path: root/drivers/Makefile
2011-05-28Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: (33 commits) x86: poll waiting for I/OAT DMA channel status maintainers: add dma engine tree details dmaengine: add TODO items for future work on dma drivers dmaengine: Add API documentation for slave dma usage dmaengine/dw_dmac: Update maintainer-ship dmaengine: move link order dmaengine/dw_dmac: implement pause and resume in dwc_control dmaengine/dw_dmac: Replace spin_lock* with irqsave variants and enable submission from callback dmaengine/dw_dmac: Divide one sg to many desc, if sg len is greater than DWC_MAX_COUNT dmaengine/dw_dmac: set residue as total len in dwc_tx_status if status is !DMA_SUCCESS dmaengine/dw_dmac: don't call callback routine in case dmaengine_terminate_all() is called dmaengine: at_hdmac: pause: no need to wait for FIFO empty pch_dma: modify pci device table definition pch_dma: Support new device ML7223 IOH pch_dma: Support I2S for ML7213 IOH pch_dma: Fix DMA setting issue pch_dma: modify for checkpatch pch_dma: fix dma direction issue for ML7213 IOH video-in dmaengine: at_hdmac: use descriptor chaining help function dmaengine: at_hdmac: implement pause and resume in atc_control ... Fix up trivial conflict in drivers/dma/dw_dmac.c
2011-05-25Merge branch 'timers-ptp-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-ptp-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: ptp: Fix dp83640 build warning when building statically ptp: Added a clock driver for the National Semiconductor PHYTER. ptp: Added a clock driver for the IXP46x. ptp: Added a clock that uses the eTSEC found on the MPC85xx. ptp: Added a brand new class driver for ptp clocks.
2011-05-25leds: provide helper to register "leds-gpio" devicesUwe Kleine-König
This function makes a deep copy of the platform data to allow it to live in init memory. For a kernel that supports several machines and so includes the definition for several leds-gpio devices this saves quite some memory because all but one definition can be free'd after boot. As the function is used by arch code it must be builtin and so cannot go into leds-gpio.c. [akpm@linux-foundation.org: s/CONFIG_LED_REGISTER_GPIO/CONFIG_LEDS_REGISTER_GPIO/] Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Russell King <rmk@arm.linux.org.uk> Acked-by: Richard Purdie <richard.purdie@linuxfoundation.org> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Sascha Hauer <s.hauer@pengutronix.de> Tested-by: H Hartley Sweeten <hartleys@visionengravers.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-23ptp: Added a brand new class driver for ptp clocks.Richard Cochran
This patch adds an infrastructure for hardware clocks that implement IEEE 1588, the Precision Time Protocol (PTP). A class driver offers a registration method to particular hardware clock drivers. Each clock is presented as a standard POSIX clock. The ancillary clock features are exposed in two different ways, via the sysfs and by a character device. Signed-off-by: Richard Cochran <richard.cochran@omicron.at> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-05-23Merge branch 'usb-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6 * 'usb-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (205 commits) USB: EHCI: Remove SPARC_LEON {read,write}_be definitions from ehci.h USB: UHCI: Support big endian GRUSBHC HC sparc: add {read,write}*_be routines USB: UHCI: Add support for big endian descriptors USB: UHCI: Use ACCESS_ONCE rather than using a full compiler barrier USB: UHCI: Add support for big endian mmio usb-storage: Correct adjust_quirks to include latest flags usb/isp1760: Fix possible unlink problems usb/isp1760: Move function isp1760_endpoint_disable() within file. USB: remove remaining usages of hcd->state from usbcore and fix regression usb: musb: ux500: add configuration and build options for ux500 dma usb: musb: ux500: add dma glue layer for ux500 usb: musb: ux500: add dma name for ux500 usb: musb: ux500: add ux500 specific code for gadget side usb: musb: fix compile error usb-storage: fix up the unusual_realtek device list USB: gadget: f_audio: Fix invalid dereference of initdata EHCI: don't rescan interrupt QHs needlessly OHCI: fix regression caused by nVidia shutdown workaround USB: OTG: msm: Free VCCCX regulator even if we can't set the voltage ...
