path: root/drivers/Makefile
2018-08-18Merge tag 'char-misc-4.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver updates from Greg KH: "Here is the bit set of char/misc drivers for 4.19-rc1 There is a lot here, much more than normal, seems like everyone is writing new driver subsystems these days... Anyway, major things here are: - new FSI driver subsystem, yet-another-powerpc low-level hardware bus - gnss, finally an in-kernel GPS subsystem to try to tame all of the crazy out-of-tree drivers that have been floating around for years, combined with some really hacky userspace implementations. This is only for GNSS receivers, but you have to start somewhere, and this is great to see. Other than that, there are new slimbus drivers, new coresight drivers, new fpga drivers, and loads of DT bindings for all of these and existing drivers. All of these have been in linux-next for a while with no reported issues" * tag 'char-misc-4.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (255 commits) android: binder: Rate-limit debug and userspace triggered err msgs fsi: sbefifo: Bump max command length fsi: scom: Fix NULL dereference misc: mic: SCIF Fix scif_get_new_port() error handling misc: cxl: changed asterisk position genwqe: card_base: Use true and false for boolean values misc: eeprom: assignment outside the if statement uio: potential double frees if __uio_register_device() fails eeprom: idt_89hpesx: clean up an error pointer vs NULL inconsistency misc: ti-st: Fix memory leak in the error path of probe() android: binder: Show extra_buffers_size in trace firmware: vpd: Fix section enabled flag on vpd_section_destroy platform: goldfish: Retire pdev_bus goldfish: Use dedicated macros instead of manual bit shifting goldfish: Add missing includes to goldfish.h mux: adgs1408: new driver for Analog Devices ADGS1408/1409 mux dt-bindings: mux: add adi,adgs1408 Drivers: hv: vmbus: Cleanup synic memory free path Drivers: hv: vmbus: Remove use of slow_virt_to_phys() Drivers: hv: vmbus: Reset the channel callback in vmbus_onoffer_rescind() ...
2018-08-02scsi: build scsi_common.o for all scsi passthrough request usersChristoph Hellwig
Split scsi_common.o out of SCSI so that non-SCSI users can pull it in easily for future sense buffer helper usage. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-06-28gnss: add GNSS receiver subsystemJohan Hovold
Add a new subsystem for GNSS (e.g. GPS) receivers. While GNSS receivers are typically accessed using a UART interface they often also support other I/O interfaces such as I2C, SPI and USB, while yet other devices use iomem or even some form of remote-processor messaging (rpmsg). The new GNSS subsystem abstracts the underlying interface and provides a new "gnss" class type, which exposes a character-device interface (e.g. /dev/gnss0) to user space. This allows GNSS receivers to have a representation in the Linux device model, something which is important not least for power management purposes. Note that the character-device interface provides raw access to whatever protocol the receiver is (currently) using, such as NMEA 0183, UBX or SiRF Binary. These protocols are expected to be continued to be handled by user space for the time being, even if some hybrid solutions are also conceivable (e.g. to have kernel drivers issue management commands). This will still allow for better platform integration by allowing GNSS devices and their resources (e.g. regulators and enable-gpios) to be described by firmware and managed by kernel drivers rather than platform-specific scripts and services. While the current interface is kept minimal, it could be extended using IOCTLs, sysfs or uevents as needs and proper abstraction levels are identified and determined (e.g. for device and feature identification). Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-06Merge tag 'pci-v4.16-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI updates from Bjorn Helgaas: - skip AER driver error recovery callbacks for correctable errors reported via ACPI APEI, as we already do for errors reported via the native path (Tyler Baicar) - fix DPC shared interrupt handling (Alex Williamson) - print full DPC interrupt number (Keith Busch) - enable DPC only if AER is available (Keith Busch) - simplify DPC code (Bjorn Helgaas) - calculate ASPM L1 substate parameter instead of hardcoding it (Bjorn Helgaas) - enable Latency Tolerance Reporting for ASPM L1 substates (Bjorn Helgaas) - move ASPM internal interfaces out of public header (Bjorn Helgaas) - allow hot-removal of VGA devices (Mika Westerberg) - speed up unplug and shutdown by assuming Thunderbolt controllers don't support Command Completed events (Lukas Wunner) - add AtomicOps support for GPU and Infiniband drivers (Felix Kuehling, Jay Cornwall) - expose "ari_enabled" in sysfs to help NIC naming (Stuart Hayes) - clean up PCI DMA interface usage (Christoph Hellwig) - remove PCI pool API (replaced with DMA pool) (Romain Perier) - deprecate pci_get_bus_and_slot(), which assumed PCI domain 0 (Sinan Kaya) - move DT PCI code from drivers/of/ to drivers/pci/ (Rob Herring) - add PCI-specific wrappers for dev_info(), etc (Frederick Lawler) - remove warnings on sysfs mmap failure (Bjorn Helgaas) - quiet ROM validation messages (Alex Deucher) - remove redundant memory alloc failure messages (Markus Elfring) - fill in types for compile-time VGA and other I/O port resources (Bjorn Helgaas) - make "pci=pcie_scan_all" work for Root Ports as well as Downstream Ports to help AmigaOne X1000 (Bjorn Helgaas) - add SPDX tags to all PCI files (Bjorn Helgaas) - quirk Marvell 9128 DMA aliases (Alex Williamson) - quirk broken INTx disable on Ceton InfiniTV4 (Bjorn Helgaas) - fix CONFIG_PCI=n build by adding dummy pci_irqd_intx_xlate() (Niklas Cassel) - use DMA API to get MSI address for DesignWare IP (Niklas Cassel) - fix endpoint-mode DMA mask configuration (Kishon Vijay Abraham I) - fix ARTPEC-6 incorrect IS_ERR() usage (Wei Yongjun) - add support for ARTPEC-7 SoC (Niklas Cassel) - add endpoint-mode support for ARTPEC (Niklas Cassel) - add Cadence PCIe host and endpoint controller driver (Cyrille Pitchen) - handle multiple INTx status bits being set in dra7xx (Vignesh R) - translate dra7xx hwirq range to fix INTD handling (Vignesh R) - remove deprecated Exynos PHY initialization code (Jaehoon Chung) - fix MSI erratum workaround for HiSilicon Hip06/Hip07 (Dongdong Liu) - fix NULL pointer dereference in iProc BCMA driver (Ray Jui) - fix Keystone interrupt-controller-node lookup (Johan Hovold) - constify qcom driver structures (Julia Lawall) - rework Tegra config space mapping to increase space available for endpoints (Vidya Sagar) - simplify Tegra driver by using bus->sysdata (Manikanta Maddireddy) - remove PCI_REASSIGN_ALL_BUS usage on Tegra (Manikanta Maddireddy) - add support for Global Fabric Manager Server (GFMS) event to Microsemi Switchtec switch driver (Logan Gunthorpe) - add IDs for Switchtec PSX 24xG3 and PSX 48xG3 (Kelvin Cao) * tag 'pci-v4.16-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (140 commits) PCI: cadence: Add EndPoint Controller driver for Cadence PCIe controller dt-bindings: PCI: cadence: Add DT bindings for Cadence PCIe endpoint controller PCI: endpoint: Fix EPF device name to support multi-function devices PCI: endpoint: Add the function number as argument to EPC ops PCI: cadence: Add host driver for Cadence PCIe controller dt-bindings: PCI: cadence: Add DT bindings for Cadence PCIe host controller PCI: Add vendor ID for Cadence PCI: Add generic function to probe PCI host controllers PCI: generic: fix missing call of pci_free_resource_list() PCI: OF: Add generic function to parse and allocate PCI resources PCI: Regroup all PCI related entries into drivers/pci/Makefile PCI/DPC: Reformat DPC register definitions PCI/DPC: Add and use DPC Status register field definitions PCI/DPC: Squash dpc_rp_pio_get_info() into dpc_process_rp_pio_error() PCI/DPC: Remove unnecessary RP PIO register structs PCI/DPC: Push dpc->rp_pio_status assignment into dpc_rp_pio_get_info() PCI/DPC: Squash dpc_rp_pio_print_error() into dpc_rp_pio_get_info() PCI/DPC: Make RP PIO log size check more generic PCI/DPC: Rename local "status" to "dpc_status" PCI/DPC: Squash dpc_rp_pio_print_tlp_header() into dpc_rp_pio_print_error() ...
