path: root/crypto
2016-10-11kthread: kthread worker API cleanupPetr Mladek
A good practice is to prefix the names of functions by the name of the subsystem. The kthread worker API is a mix of classic kthreads and workqueues. Each worker has a dedicated kthread. It runs a generic function that process queued works. It is implemented as part of the kthread subsystem. This patch renames the existing kthread worker API to use the corresponding name from the workqueues API prefixed by kthread_: __init_kthread_worker() -> __kthread_init_worker() init_kthread_worker() -> kthread_init_worker() init_kthread_work() -> kthread_init_work() insert_kthread_work() -> kthread_insert_work() queue_kthread_work() -> kthread_queue_work() flush_kthread_work() -> kthread_flush_work() flush_kthread_worker() -> kthread_flush_worker() Note that the names of DEFINE_KTHREAD_WORK*() macros stay as they are. It is common that the "DEFINE_" prefix has precedence over the subsystem names. Note that INIT() macros and init() functions use different naming scheme. There is no good solution. There are several reasons for this solution: + "init" in the function names stands for the verb "initialize" aka "initialize worker". While "INIT" in the macro names stands for the noun "INITIALIZER" aka "worker initializer". + INIT() macros are used only in DEFINE() macros + init() functions are used close to the other kthread() functions. It looks much better if all the functions use the same scheme. + There will be also kthread_destroy_worker() that will be used close to kthread_cancel_work(). It is related to the init() function. Again it looks better if all functions use the same naming scheme. + there are several precedents for such init() function names, e.g. amd_iommu_init_device(), free_area_init_node(), jump_label_init_type(), regmap_init_mmio_clk(), + It is not an argument but it was inconsistent even before. [arnd@arndb.de: fix linux-next merge conflict] Link: http://lkml.kernel.org/r/20160908135724.1311726-1-arnd@arndb.de Link: http://lkml.kernel.org/r/1470754545-17632-3-git-send-email-pmladek@suse.com Suggested-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Petr Mladek <pmladek@suse.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Tejun Heo <tj@kernel.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Borislav Petkov <bp@suse.de> Cc: Michal Hocko <mhocko@suse.cz> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-10Merge branch 'linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6 Pull crypto updates from Herbert Xu: "Here is the crypto update for 4.9: API: - The crypto engine code now supports hashes. Algorithms: - Allow keys >= 2048 bits in FIPS mode for RSA. Drivers: - Memory overwrite fix for vmx ghash. - Add support for building ARM sha1-neon in Thumb2 mode. - Reenable ARM ghash-ce code by adding import/export. - Reenable img-hash by adding import/export. - Add support for multiple cores in omap-aes. - Add little-endian support for sha1-powerpc. - Add Cavium HWRNG driver for ThunderX SoC" * 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (137 commits) crypto: caam - treat SGT address pointer as u64 crypto: ccp - Make syslog errors human-readable crypto: ccp - clean up data structure crypto: vmx - Ensure ghash-generic is enabled crypto: testmgr - add guard to dst buffer for ahash_export crypto: caam - Unmap region obtained by of_iomap crypto: sha1-powerpc - little-endian support crypto: gcm - Fix IV buffer size in crypto_gcm_setkey crypto: vmx - Fix memory corruption caused by p8_ghash crypto: ghash-generic - move common definitions to a new header file crypto: caam - fix sg dump hwrng: omap - Only fail if pm_runtime_get_sync returns < 0 crypto: omap-sham - shrink the internal buffer size crypto: omap-sham - add support for export/import crypto: omap-sham - convert driver logic to use sgs for data xmit crypto: omap-sham - change the DMA threshold value to a define crypto: omap-sham - add support functions for sg based data handling crypto: omap-sham - rename sgl to sgl_tmp for deprecation crypto: omap-sham - align algorithms on word offset crypto: omap-sham - add context export/import stubs ...
2016-10-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Herbert Xu
Merge the crypto tree to pull in vmx ghash fix.
