Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
(cherry picked from commit 50496a1fab6c6a90b77da4b247321a88e632bd46)
(cherry picked from commit 6238cbaec429c98d1a280014839c934107c7c8f6)
(cherry picked from commit f4d663ce6357e533f107ce3789bd8848c94bea81)
(cherry picked from commit 6c5a86f529a9e9ca4c9aca5fa477e9557d4a3d3d)
We add a report function pointer to struct crypto_type. This function
pointer is used from the crypto userspace configuration API to report
crypto algorithms to userspace.
(cherry picked from commit b6aa63c09ba3b150a1030f9c95c7647361e7910e)
The upcomming crypto usrerspace configuration api needs
to remove the spawns on top on an algorithm, so export
crypto_remove_spawns.
(cherry picked from commit 89b596ba22d79dd5616616a9975192e1c2bea0fe)
This patch adds a basic userspace configuration API for the crypto layer.
With this it is possible to instantiate, remove and to show crypto
algorithms from userspace.
(cherry picked from commit a38f7907b926e4c6c7d389ad96cc38cec2e5a9e9)
Patch adds support for NIST recommended block cipher mode CMAC to CryptoAPI.
This work is based on Tom St Denis' earlier patch,
http://marc.info/?l=linux-crypto-vger&m=135877306305466&w=2
Cc: Tom St Denis <tstdenis@elliptictech.com>
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi>
(cherry picked from commit 93b5e86a6d13c5dec18c6611933fb38d7d80f0d2)
This reverts commit 2afef0391f30a2831f8beed6a89351682c8a81f6.
Change-Id: Ieef8fd28ba78334a4a0a1b7c64ba6fd4d0f4cb05
Reviewed-on: http://git-master/r/90082
Reviewed-by: Mallikarjun Kasoju <mkasoju@nvidia.com>
Tested-by: Mallikarjun Kasoju <mkasoju@nvidia.com>
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
commit 51fc6dc8f948047364f7d42a4ed89b416c6cc0a3 upstream.
For rounds 16--79, W[i] only depends on W[i - 2], W[i - 7], W[i - 15] and W[i - 16].
Consequently, keeping all W[80] array on stack is unnecessary,
only 16 values are really needed.
Using W[16] instead of W[80] greatly reduces stack usage
(~750 bytes to ~340 bytes on x86_64).
Line by line explanation:
* BLEND_OP
array is "circular" now, all indexes have to be modulo 16.
Round number is positive, so remainder operation should be
without surprises.
* initial full message scheduling is trimmed to first 16 values which
come from data block, the rest is calculated before it's needed.
* original loop body is unrolled version of new SHA512_0_15 and
SHA512_16_79 macros, unrolling was done to not do explicit variable
renaming. Otherwise it's the very same code after preprocessing.
See sha1_transform() code which does the same trick.
Patch survives in-tree crypto test and original bugreport test
(ping flood with hmac(sha512).
See FIPS 180-2 for SHA-512 definition
http://csrc.nist.gov/publications/fips/fips180-2/fips180-2withchangenotice.pdf
Change-Id: I7945bdc928bd3491117ea5e334a0bc5dd6231299
Reviewed-on: http://git-master/r/79657
commit 84e31fdb7c797a7303e0cc295cb9bc8b73fb872d upstream.
commit f9e2bca6c22d75a289a349f869701214d63b5060
aka "crypto: sha512 - Move message schedule W[80] to static percpu area"
created global message schedule area.
If sha512_update will ever be entered twice, hash will be silently
calculated incorrectly.
Probably the easiest way to notice incorrect hashes being calculated is
to run 2 ping floods over AH with hmac(sha512):
#!/usr/sbin/setkey -f
flush;
spdflush;
add IP1 IP2 ah 25 -A hmac-sha512 0x00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000025;
add IP2 IP1 ah 52 -A hmac-sha512 0x00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000052;
spdadd IP1 IP2 any -P out ipsec ah/transport//require;
spdadd IP2 IP1 any -P in ipsec ah/transport//require;
XfrmInStateProtoError will start ticking with -EBADMSG being returned
from ah_input(). This never happens with, say, hmac(sha1).
With patch applied (on BOTH sides), XfrmInStateProtoError does not tick
with multiple bidirectional ping flood streams like it doesn't tick
with SHA-1.
After this patch sha512_transform() will start using ~750 bytes of stack on x86_64.
This is OK for simple loads, for something more heavy, stack reduction will be done
separatedly.
