switch: Export symbol switch_set_state.
Signed-off-by: Mike Lockwood <lockwood@android.com>
switch: gpio: Don't call request_irq with interrupts disabled
Signed-off-by: Arve Hjønnevåg <arve@android.com>
switch: Use device_create instead of device_create_drvdata.
device_create_drvdata is obsolete.
switch_gpio: Add missing #include <linux/interrupt.h>
Change-Id: I6c397e41bbe1457162cc69e31a29db5d9f76fccb
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (99 commits)
drivers/virt: add missing linux/interrupt.h to fsl_hypervisor.c
powerpc/85xx: fix mpic configuration in CAMP mode
powerpc: Copy back TIF flags on return from softirq stack
powerpc/64: Make server perfmon only built on ppc64 server devices
powerpc/pseries: Fix hvc_vio.c build due to recent changes
powerpc: Exporting boot_cpuid_phys
powerpc: Add CFAR to oops output
hvc_console: Add kdb support
powerpc/pseries: Fix hvterm_raw_get_chars to accept < 16 chars, fixing xmon
powerpc/irq: Quieten irq mapping printks
powerpc: Enable lockup and hung task detectors in pseries and ppc64 defeconfigs
powerpc: Add mpt2sas driver to pseries and ppc64 defconfig
powerpc: Disable IRQs off tracer in ppc64 defconfig
powerpc: Sync pseries and ppc64 defconfigs
powerpc/pseries/hvconsole: Fix dropped console output
hvc_console: Improve tty/console put_chars handling
powerpc/kdump: Fix timeout in crash_kexec_wait_realmode
powerpc/mm: Fix output of total_ram.
powerpc/cpufreq: Add cpufreq driver for Momentum Maple boards
powerpc: Correct annotations of pmu registration functions
Fix up trivial Kconfig/Makefile conflicts in arch/powerpc, drivers, and
drivers/cpufreq
* 'core-iommu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
iommu/core: Fix build with INTR_REMAP=y && CONFIG_DMAR=n
iommu/amd: Don't use MSI address range for DMA addresses
iommu/amd: Move missing parts to drivers/iommu
iommu: Move iommu Kconfig entries to submenu
x86/ia64: intel-iommu: move to drivers/iommu/
x86: amd_iommu: move to drivers/iommu/
msm: iommu: move to drivers/iommu/
drivers: iommu: move to a dedicated folder
x86/amd-iommu: Store device alias as dev_data pointer
x86/amd-iommu: Search for existind dev_data before allocting a new one
x86/amd-iommu: Allow dev_data->alias to be NULL
x86/amd-iommu: Use only dev_data in low-level domain attach/detach functions
x86/amd-iommu: Use only dev_data for dte and iotlb flushing routines
x86/amd-iommu: Store ATS state in dev_data
x86/amd-iommu: Store devid in dev_data
x86/amd-iommu: Introduce global dev_data_list
x86/amd-iommu: Remove redundant device_flush_dte() calls
iommu-api: Add missing header file
Fix up trivial conflicts (independent additions close to each other) in
drivers/Makefile and include/linux/pci.h
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
Add the drivers/virt directory, which houses drivers that support
virtualization environments, and add the Freescale hypervisor management
driver.
The Freescale hypervisor management driver provides several services to
drivers and applications related to the Freescale hypervisor:
1. An ioctl interface for querying and managing partitions
2. A file interface to reading incoming doorbells
3. An interrupt handler for shutting down the partition upon receiving the
shutdown doorbell from a manager partition
4. A kernel interface for receiving callbacks when a managed partition
shuts down.
IOMMU_API is not selected when no DMA remapping driver is
selected, but the whole drivers/iommu/ directory is only
built with IOMMU_API=y. Fixed with this patch by including
the directory with IOMMU_SUPPORT instead.
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
The NFC subsystem core is responsible for providing the device driver
interface. It is also responsible for providing an interface to the control
operations and data exchange.
