path: root/drivers/acpi/apei/erst.c
2014-01-12Merge tag 'ras_for_3.14_p2' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/ras/ras into x86/ras Pull RAS updates from Borislav Petkov: " SCI reporting for other error types not only correctable ones + APEI GHES cleanups + mce timer fix " Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-12-21ACPI, APEI: Cleanup alignment-aware accessesChen, Gong
We do use memcpy to avoid access alignment issues between firmware and OS. Now we can use a better and standard way to avoid this issue. While at it, simplify some variable names to avoid the 80 cols limit and use structure assignment instead of unnecessary memcpy. No functional changes. Because ERST record id cache is implemented in memory to increase the access speed via caching ERST content we can refrain from using memcpy there too and use regular assignment instead. Signed-off-by: Chen, Gong <gong.chen@linux.intel.com> Cc: Cc: Tony Luck <tony.luck@intel.com> Link: http://lkml.kernel.org/r/1387348249-20014-1-git-send-email-gong.chen@linux.intel.com [ Boris: massage commit message a bit. ] Signed-off-by: Borislav Petkov <bp@suse.de>
2013-12-20pstore: Don't allow high traffic options on fragile devicesLuck, Tony
Some pstore backing devices use on board flash as persistent storage. These have limited numbers of write cycles so it is a poor idea to use them from high frequency operations. Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-04Merge branch 'x86-ras-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 RAS changes from Ingo Molnar: "[ The reason for drivers/ updates is that Boris asked for the drivers/edac/ changes to go via x86/ras in this cycle ] Main changes: - AMD CPUs: . Add ECC event decoding support for new F15h models . Various erratum fixes . Fix single-channel on dual-channel-controllers bug. - Intel CPUs: . UC uncorrectable memory error parsing fix . Add support for CMC (Corrected Machine Check) 'FF' (Firmware First) flag in the APEI HEST - Various cleanups and fixes" * 'x86-ras-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: amd64_edac: Fix incorrect wraparounds amd64_edac: Correct erratum 505 range cpc925_edac: Use proper array termination x86/mce, acpi/apei: Only disable banks listed in HEST if mce is configured amd64_edac: Get rid of boot_cpu_data accesses amd64_edac: Add ECC decoding support for newer F15h models x86, amd_nb: Clarify F15h, model 30h GART and L3 support pci_ids: Add PCI device ID functions 3 and 4 for newer F15h models. x38_edac: Make a local function static i3200_edac: Make a local function static x86/mce: Pay no attention to 'F' bit in MCACOD when parsing 'UC' errors APEI/ERST: Fix error message formatting amd64_edac: Fix single-channel setups EDAC: Replace strict_strtol() with kstrtol() mce: acpi/apei: Soft-offline a page on firmware GHES notification mce: acpi/apei: Add a boot option to disable ff mode for corrected errors mce: acpi/apei: Honour Firmware First for MCA banks listed in APEI HEST CMC
2013-08-19erst: Read and write to the 'compressed' flag of pstoreAruna Balakrishnaiah
In pstore write, set the section type to CPER_SECTION_TYPE_DMESG_COMPR if the data is compressed. In pstore read, read the section type and update the 'compressed' flag accordingly. Signed-off-by: Aruna Balakrishnaiah <aruna@linux.vnet.ibm.com> Reviewed-by: Kees Cook <keescook@chromium.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2013-08-19pstore: Introduce new argument 'compressed' in the read callbackAruna Balakrishnaiah
Backends will set the flag 'compressed' after reading the log from persistent store to indicate the data being returned to pstore is compressed or not. Signed-off-by: Aruna Balakrishnaiah <aruna@linux.vnet.ibm.com> Reviewed-by: Kees Cook <keescook@chromium.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2013-08-19pstore: Add new argument 'compressed' in pstore write callbackAruna Balakrishnaiah
Addition of new argument 'compressed' in the write call back will help the backend to know if the data passed from pstore is compressed or not (In case where compression fails.). If compressed, the backend can add a tag indicating the data is compressed while writing to persistent store. Signed-off-by: Aruna Balakrishnaiah <aruna@linux.vnet.ibm.com> Reviewed-by: Kees Cook <keescook@chromium.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2013-08-19acpi/apei/erst: Add missing iounmap() on error in erst_exec_move_data()Wei Yongjun
Add the missing iounmap() before return from erst_exec_move_data() in the error handling case. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Acked-by: Kees Cook <keescook@chromium.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2013-07-31APEI/ERST: Fix error message formattingBorislav Petkov
... according to acpi/apei/ conventions. Use standard pr_fmt prefix while at it. Signed-off-by: Borislav Petkov <bp@suse.de> Acked-by: Bjorn Helgaas <bhelgaas@google.com>