2016-10-06Merge tag 'dmaengine-4.9-rc1' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull dmaengine updates from Vinod Koul: "This is bit large pile of code which bring in some nice additions: - Error reporting: we have added a new mechanism for users of dmaenegine to register a callback_result which tells them the result of the dma transaction. Right now only one user (ntb) is using it. - As we discussed on KS mailing list and pointed out NO_IRQ has no place in kernel, this also remove NO_IRQ from dmaengine subsystem (both arm and ppc users) - Support for IOMMU slave transfers and its implementation for arm. - To get better build coverage, enable COMPILE_TEST for bunch of driver, and fix the warning and sparse complaints on these. - Apart from above, usual updates spread across drivers" * tag 'dmaengine-4.9-rc1' of git://git.infradead.org/users/vkoul/slave-dma: (169 commits) async_pq_val: fix DMA memory leak dmaengine: virt-dma: move function declarations dmaengine: omap-dma: Enable burst and data pack for SG DT: dmaengine: rcar-dmac: document R8A7743/5 support dmaengine: fsldma: Unmap region obtained by of_iomap dmaengine: jz4780: fix resource leaks on error exit return dma-debug: fix ia64 build, use PHYS_PFN dmaengine: coh901318: fix integer overflow when shifting more than 32 places dmaengine: edma: avoid uninitialized variable use dma-mapping: fix m32r build warning dma-mapping: fix ia64 build, use PHYS_PFN dmaengine: ti-dma-crossbar: enable COMPILE_TEST dmaengine: omap-dma: enable COMPILE_TEST dmaengine: edma: enable COMPILE_TEST dmaengine: ti-dma-crossbar: Fix of_device_id data parameter usage dmaengine: ti-dma-crossbar: Correct type for of_find_property() third parameter dmaengine/ARM: omap-dma: Fix the DMAengine compile test on non OMAP configs dmaengine: edma: Rename set_bits and remove unused clear_bits helper dmaengine: edma: Use correct type for of_find_property() third parameter dmaengine: edma: Fix of_device_id data parameter usage (legacy vs TPCC) ...
2016-10-05async_pq_val: fix DMA memory leakJustin Maggard
Add missing dmaengine_unmap_put(), so we don't OOM during RAID6 sync. Fixes: 1786b943dad0 ("async_pq_val: convert to dmaengine_unmap_data") Signed-off-by: Justin Maggard <jmaggard@netgear.com> Reviewed-by: Dan Williams <dan.j.williams@intel.com> Cc: <stable@vger.kernel.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2016-10-02crypto: testmgr - add guard to dst buffer for ahash_exportJan Stancek
Add a guard to 'state' buffer and warn if its consistency after call to crypto_ahash_export() changes, so that any write that goes beyond advertised statesize (and thus causing potential memory corruption [1]) is more visible. [1] https://marc.info/?l=linux-crypto-vger&m=147467656516085 Signed-off-by: Jan Stancek <jstancek@redhat.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Marcelo Cerri <marcelo.cerri@canonical.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-10-02crypto: gcm - Fix IV buffer size in crypto_gcm_setkeyOndrej Mosnáček
The cipher block size for GCM is 16 bytes, and thus the CTR transform used in crypto_gcm_setkey() will also expect a 16-byte IV. However, the code currently reserves only 8 bytes for the IV, causing an out-of-bounds access in the CTR transform. This patch fixes the issue by setting the size of the IV buffer to 16 bytes. Fixes: 84c911523020 ("[CRYPTO] gcm: Add support for async ciphers") Signed-off-by: Ondrej Mosnacek <omosnacek@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-10-02crypto: ghash-generic - move common definitions to a new header fileMarcelo Cerri
Move common values and types used by ghash-generic to a new header file so drivers can directly use ghash-generic as a fallback implementation. Fixes: cc333cd68dfa ("crypto: vmx - Adding GHASH routines for VMX module") Cc: stable@vger.kernel.org Signed-off-by: Marcelo Cerri <marcelo.cerri@canonical.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-09-22crypto: rsa-pkcs1pad - Handle leading zero for decryptionHerbert Xu