Signed-off-by: Lauro Ramos Venancio <lauro.venancio@openbossa.org>
Signed-off-by: Aloisio Almeida Jr <aloisio.almeida@openbossa.org>
Create a dedicated folder for iommu drivers, and move the base
iommu implementation over there.
Grouping the various iommu drivers in a single location will help
finding similar problems shared by different platforms, so they
could be solved once, in the iommu framework, instead of solved
differently (or duplicated) in each driver.
Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com>
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: (33 commits)
x86: poll waiting for I/OAT DMA channel status
maintainers: add dma engine tree details
dmaengine: add TODO items for future work on dma drivers
dmaengine: Add API documentation for slave dma usage
dmaengine/dw_dmac: Update maintainer-ship
dmaengine: move link order
dmaengine/dw_dmac: implement pause and resume in dwc_control
dmaengine/dw_dmac: Replace spin_lock* with irqsave variants and enable submission from callback
dmaengine/dw_dmac: Divide one sg to many desc, if sg len is greater than DWC_MAX_COUNT
dmaengine/dw_dmac: set residue as total len in dwc_tx_status if status is !DMA_SUCCESS
dmaengine/dw_dmac: don't call callback routine in case dmaengine_terminate_all() is called
dmaengine: at_hdmac: pause: no need to wait for FIFO empty
pch_dma: modify pci device table definition
pch_dma: Support new device ML7223 IOH
pch_dma: Support I2S for ML7213 IOH
pch_dma: Fix DMA setting issue
pch_dma: modify for checkpatch
pch_dma: fix dma direction issue for ML7213 IOH video-in
dmaengine: at_hdmac: use descriptor chaining help function
dmaengine: at_hdmac: implement pause and resume in atc_control
Fix up trivial conflict in drivers/dma/dw_dmac.c
* 'timers-ptp-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
ptp: Fix dp83640 build warning when building statically
ptp: Added a clock driver for the National Semiconductor PHYTER.
ptp: Added a clock driver for the IXP46x.
ptp: Added a clock that uses the eTSEC found on the MPC85xx.
ptp: Added a brand new class driver for ptp clocks.
This function makes a deep copy of the platform data to allow it to live
in init memory. For a kernel that supports several machines and so
includes the definition for several leds-gpio devices this saves quite
some memory because all but one definition can be free'd after boot.
As the function is used by arch code it must be builtin and so cannot go
into leds-gpio.c.
[akpm@linux-foundation.org: s/CONFIG_LED_REGISTER_GPIO/CONFIG_LEDS_REGISTER_GPIO/]
Acked-by: Richard Purdie <richard.purdie@linuxfoundation.org>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Tested-by: H Hartley Sweeten <hartleys@visionengravers.com>
This patch adds an infrastructure for hardware clocks that implement
IEEE 1588, the Precision Time Protocol (PTP). A class driver offers a
registration method to particular hardware clock drivers. Each clock is
presented as a standard POSIX clock.
The ancillary clock features are exposed in two different ways, via
the sysfs and by a character device.
Signed-off-by: Richard Cochran <richard.cochran@omicron.at>
Signed-off-by: John Stultz <john.stultz@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6
* 'usb-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (205 commits)
USB: EHCI: Remove SPARC_LEON {read,write}_be definitions from ehci.h
USB: UHCI: Support big endian GRUSBHC HC
sparc: add {read,write}*_be routines
USB: UHCI: Add support for big endian descriptors
USB: UHCI: Use ACCESS_ONCE rather than using a full compiler barrier
USB: UHCI: Add support for big endian mmio
usb-storage: Correct adjust_quirks to include latest flags
usb/isp1760: Fix possible unlink problems
usb/isp1760: Move function isp1760_endpoint_disable() within file.
