path: root/crypto
2009-07-22crypto: sha512_generic - Use 64-bit countersHerbert Xu
This patch replaces the 32-bit counters in sha512_generic with 64-bit counters. It also switches the bit count to the simpler byte count. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-22crypto: sha512 - Export struct sha512_stateHerbert Xu
This patch renames struct sha512_ctx and exports it as struct sha512_state so that other sha512 implementations can use it as the reference structure for exporting their state. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-22crypto: xcbc - Fix shash conversionHerbert Xu
Although xcbc was converted to shash, it didn't obey the new requirement that all hash state must be stored in the descriptor rather than the transform. This patch fixes this issue and also optimises away the rekeying by precomputing K2 and K3 within setkey. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-22crypto: xcbc - Use crypto_xorHerbert Xu
This patch replaces the local xor function with the generic crypto_xor function. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-22crypto: cryptd - Add finup/export/import for hashHerbert Xu
This patch adds the finup/export/import functions to the cryptd ahash implementation. We simply invoke the underlying shash operations. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-15crypto: shash - Fix async finup handling of null digestHerbert Xu
When shash_ahash_finup encounters a null request, we end up not calling the underlying final function. This patch fixes that. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-15crypto: ahash - Fix setkey crashHerbert Xu
When the alignment check was made unconditional for ahash we may end up crashing on shash algorithms because we're always calling alg->setkey instead of tfm->setkey. This patch fixes it. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-15crypto: xcbc - Fix incorrect error value when creating instanceHerbert Xu
If shash_alloc_instance() fails, we return the wrong error value. This patch fixes it. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-15crypto: hmac - Fix incorrect error value when creating instanceHerbert Xu
2009-07-15crypto: cryptd - Fix uninitialized return valueSteffen Klassert
If cryptd_alloc_instance() fails, the return value is uninitialized. This patch fixes this by setting the return value. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-15crypto: ahash - Add unaligned handling and default operationsHerbert Xu
This patch exports the finup operation where available and adds a default finup operation for ahash. The operations final, finup and digest also will now deal with unaligned result pointers by copying it. Finally export/import operations are will now be exported too. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: ahash - Use GFP_KERNEL in unaligned setkeyHerbert Xu
We currently use GFP_ATOMIC in the unaligned setkey function to allocate the temporary aligned buffer. Since setkey must be called in a sleepable context, we can use GFP_KERNEL instead. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: shash - Fix alignment in unaligned operationsHerbert Xu
When we encounter an unaligned pointer we are supposed to copy it to a temporary aligned location. However the temporary buffer isn't aligned properly. This patch fixes that. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: hash - Zap unaligned buffersHerbert Xu
Some unaligned buffers on the stack weren't zapped properly which may cause secret data to be leaked. This patch fixes them by doing a zero memset. It is also possible for us to place random kernel stack contents in the digest buffer if a digest operation fails. This is fixed by only copying if the operation succeeded. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: ahash - Remove old_ahash_algHerbert Xu
Now that all ahash implementations have been converted to the new ahash type, we can remove old_ahash_alg and its associated support. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: cryptd - Switch to new style ahashHerbert Xu
This patch changes cryptd to use the new style ahash type. In particular, the instance is enlarged to encapsulate the new ahash_alg structure. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: cryptd - Switch to template create APIHerbert Xu
This patch changes cryptd to use the template->create function instead of alloc in anticipation for the switch to new style ahash algorithms. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: tcrypt - Add mask parameterHerbert Xu
This patch adds a mask parameter to complement the existing type parameter. This is useful when instantiating algorithms that require a mask other than the default, e.g., ahash algorithms. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: ahash - Add instance/spawn supportHerbert Xu
This patch adds support for creating ahash instances and using ahash as spawns. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: ahash - Convert to new style algorithmsHerbert Xu
