path: root/crypto
2009-08-20crypto: fips - Depend on ansi_cprngNeil Horman
What about something like this? It defaults the CPRNG to m and makes FIPS dependent on the CPRNG. That way you get a module build by default, but you can change it to y manually during config and still satisfy the dependency, and if you select N it disables FIPS as well. I rather like that better than making FIPS a tristate. I just tested it out here and it seems to work well. Let me know what you think Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-08-14crypto: blkcipher - Do not use eseqiv on stream ciphersHerbert Xu
Recently we switched to using eseqiv on SMP machines in preference over chainiv. However, eseqiv does not support stream ciphers so they should still default to chainiv. This patch applies the same check as done by eseqiv to weed out the stream ciphers. In particular, all algorithms where the IV size is not equal to the block size will now default to chainiv. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-08-13crypto: ctr - Use chainiv on raw counter modeHerbert Xu
Raw counter mode only works with chainiv, which is no longer the default IV generator on SMP machines. This broke raw counter mode as it can no longer instantiate as a givcipher. This patch fixes it by always picking chainiv on raw counter mode. This is based on the diagnosis and a patch by Huang Ying. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-08-13Revert crypto: fips - Select CPRNGHerbert Xu
This reverts commit 215ccd6f55a2144bd553e0a3d12e1386f02309fd. It causes CPRNG and everything selected by it to be built-in whenever FIPS is enabled. The problem is that it is selecting a tristate from a bool, which is usually not what is intended. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-08-13crypto: rng - Fix typoChristian Kujau
Correct a typo in crypto/rng.c Signed-off-by: Christian Kujau <lists@nerdbynature.de> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-08-06crypto: cryptd - Add support to access underlaying shashHuang Ying
cryptd_alloc_ahash() will allocate a cryptd-ed ahash for specified algorithm name. The new allocated one is guaranteed to be cryptd-ed ahash, so the shash underlying can be gotten via cryptd_ahash_child(). Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-08-06crypto: gcm - Use GHASH digest algorithmHuang Ying
Remove the dedicated GHASH implementation in GCM, and uses the GHASH digest algorithm instead. This will make GCM uses hardware accelerated GHASH implementation automatically if available. ahash instead of shash interface is used, because some hardware accelerated GHASH implementation needs asynchronous interface. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-08-06crypto: ghash - Add GHASH digest algorithm for GCMHuang Ying
GHASH is implemented as a shash algorithm. The actual implementation is copied from gcm.c. This makes it possible to add architecture/hardware accelerated GHASH implementation. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-08-05crypto: authenc - Convert to ahashSteffen Klassert
This patch converts authenc to the new ahash interface. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-30Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: dmaengine: at_hdmac: add DMA slave transfers dmaengine: at_hdmac: new driver for the Atmel AHB DMA Controller dmaengine: dmatest: correct thread_count while using multiple thread per channel dmaengine: dmatest: add a maximum number of test iterations drivers/dma: Remove unnecessary semicolons drivers/dma/fsldma.c: Remove unnecessary semicolons dmaengine: move HIGHMEM64G restriction to ASYNC_TX_DMA fsldma: do not clear bandwidth control bits on the 83xx controller fsldma: enable external start for the 83xx controller fsldma: use PCI Read Multiple command
2009-07-24crypto: hmac - Prehash ipad/opadHerbert Xu
This patch uses crypto_shash_export/crypto_shash_import to prehash ipad/opad to speed up hmac. This is partly based on a similar patch by Steffen Klassert. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-24crypto: aes - Undefined behaviour in crypto_aes_expand_keyPhil Carmody
It's undefined behaviour in C to write outside the bounds of an array. The key expansion routine takes a shortcut of creating 8 words at a time, but this creates 4 additional words which don't fit in the array. As everyone is hopefully now aware, GCC is at liberty to make any assumptions and optimisations it likes in situations where it can detect that UB has occured, up to and including nasal demons, and as the indices being accessed in the array are trivially calculable, it's rash to invite gcc to do take any liberties at all. Signed-off-by: Phil Carmody <ext-phil.2.carmody@nokia.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-24crypto: shash - Test for the algorithms import function before exporting itSteffen Klassert
crypto_init_shash_ops_async() tests for setkey and not for import before exporting the algorithms import function to ahash. This patch fixes this. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-24crypto: ahash - Use GFP_KERNEL on allocation if the request can sleepSteffen Klassert
ahash_op_unaligned() and ahash_def_finup() allocate memory atomically, regardless whether the request can sleep or not. This patch changes this to use GFP_KERNEL if the request can sleep. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-22crypto: shash - Require all algorithms to support export/importHerbert Xu
This patch provides a default export/import function for all shash algorithms. It simply copies the descriptor context as is done by sha1_generic. This in essence means that all existing shash algorithms now support export/import. This is something that will be depended upon in implementations such as hmac. Therefore all new shash and ahash implementations must support export/import. For those that cannot obtain a partial result, padlock-sha's fallback model should be used so that a partial result is always available. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-22crypto: sha512_generic - Use 64-bit countersHerbert Xu
This patch replaces the 32-bit counters in sha512_generic with 64-bit counters. It also switches the bit count to the simpler byte count. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-22crypto: sha512 - Export struct sha512_stateHerbert Xu
This patch renames struct sha512_ctx and exports it as struct sha512_state so that other sha512 implementations can use it as the reference structure for exporting their state. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-22crypto: xcbc - Fix shash conversionHerbert Xu
Although xcbc was converted to shash, it didn't obey the new requirement that all hash state must be stored in the descriptor rather than the transform. This patch fixes this issue and also optimises away the rekeying by precomputing K2 and K3 within setkey. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-22crypto: xcbc - Use crypto_xorHerbert Xu
This patch replaces the local xor function with the generic crypto_xor function. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-22crypto: cryptd - Add finup/export/import for hashHerbert Xu
This patch adds the finup/export/import functions to the cryptd ahash implementation. We simply invoke the underlying shash operations. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-15crypto: shash - Fix async finup handling of null digestHerbert Xu
