path: root/crypto
2008-12-25crypto: aes - Precompute tablesHerbert Xu
The tables used by the various AES algorithms are currently computed at run-time. This has created an init ordering problem because some AES algorithms may be registered before the tables have been initialised. This patch gets around this whole thing by precomputing the tables. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: testmgr - Correct comment about deflate parametersGeert Uytterhoeven
The comment for the deflate test vectors says the winbits parameter is 11, while the deflate module actually uses -11 (a negative window bits parameter enables the raw deflate format instead of the zlib format). Correct this, to avoid confusion about the format used. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: salsa20 - Remove private wrappers around various operationsHarvey Harrison
ROTATE -> rol32 XOR was always used with the same destination, use ^= PLUS/PLUSONE use ++ or += Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: des3_ede - permit weak keys unless REQ_WEAK_KEY setJarod Wilson
While its a slightly insane to bypass the key1 == key2 || key2 == key3 check in triple-des, since it reduces it to the same strength as des, some folks do need to do this from time to time for backwards compatibility with des. My own case is FIPS CAVS test vectors. Many triple-des test vectors use a single key, replicated 3x. In order to get the expected results, des3_ede_setkey() needs to only reject weak keys if the CRYPTO_TFM_REQ_WEAK_KEY flag is set. Also sets a more appropriate RES flag when a weak key is found. Signed-off-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: sha512 - Switch to shash Adrian-Ken Rueegsegger
This patch changes sha512 and sha384 to the new shash interface. Signed-off-by: Adrian-Ken Rueegsegger <ken@codelabs.ch> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: sha512 - Move message schedule W[80] to static percpu areaAdrian-Ken Rueegsegger
The message schedule W (u64[80]) is too big for the stack. In order for this algorithm to be used with shash it is moved to a static percpu area. Signed-off-by: Adrian-Ken Rueegsegger <ken@codelabs.ch> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: michael_mic - Switch to shashAdrian-Ken Rueegsegger
This patch changes michael_mic to the new shash interface. Signed-off-by: Adrian-Ken Rueegsegger <ken@codelabs.ch> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: wp512 - Switch to shashAdrian-Ken Rueegsegger
This patch changes wp512, wp384 and wp256 to the new shash interface. Signed-off-by: Adrian-Ken Rueegsegger <ken@codelabs.ch> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: tgr192 - Switch to shashAdrian-Ken Rueegsegger
This patch changes tgr192, tgr160 and tgr128 to the new shash interface. Signed-off-by: Adrian-Ken Rueegsegger <ken@codelabs.ch> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: sha256 - Switch to shashAdrian-Ken Rueegsegger
This patch changes sha256 and sha224 to the new shash interface. Signed-off-by: Adrian-Ken Rueegsegger <ken@codelabs.ch> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: md5 - Switch to shashAdrian-Ken Rueegsegger
This patch changes md5 to the new shash interface. Signed-off-by: Adrian-Ken Rueegsegger <ken@codelabs.ch> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: md4 - Switch to shashAdrian-Ken Rueegsegger
This patch changes md4 to the new shash interface. Signed-off-by: Adrian-Ken Rueegsegger <ken@codelabs.ch> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: sha1 - Switch to shashAdrian-Ken Rueegsegger
This patch changes sha1 to the new shash interface. Signed-off-by: Adrian-Ken Rueegsegger <ken@codelabs.ch> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: rmd320 - Switch to shashHerbert Xu
This patch changes rmd320 to the new shash interface. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: rmd256 - Switch to shashHerbert Xu
This patch changes rmd256 to the new shash interface. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: rmd160 - Switch to shashHerbert Xu
This patch changes rmd160 to the new shash interface. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: rmd128 - Switch to shashHerbert Xu
This patch changes rmd128 to the new shash interface. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: null - Switch to shashHerbert Xu
This patch changes digest_null to the new shash interface. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: hash - Make setkey optionalHerbert Xu
