path: root/crypto
2009-03-16crypto: api - Fix algorithm test race that broke aead initialisationHerbert Xu
commit b8e15992b420d09dae831125a623c474c8637cee upstream. When we complete a test we'll notify everyone waiting on it, drop the mutex, and then remove the test larval (after reacquiring the mutex). If one of the notified parties tries to register another algorithm with the same driver name prior to the removal of the test larval, they will fail with EEXIST as only one algorithm of a given name can be tested at any time. This broke the initialisation of aead and givcipher algorithms as they will register two algorithms with the same driver name, in sequence. This patch fixes the problem by marking the larval as dead before we drop the mutex, and also ignoring all dead or dying algorithms on the registration path. Tested-by: Andreas Steffen <andreas.steffen@strongswan.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Cc: Kerin Millar <kerframil@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-02-02dmaengine: fix dependency chainingYuri Tikhonov
commit dd59b8537f6cb53ab863fafad86a5828f1e889a2 upstream ASYNC_TX: fix dependency chaining In ASYNC_TX we track the dependencies between the descriptors using the 'next' pointers of the structures. These pointers are set to NULL as soon as the corresponding descriptor has been submitted to the channel (in async_tx_run_dependencies()). But, the first 'next' in chain still remains set, regardless the fact, that tx->next is already submitted. This may lead to multiple submisions of the same descriptor. This patch fixes this. Signed-off-by: Yuri Tikhonov <yur@emcraft.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-02-02crypto: ccm - Fix handling of null assoc dataJarod Wilson
commit 516280e735b034216de97eb7ba080ec6acbfc58f upstream. Its a valid use case to have null associated data in a ccm vector, but this case isn't being handled properly right now. The following ccm decryption/verification test vector, using the rfc4309 implementation regularly triggers a panic, as will any other vector with null assoc data: * key: ab2f8a74b71cd2b1ff802e487d82f8b9 * iv: c6fb7d800d13abd8a6b2d8 * Associated Data: [NULL] * Tag Length: 8 * input: d5e8939fc7892e2b The resulting panic looks like so: Unable to handle kernel paging request at ffff810064ddaec0 RIP: [<ffffffff8864c4d7>] :ccm:get_data_to_compute+0x1a6/0x1d6 PGD 8063 PUD 0 Oops: 0002 [1] SMP last sysfs file: /module/libata/version CPU 0 Modules linked in: crypto_tester_kmod(U) seqiv krng ansi_cprng chainiv rng ctr aes_generic aes_x86_64 ccm cryptomgr testmgr_cipher testmgr aead crypto_blkcipher crypto_a lgapi des ipv6 xfrm_nalgo crypto_api autofs4 hidp l2cap bluetooth nfs lockd fscache nfs_acl sunrpc ip_conntrack_netbios_ns ipt_REJECT xt_state ip_conntrack nfnetlink xt_ tcpudp iptable_filter ip_tables x_tables dm_mirror dm_log dm_multipath scsi_dh dm_mod video hwmon backlight sbs i2c_ec button battery asus_acpi acpi_memhotplug ac lp sg snd_intel8x0 snd_ac97_codec ac97_bus snd_seq_dummy snd_seq_oss joydev snd_seq_midi_event snd_seq snd_seq_device snd_pcm_oss snd_mixer_oss ide_cd snd_pcm floppy parport_p c shpchp e752x_edac snd_timer e1000 i2c_i801 edac_mc snd soundcore snd_page_alloc i2c_core cdrom parport serio_raw pcspkr ata_piix libata sd_mod scsi_mod ext3 jbd uhci_h cd ohci_hcd ehci_hcd Pid: 12844, comm: crypto-tester Tainted: G 2.6.18-128.el5.fips1 #1 RIP: 0010:[<ffffffff8864c4d7>] [<ffffffff8864c4d7>] :ccm:get_data_to_compute+0x1a6/0x1d6 RSP: 0018:ffff8100134434e8 EFLAGS: 00010246 RAX: 0000000000000000 RBX: ffff8100104898b0 RCX: ffffffffab6aea10 RDX: 0000000000000010 RSI: ffff8100104898c0 RDI: ffff810064ddaec0 RBP: 0000000000000000 R08: ffff8100104898b0 R09: 0000000000000000 R10: ffff8100103bac84 R11: ffff8100104898b0 R12: ffff810010489858 R13: ffff8100104898b0 R14: ffff8100103bac00 R15: 0000000000000000 FS: 00002ab881adfd30(0000) GS:ffffffff803ac000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: ffff810064ddaec0 CR3: 0000000012a88000 CR4: 00000000000006e0 Process crypto-tester (pid: 12844, threadinfo ffff810013442000, task ffff81003d165860) Stack: ffff8100103bac00 ffff8100104898e8 ffff8100134436f8 ffffffff00000000 0000000000000000 ffff8100104898b0 0000000000000000 ffff810010489858 0000000000000000 ffff8100103bac00 ffff8100134436f8 ffffffff8864c634 Call Trace: [<ffffffff8864c634>] :ccm:crypto_ccm_auth+0x12d/0x140 [<ffffffff8864cf73>] :ccm:crypto_ccm_decrypt+0x161/0x23a [<ffffffff88633643>] :crypto_tester_kmod:cavs_test_rfc4309_ccm+0x4a5/0x559 [...] The above is from a RHEL5-based kernel, but upstream is susceptible too. The fix is trivial: in crypto/ccm.c:crypto_ccm_auth(), pctx->ilen contains whatever was in memory when pctx was allocated if assoclen is 0. The tested fix is to simply add an else clause setting pctx->ilen to 0 for the assoclen == 0 case, so that get_data_to_compute() doesn't try doing things its not supposed to. Signed-off-by: Jarod Wilson <jarod@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-02-02crypto: authenc - Fix zero-length IV crashHerbert Xu
