path: root/crypto
2013-11-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix memory leaks and other issues in mwifiex driver, from Amitkumar Karwar. 2) skb_segment() can choke on packets using frag lists, fix from Herbert Xu with help from Eric Dumazet and others. 3) IPv4 output cached route instantiation properly handles races involving two threads trying to install the same route, but we forgot to propagate this logic to input routes as well. Fix from Alexei Starovoitov. 4) Put protections in place to make sure that recvmsg() paths never accidently copy uninitialized memory back into userspace and also make sure that we never try to use more that sockaddr_storage for building the on-kernel-stack copy of a sockaddr. Fixes from Hannes Frederic Sowa. 5) R8152 driver transmit flow bug fixes from Hayes Wang. 6) Fix some minor fallouts from genetlink changes, from Johannes Berg and Michael Opdenacker. 7) AF_PACKET sendmsg path can race with netdevice unregister notifier, fix by using RCU to make sure the network device doesn't go away from under us. Fix from Daniel Borkmann. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (43 commits) gso: handle new frag_list of frags GRO packets genetlink: fix genl_set_err() group ID genetlink: fix genlmsg_multicast() bug packet: fix use after free race in send path when dev is released xen-netback: stop the VIF thread before unbinding IRQs wimax: remove dead code net/phy: Add the autocross feature for forced links on VSC82x4 net/phy: Add VSC8662 support net/phy: Add VSC8574 support net/phy: Add VSC8234 support net: add BUG_ON if kernel advertises msg_namelen > sizeof(struct sockaddr_storage) net: rework recvmsg handler msg_name and msg_namelen logic bridge: flush br's address entry in fdb when remove the net: core: Always propagate flag changes to interfaces ipv4: fix race in concurrent ip_route_input_slow() r8152: fix incorrect type in assignment r8152: support stopping/waking tx queue r8152: modify the tx flow r8152: fix tx/rx memory overflow netfilter: ebt_ip6: fix source and destination matching ...
2013-11-21Merge branch 'for-linus2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "In this patchset, we finally get an SELinux update, with Paul Moore taking over as maintainer of that code. Also a significant update for the Keys subsystem, as well as maintenance updates to Smack, IMA, TPM, and Apparmor" and since I wanted to know more about the updates to key handling, here's the explanation from David Howells on that: "Okay. There are a number of separate bits. I'll go over the big bits and the odd important other bit, most of the smaller bits are just fixes and cleanups. If you want the small bits accounting for, I can do that too. (1) Keyring capacity expansion. KEYS: Consolidate the concept of an 'index key' for key access KEYS: Introduce a search context structure KEYS: Search for auth-key by name rather than target key ID Add a generic associative array implementation. KEYS: Expand the capacity of a keyring Several of the patches are providing an expansion of the capacity of a keyring. Currently, the maximum size of a keyring payload is one page. Subtract a small header and then divide up into pointers, that only gives you ~500 pointers on an x86_64 box. However, since the NFS idmapper uses a keyring to store ID mapping data, that has proven to be insufficient to the cause. Whatever data structure I use to handle the keyring payload, it can only store pointers to keys, not the keys themselves because several keyrings may point to a single key. This precludes inserting, say, and rb_node struct into the key struct for this purpose. I could make an rbtree of records such that each record has an rb_node and a key pointer, but that would use four words of space per key stored in the keyring. It would, however, be able to use much existing code. I selected instead a non-rebalancing radix-tree type approach as that could have a better space-used/key-pointer ratio. I could have used the radix tree implementation that we already have and insert keys into it by their serial numbers, but that means any sort of search must iterate over the whole radix tree. Further, its nodes are a bit on the capacious side for what I want - especially given that key serial numbers are randomly allocated, thus leaving a lot of empty space in the tree. So what I have is an associative array that internally is a radix-tree with 16 pointers per node where the index key is constructed from the key type pointer and the key description. This means that an exact lookup by type+description is very fast as this tells us how to navigate directly to the target key. I made the data structure general in lib/assoc_array.c as far as it is concerned, its index key is just a sequence of bits that leads to