path: root/crypto
2017-03-30crypto: algif_hash - avoid zero-sized arrayJiri Slaby
commit 6207119444595d287b1e9e83a2066c17209698f3 upstream. With this reproducer: struct sockaddr_alg alg = { .salg_family = 0x26, .salg_type = "hash", .salg_feat = 0xf, .salg_mask = 0x5, .salg_name = "digest_null", }; int sock, sock2; sock = socket(AF_ALG, SOCK_SEQPACKET, 0); bind(sock, (struct sockaddr *)&alg, sizeof(alg)); sock2 = accept(sock, NULL, NULL); setsockopt(sock, SOL_ALG, ALG_SET_KEY, "\x9b\xca", 2); accept(sock2, NULL, NULL); ==== 8< ======== 8< ======== 8< ======== 8< ==== one can immediatelly see an UBSAN warning: UBSAN: Undefined behaviour in crypto/algif_hash.c:187:7 variable length array bound value 0 <= 0 CPU: 0 PID: 15949 Comm: syz-executor Tainted: G E 4.4.30-0-default #1 ... Call Trace: ... [<ffffffff81d598fd>] ? __ubsan_handle_vla_bound_not_positive+0x13d/0x188 [<ffffffff81d597c0>] ? __ubsan_handle_out_of_bounds+0x1bc/0x1bc [<ffffffffa0e2204d>] ? hash_accept+0x5bd/0x7d0 [algif_hash] [<ffffffffa0e2293f>] ? hash_accept_nokey+0x3f/0x51 [algif_hash] [<ffffffffa0e206b0>] ? hash_accept_parent_nokey+0x4a0/0x4a0 [algif_hash] [<ffffffff8235c42b>] ? SyS_accept+0x2b/0x40 It is a correct warning, as hash state is propagated to accept as zero, but creating a zero-length variable array is not allowed in C. Fix this as proposed by Herbert -- do "?: 1" on that site. No sizeof or similar happens in the code there, so we just allocate one byte even though we do not use the array. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: "David S. Miller" <davem@davemloft.net> (maintainer:CRYPTO API) Reported-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-26crypto: mcryptd - Fix load failureWang, Rui Y
commit ddef482420b1ba8ec45e6123a7e8d3f67b21e5e3 upstream. mcryptd_create_hash() fails by returning -EINVAL, causing any driver using mcryptd to fail to load. It is because it needs to set its statesize properly. Signed-off-by: Rui Wang <rui.y.wang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Cc: Sumit Semwal <sumit.semwal@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-26crypto: cryptd - Assign statesize properlyWang, Rui Y
commit 1a07834024dfca5c4bed5de8f8714306e0a11836 upstream. cryptd_create_hash() fails by returning -EINVAL. It is because after 8996eafdc ("crypto: ahash - ensure statesize is non-zero") all ahash drivers must have a non-zero statesize. This patch fixes the problem by properly assigning the statesize. Signed-off-by: Rui Wang <rui.y.wang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Cc: Sumit Semwal <sumit.semwal@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-18crypto: improve gcc optimization flags for serpent and wp512Arnd Bergmann
commit 7d6e9105026788c497f0ab32fa16c82f4ab5ff61 upstream. An ancient gcc bug (first reported in 2003) has apparently resurfaced on MIPS, where kernelci.org reports an overly large stack frame in the whirlpool hash algorithm: crypto/wp512.c:987:1: warning: the frame size of 1112 bytes is larger than 1024 bytes [-Wframe-larger-than=] With some testing in different configurations, I'm seeing large variations in stack frames size up to 1500 bytes for what should have around 300 bytes at most. I also checked the reference implementation, which is essentially the same code but also comes with some test and benchmarking infrastructure. It seems that recent compiler versions on at least arm, arm64 and powerpc have a partial fix for this problem, but enabling "-fsched-pressure", but even with that fix they suffer from the issue to a certain degree. Some testing on arm64 shows that the time needed to hash a given amount of data is roughly proportional to the stack frame size here, which makes sense given that the wp512 implementation is doing lots of loads for table lookups, and the problem with the overly large stack is a result of doing a lot more loads and stores for spilled registers (as seen from inspecting the object code). Disabling -fschedule-insns consistently fixes the problem for wp512, in my collection of cross-compilers, the results are consistently better or identical when comparing the stack sizes in this function, though some architectures (notable x86) have schedule-insns disabled by default. The four columns are: default: -O2 press: -O2 -fsched-pressure nopress: -O2 -fschedule-insns -fno-sched-pressure nosched: -O2 -no-schedule-insns (disables sched-pressure) default press nopress nosched alpha-linux-gcc-4.9.3 1136 848 1136 176 am33_2.0-linux-gcc-4.9.3 2100 2076 2100 2104 arm-linux-gnueabi-gcc-4.9.3 848 848 1048 352 cris-linux-gcc-4.9.3 272 272 272 272 frv-linux-gcc-4.9.3 1128 1000 1128 280 hppa64-linux-gcc-4.9.3 1128 336 1128 184 hppa-linux-gcc-4.9.3 644 308 644 276 i386-linux-gcc-4.9.3 352 352 352 352 m32r-linux-gcc-4.9.3 720 656 720 268 microblaze-linux-gcc-4.9.3 1108 604 1108 256 mips64-linux-gcc-4.9.3 1328 592 1328 208 mips-linux-gcc-4.9.3 1096 624 1096 240 