corruption
commit 9efade1b3e981f5064f9db9ca971b4dc7557ae42 upstream.
cryptd_queue_worker attempts to prevent simultaneous accesses to crypto
workqueue by cryptd_enqueue_request using preempt_disable/preempt_enable.
However cryptd_enqueue_request might be called from softirq context,
so add local_bh_disable/local_bh_enable to prevent data corruption and
panics.
Bug report at http://marc.info/?l=linux-crypto-vger&m=134858649616319&w=2
v2:
- Disable software interrupts instead of hardware interrupts
Reported-by: Gurucharan Shetty <gurucharan.shetty@gmail.com>
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
Signed-off-by: Willy Tarreau <w@1wt.eu>
commit 25c3d30c918207556ae1d6e663150ebdf902186b upstream.
The current code only increments the upper 64 bits of the SHA-512 byte
counter when the number of bytes hashed happens to hit 2^64 exactly.
This patch increments the upper 64 bits whenever the lower 64 bits
overflows.
Signed-off-by: Kent Yoder <key@linux.vnet.ibm.com>
commit f2ea0f5f04c97b48c88edccba52b0682fbe45087 upstream.
Use standard ror64() instead of hand-written.
There is no standard ror64, so create it.
The difference is shift value being "unsigned int" instead of uint64_t
(for which there is no reason). gcc starts to emit native ROR instructions
which it doesn't do for some reason currently. This should make the code
faster.
Patch survives in-tree crypto test and ping flood with hmac(sha512) on.
commit 3a92d687c8015860a19213e3c102cad6b722f83c upstream.
Unfortunately in reducing W from 80 to 16 we ended up unrolling
the loop twice. As gcc has issues dealing with 64-bit ops on
i386 this means that we end up using even more stack space (>1K).
This patch solves the W reduction by moving LOAD_OP/BLEND_OP
into the loop itself, thus avoiding the need to duplicate it.
While the stack space still isn't great (>0.5K) it is at least
in the same ball park as the amount of stack used for our C sha1
implementation.
Note that this patch basically reverts to the original code so
the diff looks bigger than it really is.
commit 58d7d18b5268febb8b1391c6dffc8e2aaa751fcd upstream.
The previous patch used the modulus operator over a power of 2
unnecessarily which may produce suboptimal binary code. This
patch changes changes them to binary ands instead.
commit 51fc6dc8f948047364f7d42a4ed89b416c6cc0a3 upstream.
For rounds 16--79, W[i] only depends on W[i - 2], W[i - 7], W[i - 15] and W[i - 16].
Consequently, keeping all W[80] array on stack is unnecessary,
only 16 values are really needed.
Using W[16] instead of W[80] greatly reduces stack usage
(~750 bytes to ~340 bytes on x86_64).
Line by line explanation:
* BLEND_OP
array is "circular" now, all indexes have to be modulo 16.
Round number is positive, so remainder operation should be
without surprises.
* initial full message scheduling is trimmed to first 16 values which
come from data block, the rest is calculated before it's needed.
* original loop body is unrolled version of new SHA512_0_15 and
SHA512_16_79 macros, unrolling was done to not do explicit variable
renaming. Otherwise it's the very same code after preprocessing.
See sha1_transform() code which does the same trick.
Patch survives in-tree crypto test and original bugreport test
(ping flood with hmac(sha512).
See FIPS 180-2 for SHA-512 definition
http://csrc.nist.gov/publications/fips/fips180-2/fips180-2withchangenotice.pdf
commit 84e31fdb7c797a7303e0cc295cb9bc8b73fb872d upstream.
commit f9e2bca6c22d75a289a349f869701214d63b5060
aka "crypto: sha512 - Move message schedule W[80] to static percpu area"
created global message schedule area.
If sha512_update will ever be entered twice, hash will be silently
calculated incorrectly.
Probably the easiest way to notice incorrect hashes being calculated is
to run 2 ping floods over AH with hmac(sha512):
#!/usr/sbin/setkey -f
flush;
spdflush;
add IP1 IP2 ah 25 -A hmac-sha512 0x00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000025;
add IP2 IP1 ah 52 -A hmac-sha512 0x00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000052;
spdadd IP1 IP2 any -P out ipsec ah/transport//require;
spdadd IP2 IP1 any -P in ipsec ah/transport//require;
XfrmInStateProtoError will start ticking with -EBADMSG being returned
from ah_input(). This never happens with, say, hmac(sha1).