a pointer. It's possible that someone else will be able to make use of it also. FS-Cache might, for example. (2) Mark keys as 'trusted' and keyrings as 'trusted only'. KEYS: verify a certificate is signed by a 'trusted' key KEYS: Make the system 'trusted' keyring viewable by userspace KEYS: Add a 'trusted' flag and a 'trusted only' flag KEYS: Separate the kernel signature checking keyring from module signing These patches allow keys carrying asymmetric public keys to be marked as being 'trusted' and allow keyrings to be marked as only permitting the addition or linkage of trusted keys. Keys loaded from hardware during kernel boot or compiled into the kernel during build are marked as being trusted automatically. New keys can be loaded at runtime with add_key(). They are checked against the system keyring contents and if their signatures can be validated with keys that are already marked trusted, then they are marked trusted also and can thus be added into the master keyring. Patches from Mimi Zohar make this usable with the IMA keyrings also. (3) Remove the date checks on the key used to validate a module signature. X.509: Remove certificate date checks It's not reasonable to reject a signature just because the key that it was generated with is no longer valid datewise - especially if the kernel hasn't yet managed to set the system clock when the first module is loaded - so just remove those checks. (4) Make it simpler to deal with additional X.509 being loaded into the kernel. KEYS: Load *.x509 files into kernel keyring KEYS: Have make canonicalise the paths of the X.509 certs better to deduplicate The builder of the kernel now just places files with the extension ".x509" into the kernel source or build trees and they're concatenated by the kernel build and stuffed into the appropriate section. (5) Add support for userspace kerberos to use keyrings. KEYS: Add per-user_namespace registers for persistent per-UID kerberos caches KEYS: Implement a big key type that can save to tmpfs Fedora went to, by default, storing kerberos tickets and tokens in tmpfs. We looked at storing it in keyrings instead as that confers certain advantages such as tickets being automatically deleted after a certain amount of time and the ability for the kernel to get at these tokens more easily. To make this work, two things were needed: (a) A way for the tickets to persist beyond the lifetime of all a user's sessions so that cron-driven processes can still use them. The problem is that a user's session keyrings are deleted when the session that spawned them logs out and the user's user keyring is deleted when the UID is deleted (typically when the last log out happens), so neither of these places is suitable. I've added a system keyring into which a 'persistent' keyring is created for each UID on request. Each time a user requests their persistent keyring, the expiry time on it is set anew. If the user doesn't ask for it for, say, three days, the keyring is automatically expired and garbage collected using the existing gc. All the kerberos tokens it held are then also gc'd. (b) A key type that can hold really big tickets (up to 1MB in size). The problem is that Active Directory can return huge tickets with lots of auxiliary data attached. We don't, however, want to eat up huge tracts of unswappable kernel space for this, so if the ticket is greater than a certain size, we create a swappable shmem file and dump the contents in there and just live with the fact we then have an inode and a dentry overhead. If the ticket is smaller than that, we slap it in a kmalloc()'d buffer" * 'for-linus2' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (121 commits) KEYS: Fix keyring content gc scanner KEYS: Fix error handling in big_key instantiation KEYS: Fix UID check in keyctl_get_persistent() KEYS: The RSA public key algorithm needs to select MPILIB ima: define '_ima' as a builtin 'trusted' keyring ima: extend the measurement list to include the file signature kernel/system_certificate.S: use real contents instead of macro GLOBAL() KEYS: fix error return code in big_key_instantiate() KEYS: Fix keyring quota misaccounting on key replacement and unlink KEYS: Fix a race between negating a key and reading the error set KEYS: Make BIG_KEYS boolean apparmor: remove the "task" arg from may_change_ptraced_domain() apparmor: remove parent task info from audit logging apparmor: remove tsk field from the apparmor_audit_struct apparmor: fix capability to not use the current task, during reporting Smack: Ptrace access check mode ima: provide hash algo info in the xattr ima: enable support for larger default filedata hash algorithms ima: define kernel parameter 'ima_template=' to change configured default ima: add Kconfig default measurement list template ...