USB: remove remaining usages of hcd->state from usbcore and fix regression
usb: musb: ux500: add configuration and build options for ux500 dma
usb: musb: ux500: add dma glue layer for ux500
usb: musb: ux500: add dma name for ux500
usb: musb: ux500: add ux500 specific code for gadget side
usb: musb: fix compile error
usb-storage: fix up the unusual_realtek device list
USB: gadget: f_audio: Fix invalid dereference of initdata
EHCI: don't rescan interrupt QHs needlessly
OHCI: fix regression caused by nVidia shutdown workaround
USB: OTG: msm: Free VCCCX regulator even if we can't set the voltage
Move the dmaengine subsystem up early in the drivers Makefile so
DMA is made available early to all drivers, just like e.g.
regulators. Now even regulators can use DMA on the same initlevel.
As a result we can bump the ste_dma40 and coh901318 dmaengine
drivers down one initlevel to subsys_init().
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
Broadcom has released cards based on a new AMBA-based bus type. From a
programming point of view, this new bus type differs from AMBA and does
not use AMBA common registers. It also differs enough from SSB. We
decided that a new bus driver is needed to keep the code clean.
In its current form, the driver detects devices present on the bus and
registers them in the system. It allows registering BCMA drivers for
specified bus devices and provides them basic operations. The bus driver
itself includes two important bus managing drivers: ChipCommon core
driver and PCI(c) core driver. They are early used to allow correct
initialization.
Currently code is limited to supporting buses on PCI(e) devices, however
the driver is designed to be used also on other hosts. The host
abstraction layer is implemented and already used for PCI(e).
Support for PCI(e) hosts is working and seems to be stable (access to
80211 core was tested successfully on a few devices). We can still
optimize it by using some fixed windows, but this can be done later
without affecting any external code. Windows are just ranges in MMIO
used for accessing cores on the bus.
Cc: Greg KH <greg@kroah.com>
Cc: Michael Büsch <mb@bu3sch.de>
Cc: Larry Finger <Larry.Finger@lwfinger.net>
Cc: George Kashperko <george@znau.edu.ua>
Cc: Arend van Spriel <arend@broadcom.com>
Cc: Andy Botting <andy@andybotting.com>
Cc: linuxdriverproject <devel@linuxdriverproject.org>
Cc: linux-kernel@vger.kernel.org <linux-kernel@vger.kernel.org>
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
Instead, make we enter usb/ directory on all
needed cases and enter the subdirectories from
drivers/usb/Makefile.
Signed-off-by: Felipe Balbi <balbi@ti.com>
Renesas SuperH has USBHS IP which can switch Host / Function.
This driver is designed so that Host / Function may dynamically change.
This patch add usb/renesas_usbhs and common code for SuperH USBHS.
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Add a platform-independent hwspinlock framework.
Hardware spinlock devices are needed, e.g., in order to access data
that is shared between remote processors, that otherwise have no
alternative mechanism to accomplish synchronization and mutual exclusion
operations.
Cc: Hari Kanigeri <h-kanigeri2@ti.com>
Cc: Benoit Cousson <b-cousson@ti.com>
Cc: Kevin Hilman <khilman@ti.com>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Paul Walmsley <paul@pwsan.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6
* 'tty-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6:
tty: update MAINTAINERS file due to driver movement
tty: move drivers/serial/ to drivers/tty/serial/
tty: move hvc drivers to drivers/tty/hvc/
LIO target is a full featured in-kernel target framework with the
following feature set:
High-performance, non-blocking, multithreaded architecture with SIMD
support.
Advanced SCSI feature set:
* Persistent Reservations (PRs)
* Asymmetric Logical Unit Assignment (ALUA)
* Protocol and intra-nexus multiplexing, load-balancing and failover (MC/S)
* Full Error Recovery (ERL=0,1,2)
* Active/active task migration and session continuation (ERL=2)
* Thin LUN provisioning (UNMAP and WRITE_SAMExx)
Multiprotocol target plugins
Storage media independence:
* Virtualization of all storage media; transparent mapping of IO to LUNs
* No hard limits on number of LUNs per Target; maximum LUN size ~750 TB
* Backstores: SATA, SAS, SCSI, BluRay, DVD, FLASH, USB, ramdisk, etc.
Standards compliance:
* Full compliance with IETF (RFC 3720)
* Full implementation of SPC-4 PRs and ALUA
Significant code cleanups done by Christoph Hellwig.