Since most cryptographic hash algorithms have no keys, this patch makes the setkey function optional for ahash and shash. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: testmgr - Validate output length in (de)compression testsGeert Uytterhoeven
When self-testing (de)compression algorithms, make sure the actual size of the (de)compressed output data matches the expected output size. Otherwise, in case the actual output size would be smaller than the expected output size, the subsequent buffer compare test would still succeed, and no error would be reported. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: remove uses of __constant_{endian} helpersHarvey Harrison
Base versions handle constant folding just fine. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: testmgr - Fix error flow of test_compIngo Molnar
This warning: crypto/testmgr.c: In function ‘test_comp’: crypto/testmgr.c:829: warning: ‘ret’ may be used uninitialized in this function triggers because GCC correctly notices that in the ctcount == 0 && dtcount != 0 input condition case this function can return an undefined value, if the second loop fails. Remove the shadowed 'ret' variable from the second loop that was probably unintended. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: ansi_cprng - fix inverted DT increment routineJarod Wilson
The ANSI X9.31 PRNG docs aren't particularly clear on how to increment DT, but empirical testing shows we're incrementing from the wrong end. A 10,000 iteration Monte Carlo RNG test currently winds up not getting the expected result. From http://csrc.nist.gov/groups/STM/cavp/documents/rng/RNGVS.pdf : # CAVS 4.3 # ANSI931 MCT [X9.31] [AES 128-Key] COUNT = 0 Key = 9f5b51200bf334b5d82be8c37255c848 DT = 6376bbe52902ba3b67c925fa701f11ac V = 572c8e76872647977e74fbddc49501d1 R = 48e9bd0d06ee18fbe45790d5c3fc9b73 Currently, we get 0dd08496c4f7178bfa70a2161a79459a after 10000 loops. Inverting the DT increment routine results in us obtaining the expected result of 48e9bd0d06ee18fbe45790d5c3fc9b73. Verified on both x86_64 and ppc64. Signed-off-by: Jarod Wilson <jarod@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: ansi_cprng - Avoid incorrect extra call to _get_more_prng_bytesJarod Wilson
While working with some FIPS RNGVS test vectors yesterday, I discovered a little bug in the way the ansi_cprng code works right now. For example, the following test vector (complete with expected result) from http://csrc.nist.gov/groups/STM/cavp/documents/rng/RNGVS.pdf ... Key = f3b1666d13607242ed061cabb8d46202 DT = e6b3be782a23fa62d71d4afbb0e922fc V = f0000000000000000000000000000000 R = 88dda456302423e5f69da57e7b95c73a ...when run through ansi_cprng, yields an incorrect R value of e2afe0d794120103d6e86a2b503bdfaa. If I load up ansi_cprng w/dbg=1 though, it was fairly obvious what was going wrong: ----8<---- getting 16 random bytes for context ffff810033fb2b10 Calling _get_more_prng_bytes for context ffff810033fb2b10 Input DT: 00000000: e6 b3 be 78 2a 23 fa 62 d7 1d 4a fb b0 e9 22 fc Input I: 00000000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Input V: 00000000: f0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 tmp stage 0: 00000000: e6 b3 be 78 2a 23 fa 62 d7 1d 4a fb b0 e9 22 fc tmp stage 1: 00000000: f4 8e cb 25 94 3e 8c 31 d6 14 cd 8a 23 f1 3f 84 tmp stage 2: 00000000: 8c 53 6f 73 a4 1a af d4 20 89 68 f4 58 64 f8 be Returning new block for context ffff810033fb2b10 Output DT: 00000000: e7 b3 be 78 2a 23 fa 62 d7 1d 4a fb b0 e9 22 fc Output I: 00000000: 04 8e cb 25 94 3e 8c 31 d6 14 cd 8a 23 f1 3f 84 Output V: 00000000: 48 89 3b 71 bc e4 00 b6 5e 21 ba 37 8a 0a d5 70 New Random Data: 00000000: 88 dd a4 56 30 24 23 e5 f6 9d a5 7e 7b 95 c7 3a Calling _get_more_prng_bytes for context ffff810033fb2b10 Input DT: 00000000: e7 b3 be 78 2a 23 fa 62 d7 1d 4a fb b0 e9 22 fc Input I: 00000000: 04 8e cb 25 94 3e 8c 31 d6 14 cd 8a 23 f1 3f 84 Input V: 00000000: 48 89 3b 71 bc e4 00 b6 5e 21 ba 37 8a 0a d5 70 tmp stage 0: 00000000: e7 b3 be 78 2a 23 fa 62 d7 1d 4a fb b0 e9 22 fc tmp stage 1: 00000000: 80 6b 3a 8c 23 ae 8f 53 be 71 4c 16 fc 13 b2 ea tmp stage 2: 00000000: 2a 4d e1 2a 0b 58 8e e6 36 b8 9c 0a 26 22 b8 30 Returning new block for context ffff810033fb2b10 Output DT: 00000000: e8 b3 be 78 2a 23 fa 62 d7 1d 4a fb b0 e9 22 fc Output I: 00000000: c8 e2 01 fd 9f 4a 8f e5 e0 50 f6 21 76 19 67 9a Output V: 00000000: ba 98 e3 75 c0 1b 81 8d 03 d6 f8 e2 0c c6 54 4b New Random Data: 00000000: e2 af e0 d7 94 12 01 03 d6 e8 6a 