2013-11-20net: rework recvmsg handler msg_name and msg_namelen logicHannes Frederic Sowa
This patch now always passes msg->msg_namelen as 0. recvmsg handlers must set msg_namelen to the proper size <= sizeof(struct sockaddr_storage) to return msg_name to the user. This prevents numerous uninitialized memory leaks we had in the recvmsg handlers and makes it harder for new code to accidentally leak uninitialized memory. Optimize for the case recvfrom is called with NULL as address. We don't need to copy the address at all, so set it to NULL before invoking the recvmsg handler. We can do so, because all the recvmsg handlers must cope with the case a plain read() is called on them. read() also sets msg_name to NULL. Also document these changes in include/linux/net.h as suggested by David Miller. Changes since RFC: Set msg->msg_name = NULL if user specified a NULL in msg_name but had a non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't affect sendto as it would bail out earlier while trying to copy-in the address. It also more naturally reflects the logic by the callers of verify_iovec. With this change in place I could remove " if (!uaddr || msg_sys->msg_namelen == 0) msg->msg_name = NULL ". This change does not alter the user visible error logic as we ignore msg_namelen as long as msg_name is NULL. Also remove two unnecessary curly brackets in ___sys_recvmsg and change comments to netdev style. Cc: David Miller <davem@davemloft.net> Suggested-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-20Merge branch 'next' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dmaengine changes from Vinod Koul: "This brings for slave dmaengine: - Change dma notification flag to DMA_COMPLETE from DMA_SUCCESS as dmaengine can only transfer and not verify validaty of dma transfers - Bunch of fixes across drivers: - cppi41 driver fixes from Daniel - 8 channel freescale dma engine support and updated bindings from Hongbo - msx-dma fixes and cleanup by Markus - DMAengine updates from Dan: - Bartlomiej and Dan finalized a rework of the dma address unmap implementation. - In the course of testing 1/ a collection of enhancements to dmatest fell out. Notably basic performance statistics, and fixed / enhanced test control through new module parameters 'run', 'wait', 'noverify', and 'verbose'. Thanks to Andriy and Linus [Walleij] for their review. - Testing the raid related corner cases of 1/ triggered bugs in the recently added 16-source operation support in the ioatdma driver. - Some minor fixes / cleanups to mv_xor and ioatdma" * 'next' of git://git.infradead.org/users/vkoul/slave-dma: (99 commits) dma: mv_xor: Fix mis-usage of mmio 'base' and 'high_base' registers dma: mv_xor: Remove unneeded NULL address check ioat: fix ioat3_irq_reinit ioat: kill msix_single_vector support raid6test: add new corner case for ioatdma driver ioatdma: clean up sed pool kmem_cache ioatdma: fix selection of 16 vs 8 source path ioatdma: fix sed pool selection ioatdma: Fix bug in selftest after removal of DMA_MEMSET. dmatest: verbose mode dmatest: convert to dmaengine_unmap_data dmatest: add a 'wait' parameter dmatest: add basic performance metrics dmatest: add support for skipping verification and random data setup dmatest: use pseudo random numbers dmatest: support xor-only, or pq-only channels in tests dmatest: restore ability to start test at module load and init dmatest: cleanup redundant "dmatest: " prefixes dmatest: replace stored results mechanism, with uniform messages Revert "dmatest: append verify result to results" ...
2013-11-16Merge commit 'dmaengine-3.13-v2' of ↵Vinod Koul
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/dmaengine Pull dmaengine changes from Dan 1/ Bartlomiej and Dan finalized a rework of the dma address unmap implementation. 2/ In the course of testing 1/ a collection of enhancements to dmatest fell out. Notably basic performance statistics, and fixed / enhanced test control through new module parameters 'run', 'wait', 'noverify', and 'verbose'. Thanks to Andriy and Linus for their review. 3/ Testing the raid related corner cases of 1/ triggered bugs in the recently added 16-source operation support in the ioatdma driver. 4/ Some minor fixes / cleanups to mv_xor and ioatdma. Conflicts: drivers/dma/dmatest.c Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-11-15tree-wide: use reinit_completion instead of INIT_COMPLETIONWolfram Sang
Use this new function to make code more comprehensible, since we are reinitialzing the completion, not initializing. [akpm@linux-foundation.org: linux-next resyncs] Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Acked-by: Linus Walleij <linus.walleij@linaro.org> (personally at LCE13) Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-14raid6test: add new corner case for ioatdma driverDan Williams
With 24 disks and an ioatdma instance with 16 source support there is a corner case where the driver needs to be careful to account for the number of implied sources in the continuation case. Also bump the default case to test more than 16 sources now that it triggers different paths in offload drivers. Cc: Dave Jiang <dave.jiang@intel.com> Acked-by: Dave Jiang <dave.jiang@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2013-11-14dmaengine: remove DMA unmap flagsBartlomiej Zolnierkiewicz