powerpc64-linux-gcc-4.9.3 1088 432 1088 160 powerpc-linux-gcc-4.9.3 1080 584 1080 224 s390-linux-gcc-4.9.3 456 456 624 360 sh3-linux-gcc-4.9.3 292 292 292 292 sparc64-linux-gcc-4.9.3 992 240 992 208 sparc-linux-gcc-4.9.3 680 592 680 312 x86_64-linux-gcc-4.9.3 224 240 272 224 xtensa-linux-gcc-4.9.3 1152 704 1152 304 aarch64-linux-gcc-7.0.0 224 224 1104 208 arm-linux-gnueabi-gcc-7.0.1 824 824 1048 352 mips-linux-gcc-7.0.0 1120 648 1120 272 x86_64-linux-gcc-7.0.1 240 240 304 240 arm-linux-gnueabi-gcc-4.4.7 840 392 arm-linux-gnueabi-gcc-4.5.4 784 728 784 320 arm-linux-gnueabi-gcc-4.6.4 736 728 736 304 arm-linux-gnueabi-gcc-4.7.4 944 784 944 352 arm-linux-gnueabi-gcc-4.8.5 464 464 760 352 arm-linux-gnueabi-gcc-4.9.3 848 848 1048 352 arm-linux-gnueabi-gcc-5.3.1 824 824 1064 336 arm-linux-gnueabi-gcc-6.1.1 808 808 1056 344 arm-linux-gnueabi-gcc-7.0.1 824 824 1048 352 Trying the same test for serpent-generic, the picture is a bit different, and while -fno-schedule-insns is generally better here than the default, -fsched-pressure wins overall, so I picked that instead. default press nopress nosched alpha-linux-gcc-4.9.3 1392 864 1392 960 am33_2.0-linux-gcc-4.9.3 536 524 536 528 arm-linux-gnueabi-gcc-4.9.3 552 552 776 536 cris-linux-gcc-4.9.3 528 528 528 528 frv-linux-gcc-4.9.3 536 400 536 504 hppa64-linux-gcc-4.9.3 524 208 524 480 hppa-linux-gcc-4.9.3 768 472 768 508 i386-linux-gcc-4.9.3 564 564 564 564 m32r-linux-gcc-4.9.3 712 576 712 532 microblaze-linux-gcc-4.9.3 724 392 724 512 mips64-linux-gcc-4.9.3 720 384 720 496 mips-linux-gcc-4.9.3 728 384 728 496 powerpc64-linux-gcc-4.9.3 704 304 704 480 powerpc-linux-gcc-4.9.3 704 296 704 480 s390-linux-gcc-4.9.3 560 560 592 536 sh3-linux-gcc-4.9.3 540 540 540 540 sparc64-linux-gcc-4.9.3 544 352 544 496 sparc-linux-gcc-4.9.3 544 344 544 496 x86_64-linux-gcc-4.9.3 528 536 576 528 xtensa-linux-gcc-4.9.3 752 544 752 544 aarch64-linux-gcc-7.0.0 432 432 656 480 arm-linux-gnueabi-gcc-7.0.1 616 616 808 536 mips-linux-gcc-7.0.0 720 464 720 488 x86_64-linux-gcc-7.0.1 536 528 600 536 arm-linux-gnueabi-gcc-4.4.7 592 440 arm-linux-gnueabi-gcc-4.5.4 776 448 776 544 arm-linux-gnueabi-gcc-4.6.4 776 448 776 544 arm-linux-gnueabi-gcc-4.7.4 768 448 768 544 arm-linux-gnueabi-gcc-4.8.5 488 488 776 544 arm-linux-gnueabi-gcc-4.9.3 552 552 776 536 arm-linux-gnueabi-gcc-5.3.1 552 552 776 536 arm-linux-gnueabi-gcc-6.1.1 560 560 776 536 arm-linux-gnueabi-gcc-7.0.1 616 616 808 536 I did not do any runtime tests with serpent, so it is possible that stack frame size does not directly correlate with runtime performance here and it actually makes things worse, but it's more likely to help here, and the reduced stack frame size is probably enough reason to apply the patch, especially given that the crypto code is often used in deep call chains. Link: https://kernelci.org/build/id/58797d7559b5149efdf6c3a9/logs/ Link: http://www.larc.usp.br/~pbarreto/WhirlpoolPage.html Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=11488 Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=79149 Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-12crypto: testmgr - Pad aes_ccm_enc_tv_template vectorLaura Abbott
commit 1c68bb0f62bf8de8bb30123ea840d5168f25abea upstream. Running with KASAN and crypto tests currently gives BUG: KASAN: global-out-of-bounds in __test_aead+0x9d9/0x2200 at addr ffffffff8212fca0 Read of size 16 by task cryptomgr_test/1107 Address belongs to variable 0xffffffff8212fca0 CPU: 0 PID: 1107 Comm: cryptomgr_test Not tainted 4.10.0+ #45 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.9.1-1.fc24 04/01/2014 Call Trace: dump_stack+0x63/0x8a kasan_report.part.1+0x4a7/0x4e0 ? __test_aead+0x9d9/0x2200 ? crypto_ccm_init_crypt+0x218/0x3c0 [ccm] kasan_report+0x20/0x30 check_memory_region+0x13c/0x1a0 memcpy+0x23/0x50 __test_aead+0x9d9/0x2200 ? kasan_unpoison_shadow+0x35/0x50 ? alg_test_akcipher+0xf0/0xf0 ? crypto_skcipher_init_tfm+0x2e3/0x310 ? crypto_spawn_tfm2+0x37/0x60 ? crypto_ccm_init_tfm+0xa9/0xd0 [ccm] ? crypto_aead_init_tfm+0x7b/0x90 ? crypto_alloc_tfm+0xc4/0x190 test_aead+0x28/0xc0 alg_test_aead+0x54/0xd0 alg_test+0x1eb/0x3d0 ? alg_find_test+0x90/0x90 ? __sched_text_start+0x8/0x8 ? __wake_up_common+0x70/0xb0 cryptomgr_test+0x4d/0x60 kthread+0x173/0x1c0 ? crypto_acomp_scomp_free_ctx+0x60/0x60 ? kthread_create_on_node+0xa0/0xa0 ret_from_fork+0x2c/0x40 Memory state around the buggy address: ffffffff8212fb80: 00 00 00 00 01 fa fa fa fa fa fa fa 00 00 00 00 ffffffff8212fc00: 00 01 fa fa fa fa fa fa 00 00 00 00 01 fa fa fa >ffffffff8212fc80: fa fa fa fa 00 05 fa fa fa fa fa fa 00 00 00 00 ^ ffffffff8212fd00: 01 fa fa fa fa fa fa fa 00 00 00 00 01 fa fa fa ffffffff8212fd80: fa fa fa fa 00 00 00 00 00 05 fa fa fa fa fa fa This always happens on the same IV which is less than 16 bytes. Per Ard, "CCM IVs are 16 bytes, but due to the way they are constructed internally, the final couple of bytes of input IV are dont-cares. Apparently, we do read all 16 bytes, which triggers the KASAN errors." Fix this by padding the IV with null bytes to be at least 16 bytes. Fixes: 0bc5a6c5c79a ("crypto: testmgr - Disable rfc4309 test and convert test vectors") Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Laura Abbott <labbott@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-09crypto: api - Clear CRYPTO_ALG_DEAD bit before registering an algSalvatore Benedetto