2b 50 3b df aa returning 16 from get_prng_bytes in context ffff810033fb2b10 ----8<---- The expected result is there, in the first "New Random Data", but we're incorrectly making a second call to _get_more_prng_bytes, due to some checks that are slightly off, which resulted in our original bytes never being returned anywhere. One approach to fixing this would be to alter some byte_count checks in get_prng_bytes, but it would mean the last DEFAULT_BLK_SZ bytes would be copied a byte at a time, rather than in a single memcpy, so a slightly more involved, equally functional, and ultimately more efficient way of fixing this was suggested to me by Neil, which I'm submitting here. All of the RNGVS ANSI X9.31 AES128 VST test vectors I've passed through ansi_cprng are now returning the expected results with this change. Signed-off-by: Jarod Wilson <jarod@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: md4 - Use ARRAY_SIZEJulia Lawall
ARRAY_SIZE is more concise to use when the size of an array is divided by the size of its type or the size of its first element. The semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @i@ @@ #include <linux/kernel.h> @depends on i using "paren.iso"@ type T; T[] E; @@ - (sizeof(E)/sizeof(T)) + ARRAY_SIZE(E) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25libcrc32c: Move implementation to crypto crc32cHerbert Xu
This patch swaps the role of libcrc32c and crc32c. Previously the implementation was in libcrc32c and crc32c was a wrapper. Now the code is in crc32c and libcrc32c just calls the crypto layer. The reason for the change is to tap into the algorithm selection capability of the crypto API so that optimised implementations such as the one utilising Intel's CRC32C instruction can be used where available. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: crc32c - Test descriptor context formatHerbert Xu
This patch adds a test for the requirement that all crc32c algorithms shall store the partial result in the first four bytes of the descriptor context. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: crc32c - Switch to shashHerbert Xu
This patch changes crc32c to the new shash interface. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: hash - Export shash through hashHerbert Xu
This patch allows shash algorithms to be used through the old hash interface. This is a transitional measure so we can convert the underlying algorithms to shash before converting the users across. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: api - Call type show function before legacy for procHerbert Xu
This patch makes /proc/crypto call the type-specific show function if one is present before calling the legacy show functions for cipher/digest/compress. This allows us to reuse the type values for those legacy types. In particular, hash and digest will share one type value while shash is phased in as the default hash type. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: hash - Add import/export interfaceHerbert Xu
It is often useful to save the partial state of a hash function so that it can be used as a base for two or more computations. The most prominent example is HMAC where all hashes start from a base determined by the key. Having an import/export interface means that we only have to compute that base once rather than for each message. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: hash - Export shash through ahashHerbert Xu
This patch allows shash algorithms to be used through the ahash interface. This is required before we can convert digest algorithms over to shash. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: hash - Add shash interfaceHerbert Xu
The shash interface replaces the current synchronous hash interface. It improves over hash in two ways. Firstly shash is reentrant, meaning that the same tfm may be used by two threads simultaneously as all hashing state is stored in a local descriptor. The other enhancement is that shash no longer takes scatter list entries. This is because shash is specifically designed for synchronous algorithms and as such scatter lists are unnecessary. All existing hash users will be converted to shash once the algorithms have been completely converted. There is also a new finup function that combines update with final. This will be extended to ahash once the algorithm conversion is done. This is also the first time that an algorithm type has their own registration function. Existing algorithm types will be converted to this way in due course. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: api - Rebirth of crypto_alloc_tfmHerbert Xu