This patch converts crypto_ahash to the new style. The old ahash algorithm type is retained until the existing ahash implementations are also converted. All ahash users will automatically get the new crypto_ahash type. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: api - Remove frontend argument from extsize/init_tfmHerbert Xu
As the extsize and init_tfm functions belong to the frontend the frontend argument is superfluous. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: cryptd - Use crypto_ahash_set_reqsizeHerbert Xu
This patch makes cryptd use crypto_ahash_set_reqsize to avoid accessing crypto_ahash directly. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: cryptd - Use shash algorithmsHerbert Xu
This patch changes cryptd to use shash algorithms instead of the legacy hash interface. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: shash - Export async functionsHerbert Xu
This patch exports the async functions so that they can be reused by cryptd when it switches over to using shash. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: hash - Remove legacy hash/digest implementaionHerbert Xu
This patch removes the implementation of hash and digest now that no algorithms use them anymore. The interface though will remain until the users are converted across. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: authenc - Remove reference to crypto_hashHerbert Xu
Now that there are no more legacy hash implementations we can remove the reference to crypto_hash. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: xcbc - Switch to shashHerbert Xu
This patch converts the xcbc algorithm to the new shash type. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: hmac - Switch to shashHerbert Xu
This patch changes hmac to the new shash interface. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: shash - Make descsize a run-time attributeHerbert Xu
This patch changes descsize to a run-time attribute so that implementations can change it in their init functions. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-12crypto: shash - Move null setkey check to registration timeHerbert Xu
This patch moves the run-time null setkey check to shash_prepare_alg just like we did for finup/digest. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-11crypto: sha256_generic - Add export/import supportHerbert Xu
This patch adds export/import support to sha256_generic. The exported type is defined by struct sha256_state, which is basically the entire descriptor state of sha256_generic. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-11crypto: sha256_generic - Use 64-bit counter like sha1Herbert Xu
This patch replaces the two 32-bit counter code in sha256_generic with the simpler 64-bit counter code from sha1. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-11crypto: sha1_generic - Add export/import supportHerbert Xu
This patch adds export/import support to sha1_generic. The exported type is defined by struct sha1_state, which is basically the entire descriptor state of sha1_generic. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-11crypto: shash - Move finup/digest null checks to registration timeHerbert Xu
This patch moves the run-time null finup/digest checks to the shash_prepare_alg function which is run at registration time. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-11crypto: shash - Export/import hash state onlyHerbert Xu
This patch replaces the full descriptor export with an export of the partial hash state. This allows the use of a consistent export format across all implementations of a given algorithm. This is useful because a number of cases require the use of the partial hash state, e.g., PadLock can use the SHA1 hash state to get around the fact that it can only hash contiguous data chunks. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-09crypto: api - Fix crypto_drop_spawn crash on blank spawnsHerbert Xu
This patch allows crypto_drop_spawn to be called on spawns that have not been initialised or have failed initialisation. This fixes potential crashes during initialisation without adding special case code. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-08crypto: shash - Propagate reinit return valueHerbert Xu
This patch fixes crypto_shash_import to propagate the value returned by reinit. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-08crypto: shash - Use finup in default digestHerbert Xu
This patch simplifies the default digest function by using finup. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-08crypto: shash - Add shash_register_instanceHerbert Xu
This patch adds shash_register_instance so that shash instances can be registered without bypassing the shash checks applied to normal algorithms. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-08crypto: shash - Add shash_attr_alg2 helperHerbert Xu
