[ Upstream commit d693c008e3ca04db5916ff72e68ce661888a913b ]
Commit 53fa1f6e8a59 ("ACPI / video: Only default only_lcd to true on
Win8-ready _desktops_") introduced chassis type detection, limiting the
lcd_only check for the backlight to devices where the chassis-type
indicates their is no builtin LCD panel.
The purpose of the lcd_only check is to avoid advertising a backlight
interface on desktops, since skylake and newer machines seem to always
have a backlight interface even if there is no LCD panel. The limiting
of this check to desktops only was done to avoid breaking backlight
support on some laptops which do not have the lcd flag set.
The Fujitsu ESPRIMO Q910 which is a compact (NUC like) desktop machine
has a chassis type of 0x10 aka "Lunch Box". Without the lcd_only check
we end up falsely advertising backlight/brightness control on this
device. This commit extend the dmi_is_desktop check to return true
for type 0x10 to fix this.
Fixes: 53fa1f6e8a59 ("ACPI / video: Only default only_lcd to true ...")
[ Upstream commit cecf3e3e0803462335e25d083345682518097334 ]
This commit refactors the chassis-type detection introduced by
commit 53fa1f6e8a59 ("ACPI / video: Only default only_lcd to true on
Win8-ready _desktops_") (where desktop means anything without a builtin
screen).
The DMI chassis_type is an unsigned integer, so rather then doing a
whole bunch of string-compares on it, convert it to an int and feed
the result to a switch case.
Note the switch case uses hex values, this is done because the spec
uses hex values too. This changes the check for "Main Server Chassis"
from checking for 11 decimal to 11 hexadecimal, this is a bug fix,
the original check for 11 decimal was wrong.
[ rjw: Drop redundant return statements ]
commit 53fa1f6e8a5958da698a31edf366ffe90596b490 upstream.
Commit 5928c281524f (ACPI / video: Default lcd_only to true on Win8-ready
and newer machines) made only_lcd default to true on all machines where
acpi_osi_is_win8() returns true, including laptops.
The purpose of this is to avoid the bogus / non-working acpi backlight
interface which many newer BIOS-es define on desktop machines.
But this is causing a regression on some laptops, specifically on the
Dell XPS 13 2013 model, which does not have the LCD flag set for its
fully functional ACPI backlight interface.
Rather then DMI quirking our way out of this, this commits changes the
logic for setting only_lcd to true, to only do this on machines with
a desktop (or server) dmi chassis-type.
Note that we cannot simply only check the chassis-type and not register
the backlight interface based on that as there are some laptops and
tablets which have their chassis-type set to "3" aka desktop. Hopefully
the combination of checking the LCD flag, but only on devices with
a desktop(ish) chassis-type will avoid the needs for DMI quirks for this,
or at least limit the amount of DMI quirks which we need to a minimum.
Fixes: 5928c281524f (ACPI / video: Default lcd_only to true on Win8-ready and newer machines)
Reported-and-tested-by: James Hogan <jhogan@kernel.org>
Cc: 4.15+ <stable@vger.kernel.org> # 4.15+
[ Upstream commit 5928c281524fe451114e04f1dfa11246a37e859f ]
We're seeing a lot of bogus backlight interfaces on newer machines without
a LCD such as desktops, servers and HDMI sticks. This causes userspace to
show a non-functional brightness slider in e.g. the GNOME3 system menu,
which is undesirable. And, in general, we should simply just not register
a non functional backlight interface.
Checking the LCD flag causes the bogus acpi_video backlight interfaces to
go away (on the machines this was tested on).
This change sets the lcd_only option by default on any machines which
are Win8-ready, to fix this.
This is not entirely without a risk of regressions, but video_detect.c
already prefers native-backlight interfaces over the acpi_video one
on Win8-ready machines, calling acpi_video_unregister_backlight() as soon
as a native interface shows up. This is done because the ACPI backlight
interface often is broken on Win8-ready machines, because win8 does not
seem to actually use it.
So in practice we already end up not registering the ACPI backlight
interface on (most) Win8-ready machines with a LCD panel, thus this
change does not change anything for (most) machines with a LCD panel
and on machines without a LCD panel we actually don't want to register
any backlight interfaces.
This has been tested on the following machines and fixes a bogus backlight
interface showing up there:
- Desktop with an Asrock B150M Pro4S/D3 m.b. using i5-6500 builtin gfx
- Intel Compute Stick STK1AW32SC
- Meegopad T08 HDMI stick
Bogus backlight interfaces have also been reported on:
- Desktop with Asus H87I-Plus m.b.
- Desktop with ASRock B75M-ITX m.b.
- Desktop with Gigabyte Z87-D3HP m.b.