commit d6040764adcb5cb6de1489422411d701c158bb69 upstream. Make sure CRYPTO_ALG_DEAD bit is cleared before proceeding with the algorithm registration. This fixes qat-dh registration when driver is restarted Signed-off-by: Salvatore Benedetto <salvatore.benedetto@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-12-15crypto: rsa - Add Makefile dependencies to fix parallel buildsDavid Michael
commit 57891633eeef60e732e045731cf20e50ee80acb4 upstream. Both asn1 headers are included by rsa_helper.c, so rsa_helper.o should explicitly depend on them. Signed-off-by: David Michael <david.michael@coreos.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Cc: Tuomas Tynkkynen <tuomas@tuxera.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-12-15crypto: mcryptd - Check mcryptd algorithm compatibilitytim
commit 48a992727d82cb7db076fa15d372178743b1f4cd upstream. Algorithms not compatible with mcryptd could be spawned by mcryptd with a direct crypto_alloc_tfm invocation using a "mcryptd(alg)" name construct. This causes mcryptd to crash the kernel if an arbitrary "alg" is incompatible and not intended to be used with mcryptd. It is an issue if AF_ALG tries to spawn mcryptd(alg) to expose it externally. But such algorithms must be used internally and not be exposed. We added a check to enforce that only internal algorithms are allowed with mcryptd at the time mcryptd is spawning an algorithm. Link: http://marc.info/?l=linux-crypto-vger&m=148063683310477&w=2 Reported-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31crypto: gcm - Fix IV buffer size in crypto_gcm_setkeyOndrej Mosnáček
commit 50d2e6dc1f83db0563c7d6603967bf9585ce934b upstream. The cipher block size for GCM is 16 bytes, and thus the CTR transform used in crypto_gcm_setkey() will also expect a 16-byte IV. However, the code currently reserves only 8 bytes for the IV, causing an out-of-bounds access in the CTR transform. This patch fixes the issue by setting the size of the IV buffer to 16 bytes. Fixes: 84c911523020 ("[CRYPTO] gcm: Add support for async ciphers") Signed-off-by: Ondrej Mosnacek <omosnacek@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28PKCS#7: Don't require SpcSpOpusInfo in Authenticode pkcs7 signaturesPeter Jones
commit 7ee7014d0eb6bcac679c0bd5fe9ce65bc4325648 upstream. Dave Young reported: > Hi, > > I saw the warning "Missing required AuthAttr" when testing kexec, > known issue? Idea about how to fix it? > > The kernel is latest linus tree plus sevral patches from Toshi to > cleanup io resource structure. > > in function pkcs7_sig_note_set_of_authattrs(): > if (!test_bit(sinfo_has_content_type, &sinfo->aa_set) || > !test_bit(sinfo_has_message_digest, &sinfo->aa_set) || > (ctx->msg->data_type == OID_msIndirectData && > !test_bit(sinfo_has_ms_opus_info, &sinfo->aa_set))) { > pr_warn("Missing required AuthAttr\n"); > return -EBADMSG; > } > > The third condition below is true: > (ctx->msg->data_type == OID_msIndirectData && > !test_bit(sinfo_has_ms_opus_info, &sinfo->aa_set)) > > I signed the kernel with redhat test key like below: > pesign -c 'Red Hat Test Certificate' -i arch/x86/boot/bzImage -o /boot/vmlinuz-4.4.0-rc8+ -s --force And right he is! The Authenticode specification is a paragon amongst technical documents, and has this pearl of wisdom to offer: --------------------------------- Authenticode-Specific SignerInfo UnauthenticatedAttributes Structures The following Authenticode-specific data structures are present in SignerInfo authenticated attributes. SpcSpOpusInfo SpcSpOpusInfo is identified by SPC_SP_OPUS_INFO_OBJID (1.3.6.1.4.1.311.2.1.12) and is defined as follows: SpcSpOpusInfo ::= SEQUENCE { programName [0] EXPLICIT SpcString OPTIONAL, moreInfo [1] EXPLICIT SpcLink OPTIONAL, } --#public-- SpcSpOpusInfo has two fields: programName This field contains the program description: If publisher chooses not to specify a description, the SpcString structure contains a zero-length program name. If the publisher chooses to specify a description, the SpcString structure contains a Unicode string. moreInfo This field is set to an SPCLink structure that contains a URL for a Web site with more information about the signer. The URL is an ASCII string. --------------------------------- Which is to say that this is an optional *unauthenticated* field which may be present in the Authenticated Attribute list. This is not how pkcs7 is supposed to work, so when David implemented this, he didn't appreciate the subtlety the original