Change-Id: I752dc16e90deb04b35202fddce818ace0b605e9d
Reviewed-on: http://git-master/r/79656
the fix add testcase for testing aes ofb mode.
Signed-off-by: Puneet Saxena <puneets@nvidia.com>
Bug 787628
cherry picked the following commit
http://git.kernel.org/?p=linux/kernel/git/herbert/
cryptodev-2.6.git;a=commit;h=ba0e14acc417eceb895efda1ff46366f4d1728f8
Reviewed-on: http://git-master/r/30339
Reviewed-on: http://git-master/r/54441
(cherry picked from commit b6a86d94028d57884b85179a641a6275d6708c70)
Change-Id: I5bbd3e8a04f0281ff5c22ffcf7522ac3d4a31e30
Reviewed-on: http://git-master/r/68150
Tested-by: Puneet Saxena <puneets@nvidia.com>
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Added ofb(aes) and cmac(aes) tests
Original-Change-Id: Ia79b0f979af88d337e91164f0b8b6d0eba18cd03
Reviewed-on: http://git-master/r/34701
Reviewed-by: Hanumanth Venkateswa Moganty <vmoganty@nvidia.com>
Rebase-Id: R383d7f642cab41350f54367687861615f9484cf3
commit b2bac6acf86d05d8af0499f37d91ecac15722803 upstream.
As cryptd is depeneded on by other algorithms such as aesni-intel,
it needs to be registered before them. When everything is built
as modules, this occurs naturally. However, for this to work when
they are built-in, we need to use subsys_initcall in cryptd.
Tested-by: Josh Boyer <jwboyer@redhat.com>
Cc: Kerin Millar <kerframil@gmail.com>
The ghash_update function passes a pointer to gf128mul_4k_lle which will
be NULL if ghash_setkey is not called or if the most recent call to
ghash_setkey failed to allocate memory. This causes an oops. Fix this
up by returning an error code in the null case.
This is trivially triggered from unprivileged userspace through the
AF_ALG interface by simply writing to the socket without setting a key.
The ghash_final function has a similar issue, but triggering it requires
a memory allocation failure in ghash_setkey _after_ at least one
successful call to ghash_update.
BUG: unable to handle kernel NULL pointer dereference at 00000670
IP: [<d88c92d4>] gf128mul_4k_lle+0x23/0x60 [gf128mul]
*pde = 00000000
Oops: 0000 [#1] PREEMPT SMP
Modules linked in: ghash_generic gf128mul algif_hash af_alg nfs lockd nfs_acl sunrpc bridge ipv6 stp llc
Pid: 1502, comm: hashatron Tainted: G W 3.1.0-rc9-00085-ge9308cf #32 Bochs Bochs
EIP: 0060:[<d88c92d4>] EFLAGS: 00000202 CPU: 0
EIP is at gf128mul_4k_lle+0x23/0x60 [gf128mul]
EAX: d69db1f0 EBX: d6b8ddac ECX: 00000004 EDX: 00000000
ESI: 00000670 EDI: d6b8ddac EBP: d6b8ddc8 ESP: d6b8dda4
DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068
Process hashatron (pid: 1502, ti=d6b8c000 task=d6810000 task.ti=d6b8c000)
Stack:
00000000 d69db1f0 00000163 00000000 d6b8ddc8 c101a520 d69db1f0 d52aa000
00000ff0 d6b8dde8 d88d310f d6b8a3f8 d52aa000 00001000 d88d502c d6b8ddfc
00001000 d6b8ddf4 c11676ed d69db1e8 d6b8de24 c11679ad d52aa000 00000000
Call Trace:
[<c101a520>] ? kmap_atomic_prot+0x37/0xa6
[<d88d310f>] ghash_update+0x85/0xbe [ghash_generic]
[<c11676ed>] crypto_shash_update+0x18/0x1b
[<c11679ad>] shash_ahash_update+0x22/0x36
[<c11679cc>] shash_async_update+0xb/0xd
[<d88ce0ba>] hash_sendpage+0xba/0xf2 [algif_hash]
[<c121b24c>] kernel_sendpage+0x39/0x4e
[<d88ce000>] ? 0xd88cdfff
[<c121b298>] sock_sendpage+0x37/0x3e
[<c121b261>] ? kernel_sendpage+0x4e/0x4e
[<c10b4dbc>] pipe_to_sendpage+0x56/0x61
[<c10b4e1f>] splice_from_pipe_feed+0x58/0xcd
[<c10b4d66>] ? splice_from_pipe_begin+0x10/0x10
[<c10b51f5>] __splice_from_pipe+0x36/0x55
[<c10b6383>] splice_from_pipe+0x51/0x64
[<c10b63c2>] ? default_file_splice_write+0x2c/0x2c
[<c10b63d5>] generic_splice_sendpage+0x13/0x15
[<c10b527f>] do_splice_from+0x5d/0x67
[<c10b6865>] sys_splice+0x2bf/0x363
[<c129373b>] ? sysenter_exit+0xf/0x16
[<c104dc1e>] ? trace_hardirqs_on_caller+0x10e/0x13f
[<c129370c>] sysenter_do_call+0x12/0x32
Code: 83 c4 0c 5b 5e 5f c9 c3 55 b9 04 00 00 00 89 e5 57 8d 7d e4 56 53 8d 5d e4 83 ec 18 89 45 e0 89 55 dc 0f b6 70 0f c1 e6 04 01 d6 <f3> a5 be 0f 00 00 00 4e 89 d8 e8 48 ff ff ff 8b 45 e0 89 da 0f
EIP: [<d88c92d4>] gf128mul_4k_lle+0x23/0x60 [gf128mul] SS:ESP 0068:d6b8dda4
CR2: 0000000000000670
---[ end trace 4eaa2a86a8e2da24 ]---
note: hashatron[1502] exited with preempt_count 1
BUG: scheduling while atomic: hashatron/1502/0x10000002
INFO: lockdep is turned off.