2018-02-01Merge tag 'char-misc-4.16-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver updates from Greg KH: "Here is the big pull request for char/misc drivers for 4.16-rc1. There's a lot of stuff in here. Three new driver subsystems were added for various types of hardware busses: - siox - slimbus - soundwire as well as a new vboxguest subsystem for the VirtualBox hypervisor drivers. There's also big updates from the FPGA subsystem, lots of Android binder fixes, the usual handful of hyper-v updates, and lots of other smaller driver updates. All of these have been in linux-next for a long time, with no reported issues" * tag 'char-misc-4.16-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (155 commits) char: lp: use true or false for boolean values android: binder: use VM_ALLOC to get vm area android: binder: Use true and false for boolean values lkdtm: fix handle_irq_event symbol for INT_HW_IRQ_EN EISA: Delete error message for a failed memory allocation in eisa_probe() EISA: Whitespace cleanup misc: remove AVR32 dependencies virt: vbox: Add error mapping for VERR_INVALID_NAME and VERR_NO_MORE_FILES soundwire: Fix a signedness bug uio_hv_generic: fix new type mismatch warnings uio_hv_generic: fix type mismatch warnings auxdisplay: img-ascii-lcd: add missing MODULE_DESCRIPTION/AUTHOR/LICENSE uio_hv_generic: add rescind support uio_hv_generic: check that host supports monitor page uio_hv_generic: create send and receive buffers uio: document uio_hv_generic regions doc: fix documentation about uio_hv_generic vmbus: add monitor_id and subchannel_id to sysfs per channel vmbus: fix ABI documentation uio_hv_generic: use ISR callback method ...
2018-01-31PCI: Regroup all PCI related entries into drivers/pci/MakefileCyrille Pitchen
Clean up drivers/Makefile by moving the pci/endpoint and pci/dwc entries from drivers/Makefile into drivers/pci/Makefile. Since we don't want to introduce any dependency between CONFIG_PCI and CONFIG_PCI_ENDPOINT, we now always execute drivers/pci/Makefile. Hence all Makefiles in drivers/pci/ were updated accordingly so no file is compiled when CONFIG_PCI is not defined. Also, we add a comment to reinforce that EPC and EPF libraries must be initialized before their users. Hence built-in EPC drivers, such as those of Designware, are linked after the endpoint core libraries. Finally, we add another comment to explain why obj-y has been chosen instead of obj-$(CONFIG_PCIE_DW) to parse the dwc/ sub-folder. Signed-off-by: Cyrille Pitchen <cyrille.pitchen@free-electrons.com> Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
2017-12-19soundwire: Add SoundWire bus typeVinod Koul
This adds the base SoundWire bus type, bus and driver registration. along with changes to module device table for new SoundWire device type. Signed-off-by: Sanyog Kale <sanyog.r.kale@intel.com> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Acked-By: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com> Reviewed-by: Takashi Iwai <tiwai@suse.de> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-19slimbus: Add SLIMbus bus typeSagar Dharia
SLIMbus (Serial Low Power Interchip Media Bus) is a specification developed by MIPI (Mobile Industry Processor Interface) alliance. SLIMbus is a 2-wire implementation, which is used to communicate with peripheral components like audio-codec. SLIMbus uses Time-Division-Multiplexing to accommodate multiple data channels, and control channel. Control channel has messages to do device-enumeration, messages to send/receive control-data to/from SLIMbus devices, messages for port/channel management, and messages to do bandwidth allocation. The framework supports multiple instances of the bus (1 controller per bus), and multiple slave devices per controller. This patch adds support to basic silmbus core which includes support to SLIMbus type, slimbus device registeration and some basic data structures. Signed-off-by: Sagar Dharia <sdharia@codeaurora.org> Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> Reviwed-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-19siox: new driver framework for eckelmann SIOXUwe Kleine-König
SIOX is a bus system invented at Eckelmann AG to control their building management and refrigeration systems. Traditionally the bus was implemented on custom microcontrollers, today Linux based machines are in use, too. The topology on a SIOX bus looks as follows: ,------->--DCLK-->---------------+----------------------. ^ v v ,--------. ,----------------------. ,------ | | | ,--------------. | | | |--->--DOUT-->---|->-|shift register|->-|--->---| | | | `--------------' | | | master | | device | | device | | | ,--------------. | | | |---<--DIN---<---|-<-|shift register|-<-|---<---| | | | `--------------' | | `--------' `----------------------' `------ v ^ ^ `----------DLD-------------------+----------------------' There are two control lines (DCLK and DLD) driven from the bus master to all devices in parallel and two daisy chained data lines, one for input and one for output. DCLK is the clock to shift both chains by a single bit. On an edge of DLD the devices latch both their input and output shift registers. This patch adds a framework for this bus type. Acked-by: Gavin Schenk <g.schenk@eckelmann.de> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-08drivers: visorbus: move driver out of stagingDavid Kershner
Move the visorbus driver out of staging (drivers/staging/unisys/visorbus) and to drivers/visorbus. Modify the configuration and makefiles so they now reference the new location. The s-Par header file visorbus.h that is referenced by all s-Par drivers, is being moved into include/linux. Signed-off-by: David Kershner <david.kershner@unisys.com> Reviewed-by: Tim Sell <timothy.sell@unisys.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-28usb: build drivers/usb/common/ when USB_SUPPORT is setRandy Dunlap
PHY drivers can use ULPI interfaces when CONFIG_USB (which is host side support) is not enabled, so also build drivers/usb/ when CONFIG_USB_SUPPORT is enabled so that drivers/usb/common/ is built. ERROR: "ulpi_unregister_driver" [drivers/phy/ti/phy-tusb1210.ko] undefined! ERROR: "__ulpi_register_driver" [drivers/phy/ti/phy-tusb1210.ko] undefined! ERROR: "ulpi_read" [drivers/phy/ti/phy-tusb1210.ko] undefined! ERROR: "ulpi_write" [drivers/phy/ti/phy-tusb1210.ko] undefined! ERROR: "ulpi_unregister_driver" [drivers/phy/qualcomm/phy-qcom-usb-hs.ko] undefined! ERROR: "__ulpi_register_driver" [drivers/phy/qualcomm/phy-qcom-usb-hs.ko] undefined! ERROR: "ulpi_write" [drivers/phy/qualcomm/phy-qcom-usb-hs.ko] undefined! Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-13Merge branches 'pm-cpufreq-sched' and 'pm-opp'Rafael J. Wysocki
* pm-cpufreq-sched: cpufreq: schedutil: Reset cached_raw_freq when not in sync with next_freq * pm-opp: PM / OPP: Add dev_pm_opp_{un}register_get_pstate_helper() PM / OPP: Support updating performance state of device's power domain PM / OPP: add missing of_node_put() for of_get_cpu_node() PM / OPP: Rename dev_pm_opp_register_put_opp_helper() PM / OPP: Add missing of_node_put(np) PM / OPP: Move error message to debug level PM / OPP: Use snprintf() to avoid kasprintf() and kfree() PM / OPP: Move the OPP directory out of power/
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-03PM / OPP: Move the OPP directory out of power/Viresh Kumar