2011-05-19dmaengine: move link orderLinus Walleij
Move the dmaengine subsystem up early in the drivers Makefile so DMA is made available early to all drivers, just like e.g. regulators. Now even regulators can use DMA on the same initlevel. As a result we can bump the ste_dma40 and coh901318 dmaengine drivers down one initlevel to subsys_init(). Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2011-05-10bcma: add Broadcom specific AMBA bus driverRafał Miłecki
Broadcom has released cards based on a new AMBA-based bus type. From a programming point of view, this new bus type differs from AMBA and does not use AMBA common registers. It also differs enough from SSB. We decided that a new bus driver is needed to keep the code clean. In its current form, the driver detects devices present on the bus and registers them in the system. It allows registering BCMA drivers for specified bus devices and provides them basic operations. The bus driver itself includes two important bus managing drivers: ChipCommon core driver and PCI(c) core driver. They are early used to allow correct initialization. Currently code is limited to supporting buses on PCI(e) devices, however the driver is designed to be used also on other hosts. The host abstraction layer is implemented and already used for PCI(e). Support for PCI(e) hosts is working and seems to be stable (access to 80211 core was tested successfully on a few devices). We can still optimize it by using some fixed windows, but this can be done later without affecting any external code. Windows are just ranges in MMIO used for accessing cores on the bus. Cc: Greg KH <greg@kroah.com> Cc: Michael Büsch <mb@bu3sch.de> Cc: Larry Finger <Larry.Finger@lwfinger.net> Cc: George Kashperko <george@znau.edu.ua> Cc: Arend van Spriel <arend@broadcom.com> Cc: linux-arm-kernel@lists.infradead.org Cc: Russell King <rmk@arm.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Andy Botting <andy@andybotting.com> Cc: linuxdriverproject <devel@linuxdriverproject.org> Cc: linux-kernel@vger.kernel.org <linux-kernel@vger.kernel.org> Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-04-13usb: don't enter usb subdirectories directlyFelipe Balbi
Instead, make we enter usb/ directory on all needed cases and enter the subdirectories from drivers/usb/Makefile. Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-13usb: renesas_usbhs: Add Renesas USBHS common codeKuninori Morimoto
Renesas SuperH has USBHS IP which can switch Host / Function. This driver is designed so that Host / Function may dynamically change. This patch add usb/renesas_usbhs and common code for SuperH USBHS. Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17drivers: hwspinlock: add frameworkOhad Ben-Cohen
Add a platform-independent hwspinlock framework. Hardware spinlock devices are needed, e.g., in order to access data that is shared between remote processors, that otherwise have no alternative mechanism to accomplish synchronization and mutual exclusion operations. Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Cc: Hari Kanigeri <h-kanigeri2@ti.com> Cc: Benoit Cousson <b-cousson@ti.com> Cc: Kevin Hilman <khilman@ti.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Paul Walmsley <paul@pwsan.com> Cc: Russell King <linux@arm.linux.org.uk> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-01-20Merge branch 'tty-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: tty: update MAINTAINERS file due to driver movement tty: move drivers/serial/ to drivers/tty/serial/ tty: move hvc drivers to drivers/tty/hvc/
2011-01-14[SCSI] target: Add LIO target core v4.0.0-rc6Nicholas Bellinger
LIO target is a full featured in-kernel target framework with the following feature set: High-performance, non-blocking, multithreaded architecture with SIMD support. Advanced SCSI feature set: * Persistent Reservations (PRs) * Asymmetric Logical Unit Assignment (ALUA) * Protocol and intra-nexus multiplexing, load-balancing and failover (MC/S) * Full Error Recovery (ERL=0,1,2) * Active/active task migration and session continuation (ERL=2) * Thin LUN provisioning (UNMAP and WRITE_SAMExx) Multiprotocol target plugins Storage media independence: * Virtualization of all storage media; transparent mapping of IO to LUNs * No hard limits on number of LUNs per Target; maximum LUN size ~750 TB * Backstores: SATA, SAS, SCSI, BluRay, DVD, FLASH, USB, ramdisk, etc. Standards compliance: * Full compliance with IETF (RFC 3720) * Full implementation of SPC-4 PRs and ALUA Significant code cleanups done by Christoph Hellwig. [jejb: fix up for new block bdev exclusive interface. Minor fixes from Randy Dunlap and Dan Carpenter.] Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-01-13tty: move drivers/serial/ to drivers/tty/serial/Greg Kroah-Hartman