Remove no longer needed DMA unmap flags: - DMA_COMPL_SKIP_SRC_UNMAP - DMA_COMPL_SKIP_DEST_UNMAP - DMA_COMPL_SRC_UNMAP_SINGLE - DMA_COMPL_DEST_UNMAP_SINGLE Cc: Vinod Koul <vinod.koul@intel.com> Cc: Tomasz Figa <t.figa@samsung.com> Cc: Dave Jiang <dave.jiang@intel.com> Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Jon Mason <jon.mason@intel.com> Acked-by: Mark Brown <broonie@linaro.org> [djbw: clean up straggling skip unmap flags in ntb] Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2013-11-14async_pq_val: convert to dmaengine_unmap_dataDan Williams
Use the generic unmap object to unmap dma buffers. Cc: Vinod Koul <vinod.koul@intel.com> Cc: Tomasz Figa <t.figa@samsung.com> Cc: Dave Jiang <dave.jiang@intel.com> Reported-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2013-11-14async_pq: convert to dmaengine_unmap_dataDan Williams
Use the generic unmap object to unmap dma buffers. Cc: Vinod Koul <vinod.koul@intel.com> Cc: Tomasz Figa <t.figa@samsung.com> Cc: Dave Jiang <dave.jiang@intel.com> Reported-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> [bzolnier: keep temporary dma_dest array in do_async_gen_syndrome()] Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2013-11-14async_raid6_recov: convert to dmaengine_unmap_dataDan Williams
Use the generic unmap object to unmap dma buffers. Cc: Vinod Koul <vinod.koul@intel.com> Cc: Tomasz Figa <t.figa@samsung.com> Cc: Dave Jiang <dave.jiang@intel.com> Reported-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> [bzolnier: keep temporary dma_dest array in async_mult()] Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2013-11-14async_xor_val: convert to dmaengine_unmap_dataDan Williams
Use the generic unmap object to unmap dma buffers. Cc: Vinod Koul <vinod.koul@intel.com> Cc: Tomasz Figa <t.figa@samsung.com> Cc: Dave Jiang <dave.jiang@intel.com> Reported-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> [bzolnier: minor cleanups] Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2013-11-14async_xor: convert to dmaengine_unmap_dataDan Williams
Use the generic unmap object to unmap dma buffers. Later we can push this unmap object up to the raid layer and get rid of the 'scribble' parameter. Cc: Vinod Koul <vinod.koul@intel.com> Cc: Tomasz Figa <t.figa@samsung.com> Cc: Dave Jiang <dave.jiang@intel.com> Reported-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> [bzolnier: minor cleanups] Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2013-11-14async_memcpy: convert to dmaengine_unmap_dataDan Williams
Use the generic unmap object to unmap dma buffers. Cc: Vinod Koul <vinod.koul@intel.com> Cc: Tomasz Figa <t.figa@samsung.com> Cc: Dave Jiang <dave.jiang@intel.com> Reported-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> [bzolnier: add missing unmap->len initialization] [bzolnier: fix whitespace damage] Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> [djbw: add DMA_ENGINE=n support] Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2013-11-01KEYS: The RSA public key algorithm needs to select MPILIBDavid Howells
The RSA public key algorithm needs to select MPILIB directly in Kconfig as the 'select' directive is not recursive and is thus MPILIB is not enabled by selecting MPILIB_EXTRA. Without this, the following errors can occur: crypto/built-in.o: In function `RSA_verify_signature': rsa.c:(.text+0x1d347): undefined reference to `mpi_get_nbits' rsa.c:(.text+0x1d354): undefined reference to `mpi_get_nbits' rsa.c:(.text+0x1d36e): undefined reference to `mpi_cmp_ui' rsa.c:(.text+0x1d382): undefined reference to `mpi_cmp' rsa.c:(.text+0x1d391): undefined reference to `mpi_alloc' rsa.c:(.text+0x1d3b0): undefined reference to `mpi_powm' rsa.c:(.text+0x1d3c3): undefined reference to `mpi_free' rsa.c:(.text+0x1d3d8): undefined reference to `mpi_get_buffer' rsa.c:(.text+0x1d4d4): undefined reference to `mpi_free' rsa.c:(.text+0x1d503): undefined reference to `mpi_get_nbits' Reported-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Randy Dunlap <rdunlap@infradead.org>
2013-10-25ima: provide support for arbitrary hash algorithmsDmitry Kasatkin
In preparation of supporting more hash algorithms with larger hash sizes needed for signature verification, this patch replaces the 20 byte sized digest, with a more flexible structure. The new structure includes the hash algorithm, digest size, and digest. Changelog: - recalculate filedata hash for the measurement list, if the signature hash digest size is greater than 20 bytes. - use generic HASH_ALGO_ - make ima_calc_file_hash static - scripts lindent and checkpatch fixes Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-10-25keys: change asymmetric keys to use common hash definitionsDmitry Kasatkin
This patch makes use of the newly defined common hash algorithm info, replacing, for example, PKEY_HASH with HASH_ALGO. Changelog: - Lindent fixes - Mimi CC: David Howells <dhowells@redhat.com> Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
2013-10-25crypto: provide single place for hash algo informationDmitry Kasatkin
