commit 318abdfbe708aaaa652c79fb500e9bd60521f9dc upstream.
Like the skcipher_walk and blkcipher_walk cases:
scatterwalk_done() is only meant to be called after a nonzero number of
bytes have been processed, since scatterwalk_pagedone() will flush the
dcache of the *previous* page. But in the error case of
ablkcipher_walk_done(), e.g. if the input wasn't an integer number of
blocks, scatterwalk_done() was actually called after advancing 0 bytes.
This caused a crash ("BUG: unable to handle kernel paging request")
during '!PageSlab(page)' on architectures like arm and arm64 that define
ARCH_IMPLEMENTS_FLUSH_DCACHE_PAGE, provided that the input was
page-aligned as in that case walk->offset == 0.
Fix it by reorganizing ablkcipher_walk_done() to skip the
scatterwalk_advance() and scatterwalk_done() if an error has occurred.
Reported-by: Liu Chao <liuchao741@huawei.com>
Fixes: bf06099db18a ("crypto: skcipher - Add ablkcipher_walk interfaces")
Cc: <stable@vger.kernel.org> # v2.6.35+
commit 0868def3e4100591e7a1fdbf3eed1439cc8f7ca3 upstream.
Like the skcipher_walk case:
Fix it by reorganizing blkcipher_walk_done() to skip the
This bug was found by syzkaller fuzzing.
Reproducer, assuming ARCH_IMPLEMENTS_FLUSH_DCACHE_PAGE:
#include <linux/if_alg.h>
#include <sys/socket.h>
#include <unistd.h>
int main()
struct sockaddr_alg addr = {
.salg_type = "skcipher",
.salg_name = "ecb(aes-generic)",
char buffer[4096] __attribute__((aligned(4096))) = { 0 };
int fd;
fd = socket(AF_ALG, SOCK_SEQPACKET, 0);
bind(fd, (void *)&addr, sizeof(addr));
setsockopt(fd, SOL_ALG, ALG_SET_KEY, buffer, 16);
fd = accept(fd, NULL, NULL);
write(fd, buffer, 15);
read(fd, buffer, 15);
Fixes: 5cde0af2a982 ("[CRYPTO] cipher: Added block cipher type")
Cc: <stable@vger.kernel.org> # v2.6.19+
commit bb29648102335586e9a66289a1d98a0cb392b6e5 upstream.
syzbot reported a crash in vmac_final() when multiple threads
concurrently use the same "vmac(aes)" transform through AF_ALG. The bug
is pretty fundamental: the VMAC template doesn't separate per-request
state from per-tfm (per-key) state like the other hash algorithms do,
but rather stores it all in the tfm context. That's wrong.
Also, vmac_final() incorrectly zeroes most of the state including the
derived keys and cached pseudorandom pad. Therefore, only the first
VMAC invocation with a given key calculates the correct digest.
Fix these bugs by splitting the per-tfm state from the per-request state
and using the proper init/update/final sequencing for requests.
Reproducer for the crash:
#include <unistd.h>
int main()
int fd;
.salg_type = "hash",
.salg_name = "vmac(aes)",
char buf[256] = { 0 };
setsockopt(fd, SOL_ALG, ALG_SET_KEY, buf, 16);
fork();
for (;;)
write(fd, buf, 256);
The immediate cause of the crash is that vmac_ctx_t.partial_size exceeds
VMAC_NHBYTES, causing vmac_final() to memset() a negative length.
Reported-by: syzbot+264bca3a6e8d645550d3@syzkaller.appspotmail.com
Fixes: f1939f7c5645 ("crypto: vmac - New hash algorithm for intel_txt support")
Cc: <stable@vger.kernel.org> # v2.6.32+
commit 73bf20ef3df262026c3470241ae4ac8196943ffa upstream.
The VMAC template assumes the block cipher has a 128-bit block size, but
it failed to check for that. Thus it was possible to instantiate it
using a 64-bit block size cipher, e.g. "vmac(cast5)", causing
uninitialized memory to be used.
Add the needed check when instantiating the template.
[ Upstream commit ad2fdcdf75d169e7a5aec6c7cb421c0bec8ec711 ]
In crypto_authenc_setkey we save pointers to the authenc keys in
a local variable of type struct crypto_authenc_keys and we don't
zeroize it after use. Fix this and don't leak pointers to the
authenc keys.
Signed-off-by: Tudor Ambarus <tudor.ambarus@microchip.com>
[ Upstream commit 31545df391d58a3bb60e29b1192644a6f2b5a8dd ]
In crypto_authenc_esn_setkey we save pointers to the authenc keys
in a local variable of type struct crypto_authenc_keys and we don't
authenc keys.
commit b65c32ec5a942ab3ada93a048089a938918aba7f upstream.
The signatureValue field of a X.509 certificate is encoded as a BIT STRING.
For RSA signatures this BIT STRING is of so-called primitive subtype, which
contains a u8 prefix indicating a count of unused bits in the encoding.
We have to strip this prefix from signature data, just as we already do for
key data in x509_extract_key_data() function.
This wasn't noticed earlier because this prefix byte is zero for RSA key
sizes divisible by 8. Since BIT STRING is a big-endian encoding adding zero
prefixes has no bearing on its value.
The signature length, however was incorrect, which is a problem for RSA
implementations that need it to be exactly correct (like AMD CCP).