- Dell PowerEdge T20 desktop
Link: https://bugzilla.redhat.com/show_bug.cgi?id=1097436
Link: https://bugzilla.redhat.com/show_bug.cgi?id=1133327
Link: https://bugzilla.redhat.com/show_bug.cgi?id=1133329
Link: https://bugzilla.redhat.com/show_bug.cgi?id=1133646
Some system supports hybrid graphics and its discrete VGA
does not have any connectors and therefore has no _DOD method.
Signed-off-by: Alex Hung <alex.hung@canonical.com>
Reviewed-by: Aaron Lu <aaron.lu@intel.com>
commit 059500940def (ACPI/video: export acpi_video_get_levels)
mistakenly dropped the correct value of max_level and that caused the
set_level function following failed and the acpi_video backlight interface
didn't get created. Fix this by passing back the correct max_level value.
While at it, also fix the param used in acpi_video_device_lcd_query_levels
where acpi_handle is expected but acpi_video_device is passed.
Fixes: 059500940def (ACPI/video: export acpi_video_get_levels)
Reported-and-tested-by: Valdis Kletnieks <valdis.kletnieks@vt.edu>
Signed-off-by: Aaron Lu <aaron.lu@intel.com>
Acked-by: Zhang Rui <rui.zhang@intel.com>
The acpi_video_get_levels is useful for other drivers, i.e. the
to-be-added int3406 thermal driver, so export it.
device_decode is now no longer used, so we may as well remove it.
Fixes gcc 6 warning:
drivers/acpi/acpi_video.c:221:19: warning: ‘device_decode’ defined
but not used [-Wunused-const-variable]
static const char device_decode[][30] = {
R830
The Toshiba Satellite R830 needs disable_backlight_sysfs_if=1, just like
the Toshiba Portege R830. Add a quirk for this.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=21012
Cc: 4.2+ <stable@vger.kernel.org> # 4.2+
Tested-by: To Do <entodoays@gmail.com>
acpi_video_handles_brightness_key_presses()
If acpi_video_handles_brightness_key_presses() was called before
acpi_video_register(), it would use the video_list mutex / list_head
uninitialized.
This patch fixes this by using DEFINE_MUTEX / LIST_HEAD when declaring
these, instead of initializing them runtime from acpi_video_register().
Fixes: 90b066b15eda "ACPI / video: Add a acpi_video_handles_brightness_key_presses() helper"
checking for keypresses"
On systems with an intel video opcode region, the completion used in the
patch this commit reverts will only complete if the i915 driver loads.
If for some reason the i915 driver never loads calls to
acpi_video_handles_brightness_key_presses() may be delayed indefinitely.
This reverts commit aecbd9b1bff6 ("ACPI / video: driver must be registered
before checking for keypresses") fixing this.
This reintroduces a potential NULL pointer deref due to using an
uninitalized mutex, this is fixed differently in a follow-up patch.
Fixes: aecbd9b1bff6 (ACPI / video: driver must be registered before checking for keypresses)
The Toshiba Portege R700 needs disable_backlight_sysfs_if=1, just like
Tested-by: Emma Reisz <emmareisz@outlook.com>
acpi_video_handles_brightness_key_presses() may use an uninitialized mutex.
The error has been reported by lockdep: DEBUG_LOCKS_WARN_ON(l->magic != l).
The function assumes that the video driver has been registered before being
called. As explained in the comment of acpi_video_init(), the registration
of the video class may be defered and thus may not take place in the init
function of the module.
Use completion mechanisms to make sure that
acpi_video_handles_brightness_key_presses() wait for the completion of
acpi_video_register() before using the mutex.
Also get rid of register_count since task completion can replace it.
Signed-off-by: Adrien Schildknecht <adrien+dev@schischi.me>
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
The Dell Vostro V131 has an especially broken acpi-video implementation.
The backlight control bits work, but when the brightness is changed via
the acpi-video interface the backlight flickers annoyingly before settling
at the new brightness, switching to using the native interface fixes the
flickering so add a quirk for this (the vendor interface has the same
problem).
Brightness keypresses reported through the acpi-video-bus are also broken,
they get reported one event delayed, so if you press the brightness-up
hotkey on the keyboard nothing happens, then if you press brightness-down,
the previous brightness-up event gets reported. Since the keypresses are
also reported via wmi (if active) and via atkbd (when wmi is not active)
add a quirk to simply filter out the delayed (broken) events.
Reported-and-tested-by: Michał Kępień <kernel@kempniu.pl>
Add a module option to disable the reporting of keypresses, in some buggy
firmware implementatinon, the reported events are wrong. E.g. they lag
reality by one event in the case triggering the writing of this patch.