Signed-off-by: Nick Bowler <nbowler@elliptictech.com>
Cc: stable@kernel.org [2.6.37+]
We are going to use this for TCP/IP sequence number and fragment ID
generation.
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
fs: Merge split strings
treewide: fix potentially dangerous trailing ';' in #defined values/expressions
uwb: Fix misspelling of neighbourhood in comment
net, netfilter: Remove redundant goto in ebt_ulog_packet
trivial: don't touch files that are removed in the staging tree
lib/vsprintf: replace link to Draft by final RFC number
doc: Kconfig: `to be' -> `be'
doc: Kconfig: Typo: square -> squared
doc: Konfig: Documentation/power/{pm => apm-acpi}.txt
drivers/net: static should be at beginning of declaration
drivers/media: static should be at beginning of declaration
drivers/i2c: static should be at beginning of declaration
XTENSA: static should be at beginning of declaration
SH: static should be at beginning of declaration
MIPS: static should be at beginning of declaration
ARM: static should be at beginning of declaration
rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check
Update my e-mail address
PCIe ASPM: forcedly -> forcibly
gma500: push through device driver tree
Fix up trivial conflicts:
- arch/arm/mach-ep93xx/dma-m2p.c (deleted)
- drivers/gpio/gpio-ep93xx.c (renamed and context nearby)
- drivers/net/r8169.c (just context changes)
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (34 commits)
crypto: caam - ablkcipher support
crypto: caam - faster aead implementation
crypto: caam - structure renaming
crypto: caam - shorter names
crypto: talitos - don't bad_key in ablkcipher setkey
crypto: talitos - remove unused giv from ablkcipher methods
crypto: talitos - don't set done notification in hot path
crypto: talitos - ensure request ordering within a single tfm
crypto: gf128mul - fix call to memset()
crypto: s390 - support hardware accelerated SHA-224
crypto: algif_hash - Handle initial af_alg_make_sg error correctly
crypto: sha1_generic - use SHA1_BLOCK_SIZE
hwrng: ppc4xx - add support for ppc4xx TRNG
crypto: crypto4xx - Perform read/modify/write on device control register
crypto: caam - fix build warning when DEBUG_FS not configured
crypto: arc4 - Fixed coding style issues
crypto: crc32c - Fixed coding style issue
crypto: omap-sham - do not schedule tasklet if there is no active requests
crypto: omap-sham - clear device flags when finishing request
crypto: omap-sham - irq handler must not clear error code
Also, a comma was inserted to offset a modifier.
Signed-off-by: Michael Witten <mfwitten@gmail.com>
In gf128mul_lle() and gf128mul_bbe() r isn't completely initialized with
zero because the size argument passed to memset() is the size of the
pointer, not the structure it points to.
Luckily there are no in-kernel users of those functions so the ABI
change implied by this fix should break no existing code.
Based on a patch by the PaX Team.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Cc: PaX Team <pageexec@freemail.hu>
When the first call to af_alg_make_sg fails, we may return garbage
instead of the real error. This patch fixes it by setting the error
if "copied" is zero.
Based on a patch by Jesper Juhl.
Reported-by: Jesper Juhl <jj@chaosbits.net>
Modify sha1_update to use SHA1_BLOCK_SIZE.