The drivers/base/power/ directory is special and contains code related to power management core like system suspend/resume, hibernation, etc. It was fine to keep the OPP code inside it when we had just one file for it, but it is growing now and already has a directory for itself. Lets move it directly under drivers/ directory, just like cpufreq and cpuidle. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2017-08-24x86/lguest: Remove lguest supportJuergen Gross
Lguest seems to be rather unused these days. It has seen only patches ensuring it still builds the last two years and its official state is "Odd Fixes". Remove it in order to be able to clean up the paravirt code. Signed-off-by: Juergen Gross <jgross@suse.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: boris.ostrovsky@oracle.com Cc: lguest@lists.ozlabs.org Cc: rusty@rustcorp.com.au Cc: xen-devel@lists.xenproject.org Link: http://lkml.kernel.org/r/20170816173157.8633-3-jgross@suse.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-06-03mux: minimal mux subsystemPeter Rosin
Add a new minimalistic subsystem that handles multiplexer controllers. When multiplexers are used in various places in the kernel, and the same multiplexer controller can be used for several independent things, there should be one place to implement support for said multiplexer controller. A single multiplexer controller can also be used to control several parallel multiplexers, that are in turn used by different subsystems in the kernel, leading to a need to coordinate multiplexer accesses. The multiplexer subsystem handles this coordination. Thanks go out to Lars-Peter Clausen, Jonathan Cameron, Rob Herring, Wolfram Sang, Paul Gortmaker, Dan Carpenter, Colin Ian King, Greg Kroah-Hartman and last but certainly not least to Philipp Zabel for helpful comments, reviews, patches and general encouragement! Reviewed-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Peter Rosin <peda@axentia.se> Reviewed-by: Philipp Zabel <p.zabel@pengutronix.de> Tested-by: Philipp Zabel <p.zabel@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-10Merge tag 'armsoc-tee' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull TEE driver infrastructure and OP-TEE drivers from Arnd Bergmann: "This introduces a generic TEE framework in the kernel, to handle trusted environemtns (security coprocessor or software implementations such as OP-TEE/TrustZone). I'm sending it separately from the other arm-soc driver changes to give it a little more visibility, once the subsystem is merged, we will likely keep this in the arm₋soc drivers branch or have the maintainers submit pull requests directly, depending on the patch volume. I have reviewed earlier versions in the past, and have reviewed the latest version in person during Linaro Connect BUD17. Here is my overall assessment of the subsystem: - There is clearly demand for this, both for the generic infrastructure and the specific OP-TEE implementation. - The code has gone through a large number of reviews, and the review comments have all been addressed, but the reviews were not coming up with serious issues any more and nobody volunteered to vouch for the quality. - The user space ioctl interface is sufficient to work with the OP-TEE driver, and it should in principle work with other TEE implementations that follow the GlobalPlatform[1] standards, but it might need to be extended in minor ways depending on specific requirements of future TEE implementations - The main downside of the API to me is how the user space is tied to the TEE implementation in hardware or firmware, but uses a generic way to communicate with it. This seems to be an inherent problem with what it is trying to do, and I could not come up with any better solution than what is implemented here. For a detailed history of the patch series, see https://lkml.org/lkml/2017/3/10/1277" * tag 'armsoc-tee' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: arm64: dt: hikey: Add optee node Documentation: tee subsystem and op-tee driver tee: add OP-TEE driver tee: generic TEE subsystem dt/bindings: add bindings for optee
2017-05-08Merge tag 'pci-v4.12-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI updates from Bjorn Helgaas: - add framework for supporting PCIe devices in Endpoint mode (Kishon Vijay Abraham I) - use non-postable PCI config space mappings when possible (Lorenzo Pieralisi) - clean up and unify mmap of PCI BARs (David Woodhouse) - export and unify Function Level Reset support (Christoph Hellwig) - avoid FLR for Intel 82579 NICs (Sasha Neftin) - add pci_request_irq() and pci_free_irq() helpers (Christoph Hellwig) - short-circuit config access failures for disconnected devices (Keith Busch) - remove D3 sleep delay when possible (Adrian Hunter) - freeze PME scan before suspending devices (Lukas Wunner) - stop disabling MSI/MSI-X in pci_device_shutdown() (Prarit Bhargava) - disable boot interrupt quirk for ASUS M2N-LR (Stefan Assmann) - add arch-specific alignment control to improve device passthrough by avoiding multiple BARs in a page (Yongji Xie) - add sysfs sriov_drivers_autoprobe to control VF driver binding (Bodong Wang) - allow slots below PCI-to-PCIe "reverse bridges" (Bjorn Helgaas) - fix crashes when unbinding host controllers that don't support removal (Brian Norris) - add driver for MicroSemi Switchtec management interface (Logan Gunthorpe) - add driver for Faraday Technology FTPCI100 host bridge (Linus Walleij) - add i.MX7D support (Andrey Smirnov) - use generic MSI support for Aardvark (Thomas Petazzoni) - make Rockchip driver modular (Brian Norris) - advertise 128-byte Read Completion Boundary support for Rockchip (Shawn Lin) - advertise PCI_EXP_LNKSTA_SLC for Rockchip root port (Shawn Lin) - convert atomic_t to refcount_t in HV driver (Elena Reshetova) - add CPU IRQ affinity in HV driver (K. Y. Srinivasan) - fix PCI bus removal in HV driver (Long Li) - add support for ThunderX2 DMA alias topology (Jayachandran C) - add ThunderX pass2.x 2nd node MCFG quirk (Tomasz Nowicki) - add ITE 8893 bridge DMA alias quirk (Jarod Wilson) - restrict Cavium ACS quirk only to CN81xx/CN83xx/CN88xx devices (Manish Jaggi) * tag 'pci-v4.12-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (146 commits) PCI: Don't allow unbinding host controllers that aren't prepared ARM: DRA7: clockdomain: Change the CLKTRCTRL of CM_PCIE_CLKSTCTRL to SW_WKUP MAINTAINERS: Add PCI Endpoint maintainer Documentation: PCI: Add userguide for PCI endpoint test function tools: PCI: Add sample test script to invoke pcitest tools: PCI: Add a userspace tool to test PCI endpoint Documentation: misc-devices: Add Documentation for pci-endpoint-test driver misc: Add host side PCI driver for PCI test function device PCI: Add device IDs for DRA74x and DRA72x dt-bindings: PCI: dra7xx: Add DT bindings to enable unaligned access PCI: dwc: dra7xx: Workaround for errata id i870 dt-bindings: PCI: dra7xx: Add DT bindings for PCI dra7xx EP mode PCI: dwc: dra7xx: Add EP mode support PCI: dwc: dra7xx: Facilitate wrapper and MSI interrupts to be enabled independently dt-bindings: PCI: Add DT bindings for PCI designware EP mode PCI: dwc: designware: Add EP mode support Documentation: PCI: Add binding documentation for pci-test endpoint function ixgbe: Use pcie_flr() instead of duplicating it IB/hfi1: Use pcie_flr() instead of duplicating it PCI: imx6: Fix spelling mistake: "contol" -> "control" ...