With patch applied (on BOTH sides), XfrmInStateProtoError does not tick
with multiple bidirectional ping flood streams like it doesn't tick
with SHA-1.
After this patch sha512_transform() will start using ~750 bytes of stack on x86_64.
This is OK for simple loads, for something more heavy, stack reduction will be done
separatedly.
We are going to use this for TCP/IP sequence number and fragment ID
generation.
commit 863b557a88f8c033f7419fabafef4712a5055f85 upstream.
When load aesni-intel and ghash_clmulni-intel driver,kernel will complain no
test for some internal used algorithm.
The strange information as following:
alg: No test for __aes-aesni (__driver-aes-aesni)
alg: No test for __ecb-aes-aesni (__driver-ecb-aes-aesni)
alg: No test for __cbc-aes-aesni (__driver-cbc-aes-aesni)
alg: No test for __ecb-aes-aesni (cryptd(__driver-ecb-aes-aesni)
alg: No test for __ghash (__ghash-pclmulqdqni)
alg: No test for __ghash (cryptd(__ghash-pclmulqdqni))
This patch add NULL test entries for these algorithm and driver.
Signed-off-by: Song Youquan <youquan.song@intel.com>
Signed-off-by: Hang Ying <ying.huang@intel.com>
Acked-by: Jiri Kosina <jkosina@suse.cz>
commit 180ce7e81030e1ef763d58f97f9ab840ff57d848 upstream.
When Steffen originally wrote the authenc async hash patch, he
correctly had EINPROGRESS checks in place so that we did not invoke
the original completion handler with it.
Unfortuantely I told him to remove it before the patch was applied.
As only MAY_BACKLOG request completion handlers are required to
handle EINPROGRESS completions, those checks are really needed.
This patch restores them.
Reported-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc>
commit 5157b4aa5b7de8787b6318e61bcc285031bb9088 upstream.
The raid6 recovery code should immediately drop back to the optimized
synchronous path when a p+q dma resource is not available. Otherwise we
run the non-optimized/multi-pass async code in sync mode.
Verified with raid6test (NDISKS=255)
Applies to kernels >= 2.6.32.
Acked-by: NeilBrown <neilb@suse.de>
Reported-by: H. Peter Anvin <hpa@zytor.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6:
crypto: gcm - fix another complete call in complete fuction
crypto: padlock-aes - Use the correct mask when checking whether copying is required
ioat3.2 does not support asynchronous error notifications which makes
the driver experience latencies when non-zero pq validate results are
expected. Provide a mechanism for turning off async_xor_val and
async_syndrome_val via Kconfig. This approach is generally useful for
any driver that specifies ASYNC_TX_DISABLE_CHANNEL_SWITCH and would like
to force the async_tx api to fall back to the synchronous path for
certain operations.
The flow of the complete function (xxx_done) in gcm.c is as follow:
void complete(struct crypto_async_request *areq, int err)
struct aead_request *req = areq->data;
if (!err) {
err = async_next_step();
if (err == -EINPROGRESS || err == -EBUSY)
return;
complete_for_next_step(areq, err);
But *areq may be destroyed in async_next_step(), this makes
complete_for_next_step() can not work properly. To fix this, one of
following methods is used for each complete function.
- Add a __complete() for each complete(), which accept struct
aead_request *req instead of areq, so avoid using areq after it is
destroyed.
- Expand complete_for_next_step().
The fixing method is based on the idea of Herbert Xu.
Signed-off-by: Huang Ying <ying.huang@intel.com>
* 'for-linus' of git://neil.brown.name/md:
async_tx: fix asynchronous raid6 recovery for ddf layouts
async_pq: rename scribble page
async_pq: kill a stray dma_map() call and other cleanups
md/raid6: kill a gcc-4.0.1 'uninitialized variable' warning
raid6/async_tx: handle holes in block list in async_syndrome_val
md/async: don't pass a memory pointer as a page pointer.
md: Fix handling of raid5 array which is being reshaped to fewer devices.
md: fix problems with RAID6 calculations for DDF.
md/raid456: downlevel multicore operations to raid_run_ops
md: drivers/md/unroll.pl replaced with awk analog
md: remove clumsy usage of do_sync_mapping_range from bitmap code
md: raid1/raid10: handle allocation errors during array setup.
md/raid5: initialize conf->device_lock earlier
md/raid1/raid10: add a cond_resched
Revert "md: do not progress the resync process if the stripe was blocked"
The raid6 recovery code currently requires special handling of the
4-disk and 5-disk recovery scenarios for the native layout. Quoting
from commit 0a82a623:
In these situations the default N-disk algorithm will present
0-source or 1-source operations to dma devices. To cover for
dma devices where the minimum source count is 2 we implement
4-disk and 5-disk handling in the recovery code.
