path: root/crypto
2012-04-27crypto: sha512 - Fix byte counter overflow in SHA-512Kent Yoder
commit 25c3d30c918207556ae1d6e663150ebdf902186b upstream. The current code only increments the upper 64 bits of the SHA-512 byte counter when the number of bytes hashed happens to hit 2^64 exactly. This patch increments the upper 64 bits whenever the lower 64 bits overflows. Signed-off-by: Kent Yoder <key@linux.vnet.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: sha512 - use standard ror64()
2012-02-16crypto: sha512 - use standard ror64()Alexey Dobriyan
Use standard ror64() instead of hand-written. There is no standard ror64, so create it. The difference is shift value being "unsigned int" instead of uint64_t (for which there is no reason). gcc starts to emit native ROR instructions which it doesn't do for some reason currently. This should make the code faster. Patch survives in-tree crypto test and ping flood with hmac(sha512) on. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-02-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
This updates the sha512 fix so that it doesn't cause excessive stack usage on i386. This is done by reverting to the original code, and avoiding the W duplication by moving its initialisation into the loop. As the underlying code is in fact the one that we have used for years, I'm pushing this now instead of postponing to the next cycle. * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: sha512 - Avoid stack bloat on i386 crypto: sha512 - Use binary and instead of modulus
2012-02-05crypto: sha512 - Avoid stack bloat on i386Herbert Xu
Unfortunately in reducing W from 80 to 16 we ended up unrolling the loop twice. As gcc has issues dealing with 64-bit ops on i386 this means that we end up using even more stack space (>1K). This patch solves the W reduction by moving LOAD_OP/BLEND_OP into the loop itself, thus avoiding the need to duplicate it. While the stack space still isn't great (>0.5K) it is at least in the same ball park as the amount of stack used for our C sha1 implementation. Note that this patch basically reverts to the original code so the diff looks bigger than it really is. Cc: stable@vger.kernel.org Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-01-26crypto: sha512 - Use binary and instead of modulusHerbert Xu
The previous patch used the modulus operator over a power of 2 unnecessarily which may produce suboptimal binary code. This patch changes changes them to binary ands instead. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-01-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: sha512 - reduce stack usage to safe number crypto: sha512 - make it work, undo percpu message schedule
2012-01-14Merge branch 'for-linus' of git://selinuxproject.org/~jmorris/linux-securityLinus Torvalds
* 'for-linus' of git://selinuxproject.org/~jmorris/linux-security: capabilities: remove __cap_full_set definition security: remove the security_netlink_recv hook as it is equivalent to capable() ptrace: do not audit capability check when outputing /proc/pid/stat capabilities: remove task_ns_* functions capabitlies: ns_capable can use the cap helpers rather than lsm call capabilities: style only - move capable below ns_capable capabilites: introduce new has_ns_capabilities_noaudit capabilities: call has_ns_capability from has_capability capabilities: remove all _real_ interfaces capabilities: introduce security_capable_noaudit capabilities: reverse arguments to security_capable capabilities: remove the task from capable LSM hook entirely selinux: sparse fix: fix several warnings in the security server cod selinux: sparse fix: fix warnings in netlink code selinux: sparse fix: eliminate warnings for selinuxfs selinux: sparse fix: declare selinux_disable() in security.h selinux: sparse fix: move selinux_complete_init selinux: sparse fix: make selinux_secmark_refcount static SELinux: Fix RCU deref check warning in sel_netport_insert() Manually fix up a semantic mis-merge wrt security_netlink_recv(): - the interface was removed in commit fd7784615248 ("security: remove the security_netlink_recv hook as it is equivalent to capable()") - a new user of it appeared in commit a38f7907b926 ("crypto: Add userspace configuration API") causing no automatic merge conflict, but Eric Paris pointed out the issue.