The serial drivers are really just tty drivers, so move them to drivers/tty/ to make things a bit neater overall. This is part of the tty/serial driver movement proceedure as proposed by Arnd Bergmann and approved by everyone involved a number of months ago. Cc: Arnd Bergmann <arnd@arndb.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Rogier Wolff <R.E.Wolff@bitwizard.nl> Cc: Michael H. Warfield <mhw@wittsend.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-13NFC: Driver for NXP Semiconductors PN544 NFC chip.Matti J. Aaltonen
Creates a new "Near Field Communication" subsystem in drivers/nfc. http://en.wikipedia.org/wiki/Near_Field_Communication is useful ;) This is a driver for the pn544 NFC device. The driver transfers ETSI messages between the device and the user space. Signed-off-by: Matti J. Aaltonen <matti.j.aaltonen@nokia.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-06Merge branch 'smp' into miscRussell King
Conflicts: arch/arm/kernel/entry-armv.S arch/arm/mm/ioremap.c
2010-11-26ARM: 6483/1: arm & sh: factorised duplicated clkdev.cJean-Christop PLAGNIOL-VILLARD
factorise some generic infrastructure to assist looking up struct clks for the ARM & SH architecture. as the code is identical at 99% put the arch specific code for allocation as example in asm/clkdev.h Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-11-05TTY: create drivers/tty and move the tty core files thereGreg Kroah-Hartman
The tty code should be in its own subdirectory and not in the char driver with all of the cruft that is currently there. Based on work done by Arnd Bergmann <arnd@arndb.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-25Merge branch 'ieee1394-removal' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6 * 'ieee1394-removal' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6: ieee1394: remove the old IEEE 1394 driver stack ieee1394: move init_ohci1394_dma to drivers/firewire/ Fix trivial change/delete conflict: drivers/ieee1394/eth1394.c is getting removed, but was modified by the networking merge.
2010-10-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (110 commits) sh: i2c-sh7760: Replase from ctrl_* to __raw_* sh: clkfwk: Shuffle around to match the intc split up. sh: clkfwk: modify for_each_frequency end condition sh: fix clk_get() error handling sh: clkfwk: Fix fault in frequency iterator. sh: clkfwk: Add a helper for rate rounding by divisor ranges. sh: clkfwk: Abstract rate rounding helper. sh: clkfwk: support clock remapping. sh: pci: Convert to upper/lower_32_bits() helpers. sh: mach-sdk7786: Add support for the FPGA SRAM. sh: Provide a generic SRAM pool for tiny memories. sh: pci: Support secondary FPGA-driven PCIe clocks on SDK7786. sh: pci: Support slot 4 routing on SDK7786. sh: Fix up PMB locking. sh: mach-sdk7786: Add support for fpga gpios. sh: use pr_fmt for clock framework, too. sh: remove name and id from struct clk sh: free-without-alloc fix for sh_mobile_lcdcfb sh: perf: Set up perf_max_events. sh: perf: Support SH-X3 hardware counters. ... Fix up trivial conflicts (perf_max_events got removed) in arch/sh/kernel/perf_event.c
2010-10-11ieee1394: remove the old IEEE 1394 driver stackStefan Richter
The drivers - ohci1394 (controller driver) - ieee1394 (core) - dv1394, raw1394, video1394 (userspace ABI) - eth1394, sbp2 (protocol drivers) are replaced by - firewire-ohci (controller driver) - firewire-core (core and userspace ABI) - firewire-net, firewire-sbp2 (protocol drivers) which are more featureful, better performing, and more secure than the older drivers; all with a smaller and more modern code base. The driver firedtv in drivers/media/dvb/firewire/ contains backends to both ieee1394 and firewire-core. Its ieee1394 backend code can be removed in an independent commit; firedtv as-is builds and works fine without ieee1394. The driver pcilynx (an incomplete