2017-05-05Merge tag 'libnvdimm-for-4.12' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm Pull libnvdimm updates from Dan Williams: "The bulk of this has been in multiple -next releases. There were a few late breaking fixes and small features that got added in the last couple days, but the whole set has received a build success notification from the kbuild robot. Change summary: - Region media error reporting: A libnvdimm region device is the parent to one or more namespaces. To date, media errors have been reported via the "badblocks" attribute attached to pmem block devices for namespaces in "raw" or "memory" mode. Given that namespaces can be in "device-dax" or "btt-sector" mode this new interface reports media errors generically, i.e. independent of namespace modes or state. This subsequently allows userspace tooling to craft "ACPI 6.1 Section 9.20.7.6 Function Index 4 - Clear Uncorrectable Error" requests and submit them via the ioctl path for NVDIMM root bus devices. - Introduce 'struct dax_device' and 'struct dax_operations': Prompted by a request from Linus and feedback from Christoph this allows for dax capable drivers to publish their own custom dax operations. This fixes the broken assumption that all dax operations are related to a persistent memory device, and makes it easier for other architectures and platforms to add customized persistent memory support. - 'libnvdimm' core updates: A new "deep_flush" sysfs attribute is available for storage appliance applications to manually trigger memory controllers to drain write-pending buffers that would otherwise be flushed automatically by the platform ADR (asynchronous-DRAM-refresh) mechanism at a power loss event. Support for "locked" DIMMs is included to prevent namespaces from surfacing when the namespace label data area is locked. Finally, fixes for various reported deadlocks and crashes, also tagged for -stable. - ACPI / nfit driver updates: General updates of the nfit driver to add DSM command overrides, ACPI 6.1 health state flags support, DSM payload debug available by default, and various fixes. Acknowledgements that came after the branch was pushed: - commmit 565851c972b5 "device-dax: fix sysfs attribute deadlock": Tested-by: Yi Zhang <yizhan@redhat.com> - commit 23f498448362 "libnvdimm: rework region badblocks clearing" Tested-by: Toshi Kani <toshi.kani@hpe.com>" * tag 'libnvdimm-for-4.12' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm: (52 commits) libnvdimm, pfn: fix 'npfns' vs section alignment libnvdimm: handle locked label storage areas libnvdimm: convert NDD_ flags to use bitops, introduce NDD_LOCKED brd: fix uninitialized use of brd->dax_dev block, dax: use correct format string in bdev_dax_supported device-dax: fix sysfs attribute deadlock libnvdimm: restore "libnvdimm: band aid btt vs clear poison locking" libnvdimm: fix nvdimm_bus_lock() vs device_lock() ordering libnvdimm: rework region badblocks clearing acpi, nfit: kill ACPI_NFIT_DEBUG libnvdimm: fix clear length of nvdimm_forget_poison() libnvdimm, pmem: fix a NULL pointer BUG in nd_pmem_notify libnvdimm, region: sysfs trigger for nvdimm_flush() libnvdimm: fix phys_addr for nvdimm_clear_poison x86, dax, pmem: remove indirection around memcpy_from_pmem() block: remove block_device_operations ->direct_access() block, dax: convert bdev_dax_supported() to dax_direct_access() filesystem-dax: convert to dax_direct_access() Revert "block: use DAX for partition table reads" ext2, ext4, xfs: retrieve dax_device for iomap operations ...
2017-04-25usb: Make sure usb/phy/of gets built-inAlexey Brodkin
DWC3 driver uses of_usb_get_phy_mode() which is implemented in drivers/usb/phy/of.c and in bare minimal configuration it might not be pulled in kernel binary. In case of ARC or ARM this could be easily reproduced with "allnodefconfig" +CONFIG_USB=m +CONFIG_USB_DWC3=m. On building all ends-up with: ---------------------->8------------------ Kernel: arch/arm/boot/Image is ready Kernel: arch/arm/boot/zImage is ready Building modules, stage 2. MODPOST 5 modules ERROR: "of_usb_get_phy_mode" [drivers/usb/dwc3/dwc3.ko] undefined! make[1]: *** [__modpost] Error 1 make: *** [modules] Error 2 ---------------------->8------------------ Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Geert Uytterhoeven <geert+renesas@glider.be> Cc: Nicolas Pitre <nicolas.pitre@linaro.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Felipe Balbi <balbi@kernel.org> Cc: Felix Fietkau <nbd@nbd.name> Cc: Jeremy Kerr <jk@ozlabs.org> Cc: linux-snps-arc@lists.infradead.org Cc: stable@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-12dax: refactor dax-fs into a generic provider of 'struct dax_device' instancesDan Williams
We want dax capable drivers to be able to publish a set of dax operations [1]. However, we do not want to further abuse block_devices to advertise these operations. Instead we will attach these operations to a dax device and add a lookup mechanism to go from block device path to a dax device. A dax capable driver like pmem or brd is responsible for registering a dax device, alongside a block device, and then a dax capable filesystem is responsible for retrieving the dax device by path name if it wants to call dax_operations. For now, we refactor the dax pseudo-fs to be a generic facility, rather than an implementation detail, of the device-dax use case. Where a "dax device" is just an inode + dax infrastructure, and "Device DAX" is a mapping service layered on top of that base 'struct dax_device'. "Filesystem DAX" is then a mapping service that layers a filesystem on top of that same base device. Filesystem DAX is associated with a block_device for now, but perhaps directly to a dax device in the future, or for new pmem-only filesystems. [1]: https://lkml.org/lkml/2017/1/19/880 Suggested-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2017-04-11PCI: endpoint: Add EP core layer to enable EP controller and EP functionsKishon Vijay Abraham I
Introduce a new EP core layer in order to support endpoint functions in linux kernel. This comprises the EPC library (Endpoint Controller Library) and EPF library (Endpoint Function Library). EPC library implements functions specific to an endpoint controller and EPF library implements functions specific to an endpoint function. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Acked-by: Joao Pinto <jpinto@synopsys.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2017-03-09tee: generic TEE subsystemJens Wiklander
Initial patch for generic TEE subsystem. This subsystem provides: * Registration/un-registration of TEE drivers. * Shared memory between normal world and secure world. * Ioctl interface for interaction with user space. * Sysfs implementation_id of TEE driver A TEE (Trusted Execution Environment) driver is a driver that interfaces with a trusted OS running in some secure environment, for example, TrustZone on ARM cpus, or a separate secure co-processor etc. The TEE subsystem can serve a TEE driver for a Global Platform compliant TEE, but it's not limited to only Global Platform TEEs. This patch builds on other similar implementations trying to solve the same problem: * "optee_linuxdriver" by among others Jean-michel DELORME<jean-michel.delorme@st.com> and Emmanuel MICHEL <emmanuel.michel@st.com> * "Generic TrustZone Driver" by Javier González <javier@javigon.com> Acked-by: Andreas Dannenberg <dannenberg@ti.com> Tested-by: Jerome Forissier <jerome.forissier@linaro.org> (HiKey) Tested-by: Volodymyr Babchuk <vlad.babchuk@gmail.com> (RCAR H3) Tested-by: Scott Branden <scott.branden@broadcom.com> Reviewed-by: Javier González <javier@javigon.com> Signed-off-by: Jens Wiklander <jens.wiklander@linaro.org>
2017-02-23Merge tag 'pci-v4.11-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI updates from Bjorn Helgaas: - add ASPM L1 substate support - enable PCIe Extended Tags when supported - configure PCIe MPS settings on iProc, Versatile, X-Gene, and Xilinx - increase VPD access timeout - add ACS quirks for Intel Union Point, Qualcomm QDF2400 and QDF2432 - use new pci_irq_alloc_vectors() in more drivers - fix MSI affinity memory leak - remove unused MSI interfaces and update documentation - remove unused AER .link_reset() callback - avoid pci_lock / p->pi_lock deadlock seen with perf - serialize sysfs enable/disable num_vfs operations - move DesignWare IP from drivers/pci/host/ to drivers/pci/dwc/ and refactor so we can support both hosts and endpoints - add DT ECAM-like support for HiSilicon Hip06/Hip07 controllers - add Rockchip system power management support - add Thunder-X cn81xx and cn83xx support - add Exynos 5440 PCIe PHY support * tag 'pci-v4.11-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (93 commits) PCI: dwc: Remove dependency of designware on CONFIG_PCI PCI: dwc: Add CONFIG_PCIE_DW_HOST to enable PCI dwc host PCI: dwc: Split pcie-designware.c into host and core files PCI: dwc: designware: Fix style errors in pcie-designware.c PCI: dwc: designware: Parse "num-lanes" property in dw_pcie_setup_rc() PCI: dwc: all: Split struct pcie_port into host-only and core structures PCI: dwc: designware: Get device pointer at the start of dw_pcie_host_init() PCI: dwc: all: Rename cfg_read/cfg_write to read/write PCI: dwc: all: Use platform_set_drvdata() to save private data PCI: dwc: designware: Move register defines to designware header file PCI: dwc: Use PTR_ERR_OR_ZERO to simplify code PCI: dra7xx: Group PHY API invocations PCI: dra7xx: Enable MSI and legacy interrupts simultaneously PCI: dra7xx: Add support to force RC to work in GEN1 mode PCI: dra7xx: Simplify probe code with devm_gpiod_get_optional() PCI: Move DesignWare IP support to new drivers/pci/dwc/ directory PCI: exynos: Support the PHY generic framework Documentation: binding: Modify the exynos5440 PCIe binding phy: phy-exynos-pcie: Add support for Exynos PCIe PHY Documentation: samsung-phy: Add exynos-pcie-phy binding ...
