commit 8a45ac12ec5b6ee67f8559c78ae11d9af8b821ee upstream.
tcrypt/testmgr uses wait_for_completion_interruptible() everywhere when
it waits for a request to be completed. If it's interrupted, then the
test is aborted and the request is freed.
However, if any of these calls actually do get interrupted, the result
will likely be a kernel crash, when the driver handles the now-freed
request. Use wait_for_completion() instead.
Signed-off-by: Rabin Vincent <rabin.vincent@axis.com>
commit be34c4ef693ff5c10f55606dbd656ddf0b4a8340 upstream.
Like SHA1, use get_unaligned_be*() on the raw input data.
Reported-by: Bob Picco <bob.picco@oracle.com>
The backport of commit 5d26a105b5a7 ("crypto: prefix module autoloading
with "crypto-"") lost the MODULE_ALIAS_CRYPTO() annotation of crc32c.c.
Add it to fix the reported filesystem related regressions.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Reported-by: Philip Müller <philm@manjaro.org>
Cc: Rob McCathie <rob@manjaro.org>
Cc: Luis Henriques <luis.henriques@canonical.com>
Cc: Kamal Mostafa <kamal@canonical.com>
Cc: Jiri Slaby <jslaby@suse.cz>
commit 3e14dcf7cb80b34a1f38b55bc96f02d23fdaaaaf upstream.
Commit 5d26a105b5a7 ("crypto: prefix module autoloading with "crypto-"")
changed the automatic module loading when requesting crypto algorithms
to prefix all module requests with "crypto-". This requires all crypto
modules to have a crypto specific module alias even if their file name
would otherwise match the requested crypto algorithm.
Even though commit 5d26a105b5a7 added those aliases for a vast amount of
modules, it was missing a few. Add the required MODULE_ALIAS_CRYPTO
annotations to those files to make them get loaded automatically, again.
This fixes, e.g., requesting 'ecb(blowfish-generic)', which used to work
with kernels v3.18 and below.
Also change MODULE_ALIAS() lines to MODULE_ALIAS_CRYPTO(). The former
won't work for crypto modules any more.
Fixes: 5d26a105b5a7 ("crypto: prefix module autoloading with "crypto-"")
commit 4943ba16bbc2db05115707b3ff7b4874e9e3c560 upstream.
This adds the module loading prefix "crypto-" to the template lookup
as well.
For example, attempting to load 'vfat(blowfish)' via AF_ALG now correctly
includes the "crypto-" prefix at every level, correctly rejecting "vfat":
net-pf-38
algif-hash
crypto-vfat(blowfish)
crypto-vfat(blowfish)-all
crypto-vfat
Reported-by: Mathias Krause <minipli@googlemail.com>
Acked-by: Mathias Krause <minipli@googlemail.com>
commit 5d26a105b5a73e5635eae0629b42fa0a90e07b7b upstream.
This prefixes all crypto module loading with "crypto-" so we never run
the risk of exposing module auto-loading to userspace via a crypto API,
as demonstrated by Mathias Krause:
https://lkml.org/lkml/2013/3/4/70
commit 7e77bdebff5cb1e9876c561f69710b9ab8fa1f7e upstream.
If a request is backlogged, it's complete() handler will get called
twice: once with -EINPROGRESS, and once with the final error code.
af_alg's complete handler, unlike other users, does not handle the
-EINPROGRESS but instead always completes the completion that recvmsg()
is waiting on. This can lead to a return to user space while the
request is still pending in the driver. If userspace closes the sockets
before the requests are handled by the driver, this will lead to
use-after-frees (and potential crashes) in the kernel due to the tfm
having been freed.
The crashes can be easily reproduced (for example) by reducing the max
queue length in cryptod.c and running the following (from
http://www.chronox.de/libkcapi.html) on AES-NI capable hardware:
$ while true; do kcapi -x 1 -e -c '__ecb-aes-aesni' \
-k 00000000000000000000000000000000 \
-p 00000000000000000000000000000000 >/dev/null & done
commit e2cffb5f493a8b431dc87124388ea59b79f0bccb upstream.
On archs with PAGE_SIZE >= 64 KiB the function skcipher_alloc_sgl()
fails with -ENOMEM no matter what user space actually requested.
This is caused by the fact sock_kmalloc call inside the function tried
to allocate more memory than allowed by the default kernel socket buffer
size (kernel param net.core.optmem_max).