controller driver) is deleted without replacement since PCILynx cards are extremely rare. Owners of these cards use them with the stand-alone bus sniffer driver nosy instead. The drivers nosy and init_ohci1394_dma which do not interact with either of the two IEEE 1394 stacks are not affected by the ieee1394 subsystem removal. There are still some issues with the newer firewire subsystem compared to the older one: - The rare and quirky controllers ALi M52xx, Apple UniNorth v1, NVIDIA NForce2 are even less well supported by firewire-ohci than by ohci1394. I am looking into the M52xx issue. - The experimental firewire-net is reportedly less stable than its experimental cousin eth1394. - Audio playback of a certain group of audio devices (ones based on DICE chipset with EAP; supported by prerelease FFADO code) does not work yet. This issue is still under investigation. - There were some ieee1394 based out-of-the-mainline drivers. Of them, only lisight, an audio driver for iSight webcams, seems still useful. Work is underway to reimplement it on top of firewire-core. All these remainig issues are minor; they should not stand in the way of overall better user experience of IEEE 1394 on Linux, together with a reduction in support efforts and maintenance burden. The coexistence of two IEEE 1394 kernel driver stacks in the mainline since 2.6.22 shall end now, as announced earlier this year. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2010-09-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6: firewire: nosy: fix build when CONFIG_FIREWIRE=N firewire: ohci: activate cycle timer register quirk on Ricoh chips
2010-09-17firewire: nosy: fix build when CONFIG_FIREWIRE=NStefan Richter
drivers/firewire/nosy* is a stand-alone driver that does not depend on CONFIG_FIREWIRE. Hence let make descend into drivers/firewire/ also if that option is off. The stand-alone driver drivers/ieee1394/init_ohci1394_dma* will soon be moved into drivers/firewire/ too and will require the same makefile fix. Side effect: As mentioned in https://bugzilla.novell.com/show_bug.cgi?id=586172#c24 this influences the order in which either firewire-ohci or ohci1394 is going to be bound to an OHCI-1394 controller in case of a modular build of both drivers if no modprobe blacklist entries are configured. However, a user of such a setup cannot expect deterministic behavior anyway. The Kconfig help and the migration guide at ieee1394.wiki.kernel.org recommend blacklist entries when a dual IEEE 1394 stack build is being used. (The coexistence period of the two stacks is planned to end soon.) Cc: Michal Marek <mmarek@suse.cz> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2010-08-16Merge branch 'master' of ↵Paul Mundt
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: arch/sh/include/asm/Kbuild drivers/Makefile Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-07-27time: Kill off CONFIG_GENERIC_TIMEJohn Stultz
Now that all arches have been converted over to use generic time via clocksources or arch_gettimeoffset(), we can remove the GENERIC_TIME config option and simplify the generic code. Signed-off-by: John Stultz <johnstul@us.ibm.com> LKML-Reference: <1279068988-21864-4-git-send-email-johnstul@us.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-07-02dmaengine: initialise DMA engine before MMCGuennadi Liakhovetski
To use DMA engine based DMA with MMC in a non-modular build, the DMA engine has to initialise before MMC. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-05-28intel_idle: native hardware cpuidle driver for latest Intel processorsLen Brown
This EXPERIMENTAL driver supersedes acpi_idle on Intel Atom Processors, Intel Core i3/i5/i7 Processors and associated Intel Xeon processors. It does not support the Intel Core2 processor or earlier. For kernels configured with ACPI, CONFIG_INTEL_IDLE=y allows intel_idle to probe before the ACPI processor driver. Booting with "intel_idle.max_cstate=0" disables intel_idle and the system will fall back on ACPI's "acpi_idle". Typical Linux distributions load ACPI processor module early, making CONFIG_INTEL_IDLE=m not easily useful on ACPI platforms. intel_idle probes all processors at module_init time. Processors that are hot-added later will be limited to using C1 in idle. Signed-off-by: Len Brown <len.brown@intel.com>