spec author was working with, and missed the part of the sublime prose that says this Authenticated Attribute is an Unauthenticated Attribute. As a result, the code in question simply takes as given that the Authenticated Attributes should be authenticated. But this one should not, individually. Because it says it's not authenticated. It still has to hash right so the TBS digest is correct. So it is both authenticated and unauthenticated, all at once. Truly, a wonder of technical accomplishment. Additionally, pesign's implementation has always attempted to be compatible with the signatures emitted from contemporary versions of Microsoft's signtool.exe. During the initial implementation, Microsoft signatures always produced the same values for SpcSpOpusInfo - {U"Microsoft Windows", "http://www.microsoft.com"} - without regard to who the signer was. Sometime between Windows 8 and Windows 8.1 they stopped including the field in their signatures altogether, and as such pesign stopped producing them in commits c0c4da6 and d79cb0c, sometime around June of 2012. The theory here is that anything that breaks with pesign signatures would also be breaking with signtool.exe sigs as well, and that'll be a more noticed problem for firmwares parsing it, so it'll get fixed. The fact that we've done exactly this bug in Linux code is first class, grade A irony. So anyway, we should not be checking this field for presence or any particular value: if the field exists, it should be at the right place, but aside from that, as long as the hash matches the field is good. Signed-off-by: Peter Jones <pjones@redhat.com> Tested-by: Dave Young <dyoung@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Juerg Haefliger <juerg.haefliger@hpe.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-22crypto: ghash-generic - move common definitions to a new header fileMarcelo Cerri
commit a397ba829d7f8aff4c90af3704573a28ccd61a59 upstream. Move common values and types used by ghash-generic to a new header file so drivers can directly use ghash-generic as a fallback implementation. Fixes: cc333cd68dfa ("crypto: vmx - Adding GHASH routines for VMX module") Signed-off-by: Marcelo Cerri <marcelo.cerri@canonical.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-22async_pq_val: fix DMA memory leakJustin Maggard
commit c84750906b4818d4929fbf73a4ae6c113b94f52b upstream. Add missing dmaengine_unmap_put(), so we don't OOM during RAID6 sync. Fixes: 1786b943dad0 ("async_pq_val: convert to dmaengine_unmap_data") Signed-off-by: Justin Maggard <jmaggard@netgear.com> Reviewed-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-30crypto: echainiv - Replace chaining with multiplicationHerbert Xu
commit 53a5d5ddccf849dbc27a8c1bba0b43c3a45fb792 upstream. The current implementation uses a global per-cpu array to store data which are used to derive the next IV. This is insecure as the attacker may change the stored data. This patch removes all traces of chaining and replaces it with multiplication of the salt and the sequence number. Fixes: a10f554fa7e0 ("crypto: echainiv - Add encrypted chain IV...") Reported-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-30crypto: skcipher - Fix blkcipher walk OOM crashHerbert Xu
commit acdb04d0b36769b3e05990c488dc74d8b7ac8060 upstream. When we need to allocate a temporary blkcipher_walk_next and it fails, the code is supposed to take the slow path of processing the data block by block. However, due to an unrelated change we instead end up dereferencing the NULL pointer. This patch fixes it by moving the unrelated bsize setting out of the way so that we enter the slow path as inteded. Fixes: 7607bd8ff03b ("[CRYPTO] blkcipher: Added blkcipher_walk_virt_block") Reported-by: xiakaixu <xiakaixu@huawei.com> Reported-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Tested-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-24crypto: cryptd - initialize child shash_desc on importArd Biesheuvel
commit 0bd2223594a4dcddc1e34b15774a3a4776f7749e upstream. When calling .import() on a cryptd ahash_request, the structure members that describe the child transform in the shash_desc need to be initialized like they are when calling .init() Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-16crypto: scatterwalk - Fix test in scatterwalk_doneHerbert Xu
commit 5f070e81bee35f1b7bd1477bb223a873ff657803 upstream. When there is more data to be processed, the current test in scatterwalk_done may prevent us from calling pagedone even when we should. In particular, if we're on an SG entry spanning multiple pages where the last page is not a full page, we will incorrectly skip calling pagedone on the second last page. This patch fixes this by adding a separate test for whether we've reached the end of a page. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-16crypto: gcm - Filter out async ghash if necessaryHerbert Xu