Signed-off-by: Ondrej Kozina <okozina@redhat.com>
commit 4c63f83c2c2e16a13ce274ee678e28246bd33645 upstream.
Th AF_ALG socket was missing a security label (e.g. SELinux)
which means that socket was in "unlabeled" state.
This was recently demonstrated in the cryptsetup package
(cryptsetup v1.6.5 and later.)
See https://bugzilla.redhat.com/show_bug.cgi?id=1115120
This patch clones the sock's label from the parent sock
and resolves the issue (similar to AF_BLUETOOTH protocol family).
Signed-off-by: Milan Broz <gmazyland@gmail.com>
Acked-by: Paul Moore <paul@paul-moore.com>
[ Upstream commit 90f62cf30a78721641e08737bda787552428061e ]
It is possible by passing a netlink socket to a more privileged
executable and then to fool that executable into writing to the socket
data that happens to be valid netlink message to do something that
privileged executable did not intend to do.
To keep this from happening replace bare capable and ns_capable calls
with netlink_capable, netlink_net_calls and netlink_ns_capable calls.
Which act the same as the previous calls except they verify that the
opener of the socket had the desired permissions as well.
Reported-by: Andy Lutomirski <luto@amacapital.net>
commit 130fa5bc81b44b6cc1fbdea3abf6db0da22964e0 upstream.
The crypto algorithm modules utilizing the crypto daemon could
be used early when the system start up. Using module_init
does not guarantee that the daemon's work queue is initialized
when the cypto alorithm depending on crypto_wq starts. It is necessary
to initialize the crypto work queue earlier at the subsystem
init time to make sure that it is initialized
when used.
Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com>
commit 57be4a784bf58eb41784aa3431165b455cf7e9c6 upstream.
struct x509_certificate needs struct tm declaring by #inclusion of linux/time.h
prior to its definition.
Reviewed-by: Josh Boyer <jwboyer@redhat.com>
It turns out that commit: d3f7d56a7a4671d395e8af87071068a195257bf6 was
applied to the tree twice, which didn't hurt anything, but it's good to
fix this up.
Reported-by: Veaceslav Falico <veaceslav@falico.eu>
Cc: Richard Weinberger <richard@nod.at>
Cc: Shawn Landden <shawnlandden@gmail.com>
Cc: Tom Herbert <therbert@google.com>
commit d3f7d56a7a4671d395e8af87071068a195257bf6 upstream.
Commit 35f9c09fe (tcp: tcp_sendpages() should call tcp_push() once)
added an internal flag MSG_SENDPAGE_NOTLAST, similar to
MSG_MORE.
algif_hash, algif_skcipher, and udp used MSG_MORE from tcp_sendpages()
and need to see the new flag as identical to MSG_MORE.
This fixes sendfile() on AF_ALG.
v3: also fix udp
Reported-and-tested-by: Shawn Landden <shawnlandden@gmail.com>
Original-patch: Richard Weinberger <richard@nod.at>
Signed-off-by: Shawn Landden <shawn@churchofgit.com>
commit fc019c7122dfcd69c50142b57a735539aec5da95 upstream.
When performing an asynchronous ablkcipher operation the authenc
completion callback routine is invoked, but it does not locate and use
the proper IV.
The callback routine, crypto_authenc_encrypt_done, is updated to use
the same method of calculating the address of the IV as is done in
crypto_authenc_encrypt function which sets up the callback.
Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com>
commit 5638cabf3e4883f38dfb246c30980cebf694fbda upstream.
There are cases when cryptlen can be zero in crypto_ccm_auth():
-encryptiom: input scatterlist length is zero (no plaintext)
-decryption: input scatterlist contains only the mac
plus the condition of having different source and destination buffers
(or else scatterlist length = max(plaintext_len, ciphertext_len)).
These are not handled correctly, leading to crashes like:
root@p4080ds:~/crypto# insmod tcrypt.ko mode=45
kernel BUG at crypto/scatterwalk.c:37!