commit 29b37f42127f7da511560a40ea74f5047da40c13 upstream. As it is if an algorithm with a zero-length IV is used (e.g., NULL encryption) with authenc, authenc may generate an SG entry of length zero, which will trigger a BUG check in the hash layer. This patch fixes it by skipping the IV SG generation if the IV size is zero. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-12-18Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: async_xor: dma_map destination DMA_BIDIRECTIONAL dmaengine: protect 'id' from concurrent registrations ioat: wait for self-test completion
2008-12-10crypto: api - Disallow cryptomgr as a module if algorithms are built-inHerbert Xu
If we have at least one algorithm built-in then it no longer makes sense to have the testing framework, and hence cryptomgr to be a module. It should be either on or off, i.e., built-in or disabled. This just happens to stop a potential runaway modprobe loop that seems to trigger on at least one distro. With fixes from Evgeniy Polyakov. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-08async_xor: dma_map destination DMA_BIDIRECTIONALDan Williams
Mapping the destination multiple times is a misuse of the dma-api. Since the destination may be reused as a source, ensure that it is only mapped once and that it is mapped bidirectionally. This appears to add ugliness on the unmap side in that it always reads back the destination address from the descriptor, but gcc can determine that dma_unmap is a nop and not emit the code that calculates its arguments. Cc: <stable@kernel.org> Cc: Saeed Bishara <saeed@marvell.com> Acked-by: Yuri Tikhonov <yur@emcraft.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2008-10-20Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: fsldma: allow Freescale Elo DMA driver to be compiled as a module fsldma: remove internal self-test from Freescale Elo DMA driver drivers/dma/dmatest.c: switch a GFP_ATOMIC to GFP_KERNEL dmatest: properly handle duplicate DMA channels drivers/dma/ioat_dma.c: drop code after return async_tx: make async_tx_run_dependencies() easier to read
2008-10-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: skcipher - Use RNG interface instead of get_random_bytes crypto: rng - RNG interface and implementation crypto: api - Add fips_enable flag crypto: skcipher - Move IV generators into their own modules crypto: cryptomgr - Test ciphers using ECB crypto: api - Use test infrastructure crypto: cryptomgr - Add test infrastructure crypto: tcrypt - Add alg_test interface crypto: tcrypt - Abort and only log if there is an error crypto: crc32c - Use Intel CRC32 instruction crypto: tcrypt - Avoid using contiguous pages crypto: api - Display larval objects properly crypto: api - Export crypto_alg_lookup instead of __crypto_alg_lookup crypto: Kconfig - Replace leading spaces with tabs
2008-09-13async_tx: make async_tx_run_dependencies() easier to readDan Williams
* Rename 'next' to 'dep' * Move the channel switch check inside the loop to simplify termination Acked-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2008-09-08Revert "crypto: camellia - Use kernel-provided bitops, unaligned access helpers"Herbert Xu
This reverts commit bd699f2df6dbc2f4cba528fe598bd63a4d3702c5, which causes camellia to fail the included self-test vectors. It has also been confirmed that it breaks existing encrypted disks using camellia. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-09-05async_tx: fix the bug in async_tx_run_dependenciesYuri Tikhonov
Should clear the next pointer of the TX if we are sure that the next TX (say NXT) will be submitted to the channel too. Overwise, we break the chain of descriptors, because we lose the information about the next descriptor to run. So next time, when invoke async_tx_run_dependencies() with TX, it's TX->next will be NULL, and NXT will be never submitted. Cc: <stable@kernel.org> [2.6.26] Signed-off-by: Yuri Tikhonov <yur@emcraft.com> Signed-off-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2008-08-29crypto: skcipher - Use RNG interface instead of get_random_bytesHerbert Xu