commit b30bdfa86431afbafe15284a3ad5ac19b49b88e3 upstream. As it is if you ask for a sync gcm you may actually end up with an async one because it does not filter out async implementations of ghash. This patch fixes this by adding the necessary filter when looking for ghash. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-07-11crypto: user - re-add size check for CRYPTO_MSG_GETALGMathias Krause
commit 055ddaace03580455a7b7dbea8e93d62acee61fc upstream. Commit 9aa867e46565 ("crypto: user - Add CRYPTO_MSG_DELRNG") accidentally removed the minimum size check for CRYPTO_MSG_GETALG netlink messages. This allows userland to send a truncated CRYPTO_MSG_GETALG message as short as a netlink header only making crypto_report() operate on uninitialized memory by accessing data beyond the end of the netlink message. Fix this be re-adding the minimum required size of CRYPTO_MSG_GETALG messages to the crypto_msg_min[] array. Fixes: 9aa867e46565 ("crypto: user - Add CRYPTO_MSG_DELRNG") Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-06-24crypto: public_key: select CRYPTO_AKCIPHERArnd Bergmann
commit bad6a185b4d6f81d0ed2b6e4c16307969f160b95 upstream. In some rare randconfig builds, we can end up with ASYMMETRIC_PUBLIC_KEY_SUBTYPE enabled but CRYPTO_AKCIPHER disabled, which fails to link because of the reference to crypto_alloc_akcipher: crypto/built-in.o: In function `public_key_verify_signature': :(.text+0x110e4): undefined reference to `crypto_alloc_akcipher' This adds a Kconfig 'select' statement to ensure the dependency is always there. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-18crypto: testmgr - Use kmalloc memory for RSA inputHerbert Xu
commit df27b26f04ed388ff4cc2b5d8cfdb5d97678816f upstream. As akcipher uses an SG interface, you must not use vmalloc memory as input for it. This patch fixes testmgr to copy the vmalloc test vectors to kmalloc memory before running the test. This patch also removes a superfluous sg_virt call in do_test_rsa. Reported-by: Anatoly Pugachev <matorola@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-18crypto: hash - Fix page length clamping in hash walkHerbert Xu
commit 13f4bb78cf6a312bbdec367ba3da044b09bf0e29 upstream. The crypto hash walk code is broken when supplied with an offset greater than or equal to PAGE_SIZE. This patch fixes it by adjusting walk->pg and walk->offset when this happens. Reported-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-20PKCS#7: pkcs7_validate_trust(): initialize the _trusted output argumentNicolai Stange
commit e54358915d0a00399c11c2c23ae1be674cba188a upstream. Despite what the DocBook comment to pkcs7_validate_trust() says, the *_trusted argument is never set to false. pkcs7_validate_trust() only positively sets *_trusted upon encountering a trusted PKCS#7 SignedInfo block. This is quite unfortunate since its callers, system_verify_data() for example, depend on pkcs7_validate_trust() clearing *_trusted on non-trust. Indeed, UBSAN splats when attempting to load the uninitialized local variable 'trusted' from system_verify_data() in pkcs7_validate_trust(): UBSAN: Undefined behaviour in crypto/asymmetric_keys/pkcs7_trust.c:194:14 load of value 82 is not a valid value for type '_Bool' [...] Call Trace: [<ffffffff818c4d35>] dump_stack+0xbc/0x117 [<ffffffff818c4c79>] ? _atomic_dec_and_lock+0x169/0x169 [<ffffffff8194113b>] ubsan_epilogue+0xd/0x4e [<ffffffff819419fa>] __ubsan_handle_load_invalid_value+0x111/0x158 [<ffffffff819418e9>] ? val_to_string.constprop.12+0xcf/0xcf [<ffffffff818334a4>] ? x509_request_asymmetric_key+0x114/0x370 [<ffffffff814b83f0>] ? kfree+0x220/0x370 [<ffffffff818312c2>] ? public_key_verify_signature_2+0x32/0x50 [<ffffffff81835e04>] pkcs7_validate_trust+0x524/0x5f0 [<ffffffff813c391a>] system_verify_data+0xca/0x170 [<ffffffff813c3850>] ? top_trace_array+0x9b/0x9b [<ffffffff81510b29>] ? __vfs_read+0x279/0x3d0 [<ffffffff8129372f>] mod_verify_sig+0x1ff/0x290 [...] The implication is that pkcs7_validate_trust() effectively grants trust when it really shouldn't have. Fix this by explicitly setting *_trusted to false at the very beginning of pkcs7_validate_trust(). Signed-off-by: Nicolai Stange <nicstange@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-12X.509: Fix leap year handling againDavid Howells
commit ac4cbedfdf55455b4c447f17f0fa027dbf02b2a6 upstream. There are still a couple of minor issues in the X.509 leap year handling: (1) To avoid doing a modulus-by-400 in addition to a modulus-by-100 when determining whether the year is a leap year or not, I divided the year by 100 after doing the modulus-by-100, thereby letting the compiler do one instruction for both, and then did a modulus-by-4. Unfortunately, I then passed the now-modified year value to mktime64() to construct a time value. Since this isn't a fast path and since mktime64() does a bunch of divisions, just condense down to "% 400". It's also easier to read. (2) The default month length for any February where the year doesn't divide by four exactly is obtained from the month_length[] array where the value is 29, not 28. This is fixed by altering the table. Reported-by: Rudolf Polzer <rpolzer@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: David Woodhouse <David.Woodhouse@intel.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-12crypto: keywrap - memzero the correct memoryDan Carpenter