Oops: Exception in kernel mode, sig: 5 [#1]
SMP NR_CPUS=8 P4080 DS
Modules linked in: tcrypt(+) crc32c xts xcbc vmac pcbc ecb gcm ghash_generic gf128mul ccm ctr seqiv
CPU: 3 PID: 1082 Comm: cryptomgr_test Not tainted 3.11.0 #14
task: ee12c5b0 ti: eecd0000 task.ti: eecd0000
NIP: c0204d98 LR: f9225848 CTR: c0204d80
REGS: eecd1b70 TRAP: 0700 Not tainted (3.11.0)
MSR: 00029002 <CE,EE,ME> CR: 22044022 XER: 20000000
GPR00: f9225c94 eecd1c20 ee12c5b0 eecd1c28 ee879400 ee879400 00000000 ee607464
GPR08: 00000001 00000001 00000000 006b0000 c0204d80 00000000 00000002 c0698e20
GPR16: ee987000 ee895000 fffffff4 ee879500 00000100 eecd1d58 00000001 00000000
GPR24: ee879400 00000020 00000000 00000000 ee5b2800 ee607430 00000004 ee607460
NIP [c0204d98] scatterwalk_start+0x18/0x30
LR [f9225848] get_data_to_compute+0x28/0x2f0 [ccm]
Call Trace:
[eecd1c20] [f9225974] get_data_to_compute+0x154/0x2f0 [ccm] (unreliable)
[eecd1c70] [f9225c94] crypto_ccm_auth+0x184/0x1d0 [ccm]
[eecd1cb0] [f9225d40] crypto_ccm_encrypt+0x60/0x2d0 [ccm]
[eecd1cf0] [c020d77c] __test_aead+0x3ec/0xe20
[eecd1e20] [c020f35c] test_aead+0x6c/0xe0
[eecd1e40] [c020f420] alg_test_aead+0x50/0xd0
[eecd1e60] [c020e5e4] alg_test+0x114/0x2e0
[eecd1ee0] [c020bd1c] cryptomgr_test+0x4c/0x60
[eecd1ef0] [c0047058] kthread+0xa8/0xb0
[eecd1f40] [c000eb0c] ret_from_kernel_thread+0x5c/0x64
Instruction dump:
0f080000 81290024 552807fe 0f080000 5529003a 4bffffb4 90830000 39400000
39000001 8124000c 2f890000 7d28579e <0f090000> 81240008 91230004 4e800020
---[ end trace 6d652dfcd1be37bd ]---
Cc: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
Signed-off-by: Horia Geanta <horia.geanta@freescale.com>
[ Upstream commit d3f7d56a7a4671d395e8af87071068a195257bf6 ]
MSG_MORE.
v3: also fix udp
Cc: <stable@vger.kernel.org> # 3.4.x + 3.2.x
[ Upstream commit f3d3342602f8bcbf37d7c46641cb9bca7618eb1c ]
This patch now always passes msg->msg_namelen as 0. recvmsg handlers must
set msg_namelen to the proper size <= sizeof(struct sockaddr_storage)
to return msg_name to the user.
This prevents numerous uninitialized memory leaks we had in the
recvmsg handlers and makes it harder for new code to accidentally leak
uninitialized memory.
Optimize for the case recvfrom is called with NULL as address. We don't
need to copy the address at all, so set it to NULL before invoking the
recvmsg handler. We can do so, because all the recvmsg handlers must
cope with the case a plain read() is called on them. read() also sets
msg_name to NULL.
Also document these changes in include/linux/net.h as suggested by David
Miller.
Changes since RFC:
Set msg->msg_name = NULL if user specified a NULL in msg_name but had a
non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't
affect sendto as it would bail out earlier while trying to copy-in the
address. It also more naturally reflects the logic by the callers of
verify_iovec.
With this change in place I could remove "
if (!uaddr || msg_sys->msg_namelen == 0)
This change does not alter the user visible error logic as we ignore
msg_namelen as long as msg_name is NULL.
Also remove two unnecessary curly brackets in ___sys_recvmsg and change
comments to netdev style.
Suggested-by: Eric Dumazet <eric.dumazet@gmail.com>
commit 124df926090b32a998483f6e43ebeccdbe5b5302 upstream.
Remove the certificate date checks that are performed when a certificate is
parsed. There are two checks: a valid from and a valid to. The first check is
causing a lot of problems with system clocks that don't keep good time and the
second places an implicit expiry date upon the kernel when used for module
signing, so do we really need them?
cc: David Woodhouse <dwmw2@infradead.org>
cc: Rusty Russell <rusty@rustcorp.com.au>
cc: Josh Boyer <jwboyer@redhat.com>
cc: Alexander Holler <holler@ahsoftware.de>
commit 714b33d15130cbb5ab426456d4e3de842d6c5b8a upstream.