2010-05-07virtio: initialize earlierStijn Tintel
Move initialization of the virtio framework before the initialization of mtd, so that block2mtd can be used on virtio-based block devices. Addresses https://bugzilla.kernel.org/show_bug.cgi?id=15644 Signed-off-by: Stijn Tintel <stijn@linux-ipv6.be> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-08Merge branch 'origin' into devel-stableRussell King
Conflicts: arch/arm/mach-mx2/devices.c arch/arm/mach-mx2/devices.h sound/soc/pxa/pxa-ssp.c
2010-02-08sh: Build drivers/sh for ARM-based SH-Mobile CPUs.Magnus Damm
Build drivers/sh in the case of ARM-based SH-Mobile CPUs. Shared code for the interrupt controller (INTC) and the gpio/pinmux (PFC) is located there. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-01-15vhost_net: a kernel-level virtio serverMichael S. Tsirkin
What it is: vhost net is a character device that can be used to reduce the number of system calls involved in virtio networking. Existing virtio net code is used in the guest without modification. There's similarity with vringfd, with some differences and reduced scope - uses eventfd for signalling - structures can be moved around in memory at any time (good for migration, bug work-arounds in userspace) - write logging is supported (good for migration) - support memory table and not just an offset (needed for kvm) common virtio related code has been put in a separate file vhost.c and can be made into a separate module if/when more backends appear. I used Rusty's lguest.c as the source for developing this part : this supplied me with witty comments I wouldn't be able to write myself. What it is not: vhost net is not a bus, and not a generic new system call. No assumptions are made on how guest performs hypercalls. Userspace hypervisors are supported as well as kvm. How it works: Basically, we connect virtio frontend (configured by userspace) to a backend. The backend could be a network device, or a tap device. Backend is also configured by userspace, including vlan/mac etc. Status: This works for me, and I haven't see any crashes. Compared to userspace, people reported improved latency (as I save up to 4 system calls per packet), as well as better bandwidth and CPU utilization. Features that I plan to look at in the future: - mergeable buffers - zero copy - scalability tuning: figure out the best threading model to use Note on RCU usage (this is also documented in vhost.h, near private_pointer which is the value protected by this variant of RCU): what is happening is that the rcu_dereference() is being used in a workqueue item. The role of rcu_read_lock() is taken on by the start of execution of the workqueue item, of rcu_read_unlock() by the end of execution of the workqueue item, and of synchronize_rcu() by flush_workqueue()/flush_work(). In the future we might need to apply some gcc attribute or sparse annotation to the function passed to INIT_WORK(). Paul's ack below is for this RCU usage. (Includes fixes by Alan Cox <alan@linux.intel.com>, David L Stevens <dlstevens@us.ibm.com>, Chris Wright <chrisw@redhat.com>) Acked-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-23Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (58 commits) mtd: jedec_probe: add PSD4256G6V id mtd: OneNand support for Nomadik 8815 SoC (on NHK8815 board) mtd: nand: driver for Nomadik 8815 SoC (on NHK8815 board) m25p80: Add Spansion S25FL129P serial flashes jffs2: Use SLAB_HWCACHE_ALIGN for jffs2_raw_{dirent,inode} slabs mtd: sh_flctl: register sh_flctl using platform_driver_probe() mtd: nand: txx9ndfmc: transfer 512 byte at a time if possible mtd: nand: fix tmio_nand ecc correction mtd: nand: add __nand_correct_data helper function mtd: cfi_cmdset_0002: add 0xFF intolerance for M29W128G mtd: inftl: fix fold chain block number mtd: jedec: fix compilation problem with I28F640C3B definition mtd: nand: fix ECC Correction bug for SMC ordering for NDFC driver mtd: ofpart: Check availability of reg property instead of name property driver/Makefile: Initialize "mtd" and "spi" before "net" mtd: omap: adding DMA mode support in nand prefetch/post-write mtd: omap: add support for nand prefetch-read and post-write mtd: add nand support for w90p910 (v2) mtd: maps: add mtd-ram support to physmap_of mtd: pxa3xx_nand: add single-bit error corrections reporting ...