2012-01-15crypto: sha512 - reduce stack usage to safe numberAlexey Dobriyan
For rounds 16--79, W[i] only depends on W[i - 2], W[i - 7], W[i - 15] and W[i - 16]. Consequently, keeping all W[80] array on stack is unnecessary, only 16 values are really needed. Using W[16] instead of W[80] greatly reduces stack usage (~750 bytes to ~340 bytes on x86_64). Line by line explanation: * BLEND_OP array is "circular" now, all indexes have to be modulo 16. Round number is positive, so remainder operation should be without surprises. * initial full message scheduling is trimmed to first 16 values which come from data block, the rest is calculated before it's needed. * original loop body is unrolled version of new SHA512_0_15 and SHA512_16_79 macros, unrolling was done to not do explicit variable renaming. Otherwise it's the very same code after preprocessing. See sha1_transform() code which does the same trick. Patch survives in-tree crypto test and original bugreport test (ping flood with hmac(sha512). See FIPS 180-2 for SHA-512 definition http://csrc.nist.gov/publications/fips/fips180-2/fips180-2withchangenotice.pdf Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: stable@vger.kernel.org Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-01-15crypto: sha512 - make it work, undo percpu message scheduleAlexey Dobriyan
commit f9e2bca6c22d75a289a349f869701214d63b5060 aka "crypto: sha512 - Move message schedule W[80] to static percpu area" created global message schedule area. If sha512_update will ever be entered twice, hash will be silently calculated incorrectly. Probably the easiest way to notice incorrect hashes being calculated is to run 2 ping floods over AH with hmac(sha512): #!/usr/sbin/setkey -f flush; spdflush; add IP1 IP2 ah 25 -A hmac-sha512 0x00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000025; add IP2 IP1 ah 52 -A hmac-sha512 0x00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000052; spdadd IP1 IP2 any -P out ipsec ah/transport//require; spdadd IP2 IP1 any -P in ipsec ah/transport//require; XfrmInStateProtoError will start ticking with -EBADMSG being returned from ah_input(). This never happens with, say, hmac(sha1). With patch applied (on BOTH sides), XfrmInStateProtoError does not tick with multiple bidirectional ping flood streams like it doesn't tick with SHA-1. After this patch sha512_transform() will start using ~750 bytes of stack on x86_64. This is OK for simple loads, for something more heavy, stack reduction will be done separatedly. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: stable@vger.kernel.org Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-01-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (54 commits) crypto: gf128mul - remove leftover "(EXPERIMENTAL)" in Kconfig crypto: serpent-sse2 - remove unneeded LRW/XTS #ifdefs crypto: serpent-sse2 - select LRW and XTS crypto: twofish-x86_64-3way - remove unneeded LRW/XTS #ifdefs crypto: twofish-x86_64-3way - select LRW and XTS crypto: xts - remove dependency on EXPERIMENTAL crypto: lrw - remove dependency on EXPERIMENTAL crypto: picoxcell - fix boolean and / or confusion crypto: caam - remove DECO access initialization code crypto: caam - fix polarity of "propagate error" logic crypto: caam - more desc.h cleanups crypto: caam - desc.h - convert spaces to tabs crypto: talitos - convert talitos_error to struct device crypto: talitos - remove NO_IRQ references crypto: talitos - fix bad kfree crypto: convert drivers/crypto/* to use module_platform_driver() char: hw_random: convert drivers/char/hw_random/* to use module_platform_driver() crypto: serpent-sse2 - should select CRYPTO_CRYPTD crypto: serpent - rename serpent.c to serpent_generic.c crypto: serpent - cleanup checkpatch errors and warnings ...
2011-12-20crypto: gf128mul - remove leftover "(EXPERIMENTAL)" in KconfigJussi Kivilinna
CRYPTO_GF128MUL does not select EXPERIMENTAL anymore so remove the "(EXPERIMENTAL)" from its name. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-12-20crypto: serpent-sse2 - select LRW and XTSJussi Kivilinna
serpent-sse2 uses functions from LRW and XTS modules, so selecting would appear to be better option than using #ifdefs in serpent_sse2_glue.c to enable/disable LRW and XTS features. This also fixes build problem when serpent-sse2 would be build into kernel but XTS/LRW are build as modules. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-12-20crypto: twofish-x86_64-3way - select LRW and XTSJussi Kivilinna