Stephan Mueller reported to me recently a error in random number generation in
the ansi cprng. If several small requests are made that are less than the
instances block size, the remainder for loop code doesn't increment
rand_data_valid in the last iteration, meaning that the last bytes in the
rand_data buffer gets reused on the subsequent smaller-than-a-block request for
random data.
The fix is pretty easy, just re-code the for loop to make sure that
rand_data_valid gets incremented appropriately
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Reported-by: Stephan Mueller <stephan.mueller@atsec.com>
CC: Stephan Mueller <stephan.mueller@atsec.com>
CC: Petr Matousek <pmatouse@redhat.com>
CC: Herbert Xu <herbert@gondor.apana.org.au>
CC: "David S. Miller" <davem@davemloft.net>
Unfortunately, even with a softdep some distros fail to include
the necessary modules in the initrd. Therefore this patch adds
a fallback path to restore existing behaviour where we cannot
load the new crypto crct10dif algorithm.
In order to do this, the underlying crct10dif has been split out
from the crypto implementation so that it can be used on the
fallback path.
crypto_larval_lookup should only return a larval if it created one.
Any larval created by another entity must be processed through
crypto_larval_wait before being returned.
Otherwise this will lead to a larval being killed twice, which
will most likely lead to a crash.
Cc: stable@vger.kernel.org
Reported-by: Kees Cook <keescook@chromium.org>
Tested-by: Kees Cook <keescook@chromium.org>
Pull crypto update from Herbert Xu:
"Here is the crypto update for 3.12:
- Added MODULE_SOFTDEP to allow pre-loading of modules.
- Reinstated crct10dif driver using the module softdep feature.
- Allow via rng driver to be auto-loaded.
- Split large input data when necessary in nx.
- Handle zero length messages correctly for GCM/XCBC in nx.
- Handle SHA-2 chunks bigger than block size properly in nx.
- Handle unaligned lengths in omap-aes.
- Added SHA384/SHA512 to omap-sham.
- Added OMAP5/AM43XX SHAM support.
- Added OMAP4 TRNG support.
- Misc fixes"
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (66 commits)
Reinstate "crypto: crct10dif - Wrap crc_t10dif function all to use crypto transform framework"
hwrng: via - Add MODULE_DEVICE_TABLE
crypto: fcrypt - Fix bitoperation for compilation with clang
crypto: nx - fix SHA-2 for chunks bigger than block size
crypto: nx - fix GCM for zero length messages
crypto: nx - fix XCBC for zero length messages
crypto: nx - fix limits to sg lists for AES-CCM
crypto: nx - fix limits to sg lists for AES-XCBC
crypto: nx - fix limits to sg lists for AES-GCM
crypto: nx - fix limits to sg lists for AES-CTR
crypto: nx - fix limits to sg lists for AES-CBC
crypto: nx - fix limits to sg lists for AES-ECB
crypto: nx - add offset to nx_build_sg_lists()
padata - Register hotcpu notifier after initialization
padata - share code between CPU_ONLINE and CPU_DOWN_FAILED, same to CPU_DOWN_PREPARE and CPU_UP_CANCELED
hwrng: omap - reorder OMAP TRNG driver code
crypto: omap-sham - correct dma burst size
crypto: omap-sham - Enable Polling mode if DMA fails
crypto: tegra-aes - bitwise vs logical and
crypto: sahara - checking the wrong variable
This patch reinstates commits
67822649d7305caf3dd50ed46c27b99c94eff996
39761214eefc6b070f29402aa1165f24d789b3f7
0b95a7f85718adcbba36407ef88bba0a7379ed03
31d939625a9a20b1badd2d4e6bf6fd39fa523405
2d31e518a42828df7877bca23a958627d60408bc
Now that module softdeps are in the kernel we can use that to resolve
the boot issue which cause the revert.
Merge upstream tree in order to reinstate crct10dif.
v2: Fix bug in statement as pointed out by Herbert Xu. Kudos to pipacs.