[jejb: fix up for new block bdev exclusive interface. Minor fixes from
Randy Dunlap and Dan Carpenter.]
Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
The serial drivers are really just tty drivers, so move them to
drivers/tty/ to make things a bit neater overall.
This is part of the tty/serial driver movement proceedure as proposed by
Arnd Bergmann and approved by everyone involved a number of months ago.
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Rogier Wolff <R.E.Wolff@bitwizard.nl>
Cc: Michael H. Warfield <mhw@wittsend.com>
Creates a new "Near Field Communication" subsystem in drivers/nfc.
http://en.wikipedia.org/wiki/Near_Field_Communication is useful ;)
This is a driver for the pn544 NFC device. The driver transfers
ETSI messages between the device and the user space.
Signed-off-by: Matti J. Aaltonen <matti.j.aaltonen@nokia.com>
arch/arm/kernel/entry-armv.S
arch/arm/mm/ioremap.c
factorise some generic infrastructure to assist looking up struct clks
for the ARM & SH architecture.
as the code is identical at 99%
put the arch specific code for allocation as example in asm/clkdev.h
Acked-by: Paul Mundt <lethal@linux-sh.org>
The tty code should be in its own subdirectory and not in the char
driver with all of the cruft that is currently there.
Based on work done by Arnd Bergmann <arnd@arndb.de>
Cc: Jiri Slaby <jslaby@suse.cz>
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6
* 'ieee1394-removal' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6:
ieee1394: remove the old IEEE 1394 driver stack
ieee1394: move init_ohci1394_dma to drivers/firewire/
Fix trivial change/delete conflict: drivers/ieee1394/eth1394.c is
getting removed, but was modified by the networking merge.
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (110 commits)
sh: i2c-sh7760: Replase from ctrl_* to __raw_*
sh: clkfwk: Shuffle around to match the intc split up.
sh: clkfwk: modify for_each_frequency end condition
sh: fix clk_get() error handling
sh: clkfwk: Fix fault in frequency iterator.
sh: clkfwk: Add a helper for rate rounding by divisor ranges.
sh: clkfwk: Abstract rate rounding helper.
sh: clkfwk: support clock remapping.
sh: pci: Convert to upper/lower_32_bits() helpers.
sh: mach-sdk7786: Add support for the FPGA SRAM.
sh: Provide a generic SRAM pool for tiny memories.
sh: pci: Support secondary FPGA-driven PCIe clocks on SDK7786.
sh: pci: Support slot 4 routing on SDK7786.
sh: Fix up PMB locking.
sh: mach-sdk7786: Add support for fpga gpios.
sh: use pr_fmt for clock framework, too.
sh: remove name and id from struct clk
sh: free-without-alloc fix for sh_mobile_lcdcfb
sh: perf: Set up perf_max_events.
sh: perf: Support SH-X3 hardware counters.
Fix up trivial conflicts (perf_max_events got removed) in arch/sh/kernel/perf_event.c
The drivers
- ohci1394 (controller driver)
- ieee1394 (core)
- dv1394, raw1394, video1394 (userspace ABI)
- eth1394, sbp2 (protocol drivers)
are replaced by
- firewire-ohci (controller driver)
- firewire-core (core and userspace ABI)
- firewire-net, firewire-sbp2 (protocol drivers)
which are more featureful, better performing, and more secure than the older
drivers; all with a smaller and more modern code base.
The driver firedtv in drivers/media/dvb/firewire/ contains backends to both
ieee1394 and firewire-core. Its ieee1394 backend code can be removed in an
independent commit; firedtv as-is builds and works fine without ieee1394.
The driver pcilynx (an incomplete controller driver) is deleted without
replacement since PCILynx cards are extremely rare. Owners of these cards
use them with the stand-alone bus sniffer driver nosy instead.
The drivers nosy and init_ohci1394_dma which do not interact with either of
the two IEEE 1394 stacks are not affected by the ieee1394 subsystem removal.