When shash_ahash_finup encounters a null request, we end up not calling the underlying final function. This patch fixes that. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-15crypto: ahash - Fix setkey crashHerbert Xu
When the alignment check was made unconditional for ahash we may end up crashing on shash algorithms because we're always calling alg->setkey instead of tfm->setkey. This patch fixes it. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-15crypto: xcbc - Fix incorrect error value when creating instanceHerbert Xu
If shash_alloc_instance() fails, we return the wrong error value. This patch fixes it. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-15crypto: hmac - Fix incorrect error value when creating instanceHerbert Xu
2009-07-15crypto: cryptd - Fix uninitialized return valueSteffen Klassert
If cryptd_alloc_instance() fails, the return value is uninitialized. This patch fixes this by setting the return value. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-15crypto: ahash - Add unaligned handling and default operationsHerbert Xu
This patch exports the finup operation where available and adds a default finup operation for ahash. The operations final, finup and digest also will now deal with unaligned result pointers by copying it. Finally export/import operations are will now be exported too. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: ahash - Use GFP_KERNEL in unaligned setkeyHerbert Xu
We currently use GFP_ATOMIC in the unaligned setkey function to allocate the temporary aligned buffer. Since setkey must be called in a sleepable context, we can use GFP_KERNEL instead. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: shash - Fix alignment in unaligned operationsHerbert Xu
When we encounter an unaligned pointer we are supposed to copy it to a temporary aligned location. However the temporary buffer isn't aligned properly. This patch fixes that. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: hash - Zap unaligned buffersHerbert Xu
Some unaligned buffers on the stack weren't zapped properly which may cause secret data to be leaked. This patch fixes them by doing a zero memset. It is also possible for us to place random kernel stack contents in the digest buffer if a digest operation fails. This is fixed by only copying if the operation succeeded. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: ahash - Remove old_ahash_algHerbert Xu
Now that all ahash implementations have been converted to the new ahash type, we can remove old_ahash_alg and its associated support. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: cryptd - Switch to new style ahashHerbert Xu
This patch changes cryptd to use the new style ahash type. In particular, the instance is enlarged to encapsulate the new ahash_alg structure. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: cryptd - Switch to template create APIHerbert Xu
This patch changes cryptd to use the template->create function instead of alloc in anticipation for the switch to new style ahash algorithms. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: tcrypt - Add mask parameterHerbert Xu
This patch adds a mask parameter to complement the existing type parameter. This is useful when instantiating algorithms that require a mask other than the default, e.g., ahash algorithms. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: ahash - Add instance/spawn supportHerbert Xu
This patch adds support for creating ahash instances and using ahash as spawns. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: ahash - Convert to new style algorithmsHerbert Xu
This patch converts crypto_ahash to the new style. The old ahash algorithm type is retained until the existing ahash implementations are also converted. All ahash users will automatically get the new crypto_ahash type. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: api - Remove frontend argument from extsize/init_tfmHerbert Xu
As the extsize and init_tfm functions belong to the frontend the frontend argument is superfluous. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: cryptd - Use crypto_ahash_set_reqsizeHerbert Xu
This patch makes cryptd use crypto_ahash_set_reqsize to avoid accessing crypto_ahash directly. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: cryptd - Use shash algorithmsHerbert Xu
This patch changes cryptd to use shash algorithms instead of the legacy hash interface. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: shash - Export async functionsHerbert Xu
This patch exports the async functions so that they can be reused by cryptd when it switches over to using shash. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: hash - Remove legacy hash/digest implementaionHerbert Xu
This patch removes the implementation of hash and digest now that no algorithms use them anymore. The interface though will remain until the users are converted across. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: authenc - Remove reference to crypto_hashHerbert Xu
Now that there are no more legacy hash implementations we can remove the reference to crypto_hash. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: xcbc - Switch to shashHerbert Xu
This patch converts the xcbc algorithm to the new shash type. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: hmac - Switch to shashHerbert Xu
This patch changes hmac to the new shash interface. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: shash - Make descsize a run-time attributeHerbert Xu
This patch changes descsize to a run-time attribute so that implementations can change it in their init functions. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-12crypto: shash - Move null setkey check to registration timeHerbert Xu
This patch moves the run-time null setkey check to shash_prepare_alg just like we did for finup/digest. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-11crypto: sha256_generic - Add export/import supportHerbert Xu
This patch adds export/import support to sha256_generic. The exported type is defined by struct sha256_state, which is basically the entire descriptor state of sha256_generic. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-11crypto: sha256_generic - Use 64-bit counter like sha1Herbert Xu
This patch replaces the two 32-bit counter code in sha256_generic with the simpler 64-bit counter code from sha1. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-11crypto: sha1_generic - Add export/import supportHerbert Xu
This patch adds export/import support to sha1_generic. The exported type is defined by struct sha1_state, which is basically the entire descriptor state of sha1_generic. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-11crypto: shash - Move finup/digest null checks to registration timeHerbert Xu
This patch moves the run-time null finup/digest checks to the shash_prepare_alg function which is run at registration time. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-11crypto: shash - Export/import hash state onlyHerbert Xu
This patch replaces the full descriptor export with an export of the partial hash state. This allows the use of a consistent export format across all implementations of a given algorithm. This is useful because a number of cases require the use of the partial hash state, e.g., PadLock can use the SHA1 hash state to get around the fact that it can only hash contiguous data chunks. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