twofish-x86_64-3way uses functions from LRW and XTS modules, so selecting would appear to be better option than using #ifdefs in twofish_glue_3way.c to enable/disable LRW and XTS features. This also fixes build problem when twofish-x86_64-3way would be build into kernel but XTS/LRW are build as modules. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-12-20crypto: xts - remove dependency on EXPERIMENTALJussi Kivilinna
XTS has been EXPERIMENTAL since it was introduced in 2007. I'd say by now it has seen enough testing to justify removal of EXPERIMENTAL tag. CC: Rik Snel <rsnel@cube.dyndns.org> Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-12-20crypto: lrw - remove dependency on EXPERIMENTALJussi Kivilinna
LRW has been EXPERIMENTAL since it was introduced in 2006. I'd say by now it has seen enough testing to justify removal of EXPERIMENTAL tag. CC: Rik Snel <rsnel@cube.dyndns.org> Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-30crypto: serpent-sse2 - should select CRYPTO_CRYPTDJussi Kivilinna
Since serpent_sse2_glue.c uses cryptd, CRYPTO_SERPENT_SSE2_X86_64 and CRYPTO_SERPENT_SSE2_586 should be selecting CRYPTO_CRYPTD. Reported-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-30crypto: serpent - rename serpent.c to serpent_generic.cJussi Kivilinna
Now that serpent.c has been cleaned from checkpatch warnings, we can do clean rename. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-30crypto: serpent - cleanup checkpatch errors and warningsJussi Kivilinna
Do checkpatch fixes before rename to keep rename patch simple and clean. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-21crypto: serpent-sse2 - add lrw supportJussi Kivilinna
Patch adds LRW support for serpent-sse2 by using lrw_crypt(). Patch has been tested with tcrypt and automated filesystem tests. Tcrypt benchmarks results (serpent-sse2/serpent_generic speed ratios): Benchmark results with tcrypt: Intel Celeron T1600 (x86_64) (fam:6, model:15, step:13): size lrw-enc lrw-dec 16B 1.00x 0.96x 64B 1.01x 1.01x 256B 3.01x 2.97x 1024B 3.39x 3.33x 8192B 3.35x 3.33x AMD Phenom II 1055T (x86_64) (fam:16, model:10): size lrw-enc lrw-dec 16B 0.98x 1.03x 64B 1.01x 1.04x 256B 2.10x 2.14x 1024B 2.28x 2.33x 8192B 2.30x 2.33x Intel Atom N270 (i586): size lrw-enc lrw-dec 16B 0.97x 0.97x 64B 1.47x 1.50x 256B 1.72x 1.69x 1024B 1.88x 1.81x 8192B 1.84x 1.79x Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-21crypto: serpent - add 4-way parallel i586/SSE2 assembler implementationJussi Kivilinna
Patch adds i586/SSE2 assembler implementation of serpent cipher. Assembler functions crypt data in four block chunks. Patch has been tested with tcrypt and automated filesystem tests. Tcrypt benchmarks results (serpent-sse2/serpent_generic speed ratios): Intel Atom N270: size ecb-enc ecb-dec cbc-enc cbc-dec ctr-enc ctr-dec 16 0.95x 1.12x 1.02x 1.07x 0.97x 0.98x 64 1.73x 1.82x 1.08x 1.82x 1.72x 1.73x 256 2.08x 2.00x 1.04x 2.07x 1.99x 2.01x 1024 2.28x 2.18x 1.05x 2.23x 2.17x 2.20x 8192 2.28x 2.13x 1.05x 2.23x 2.18x 2.20x Full output: http://koti.mbnet.fi/axh/kernel/crypto/atom-n270/serpent-generic.txt http://koti.mbnet.fi/axh/kernel/crypto/atom-n270/serpent-sse2.txt Userspace test results: Encryption/decryption of sse2-i586 vs generic on Intel Atom N270: encrypt: 2.35x decrypt: 2.54x Encryption/decryption of sse2-i586 vs generic on AMD Phenom II: encrypt: 1.82x decrypt: 2.51x Encryption/decryption of sse2-i586 vs generic on Intel Xeon E7330: encrypt: 2.99x decrypt: 3.48x Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-21crypto: serpent - add 8-way parallel x86_64/SSE2 assembler implementationJussi Kivilinna
Patch adds x86_64/SSE2 assembler implementation of serpent cipher. Assembler functions crypt data in eigth block chunks (two 4 block chunk SSE2 operations in parallel to improve performance on out-of-order CPUs). Glue code is based on one from AES-NI implementation, so requests from irq context are redirected to cryptd. v2: - add missing include of linux/module.h (appearently crypto.h used to include module.h, which changed for 3.2 by commit 7c926402a7e8c9b279968fd94efec8700ba3859e) Patch has been tested with tcrypt and automated filesystem tests. Tcrypt benchmarks results (serpent-sse2/serpent_generic speed ratios): AMD Phenom II 1055T (fam:16, model:10): size ecb-enc ecb-dec cbc-enc cbc-dec ctr-enc ctr-dec 16B 1.03x 1.01x 1.03x 1.05x 1.00x 0.99x 64B 1.00x 1.01x 1.02x 1.04x 1.02x 1.01x 256B 2.34x 2.41x 0.99x 2.43x 2.39x 2.40x 1024B 2.51x 