This patch adds the af_alg plugin for hash, corresponding to
the ahash kernel operation type.
Keys can optionally be set through the setsockopt interface.
Each sendmsg call will finalise the hash unless sent with a MSG_MORE
flag.
Partial hash states can be cloned using accept(2).
The interface is completely synchronous, all operations will
complete prior to the system call returning.
Both sendmsg(2) and splice(2) support reading the user-space
data directly without copying (except that the Crypto API itself
may copy the data if alignment is off).
For now only the splice(2) interface supports performing digest
instead of init/update/final. In future the sendmsg(2) interface
will also be modified to use digest/finup where possible so that
hardware that cannot return a partial hash state can still benefit
from this interface.
Thakns to Miloslav Trmac for reviewing this and contributing
fixes and improvements.
Tested-by: Martin Willi <martin@strongswan.org>
This patch creates the backbone of the user-space interface for
the Crypto API, through a new socket family AF_ALG.
Each session corresponds to one or more connections obtained from
that socket. The number depends on the number of inputs/outputs
of that particular type of operation. For most types there will
be a s ingle connection/file descriptor that is used for both input
and output. AEAD is one of the few that require two inputs.
Each algorithm type will provide its own implementation that plugs
into af_alg. They're keyed using a string such as "skcipher" or
"hash".
IOW this patch only contains the boring bits that is required
to hold everything together.
Updated RFC4106 AES-GCM testing. Some test vectors were taken from
http://csrc.nist.gov/groups/ST/toolkit/BCM/documents/proposedmodes/
gcm/gcm-test-vectors.tar.gz
Signed-off-by: Adrian Hoban <adrian.hoban@intel.com>
Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com>
Signed-off-by: Gabriele Paoloni <gabriele.paoloni@intel.com>
Signed-off-by: Aidan O'Mahony <aidan.o.mahony@intel.com>
I noticed that by factoring out common rounds from the
branches of the if-statements in the encryption and
decryption functions, the executable file size goes down
significantly, for crypto/cast5.ko from 26688 bytes
to 24336 bytes (amd64).
On my test system, I saw a slight speedup. This is the
first time I'm doing such a benchmark - I found a similar
one on the crypto mailing list, and I hope I did it right?
Before:
# cryptsetup create dm-test /dev/hda2 -c cast5-cbc-plain -s 128
Passsatz eingeben:
# dd if=/dev/zero of=/dev/mapper/dm-test bs=1M count=50
52428800 Bytes (52 MB) kopiert, 2,43484 s, 21,5 MB/s
52428800 Bytes (52 MB) kopiert, 2,4089 s, 21,8 MB/s
52428800 Bytes (52 MB) kopiert, 2,41091 s, 21,7 MB/s
After:
Passsatz eingeben:
52428800 Bytes (52 MB) kopiert, 2,38128 s, 22,0 MB/s
52428800 Bytes (52 MB) kopiert, 2,29486 s, 22,8 MB/s
52428800 Bytes (52 MB) kopiert, 2,37162 s, 22,1 MB/s
Signed-off-by: Nicolas Kaiser <nikai@nikai.net>
kobject_put is called from padata_free for the padata kobject.
The kobject's release function frees the padata instance,
so don't call kobject_put for the padata kobject from pcrypt.
Reported-and-tested-by: Randy Dunlap <randy.dunlap@oracle.com>
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
The function shash_async_import did not initialise the descriptor
correctly prior to calling the underlying shash import function.
This patch adds the required initialisation.