This patch provides a single place for information about hash algorithms, such as hash sizes and kernel driver names, which will be used by IMA and the public key code. Changelog: - Fix sparse and checkpatch warnings - Move hash algo enums to uapi for userspace signing functions. Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com> Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-10-25async_tx: use DMA_COMPLETE for dma completion statusVinod Koul
Acked-by: Dan Williams <dan.j.williams@intel.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-10-04ARM: add support for bit sliced AES using NEON instructionsArd Biesheuvel
Bit sliced AES gives around 45% speedup on Cortex-A15 for encryption and around 25% for decryption. This implementation of the AES algorithm does not rely on any lookup tables so it is believed to be invulnerable to cache timing attacks. This algorithm processes up to 8 blocks in parallel in constant time. This means that it is not usable by chaining modes that are strictly sequential in nature, such as CBC encryption. CBC decryption, however, can benefit from this implementation and runs about 25% faster. The other chaining modes implemented in this module, XTS and CTR, can execute fully in parallel in both directions. The core code has been adopted from the OpenSSL project (in collaboration with the original author, on cc). For ease of maintenance, this version is identical to the upstream OpenSSL code, i.e., all modifications that were required to make it suitable for inclusion into the kernel have been made upstream. The original can be found here: http://git.openssl.org/gitweb/?p=openssl.git;a=commit;h=6f6a6130 Note to integrators: While this implementation is significantly faster than the existing table based ones (generic or ARM asm), especially in CTR mode, the effects on power efficiency are unclear as of yet. This code does fundamentally more work, by calculating values that the table based code obtains by a simple lookup; only by doing all of that work in a SIMD fashion, it manages to perform better. Cc: Andy Polyakov <appro@openssl.org> Acked-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
2013-09-25X.509: add module description and licenseKonstantin Khlebnikov
This patch fixes lack of license, otherwise x509_key_parser.ko taints kernel. Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Signed-off-by: David Howells <dhowells@redhat.com>
2013-09-25KEYS: verify a certificate is signed by a 'trusted' keyMimi Zohar
Only public keys, with certificates signed by an existing 'trusted' key on the system trusted keyring, should be added to a trusted keyring. This patch adds support for verifying a certificate's signature. This is derived from David Howells pkcs7_request_asymmetric_key() patch. Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com> Signed-off-by: David Howells <dhowells@redhat.com>
2013-09-25KEYS: Set the asymmetric-key type default search methodDavid Howells
The keyring expansion patches introduces a new search method by which key_search() attempts to walk directly to the key that has exactly the same description as the requested one. However, this causes inexact matching of asymmetric keys to fail. The solution to this is to select iterative rather than direct search as the default search type for asymmetric keys. As an example, the kernel might have a key like this: Magrathea: Glacier signing key: 6a2a0f82bad7e396665f465e4e3e1f9bd24b1226 and: keyctl search <keyring-ID> asymmetric id:d24b1226 should find the key, despite that not being its exact description. Signed-off-by: David Howells <dhowells@redhat.com>
2013-09-25X.509: Remove certificate date checksDavid Howells
Remove the certificate date checks that are performed when a certificate is parsed. There are two checks: a valid from and a valid to. The first check is causing a lot of problems with system clocks that don't keep good time and the second places an implicit expiry date upon the kernel when used for module signing, so do we really need them? Signed-off-by: David Howells <dhowells@redhat.com> cc: David Woodhouse <dwmw2@infradead.org> cc: Rusty Russell <rusty@rustcorp.com.au> cc: Josh Boyer <jwboyer@redhat.com> cc: Alexander Holler <holler@ahsoftware.de> cc: stable@vger.kernel.org
2013-09-25X.509: Handle certificates that lack an authorityKeyIdentifier fieldDavid Howells
Handle certificates that lack an authorityKeyIdentifier field by assuming they're self-signed and checking their signatures against themselves. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: Kees Cook <keescook@chromium.org> Reviewed-by: Josh Boyer <jwboyer@redhat.com>
2013-09-25X.509: Check the algorithm IDs obtained from parsing an X.509 certificateDavid Howells
Check that the algorithm IDs obtained from the ASN.1 parse by OID lookup corresponds to algorithms that are available to us. Reported-by: Kees Cook <keescook@chromium.org> Signed-off-by: David Howells <dhowells@redhat.com>
2013-09-25X.509: Embed public_key_signature struct and create filler functionDavid Howells