2.57x 1.00x 2.59x 2.56x 2.56x 8192B 2.50x 2.54x 1.00x 2.55x 2.57x 2.57x Intel Celeron T1600 (fam:6, model:15, step:13): size ecb-enc ecb-dec cbc-enc cbc-dec ctr-enc ctr-dec 16B 0.97x 0.97x 1.01x 1.01x 1.01x 1.02x 64B 1.00x 1.00x 1.00x 1.02x 1.01x 1.01x 256B 3.41x 3.35x 1.00x 3.39x 3.42x 3.44x 1024B 3.75x 3.72x 0.99x 3.74x 3.75x 3.75x 8192B 3.70x 3.68x 0.99x 3.68x 3.69x 3.69x Full output: http://koti.mbnet.fi/axh/kernel/crypto/phenom-ii-1055t/serpent-generic.txt http://koti.mbnet.fi/axh/kernel/crypto/phenom-ii-1055t/serpent-sse2.txt http://koti.mbnet.fi/axh/kernel/crypto/celeron-t1600/serpent-generic.txt http://koti.mbnet.fi/axh/kernel/crypto/celeron-t1600/serpent-sse2.txt Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-13Merge branch 'master' into for-nextJiri Kosina
Sync with Linus tree to have 157550ff ("mtd: add GPMI-NAND driver in the config and Makefile") as I have patch depending on that one.
2011-11-13crypto: drop selects of bogus Kconfig symbolPaul Bolle
Commits 2cdc6899a8 ("crypto: ghash - Add GHASH digest algorithm for GCM") and 0e1227d356 ("crypto: ghash - Add PCLMULQDQ accelerated implementation") added "select CRYPTO_SHASH" to two entries. That Kconfig symbol doesn't exist. These two selects are nops. Drop them. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-11-11Merge git://github.com/herbertx/cryptoLinus Torvalds
* git://github.com/herbertx/crypto: crypto: algapi - Fix build problem with NET disabled crypto: user - Fix rwsem leak in crypto_user
2011-11-11crypto: algapi - Fix build problem with NET disabledHerbert Xu
The report functions use NLA_PUT so we need to ensure that NET is enabled. Reported-by: Luis Henriques <henrix@camandro.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-09crypto: fix typo in crypto/KconfigValdis.Kletnieks@vt.edu
Fix a typo in the Kconfig file help text. Signed-off-by: Valdis Kletnieks <valdis.kletnieks@vt.edu> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-09crypto: Unlink and free instances when deletedSteffen Klassert
We leak the crypto instance when we unregister an instance with crypto_del_alg(). Therefore we introduce crypto_unregister_instance() to unlink the crypto instance from the template's instances list and to free the recources of the instance properly. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-09crypto: ansi_cprng - enforce key != seed in fips modeJarod Wilson
Apparently, NIST is tightening up its requirements for FIPS validation with respect to RNGs. Its always been required that in fips mode, the ansi cprng not be fed key and seed material that was identical, but they're now interpreting FIPS 140-2, section AS07.09 as requiring that the implementation itself must enforce the requirement. Easy fix, we just do a memcmp of key and seed in fips_cprng_reset and call it a day. v2: Per Neil's advice, ensure slen is sufficiently long before we compare key and seed to avoid looking at potentially unallocated mem. CC: Stephan Mueller <smueller@atsec.com> CC: Steve Grubb <sgrubb@redhat.com> Signed-off-by: Jarod Wilson <jarod@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-09crypto: tcrypt - add xts(twofish) testsJussi Kivilinna
2011-11-09crypto: testmgr - add xts(twofish) test vectorsJussi Kivilinna
Add test vectors for xts(twofish). These are generated from xts(twofish) test vectors. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-09crypto: tcrypt - add xts(serpent) testsJussi Kivilinna
2011-11-09crypto: testmgr - add xts(serpent) test vectorsJussi Kivilinna
Add test vectors for xts(serpent). These are generated from xts(aes) test vectors. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-09crypto: xts: add interface for parallelized cipher implementationsJussi Kivilinna
Add xts_crypt() function that can be used by cipher implementations that can benefit from parallelized cipher operations. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-09crypto: xts - use blocksize constantJussi Kivilinna
XTS has fixed blocksize of 16. Define XTS_BLOCK_SIZE and use in place of crypto_cipher_blocksize(). Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-09crypto: twofish-x86_64-3way - add lrw supportJussi Kivilinna