This patch makes the IV generators use the new RNG interface so that the user can pick an RNG other than the default get_random_bytes. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: rng - RNG interface and implementationNeil Horman
This patch adds a random number generator interface as well as a cryptographic pseudo-random number generator based on AES. It is meant to be used in cases where a deterministic CPRNG is required. One of the first applications will be as an input in the IPsec IV generation process. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: api - Add fips_enable flagNeil Horman
Add the ability to turn FIPS-compliant mode on or off at boot In order to be FIPS compliant, several check may need to be preformed that may be construed as unusefull in a non-compliant mode. This patch allows us to set a kernel flag incating that we are running in a fips-compliant mode from boot up. It also exports that mode information to user space via a sysctl (/proc/sys/crypto/fips_enabled). Tested successfully by me. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: skcipher - Move IV generators into their own modulesHerbert Xu
This patch moves the default IV generators into their own modules in order to break a dependency loop between cryptomgr, rng, and blkcipher. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: cryptomgr - Test ciphers using ECBHerbert Xu
As it is we only test ciphers when combined with a mode. That means users that do not invoke a mode of operations may get an untested cipher. This patch tests all ciphers using the ECB mode so that simple cipher users such as ansi-cprng are also protected. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: api - Use test infrastructureHerbert Xu
This patch makes use of the new testing infrastructure by requiring algorithms to pass a run-time test before they're made available to users. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: cryptomgr - Add test infrastructureHerbert Xu
This patch moves the newly created alg_test infrastructure into cryptomgr. This shall allow us to use it for testing at algorithm registrations. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: tcrypt - Add alg_test interfaceHerbert Xu
This patch creates a new interface algorithm testing. A test can be requested for a particular implementation of an algorithm. This is achieved by taking both the name of the algorithm and that of the implementation. The all-inclusive test has also been rewritten to no longer require a duplicate listing of all algorithms with tests. In that process a number of missing tests have also been discovered and rectified. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: tcrypt - Abort and only log if there is an errorHerbert Xu
The info printed is a complete waste of space when there is no error since it doesn't tell us anything that we don't already know. If there is an error, we can also be more verbose. In case that there is an error, this patch also aborts the test and returns the error to the caller. In future this will be used to algorithms at registration time. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: crc32c - Use Intel CRC32 instructionAustin Zhang
From NHM processor onward, Intel processors can support hardware accelerated CRC32c algorithm with the new CRC32 instruction in SSE 4.2 instruction set. The patch detects the availability of the feature, and chooses the most proper way to calculate CRC32c checksum. Byte code instructions are used for compiler compatibility. No MMX / XMM registers is involved in the implementation. Signed-off-by: Austin Zhang <austin.zhang@intel.com> Signed-off-by: Kent Liu <kent.liu@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: tcrypt - Avoid using contiguous pagesHerbert Xu
If tcrypt is to be used as a run-time integrity test, it needs to be more resilient in a hostile environment. For a start allocating 32K of physically contiguous memory is definitely out. This patch teaches it to use separate pages instead. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: api - Display larval objects properlyHerbert Xu
Rather than displaying larval objects as real objects, this patch makes them show up under /proc/crypto as of type larval. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: api - Export crypto_alg_lookup instead of __crypto_alg_lookupHerbert Xu
Since the only user of __crypto_alg_lookup is doing exactly what crypto_alg_lookup does, we can now the latter in lieu of the former. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: Kconfig - Replace leading spaces with tabsAdrian Bunk
Instead of tabs there were two spaces. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-23crypto: authenc - Avoid using clobbered request pointerHerbert Xu