This patch reintroduces a completely revamped crypto_alloc_tfm. The biggest change is that we now take two crypto_type objects when allocating a tfm, a frontend and a backend. In fact this simply formalises what we've been doing behind the API's back. For example, as it stands crypto_alloc_ahash may use an actual ahash algorithm or a crypto_hash algorithm. Putting this in the API allows us to do this much more cleanly. The existing types will be converted across gradually. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: api - Move type exit function into crypto_tfmHerbert Xu
The type exit function needs to undo any allocations done by the type init function. However, the type init function may differ depending on the upper-level type of the transform (e.g., a crypto_blkcipher instantiated as a crypto_ablkcipher). So we need to move the exit function out of the lower-level structure and into crypto_tfm itself. As it stands this is a no-op since nobody uses exit functions at all. However, all cases where a lower-level type is instantiated as a different upper-level type (such as blkcipher as ablkcipher) will be converted such that they allocate the underlying transform and use that instead of casting (e.g., crypto_ablkcipher casted into crypto_blkcipher). That will need to use a different exit function depending on the upper-level type. This patch also allows the type init/exit functions to call (or not) cra_init/cra_exit instead of always calling them from the top level. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: ansi_cprng - Allow resetting of DT valueNeil Horman
This is a patch that was sent to me by Jarod Wilson, marking off my outstanding todo to allow the ansi cprng to set/reset the DT counter value in a cprng instance. Currently crytpo_rng_reset accepts a seed byte array which is interpreted by the ansi_cprng as a {V key} tuple. This patch extends that tuple to now be {V key DT}, with DT an optional value during reset. This patch also fixes a bug we noticed in which the offset of the key area of the seed is started at DEFAULT_PRNG_KSZ rather than DEFAULT_BLK_SZ as it should be. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: camellia - use kernel-provided bitops, unaligned accessHarvey Harrison
Remove the private implementation of 32-bit rotation and unaligned access with byteswapping. As a bonus, fixes sparse warnings: crypto/camellia.c:602:2: warning: cast to restricted __be32 crypto/camellia.c:603:2: warning: cast to restricted __be32 crypto/camellia.c:604:2: warning: cast to restricted __be32 crypto/camellia.c:605:2: warning: cast to restricted __be32 crypto/camellia.c:710:2: warning: cast to restricted __be32 crypto/camellia.c:711:2: warning: cast to restricted __be32 crypto/camellia.c:712:2: warning: cast to restricted __be32 crypto/camellia.c:713:2: warning: cast to restricted __be32 crypto/camellia.c:714:2: warning: cast to restricted __be32 crypto/camellia.c:715:2: warning: cast to restricted __be32 crypto/camellia.c:716:2: warning: cast to restricted __be32 crypto/camellia.c:717:2: warning: cast to restricted __be32 [Thanks to Tomoyuki Okazaki for spotting the typo] Tested-by: Carlo E. Prelz <fluido@fluido.as> Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-25crypto: testmgr - Trigger a panic when self test fails in FIPS modeNeil Horman
The FIPS specification requires that should self test for any supported crypto algorithm fail during operation in fips mode, we need to prevent the use of any crypto functionality until such time as the system can be re-initialized. Seems like the best way to handle that would be to panic the system if we were in fips mode and failed a self test. This patch implements that functionality. I've built and run it successfully. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-18Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: async_xor: dma_map destination DMA_BIDIRECTIONAL dmaengine: protect 'id' from concurrent registrations ioat: wait for self-test completion
2008-12-10crypto: api - Disallow cryptomgr as a module if algorithms are built-inHerbert Xu
If we have at least one algorithm built-in then it no longer makes sense to have the testing framework, and hence cryptomgr to be a module. It should be either on or off, i.e., built-in or disabled. This just happens to stop a potential runaway modprobe loop that seems to trigger on at least one distro. With fixes from Evgeniy Polyakov. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-12-08async_xor: dma_map destination DMA_BIDIRECTIONALDan Williams