Patch adds LRW support for twofish-x86_64-3way by using lrw_crypt(). Patch has been tested with tcrypt and automated filesystem tests. Tcrypt benchmarks results (twofish-3way/twofish-asm speed ratios): Intel Celeron T1600 (fam:6, model:15, step:13): size lrw-enc lrw-dec 16B 0.99x 1.00x 64B 1.17x 1.17x 256B 1.26x 1.27x 1024B 1.30x 1.31x 8192B 1.31x 1.32x AMD Phenom II 1055T (fam:16, model:10): size lrw-enc lrw-dec 16B 1.06x 1.01x 64B 1.08x 1.14x 256B 1.19x 1.20x 1024B 1.21x 1.22x 8192B 1.23x 1.24x Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-09crypto: tcrypt - add lrw(twofish) testsJussi Kivilinna
2011-11-09crypto: testmgr - add lrw(twofish) test vectorsJussi Kivilinna
Add test vectors for lrw(twofish). These are generated from lrw(aes) test vectors. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-09crypto: tcrypt - add lrw(serpent) testsJussi Kivilinna
2011-11-09crypto: testmgr - add lrw(serpent) test vectorsJussi Kivilinna
Add test vectors for lrw(serpent). These are generated from lrw(aes) test vectors. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-09crypto: lrw - add interface for parallelized cipher implementionsJussi Kivilinna
Export gf128mul table initialization routines and add lrw_crypt() function that can be used by cipher implementations that can benefit from parallelized cipher operations. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-09crypto: lrw - split gf128mul table initialization from setkeyJussi Kivilinna
Split gf128mul initialization from setkey so that it can be used outside lrw-module. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-09crypto: lrw - use blocksize constantJussi Kivilinna
LRW has fixed blocksize of 16. Define LRW_BLOCK_SIZE and use in place of crypto_cipher_blocksize(). Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-09crypto: lrw - fix memleakJussi Kivilinna
LRW module leaks child cipher memory when init_tfm() fails because of child block size not being 16. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-09crypto: serpent - rename module from serpent to serpent_genericJussi Kivilinna
Rename module from serpent.ko to serpent_generic.ko and add module alias. This is to allow assembler implementation to autoload on 'modprobe serpent'. Also add driver_name and priority for serpent cipher. CC: Dag Arne Osvik <osvik@ii.uib.no> Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-09crypto: serpent - export common functions for x86_64/i386-sse2 assembler ↵Jussi Kivilinna
implementations Serpent SSE2 assembler implementations only provide 4-way/8-way parallel functions and need setkey and one-block encrypt/decrypt functions. CC: Dag Arne Osvik <osvik@ii.uib.no> Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-09crypto: tcrypt - add serpent speed testsJussi Kivilinna
2011-11-09crypto: tcrypt - add test_acipher_speedJussi Kivilinna
Add test_acipher_speed for testing async block ciphers. Also include tests for aes/des/des3/ede as these appear to have ablk_cipher implementations available. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-09crypto: testmgr - add new serpent test vectorsJussi Kivilinna
Add new serpent tests for serpent_sse2 x86_64/i586 8-way/4-way code paths. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-06Merge branch 'modsplit-Oct31_2011' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux * 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits) Revert "tracing: Include module.h in define_trace.h" irq: don't put module.h into irq.h for tracking irqgen modules. bluetooth: macroize two small inlines to avoid module.h ip_vs.h: fix implicit use of module_get/module_put from module.h nf_conntrack.h: fix up fallout from implicit moduleparam.h presence include: replace linux/module.h with "struct module" wherever possible include: convert various register fcns to macros to avoid include chaining crypto.h: remove unused crypto_tfm_alg_modname() inline uwb.h: fix implicit use of asm/page.h for PAGE_SIZE pm_runtime.h: explicitly requires notifier.h linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h miscdevice.h: fix up implicit use of lists and types stop_machine.h: fix implicit use of smp.h for smp_processor_id of: fix implicit use of errno.h in include/linux/of.h of_platform.h: delete needless include <linux/module.h> acpi: remove module.h include from platform/aclinux.h miscdevice.h: delete unnecessary inclusion of module.h device_cgroup.h: delete needless include <linux/module.h> net: sch_generic remove redundant use of <linux/module.h> net: inet_timewait_sock doesnt need <linux/module.h> ... Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in - drivers/media/dvb/frontends/dibx000_common.c - drivers/media/video/{mt9m111.c,ov6650.c} - drivers/mfd/ab3550-core.c - include/linux/dmaengine.h