Embed a public_key_signature struct in struct x509_certificate, eliminating now unnecessary fields, and split x509_check_signature() to create a filler function for it that attaches a digest of the signed data and an MPI that represents the signature data. x509_free_certificate() is then modified to deal with these. Whilst we're at it, export both x509_check_signature() and the new x509_get_sig_params(). Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: Kees Cook <keescook@chromium.org> Reviewed-by: Josh Boyer <jwboyer@redhat.com>
2013-09-25X.509: struct x509_certificate needs struct tm declaringDavid Howells
struct x509_certificate needs struct tm declaring by #inclusion of linux/time.h prior to its definition. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: Kees Cook <keescook@chromium.org> Reviewed-by: Josh Boyer <jwboyer@redhat.com>
2013-09-25KEYS: Split public_key_verify_signature() and make availableDavid Howells
Modify public_key_verify_signature() so that it now takes a public_key struct rather than a key struct and supply a wrapper that takes a key struct. The wrapper is then used by the asymmetric key subtype and the modified function is used by X.509 self-signature checking and can be used by other things also. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: Kees Cook <keescook@chromium.org> Reviewed-by: Josh Boyer <jwboyer@redhat.com>
2013-09-25KEYS: Store public key algo ID in public_key structDavid Howells
Store public key algo ID in public_key struct for reference purposes. This allows it to be removed from the x509_certificate struct and used to find a default in public_key_verify_signature(). Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: Kees Cook <keescook@chromium.org> Reviewed-by: Josh Boyer <jwboyer@redhat.com>
2013-09-25KEYS: Move the algorithm pointer array from x509 to public_key.cDavid Howells
Move the public-key algorithm pointer array from x509_public_key.c to public_key.c as it isn't X.509 specific. Note that to make this configure correctly, the public key part must be dependent on the RSA module rather than the other way round. This needs a further patch to make use of the crypto module loading stuff rather than using a fixed table. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: Kees Cook <keescook@chromium.org> Reviewed-by: Josh Boyer <jwboyer@redhat.com>
2013-09-25KEYS: Rename public key parameter name arraysDavid Howells
Rename the arrays of public key parameters (public key algorithm names, hash algorithm names and ID type names) so that the array name ends in "_name". Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: Kees Cook <keescook@chromium.org> Reviewed-by: Josh Boyer <jwboyer@redhat.com>
2013-09-12crypto: crct10dif - Add fallback for broken initrdsHerbert Xu
Unfortunately, even with a softdep some distros fail to include the necessary modules in the initrd. Therefore this patch adds a fallback path to restore existing behaviour where we cannot load the new crypto crct10dif algorithm. In order to do this, the underlying crct10dif has been split out from the crypto implementation so that it can be used on the fallback path. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-09-08crypto: api - Fix race condition in larval lookupHerbert Xu
crypto_larval_lookup should only return a larval if it created one. Any larval created by another entity must be processed through crypto_larval_wait before being returned. Otherwise this will lead to a larval being killed twice, which will most likely lead to a crash. Cc: stable@vger.kernel.org Reported-by: Kees Cook <keescook@chromium.org> Tested-by: Kees Cook <keescook@chromium.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-09-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto update from Herbert Xu: "Here is the crypto update for 3.12: - Added MODULE_SOFTDEP to allow pre-loading of modules. - Reinstated crct10dif driver using the module softdep feature. - Allow via rng driver to be auto-loaded. - Split large input data when necessary in nx. - Handle zero length messages correctly for GCM/XCBC in nx. - Handle SHA-2 chunks bigger than block size properly in nx. - Handle unaligned lengths in omap-aes. - Added SHA384/SHA512 to omap-sham. - Added OMAP5/AM43XX SHAM support. - Added OMAP4 TRNG support. - Misc fixes" * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (66 commits) Reinstate "crypto: crct10dif - Wrap crc_t10dif function all to use crypto transform framework" hwrng: via - Add MODULE_DEVICE_TABLE crypto: fcrypt - Fix bitoperation for compilation with clang crypto: nx - fix SHA-2 for chunks bigger than block size crypto: nx - fix GCM for zero length messages crypto: nx - fix XCBC for zero length messages crypto: nx - fix limits to sg lists for AES-CCM crypto: nx - fix limits to sg lists for AES-XCBC crypto: nx - fix limits to sg lists for AES-GCM crypto: nx - fix limits to sg lists for AES-CTR crypto: nx - fix limits to sg lists for AES-CBC crypto: nx - fix limits to sg lists for AES-ECB crypto: nx - add offset to nx_build_sg_lists() padata - Register hotcpu notifier after initialization padata - share code between CPU_ONLINE and CPU_DOWN_FAILED, same to CPU_DOWN_PREPARE and CPU_UP_CANCELED hwrng: omap - reorder OMAP TRNG driver code crypto: omap-sham - correct dma burst size crypto: omap-sham - Enable Polling mode if DMA fails crypto: tegra-aes - bitwise vs logical and crypto: sahara - checking the wrong variable ...