There are still some issues with the newer firewire subsystem compared to
the older one:
- The rare and quirky controllers ALi M52xx, Apple UniNorth v1, NVIDIA
NForce2 are even less well supported by firewire-ohci than by ohci1394.
I am looking into the M52xx issue.
- The experimental firewire-net is reportedly less stable than its
experimental cousin eth1394.
- Audio playback of a certain group of audio devices (ones based on DICE
chipset with EAP; supported by prerelease FFADO code) does not work yet.
This issue is still under investigation.
- There were some ieee1394 based out-of-the-mainline drivers. Of them,
only lisight, an audio driver for iSight webcams, seems still useful.
Work is underway to reimplement it on top of firewire-core.
All these remainig issues are minor; they should not stand in the way of
overall better user experience of IEEE 1394 on Linux, together with a
reduction in support efforts and maintenance burden. The coexistence of two
IEEE 1394 kernel driver stacks in the mainline since 2.6.22 shall end now,
as announced earlier this year.
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6:
firewire: nosy: fix build when CONFIG_FIREWIRE=N
firewire: ohci: activate cycle timer register quirk on Ricoh chips
drivers/firewire/nosy* is a stand-alone driver that does not depend on
CONFIG_FIREWIRE. Hence let make descend into drivers/firewire/ also
if that option is off.
The stand-alone driver drivers/ieee1394/init_ohci1394_dma* will soon be
moved into drivers/firewire/ too and will require the same makefile fix.
Side effect:
As mentioned in https://bugzilla.novell.com/show_bug.cgi?id=586172#c24
this influences the order in which either firewire-ohci or ohci1394 is
going to be bound to an OHCI-1394 controller in case of a modular build
of both drivers if no modprobe blacklist entries are configured.
However, a user of such a setup cannot expect deterministic behavior
anyway. The Kconfig help and the migration guide at
ieee1394.wiki.kernel.org recommend blacklist entries when a dual
IEEE 1394 stack build is being used. (The coexistence period of the two
stacks is planned to end soon.)
Cc: Michal Marek <mmarek@suse.cz>
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
arch/sh/include/asm/Kbuild
drivers/Makefile
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Now that all arches have been converted over to use generic time via
clocksources or arch_gettimeoffset(), we can remove the GENERIC_TIME
config option and simplify the generic code.
Signed-off-by: John Stultz <johnstul@us.ibm.com>
LKML-Reference: <1279068988-21864-4-git-send-email-johnstul@us.ibm.com>
To use DMA engine based DMA with MMC in a non-modular build, the DMA
engine has to initialise before MMC.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Acked-by: Dan Williams <dan.j.williams@intel.com>
This EXPERIMENTAL driver supersedes acpi_idle on
Intel Atom Processors, Intel Core i3/i5/i7 Processors
and associated Intel Xeon processors.
It does not support the Intel Core2 processor or earlier.
For kernels configured with ACPI, CONFIG_INTEL_IDLE=y
allows intel_idle to probe before the ACPI processor driver.
Booting with "intel_idle.max_cstate=0" disables intel_idle
and the system will fall back on ACPI's "acpi_idle".
Typical Linux distributions load ACPI processor module early,
making CONFIG_INTEL_IDLE=m not easily useful on ACPI platforms.
intel_idle probes all processors at module_init time.
Processors that are hot-added later will be limited
to using C1 in idle.
Signed-off-by: Len Brown <len.brown@intel.com>
Move initialization of the virtio framework before the initialization of
mtd, so that block2mtd can be used on virtio-based block devices.
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=15644
Signed-off-by: Stijn Tintel <stijn@linux-ipv6.be>
Cc: stable@kernel.org
arch/arm/mach-mx2/devices.c
arch/arm/mach-mx2/devices.h
sound/soc/pxa/pxa-ssp.c
Build drivers/sh in the case of ARM-based SH-Mobile CPUs.
Shared code for the interrupt controller (INTC) and
the gpio/pinmux (PFC) is located there.
Signed-off-by: Magnus Damm <damm@opensource.se>
What it is: vhost net is a character device that can be used to reduce
the number of system calls involved in virtio networking.