As the software RSA implementation now produces fixed-length output, we need to eliminate leading zeros in the calling code instead. This patch does just that for pkcs1pad decryption while signature verification was fixed in an earlier patch. Fixes: 9b45b7bba3d2 ("crypto: rsa - Generate fixed-length output") Reported-by: Mat Martineau <mathew.j.martineau@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-09-13crypto: squash lines for simple wrapper functionsMasahiro Yamada
Remove unneeded variables and assignments. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-09-13crypto: skcipher - Fix blkcipher walk OOM crashHerbert Xu
When we need to allocate a temporary blkcipher_walk_next and it fails, the code is supposed to take the slow path of processing the data block by block. However, due to an unrelated change we instead end up dereferencing the NULL pointer. This patch fixes it by moving the unrelated bsize setting out of the way so that we enter the slow path as inteded. Fixes: 7607bd8ff03b ("[CRYPTO] blkcipher: Added blkcipher_walk_virt_block") Cc: stable@vger.kernel.org Reported-by: xiakaixu <xiakaixu@huawei.com> Reported-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Tested-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
2016-09-13crypto: echainiv - Replace chaining with multiplicationHerbert Xu
The current implementation uses a global per-cpu array to store data which are used to derive the next IV. This is insecure as the attacker may change the stored data. This patch removes all traces of chaining and replaces it with multiplication of the salt and the sequence number. Fixes: a10f554fa7e0 ("crypto: echainiv - Add encrypted chain IV...") Cc: stable@vger.kernel.org Reported-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-09-07crypto: algif_hash - Handle NULL hashes correctlyHerbert Xu
Right now attempting to read an empty hash simply returns zeroed bytes, this patch corrects this by calling the digest function using an empty input. Reported-by: Russell King - ARM Linux <linux@armlinux.org.uk> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-09-07crypto: engine - permit to enqueue ashash_requestCorentin LABBE
The current crypto engine allow only ablkcipher_request to be enqueued. Thus denying any use of it for hardware that also handle hash algo. This patch modify the API for allowing to enqueue ciphers and hash. Since omap-aes/omap-des are the only users, this patch also convert them to the new cryptoengine API. Signed-off-by: Corentin Labbe <clabbe.montjoie@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-09-07crypto: engine - move crypto engine to its own headerCorentin LABBE
This patch move the whole crypto engine API to its own header crypto/engine.h. Signed-off-by: Corentin Labbe <clabbe.montjoie@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-09-07crypto: cryptd - initialize child shash_desc on importArd Biesheuvel
When calling .import() on a cryptd ahash_request, the structure members that describe the child transform in the shash_desc need to be initialized like they are when calling .init() Cc: stable@vger.kernel.org Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-08-31crypto: FIPS - allow tests to be disabled in FIPS modeStephan Mueller
In FIPS mode, additional restrictions may apply. If these restrictions are violated, the kernel will panic(). This patch allows test vectors for symmetric ciphers to be marked as to be skipped in FIPS mode. Together with the patch, the XTS test vectors where the AES key is identical to the tweak key is disabled in FIPS mode. This test vector violates the FIPS requirement that both keys must be different. Reported-by: Tapas Sarangi <TSarangi@trustwave.com> Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-08-31crypto: xor - Fix warning when XOR_SELECT_TEMPLATE is unsetHerbert Xu
This patch fixes an unused label warning triggered when the macro XOR_SELECT_TEMPLATE is not set. Fixes: 39457acda913 ("crypto: xor - skip speed test if the xor...") Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Suggested-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-08-31crypto: cryptd - Use correct tfm object for AEAD trackingHerbert Xu
The AEAD code path incorrectly uses the child tfm to track the cryptd refcnt, and then potentially frees the child tfm. Fixes: 81760ea6a95a ("crypto: cryptd - Add helpers to check...") Reported-by: Sowmini Varadhan <sowmini.varadhan@oracle.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-08-24crypto: rsa - allow keys >= 2048 bits in FIPS modeStephan Mueller