Author: PaX Team <pageexec at freemail.hu>
ML-Post: http://lists.cs.uiuc.edu/pipermail/llvm-commits/Week-of-Mon-20120507/142707.html
URL: http://llvm.linuxfoundation.org
Merge: Jan-Simon Möller <dl9pf at gmx.de>
Description:
Fix for warning:
linux/crypto/fcrypt.c:143:47: warning: signed shift result (0x598000000) requires 36 bits to
represent, but 'int' only has 32 bits [-Wshift-overflow]
Z(0xef), Z(0x70), Z(0xcf), Z(0xc2), Z(0x2a), Z(0xb3), Z(0x61), Z(0xad),
linux/crypto/fcrypt.c:113:29: note: expanded from macro 'Z'
linux/include/uapi/linux/byteorder/little_endian.h:38:53: note: expanded from macro
'__cpu_to_be32'
linux/include/uapi/linux/swab.h:116:21: note: expanded from macro '__swab32'
___constant_swab32(x) : \
linux/include/uapi/linux/swab.h:18:12: note: expanded from macro '___constant_swab32'
(((__u32)(x) & (__u32)0x0000ff00UL) << 8) | \
Solution - make sure we don't exceed the 32 bit range.
#define Z(x) cpu_to_be32(((x & 0x1f) << 27) | (x >> 5))
Signed-off-by: Jan-Simon Möller <dl9pf@gmx.de>
CC: pageexec@freemail.hu
CC: llvmlinux@lists.linuxfoundation.org
CC: behanw@converseincode.com
CC: herbert@gondor.apana.org.au
CC: davem@davemloft.net
CC: linux-crypto@vger.kernel.org
CC: linux-kernel@vger.kernel.org
Crypto layer only passes nbytes to encrypt but in omap-aes driver we need to
know number of SG elements to pass to dmaengine slave API. We add function for
the same to scatterwalk library.
Signed-off-by: Joel Fernandes <joelf@ti.com>
alignment
Adjust alignment and replace commas by semicolons in automatically
generated code.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Signed-off-by: Cristian Stoica <cristian.stoica@freescale.com>
Tables used from assembler should be marked __visible to let
the compiler know.
This patch removes redundant execution of the same test suite in cases
where alg and driver variables are the same (e.g. when alg_test is
called from tcrypt_test)
Reviewed-by: Horia Geanta <horia.geanta@freescale.com>
Reviewed-by: Ruchika Gupta <ruchika.gupta@freescale.com>
Pull crypto fixes from Herbert Xu:
"This push fixes a memory corruption issue in caam, as well as
reverting the new optimised crct10dif implementation as it breaks boot
on initrd systems.
Hopefully crct10dif will be reinstated once the supporting code is
added so that it doesn't break boot"
Revert "crypto: crct10dif - Wrap crc_t10dif function all to use crypto transform framework"
crypto: caam - Fixed the memory out of bound overwrite issue
This reverts commits
Unfortunately this change broke boot on some systems that used an
initrd which does not include the newly created crct10dif modules.
As these modules are required by sd_mod under certain configurations
this is a serious problem.
Add support for lz4 and lz4hc compression algorithm using the lib/lz4/*
codebase.
[akpm@linux-foundation.org: fix warnings]
Signed-off-by: Chanho Min <chanho.min@lge.com>
Cc: "Darrick J. Wong" <djwong@us.ibm.com>
Cc: Bob Pearson <rpearson@systemfabricworks.com>
Cc: Herbert Xu <herbert@gondor.hengli.com.au>
Cc: Yann Collet <yann.collet.73@gmail.com>
Cc: Kyungsik Lee <kyungsik.lee@lge.com>
- Do not idle omap device between crypto operations in one session.
- Added sha224/sha384 shims for SSSE3.
- More optimisations for camellia-aesni-avx2.
- Removed defunct blowfish/twofish AVX2 implementations.
- Added unaligned buffer self-tests.
- Added PCLMULQDQ optimisation for CRCT10DIF.
- Added support for Freescale's DCP co-processor
- Misc fixes.