Existing virtio net code is used in the guest without modification.
There's similarity with vringfd, with some differences and reduced scope
- uses eventfd for signalling
- structures can be moved around in memory at any time (good for
migration, bug work-arounds in userspace)
- write logging is supported (good for migration)
- support memory table and not just an offset (needed for kvm)
common virtio related code has been put in a separate file vhost.c and
can be made into a separate module if/when more backends appear. I used
Rusty's lguest.c as the source for developing this part : this supplied
me with witty comments I wouldn't be able to write myself.
What it is not: vhost net is not a bus, and not a generic new system
call. No assumptions are made on how guest performs hypercalls.
Userspace hypervisors are supported as well as kvm.
How it works: Basically, we connect virtio frontend (configured by
userspace) to a backend. The backend could be a network device, or a tap
device. Backend is also configured by userspace, including vlan/mac
etc.
Status: This works for me, and I haven't see any crashes.
Compared to userspace, people reported improved latency (as I save up to
4 system calls per packet), as well as better bandwidth and CPU
utilization.
Features that I plan to look at in the future:
- mergeable buffers
- zero copy
- scalability tuning: figure out the best threading model to use
Note on RCU usage (this is also documented in vhost.h, near
private_pointer which is the value protected by this variant of RCU):
what is happening is that the rcu_dereference() is being used in a
workqueue item. The role of rcu_read_lock() is taken on by the start of
execution of the workqueue item, of rcu_read_unlock() by the end of
execution of the workqueue item, and of synchronize_rcu() by
flush_workqueue()/flush_work(). In the future we might need to apply
some gcc attribute or sparse annotation to the function passed to
INIT_WORK(). Paul's ack below is for this RCU usage.
(Includes fixes by Alan Cox <alan@linux.intel.com>,
David L Stevens <dlstevens@us.ibm.com>,
Chris Wright <chrisw@redhat.com>)
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
Acked-by: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
* git://git.infradead.org/mtd-2.6: (58 commits)
mtd: jedec_probe: add PSD4256G6V id
mtd: OneNand support for Nomadik 8815 SoC (on NHK8815 board)
mtd: nand: driver for Nomadik 8815 SoC (on NHK8815 board)
m25p80: Add Spansion S25FL129P serial flashes
jffs2: Use SLAB_HWCACHE_ALIGN for jffs2_raw_{dirent,inode} slabs
mtd: sh_flctl: register sh_flctl using platform_driver_probe()
mtd: nand: txx9ndfmc: transfer 512 byte at a time if possible
mtd: nand: fix tmio_nand ecc correction
mtd: nand: add __nand_correct_data helper function
mtd: cfi_cmdset_0002: add 0xFF intolerance for M29W128G
mtd: inftl: fix fold chain block number
mtd: jedec: fix compilation problem with I28F640C3B definition
mtd: nand: fix ECC Correction bug for SMC ordering for NDFC driver
mtd: ofpart: Check availability of reg property instead of name property
driver/Makefile: Initialize "mtd" and "spi" before "net"
mtd: omap: adding DMA mode support in nand prefetch/post-write
mtd: omap: add support for nand prefetch-read and post-write
mtd: add nand support for w90p910 (v2)
mtd: maps: add mtd-ram support to physmap_of
mtd: pxa3xx_nand: add single-bit error corrections reporting
On TI's da850/omap-l138 EVM, MAC address is stored in SPI flash.
This patch changes the initialization sequence of the drivers
by moving mtd and spi ahead of net in drivers/Makefile thereby
enabling da850/omap-l138 ethernet driver to read the MAC address
while booting.
Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
drivers/sfi/sfi_core.c contains the generic SFI implementation.
It has a private header, sfi_core.h, for its own use and the
private use of future files in drivers/sfi/
Signed-off-by: Feng Tang <feng.tang@intel.com>
This patch adds the kernel side of the PPS support currently named
"LinuxPPS".
PPS means "pulse per second" and a PPS source is just a device which
provides a high precision signal each second so that an application can
use it to adjust system clock time.