Signed-off-by: Maciej S. Szmigiero <mail@maciej.szmigiero.name>
Fixes: c26fd69fa009 ("X.509: Add a crypto key parser for binary (DER) X.509 certificates")
Cc: stable@vger.kernel.org
Signed-off-by: James Morris <james.morris@microsoft.com>
[ Upstream commit 6459ae386699a5fe0dc52cf30255f75274fa43a4 ]
If none of the certificates in a SignerInfo's certificate chain match a
trusted key, nor is the last certificate signed by a trusted key, then
pkcs7_validate_trust_one() tries to check whether the SignerInfo's
signature was made directly by a trusted key. But, it actually fails to
set the 'sig' variable correctly, so it actually verifies the last
signature seen. That will only be the SignerInfo's signature if the
certificate chain is empty; otherwise it will actually be the last
certificate's signature.
This is not by itself a security problem, since verifying any of the
certificates in the chain should be sufficient to verify the SignerInfo.
Still, it's not working as intended so it should be fixed.
Fix it by setting 'sig' correctly for the direct verification case.
Fixes: 757932e6da6d ("PKCS#7: Handle PKCS#7 messages that contain no X.509 certs")
commit a466856e0b7ab269cdf9461886d007e88ff575b0 upstream.
syzbot reported :
BUG: KMSAN: uninit-value in alg_bind+0xe3/0xd90 crypto/af_alg.c:162
We need to check addr_len before dereferencing sa (or uaddr)
Fixes: bb30b8848c85 ("crypto: af_alg - whitelist mask and type")
Reported-by: syzbot <syzkaller@googlegroups.com>
Cc: Stephan Mueller <smueller@chronox.de>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
commit eea0d3ea7546961f69f55b26714ac8fd71c7c020 upstream.
During freeing of the internal buffers used by the DRBG, set the pointer
to NULL. It is possible that the context with the freed buffers is
reused. In case of an error during initialization where the pointers
do not yet point to allocated memory, the NULL value prevents a double
free.
Fixes: 3cfc3b9721123 ("crypto: drbg - use aligned buffers")
Signed-off-by: Stephan Mueller <smueller@chronox.de>
Reported-by: syzbot+75397ee3df5c70164154@syzkaller.appspotmail.com
[ Upstream commit 4e880168e9ffb1cdbdb72b3b48ab0324b30c2d62 ]
We forgot to set the error code on this path so it could result in
returning NULL which leads to a NULL dereference.
Fixes: db6c43bd2132 ("crypto: KEYS: convert public key and digsig asym to the akcipher api")
Signed-off-by: James Morris <james.l.morris@oracle.com>
[ Upstream commit baae03a0e2497f49704628fd0aaf993cf98e1b99 ]
The DMA_PREP_FENCE is to be used when preparing Tx descriptor if output
of Tx descriptor is to be used by next/dependent Tx descriptor.
The DMA_PREP_FENSE will not be set correctly in do_async_gen_syndrome()
when calling dma->device_prep_dma_pq() under following conditions:
1. ASYNC_TX_FENCE not set in submit->flags
2. DMA_PREP_FENCE not set in dma_flags
3. src_cnt (= (disks - 2)) is greater than dma_maxpq(dma, dma_flags)
This patch fixes DMA_PREP_FENCE usage in do_async_gen_syndrome() taking
inspiration from do_async_xor() implementation.
Signed-off-by: Anup Patel <anup.patel@broadcom.com>
Reviewed-by: Ray Jui <ray.jui@broadcom.com>
Reviewed-by: Scott Branden <scott.branden@broadcom.com>
Acked-by: Dan Williams <dan.j.williams@intel.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
commit 900a081f6912a8985dc15380ec912752cb66025a upstream.
When we have an unaligned SG list entry where there is no leftover
aligned data, the hash walk code will incorrectly return zero as if
the entire SG list has been processed.
This patch fixes it by moving onto the next page instead.
Reported-by: Eli Cooper <elicooper@gmx.com>
commit 4b34968e77ad09628cfb3c4a7daf2adc2cefc6e8 upstream.
The asymmetric key type allows an X.509 certificate to be added even if
its signature's hash algorithm is not available in the crypto API. In
that case 'payload.data[asym_auth]' will be NULL. But the key
restriction code failed to check for this case before trying to use the
signature, resulting in a NULL pointer dereference in
key_or_keyring_common() or in restrict_link_by_signature().
Fix this by returning -ENOPKG when the signature is unsupported.
Reproducer when all the CONFIG_CRYPTO_SHA512* options are disabled and
keyctl has support for the 'restrict_keyring' command:
keyctl new_session
keyctl restrict_keyring @s asymmetric builtin_trusted
openssl req -new -sha512 -x509 -batch -nodes -outform der \
| keyctl padd asymmetric desc @s
Fixes: a511e1af8b12 ("KEYS: Move the point of trust determination to __key_link()")
Cc: <stable@vger.kernel.org> # v4.7+
commit 971b42c038dc83e3327872d294fe7131bab152fc upstream.
When pkcs7_verify_sig_chain() is building the certificate chain for a
SignerInfo using the certificates in the PKCS#7 message, it is passing
the wrong arguments to public_key_verify_signature(). Consequently,
when the next certificate is supposed to be used to verify the previous
certificate, the next certificate is actually used to verify itself.
An attacker can use this bug to create a bogus certificate chain that
has no cryptographic relationship between the beginning and end.
Fortunately I couldn't quite find a way to use this to bypass the
overall signature verification, though it comes very close. Here's the
reasoning: due to the bug, every certificate in the chain beyond the
first actually has to be self-signed (where "self-signed" here refers to
the actual key and signature; an attacker might still manipulate the
certificate fields such that the self_signed flag doesn't actually get
set, and thus the chain doesn't end immediately). But to pass trust
validation (pkcs7_validate_trust()), either the SignerInfo or one of the
certificates has to actually be signed by a trusted key. Since only
self-signed certificates can be added to the chain, the only way for an
attacker to introduce a trusted signature is to include a self-signed
trusted certificate.