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (44 commits)
crypto: testmgr - test hash implementations with unaligned buffers
crypto: testmgr - test AEADs with unaligned buffers
crypto: testmgr - test skciphers with unaligned buffers
crypto: testmgr - check that entries in alg_test_descs are in correct order
Revert "crypto: twofish - add AVX2/x86_64 assembler implementation of twofish cipher"
Revert "crypto: blowfish - add AVX2/x86_64 implementation of blowfish cipher"
crypto: camellia-aesni-avx2 - tune assembly code for more performance
hwrng: bcm2835 - fix MODULE_LICENSE tag
hwrng: nomadik - use clk_prepare_enable()
crypto: picoxcell - replace strict_strtoul() with kstrtoul()
crypto: dcp - Staticize local symbols
crypto: dcp - Use NULL instead of 0
crypto: dcp - Use devm_* APIs
crypto: dcp - Remove redundant platform_set_drvdata()
hwrng: use platform_{get,set}_drvdata()
crypto: omap-aes - Don't idle/start AES device between Encrypt operations
crypto: crct10dif - Use PTR_RET
crypto: ux500 - Cocci spatch "resource_size.spatch"
crypto: sha256_ssse3 - add sha224 support
crypto: sha512_ssse3 - add sha384 support
There have never been any real users of MEMSET operations since they
have been introduced in January 2007 by commit 7405f74badf4 ("dmaengine:
refactor dmaengine around dma_async_tx_descriptor"). Therefore remove
support for them for now, it can be always brought back when needed.
[sebastian.hesselbarth@gmail.com: fix drivers/dma/mv_xor]
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Cc: Vinod Koul <vinod.koul@intel.com>
Acked-by: Dan Williams <djbw@fb.com>
Cc: Tomasz Figa <t.figa@samsung.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Olof Johansson <olof@lixom.net>
Cc: Kevin Hilman <khilman@linaro.org>
For the workqueue creation interfaces that do not expect format strings,
make sure they cannot accidently be parsed that way. Additionally, clean
up calls made with a single parameter that would be handled as a format
string. Many callers are passing potentially dynamic string content, so
use "%s" in those cases to avoid any potential accidents.
The template lookup interface does not provide a way to use format
strings, so make sure that the interface cannot be abused accidentally.
On Thu, Jun 20, 2013 at 10:00:21AM +0200, Daniel Borkmann wrote:
> After having fixed a NULL pointer dereference in SCTP 1abd165e ("net:
> sctp: fix NULL pointer dereference in socket destruction"), I ran into
> the following NULL pointer dereference in the crypto subsystem with
> the same reproducer, easily hit each time:
> BUG: unable to handle kernel NULL pointer dereference at (null)
> IP: [<ffffffff81070321>] __wake_up_common+0x31/0x90
> PGD 0
> Oops: 0000 [#1] SMP
> Modules linked in: padlock_sha(F-) sha256_generic(F) sctp(F) libcrc32c(F) [..]
> CPU: 6 PID: 3326 Comm: cryptomgr_probe Tainted: GF 3.10.0-rc5+ #1
> Hardware name: Dell Inc. PowerEdge T410/0H19HD, BIOS 1.6.3 02/01/2011
> task: ffff88007b6cf4e0 ti: ffff88007b7cc000 task.ti: ffff88007b7cc000
> RIP: 0010:[<ffffffff81070321>] [<ffffffff81070321>] __wake_up_common+0x31/0x90
> RSP: 0018:ffff88007b7cde08 EFLAGS: 00010082
> RAX: ffffffffffffffe8 RBX: ffff88003756c130 RCX: 0000000000000000
> RDX: 0000000000000000 RSI: 0000000000000003 RDI: ffff88003756c130
> RBP: ffff88007b7cde48 R08: 0000000000000000 R09: ffff88012b173200
> R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000282
> R13: ffff88003756c138 R14: 0000000000000000 R15: 0000000000000000
> FS: 0000000000000000(0000) GS:ffff88012fc60000(0000) knlGS:0000000000000000
> CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
> CR2: 0000000000000000 CR3: 0000000001a0b000 CR4: 00000000000007e0
> DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
> DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
> Stack:
> ffff88007b7cde28 0000000300000000 ffff88007b7cde28 ffff88003756c130
> 0000000000000282 ffff88003756c128 ffffffff81227670 0000000000000000
> ffff88007b7cde78 ffffffff810722b7 ffff88007cdcf000 ffffffff81a90540
> Call Trace:
> [<ffffffff81227670>] ? crypto_alloc_pcomp+0x20/0x20
> [<ffffffff810722b7>] complete_all+0x47/0x60
> [<ffffffff81227708>] cryptomgr_probe+0x98/0xc0
> [<ffffffff8106760e>] kthread+0xce/0xe0
> [<ffffffff81067540>] ? kthread_freezable_should_stop+0x70/0x70
> [<ffffffff815450dc>] ret_from_fork+0x7c/0xb0
> Code: 41 56 41 55 41 54 53 48 83 ec 18 66 66 66 66 90 89 75 cc 89 55 c8
> 4c 8d 6f 08 48 8b 57 08 41 89 cf 4d 89 c6 48 8d 42 e
> RIP [<ffffffff81070321>] __wake_up_common+0x31/0x90
> RSP <ffff88007b7cde08>
> ---[ end trace b495b19270a4d37e ]---
> My assumption is that the following is happening: the minimal SCTP
> tool runs under ``echo 1 > /proc/sys/net/sctp/auth_enable'', hence
> it's making use of crypto_alloc_hash() via sctp_auth_init_hmacs().