Common use is the combination of the NTPD as userland program with a GPS
receiver as PPS source to obtain a wallclock-time with sub-millisecond
synchronisation to UTC.
To obtain this goal the userland programs shoud use the PPS API
specification (RFC 2783 - Pulse-Per-Second API for UNIX-like Operating
Systems, Version 1.0) which in part is implemented by this patch. It
provides a set of chars devices, one per PPS source, which can be used to
get the time signal. The RFC's functions can be implemented by accessing
to these char devices.
Signed-off-by: Rodolfo Giometti <giometti@linux.it>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
Cc: Kay Sievers <kay.sievers@vrfy.org>
Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Michael Kerrisk <mtk.manpages@googlemail.com>
Cc: Roman Zippel <zippel@linux-m68k.org>
Add support for the TI VLYNQ high-speed, serial and packetized bus.
This bus allows external devices to be connected to the System-on-Chip and
appear in the main system memory just like any memory mapped peripheral.
It is widely used in TI's networking and multimedia SoC, including the AR7
SoC.
Signed-off-by: Eugene Konev <ejka@imfi.kspu.ru>
Signed-off-by: Florian Fainelli <florian@openwrt.org>
fakehard is a really simple driver implementing only necessary
callbacks and serves the role of an example of driver for HardMAC
IEEE 802.15.4 device.
Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
Signed-off-by: Sergey Lapin <slapin@ossfans.org>
Currently drivers/media drivers are linked very early - directly after
base, block, misc, and mfd and before ata, scsi, ide, input, firewire,
usb, and i2c. This breaks static build of video4linux drivers, that use
generic CPU i2c adapter drivers and the v4l2-subdev subsystem, because
during video4linux probing the v4l2-subdev core requires a struct
i2c_adapter context, which cannot be satisfied before the i2c subsystem is
initialised. Moving drivers/media after drivers/i2c fixes this problem.
The best way to trigger action is by submitting a patch:-) So, let's see
what comes out of it - on the one hand I don't see any reason why media
has to be linked this early, and nobody was able to give me one yesterday
as this problem has been discussed on linux-media, OTOH, maybe indeed it
would be better to move i2c the whole way up above media, but that'd be
much bigger of a change, I think.
To unsubscribe from this list: send the line "unsubscribe linux-media" in
the body of a message to majordomo@vger.kernel.org
More majordomo info at http://vger.kernel.org/majordomo-info.html
Acked-by: Jean Delvare <khali@linux-fr.org>
this patch flips the order in which sata and network drivers are initialized.
SATA probing takes quite a bit of time, and with the asynchronous infrastructure
other drivers that run after it can execute in parallel. Network drivers do tend
to take some real time talking to the hardware, so running these later is
a good thing (the sata probe then runs concurrent)
This saves about 15% of my kernels boot time.
Both Dave and Jeff acked this patch and suggested it should go via the async
tree.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Acked-by: Jeff Garzik <jeff@garzik.org>
drivers/misc/Kconfig
Move regulator earlier in link sequence.
The regulator core currently initializes as a core_initcall() to be
available early ... but then it links way late, throwing away that
benefit, so regulators available at e.g. subsys_initcall() are not
available to subsystems which need to use them.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
This moves the isp1301-omap driver from the drivers/i2c/chips
directory (which will be shrinking) into a new drivers/usb/otg
directory (which will grow, with more drivers and utilities).
Note that OTG infrastructure needs to be initialized before
either host or peripheral side USB support, and may be needed
before for pure host or pure peripheral configurations.
Move x86 platform specific drivers from drivers/misc/
to a new home under drivers/platform/x86/.
The community has been maintaining x86 vendor-specific
platform specific drivers under /drivers/misc/ for a few years.
The oldest ones started life under drivers/acpi.
They moved out of drivers/acpi/ because they don't actually
implement the ACPI specification, but either simply
use ACPI, or implement vendor-specific ACPI extensions.
In the future we anticipate...
drivers/misc/ will go away.
other architectures will create drivers/platform/<arch>