But, when pkcs7_validate_trust_one() reaches that certificate, instead
of trying to verify the signature on that certificate, it will actually
look up the corresponding trusted key, which will succeed, and then try
to verify the *previous* certificate, which will fail. Thus, disaster
is narrowly averted (as far as I could tell).
Fixes: 6c2dc5ae4ab7 ("X.509: Extract signature digest and make self-signed cert checks earlier")
commit 437499eea4291ae9621e8763a41df027c110a1ef upstream.
The X.509 parser mishandles the case where the certificate's signature's
hash algorithm is not available in the crypto API. In this case,
x509_get_sig_params() doesn't allocate the cert->sig->digest buffer;
this part seems to be intentional. However,
public_key_verify_signature() is still called via
x509_check_for_self_signed(), which triggers the 'BUG_ON(!sig->digest)'.
Fix this by making public_key_verify_signature() return -ENOPKG if the
hash buffer has not been allocated.
Reproducer when all the CONFIG_CRYPTO_SHA512* options are disabled:
Reported-by: Paolo Valente <paolo.valente@linaro.org>
Cc: Paolo Valente <paolo.valente@linaro.org>
commit 9fa68f620041be04720d0cbfb1bd3ddfc6310b24 upstream.
Currently, almost none of the keyed hash algorithms check whether a key
has been set before proceeding. Some algorithms are okay with this and
will effectively just use a key of all 0's or some other bogus default.
However, others will severely break, as demonstrated using
"hmac(sha3-512-generic)", the unkeyed use of which causes a kernel crash
via a (potentially exploitable) stack buffer overflow.
A while ago, this problem was solved for AF_ALG by pairing each hash
transform with a 'has_key' bool. However, there are still other places
in the kernel where userspace can specify an arbitrary hash algorithm by
name, and the kernel uses it as unkeyed hash without checking whether it
is really unkeyed. Examples of this include:
- KEYCTL_DH_COMPUTE, via the KDF extension
- dm-verity
- dm-crypt, via the ESSIV support
- dm-integrity, via the "internal hash" mode with no key given
- drbd (Distributed Replicated Block Device)
This bug is especially bad for KEYCTL_DH_COMPUTE as that requires no
privileges to call.
Fix the bug for all users by adding a flag CRYPTO_TFM_NEED_KEY to the
->crt_flags of each hash transform that indicates whether the transform
still needs to be keyed or not. Then, make the hash init, import, and
digest functions return -ENOKEY if the key is still needed.
The new flag also replaces the 'has_key' bool which algif_hash was
previously using, thereby simplifying the algif_hash implementation.
commit a208fa8f33031b9e0aba44c7d1b7e68eb0cbd29e upstream.
We need to consistently enforce that keyed hashes cannot be used without
setting the key. To do this we need a reliable way to determine whether
a given hash algorithm is keyed or not. AF_ALG currently does this by
checking for the presence of a ->setkey() method. However, this is
actually slightly broken because the CRC-32 algorithms implement
->setkey() but can also be used without a key. (The CRC-32 "key" is not
actually a cryptographic key but rather represents the initial state.
If not overridden, then a default initial state is used.)
Prepare to fix this by introducing a flag CRYPTO_ALG_OPTIONAL_KEY which
indicates that the algorithm has a ->setkey() method, but it is not
required to be called. Then set it on all the CRC-32 algorithms.
The same also applies to the Adler-32 implementation in Lustre.
Also, the cryptd and mcryptd templates have to pass through the flag
from their underlying algorithm.
commit a16e772e664b9a261424107784804cffc8894977 upstream.
Since Poly1305 requires a nonce per invocation, the Linux kernel
implementations of Poly1305 don't use the crypto API's keying mechanism
and instead expect the key and nonce as the first 32 bytes of the data.
But ->setkey() is still defined as a stub returning an error code. This
prevents Poly1305 from being used through AF_ALG and will also break it
completely once we start enforcing that all crypto API users (not just
AF_ALG) call ->setkey() if present.
Fix it by removing crypto_poly1305_setkey(), leaving ->setkey as NULL.
commit fa59b92d299f2787e6bae1ff078ee0982e80211f upstream.
When the mcryptd template is used to wrap an unkeyed hash algorithm,
don't install a ->setkey() method to the mcryptd instance. This change
is necessary for mcryptd to keep working with unkeyed hash algorithms
once we start enforcing that ->setkey() is called when present.
commit 841a3ff329713f796a63356fef6e2f72e4a3f6a3 upstream.
When the cryptd template is used to wrap an unkeyed hash algorithm,
don't install a ->setkey() method to the cryptd instance. This change
is necessary for cryptd to keep working with unkeyed hash algorithms
commit cd6ed77ad5d223dc6299fb58f62e0f5267f7e2ba upstream.
Templates that use an shash spawn can use crypto_shash_alg_has_setkey()
to determine whether the underlying algorithm requires a key or not.
But there was no corresponding function for ahash spawns. Add it.
Note that the new function actually has to support both shash and ahash
algorithms, since the ahash API can be used with either.
commit 5c6ac1d4f8fbdbed65dbeb8cf149d736409d16a1 upstream.
In case buffer length is a multiple of PAGE_SIZE,
the S/G table is incorrectly generated.