Mapping the destination multiple times is a misuse of the dma-api. Since the destination may be reused as a source, ensure that it is only mapped once and that it is mapped bidirectionally. This appears to add ugliness on the unmap side in that it always reads back the destination address from the descriptor, but gcc can determine that dma_unmap is a nop and not emit the code that calculates its arguments. Cc: <stable@kernel.org> Cc: Saeed Bishara <saeed@marvell.com> Acked-by: Yuri Tikhonov <yur@emcraft.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2008-10-20Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: fsldma: allow Freescale Elo DMA driver to be compiled as a module fsldma: remove internal self-test from Freescale Elo DMA driver drivers/dma/dmatest.c: switch a GFP_ATOMIC to GFP_KERNEL dmatest: properly handle duplicate DMA channels drivers/dma/ioat_dma.c: drop code after return async_tx: make async_tx_run_dependencies() easier to read
2008-10-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: skcipher - Use RNG interface instead of get_random_bytes crypto: rng - RNG interface and implementation crypto: api - Add fips_enable flag crypto: skcipher - Move IV generators into their own modules crypto: cryptomgr - Test ciphers using ECB crypto: api - Use test infrastructure crypto: cryptomgr - Add test infrastructure crypto: tcrypt - Add alg_test interface crypto: tcrypt - Abort and only log if there is an error crypto: crc32c - Use Intel CRC32 instruction crypto: tcrypt - Avoid using contiguous pages crypto: api - Display larval objects properly crypto: api - Export crypto_alg_lookup instead of __crypto_alg_lookup crypto: Kconfig - Replace leading spaces with tabs
2008-09-13async_tx: make async_tx_run_dependencies() easier to readDan Williams
* Rename 'next' to 'dep' * Move the channel switch check inside the loop to simplify termination Acked-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2008-09-08Revert "crypto: camellia - Use kernel-provided bitops, unaligned access helpers"Herbert Xu
This reverts commit bd699f2df6dbc2f4cba528fe598bd63a4d3702c5, which causes camellia to fail the included self-test vectors. It has also been confirmed that it breaks existing encrypted disks using camellia. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-09-05async_tx: fix the bug in async_tx_run_dependenciesYuri Tikhonov
Should clear the next pointer of the TX if we are sure that the next TX (say NXT) will be submitted to the channel too. Overwise, we break the chain of descriptors, because we lose the information about the next descriptor to run. So next time, when invoke async_tx_run_dependencies() with TX, it's TX->next will be NULL, and NXT will be never submitted. Cc: <stable@kernel.org> [2.6.26] Signed-off-by: Yuri Tikhonov <yur@emcraft.com> Signed-off-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2008-08-29crypto: skcipher - Use RNG interface instead of get_random_bytesHerbert Xu
This patch makes the IV generators use the new RNG interface so that the user can pick an RNG other than the default get_random_bytes. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: rng - RNG interface and implementationNeil Horman
This patch adds a random number generator interface as well as a cryptographic pseudo-random number generator based on AES. It is meant to be used in cases where a deterministic CPRNG is required. One of the first applications will be as an input in the IPsec IV generation process. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: api - Add fips_enable flagNeil Horman
Add the ability to turn FIPS-compliant mode on or off at boot In order to be FIPS compliant, several check may need to be preformed that may be construed as unusefull in a non-compliant mode. This patch allows us to set a kernel flag incating that we are running in a fips-compliant mode from boot up. It also exports that mode information to user space via a sysctl (/proc/sys/crypto/fips_enabled). Tested successfully by me. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2008-08-29crypto: skcipher - Move IV generators into their own modulesHerbert Xu
This patch moves the default IV generators into their own modules in order to break a dependency loop between cryptomgr, rng, and blkcipher. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