Signed-off-by: Mandeep Singh Baines <msb@chromium.org>
Fixed coding style issues: unnecessary spaces, parentheses on wrong lines.
Signed-off-by: Mati Vait <mativait@gmail.com>
Removed coding style issue: space before tabs.
CRYPTO_GHASH_CLMUL_NI_INTEL and CRYPTO_AES_NI_INTEL cannot be used
on UML.
Commit 3e02e5cb and 54b6a1b enabled them by accident.
Signed-off-by: Richard Weinberger <richard@nod.at>
FIPS compliance requires a known-answer self-test for all approved
cipher and mode combinations, for all valid key sizes. Presently,
there are only self-tests for xts-aes-128. This adds a 256-bit one,
pulled from the same reference document, which should satisfy the
requirement.
Signed-off-by: Jarod Wilson <jarod@redhat.com>
They are 64K and result in order-4 allocations, even with SLUB.
Therefore, just like we always have for the deflate buffers, use
vmalloc.
Reported-by: Martin Jackson <mjackson220.list@gmail.com>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
Remove linux/mm.h inclusion from netdevice.h -- it's unused (I've checked manually).
To prevent mm.h inclusion via other channels also extract "enum dma_data_direction"
definition into separate header. This tiny piece is what gluing netdevice.h with mm.h
via "netdevice.h => dmaengine.h => dma-mapping.h => scatterlist.h => mm.h".
Removal of mm.h from scatterlist.h was tried and was found not feasible
on most archs, so the link was cutoff earlier.
Hope people are OK with tiny include file.
Note, that mm_types.h is still dragged in, but it is a separate story.
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (45 commits)
crypto: caam - add support for sha512 variants of existing AEAD algorithms
crypto: caam - remove unused authkeylen from caam_ctx
crypto: caam - fix decryption shared vs. non-shared key setting
crypto: caam - platform_bus_type migration
crypto: aesni-intel - fix aesni build on i386
crypto: aesni-intel - Merge with fpu.ko
crypto: mv_cesa - make count_sgs() null-pointer proof
crypto: mv_cesa - copy remaining bytes to SRAM only when needed
crypto: mv_cesa - move digest state initialisation to a better place
crypto: mv_cesa - fill inner/outer IV fields only in HMAC case
crypto: mv_cesa - refactor copy_src_to_buf()
crypto: mv_cesa - no need to save digest state after the last chunk
crypto: mv_cesa - print a warning when registration of AES algos fail
crypto: mv_cesa - drop this call to mv_hash_final from mv_hash_finup
crypto: mv_cesa - the descriptor pointer register needs to be set just once
crypto: mv_cesa - use ablkcipher_request_cast instead of the manual container_of
crypto: caam - fix printk recursion for long error texts
crypto: caam - remove unused keylen from session context
hwrng: amd - enable AMD hw rnd driver for Maple PPC boards
hwrng: amd - manage resource allocation
Loading fpu without aesni-intel does nothing. Loading aesni-intel
without fpu causes modes like xts to fail. (Unloading
aesni-intel will restore those modes.)
One solution would be to make aesni-intel depend on fpu, but it
seems cleaner to just combine the modules.
This is probably responsible for bugs like:
https://bugzilla.redhat.com/show_bug.cgi?id=589390
Signed-off-by: Andy Lutomirski <luto@mit.edu>
Add the CTR mode speed test for AES.
Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com>
Instead of always creating a huge (268K) deflate_workspace with the
maximum compression parameters (windowBits=15, memLevel=8), allow the
caller to obtain a smaller workspace by specifying smaller parameter
values.
For example, when capturing oops and panic reports to a medium with
limited capacity, such as NVRAM, compression may be the only way to
capture the whole report. In this case, a small workspace (24K works
fine) is a win, whether you allocate the workspace when you need it (i.e.,
during an oops or panic) or at boot time.
I've verified that this patch works with all accepted values of windowBits
(positive and negative), memLevel, and compression level.