The ddf layout presents disks=6 and disks=7 to the recovery code in
these situations. Instead of looking at the number of disks count the
number of non-zero sources in the list and call the special case code
when the number of non-failed sources is 0 or 1.
[neilb@suse.de: replace 'ddf' flag with counting good sources]
The global scribble page is used as a temporary destination buffer when
disabling the P or Q result is requested. The local scribble buffer
contains memory for performing address conversions. Rename the global
variable to avoid confusion.
- update the kernel doc for async_syndrome to indicate what NULL in the
source list means
- whitespace fixups
async_syndrome_val check the P and Q blocks used for RAID6
calculations.
With DDF raid6, some of the data blocks might be NULL, so
this needs to be handled in the same way that async_gen_syndrome
handles it.
As async_syndrome_val calls async_xor, also enhance async_xor
to detect and skip NULL blocks in the list.
Signed-off-by: NeilBrown <neilb@suse.de>
md/raid6 passes a list of 'struct page *' to the async_tx routines,
which then either DMA map them for offload, or take the page_address
for CPU based calculations.
For RAID6 we sometime leave 'blanks' in the list of pages.
For CPU based calcs, we want to treat theses as a page of zeros.
For offloaded calculations, we simply don't pass a page to the
hardware.
Currently the 'blanks' are encoded as a pointer to
raid6_empty_zero_page. This is a 4096 byte memory region, not a
'struct page'. This is mostly handled correctly but is rather ugly.
So change the code to pass and expect a NULL pointer for the blanks.
When taking page_address of a page, we need to check for a NULL and
in that case use raid6_empty_zero_page.
After m68k's task_thread_info() doesn't refer to current,
it's possible to remove sched.h from interrupt.h and not break m68k!
Many thanks to Heiko Carstens for allowing this.
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx into for-linus
If we are unable to offload async_mult() or async_sum_product(), then
unmap the buffers before falling through to the synchronous path.
Testing on x86_64 with NDISKS=255 yields:
do_IRQ: modprobe near stack overflow (cur:ffff88007d19c000,sp:ffff88007d19c128)
...and eventually
general protection fault: 0000 [#1]
Moving the scribble buffers off the stack allows the test to complete
successfully.
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (102 commits)
crypto: sha-s390 - Fix warnings in import function
crypto: vmac - New hash algorithm for intel_txt support
crypto: api - Do not displace newly registered algorithms
crypto: ansi_cprng - Fix module initialization
crypto: xcbc - Fix alignment calculation of xcbc_tfm_ctx
crypto: fips - Depend on ansi_cprng
crypto: blkcipher - Do not use eseqiv on stream ciphers
crypto: ctr - Use chainiv on raw counter mode
Revert crypto: fips - Select CPRNG
crypto: rng - Fix typo
crypto: talitos - add support for 36 bit addressing
crypto: talitos - align locks on cache lines
crypto: talitos - simplify hmac data size calculation
crypto: mv_cesa - Add support for Orion5X crypto engine
crypto: cryptd - Add support to access underlaying shash
crypto: gcm - Use GHASH digest algorithm
crypto: ghash - Add GHASH digest algorithm for GCM
crypto: authenc - Convert to ahash
crypto: api - Fix aligned ctx helper
crypto: hmac - Prehash ipad/opad
crypto/async_tx/async_xor.c
drivers/dma/ioat/dma_v2.h
drivers/dma/ioat/pci.c
drivers/md/raid5.c
Some engines have transfer size and address alignment restrictions. Add
a per-operation alignment property to struct dma_device that the async
routines and dmatest can use to check alignment capabilities.
Channel switching is problematic for some dmaengine drivers as the
architecture precludes separating the ->prep from ->submit. In these
cases the driver can select ASYNC_TX_DISABLE_CHANNEL_SWITCH to modify
the async_tx allocator to only return channels that support all of the
required asynchronous operations.