In this case it is better to not forward these wrong events to userspace
(esp.) when there is another source of the same events which is not buggy.
Note this is only intended to work around implementations which send
events which are plain wrong. In some cases we get double events, e.g.
from both acpi-video and the atkbd driver, in this case acpi-video is
considered the canonical source, and the events from the other source
should be filtered (using e.g. /lib/udev/hwdb.d/60-keyboard.hwdb).
Several drivers want to know if the acpi-video is generating key-presses
for brightness change hotkeys to avoid sending double key-events to
userspace for these. Currently these driver use this construct for this:
if (acpi_video_get_backlight_type() == acpi_backlight_vendor)
report_brightness_key_event();
This indirect way of detecting if acpi-video is active does not make the
code easier to understand, and in some cases it is wrong because just
because the preferred type != vendor does not mean that acpi-video is
actually listening for brightness events, e.g. there may be no acpi-video
bus on the system at all.
This commit adds a acpi_video_handles_brightness_key_presses() helper
function, making the code needing this functionality both easier to read
and more correct.
The firmware of ESPRIMO Mobile M9410 has two video output devices that
have _BCM control method, one is the type of "External Digital Monitor"
while the other is the type of "Internal/Integrated Digital Flat Panel".
Only the 2nd video output device's _BCM control method works, but
since we have created two and the 1st one got picked up by user space,
the backlight functionality is broken. To solve this problem, only
register backlight interface for "Internal/Integrated Digital Flat Panel"
type video output device on this laptop.
Another problem of this laptop is that the IDs listed by the _DOD method
doesn't have bit 31 set, which means it doesn't follow the format
specified by ACPI spec. But the value indicates that it actually follows
that format so I've added a DMI quirk and a module level parameter to
force use the device_id_scheme so that we can get the video output
device's type to do the decision if we should register backlight
interface.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=104121
Suggested-by: Hans de Goede <hdegoede@redhat.com>
Reported-and-tested-by: Christian Scharl <zahlsum-kernelbugs@yahoo.de>
There is no need to carry potentially outdated Free Software Foundation
mailing address in file headers since the COPYING file includes it.
Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
acpi_video_unregister_backlight() is now only used by video_detect.c
which is part of the same acpi_video module as video.c, make
acpi_video_unregister_backlight() private to this module.
Acked-by: Darren Hart <dvhart@linux.intel.com>
It is possible for a native backlight driver to load while
acpi_video_register is running, which may lead to
acpi_video_unregister_backlight being called while acpi_video_register
is running and the 2 racing against eachother.
The register_count variable protects against this, but not in a thread
safe manner, this commit adds locking to make this thread safe.
When builtin there is no guarantee in which order module_init functions
are run, so acpi_video_register() may get called from the i915 driver
(if it is also builtin) before acpi_video_init() gets called, resulting
in the dmi quirks not yet being parsed.
This commit moves the dmi_check_system() call to acpi_video_register(),
so that we can be sure the dmi quirks have always been applied before
probing.
Move the unregistering of the acpi backlight interface on registering of a
native backlight from video.c to video_detect.c where it belongs.
Note this removes support for re-registering the acpi backlight interface
when the native interface goes away. In practice this never happens and
it needlessly complicates the code.
Most of the patch is moving the dmi quirks for forcing use of the
acpi-video / the native backlight interface to video_detect.c.
What remains is a nice cleanup.
This is a preparation patch for the backlight interface selection logic
cleanup, there are 2 reasons to not always build the video_detect code
into the kernel:
1) In order for the video_detect.c to also deal with / select native
backlight interfaces on win8 systems, instead of doing this in video.c
where it does not belong, video_detect.c needs to call into the backlight
class code. Which cannot be done if it is builtin and the blacklight class
is not.
2) Currently all the platform/x86 drivers which have quirks to prefer
the vendor driver over acpi-video call acpi_video_unregister_backlight()
to remove the acpi-video backlight interface, this logic really belongs
in video_detect.c, which will cause video_detect.c to depend on symbols of
video.c and video.c already depends on video_detect.c symbols, so they
really need to be a single module.
Note that this commits make 2 changes so as to maintain 100% kernel
commandline compatibility:
1) The __setup call for the acpi_backlight= handling is moved to
acpi/util.c as __setup may only be used by code which is alwasy builtin
2) video.c is renamed to acpi_video.c so that it can be combined with
video_detect.c into video.ko
This commit also makes changes to drivers/platform/x86/Kconfig to ensure
that drivers which use acpi_video_backlight_support() from video_detect.c,
will not be built-in when acpi_video is not built in. This also changes
some "select" uses to "depends on" to avoid dependency loops.
