/avx - fix storing of new IV in CBC encryption crypto: tcrypt - add missing tests for camellia and ghash crypto: testmgr - make test_aead also test 'dst != src' code paths crypto: testmgr - make test_skcipher also test 'dst != src' code paths crypto: testmgr - add test vectors for CTR mode IV increasement crypto: testmgr - add test vectors for partial ctr(cast5) and ctr(cast6) crypto: testmgr - allow non-multi page and multi page skcipher tests from same test template crypto: caam - increase TRNG clocks per sample crypto, tcrypt: remove local_bh_disable/enable() around local_irq_disable/enable() crypto: tegra-aes - fix error return code crypto: crypto4xx - fix error return code crypto: hifn_795x - fix error return code crypto: ux500 - fix error return code crypto: caam - fix error IDs for SEC v5.x RNG4 hwrng: mxc-rnga - Access data via structure hwrng: mxc-rnga - Adapt clocks to new i.mx clock framework crypto: caam - add IPsec ESN support crypto: 842 - remove .cra_list initialization Revert "[CRYPTO] cast6: inline bloat--" ...
2012-10-02crypto: Build SPARC DES algorithms on SPARC only.Dave Jones
Asking for this option on x86 seems a bit pointless. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-10-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking changes from David Miller: 1) GRE now works over ipv6, from Dmitry Kozlov. 2) Make SCTP more network namespace aware, from Eric Biederman. 3) TEAM driver now works with non-ethernet devices, from Jiri Pirko. 4) Make openvswitch network namespace aware, from Pravin B Shelar. 5) IPV6 NAT implementation, from Patrick McHardy. 6) Server side support for TCP Fast Open, from Jerry Chu and others. 7) Packet BPF filter supports MOD and XOR, from Eric Dumazet and Daniel Borkmann. 8) Increate the loopback default MTU to 64K, from Eric Dumazet. 9) Use a per-task rather than per-socket page fragment allocator for outgoing networking traffic. This benefits processes that have very many mostly idle sockets, which is quite common. From Eric Dumazet. 10) Use up to 32K for page fragment allocations, with fallbacks to smaller sizes when higher order page allocations fail. Benefits are a) less segments for driver to process b) less calls to page allocator c) less waste of space. From Eric Dumazet. 11) Allow GRO to be used on GRE tunnels, from Eric Dumazet. 12) VXLAN device driver, one way to handle VLAN issues such as the limitation of 4096 VLAN IDs yet still have some level of isolation. From Stephen Hemminger. 13) As usual there is a large boatload of driver changes, with the scale perhaps tilted towards the wireless side this time around. Fix up various fairly trivial conflicts, mostly caused by the user namespace changes. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1012 commits) hyperv: Add buffer for extended info after the RNDIS response message. hyperv: Report actual status in receive completion packet hyperv: Remove extra allocated space for recv_pkt_list elements hyperv: Fix page buffer handling in rndis_filter_send_request() hyperv: Fix the missing return value in rndis_filter_set_packet_filter() hyperv: Fix the max_xfer_size in RNDIS initialization vxlan: put UDP socket in correct namespace vxlan: Depend on CONFIG_INET sfc: Fix the reported priorities of different filter types sfc: Remove EFX_FILTER_FLAG_RX_OVERRIDE_IP sfc: Fix loopback self-test with separate_tx_channels=1 sfc: Fix MCDI structure field lookup sfc: Add parentheses around use of bitfield macro arguments sfc: Fix null function pointer in efx_sriov_channel_type vxlan: virtual extensible lan igmp: export symbol ip_mc_leave_group netlink: add attributes to fdb interface tg3: unconditionally select HWMON support when tg3 is enabled. Revert "net: ti cpsw ethernet: allow reading phy interface mode from DT" gre: fix sparse warning ...
2012-10-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-nextLinus Torvalds
Pull sparc updates from David Miller: "Largely this is simply adding support for the Niagara 4 cpu. Major areas are perf events (chip now supports 4 counters and can monitor any event on each counter), crypto (opcodes are availble for sha1, sha256, sha512, md5, crc32c, AES, DES, CAMELLIA, and Kasumi although the last is unsupported since we lack a generic crypto layer Kasumi implementation), and an optimized memcpy. Finally some cleanups by Peter Senna Tschudin." * git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-next: (47 commits) sparc64: Fix trailing whitespace in NG4 memcpy. sparc64: Fix comment type in NG4 copy from user. sparc64: Add SPARC-T4 optimized memcpy. drivers/sbus/char: removes unnecessary semicolon arch/sparc/kernel/pci_sun4v.c: removes unnecessary semicolon sparc64: Fix function argument comment in camellia_sparc64_key_expand asm. sparc64: Fix IV handling bug in des_sparc64_cbc_decrypt sparc64: Add auto-loading mechanism to crypto-opcode drivers. sparc64: Add missing pr_fmt define to crypto opcode drivers. sparc64: Adjust crypto priorities. sparc64: Use cpu_pgsz_mask for linear kernel mapping config. sparc64: Probe cpu page size support more portably. sparc64: Support 2GB and 16GB page sizes for kernel linear mappings. sparc64: Fix bugs in unrolled 256-bit loops. sparc64: Avoid code duplication in crypto assembler. sparc64: Unroll CTR crypt loops in AES driver. sparc64: Unroll ECB decryption loops in AES driver. sparc64: Unroll ECB encryption loops in AES driver. sparc64: Add ctr mode support to AES driver. sparc64: Move AES driver over to a methods based implementation. ...