Fix this by handling buflen = k * PAGE_SIZE separately.
Signed-off-by: Robert Baronescu <robert.baronescu@nxp.com>
Signed-off-by: Horia Geantă <horia.geanta@nxp.com>
commit bb30b8848c85e18ca7e371d0a869e94b3e383bdf upstream.
The user space interface allows specifying the type and mask field used
to allocate the cipher. Only a subset of the possible flags are intended
for user space. Therefore, white-list the allowed flags.
In case the user space caller uses at least one non-allowed flag, EINVAL
is returned.
commit c013cee99d5a18aec8c71fee8f5f41369cd12595 upstream.
Ensure that the input is byte swabbed before injecting it into the
SHA3 transform. Use the get_unaligned() accessor for this so that
we don't perform unaligned access inadvertently on architectures
that do not support that.
Fixes: 53964b9ee63b7075 ("crypto: sha3 - Add SHA-3 hash algorithm")
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
commit b5b9007730ce1d90deaf25d7f678511550744bdc upstream.
This fixes a typo in the CRYPTO_KPP dependency of CRYPTO_ECDH.
Fixes: 3c4b23901a0c ("crypto: ecdh - Add ECDH software support")
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
commit 9a00674213a3f00394f4e3221b88f2d21fc05789 upstream.
syzkaller triggered a NULL pointer dereference in crypto_remove_spawns()
via a program that repeatedly and concurrently requests AEADs
"authenc(cmac(des3_ede-asm),pcbc-aes-aesni)" and hashes "cmac(des3_ede)"
through AF_ALG, where the hashes are requested as "untested"
(CRYPTO_ALG_TESTED is set in ->salg_mask but clear in ->salg_feat; this
causes the template to be instantiated for every request).
Although AF_ALG users really shouldn't be able to request an "untested"
algorithm, the NULL pointer dereference is actually caused by a
longstanding race condition where crypto_remove_spawns() can encounter
an instance which has had spawn(s) "grabbed" but hasn't yet been
registered, resulting in ->cra_users still being NULL.
We probably should properly initialize ->cra_users earlier, but that
would require updating many templates individually. For now just fix
the bug in a simple way that can easily be backported: make
crypto_remove_spawns() treat a NULL ->cra_users list as empty.
commit d76c68109f37cb85b243a1cf0f40313afd2bae68 upstream.
pcrypt is using the old way of freeing instances, where the ->free()
method specified in the 'struct crypto_template' is passed a pointer to
the 'struct crypto_instance'. But the crypto_instance is being
kfree()'d directly, which is incorrect because the memory was actually
allocated as an aead_instance, which contains the crypto_instance at a
nonzero offset. Thus, the wrong pointer was being kfree()'d.
Fix it by switching to the new way to free aead_instance's where the
->free() method is specified in the aead_instance itself.
Fixes: 0496f56065e0 ("crypto: pcrypt - Add support for new AEAD interface")
commit e57121d08c38dabec15cf3e1e2ad46721af30cae upstream.
If the rfc7539 template was instantiated with a hash algorithm with
digest size larger than 16 bytes (POLY1305_DIGEST_SIZE), then the digest
overran the 'tag' buffer in 'struct chachapoly_req_ctx', corrupting the
subsequent memory, including 'cryptlen'. This caused a crash during
crypto_skcipher_decrypt().
Fix it by, when instantiating the template, requiring that the
underlying hash algorithm has the digest size expected for Poly1305.
Reproducer:
#include <unistd.h>
int main()
int algfd, reqfd;
.salg_type = "aead",
.salg_name = "rfc7539(chacha20,sha256)",
unsigned char buf[32] = { 0 };
algfd = socket(AF_ALG, SOCK_SEQPACKET, 0);
bind(algfd, (void *)&addr, sizeof(addr));
setsockopt(algfd, SOL_ALG, ALG_SET_KEY, buf, sizeof(buf));
reqfd = accept(algfd, 0, 0);
write(reqfd, buf, 16);
read(reqfd, buf, 16);
Fixes: 71ebc4d1b27d ("crypto: chacha20poly1305 - Add a ChaCha20-Poly1305 AEAD construction, RFC7539")
commit 9abffc6f2efe46c3564c04312e52e07622d40e51 upstream.
mcryptd_enqueue_request() grabs the per-CPU queue struct and protects
access to it with disabled preemption. Then it schedules a worker on the
same CPU. The worker in mcryptd_queue_worker() guards access to the same
per-CPU variable with disabled preemption.
If we take CPU-hotplug into account then it is possible that between
queue_work_on() and the actual invocation of the worker the CPU goes
down and the worker will be scheduled on _another_ CPU. And here the
preempt_disable() protection does not work anymore. The easiest thing is
to add a spin_lock() to guard access to the list.
Another detail: mcryptd_queue_worker() is not processing more than
MCRYPTD_BATCH invocation in a row. If there are still items left, then
it will invoke queue_work() to proceed with more later. *I* would
suggest to simply drop that check because it does not use a system
workqueue and the workqueue is already marked as "CPU_INTENSIVE". And if
preemption is required then the scheduler should do it.
However if queue_work() is used then the work item is marked as CPU
unbound. That means it will try to run on the local CPU but it may run
on another CPU as well. Especially with CONFIG_DEBUG_WQ_FORCE_RR_CPU=y.
Again, the preempt_disable() won't work here but lock which was
introduced will help.
In order to keep work-item on the local CPU (and avoid RR) I changed it
to queue_work_on().
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
[ Upstream commit 7aacbfcb331ceff3ac43096d563a1f93ed46e35e ]
Fix the way the length of the buffers used for
encryption / decryption are computed.