2009-09-19driver/Makefile: Initialize "mtd" and "spi" before "net"Sudhakar Rajashekhara
On TI's da850/omap-l138 EVM, MAC address is stored in SPI flash. This patch changes the initialization sequence of the drivers by moving mtd and spi ahead of net in drivers/Makefile thereby enabling da850/omap-l138 ethernet driver to read the MAC address while booting. Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-08-28SFI: add platform-independent core supportFeng Tang
drivers/sfi/sfi_core.c contains the generic SFI implementation. It has a private header, sfi_core.h, for its own use and the private use of future files in drivers/sfi/ Signed-off-by: Feng Tang <feng.tang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-06-18LinuxPPS: core supportRodolfo Giometti
This patch adds the kernel side of the PPS support currently named "LinuxPPS". PPS means "pulse per second" and a PPS source is just a device which provides a high precision signal each second so that an application can use it to adjust system clock time. Common use is the combination of the NTPD as userland program with a GPS receiver as PPS source to obtain a wallclock-time with sub-millisecond synchronisation to UTC. To obtain this goal the userland programs shoud use the PPS API specification (RFC 2783 - Pulse-Per-Second API for UNIX-like Operating Systems, Version 1.0) which in part is implemented by this patch. It provides a set of chars devices, one per PPS source, which can be used to get the time signal. The RFC's functions can be implemented by accessing to these char devices. Signed-off-by: Rodolfo Giometti <giometti@linux.it> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Greg KH <greg@kroah.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16drivers: add support for the TI VLYNQ busFlorian Fainelli
Add support for the TI VLYNQ high-speed, serial and packetized bus. This bus allows external devices to be connected to the System-on-Chip and appear in the main system memory just like any memory mapped peripheral. It is widely used in TI's networking and multimedia SoC, including the AR7 SoC. Signed-off-by: Eugene Konev <ejka@imfi.kspu.ru> Signed-off-by: Florian Fainelli <florian@openwrt.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-09ieee802154: add simple HardMAC driver sampleSergey Lapin
fakehard is a really simple driver implementing only necessary callbacks and serves the role of an example of driver for HardMAC IEEE 802.15.4 device. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Sergey Lapin <slapin@ossfans.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-29V4L/DVB (11561a): move media after i2cGuennadi Liakhovetski
Currently drivers/media drivers are linked very early - directly after base, block, misc, and mfd and before ata, scsi, ide, input, firewire, usb, and i2c. This breaks static build of video4linux drivers, that use generic CPU i2c adapter drivers and the v4l2-subdev subsystem, because during video4linux probing the v4l2-subdev core requires a struct i2c_adapter context, which cannot be satisfied before the i2c subsystem is initialised. Moving drivers/media after drivers/i2c fixes this problem. The best way to trigger action is by submitting a patch:-) So, let's see what comes out of it - on the one hand I don't see any reason why media has to be linked this early, and nobody was able to give me one yesterday as this problem has been discussed on linux-media, OTOH, maybe indeed it would be better to move i2c the whole way up above media, but that'd be much bigger of a change, I think. -- To unsubscribe from this list: send the line "unsubscribe linux-media" in the body of a message to majordomo@vger.kernel.org More majordomo info at http://vger.kernel.org/majordomo-info.html Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-28ide/net: flip the order of SATA and network initArjan van de Ven
this patch flips the order in which sata and network drivers are initialized. SATA probing takes quite a bit of time, and with the asynchronous infrastructure other drivers that run after it can execute in parallel. Network drivers do tend to take some real time talking to the hardware, so running these later is a good thing (the sata probe then runs concurrent) This saves about 15% of my kernels boot time. Both Dave and Jeff acked this patch and suggested it should go via the async tree. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Jeff Garzik <jeff@garzik.org>