With a public notification, NIST now allows the use of RSA keys with a modulus >= 2048 bits. The new rule allows any modulus size >= 2048 bits provided that either 2048 or 3072 bits are supported at least so that the entire RSA implementation can be CAVS tested. This patch fixes the inability to boot the kernel in FIPS mode, because certs/x509.genkey defines a 4096 bit RSA key per default. This key causes the RSA signature verification to fail in FIPS mode without the patch below. Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-08-24crypto: drbg - fix error return codeWei Yongjun
Fix to return a negative error code from the error handling case instead of 0. Signed-off-by: Wei Yongjun <weiyj.lk@gmail.com> Acked-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-08-24crypto: xor - skip speed test if the xor function is selected automaticallyMartin Schwidefsky
If the architecture selected the xor function with XOR_SELECT_TEMPLATE the speed result of the do_xor_speed benchmark is of limited value. The speed measurement increases the bootup time a little, which can makes a difference for kernels used in container like virtual machines. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-08-16crypto: drbg - do not call drbg_instantiate in healt testStephan Mueller
When calling the DRBG health test in FIPS mode, the Jitter RNG is not yet present in the kernel crypto API which will cause the instantiation to fail and thus the health test to fail. As the health tests cover the enforcement of various thresholds, invoke the functions that are supposed to enforce the thresholds directly. This patch also saves precious seed. Reported-by: Tapas Sarangi <TSarangi@trustwave.com> Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-08-16crypto: xts - fix a little typoCorentin LABBE
The sentence 'Based on' is misspelled, respell it. Signed-off-by: LABBE Corentin <clabbe.montjoie@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-08-09crypto: testmgr - fix !x==y confusionYanjiang Jin
"if (!ret == template[i].fail)" is confusing to compilers (gcc5): crypto/testmgr.c: In function '__test_aead': crypto/testmgr.c:531:12: warning: logical not is only applied to the left hand side of comparison [-Wlogical-not-parentheses] if (!ret == template[i].fail) { ^ Let there be 'if (template[i].fail == !ret) '. Signed-off-by: Yanjiang Jin <yanjiang.jin@windriver.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-08-09crypto: powerpc - CRYPT_CRC32C_VPMSUM should depend on ALTIVECMichael Ellerman
The optimised crc32c implementation depends on VMX (aka. Altivec) instructions, so the kernel must be built with Altivec support in order for the crc32c code to build. Fixes: 6dd7a82cc54e ("crypto: powerpc - Add POWER8 optimised crc32c") Acked-by: Anton Blanchard <anton@samba.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-08-08crypto: sha3 - Add missing ULL suffixes for 64-bit constantsGeert Uytterhoeven
On 32-bit (e.g. with m68k-linux-gnu-gcc-4.1): crypto/sha3_generic.c:27: warning: integer constant is too large for ‘long’ type crypto/sha3_generic.c:28: warning: integer constant is too large for ‘long’ type crypto/sha3_generic.c:29: warning: integer constant is too large for ‘long’ type crypto/sha3_generic.c:29: warning: integer constant is too large for ‘long’ type crypto/sha3_generic.c:31: warning: integer constant is too large for ‘long’ type crypto/sha3_generic.c:31: warning: integer constant is too large for ‘long’ type crypto/sha3_generic.c:32: warning: integer constant is too large for ‘long’ type crypto/sha3_generic.c:32: warning: integer constant is too large for ‘long’ type crypto/sha3_generic.c:32: warning: integer constant is too large for ‘long’ type crypto/sha3_generic.c:33: warning: integer constant is too large for ‘long’ type crypto/sha3_generic.c:33: warning: integer constant is too large for ‘long’ type crypto/sha3_generic.c:34: warning: integer constant is too large for ‘long’ type crypto/sha3_generic.c:34: warning: integer constant is too large for ‘long’ type Fixes: 