For e.g. in case of encryption, input buffer does not contain
an authentication tag.
commit ecaaab5649781c5a0effdaf298a925063020500e upstream.
When asked to encrypt or decrypt 0 bytes, both the generic and x86
implementations of Salsa20 crash in blkcipher_walk_done(), either when
doing 'kfree(walk->buffer)' or 'free_page((unsigned long)walk->page)',
because walk->buffer and walk->page have not been initialized.
The bug is that Salsa20 is calling blkcipher_walk_done() even when
nothing is in 'walk.nbytes'. But blkcipher_walk_done() is only meant to
be called when a nonzero number of bytes have been provided.
The broken code is part of an optimization that tries to make only one
call to salsa20_encrypt_bytes() to process inputs that are not evenly
divisible by 64 bytes. To fix the bug, just remove this "optimization"
and use the blkcipher_walk API the same way all the other users do.
Reproducer:
#include <unistd.h>
int main()
int algfd, reqfd;
.salg_name = "salsa20",
char key[16] = { 0 };
setsockopt(algfd, SOL_ALG, ALG_SET_KEY, key, sizeof(key));
read(reqfd, key, sizeof(key));
Fixes: eb6f13eb9f81 ("[CRYPTO] salsa20_generic: Fix multi-page processing")
commit af3ff8045bbf3e32f1a448542e73abb4c8ceb6f1 upstream.
Because the HMAC template didn't check that its underlying hash
algorithm is unkeyed, trying to use "hmac(hmac(sha3-512-generic))"
through AF_ALG or through KEYCTL_DH_COMPUTE resulted in the inner HMAC
being used without having been keyed, resulting in sha3_update() being
called without sha3_init(), causing a stack buffer overflow.
This is a very old bug, but it seems to have only started causing real
problems when SHA-3 support was added (requires CONFIG_CRYPTO_SHA3)
because the innermost hash's state is ->import()ed from a zeroed buffer,
and it just so happens that other hash algorithms are fine with that,
but SHA-3 is not. However, there could be arch or hardware-dependent
hash algorithms also affected; I couldn't test everything.
Fix the bug by introducing a function crypto_shash_alg_has_setkey()
which tests whether a shash algorithm is keyed. Then update the HMAC
template to require that its underlying hash algorithm is unkeyed.
Here is a reproducer:
int main()
int algfd;
.salg_name = "hmac(hmac(sha3-512-generic))",
char key[4096] = { 0 };
bind(algfd, (const struct sockaddr *)&addr, sizeof(addr));
Here was the KASAN report from syzbot:
BUG: KASAN: stack-out-of-bounds in memcpy include/linux/string.h:341 [inline]
BUG: KASAN: stack-out-of-bounds in sha3_update+0xdf/0x2e0 crypto/sha3_generic.c:161
Write of size 4096 at addr ffff8801cca07c40 by task syzkaller076574/3044
CPU: 1 PID: 3044 Comm: syzkaller076574 Not tainted 4.14.0-mm1+ #25
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:17 [inline]
dump_stack+0x194/0x257 lib/dump_stack.c:53
print_address_description+0x73/0x250 mm/kasan/report.c:252
kasan_report_error mm/kasan/report.c:351 [inline]
kasan_report+0x25b/0x340 mm/kasan/report.c:409
check_memory_region_inline mm/kasan/kasan.c:260 [inline]
check_memory_region+0x137/0x190 mm/kasan/kasan.c:267
memcpy+0x37/0x50 mm/kasan/kasan.c:303
crypto_shash_update+0xcb/0x220 crypto/shash.c:109
shash_finup_unaligned+0x2a/0x60 crypto/shash.c:151
crypto_shash_finup+0xc4/0x120 crypto/shash.c:165
hmac_finup+0x182/0x330 crypto/hmac.c:152
shash_digest_unaligned+0x9e/0xd0 crypto/shash.c:172
crypto_shash_digest+0xc4/0x120 crypto/shash.c:186
hmac_setkey+0x36a/0x690 crypto/hmac.c:66
crypto_shash_setkey+0xad/0x190 crypto/shash.c:64
shash_async_setkey+0x47/0x60 crypto/shash.c:207
crypto_ahash_setkey+0xaf/0x180 crypto/ahash.c:200
hash_setkey+0x40/0x90 crypto/algif_hash.c:446
alg_setkey crypto/af_alg.c:221 [inline]
alg_setsockopt+0x2a1/0x350 crypto/af_alg.c:254
SYSC_setsockopt net/socket.c:1851 [inline]
SyS_setsockopt+0x189/0x360 net/socket.c:1830
entry_SYSCALL_64_fastpath+0x1f/0x96
commit d2890c3778b164fde587bc16583f3a1c87233ec5 upstream.
In rsa_get_n(), if the buffer contained all 0's and "FIPS mode" is
enabled, we would read one byte past the end of the buffer while
scanning the leading zeroes. Fix it by checking 'n_sz' before '!*ptr'.
This bug was reachable by adding a specially crafted key of type
"asymmetric" (requires CONFIG_RSA and CONFIG_X509_CERTIFICATE_PARSER).