commit 2b8b28fd232233c22fb61009dd8b0587390d2875 upstream. We're clearing the wrong memory. The memory corruption is likely harmless because we weren't going to use that stack memory again but not zeroing is a potential information leak. Fixes: e28facde3c39 ('crypto: keywrap - add key wrapping block chaining mode') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: algif_skcipher - Do not set MAY_BACKLOG on the async pathHerbert Xu
commit dad41997063723eaf5f77bc2015606a5a9bce320 upstream. The async path cannot use MAY_BACKLOG because it is not meant to block, which is what MAY_BACKLOG does. On the other hand, both the sync and async paths can make use of MAY_SLEEP. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: algif_skcipher - Do not dereference ctx without socket lockHerbert Xu
commit 6454c2b83f719057069777132b13949e4c6b6350 upstream. Any access to non-constant bits of the private context must be done under the socket lock, in particular, this includes ctx->req. This patch moves such accesses under the lock, and fetches the tfm from the parent socket which is guaranteed to be constant, rather than from ctx->req. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: algif_skcipher - Do not assume that req is unchangedHerbert Xu
commit ec69bbfb9902c32a5c1492f2b1b8ad032a66d724 upstream. The async path in algif_skcipher assumes that the crypto completion function will be called with the original request. This is not necessarily the case. In fact there is no need for this anyway since we already embed information into the request with struct skcipher_async_req. This patch adds a pointer to that struct and then passes it as the data to the callback function. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Tested-by: Tadeusz Struk <tadeusz.struk@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: user - lock crypto_alg_list on alg dumpMathias Krause
commit 63e41ebc6630f39422d87f8a4bade1e793f37a01 upstream. We miss to take the crypto_alg_sem semaphore when traversing the crypto_alg_list for CRYPTO_MSG_GETALG dumps. This allows a race with crypto_unregister_alg() removing algorithms from the list while we're still traversing it, thereby leading to a use-after-free as show below: [ 3482.071639] general protection fault: 0000 [#1] SMP [ 3482.075639] Modules linked in: aes_x86_64 glue_helper lrw ablk_helper cryptd gf128mul ipv6 pcspkr serio_raw virtio_net microcode virtio_pci virtio_ring virtio sr_mod cdrom [last unloaded: aesni_intel] [ 3482.075639] CPU: 1 PID: 11065 Comm: crconf Not tainted 4.3.4-grsec+ #126 [ 3482.075639] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.7.5-20140531_083030-gandalf 04/01/2014 [ 3482.075639] task: ffff88001cd41a40 ti: ffff88001cd422c8 task.ti: ffff88001cd422c8 [ 3482.075639] RIP: 0010:[<ffffffff93722bd3>] [<ffffffff93722bd3>] strncpy+0x13/0x30 [ 3482.075639] RSP: 0018:ffff88001f713b60 EFLAGS: 00010202 [ 3482.075639] RAX: ffff88001f6c4430 RBX: ffff88001f6c43a0 RCX: ffff88001f6c4430 [ 3482.075639] RDX: 0000000000000040 RSI: fefefefefefeff16 RDI: ffff88001f6c4430 [ 3482.075639] RBP: ffff88001f713b60 R08: ffff88001f6c4470 R09: ffff88001f6c4480 [ 3482.075639] R10: 0000000000000002 R11: 0000000000000246 R12: ffff88001ce2aa28 [ 3482.075639] R13: ffff880000093700 R14: ffff88001f5e4bf8 R15: 0000000000003b20 [ 3482.075639] FS: 0000033826fa2700(0000) GS:ffff88001e900000(0000) knlGS:0000000000000000 [ 3482.075639] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 3482.075639] CR2: ffffffffff600400 CR3: 00000000139ec000 CR4: 00000000001606f0 [ 3482.075639] Stack: [ 3482.075639] ffff88001f713bd8 ffffffff936ccd00 ffff88001e5c4200 ffff880000093700 [ 3482.075639] ffff88001f713bd0 ffffffff938ef4bf 0000000000000000 0000000000003b20 [ 3482.075639] ffff88001f5e4bf8 ffff88001f5e4848 0000000000000000 0000000000003b20 [ 3482.075639] Call Trace: [ 3482.075639] [<ffffffff936ccd00>] crypto_report_alg+0xc0/0x3e0 [ 3482.075639] [<ffffffff938ef4bf>] ? __alloc_skb+0x16f/0x300 [ 3482.075639] [<ffffffff936cd08a>] crypto_dump_report+0x6a/0x90 [ 3482.075639] [<ffffffff93935707>] netlink_dump+0x147/0x2e0 [ 3482.075639] [<ffffffff93935f99>] __netlink_dump_start+0x159/0x190 [ 3482.075639] [<ffffffff936ccb13>] crypto_user_rcv_msg+0xc3/0x130 [ 3482.075639] [<ffffffff936cd020>] ? crypto_report_alg+0x3e0/0x3e0 [ 3482.075639] [<ffffffff936cc4b0>] ? alg_test_crc32c+0x120/0x120 [ 3482.075639] [<ffffffff93933145>] ? __netlink_lookup+0xd5/0x120 [ 3482.075639] [<ffffffff936cca50>] ? crypto_add_alg+0x1d0/0x1d0 [ 