2017-02-21PCI: dwc: Remove dependency of designware on CONFIG_PCIKishon Vijay Abraham I
CONFIG_PCI is used to enable host mode PCI. In preparation for adding endpoint mode support to designware driver, remove the dependency of designware on CONFIG_PCI and make only the host-specific part depend on CONFIG_PCI. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2017-02-10drivers/fsi: Add empty fsi bus definitionsJeremy Kerr
This change adds the initial (empty) fsi bus definition, and introduces drivers/fsi/. Signed-off-by: Jeremy Kerr <jk@ozlabs.org> Signed-off-by: Chris Bostic <cbostic@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-16ptp_clock: Allow for it to be optionalNicolas Pitre
In order to break the hard dependency between the PTP clock subsystem and ethernet drivers capable of being clock providers, this patch provides simple PTP stub functions to allow linkage of those drivers into the kernel even when the PTP subsystem is configured out. Drivers must be ready to accept NULL from ptp_clock_register() in that case. And to make it possible for PTP to be configured out, the select statement in those driver's Kconfig menu entries is converted to the new "imply" statement. This way the PTP subsystem may have Kconfig dependencies of its own, such as POSIX_TIMERS, without having to make those ethernet drivers unavailable if POSIX timers are cconfigured out. And when support for POSIX timers is selected again then the default config option for PTP clock support will automatically be adjusted accordingly. The pch_gbe driver is a bit special as it relies on extra code in drivers/ptp/ptp_pch.c. Therefore we let the make process descend into drivers/ptp/ even if PTP_1588_CLOCK is unselected. Signed-off-by: Nicolas Pitre <nico@linaro.org> Acked-by: Richard Cochran <richardcochran@gmail.com> Acked-by: Edward Cree <ecree@solarflare.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: John Stultz <john.stultz@linaro.org> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Cc: Paul Bolle <pebolle@tiscali.nl> Cc: linux-kbuild@vger.kernel.org Cc: netdev@vger.kernel.org Cc: Michal Marek <mmarek@suse.com> Link: http://lkml.kernel.org/r/1478841010-28605-4-git-send-email-nicolas.pitre@linaro.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-10-23Merge tag 'for-linus-4.9-2' of git://git.code.sf.net/p/openipmi/linux-ipmiLinus Torvalds
Pull IPMI updates from Corey Minyard: "A small bug fix and a new driver for acting as an IPMI device. I was on vacation during the merge window (a long vacation) but this is a bug fix that should go in and a new driver that shouldn't hurt anything. This has been in linux-next for a month or so" * tag 'for-linus-4.9-2' of git://git.code.sf.net/p/openipmi/linux-ipmi: ipmi: fix crash on reading version from proc after unregisted bmc ipmi/bt-bmc: remove redundant return value check of platform_get_resource() ipmi/bt-bmc: add a dependency on ARCH_ASPEED ipmi: Fix ioremap error handling in bt-bmc ipmi: add an Aspeed BT IPMI BMC driver
2016-09-29ipmi: add an Aspeed BT IPMI BMC driverAlistair Popple
This patch adds a simple device driver to expose the iBT interface on Aspeed SOCs (AST2400 and AST2500) as a character device. Such SOCs are commonly used as BMCs (BaseBoard Management Controllers) and this driver implements the BMC side of the BT interface. The BT (Block Transfer) interface is used to perform in-band IPMI communication between a host and its BMC. Entire messages are buffered before sending a notification to the other end, host or BMC, that there is data to be read. Usually, the host emits requests and the BMC responses but the specification provides a mean for the BMC to send SMS Attention (BMC-to-Host attention or System Management Software attention) messages. For this purpose, the driver introduces a specific ioctl on the device: 'BT_BMC_IOCTL_SMS_ATN' that can be used by the system running on the BMC to signal the host of such an event. The device name defaults to '/dev/ipmi-bt-host' Signed-off-by: Alistair Popple <alistair@popple.id.au> Signed-off-by: Jeremy Kerr <jk@ozlabs.org> Signed-off-by: Joel Stanley <joel@jms.id.au> [clg: - checkpatch fixes - added a devicetree binding documentation - replace 'bt_host' by 'bt_bmc' to reflect that the driver is the BMC side of the IPMI BT interface - renamed the device to 'ipmi-bt-host' - introduced a temporary buffer to copy_{to,from}_user - used platform_get_irq() - moved the driver under drivers/char/ipmi/ but kept it as a misc device - changed the compatible cell to "aspeed,ast2400-bt-bmc" ] Signed-off-by: Cédric Le Goater <clg@kaod.org> Acked-by: Arnd Bergmann <arnd@arndb.de> [clg: - checkpatch --strict fixes - removed the use of devm_iounmap, devm_kfree in cleanup paths - introduced an atomic-t to limit opens to 1 - introduced a mutex to protect write/read operations] Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Cédric Le Goater <clg@kaod.org> Signed-off-by: Corey Minyard <cminyard@mvista.com>
2016-09-23clk: probe common clock drivers earlierMasahiro Yamada
Several SoCs implement platform drivers for clocks rather than CLK_OF_DECLARE(). Clocks should come earlier because they are prerequisites for many of other drivers. It will help to mitigate EPROBE_DEFER issues. Also, drop the comment since it does not carry much value. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Michael Turquette <mturquette@baylibre.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-06Merge tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhostLinus Torvalds
Pull virtio/vhost updates from Michael Tsirkin: - new vsock device support in host and guest - platform IOMMU support in host and guest, including compatibility quirks for legacy systems. - misc fixes and cleanups. * tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost: VSOCK: Use kvfree() vhost: split out vringh Kconfig vhost: detect 32 bit integer wrap around vhost: new device IOTLB API vhost: drop vringh dependency vhost: convert pre sorted vhost memory array to interval tree vhost: introduce vhost memory accessors VSOCK: Add Makefile and Kconfig VSOCK: Introduce vhost_vsock.ko VSOCK: Introduce virtio_transport.ko VSOCK: Introduce virtio_vsock_common.ko VSOCK: defer sock removal to transports VSOCK: transport-specific vsock_transport functions vhost: drop vringh dependency vop: pull in vhost Kconfig virtio: new feature to detect IOMMU device quirk balloon: check the number of available pages in leak balloon vhost: lockless enqueuing vhost: simplify work flushing
2016-08-02vhost: drop vringh dependencyMichael S. Tsirkin
vringh isn't used by vhost net or scsi - it's used by CAIF only at the moment. Drop the dependency. Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2016-07-27Merge tag 'hsi-for-4.8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sre/linux-hsi Pull HSI updates from Sebastian Reichel: - proper runtime pm support for omap-ssi and ssi-protocol - misc fixes * tag 'hsi-for-4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/sre/linux-hsi: (24 commits) HSI: omap_ssi: drop pm_runtime_irq_safe HSI: omap_ssi_port: use rpm autosuspend API HSI: omap_ssi: call msg->complete() from process context HSI: omap_ssi_port: ensure clocks are kept enabled during transfer HSI: omap_ssi_port: replace pm_runtime_put_sync with non-sync variant HSI: omap_ssi_port: avoid calling runtime_pm_*_sync inside spinlock HSI: omap_ssi_port: avoid pm_runtime_get_sync in ssi_start_dma and ssi_start_pio HSI: omap_ssi_port: switch to threaded pio irq HSI: omap_ssi_core: remove pm_runtime_get_sync call from tasklet HSI: omap_ssi_core: use pm_runtime_put instead of pm_runtime_put_sync HSI: omap_ssi_port: prepare start_tx/stop_tx for blocking pm_runtime calls HSI: core: switch port event notifier from atomic to blocking HSI: omap_ssi_port: replace wkin_cken with atomic bitmap operations HSI: omap_ssi: convert cawake irq handler to thread HSI: ssi_protocol: fix ssip_xmit invocation HSI: ssi_protocol: replace spin_lock with spin_lock_bh HSI: ssi_protocol: avoid ssi_waketest call with held spinlock HSI: omap_ssi: do not reset module HSI: omap_ssi_port: remove useless newline hsi: Only descend into hsi directory when CONFIG_HSI is set ...