KASAN report:
BUG: KASAN: slab-out-of-bounds in rsa_get_n+0x19e/0x1d0 crypto/rsa_helper.c:33
Read of size 1 at addr ffff88003501a708 by task keyctl/196
CPU: 1 PID: 196 Comm: keyctl Not tainted 4.14.0-09238-g1d3b78bbc6e9 #26
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.11.0-20171110_100015-anatol 04/01/2014
Call Trace:
asn1_ber_decoder+0x82a/0x1fd0 lib/asn1_decoder.c:328
rsa_set_pub_key+0xd3/0x320 crypto/rsa.c:278
crypto_akcipher_set_pub_key ./include/crypto/akcipher.h:364 [inline]
pkcs1pad_set_pub_key+0xae/0x200 crypto/rsa-pkcs1pad.c:117
public_key_verify_signature+0x270/0x9d0 crypto/asymmetric_keys/public_key.c:106
x509_check_for_self_signed+0x2ea/0x480 crypto/asymmetric_keys/x509_public_key.c:141
x509_cert_parse+0x46a/0x620 crypto/asymmetric_keys/x509_cert_parser.c:129
x509_key_preparse+0x61/0x750 crypto/asymmetric_keys/x509_public_key.c:174
asymmetric_key_preparse+0xa4/0x150 crypto/asymmetric_keys/asymmetric_type.c:388
key_create_or_update+0x4d4/0x10a0 security/keys/key.c:850
SYSC_add_key security/keys/keyctl.c:122 [inline]
SyS_add_key+0xe8/0x290 security/keys/keyctl.c:62
Allocated by task 196:
__do_kmalloc mm/slab.c:3711 [inline]
__kmalloc_track_caller+0x118/0x2e0 mm/slab.c:3726
kmemdup+0x17/0x40 mm/util.c:118
kmemdup ./include/linux/string.h:414 [inline]
x509_cert_parse+0x2cb/0x620 crypto/asymmetric_keys/x509_cert_parser.c:106
Fixes: 5a7de97309f5 ("crypto: rsa - return raw integers for the ASN.1 parser")
Cc: Tudor Ambarus <tudor-dan.ambarus@nxp.com>
Reviewed-by: James Morris <james.l.morris@oracle.com>
Reviewed-by: David Howells <dhowells@redhat.com>
commit 54c1fb39fe0495f846539ab765925b008f86801c upstream.
->pkey_algo used to be an enum, but was changed to a string by commit
4e8ae72a75aa ("X.509: Make algo identifiers text instead of enum"). But
two comparisons were not updated. Fix them to use strcmp().
This bug broke signature verification in certain configurations,
depending on whether the string constants were deduplicated or not.
Fixes: 4e8ae72a75aa ("X.509: Make algo identifiers text instead of enum")
commit 0f30cbea005bd3077bd98cd29277d7fc2699c1da upstream.
Adding a specially crafted X.509 certificate whose subjectPublicKey
ASN.1 value is zero-length caused x509_extract_key_data() to set the
public key size to SIZE_MAX, as it subtracted the nonexistent BIT STRING
metadata byte. Then, x509_cert_parse() called kmemdup() with that bogus
size, triggering the WARN_ON_ONCE() in kmalloc_slab().
This appears to be harmless, but it still must be fixed since WARNs are
never supposed to be user-triggerable.
Fix it by updating x509_cert_parse() to validate that the value has a
BIT STRING metadata byte, and that the byte is 0 which indicates that
the number of bits in the bitstring is a multiple of 8.
It would be nice to handle the metadata byte in asn1_ber_decoder()
instead. But that would be tricky because in the general case a BIT
STRING could be implicitly tagged, and/or could legitimately have a
length that is not a whole number of bytes.
Here was the WARN (cleaned up slightly):
WARNING: CPU: 1 PID: 202 at mm/slab_common.c:971 kmalloc_slab+0x5d/0x70 mm/slab_common.c:971
Modules linked in:
CPU: 1 PID: 202 Comm: keyctl Tainted: G B 4.14.0-09238-g1d3b78bbc6e9 #26
task: ffff880033014180 task.stack: ffff8800305c8000
Call Trace:
__do_kmalloc mm/slab.c:3706 [inline]
__kmalloc_track_caller+0x22/0x2e0 mm/slab.c:3726
kmemdup include/linux/string.h:414 [inline]
Fixes: 42d5ec27f873 ("X.509: Add an ASN.1 decoder")
commit 12d41a023efb01b846457ccdbbcbe2b65a87d530 upstream.
When setting the secret with the software Diffie-Hellman implementation,
if allocating 'g' failed (e.g. if it was longer than
MAX_EXTERN_MPI_BITS), then 'p' was freed twice: once immediately, and
once later when the crypto_kpp tfm was destroyed.
Fix it by using dh_free_ctx() (renamed to dh_clear_ctx()) in the error
paths, as that correctly sets the pointers to NULL.