Reported-by: Miloslav Trmac <mitr@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: (48 commits)
DMAENGINE: move COH901318 to arch_initcall
dma: imx-dma: fix signedness bug
dma/timberdale: simplify conditional
ste_dma40: remove channel_type
ste_dma40: remove enum for endianess
ste_dma40: remove TIM_FOR_LINK option
ste_dma40: move mode_opt to separate config
ste_dma40: move channel mode to a separate field
ste_dma40: move priority to separate field
ste_dma40: add variable to indicate valid dma_cfg
async_tx: make async_tx channel switching opt-in
move async raid6 test to lib/Kconfig.debug
dmaengine: Add Freescale i.MX1/21/27 DMA driver
intel_mid_dma: change the slave interface
intel_mid_dma: fix the WARN_ONs
intel_mid_dma: Add sg list support to DMA driver
intel_mid_dma: Allow DMAC2 to share interrupt
intel_mid_dma: Allow IRQ sharing
intel_mid_dma: Add runtime PM support
DMAENGINE: define a dummy filter function for ste_dma40
Ensure kmap_atomic() usage is strictly nested
Acked-by: Chris Metcalf <cmetcalf@tilera.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6:
crypto: Makefile - replace the use of <module>-objs with <module>-y
crypto: hifn_795x - use cancel_delayed_work_sync()
crypto: talitos - sparse check endian fixes
crypto: talitos - fix checkpatch warning
crypto: talitos - fix warning: 'alg' may be used uninitialized in this function
crypto: cryptd - Adding the AEAD interface type support to cryptd
crypto: n2_crypto - Niagara2 driver needs to depend upon CRYPTO_DES
crypto: Kconfig - update broken web addresses
crypto: omap-sham - Adjust DMA parameters
crypto: fips - FIPS requires algorithm self-tests
crypto: omap-aes - OMAP2/3 AES hw accelerator driver
crypto: updates to enable omap aes
padata: add missing __percpu markup in include/linux/padata.h
MAINTAINERS: Add maintainer entries for padata/pcrypt
The prompt for "Self test for hardware accelerated raid6 recovery" does not
belong in the top level configuration menu. All the options in
crypto/async_tx/Kconfig are selected and do not depend on CRYPTO.
Kconfig.debug seems like a reasonable fit.
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: David Woodhouse <David.Woodhouse@intel.com>
Rename the PC2() symbol in the generic DES crypto module to be prefixed with
DES_ to avoid collision with arch code (Blackfin in this case).
This patch adds AEAD support into the cryptd framework. Having AEAD
support in cryptd enables crypto drivers that use the AEAD
interface type (such as the patch for AEAD based RFC4106 AES-GCM
implementation using Intel New Instructions) to leverage cryptd for
asynchronous processing.
Below is a patch to update the broken web addresses, in crypto/*
that I could locate. Some are just simple typos that needed to be
fixed, and some had a change in location altogether..
let me know if any of them need to be changed and such.
Revert "hwrng: n2-drv - remove casts from void*"
crypto: testmgr - Default to no tests
crypto: testmgr - Fix test disabling option
crypto: hash - Fix handling of small unaligned buffers
Signed-off-by: Chuck Ebbert <cebbert@redhat.com>
drivers/md/Makefile
lib/raid6/unroll.pl
On Thu, Aug 05, 2010 at 07:01:21PM -0700, Linus Torvalds wrote:
> On Thu, Aug 5, 2010 at 6:40 PM, Herbert Xu <herbert@gondor.hengli.com.au> wrote:
> > -config CRYPTO_MANAGER_TESTS
> > - bool "Run algolithms' self-tests"
> > - default y
> > - depends on CRYPTO_MANAGER2
> > +config CRYPTO_MANAGER_DISABLE_TESTS
> > + bool "Disable run-time self tests"
> > + depends on CRYPTO_MANAGER2 && EMBEDDED
> Why do you still want to force-enable those tests? I was going to
> complain about the "default y" anyway, now I'm _really_ complaining,
> because you've now made it impossible to disable those tests. Why?
As requested, this patch sets the default to y and removes the
EMBEDDED dependency.
This patch fixes a serious bug in the test disabling patch where
it can cause an spurious load of the cryptomgr module even when
it's compiled in.
It also negates the test disabling option so that its absence
causes tests to be enabled.
The Kconfig option is also now behind EMBEDDED.
If a scatterwalk chain contains an entry with an unaligned offset then
hash_walk_next() will cut off the next step at the next alignment point.
However, if the entry ends before the next alignment point then we a loop,
which leads to a kernel oops.
Fix this by checking whether the next aligment point is before the end of the
current entry.