2012-09-27crypto: tcrypt - add missing tests for camellia and ghashJussi Kivilinna
Add missing tests for ctr(camellia), lrw(camellia), xts(camellia) and ghash, as these have test vectors available. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-09-27crypto: testmgr - make test_aead also test 'dst != src' code pathsJussi Kivilinna
Currrently test_aead uses same buffer for destination and source. However in any places, 'dst != src' take different path than 'dst == src' case. Therefore make test_aead also run tests with destination buffer being different than source buffer. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-09-27crypto: testmgr - make test_skcipher also test 'dst != src' code pathsJussi Kivilinna
Currrently test_skcipher uses same buffer for destination and source. However in any places, 'dst != src' take different path than 'dst == src' case. Therefore make test_skcipher also run tests with destination buffer being different than source buffer. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-09-27crypto: testmgr - add test vectors for CTR mode IV increasementJussi Kivilinna
More precisely, test 'long word' and 'long long word' overflow and carry handling. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-09-27crypto: testmgr - add test vectors for partial ctr(cast5) and ctr(cast6)Jussi Kivilinna
2012-09-27crypto: testmgr - allow non-multi page and multi page skcipher tests from ↵Jussi Kivilinna
same test template Allow non-multi page and multi page skcipher tests to be run on same test template, to avoid duplicating data. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-09-27crypto, tcrypt: remove local_bh_disable/enable() around ↵Suresh Siddha
local_irq_disable/enable() Ran into this while looking at some new crypto code using FPU hitting a WARN_ON_ONCE(!irq_fpu_usable()) in the kernel_fpu_begin() on a x86 kernel that uses the new eagerfpu model. In short, current eagerfpu changes return 0 for interrupted_kernel_fpu_idle() and the in_interrupt() thinks it is in the interrupt context because of the local_bh_disable(). Thus resulting in the WARN_ON(). Remove the local_bh_disable/enable() calls around the existing local_irq_disable/enable() calls. local_irq_disable/enable() already disables the BH. [ If there are any other legitimate users calling kernel_fpu_begin() from the process context but with BH disabled, then we can look into fixing the irq_fpu_usable() in future. ] Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-09-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: net/netfilter/nfnetlink_log.c net/netfilter/xt_LOG.c Rather easy conflict resolution, the 'net' tree had bug fixes to make sure we checked if a socket is a time-wait one or not and elide the logging code if so. Whereas on the 'net-next' side we are calculating the UID and GID from the creds using different interfaces due to the user namespace changes from Eric Biederman. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-11crypto: authenc - Fix crash with zero-length assoc dataHerbert Xu
The authenc code doesn't deal with zero-length associated data correctly and ends up constructing a zero-length sg entry which causes a crash when it's fed into the crypto system. This patch fixes this by avoiding the code-path that triggers the SG construction if we have no associated data. This isn't the most optimal fix as it means that we'll end up using the fallback code-path even when we could still execute the digest function. However, this isn't a big deal as nobody but the test path would supply zero-length associated data. Reported-by: Romain Francoise <romain@orebokech.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Tested-by: Romain Francoise <romain@orebokech.com>
2012-09-10netlink: Rename pid to portid to avoid confusionEric W. Biederman
It is a frequent mistake to confuse the netlink port identifier with a process identifier. Try to reduce this confusion by renaming fields that hold port identifiers portid instead of pid. I have carefully avoided changing the structures exported to userspace to avoid changing the userspace API. I have successfully built an allyesconfig kernel with this change. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-08netlink: hide struct module parameter in netlink_kernel_createPablo Neira Ayuso
This patch defines netlink_kernel_create as a wrapper function of __netlink_kernel_create to hide the struct module *me parameter (which seems to be THIS_MODULE in all existing netlink subsystems). Suggested by David S. Miller. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-07crypto: 842 - remove .cra_list initializationJussi Kivilinna
.cra_list initialization is unneeded and have been removed from all other crypto modules except 842. Cc: Robert Jennings <rcj@linux.vnet.ibm.com> Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: Seth Jennings <sjenning@linux.vnet.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-09-07Revert "[CRYPTO] cast6: inline bloat--"Jussi Kivilinna
This reverts commit e6ccc727f30a02670f6a00df6d548942bc988f43. Above commit caused performance regression for CAST6. Reverting gives following increase in tcrypt speed tests (revert-vs-old ratios). AMD Phenom II X6 1055T, x86-64: size ecb cbc ctr lrw xts enc dec enc dec enc dec enc dec enc dec 16b 1.15x 1.17x 1.16x 1.17x 1.16x 1.16x 1.14x 1.19x 1.05x 1.07x 64b 1.19x 1.23x 1.20x 1.22x 1.19x 1.19x 1.16x 1.24x 1.12x 1.12x 256b 1.21x 1.24x 1.22x 1.24x 1.20x 1.20x 1.17x 1.21x 1.16x 1.14x 1kb 1.21x 1.25x 1.22x 1.24x 1.21x 1.21x 1.18x 1.22x 1.17x 1.15x 8kb 1.21x 1.25x 1.22x 1.24x 1.21x 1.21x 1.18x 1.22x 1.18x 1.15x Cc: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-09-07crypto: crypto_user - fix sparse warnings (symbol was not declared, should ↵Jussi Kivilinna
be static?) Fix "symbol 'x' was not declared. Should it be static?" sparse warnings. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