KASAN report:
MPI: mpi too large (32760 bits)
BUG: KASAN: use-after-free in mpi_free+0x131/0x170
Read of size 4 at addr ffff88006c7cdf90 by task reproduce_doubl/367
CPU: 1 PID: 367 Comm: reproduce_doubl Not tainted 4.14.0-rc7-00040-g05298abde6fe #7
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
Call Trace:
dump_stack+0xb3/0x10b
? mpi_free+0x131/0x170
print_address_description+0x79/0x2a0
kasan_report+0x236/0x340
? akcipher_register_instance+0x90/0x90
__asan_report_load4_noabort+0x14/0x20
dh_exit_tfm+0x3d/0x140
crypto_kpp_exit_tfm+0x52/0x70
crypto_destroy_tfm+0xb3/0x250
__keyctl_dh_compute+0x640/0xe90
? kasan_slab_free+0x12f/0x180
? dh_data_from_key+0x240/0x240
? key_create_or_update+0x1ee/0xb20
? key_instantiate_and_link+0x440/0x440
? lock_contended+0xee0/0xee0
? kfree+0xcf/0x210
? SyS_add_key+0x268/0x340
keyctl_dh_compute+0xb3/0xf1
? __keyctl_dh_compute+0xe90/0xe90
? SyS_add_key+0x26d/0x340
? entry_SYSCALL_64_fastpath+0x5/0xbe
? trace_hardirqs_on_caller+0x3f4/0x560
SyS_keyctl+0x72/0x2c0
entry_SYSCALL_64_fastpath+0x1f/0xbe
RIP: 0033:0x43ccf9
RSP: 002b:00007ffeeec96158 EFLAGS: 00000246 ORIG_RAX: 00000000000000fa
RAX: ffffffffffffffda RBX: 000000000248b9b9 RCX: 000000000043ccf9
RDX: 00007ffeeec96170 RSI: 00007ffeeec96160 RDI: 0000000000000017
RBP: 0000000000000046 R08: 0000000000000000 R09: 0248b9b9143dc936
R10: 0000000000001000 R11: 0000000000000246 R12: 0000000000000000
R13: 0000000000409670 R14: 0000000000409700 R15: 0000000000000000
Allocated by task 367:
save_stack_trace+0x16/0x20
kasan_kmalloc+0xeb/0x180
kmem_cache_alloc_trace+0x114/0x300
mpi_alloc+0x4b/0x230
mpi_read_raw_data+0xbe/0x360
dh_set_secret+0x1dc/0x460
__keyctl_dh_compute+0x623/0xe90
Freed by task 367:
kasan_slab_free+0xab/0x180
kfree+0xb5/0x210
mpi_free+0xcb/0x170
dh_set_secret+0x2d7/0x460
Fixes: 802c7f1c84e4 ("crypto: dh - Add DH software implementation")
Reviewed-by: Tudor Ambarus <tudor.ambarus@microchip.com>
commit ee34e2644a78e2561742bea8c4bdcf83cabf90a7 upstream.
setkey can be called multiple times during the existence
of the transformation object. In case of multiple setkey calls,
the old key was not freed and we leaked memory.
Free the old MPI key if any.
commit ccd9888f14a8019c0bbdeeae758aba1f58693712 upstream.
The "qat-dh" DH implementation assumes that 'key' and 'g' can be copied
into a buffer with size 'p_size'. However it was never checked that
that was actually the case, which most likely allowed users to cause a
buffer underflow via KEYCTL_DH_COMPUTE.
Fix this by updating crypto_dh_decode_key() to verify this precondition
for all DH implementations.
Fixes: c9839143ebbf ("crypto: qat - Add DH support")
commit 199512b1234f09e44d592153ec82b44212b2f0c4 upstream.
If 'p' is 0 for the software Diffie-Hellman implementation, then
dh_max_size() returns 0. In the case of KEYCTL_DH_COMPUTE, this causes
ZERO_SIZE_PTR to be passed to sg_init_one(), which with
CONFIG_DEBUG_SG=y triggers the 'BUG_ON(!virt_addr_valid(buf));' in
sg_set_buf().
Fix this by making crypto_dh_decode_key() reject 0 for 'p'. p=0 makes
no sense for any DH implementation because 'p' is supposed to be a prime
number. Moreover, 'mod 0' is not mathematically defined.
Bug report:
kernel BUG at ./include/linux/scatterlist.h:140!
invalid opcode: 0000 [#1] SMP KASAN
CPU: 0 PID: 27112 Comm: syz-executor2 Not tainted 4.14.0-rc7-00010-gf5dbb5d0ce32-dirty #7
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.3-20171021_125229-anatol 04/01/2014
task: ffff88006caac0c0 task.stack: ffff88006c7c8000
RIP: 0010:sg_set_buf include/linux/scatterlist.h:140 [inline]
RIP: 0010:sg_init_one+0x1b3/0x240 lib/scatterlist.c:156
RSP: 0018:ffff88006c7cfb08 EFLAGS: 00010216
RAX: 0000000000010000 RBX: ffff88006c7cfe30 RCX: 00000000000064ee
RDX: ffffffff81cf64c3 RSI: ffffc90000d72000 RDI: ffffffff92e937e0
RBP: ffff88006c7cfb30 R08: ffffed000d8f9fab R09: ffff88006c7cfd30
R10: 0000000000000005 R11: ffffed000d8f9faa R12: ffff88006c7cfd30
R13: 0000000000000000 R14: 0000000000000010 R15: ffff88006c7cfc50
FS: 00007fce190fa700(0000) GS:ffff88003ea00000(0000) knlGS:0000000000000000
CR2: 00007fffc6b33db8 CR3: 000000003cf64000 CR4: 00000000000006f0
Call Trace:
__keyctl_dh_compute+0xa95/0x19b0 security/keys/dh.c:360
keyctl_dh_compute+0xac/0x100 security/keys/dh.c:434
SYSC_keyctl security/keys/keyctl.c:1745 [inline]
SyS_keyctl+0x72/0x2c0 security/keys/keyctl.c:1641
RIP: 0033:0x4585c9
RSP: 002b:00007fce190f9bd8 EFLAGS: 00000216 ORIG_RAX: 00000000000000fa
RAX: ffffffffffffffda RBX: 0000000000738020 RCX: 00000000004585c9
RDX: 000000002000d000 RSI: 0000000020000ff4 RDI: 0000000000000017
RBP: 0000000000000046 R08: 0000000020008000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000216 R12: 00007fff6e610cde
R13: 00007fff6e610cdf R14: 00007fce190fa700 R15: 0000000000000000
Code: 03 0f b6 14 02 48 89 f8 83 e0 07 83 c0 03 38 d0 7c 04 84 d2 75 33 5b 45 89 6c 24 14 41 5c 41 5d 41 5e 41 5f 5d c3 e8 fd 8f 68 ff <0f> 0b e8 f6 8f 68 ff 0f 0b e8 ef 8f 68 ff 0f 0b e8 e8 8f 68 ff 20
RIP: sg_set_buf include/linux/scatterlist.h:140 [inline] RSP: ffff88006c7cfb08
RIP: sg_init_one+0x1b3/0x240 lib/scatterlist.c:156 RSP: ffff88006c7cfb08
This reverts commit 6145171a6bc0abdc3eca7a4b795ede467d2ba569.