2013-09-07Reinstate "crypto: crct10dif - Wrap crc_t10dif function all to use crypto ↵Herbert Xu
transform framework" This patch reinstates commits 67822649d7305caf3dd50ed46c27b99c94eff996 39761214eefc6b070f29402aa1165f24d789b3f7 0b95a7f85718adcbba36407ef88bba0a7379ed03 31d939625a9a20b1badd2d4e6bf6fd39fa523405 2d31e518a42828df7877bca23a958627d60408bc Now that module softdeps are in the kernel we can use that to resolve the boot issue which cause the revert. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-09-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linuxHerbert Xu
Merge upstream tree in order to reinstate crct10dif.
2013-09-02crypto: fcrypt - Fix bitoperation for compilation with clangJan-Simon Möller
v2: Fix bug in statement as pointed out by Herbert Xu. Kudos to pipacs. Author: PaX Team <pageexec at freemail.hu> ML-Post: http://lists.cs.uiuc.edu/pipermail/llvm-commits/Week-of-Mon-20120507/142707.html URL: http://llvm.linuxfoundation.org Merge: Jan-Simon Möller <dl9pf at gmx.de> Description: Fix for warning: linux/crypto/fcrypt.c:143:47: warning: signed shift result (0x598000000) requires 36 bits to represent, but 'int' only has 32 bits [-Wshift-overflow] Z(0xef), Z(0x70), Z(0xcf), Z(0xc2), Z(0x2a), Z(0xb3), Z(0x61), Z(0xad), ^~~~~~~ linux/crypto/fcrypt.c:113:29: note: expanded from macro 'Z' ^ ~~ linux/include/uapi/linux/byteorder/little_endian.h:38:53: note: expanded from macro '__cpu_to_be32' ^ linux/include/uapi/linux/swab.h:116:21: note: expanded from macro '__swab32' ___constant_swab32(x) : \ ^ linux/include/uapi/linux/swab.h:18:12: note: expanded from macro '___constant_swab32' (((__u32)(x) & (__u32)0x0000ff00UL) << 8) | \ ^ Solution - make sure we don't exceed the 32 bit range. #define Z(x) cpu_to_be32(((x & 0x1f) << 27) | (x >> 5)) Signed-off-by: Jan-Simon Möller <dl9pf@gmx.de> CC: pageexec@freemail.hu CC: llvmlinux@lists.linuxfoundation.org CC: behanw@converseincode.com CC: herbert@gondor.apana.org.au CC: davem@davemloft.net CC: linux-crypto@vger.kernel.org CC: linux-kernel@vger.kernel.org Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-08-21crypto: scatterwalk - Add support for calculating number of SG elementsJoel Fernandes
Crypto layer only passes nbytes to encrypt but in omap-aes driver we need to know number of SG elements to pass to dmaengine slave API. We add function for the same to scatterwalk library. Signed-off-by: Joel Fernandes <joelf@ti.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-08-21crypto: camellia_generic - replace commas by semicolons and adjust code ↵Julia Lawall
alignment Adjust alignment and replace commas by semicolons in automatically generated code. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-08-20crypto: fix typo in commentCristian Stoica
Signed-off-by: Cristian Stoica <cristian.stoica@freescale.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-08-14crypto: make tables used from assembler __visibleAndi Kleen
Tables used from assembler should be marked __visible to let the compiler know. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-08-01crypto: testmgr - remove double execution of the same test suiteCristian Stoica
This patch removes redundant execution of the same test suite in cases where alg and driver variables are the same (e.g. when alg_test is called from tcrypt_test) Signed-off-by: Cristian Stoica <cristian.stoica@freescale.com> Reviewed-by: Horia Geanta <horia.geanta@freescale.com> Reviewed-by: Ruchika Gupta <ruchika.gupta@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-07-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto fixes from Herbert Xu: "This push fixes a memory corruption issue in caam, as well as reverting the new optimised crct10dif implementation as it breaks boot on initrd systems. Hopefully crct10dif will be reinstated once the supporting code is added so that it doesn't break boot" * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: Revert "crypto: crct10dif - Wrap crc_t10dif function all to use crypto transform framework" crypto: caam - Fixed the memory out of bound overwrite issue
2013-07-24Revert "crypto: crct10dif - Wrap crc_t10dif function all to use crypto ↵Herbert Xu