2016-07-27Merge tag 'leds_for_4.8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/j.anaszewski/linux-leds Pull LED updates from Jacek Anaszewski: "New LED class driver: - LED driver for TI LP3952 6-Channel Color LED LED core improvements: - Only descend into leds directory when CONFIG_NEW_LEDS is set - Add no-op gpio_led_register_device when LED subsystem is disabled - MAINTAINERS: Add file patterns for led device tree bindings LED Trigger core improvements: - return error if invalid trigger name is provided via sysfs LED class drivers improvements - is31fl32xx: define complete i2c_device_id table - is31fl32xx: fix typo in id and match table names - leds-gpio: Set of_node for created LED devices - pca9532: Add device tree support Conversion of IDE trigger to common disk trigger: - leds: convert IDE trigger to common disk trigger - leds: documentation: 'ide-disk' to 'disk-activity' - unicore32: use the new LED disk activity trigger - parisc: use the new LED disk activity trigger - mips: use the new LED disk activity trigger - arm: use the new LED disk activity trigger - powerpc: use the new LED disk activity trigger" * tag 'leds_for_4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/j.anaszewski/linux-leds: leds: is31fl32xx: define complete i2c_device_id table leds: is31fl32xx: fix typo in id and match table names leds: LED driver for TI LP3952 6-Channel Color LED leds: leds-gpio: Set of_node for created LED devices leds: triggers: return error if invalid trigger name is provided via sysfs leds: Only descend into leds directory when CONFIG_NEW_LEDS is set leds: Add no-op gpio_led_register_device when LED subsystem is disabled unicore32: use the new LED disk activity trigger parisc: use the new LED disk activity trigger mips: use the new LED disk activity trigger arm: use the new LED disk activity trigger powerpc: use the new LED disk activity trigger leds: documentation: 'ide-disk' to 'disk-activity' leds: convert IDE trigger to common disk trigger leds: pca9532: Add device tree support MAINTAINERS: Add file patterns for led device tree bindings
2016-07-26Merge tag 'gpio-v4.8-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull GPIO updates from Linus Walleij: "This is the bulk of GPIO changes for the v4.8 kernel cycle. The big news is the completion of the chardev ABI which I'm very happy about and apart from that it's an ordinary, quite busy cycle. The details are below. The patches are tested in linux-next for some time, patches to other subsystem mostly have ACKs. I got overly ambitious with configureing lines as input for IRQ lines but it turns out that some controllers have their interrupt-enable and input-enabling in orthogonal settings so the assumption that all IRQ lines are input lines does not hold. Oh well, revert and back to the drawing board with that. Core changes: - The big item is of course the completion of the character device ABI. It has now replaced and surpassed the former unmaintainable sysfs ABI: we can now hammer (bitbang) individual lines or sets of lines and read individual lines or sets of lines from userspace, and we can also register to listen to GPIO events from userspace. As a tie-in we have two new tools in tools/gpio: gpio-hammer and gpio-event-mon that illustrate the proper use of the new ABI. As someone said: the wild west days of GPIO are now over. - Continued to remove the pointless ARCH_[WANT_OPTIONAL|REQUIRE]_GPIOLIB Kconfig symbols. I'm patching hexagon, openrisc, powerpc, sh, unicore, ia64 and microblaze. These are either ACKed by their maintainers or patched anyways after a grace period and no response from maintainers. Some archs (ARM) come in from their trees, and others (x86) are still not fixed, so I might send a second pull request to root it out later in this merge window, or just defer to v4.9. - The GPIO tools are moved to the tools build system. New drivers: - New driver for the MAX77620/MAX20024. - New driver for the Intel Merrifield. - Enabled PCA953x for the TI PCA9536. - Enabled PCA953x for the Intel Edison. - Enabled R8A7792 in the RCAR driver. Driver improvements: - The STMPE and F7188x now supports the .get_direction() callback. - The Xilinx driver supports setting multiple lines at once. - ACPI support for the Vulcan GPIO controller. - The MMIO GPIO driver supports device tree probing. - The Acer One 10 is supported through the _DEP ACPI attribute. Cleanups: - A major cleanup of the OF/DT support code. It is way easier to read and understand now, probably this improves performance too. - Drop a few redundant .owner assignments. - Remove CLPS711x boardfile support: we are 100% DT" * tag 'gpio-v4.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (67 commits) MAINTAINERS: Add INTEL MERRIFIELD GPIO entry gpio: dwapb: add missing fwnode_handle_put() in dwapb_gpio_get_pdata() gpio: merrifield: Protect irq_ack() and gpio_set() by lock gpio: merrifield: Introduce GPIO driver to support Merrifield gpio: intel-mid: Make it depend to X86_INTEL_MID gpio: intel-mid: Sort header block alphabetically gpio: intel-mid: Remove potentially harmful code gpio: rcar: add R8A7792 support gpiolib: remove duplicated include from gpiolib.c Revert "gpio: convince line to become input in irq helper" gpiolib: of_find_gpio(): Don't discard errors gpio: of: Allow overriding the device node gpio: free handles in fringe cases gpio: tps65218: Add platform_device_id table gpio: max77620: get gpio value based on direction gpio: lynxpoint: avoid potential warning on error path tools/gpio: add install section tools/gpio: move to tools buildsystem gpio: intel-mid: switch to devm_gpiochip_add_data() gpio: 74x164: Use spi_write() helper instead of open coding ...