2009-01-09Merge branch 'drivers-platform' into releaseLen Brown
Conflicts: drivers/misc/Kconfig Signed-off-by: Len Brown <len.brown@intel.com>
2009-01-08regulator: init/link earlierDavid Brownell
Move regulator earlier in link sequence. The regulator core currently initializes as a core_initcall() to be available early ... but then it links way late, throwing away that benefit, so regulators available at e.g. subsys_initcall() are not available to subsystems which need to use them. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-01-07USB: move isp1301_omap to drivers/usb/otgDavid Brownell
This moves the isp1301-omap driver from the drivers/i2c/chips directory (which will be shrinking) into a new drivers/usb/otg directory (which will grow, with more drivers and utilities). Note that OTG infrastructure needs to be initialized before either host or peripheral side USB support, and may be needed before for pure host or pure peripheral configurations. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-12-19create drivers/platform/x86/ from drivers/misc/Len Brown
Move x86 platform specific drivers from drivers/misc/ to a new home under drivers/platform/x86/. The community has been maintaining x86 vendor-specific platform specific drivers under /drivers/misc/ for a few years. The oldest ones started life under drivers/acpi. They moved out of drivers/acpi/ because they don't actually implement the ACPI specification, but either simply use ACPI, or implement vendor-specific ACPI extensions. In the future we anticipate... drivers/misc/ will go away. other architectures will create drivers/platform/<arch> Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-26Merge branch 'for-upstream' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dvrabel/uwb * 'for-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/dvrabel/uwb: uwb: build UWB before USB/WUSB
2008-10-24uwb: build UWB before USB/WUSBDavid Vrabel
The WHCI-HCD driver in drivers/usb/host/ depends on the umc driver in drivers/uwb/. Signed-off-by: David Vrabel <david.vrabel@csr.com>
2008-10-23Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (123 commits) dock: make dock driver not a module ACPI: fix ia64 build warning ACPI: hack around sysfs warning with link order ACPI suspend: fix build warning when CONFIG_ACPI_SLEEP=n intel_menlo: fix build warning panasonic-laptop: fix build ACPICA: Update version to 20080926 ACPICA: Add support for zero-length buffer-to-string conversions ACPICA: New: Validation for predefined ACPI methods/objects ACPICA: Fix for implicit return compatibility ACPICA: Fixed a couple memory leaks associated with "implicit return" ACPICA: Optimize buffer allocation procedure ACPICA: Fix possible memory leak, error exit path ACPICA: Fix fault after mem allocation failure in AML parser ACPICA: Remove unused ACPI register bit definition ACPICA: Update version to 20080829 ACPICA: Fix possible memory leak in acpi_ns_get_external_pathname ACPICA: Cleanup for internal Reference Object ACPICA: Update comments - no functional changes ACPICA: Update for Reference ACPI_OPERAND_OBJECT ...
2008-10-23Merge branch 'linus' into testLen Brown
Conflicts: MAINTAINERS arch/x86/kernel/acpi/boot.c arch/x86/kernel/acpi/sleep.c drivers/acpi/Kconfig drivers/pnp/Makefile drivers/pnp/quirks.c Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-21i7300_idle driver v1.55Andy Henroid
The Intel 7300 Memory Controller supports dynamic throttling of memory which can be used to save power when system is idle. This driver does the memory throttling when all CPUs are idle on such a system. Refer to "Intel 7300 Memory Controller Hub (MCH)" datasheet for the config space description. Signed-off-by: Andy Henroid <andrew.d.henroid@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
2008-10-20Merge branch 'master' into for-upstreamDavid Vrabel
Conflicts: Documentation/ABI/testing/sysfs-bus-usb drivers/Makefile
2008-10-10Staging: add Kconfig entries and Makefile infrastructureGreg Kroah-Hartman
This hooks up the drivers/staging directory to the build system Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-09-17uwb: add the UWB stack (build system)Greg Kroah-Hartman
The Kbuild and Kconfig files. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: David Vrabel <david.vrabel@csr.com>