Signed-off-by: Szilveszter Ördög <slipszi@gmail.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (39 commits)
random: Reorder struct entropy_store to remove padding on 64bits
padata: update API documentation
padata: Remove padata_get_cpumask
crypto: pcrypt - Update pcrypt cpumask according to the padata cpumask notifier
crypto: pcrypt - Rename pcrypt_instance
padata: Pass the padata cpumasks to the cpumask_change_notifier chain
padata: Rearrange set_cpumask functions
padata: Rename padata_alloc functions
crypto: pcrypt - Dont calulate a callback cpu on empty callback cpumask
padata: Check for valid cpumasks
padata: Allocate cpumask dependend recources in any case
padata: Fix cpu index counting
crypto: geode_aes - Convert pci_table entries to PCI_VDEVICE (if PCI_ANY_ID is used)
pcrypt: Added sysfs interface to pcrypt
padata: Added sysfs primitives to padata subsystem
padata: Make two separate cpumasks
padata: update documentation
padata: simplify serialization mechanism
padata: make padata_do_parallel to return zero on success
padata: Handle empty padata cpumasks
The padata cpumask change notifier passes a padata_cpumask to the
notifier chain. So we use this cpumask instead of asking padata for
the cpumask.
In the crypto-layer an instance refers usually to a crypto instance.
The struct pcrypt_instance is not related to a crypto instance.
It rather contains the padata informations, so we rename it to
padata_pcrypt. The functions that handle this struct are renamed
accordingly.
We rename padata_alloc to padata_alloc_possible because this
function allocates a padata_instance and uses the cpu_possible
mask for parallel and serial workers. Also we rename __padata_alloc
to padata_alloc to avoid to export underlined functions. Underlined
functions are considered to be private to padata. Users are updated
accordingly.
If the callback cpumask is empty, we crash with a division by zero
when we try to calculate a callback cpu. So we don't update the callback
cpu in pcrypt_do_parallel if the callback cpumask is empty.
Added sysfs interface to pcrypt. Now pcrypt subsystem creates two
sysfs directories with corresponding padata sysfs objects:
/sys/kernel/pcrypt/[pencrypt|pdecrypt]
Signed-off-by: Dan Kruchinin <dkruchinin@acm.org>
The aim of this patch is to make two separate cpumasks
for padata parallel and serial workers respectively.
It allows user to make more thin and sophisticated configurations
of padata framework. For example user may bind parallel and serial workers to non-intersecting
CPU groups to gain better performance. Also each padata instance has notifiers chain for its
cpumasks now. If either parallel or serial or both masks were changed all
interested subsystems will get notification about that. It's especially useful
if padata user uses algorithm for callback CPU selection according to serial cpumask.
To return -EINPROGRESS on success in padata_do_parallel was
considered to be odd. This patch changes this to return zero
on success. Also the only user of padata, pcrypt is adapted to
convert a return of zero to -EINPROGRESS within the crypto layer.
This also removes the pcrypt fallback if padata_do_parallel
was called on a not running padata instance as we can't handle it
anymore. This fallback was unused, so it's save to remove it.
This patch introduces the PADATA_INVALID flag which is
checked on padata start. This will be used to mark a padata
instance as invalid, if the padata cpumask does not intersect
with the active cpumask. we change padata_start to return an
error if the PADATA_INVALID is set. Also we adapt the only
padata user, pcrypt to this change.
Stanse found a potential NULL dereference in ablkcipher_next_slow.
Even though kmalloc fails, its retval is dereferenced later. Return
from that function properly earlier.
This fixes the broken autoloading of the corresponding twofish assembler
ciphers on x86 and x86_64 if they are available. The module name of the
generic implementation was in conflict with the alias in the assembler
modules. The generic twofish c implementation is renamed to
twofish_generic according to the other algorithms with assembler
implementations and an module alias is added for 'twofish'. You can now
load 'twofish' giving you the best implementation by priority,
'twofish-generic' to get the c implementation or 'twofish-asm' to get
the assembler version of cipher.
Signed-off-by: Joachim Fritschi <jfritschi@freenet.de>
By default, CONFIG_CRYPTO_MANAGER_TESTS will be enabled and thus
self-tests will still run, but it is now possible to disable them
to gain some time during bootup.