3482.075639] [<ffffffff93938141>] netlink_rcv_skb+0xe1/0x130 [ 3482.075639] [<ffffffff936cc4f8>] crypto_netlink_rcv+0x28/0x40 [ 3482.075639] [<ffffffff939375a8>] netlink_unicast+0x108/0x180 [ 3482.075639] [<ffffffff93937c21>] netlink_sendmsg+0x541/0x770 [ 3482.075639] [<ffffffff938e31e1>] sock_sendmsg+0x21/0x40 [ 3482.075639] [<ffffffff938e4763>] SyS_sendto+0xf3/0x130 [ 3482.075639] [<ffffffff93444203>] ? bad_area_nosemaphore+0x13/0x20 [ 3482.075639] [<ffffffff93444470>] ? __do_page_fault+0x80/0x3a0 [ 3482.075639] [<ffffffff939d80cb>] entry_SYSCALL_64_fastpath+0x12/0x6e [ 3482.075639] Code: 88 4a ff 75 ed 5d 48 0f ba 2c 24 3f c3 66 66 2e 0f 1f 84 00 00 00 00 00 55 48 85 d2 48 89 f8 48 89 f9 4c 8d 04 17 48 89 e5 74 15 <0f> b6 16 80 fa 01 88 11 48 83 de ff 48 83 c1 01 4c 39 c1 75 eb [ 3482.075639] RIP [<ffffffff93722bd3>] strncpy+0x13/0x30 To trigger the race run the following loops simultaneously for a while: $ while : ; do modprobe aesni-intel; rmmod aesni-intel; done $ while : ; do crconf show all > /dev/null; done Fix the race by taking the crypto_alg_sem read lock, thereby preventing crypto_unregister_alg() from modifying the algorithm list during the dump. This bug has been detected by the PaX memory sanitize feature. Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Steffen Klassert <steffen.klassert@secunet.com> Cc: PaX Team <pageexec@freemail.hu> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: algif_hash - wait for crypto_ahash_init() to completeWang, Rui Y
commit fe09786178f9df713a4b2dd6b93c0a722346bf5e upstream. hash_sendmsg/sendpage() need to wait for the completion of crypto_ahash_init() otherwise it can cause panic. Signed-off-by: Rui Wang <rui.y.wang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: shash - Fix has_key settingHerbert Xu
commit 00420a65fa2beb3206090ead86942484df2275f3 upstream. The has_key logic is wrong for shash algorithms as they always have a setkey function. So we should instead be testing against shash_no_setkey. Fixes: a5596d633278 ("crypto: hash - Add crypto_ahash_has_setkey") Reported-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Tested-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: algif_skcipher - sendmsg SG marking is off by oneHerbert Xu
commit 202736d99b7f29279db9da61587f11a08a04a9c6 upstream. We mark the end of the SG list in sendmsg and sendpage and unmark it on the next send call. Unfortunately the unmarking in sendmsg is off-by-one, leading to an SG list that is too short. Fixes: 0f477b655a52 ("crypto: algif - Mark sgl end at the end of data") Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: algif_skcipher - Load TX SG list after waitingHerbert Xu
commit 4f0414e54e4d1893c6f08260693f8ef84c929293 upstream. We need to load the TX SG list in sendmsg(2) after waiting for incoming data, not before. Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Tested-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: crc32c - Fix crc32c soft dependencyJean Delvare
commit fd7f6727102a1ccf6b4c1dfcc631f9b546526b26 upstream. I don't think it makes sense for a module to have a soft dependency on itself. This seems quite cyclic by nature and I can't see what purpose it could serve. OTOH libcrc32c calls crypto_alloc_shash("crc32c", 0, 0) so it pretty much assumes that some incarnation of the "crc32c" hash algorithm has been loaded. Therefore it makes sense to have the soft dependency there (as crc-t10dif does.) Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: algif_skcipher - Fix race condition in skcipher_check_keyHerbert Xu
commit 1822793a523e5d5730b19cc21160ff1717421bc8 upstream. We need to lock the child socket in skcipher_check_key as otherwise two simultaneous calls can cause the parent socket to be freed. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: algif_hash - Fix race condition in hash_check_keyHerbert Xu
commit ad46d7e33219218605ea619e32553daf4f346b9f upstream. We need to lock the child socket in hash_check_key as otherwise two simultaneous calls can cause the parent socket to be freed. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: af_alg - Forbid bind(2) when nokey child sockets are presentHerbert Xu
commit a6a48c565f6f112c6983e2a02b1602189ed6e26e upstream. This patch forbids the calling of bind(2) when there are child sockets created by accept(2) in existence, even if they are created on the nokey path. This is needed as those child sockets have references to the tfm object which bind(2) will destroy. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: algif_skcipher - Remove custom release parent functionHerbert Xu
commit d7b65aee1e7b4c87922b0232eaba56a8a143a4a0 upstream. This patch removes the custom release parent function as the generic af_alg_release_parent now works for nokey sockets too. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: algif_hash - Remove custom release parent functionHerbert Xu