Signed-off-by: Jim Keniston <jkenisto@us.ibm.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Chris Mason <chris.mason@oracle.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1480 commits)
bonding: enable netpoll without checking link status
xfrm: Refcount destination entry on xfrm_lookup
net: introduce rx_handler results and logic around that
bonding: get rid of IFF_SLAVE_INACTIVE netdev->priv_flag
bonding: wrap slave state work
net: get rid of multiple bond-related netdevice->priv_flags
bonding: register slave pointer for rx_handler
be2net: Bump up the version number
be2net: Copyright notice change. Update to Emulex instead of ServerEngines
e1000e: fix kconfig for crc32 dependency
netfilter ebtables: fix xt_AUDIT to work with ebtables
xen network backend driver
bonding: Improve syslog message at device creation time
bonding: Call netif_carrier_off after register_netdevice
bonding: Incorrect TX queue offset
net_sched: fix ip_tos2prio
xfrm: fix __xfrm_route_forward()
be2net: Fix UDP packet detected status in RX compl
Phonet: fix aligned-mode pipe socket buffer header reserve
netxen: support for GbE port settings
Fix up conflicts in drivers/staging/brcm80211/brcmsmac/wl_mac80211.c
with the staging updates.
ESP with separate encryption/authentication algorithms needs a special
treatment for the associated data. This patch add a new algorithm that
handles esp with extended sequence numbers.
Commit da7f033ddc9fdeb (”crypto: cryptomgr - Add test infrastructure”) added a
const to variable which is later used as target buffer of memcpy.
crypto/tcrypt.c:217:12: warning: passing 'const char (*)[128]' to parameter of type 'void *' discards qualifiers
memset(&iv, 0xff, iv_len);
crypto/tcrypt.c:test_cipher_speed()
- unsigned char *key, iv[128];
+ const char *key, iv[128];
Signed-off-by: David Sterba <dsterba@suse.cz>
In light of the recent discovery of the bug with partial block
processing on s390, we need best test coverage for that. This
patch adds a test vector for SHA1 that should catch such problems.
A self-test failure in fips mode means a panic. Well, gcm(aes)
self-tests currently fail in fips mode, as gcm is dependent on ghash,
which semi-recently got self-test vectors added, but wasn't marked as a
fips_allowed algorithm. Because of gcm's dependence on what is now seen
as a non-fips_allowed algorithm, its self-tests refuse to run.
Previously, ghash got a pass in fips mode, due to the lack of any test
vectors at all, and thus gcm self-tests were able to run. After this
patch, a 'modprobe tcrypt mode=35' no longer panics in fips mode, and
successful self-test of gcm(aes) is reported.
We (Red Hat) are intending to include dm-crypt functionality, using
xts(aes) for disk encryption, as part of an upcoming FIPS-140-2
certification effort, and xts(aes) *is* on the list of possible
mode/cipher combinations that can be certified. To make that possible, we
need to mark xts(aes) as fips_allowed in the crypto subsystem.
A 'modprobe tcrypt mode=10' in fips mode shows xts(aes) self-tests
passing successfully after this change.
Signed-off-by: Davidlohr Bueso <dave@gnu.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (46 commits)
hwrng: via_rng - Fix memory scribbling on some CPUs
crypto: padlock - Move padlock.h into include/crypto
hwrng: via_rng - Fix asm constraints
crypto: n2 - use __devexit not __exit in n2_unregister_algs
crypto: mark crypto workqueues CPU_INTENSIVE
crypto: mv_cesa - dont return PTR_ERR() of wrong pointer
crypto: ripemd - Set module author and update email address
crypto: omap-sham - backlog handling fix
crypto: gf128mul - Remove experimental tag
crypto: af_alg - fix af_alg memory_allocated data type
crypto: aesni-intel - Fixed build with binutils 2.16
crypto: af_alg - Make sure sk_security is initialized on accept()ed sockets
net: Add missing lockdep class names for af_alg
include: Install linux/if_alg.h for user-space crypto API
crypto: omap-aes - checkpatch --file warning fixes
crypto: omap-aes - initialize aes module once per request
crypto: omap-aes - unnecessary code removed
crypto: omap-aes - error handling implementation improved
crypto: omap-aes - redundant locking is removed
crypto: omap-aes - DMA initialization fixes for OMAP off mode
kcrypto_wq and pcrypt->wq's are used to run ciphers and may consume
considerable amount of CPU cycles. Mark both as CPU_INTENSIVE so that
they don't block other work items.
As the workqueues are primarily used to burn CPU cycles, concurrency
levels shouldn't matter much and are left at 1. A higher value may be
beneficial and needs investigation.
Signed-off-by: Adrian-Ken Rueegsegger <ken@codelabs.ch>
This feature no longer needs the experimental tag.
Reported-by: Toralf Förster <toralf.foerster@gmx.de>
Change data type to fix warning:
crypto/af_alg.c:35: warning: initialization from incompatible pointer type
Signed-off-by: Miloslav Trmač <mitr@redhat.com>
Use scatterwalk_crypto_chain in favor of locally defined chaining functions.