2016-06-27leds: Only descend into leds directory when CONFIG_NEW_LEDS is setAndrew F. Davis
When CONFIG_NEW_LEDS is not set make will still descend into the leds directory but nothing will be built. This produces unneeded build artifacts and messages in addition to slowing the build. Fix this here. Signed-off-by: Andrew F. Davis <afd@ti.com> Signed-off-by: Jacek Anaszewski <j.anaszewski@samsung.com>
2016-06-15hsi: Only descend into hsi directory when CONFIG_HSI is setAndrew F. Davis
When CONFIG_HSI is not set make will still descend into the hsi directory but nothing will be built. This produces unneeded build artifacts and messages in addition to slowing the build. Fix this here. Signed-off-by: Andrew F. Davis <afd@ti.com> Signed-off-by: Sebastian Reichel <sre@kernel.org>
2016-06-14gpio: Only descend into gpio directory when CONFIG_GPIOLIB is setAndrew F. Davis
When CONFIG_GPIOLIB is not set make will still descend into the gpio directory but nothing will be built. This produces unneeded build artifacts and messages in addition to slowing the build. Fix this here. Signed-off-by: Andrew F. Davis <afd@ti.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-05-30drivers: sh: Stop using the legacy clock domain on ARMGeert Uytterhoeven
Since commits 71d076ceb245f0d9 ("ARM: shmobile: Enable PM and PM_GENERIC_DOMAINS for SoCs with PM Domains") and 2ee98234b88174f2 ("arm64: renesas: Enable PM and PM_GENERIC_DOMAINS for SoCs with PM Domains"), CONFIG_PM and CONFIG_PM_GENERIC_DOMAINS are enabled unconditionally for Renesas ARM-based SoCs. Hence the legacy clock domain is no longer used on these SoCs. Remove the related support code, and stop entering drivers/sh/ on ARM. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2016-05-20/dev/dax, pmem: direct access to persistent memoryDan Williams
Device DAX is the device-centric analogue of Filesystem DAX (CONFIG_FS_DAX). It allows memory ranges to be allocated and mapped without need of an intervening file system. Device DAX is strict, precise and predictable. Specifically this interface: 1/ Guarantees fault granularity with respect to a given page size (pte, pmd, or pud) set at configuration time. 2/ Enforces deterministic behavior by being strict about what fault scenarios are supported. For example, by forcing MADV_DONTFORK semantics and omitting MAP_PRIVATE support device-dax guarantees that a mapping always behaves/performs the same once established. It is the "what you see is what you get" access mechanism to differentiated memory vs filesystem DAX which has filesystem specific implementation semantics. Persistent memory is the first target, but the mechanism is also targeted for exclusive allocations of performance differentiated memory ranges. This commit is limited to the base device driver infrastructure to associate a dax device with pmem range. Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2015-12-08power: Fix unmet dependency on POWER_SUPPLY by POWER_RESET by uncoupling themKrzysztof Kozlowski
Currently the reset/power off handlers (POWER_RESET) and Adaptive Voltage Scaling class (POWER_AVS) are not built when POWER_SUPPLY is disabled. The POWER_RESET is also not visible in drivers main section of config. However they do not really depend on power supply so they can be built always. The objects for power supply drivers already depend on particular Kconfig symbols so there is no need for any changes in drivers/power/Makefile. This allows selecting POWER_RESET from main drivers config section and fixes following build warning (encountered on ARM exynos defconfig when POWER_SUPPLY is disabled manually): warning: (ARCH_HISI && ARCH_INTEGRATOR && ARCH_EXYNOS && ARCH_VEXPRESS && REALVIEW_DT) selects POWER_RESET which has unmet direct dependencies (POWER_SUPPLY) warning: (ARCH_EXYNOS) selects POWER_RESET_SYSCON which has unmet direct dependencies (POWER_SUPPLY && POWER_RESET && OF) warning: (ARCH_EXYNOS) selects POWER_RESET_SYSCON_POWEROFF which has unmet direct dependencies (POWER_SUPPLY && POWER_RESET && OF) Reported-by: Pavel Fedin <p.fedin@samsung.com> Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Sebastian Reichel <sre@kernel.org>
2015-11-16null_blk: register as a LightNVM deviceMatias Bjørling
Add support for registering as a LightNVM device. This allows us to evaluate the performance of the LightNVM subsystem. In /drivers/Makefile, LightNVM is moved above block device drivers to make sure that the LightNVM media managers have been initialized before drivers under /drivers/block are initialized. Signed-off-by: Matias Bjørling <m@bjorling.me> Fix by Jens Axboe to remove unneeded slab cache and the following memory leak. Signed-off-by: Jens Axboe <axboe@fb.com>
2015-11-04Merge tag 'char-misc-4.4-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver updates from Greg KH: "Here is the big char/misc driver update for 4.4-rc1. Lots of different driver and subsystem updates, hwtracing being the largest with the addition of some new platforms that are now supported. Full details in the shortlog. All of these have been in linux-next for a long time with no reported issues" * tag 'char-misc-4.4-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (181 commits) fpga: socfpga: Fix check of return value of devm_request_irq lkdtm: fix ACCESS_USERSPACE test mcb: Destroy IDA on module unload mcb: Do not return zero on error path in mcb_pci_probe() mei: bus: set the device name before running fixup mei: bus: use correct lock ordering mei: Fix debugfs filename in error output char: ipmi: ipmi_ssif: Replace timeval with timespec64 fpga: zynq-fpga: Fix issue with drvdata being overwritten. fpga manager: remove unnecessary null pointer checks fpga manager: ensure lifetime with of_fpga_mgr_get fpga: zynq-fpga: Change fw format to handle bin instead of bit. fpga: zynq-fpga: Fix unbalanced clock handling misc: sram: partition base address belongs to __iomem space coresight: etm3x: adding documentation for sysFS's cpu interface vme: 8-bit status/id takes 256 values, not 255 fpga manager: Adding FPGA Manager support for Xilinx Zynq 7000 ARM: zynq: dt: Updated devicetree for Zynq 7000 platform. ARM: dt: fpga: Added binding docs for Xilinx Zynq FPGA manager. ver_linux: proc/modules, limit text processing to 'sed' ...