transform framework" This reverts commits 67822649d7305caf3dd50ed46c27b99c94eff996 39761214eefc6b070f29402aa1165f24d789b3f7 0b95a7f85718adcbba36407ef88bba0a7379ed03 31d939625a9a20b1badd2d4e6bf6fd39fa523405 2d31e518a42828df7877bca23a958627d60408bc Unfortunately this change broke boot on some systems that used an initrd which does not include the newly created crct10dif modules. As these modules are required by sd_mod under certain configurations this is a serious problem. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-07-09crypto: add lz4 Cryptographic APIChanho Min
Add support for lz4 and lz4hc compression algorithm using the lib/lz4/* codebase. [akpm@linux-foundation.org: fix warnings] Signed-off-by: Chanho Min <chanho.min@lge.com> Cc: "Darrick J. Wong" <djwong@us.ibm.com> Cc: Bob Pearson <rpearson@systemfabricworks.com> Cc: Richard Weinberger <richard@nod.at> Cc: Herbert Xu <herbert@gondor.hengli.com.au> Cc: Yann Collet <yann.collet.73@gmail.com> Cc: Kyungsik Lee <kyungsik.lee@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto update from Herbert Xu: - Do not idle omap device between crypto operations in one session. - Added sha224/sha384 shims for SSSE3. - More optimisations for camellia-aesni-avx2. - Removed defunct blowfish/twofish AVX2 implementations. - Added unaligned buffer self-tests. - Added PCLMULQDQ optimisation for CRCT10DIF. - Added support for Freescale's DCP co-processor - Misc fixes. * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (44 commits) crypto: testmgr - test hash implementations with unaligned buffers crypto: testmgr - test AEADs with unaligned buffers crypto: testmgr - test skciphers with unaligned buffers crypto: testmgr - check that entries in alg_test_descs are in correct order Revert "crypto: twofish - add AVX2/x86_64 assembler implementation of twofish cipher" Revert "crypto: blowfish - add AVX2/x86_64 implementation of blowfish cipher" crypto: camellia-aesni-avx2 - tune assembly code for more performance hwrng: bcm2835 - fix MODULE_LICENSE tag hwrng: nomadik - use clk_prepare_enable() crypto: picoxcell - replace strict_strtoul() with kstrtoul() crypto: dcp - Staticize local symbols crypto: dcp - Use NULL instead of 0 crypto: dcp - Use devm_* APIs crypto: dcp - Remove redundant platform_set_drvdata() hwrng: use platform_{get,set}_drvdata() crypto: omap-aes - Don't idle/start AES device between Encrypt operations crypto: crct10dif - Use PTR_RET crypto: ux500 - Cocci spatch "resource_size.spatch" crypto: sha256_ssse3 - add sha224 support crypto: sha512_ssse3 - add sha384 support ...
2013-07-03drivers/dma: remove unused support for MEMSET operationsBartlomiej Zolnierkiewicz
There have never been any real users of MEMSET operations since they have been introduced in January 2007 by commit 7405f74badf4 ("dmaengine: refactor dmaengine around dma_async_tx_descriptor"). Therefore remove support for them for now, it can be always brought back when needed. [sebastian.hesselbarth@gmail.com: fix drivers/dma/mv_xor] Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Cc: Vinod Koul <vinod.koul@intel.com> Acked-by: Dan Williams <djbw@fb.com> Cc: Tomasz Figa <t.figa@samsung.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Olof Johansson <olof@lixom.net> Cc: Kevin Hilman <khilman@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03drivers: avoid format strings in names passed to alloc_workqueue()Kees Cook
For the workqueue creation interfaces that do not expect format strings, make sure they cannot accidently be parsed that way. Additionally, clean up calls made with a single parameter that would be handled as a format string. Many callers are passing potentially dynamic string content, so use "%s" in those cases to avoid any potential accidents. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03crypto: sanitize argument for format stringKees Cook
The template lookup interface does not provide a way to use format strings, so make sure that the interface cannot be abused accidentally. Signed-off-by: Kees Cook <keescook@chromium.org> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: "David S. Miller" <davem@davemloft.net> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