53964b9ee63b7075 ("crypto: sha3 - Add SHA-3 hash algorithm") Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-07-27Merge tag 'random_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random Pull random driver updates from Ted Ts'o: "A number of improvements for the /dev/random driver; the most important is the use of a ChaCha20-based CRNG for /dev/urandom, which is faster, more efficient, and easier to make scalable for silly/abusive userspace programs that want to read from /dev/urandom in a tight loop on NUMA systems. This set of patches also improves entropy gathering on VM's running on Microsoft Azure, and will take advantage of a hw random number generator (if present) to initialize the /dev/urandom pool" (It turns out that the random tree hadn't been in linux-next this time around, because it had been dropped earlier as being too quiet. Oh well). * tag 'random_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random: random: strengthen input validation for RNDADDTOENTCNT random: add backtracking protection to the CRNG random: make /dev/urandom scalable for silly userspace programs random: replace non-blocking pool with a Chacha20-based CRNG random: properly align get_random_int_hash random: add interrupt callback to VMBus IRQ handler random: print a warning for the first ten uninitialized random users random: initialize the non-blocking pool via add_hwgenerator_randomness()
2016-07-26Merge branch 'linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6 Pull crypto updates from Herbert Xu: "Here is the crypto update for 4.8: API: - first part of skcipher low-level conversions - add KPP (Key-agreement Protocol Primitives) interface. Algorithms: - fix IPsec/cryptd reordering issues that affects aesni - RSA no longer does explicit leading zero removal - add SHA3 - add DH - add ECDH - improve DRBG performance by not doing CTR by hand Drivers: - add x86 AVX2 multibuffer SHA256/512 - add POWER8 optimised crc32c - add xts support to vmx - add DH support to qat - add RSA support to caam - add Layerscape support to caam - add SEC1 AEAD support to talitos - improve performance by chaining requests in marvell/cesa - add support for Araneus Alea I USB RNG - add support for Broadcom BCM5301 RNG - add support for Amlogic Meson RNG - add support Broadcom NSP SoC RNG" * 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (180 commits) crypto: vmx - Fix aes_p8_xts_decrypt build failure crypto: vmx - Ignore generated files crypto: vmx - Adding support for XTS crypto: vmx - Adding asm subroutines for XTS crypto: skcipher - add comment for skcipher_alg->base crypto: testmgr - Print akcipher algorithm name crypto: marvell - Fix wrong flag used for GFP in mv_cesa_dma_add_iv_op crypto: nx - off by one bug in nx_of_update_msc() crypto: rsa-pkcs1pad - fix rsa-pkcs1pad request struct crypto: scatterwalk - Inline start/map/done crypto: scatterwalk - Remove unnecessary BUG in scatterwalk_start crypto: scatterwalk - Remove unnecessary advance in scatterwalk_pagedone crypto: scatterwalk - Fix test in scatterwalk_done crypto: api - Optimise away crypto_yield when hard preemption is on crypto: scatterwalk - add no-copy support to copychunks crypto: scatterwalk - Remove scatterwalk_bytes_sglen crypto: omap - Stop using crypto scatterwalk_bytes_sglen crypto: skcipher - Remove top-level givcipher interface crypto: user - Remove crypto_lookup_skcipher call crypto: cts - Convert to skcipher ...
2016-07-23Merge branch 'linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6 Pull crypto fixes from Herbert Xu: "This fixes a sporadic build failure in the qat driver as well as a memory corruption bug in rsa-pkcs1pad" * 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: rsa-pkcs1pad - fix rsa-pkcs1pad request struct crypto: qat - make qat_asym_algs.o depend on asn1 headers
2016-07-22crypto: rsa-pkcs1pad - fix rsa-pkcs1pad request structHerbert Xu
To allow for child request context the struct akcipher_request child_req needs to be at the end of the structure. Cc: stable@vger.kernel.org Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-07-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Herbert Xu
Merge the crypto tree to resolve conflict in qat Makefile.