2015-10-29lightnvm: Support for Open-Channel SSDsMatias Bjørling
Open-channel SSDs are devices that share responsibilities with the host in order to implement and maintain features that typical SSDs keep strictly in firmware. These include (i) the Flash Translation Layer (FTL), (ii) bad block management, and (iii) hardware units such as the flash controller, the interface controller, and large amounts of flash chips. In this way, Open-channels SSDs exposes direct access to their physical flash storage, while keeping a subset of the internal features of SSDs. LightNVM is a specification that gives support to Open-channel SSDs LightNVM allows the host to manage data placement, garbage collection, and parallelism. Device specific responsibilities such as bad block management, FTL extensions to support atomic IOs, or metadata persistence are still handled by the device. The implementation of LightNVM consists of two parts: core and (multiple) targets. The core implements functionality shared across targets. This is initialization, teardown and statistics. The targets implement the interface that exposes physical flash to user-space applications. Examples of such targets include key-value store, object-store, as well as traditional block devices, which can be application-specific. Contributions in this patch from: Javier Gonzalez <jg@lightnvm.io> Dongsheng Yang <yangds.fnst@cn.fujitsu.com> Jesper Madsen <jmad@itu.dk> Signed-off-by: Matias Bjørling <m@bjorling.me> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-10-09nvme: move to a new drivers/nvme/host directoryJay Sternberg
This patch moves the NVMe driver from drivers/block/ to its own new drivers/nvme/host/ directory. This is in preparation of splitting the current monolithic driver up and add support for the upcoming NVMe over Fabrics standard. The drivers/nvme/host/ is chose to leave space for a NVMe target implementation in addition to this host side driver. Signed-off-by: Jay Sternberg <jay.e.sternberg@intel.com> [hch: rebased, renamed core.c to pci.c, slight tweaks] Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Keith Busch <keith.busch@intel.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-10-07add FPGA manager coreAlan Tull
API to support programming FPGA's. The following functions are exported as GPL: * fpga_mgr_buf_load Load fpga from image in buffer * fpga_mgr_firmware_load Request firmware and load it to the FPGA. * fpga_mgr_register * fpga_mgr_unregister FPGA device drivers can be added by calling fpga_mgr_register() to register a set of fpga_manager_ops to do device specific stuff. * of_fpga_mgr_get * fpga_mgr_put Get/put a reference to a fpga manager. The following sysfs files are created: * /sys/class/fpga_manager/<fpga>/name Name of low level driver. * /sys/class/fpga_manager/<fpga>/state State of fpga manager Signed-off-by: Alan Tull <atull@opensource.altera.com> Acked-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-04intel_th: Add driver infrastructure for Intel(R) Trace Hub devicesAlexander Shishkin
Intel(R) Trace Hub (TH) is a set of hardware blocks (subdevices) that produce, switch and output trace data from multiple hardware and software sources over several types of trace output ports encoded in System Trace Protocol (MIPI STPv2) and is intended to perform full system debugging. For these subdevices, we create a bus, where they can be discovered and configured by userspace software. This patch creates this bus infrastructure, three types of devices (source, output, switch), resource allocation, some callback mechanisms to facilitate communication between the subdevices' drivers and some common sysfs attributes. Signed-off-by: Alexander Shishkin <alexander.shishkin@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-04stm class: Introduce an abstraction for System Trace Module devicesAlexander Shishkin
A System Trace Module (STM) is a device exporting data in System Trace Protocol (STP) format as defined by MIPI STP standards. Examples of such devices are Intel(R) Trace Hub and Coresight STM. This abstraction provides a unified interface for software trace sources to send their data over an STM device to a debug host. In order to do that, such a trace source needs to be assigned a pair of master/channel identifiers that all the data from this source will be tagged with. The STP decoder on the debug host side will use these master/channel tags to distinguish different trace streams from one another inside one STP stream. This abstraction provides a configfs-based policy management mechanism for dynamic allocation of these master/channel pairs based on trace source-supplied string identifier. It has the flexibility of being defined at runtime and at the same time (provided that the policy definition is aligned with the decoding end) consistency. For userspace trace sources, this abstraction provides write()-based and mmap()-based (if the underlying stm device allows this) output mechanism. For kernel-side trace sources, we provide "stm_source" device class that can be connected to an stm device at run time. Cc: linux-api@vger.kernel.org Reviewed-by: Mathieu Poirier <mathieu.poirier@linaro.org> Signed-off-by: Alexander Shishkin <alexander.shishkin@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-09-04Merge tag 'pinctrl-v4.3-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl Pull pin control updates from Linus Walleij: "This is the bulk of pin control changes for the v4.3 development cycle. Like with GPIO it's a lot of stuff. If my subsystems are any sign of the overall tempo of the kernel v4.3 will be a gigantic diff. [ It looks like 4.3 is calmer than 4.2 in most other subsystems, but we'll see - Linus ] Core changes: - It is possible configure groups in debugfs. - Consolidation of chained IRQ handler install/remove replacing all call sites where irq_set_handler_data() and irq_set_chained_handler() were done in succession with a combined call to irq_set_chained_handler_and_data(). This series was created by Thomas Gleixner after the problem was observed by Russell King. - Tglx also made another series of patches switching __irq_set_handler_locked() for irq_set_handler_locked() which is way cleaner. - Tglx also wrote a good bunch of patches to make use of irq_desc_get_xxx() accessors and avoid looking up irq_descs from IRQ numbers. The goal is to get rid of the irq number from the handlers in the IRQ flow which is nice. Driver feature enhancements: - Power management support for the SiRF SoC Atlas 7. - Power down support for the Qualcomm driver. - Intel Cherryview and Baytrail: switch drivers to use raw spinlocks in IRQ handlers to play nice with the realtime patch set. - Rework and new modes handling for Qualcomm SPMI-MPP. - Pinconf power source config for SH PFC. New drivers and subdrivers: - A new driver for Conexant Digicolor CX92755. - A new driver for UniPhier PH1-LD4, PH1-Pro4, PH1-sLD8, PH1-Pro5, ProXtream2 and PH1-LD6b SoC pin control support. - Reverse-egineered the S/PDIF settings for the Allwinner sun4i driver. - Support for Qualcomm Technologies QDF2xxx ARM64 SoCs - A new Freescale i.mx6ul subdriver. Cleanup: - Remove platform data support in a number of SH PFC subdrivers" * tag 'pinctrl-v4.3-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: (95 commits) pinctrl: at91: fix null pointer dereference pinctrl: mediatek: Implement wake handler and suspend resume pinctrl: mediatek: Fix multiple registration issue. pinctrl: sh-pfc: r8a7794: add USB pin groups pinctrl: at91: Use generic irq_{request,release}_resources() pinctrl: cherryview: Use raw_spinlock for locking pinctrl: baytrail: Use raw_spinlock for locking pinctrl: imx6ul: Remove .owner field pinctrl: zynq: Fix typos in smc0_nand_grp and smc0_nor_grp pinctrl: sh-pfc: Implement pinconf power-source param for voltage switching clk: rockchip: add pclk_pd_pmu to the list of rk3288 critical clocks pinctrl: sun4i: add spdif to pin description. pinctrl: atlas7: clear ugly branch statements for pull and drivestrength pinctrl: baytrail: Serialize all register access pinctrl: baytrail: Drop FSF mailing address pinctrl: rockchip: only enable gpio clock when it setting pinctrl/mediatek: fix spelling mistake in dev_err error message pinctrl: cherryview: Serialize all register access pinctrl: UniPhier: PH1-Pro5: add I2C ch6 pin-mux setting pinctrl: nomadik: reflect current input value ...
2015-09-03Merge branch 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM development updates from Russell King: "Included in this update: - moving PSCI code from ARM64/ARM to drivers/ - removal of some architecture internals from global kernel view - addition of software based "privileged no access" support using the old domains register to turn off the ability for kernel loads/stores to access userspace. Only the proper accessors will be usable. - addition of early fixup support for early console - re-addition (and reimplementation) of OMAP special interconnect barrier - removal of finish_arch_switch() - only expose cpuX/online in sysfs if hotpluggable - a number of code cleanups" * 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (41 commits) ARM: software-based priviledged-no-access support ARM: entry: provide uaccess assembly macro hooks ARM: entry: get rid of multiple macro definitions ARM: 8421/1: smp: Collapse arch_cpu_idle_dead() into cpu_die() ARM: uaccess: provide uaccess_save_and_enable() and uaccess_restore() ARM: mm: improve do_ldrd_abort macro ARM: entry: ensure that IRQs are enabled when calling syscall_trace_exit() ARM: entry: efficiency cleanups ARM: entry: get rid of asm_trace_hardirqs_on_cond ARM: uaccess: simplify user access assembly ARM: domains: remove DOMAIN_TABLE ARM: domains: keep vectors in separate domain ARM: domains: get rid of manager mode for user domain ARM: domains: move initial domain setting value to asm/domains.h ARM: domains: provide domain_mask() ARM: domains: switch to keeping domain value in register ARM: 8419/1: dma-mapping: harmonize definition of DMA_ERROR_CODE ARM: 8417/1: refactor bitops functions with BIT_MASK() and BIT_WORD() ARM: 8416/1: Feroceon: use of_iomap() to map register base ARM: 8415/1: early fixmap support for earlycon ...