For example MD_RAID456=y selects support for asynchronous xor, xor
validate, pq, pq validate, and memcpy. When
ASYNC_TX_DISABLE_CHANNEL_SWITCH=y any channel with all these
capabilities is marked DMA_ASYNC_TX allowing async_tx_find_channel() to
quickly locate compatible channels with the guarantee that dependency
chains will remain on one channel. When
ASYNC_TX_DISABLE_CHANNEL_SWITCH=n async_tx_find_channel() may select
channels that lead to operation chains that need to cross channel
boundaries using the async_tx channel switch capability.
Some engines optimize operation by reading ahead in the descriptor chain
such that descriptor2 may start execution before descriptor1 completes.
If descriptor2 depends on the result from descriptor1 then a fence is
required (on descriptor2) to disable this optimization. The async_tx
api could implicitly identify dependencies via the 'depend_tx'
parameter, but that would constrain cases where the dependency chain
only specifies a completion order rather than a data dependency. So,
provide an ASYNC_TX_FENCE to explicitly identify data dependencies.
include/linux/dmaengine.h
crypto: skcipher - Fix skcipher_dequeue_givcrypt NULL test
This patch adds VMAC (a fast MAC) support into crypto framework.
Signed-off-by: Shane Wang <shane.wang@intel.com>
Signed-off-by: Joseph Cihula <joseph.cihula@intel.com>
We have a mechanism where newly registered algorithms of a higher
priority can displace existing instances that use a different
implementation of the same algorithm with a lower priority.
Unfortunately the same mechanism can cause a newly registered
algorithm to displace itself if it depends on an existing version
of the same algorithm.
This patch fixes this by keeping all algorithms that the newly
reigstered algorithm depends on, thus protecting them from being
removed.
Port drivers/md/raid6test/test.c to use the async raid6 recovery
routines. This is meant as a unit test for raid6 acceleration drivers. In
addition to the 16-drive test case this implements tests for the 4-disk and
5-disk special cases (dma devices can not generically handle less than 2
sources), and adds a test for the D+Q case.
Reviewed-by: Andre Noll <maan@systemlinux.org>
Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com>
async_raid6_2data_recov() recovers two data disk failures
async_raid6_datap_recov() recovers a data disk and the P disk
These routines are a port of the synchronous versions found in
drivers/md/raid6recov.c. The primary difference is breaking out the xor
operations into separate calls to async_xor. Two helper routines are
introduced to perform scalar multiplication where needed.
async_sum_product() multiplies two sources by scalar coefficients and
then sums (xor) the result. async_mult() simply multiplies a single
source by a scalar.
This implemention also includes, in contrast to the original
synchronous-only code, special case handling for the 4-disk and 5-disk
array cases. In these situations the default N-disk algorithm will
present 0-source or 1-source operations to dma devices. To cover for
dma devices where the minimum source count is 2 we implement 4-disk and
[ Impact: asynchronous raid6 recovery routines for 2data and datap cases ]
Cc: Yuri Tikhonov <yur@emcraft.com>
Cc: Ilya Yanok <yanok@emcraft.com>
Cc: David Woodhouse <David.Woodhouse@intel.com>
[ Based on an original patch by Yuri Tikhonov ]
This adds support for doing asynchronous GF multiplication by adding
two additional functions to the async_tx API:
async_gen_syndrome() does simultaneous XOR and Galois field
multiplication of sources.
async_syndrome_val() validates the given source buffers against known P
and Q values.
When a request is made to run async_pq against more than the hardware
maximum number of supported sources we need to reuse the previous
generated P and Q values as sources into the next operation. Care must
be taken to remove Q from P' and P from Q'. For example to perform a 5
source pq op with hardware that only supports 4 sources at a time the
following approach is taken:
p, q = PQ(src0, src1, src2, src3, COEF({01}, {02}, {04}, {08}))
p', q' = PQ(p, q, q, src4, COEF({00}, {01}, {00}, {10}))
p' = p + q + q + src4 = p + src4
q' = {00}*p + {01}*q + {00}*q + {10}*src4 = q + {10}*src4
Note: 4 is the minimum acceptable maxpq otherwise we punt to
synchronous-software path.