2016-07-19crypto: testmgr - Print akcipher algorithm nameHerbert Xu
When an akcipher test fails, we don't know which algorithm failed because the name is not printed. This patch fixes this. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-07-19crypto: rsa-pkcs1pad - fix rsa-pkcs1pad request structTadeusz Struk
To allow for child request context the struct akcipher_request child_req needs to be at the end of the structure. Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-07-18crypto: scatterwalk - Inline start/map/doneHerbert Xu
This patch inlines the functions scatterwalk_start, scatterwalk_map and scatterwalk_done as they're all tiny and mostly used by the block cipher walker. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-07-18crypto: scatterwalk - Remove unnecessary BUG in scatterwalk_startHerbert Xu
Nothing bad will happen even if sg->length is zero, so there is no point in keeping this BUG_ON in scatterwalk_start. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-07-18crypto: scatterwalk - Remove unnecessary advance in scatterwalk_pagedoneHerbert Xu
The offset advance in scatterwalk_pagedone not only is unnecessary, but it was also buggy when it was needed by scatterwalk_copychunks. As the latter has long ago been fixed to call scatterwalk_advance directly, we can remove this unnecessary offset adjustment. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-07-18crypto: scatterwalk - Fix test in scatterwalk_doneHerbert Xu
When there is more data to be processed, the current test in scatterwalk_done may prevent us from calling pagedone even when we should. In particular, if we're on an SG entry spanning multiple pages where the last page is not a full page, we will incorrectly skip calling pagedone on the second last page. This patch fixes this by adding a separate test for whether we've reached the end of a page. Cc: stable@vger.kernel.org Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-07-18crypto: scatterwalk - Add no-copy support to copychunksHerbert Xu
The function ablkcipher_done_slow is pretty much identical to scatterwalk_copychunks except that it doesn't actually copy as the processing hasn't been completed yet. This patch allows scatterwalk_copychunks to be used in this case by specifying out == 2. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-07-18crypto: scatterwalk - Remove scatterwalk_bytes_sglenHerbert Xu
This patch removes the now unused scatterwalk_bytes_sglen. Anyone using this out-of-tree should switch over to sg_nents_for_len. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-07-18crypto: skcipher - Remove top-level givcipher interfaceHerbert Xu
This patch removes the old crypto_grab_skcipher helper and replaces it with crypto_grab_skcipher2. As this is the final entry point into givcipher this patch also removes all traces of the top-level givcipher interface, including all implicit IV generators such as chainiv. The bottom-level givcipher interface remains until the drivers using it are converted. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-07-18crypto: user - Remove crypto_lookup_skcipher callHerbert Xu
As there are no more kernel users of built-in IV generators we can remove the special lookup for skciphers. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-07-18crypto: cts - Convert to skcipherHerbert Xu
This patch converts cts over to the skcipher interface. It also optimises the implementation to use one CBC operation for all but the last block, which is then processed separately. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-07-18crypto: null - Remove default null blkcipherHerbert Xu
The default null blkcipher is no longer used and can now be removed. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-07-18crypto: aead - Remove blkcipher null for IV generatorsHerbert Xu
The blkcipher null object is no longer used and can now be removed. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-07-18crypto: seqiv - Use skcipherHerbert Xu
This patch replaces use of the obsolete blkcipher with skcipher. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-07-18crypto: echainiv - Use skcipherHerbert Xu
2016-07-18crypto: aead - Add skcipher null for IV generatorsHerbert Xu
This patch adds an skcipher null object alongside the existing null blkcipher so that IV generators using it can switch over to skcipher. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-07-18crypto: chacha20poly1305 - Use skcipherHerbert Xu
This patch converts chacha20poly1305 to use the new skcipher interface as opposed to ablkcipher. It also fixes a buglet where we may end up with an async poly1305 when the user asks for a async algorithm. This shouldn't be a problem yet as there aren't any async implementations of poly1305 out there. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-07-18crypto: gcm - Use skcipherHerbert Xu
This patch converts gcm to use the new skcipher interface as opposed to ablkcipher. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