commit f1d84af1835846a5a2b827382c5848faf2bb0e75 upstream. This patch removes the custom release parent function as the generic af_alg_release_parent now works for nokey sockets too. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: af_alg - Allow af_af_alg_release_parent to be called on nokey pathHerbert Xu
commit 6a935170a980024dd29199e9dbb5c4da4767a1b9 upstream. This patch allows af_alg_release_parent to be called even for nokey sockets. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: algif_skcipher - Add key check exception for cipher_nullHerbert Xu
commit 6e8d8ecf438792ecf7a3207488fb4eebc4edb040 upstream. This patch adds an exception to the key check so that cipher_null users may continue to use algif_skcipher without setting a key. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: skcipher - Add crypto_skcipher_has_setkeyHerbert Xu
commit a1383cd86a062fc798899ab20f0ec2116cce39cb upstream. This patch adds a way for skcipher users to determine whether a key is required by a transform. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: algif_hash - Require setkey before accept(2)Herbert Xu
commit 6de62f15b581f920ade22d758f4c338311c2f0d4 upstream. Hash implementations that require a key may crash if you use them without setting a key. This patch adds the necessary checks so that if you do attempt to use them without a key that we return -ENOKEY instead of proceeding. This patch also adds a compatibility path to support old applications that do acept(2) before setkey. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: hash - Add crypto_ahash_has_setkeyHerbert Xu
commit a5596d6332787fd383b3b5427b41f94254430827 upstream. This patch adds a way for ahash users to determine whether a key is required by a crypto_ahash transform. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: algif_skcipher - Add nokey compatibility pathHerbert Xu
commit a0fa2d037129a9849918a92d91b79ed6c7bd2818 upstream. This patch adds a compatibility path to support old applications that do acept(2) before setkey. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: af_alg - Add nokey compatibility pathHerbert Xu
commit 37766586c965d63758ad542325a96d5384f4a8c9 upstream. This patch adds a compatibility path to support old applications that do acept(2) before setkey. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: af_alg - Fix socket double-free when accept failsHerbert Xu
commit a383292c86663bbc31ac62cc0c04fc77504636a6 upstream. When we fail an accept(2) call we will end up freeing the socket twice, once due to the direct sk_free call and once again through newsock. This patch fixes this by removing the sk_free call. Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: af_alg - Disallow bind/setkey/... after accept(2)Herbert Xu
commit c840ac6af3f8713a71b4d2363419145760bd6044 upstream. Each af_alg parent socket obtained by socket(2) corresponds to a tfm object once bind(2) has succeeded. An accept(2) call on that parent socket creates a context which then uses the tfm object. Therefore as long as any child sockets created by accept(2) exist the parent socket must not be modified or freed. This patch guarantees this by using locks and a reference count on the parent socket. Any attempt to modify the parent socket will fail with EBUSY. Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-17crypto: algif_skcipher - Require setkey before accept(2)Herbert Xu
commit dd504589577d8e8e70f51f997ad487a4cb6c026f upstream. Some cipher implementations will crash if you try to use them without calling setkey first. This patch adds a check so that the accept(2) call will fail with -ENOKEY if setkey hasn't been done on the socket yet. Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Tested-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-01-07async_tx: use GFP_NOWAIT rather than GFP_IONeilBrown
These async_XX functions are called from md/raid5 in an atomic section, between get_cpu() and put_cpu(), so they must not sleep. So use GFP_NOWAIT rather than GFP_IO. Dan Williams writes: Longer term async_tx needs to be merged into md directly as we can allocate this unmap data statically per-stripe rather than per request. Fixed: 7476bd79fc01 ("async_pq: convert to dmaengine_unmap_data") Cc: stable@vger.kernel.org (v3.13+) Reported-and-tested-by: Stanislav Samsonov <slava@annapurnalabs.com> Acked-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: NeilBrown <neilb@suse.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-12-28Merge branch 'linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6 Pull crypto fix from Herbert Xu: "This fixes a bug in the algif_skcipher interface that can trigger a kernel WARN_ON from user-space. It does so by using the new skcipher interface which unlike the previous ablkcipher does not need to create extra geniv objects which is what was used to trigger the WARN_ON" * 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: algif_skcipher - Use new skcipher interface