Signed-off-by: Alexander Shishkin <virtuoso@slind.org>
The PCOMP Kconfig entry current allows the following combination
which is illegal:
ZLIB=y
PCOMP=y
ALGAPI=m
ALGAPI2=y
MANAGER=m
MANAGER2=m
This patch fixes this by adding PCOMP2 so that PCOMP can select
ALGAPI to propagate the setting to MANAGER2.
Use ERR_CAST(x) rather than ERR_PTR(PTR_ERR(x)). The former makes more
clear what is the purpose of the operation, which otherwise looks like a
no-op.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
type T;
T x;
identifier f;
T f (...) { <+...
- ERR_PTR(PTR_ERR(x))
+ x
expression x;
+ ERR_CAST(x)
// </smpl>
DMAENGINE: extend the control command to include an arg
async_tx: trim dma_async_tx_descriptor in 'no channel switch' case
DMAENGINE: DMA40 fix for allocation of logical channel 0
DMAENGINE: DMA40 support paused channel status
dmaengine: mpc512x: Use resource_size
DMA ENGINE: Do not reset 'private' of channel
ioat: Remove duplicated devm_kzalloc() calls for ioatdma_device
ioat3: disable cacheline-unaligned transfers for raid operations
ioat2,3: convert to producer/consumer locking
ioat: convert to circ_buf
DMAENGINE: Support for ST-Ericssons DMA40 block v3
async_tx: use of kzalloc/kfree requires the include of slab.h
dmaengine: provide helper for setting txstate
DMAENGINE: generic channel status v2
DMAENGINE: generic slave control v2
dma: timb-dma: Update comment and fix compiler warning
dma: Add timb-dma
DMAENGINE: COH 901 318 fix bytesleft
DMAENGINE: COH 901 318 rename confusing vars
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (46 commits)
random: simplify fips mode
crypto: authenc - Fix cryptlen calculation
crypto: talitos - add support for sha224
crypto: talitos - add hash algorithms
crypto: talitos - second prepare step for adding ahash algorithms
crypto: talitos - prepare for adding ahash algorithms
crypto: n2 - Add Niagara2 crypto driver
crypto: skcipher - Add ablkcipher_walk interfaces
crypto: testmgr - Add testing for async hashing and update/final
crypto: tcrypt - Add speed tests for async hashing
crypto: scatterwalk - Fix scatterwalk_done() test
crypto: hifn_795x - Rename ablkcipher_walk to hifn_cipher_walk
padata: Use get_online_cpus/put_online_cpus in padata_free
padata: Add some code comments
padata: Flush the padata queues actively
padata: Use a timer to handle remaining objects in the reorder queues
crypto: shash - Remove usage of CRYPTO_MINALIGN
crypto: mv_cesa - Use resource_size
crypto: omap - OMAP macros corrected
Fix up conflicts in arch/arm/mach-omap2/devices.c
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (44 commits)
vlynq: make whole Kconfig-menu dependant on architecture
add descriptive comment for TIF_MEMDIE task flag declaration.
EEPROM: max6875: Header file cleanup
EEPROM: 93cx6: Header file cleanup
EEPROM: Header file cleanup
agp: use NULL instead of 0 when pointer is needed
rtc-v3020: make bitfield unsigned
PCI: make bitfield unsigned
jbd2: use NULL instead of 0 when pointer is needed
cciss: fix shadows sparse warning
doc: inode uses a mutex instead of a semaphore.
uml: i386: Avoid redefinition of NR_syscalls
fix "seperate" typos in comments
cocbalt_lcdfb: correct sections
doc: Change urls for sparse
Powerpc: wii: Fix typo in comment
i2o: cleanup some exit paths
Documentation/: it's -> its where appropriate
UML: Fix compiler warning due to missing task_struct declaration
UML: add kernel.h include to signal.c
This patch (applied against 2.6.34) fixes the calculation of the
length of the ABLKCIPHER decrypt request ("cryptlen") after an
asynchronous hash request has been completed in the AUTHENC interface.
Signed-off-by: Shikhar Khattar <shikhark@gmail.com>
These are akin to the blkcipher_walk helpers.