The commit fixes a bug that was only introduced in 4.10, thus is
irrelevant for <=4.9.
commit 441f99c90497e15aa3ad1dbabd56187e29614348 upstream.
The IV buffer used during CCM operations is used twice, during both the
hashing step and the ciphering step.
When using a hardware accelerator that updates the contents of the IV
buffer at the end of ciphering operations, the value will be modified.
In the decryption case, the subsequent setup of the hashing algorithm
will interpret the updated IV instead of the original value, which can
lead to out-of-bounds writes.
Reuse the idata buffer, only used in the hashing step, to preserve the
IV's value during the ciphering step in the decryption case.
Signed-off-by: Romain Izard <romain.izard.pro@gmail.com>
commit 68a1fdbbf8bd3378325e45c19e167a165f9ffc3a upstream.
The ASN.1 parser does not necessarily set the sinfo field,
this patch prevents a NULL pointer dereference on broken
input.
Fixes: 99db44350672 ("PKCS#7: Appropriately restrict authenticated attributes and content type")
Signed-off-by: Eric Sesterhenn <eric.sesterhenn@x41-dsec.de>
[ Upstream commit 12cb3a1c4184f891d965d1f39f8cfcc9ef617647 ]
Since the
commit f1c131b45410a202eb45cc55980a7a9e4e4b4f40
crypto: xts - Convert to skcipher
the XTS mode is based on ECB, so the mode must select
ECB otherwise it can fail to initialize.
Signed-off-by: Milan Broz <gmazyland@gmail.com>
commit b61907bb42409adf9b3120f741af7c57dd7e3db2 upstream.
The shash ahash digest adaptor function may crash if given a
zero-length input together with a null SG list. This is because
it tries to read the SG list before looking at the length.
This patch fixes it by checking the length first.
Reported-by: Stephan Müller<smueller@chronox.de>
Tested-by: Stephan Müller <smueller@chronox.de>
commit bd6227a150fdb56e7bb734976ef6e53a2c1cb334 upstream.
During the change to use aligned buffers, the deallocation code path was
not updated correctly. The current code tries to free the aligned buffer
pointer and not the original buffer pointer as it is supposed to.
Thus, the code is updated to free the original buffer pointer and set
the aligned buffer pointer that is used throughout the code to NULL.
CC: Herbert Xu <herbert@gondor.apana.org.au>
Fixed differently upstream as commit 2d97591ef43d ("crypto: af_alg - consolidation of duplicate code")
The SGL is MAX_SGL_ENTS + 1 in size. The last SG entry is used for the
chaining and is properly updated with the sg_chain invocation. During
the filling-in of the initial SG entries, sg_mark_end is called for each
SG entry. This is appropriate as long as no additional SGL is chained
with the current SGL. However, when a new SGL is chained and the last
SG entry is updated with sg_chain, the last but one entry still contains
the end marker from the sg_mark_end. This end marker must be removed as
otherwise a walk of the chained SGLs will cause a NULL pointer
dereference at the last but one SG entry, because sg_next will return
NULL.
The patch only applies to all kernels up to and including 4.13. The
patch 2d97591ef43d0587be22ad1b0d758d6df4999a0b added to 4.14-rc1
introduced a complete new code base which addresses this bug in
a different way. Yet, that patch is too invasive for stable kernels
and was therefore not marked for stable.
Fixes: 8ff590903d5fc ("crypto: algif_skcipher - User-space interface for skcipher operations")
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
commit 445a582738de6802669aeed9c33ca406c23c3b1f upstream.
For asynchronous operation, SGs are allocated without a page mapped to
them or with a page that is not used (ref-counted). If the SGL is freed,
the code must only call put_page for an SG if there was a page assigned
and ref-counted in the first place.
This fixes a kernel crash when using io_submit with more than one iocb
using the sendmsg and sendpage (vmsplice/splice) interface.
commit 41cdf7a45389e01991ee31e3301ed83cb3e3f7dc upstream.
When authencesn is used together with digest_null a crash will
occur on the decrypt path. This is because normally we perform
a special setup to preserve the ESN, but this is skipped if there
is no authentication. However, on the post-authentication path
it always expects the preservation to be in place, thus causing
a crash when digest_null is used.
This patch fixes this by also skipping the post-processing when
there is no authentication.
Fixes: 104880a6b470 ("crypto: authencesn - Convert to new AEAD...")
Reported-by: Jan Tluka <jtluka@redhat.com>
commit fec17cb2231733174e039ad9054fa16bb358e2ec upstream.
Otherwise, we enable all sorts of forgeries via timing attack.
Signed-off-by: Jason A. Donenfeld <Jason@zx2c4.com>
Suggested-by: Stephan Müller <smueller@chronox.de>
Cc: linux-crypto@vger.kernel.org