The DMA_PREP_CONTINUE flag indicates to the driver to reuse p and q as
sources (in the above manner) and fill the remaining slots up to maxpq
with the new sources/coefficients.
Note1: Some devices have native support for P+Q continuation and can skip
this extra work. Devices with this capability can advertise it with
dma_set_maxpq. It is up to each driver how to handle the
DMA_PREP_CONTINUE flag.
Note2: The api supports disabling the generation of P when generating Q,
this is ignored by the synchronous path but is implemented by some dma
devices to save unnecessary writes. In this case the continuation
algorithm is simplified to only reuse Q as a source.
Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
We currently walk the parent chain when waiting for a given tx to
complete however this walk may race with the driver cleanup routine.
The routines in async_raid6_recov.c may fall back to the synchronous
path at any point so we need to be prepared to call async_tx_quiesce()
(which calls dma_wait_for_async_tx). To remove the ->parent walk we
guarantee that every time a dependency is attached ->issue_pending() is
invoked, then we can simply poll the initial descriptor until
completion.
This also allows for a lighter weight 'issue pending' implementation as
there is no longer a requirement to iterate through all the channels'
->issue_pending() routines as long as operations have been submitted in
an ordered chain. async_tx_issue_pending() is added for this case.
If module_init and module_exit are nops then neither need to be defined.
[ Impact: pure cleanup ]
Replace the flat zero_sum_result with a collection of flags to contain
the P (xor) zero-sum result, and the soon to be utilized Q (raid6 reed
solomon syndrome) zero-sum result. Use the SUM_CHECK_ namespace instead
of DMA_ since these flags will be used on non-dma-zero-sum enabled
platforms.
As struct skcipher_givcrypt_request includes struct crypto_request
at a non-zero offset, testing for NULL after converting the pointer
returned by crypto_dequeue_request does not work. This can result
in IPsec crashes when the queue is depleted.
This patch fixes it by doing the pointer conversion only when the
return value is non-NULL. In particular, we create a new function
__crypto_dequeue_request that does the pointer conversion.
Reported-by: Brad Bosch <bradbosch@comcast.net>
Return the value we got from crypto_register_alg() instead of
returning 0 in any case.
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
The alignment calculation of xcbc_tfm_ctx uses alg->cra_alignmask
and not alg->cra_alignmask + 1 as it should. This led to frequent
crashes during the selftest of xcbc(aes-asm) on x86_64
machines. This patch fixes this. Also we use the alignmask
of xcbc and not the alignmask of the underlying algorithm
for the alignmnent calculation in xcbc_create now.
What about something like this? It defaults the CPRNG to m and makes FIPS
dependent on the CPRNG. That way you get a module build by default, but you can
change it to y manually during config and still satisfy the dependency, and if
you select N it disables FIPS as well. I rather like that better than making
FIPS a tristate. I just tested it out here and it seems to work well. Let me
know what you think
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Recently we switched to using eseqiv on SMP machines in preference
over chainiv. However, eseqiv does not support stream ciphers so
they should still default to chainiv.
This patch applies the same check as done by eseqiv to weed out
the stream ciphers. In particular, all algorithms where the IV
size is not equal to the block size will now default to chainiv.
Raw counter mode only works with chainiv, which is no longer
the default IV generator on SMP machines. This broke raw counter
mode as it can no longer instantiate as a givcipher.
This patch fixes it by always picking chainiv on raw counter
mode. This is based on the diagnosis and a patch by Huang
Ying.
This reverts commit 215ccd6f55a2144bd553e0a3d12e1386f02309fd.
It causes CPRNG and everything selected by it to be built-in
whenever FIPS is enabled. The problem is that it is selecting
a tristate from a bool, which is usually not what is intended.
Correct a typo in crypto/rng.c
Signed-off-by: Christian Kujau <lists@nerdbynature.de>
cryptd_alloc_ahash() will allocate a cryptd-ed ahash for specified
algorithm name. The new allocated one is guaranteed to be cryptd-ed
ahash, so the shash underlying can be gotten via cryptd_ahash_child().
Remove the dedicated GHASH implementation in GCM, and uses the GHASH
digest algorithm instead. This will make GCM uses hardware accelerated
GHASH implementation automatically if available.
ahash instead of shash interface is used, because some hardware
accelerated GHASH implementation needs asynchronous interface.