This patch adds the helper shash_attr_alg2 which locates a shash algorithm based on the information in the given attribute. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-08crypto: api - Add crypto_attr_alg2 helperHerbert Xu
This patch adds the helper crypto_attr_alg2 which is similar to crypto_attr_alg but takes an extra frontend argument. This is intended to be used by new style algorithm types such as shash. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-08crypto: shash - Add spawn supportHerbert Xu
This patch adds the functions needed to create and use shash spawns, i.e., to use shash algorithms in a template. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-08crypto: api - Add new style spawn supportHerbert Xu
This patch modifies the spawn infrastructure to support new style algorithms like shash. In particular, this means storing the frontend type in the spawn and using crypto_create_tfm to allocate the tfm. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-08crypto: shash - Add shash_instanceHerbert Xu
This patch adds shash_instance and the associated alloc/free functions. This is meant to be an instance that with a shash algorithm under it. Note that the instance itself doesn't have to be shash. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-07crypto: api - Add crypto_alloc_instance2Herbert Xu
This patch adds a new argument to crypto_alloc_instance which sets aside some space before the instance for use by algorithms such as shash that place type-specific data before crypto_alg. For compatibility the function has been renamed so that existing users aren't affected. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-07crypto: api - Add new template create functionHerbert Xu
This patch introduces the template->create function intended to replace the existing alloc function. The intention is for create to handle the registration directly, whereas currently the caller of alloc has to handle the registration. This allows type-specific code to be run prior to registration. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-03crypto: ansi_prng - alloc cipher just in initSebastian Andrzej Siewior
As reported by Eric Sesterhenn the re-allocation of the cipher in reset leads to: |BUG: sleeping function called from invalid context at kernel/rwsem.c:21 |in_atomic(): 1, irqs_disabled(): 0, pid: 4926, name: modprobe |INFO: lockdep is turned off. |Pid: 4926, comm: modprobe Tainted: G M 2.6.31-rc1-22297-g5298976 #24 |Call Trace: | [<c011dd93>] __might_sleep+0xf9/0x101 | [<c0777aa0>] down_read+0x16/0x68 | [<c048bf04>] crypto_alg_lookup+0x16/0x34 | [<c048bf52>] crypto_larval_lookup+0x30/0xf9 | [<c048c038>] crypto_alg_mod_lookup+0x1d/0x62 | [<c048c13e>] crypto_alloc_base+0x1e/0x64 | [<c04bf991>] reset_prng_context+0xab/0x13f | [<c04e5cfc>] ? __spin_lock_init+0x27/0x51 | [<c04bfce1>] cprng_init+0x2a/0x42 | [<c048bb4c>] __crypto_alloc_tfm+0xfa/0x128 | [<c048c153>] crypto_alloc_base+0x33/0x64 | [<c04933c9>] alg_test_cprng+0x30/0x1f4 | [<c0493329>] alg_test+0x12f/0x19f | [<c0177f1f>] ? __alloc_pages_nodemask+0x14d/0x481 | [<d09219e2>] do_test+0xf9d/0x163f [tcrypt] | [<d0920de6>] do_test+0x3a1/0x163f [tcrypt] | [<d0926035>] tcrypt_mod_init+0x35/0x7c [tcrypt] | [<c010113c>] _stext+0x54/0x12c | [<d0926000>] ? tcrypt_mod_init+0x0/0x7c [tcrypt] | [<c01398a3>] ? up_read+0x16/0x2b | [<c0139fc4>] ? __blocking_notifier_call_chain+0x40/0x4c | [<c014ee8d>] sys_init_module+0xa9/0x1bf | [<c010292b>] sysenter_do_call+0x12/0x32 because a spin lock is held and crypto_alloc_base() may sleep. There is no reason to re-allocate the cipher, the state is resetted in ->setkey(). This patches makes the cipher allocation a one time thing and moves it to init. Reported-by: Eric Sesterhenn <eric.sesterhenn@lsexperts.de> Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-03crypto: ansi_prng - Use just a BH lockSebastian Andrzej Siewior
The current code uses a mix of sping_lock() & spin_lock_irqsave(). This can lead to deadlock with the correct timming & cprng_get_random() + cprng_reset() sequence. I've converted them to bottom half locks since all three user grab just a BH lock so this runs probably in softirq :) Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-02crypto: testmgr - Allow implementation-specific testsHerbert Xu
This patch adds the support for testing specific implementations. This should only be used in very specific situations. Right now this means specific implementations of random number generators. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-01dmaengine: move HIGHMEM64G restriction to ASYNC_TX_DMADan Williams
On HIGHMEM64G systems dma_addr_t is known to be larger than (void *) which precludes async_xor from performing dma address conversions by reusing the input parameter address list. However, other parts of the dmaengine infrastructure do not suffer this constraint, so the HIGHMEM64G restriction can be down-levelled. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