> It forks itself, heavily allocates, binds, listens and waits in
> accept on sctp sockets, and then randomly kills some of them (no
> need for an actual client in this case to hit this). Then, again,
> allocating, binding, etc, and then killing child processes.
> The problem that might be happening here is that cryptomgr requests
> the module to probe/load through cryptomgr_schedule_probe(), but
> before the thread handler cryptomgr_probe() returns, we return from
> the wait_for_completion_interruptible() function and probably already
> have cleared up larval, thus we run into a NULL pointer dereference
> when in cryptomgr_probe() complete_all() is being called.
> If we wait with wait_for_completion() instead, this panic will not
> occur anymore. This is valid, because in case a signal is pending,
> cryptomgr_probe() returns from probing anyway with properly calling
> complete_all().
The use of wait_for_completion_interruptible is intentional so that
we don't lock up the thread if a bug causes us to never wake up.
This bug is caused by the helper thread using the larval without
holding a reference count on it. If the helper thread completes
after the original thread requesting for help has gone away and
destroyed the larval, then we get the crash above.
So the fix is to hold a reference count on the larval.
Cc: <stable@vger.kernel.org> # 3.6+
Reported-by: Daniel Borkmann <dborkman@redhat.com>
Tested-by: Daniel Borkmann <dborkman@redhat.com>
This patch adds unaligned buffer tests for hashes.
The first new test is with one byte offset and the second test checks if
cra_alignmask for driver is big enough; for example, for testing a case
where cra_alignmask is set to 7, but driver really needs buffers to be
aligned to 16 bytes.
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi>
This patch adds unaligned buffer tests for AEADs.
This patch adds unaligned buffer tests for blkciphers.
Patch adds check for alg_test_descs list order, so that accidentically
misplaced entries are found quicker. Duplicate entries are also checked for.
twofish cipher"
This reverts commit cf1521a1a5e21fd1e79a458605c4282fbfbbeee2.
Instruction (vpgatherdd) that this implementation relied on turned out to be
slow performer on real hardware (i5-4570). The previous 8-way twofish/AVX
implementation is therefore faster and this implementation should be removed.
Converting this implementation to use the same method as in twofish/AVX for
table look-ups would give additional ~3% speed up vs twofish/AVX, but would
hardly be worth of the added code and binary size.
This reverts commit 604880107010a1e5794552d184cd5471ea31b973.
slow performer on real hardware (i5-4570). The previous 4-way blowfish
It appears that the performance of 'vpgatherdd' is suboptimal for this kind of
workload (tested on Core i5-4570) and causes blowfish-avx2 to be significantly
slower than blowfish-amd64. So disable the AVX2 implementation to avoid
performance regressions.
workload (tested on Core i5-4570) and causes twofish_avx2 to be significantly
slower than twofish_avx. So disable the AVX2 implementation to avoid
'sha512_generic' should set driver name now that there is alternative sha512
provider (sha512_ssse3).
These are simple tests to do sanity check of CRC T10 DIF hash. The
correctness of the transform can be checked with the command
modprobe tcrypt mode=47
The speed of the transform can be evaluated with the command
modprobe tcrypt mode=320
Set the cpu frequency to constant and turn turbo off when running the
speed test so the frequency governor will not tweak the frequency and
affects the measurements.
crypto transform
Glue code that plugs the PCLMULQDQ accelerated CRC T10 DIF hash into the
crypto framework. The config CRYPTO_CRCT10DIF_PCLMUL should be turned
on to enable the feature. The crc_t10dif crypto library function will
use this faster algorithm when crct10dif_pclmul module is loaded.