Authenc works in two stages for encryption, it first encrypts and then computes an ICV. The context memory of the request is used by both operations. The problem is that when an asynchronous encryption completes, we will compute the ICV and then reread the context memory of the encryption to get the original request. It just happens that we have a buffer of 16 bytes in front of the request pointer, so ICVs of 16 bytes (such as SHA1) do not trigger the bug. However, any attempt to uses a larger ICV instantly kills the machine when the first asynchronous encryption is completed. This patch fixes this by saving the request pointer before we start the ICV computation. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-13crypto: hash - Fix digest size check for digest typeHerbert Xu
The changeset ca786dc738f4f583b57b1bba7a335b5e8233f4b0 crypto: hash - Fixed digest size check missed one spot for the digest type. This patch corrects that error. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-13crypto: tcrypt - Fix AEAD chunk testingHerbert Xu
My changeset 4b22f0ddb6564210c9ded7ba25b2a1007733e784 crypto: tcrpyt - Remove unnecessary kmap/kunmap calls introduced a typo that broke AEAD chunk testing. In particular, axbuf should really be xbuf. There is also an issue with testing the last segment when encrypting. The additional part produced by AEAD wasn't tested. Similarly, on decryption the additional part of the AEAD input is mistaken for corruption. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-05async_tx: fix missing braces in async_xor_zero_sumDan Williams
Found-by: Yuri Tikhonov <yur@emcraft.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2008-07-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: (24 commits) I/OAT: I/OAT version 3.0 support I/OAT: tcp_dma_copybreak default value dependent on I/OAT version I/OAT: Add watchdog/reset functionality to ioatdma iop_adma: cleanup iop_chan_xor_slot_count iop_adma: document how to calculate the minimum descriptor pool size iop_adma: directly reclaim descriptors on allocation failure async_tx: make async_tx_test_ack a boolean routine async_tx: remove depend_tx from async_tx_sync_epilog async_tx: export async_tx_quiesce async_tx: fix handling of the "out of descriptor" condition in async_xor async_tx: ensure the xor destination buffer remains dma-mapped async_tx: list_for_each_entry_rcu() cleanup dmaengine: Driver for the Synopsys DesignWare DMA controller dmaengine: Add slave DMA interface dmaengine: add DMA_COMPL_SKIP_{SRC,DEST}_UNMAP flags to control dma unmap dmaengine: Add dma_client parameter to device_alloc_chan_resources dmatest: Simple DMA memcpy test client dmaengine: DMA engine driver for Marvell XOR engine iop-adma: fix platform driver hotplug/coldplug dmaengine: track the number of clients using a channel ... Fixed up conflict in drivers/dca/dca-sysfs.c manually
2008-07-17async_tx: remove depend_tx from async_tx_sync_epilogDan Williams
All callers of async_tx_sync_epilog have called async_tx_quiesce on the depend_tx, so async_tx_sync_epilog need only call the callback to complete the operation. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2008-07-17async_tx: export async_tx_quiesceDan Williams
Replace open coded "wait and acknowledge" instances with async_tx_quiesce. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2008-07-17async_tx: fix handling of the "out of descriptor" condition in async_xorDan Williams
Ensure forward progress is made when a dmaengine driver is unable to allocate an xor descriptor by breaking the dependency chain with async_tx_quisce() and issue any pending descriptors. Tested with iop-adma by setting device->max_xor = 2 to force multiple calls to device_prep_dma_xor for each call to async_xor and limiting the descriptor slot pool to 5. Discovered that the minimum descriptor pool size for iop-adma is 2 * iop_chan_xor_slot_cnt(device->max_xor) + 1. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2008-07-17async_tx: ensure the xor destination buffer remains dma-mappedDan Williams
When the number of source buffers for an xor operation exceeds the hardware channel maximum async_xor creates a chain of dependent operations. The result of one operation is reused as an input to the next to continue the xor calculation. The destination buffer should remain mapped for the duration of the entire chain. To provide this guarantee the code must no longer be allowed to fallback to the synchronous path as this will preclude the buffer from being unmapped, i.e. the dma-driver will potentially miss the descriptor with !DMA_COMPL_SKIP_DEST_UNMAP. Cc: Neil Brown <neilb@suse.de> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2008-07-17async_tx: list_for_each_entry_rcu() cleanupLi Zefan