The main differences in the async variant are:
1) Only physical walking is supported. We can't hold on to
kmap mappings across the async operation to support virtual
ablkcipher_walk operations anyways.
2) Bounce buffers used for async more need to be persistent and
freed at a later point in time when the async op completes.
Therefore we maintain a list of writeback buffers and require
that the ablkcipher_walk user call the 'complete' operation
so we can copy the bounce buffers out to the real buffers and
free up the bounce buffer chunks.
These interfaces will be used by the new Niagara2 crypto driver.
Extend testmgr such that it tests async hash algorithms,
and that for both sync and async hashes it tests both
->digest() and ->update()/->final() sequences.
These are invoked in the 'mode' range of 400 to 499.
The cost of async vs. sync for the software algorithm implementations
varies. It can be as low as 16 cycles but as much as a couple hundred.
Here two runs of md5 testing, async then sync:
testing speed of async md5
test 0 ( 16 byte blocks, 16 bytes per update, 1 updates): 2448 cycles/operation, 153 cycles/byte
test 1 ( 64 byte blocks, 16 bytes per update, 4 updates): 4992 cycles/operation, 78 cycles/byte
test 2 ( 64 byte blocks, 64 bytes per update, 1 updates): 3808 cycles/operation, 59 cycles/byte
test 3 ( 256 byte blocks, 16 bytes per update, 16 updates): 14000 cycles/operation, 54 cycles/byte
test 4 ( 256 byte blocks, 64 bytes per update, 4 updates): 8480 cycles/operation, 33 cycles/byte
test 5 ( 256 byte blocks, 256 bytes per update, 1 updates): 7280 cycles/operation, 28 cycles/byte
test 6 ( 1024 byte blocks, 16 bytes per update, 64 updates): 50016 cycles/operation, 48 cycles/byte
test 7 ( 1024 byte blocks, 256 bytes per update, 4 updates): 22496 cycles/operation, 21 cycles/byte
test 8 ( 1024 byte blocks, 1024 bytes per update, 1 updates): 21232 cycles/operation, 20 cycles/byte
test 9 ( 2048 byte blocks, 16 bytes per update, 128 updates): 117184 cycles/operation, 57 cycles/byte
test 10 ( 2048 byte blocks, 256 bytes per update, 8 updates): 43008 cycles/operation, 21 cycles/byte
test 11 ( 2048 byte blocks, 1024 bytes per update, 2 updates): 40176 cycles/operation, 19 cycles/byte
test 12 ( 2048 byte blocks, 2048 bytes per update, 1 updates): 39888 cycles/operation, 19 cycles/byte
test 13 ( 4096 byte blocks, 16 bytes per update, 256 updates): 194176 cycles/operation, 47 cycles/byte
test 14 ( 4096 byte blocks, 256 bytes per update, 16 updates): 84096 cycles/operation, 20 cycles/byte
test 15 ( 4096 byte blocks, 1024 bytes per update, 4 updates): 78336 cycles/operation, 19 cycles/byte
test 16 ( 4096 byte blocks, 4096 bytes per update, 1 updates): 77120 cycles/operation, 18 cycles/byte
test 17 ( 8192 byte blocks, 16 bytes per update, 512 updates): 403056 cycles/operation, 49 cycles/byte
test 18 ( 8192 byte blocks, 256 bytes per update, 32 updates): 166112 cycles/operation, 20 cycles/byte
test 19 ( 8192 byte blocks, 1024 bytes per update, 8 updates): 154768 cycles/operation, 18 cycles/byte
test 20 ( 8192 byte blocks, 4096 bytes per update, 2 updates): 151904 cycles/operation, 18 cycles/byte
test 21 ( 8192 byte blocks, 8192 bytes per update, 1 updates): 155456 cycles/operation, 18 cycles/byte
testing speed of md5
test 0 ( 16 byte blocks, 16 bytes per update, 1 updates): 2208 cycles/operation, 138 cycles/byte
test 1 ( 64 byte blocks, 16 bytes per update, 4 updates): 5008 cycles/operation, 78 cycles/byte
test 2 ( 64 byte blocks, 64 bytes per update, 1 updates): 3600 cycles/operation, 56 cycles/byte
test 3 ( 256 byte blocks, 16 bytes per update, 16 updates): 14080 cycles/operation, 55 cycles/byte