In the rcu update side, don't use list_for_each_entry_rcu(). Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2008-07-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: Revert crypto: prng - Deterministic CPRNG
2008-07-15Merge branch 'core/rcu' into core/rcu-for-linusIngo Molnar
2008-07-15Revert crypto: prng - Deterministic CPRNGHerbert Xu
This patch is clearly not ready yet for prime time. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-11Merge branch 'linus' into core/rcuIngo Molnar
Conflicts: include/linux/rculist.h kernel/rcupreempt.c Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-10crypto: hash - Move ahash functions into crypto/hash.hHerbert Xu
All new crypto interfaces should go into individual files as much as possible in order to ensure that crypto.h does not collapse under its own weight. This patch moves the ahash code into crypto/hash.h and crypto/internal/hash.h respectively. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10crypto: crc32c - Add ahash implementationHerbert Xu
This patch reimplements crc32c using the ahash interface. This allows one tfm to be used by an unlimited number of users provided that they all use the same key (which all current crc32c users do). Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10crypto: hash - Added scatter list walking helperHerbert Xu
This patch adds the walking helpers for hash algorithms akin to those of block ciphers. This is a necessary step before we can reimplement existing hash algorithms using the new ahash interface. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10crypto: prng - Deterministic CPRNGNeil Horman
This patch adds a cryptographic pseudo-random number generator based on CTR(AES-128). It is meant to be used in cases where a deterministic CPRNG is required. One of the first applications will be as an input in the IPsec IV generation process. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10crypto: hash - Removed vestigial ahash fieldsHerbert Xu
The base field in ahash_tfm appears to have been cut-n-pasted from ablkcipher. It isn't needed here at all. Similarly, the info field in ahash_request also appears to have originated from its cipher counter-part and is vestigial. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10crypto: hash - Fixed digest size checkHerbert Xu
The digest size check on hash algorithms is incorrect. It's perfectly valid for hash algorithms to have a digest length longer than their block size. For example crc32c has a block size of 1 and a digest size of 4. Rather than having it lie about its block size, this patch fixes the checks to do what they really should which is to bound the digest size so that code placing the digest on the stack continue to work. HMAC however still needs to check this as it's only defined for such algorithms. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10crypto: rmd - sparse annotationsHarvey Harrison
Similar to the rmd128.c annotations, significantly cuts down on the noise. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10crypto: rmd128 - sparse annotationsHarvey Harrison
2008-07-10crypto: camellia - Use kernel-provided bitops, unaligned access helpersHarvey Harrison
Remove the private implementation of 32-bit rotation and unaligned access with byteswapping. As a bonus, fixes sparse warnings: crypto/camellia.c:602:2: warning: cast to restricted __be32 crypto/camellia.c:603:2: warning: cast to restricted __be32 crypto/camellia.c:604:2: warning: cast to restricted __be32 crypto/camellia.c:605:2: warning: cast to restricted __be32 crypto/camellia.c:710:2: warning: cast to restricted __be32 crypto/camellia.c:711:2: warning: cast to restricted __be32 crypto/camellia.c:712:2: warning: cast to restricted __be32 crypto/camellia.c:713:2: warning: cast to restricted __be32 crypto/camellia.c:714:2: warning: cast to restricted __be32 crypto/camellia.c:715:2: warning: cast to restricted __be32 crypto/camellia.c:716:2: warning: cast to restricted __be32 crypto/camellia.c:717:2: warning: cast to restricted __be32 Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-07-10crypto: tcrpyt - Remove unnecessary kmap/kunmap callsHerbert Xu
Noticed by Neil Horman: we are doing unnecessary kmap/kunmap calls on kmalloced memory. This patch removes them. For the purposes of testing SG construction, the underlying crypto code already does plenty of kmap/kunmap calls anyway. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