test 4 ( 256 byte blocks, 64 bytes per update, 4 updates): 8560 cycles/operation, 33 cycles/byte
test 5 ( 256 byte blocks, 256 bytes per update, 1 updates): 7040 cycles/operation, 27 cycles/byte
test 6 ( 1024 byte blocks, 16 bytes per update, 64 updates): 50592 cycles/operation, 49 cycles/byte
test 7 ( 1024 byte blocks, 256 bytes per update, 4 updates): 22736 cycles/operation, 22 cycles/byte
test 8 ( 1024 byte blocks, 1024 bytes per update, 1 updates): 24960 cycles/operation, 24 cycles/byte
test 9 ( 2048 byte blocks, 16 bytes per update, 128 updates): 99312 cycles/operation, 48 cycles/byte
test 10 ( 2048 byte blocks, 256 bytes per update, 8 updates): 43520 cycles/operation, 21 cycles/byte
test 11 ( 2048 byte blocks, 1024 bytes per update, 2 updates): 40704 cycles/operation, 19 cycles/byte
test 12 ( 2048 byte blocks, 2048 bytes per update, 1 updates): 39552 cycles/operation, 19 cycles/byte
test 13 ( 4096 byte blocks, 16 bytes per update, 256 updates): 196720 cycles/operation, 48 cycles/byte
test 14 ( 4096 byte blocks, 256 bytes per update, 16 updates): 85152 cycles/operation, 20 cycles/byte
test 15 ( 4096 byte blocks, 1024 bytes per update, 4 updates): 79408 cycles/operation, 19 cycles/byte
test 16 ( 4096 byte blocks, 4096 bytes per update, 1 updates): 76816 cycles/operation, 18 cycles/byte
test 17 ( 8192 byte blocks, 16 bytes per update, 512 updates): 391520 cycles/operation, 47 cycles/byte
test 18 ( 8192 byte blocks, 256 bytes per update, 32 updates): 168464 cycles/operation, 20 cycles/byte
test 19 ( 8192 byte blocks, 1024 bytes per update, 8 updates): 156912 cycles/operation, 19 cycles/byte
test 20 ( 8192 byte blocks, 4096 bytes per update, 2 updates): 154016 cycles/operation, 18 cycles/byte
test 21 ( 8192 byte blocks, 8192 bytes per update, 1 updates): 153856 cycles/operation, 18 cycles/byte
We can ditch the sync hash code at some point if we feel that makes
sense. For now I've left it there.
We are done with the scattergather entry when the walk offset goes
past sg->offset + sg->length, not when it crosses a page boundary.
There is a similarly queer test in the second half of
scatterwalk_pagedone() that probably needs some scrutiny.
The macro CRYPTO_MINALIGN is not meant to be used directly. This
patch replaces it with crypto_tfm_ctx_alignment.
Saves 24 bytes per descriptor (64-bit) when the channel-switching
capabilities of async_tx are not required.
The raid6 recovery code should immediately drop back to the optimized
synchronous path when a p+q dma resource is not available. Otherwise we
run the non-optimized/multi-pass async code in sync mode.
Verified with raid6test (NDISKS=255)
Applies to kernels >= 2.6.32.
Cc: <stable@kernel.org>
Acked-by: NeilBrown <neilb@suse.de>
Reported-by: H. Peter Anvin <hpa@zytor.com>
We don't check "frontend" consistently in crypto_init_spawn2(). We
check it at the start of the function but then we dereference it
unconditionally in the parameter list when we call crypto_init_spawn().
I looked at the places that call crypto_init_spawn2() and "frontend" is
always a valid pointer so I removed the check for null.
crypto: authenc - Add EINPROGRESS check
When Steffen originally wrote the authenc async hash patch, he
correctly had EINPROGRESS checks in place so that we did not invoke
the original completion handler with it.
Unfortuantely I told him to remove it before the patch was applied.
As only MAY_BACKLOG request completion handlers are required to
handle EINPROGRESS completions, those checks are really needed.
This patch restores them.
Reported-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc>