2013-07-04Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc updates from Ben Herrenschmidt: "This is the powerpc changes for the 3.11 merge window. In addition to the usual bug fixes and small updates, the main highlights are: - Support for transparent huge pages by Aneesh Kumar for 64-bit server processors. This allows the use of 16M pages as transparent huge pages on kernels compiled with a 64K base page size. - Base VFIO support for KVM on power by Alexey Kardashevskiy - Wiring up of our nvram to the pstore infrastructure, including putting compressed oopses in there by Aruna Balakrishnaiah - Move, rework and improve our "EEH" (basically PCI error handling and recovery) infrastructure. It is no longer specific to pseries but is now usable by the new "powernv" platform as well (no hypervisor) by Gavin Shan. - I fixed some bugs in our math-emu instruction decoding and made it usable to emulate some optional FP instructions on processors with hard FP that lack them (such as fsqrt on Freescale embedded processors). - Support for Power8 "Event Based Branch" facility by Michael Ellerman. This facility allows what is basically "userspace interrupts" for performance monitor events. - A bunch of Transactional Memory vs. Signals bug fixes and HW breakpoint/watchpoint fixes by Michael Neuling. And more ... I appologize in advance if I've failed to highlight something that somebody deemed worth it." * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (156 commits) pstore: Add hsize argument in write_buf call of pstore_ftrace_call powerpc/fsl: add MPIC timer wakeup support powerpc/mpic: create mpic subsystem object powerpc/mpic: add global timer support powerpc/mpic: add irq_set_wake support powerpc/85xx: enable coreint for all the 64bit boards powerpc/8xx: Erroneous double irq_eoi() on CPM IRQ in MPC8xx powerpc/fsl: Enable CONFIG_E1000E in mpc85xx_smp_defconfig powerpc/mpic: Add get_version API both for internal and external use powerpc: Handle both new style and old style reserve maps powerpc/hw_brk: Fix off by one error when validating DAWR region end powerpc/pseries: Support compression of oops text via pstore powerpc/pseries: Re-organise the oops compression code pstore: Pass header size in the pstore write callback powerpc/powernv: Fix iommu initialization again powerpc/pseries: Inform the hypervisor we are using EBB regs powerpc/perf: Add power8 EBB support powerpc/perf: Core EBB support for 64-bit book3s powerpc/perf: Drop MMCRA from thread_struct powerpc/perf: Don't enable if we have zero events ...
2013-07-01pstore: Pass header size in the pstore write callbackAruna Balakrishnaiah
Header size is needed to distinguish between header and the dump data. Incorporate the addition of new argument (hsize) in the pstore write callback. Signed-off-by: Aruna Balakrishnaiah <aruna@linux.vnet.ibm.com> Acked-by: Kees Cook <keescook@chromium.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-06-28acpi: Eliminate console msg if pstore.backend excludes ERSTLenny Szubowicz
This is patch 2/3 of a patch set that avoids what misleadingly appears to be a error during boot: ERST: Could not register with persistent store This message is displayed if the system has a valid ACPI ERST table and the pstore.backend kernel parameter has been used to disable use of ERST by pstore. But this same message is used for errors that preclude registration. In erst_init don't complain if the setting of kernel parameter pstore.backend precludes use of ACPI ERST for pstore. Routine pstore_register will inform about the facility that does register. Also, don't leave a dangling pointer to deallocated mem for the pstore buffer when registration fails. Signed-off-by: Lenny Szubowicz <lszubowi@redhat.com> Reported-by: Naotaka Hamaguchi <n.hamaguchi@jp.fujitsu.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2012-11-26efi_pstore: Add a sequence counter to a variable nameSeiji Aguchi
[Issue] Currently, a variable name, which identifies each entry, consists of type, id and ctime. But if multiple events happens in a short time, a second/third event may fail to log because efi_pstore can't distinguish each event with current variable name. [Solution] A reasonable way to identify all events precisely is introducing a sequence counter to the variable name. The sequence counter has already supported in a pstore layer with "oopscount". So, this patch adds it to a variable name. Also, it is passed to read/erase callbacks of platform drivers in accordance with the modification of the variable name. <before applying this patch> a variable name of first event: dump-type0-1-12345678 a variable name of second event: dump-type0-1-12345678 type:0 id:1 ctime:12345678 If multiple events happen in a short time, efi_pstore can't distinguish them because variable names are same among them. <after applying this patch> it can be distinguishable by adding a sequence counter as follows. a variable name of first event: dump-type0-1-1-12345678 a variable name of Second event: dump-type0-1-2-12345678 type:0 id:1 sequence counter: 1(first event), 2(second event) ctime:12345678 In case of a write callback executed in pstore_console_write(), "0" is added to an argument of the write callback because it just logs all kernel messages and doesn't need to care about multiple events. Signed-off-by: Seiji Aguchi <seiji.aguchi@hds.com> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Mike Waychison <mikew@google.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2012-11-26efi_pstore: Add ctime to argument of erase callbackSeiji Aguchi
[Issue] Currently, a variable name, which is used to identify each log entry, consists of type, id and ctime. But an erase callback does not use ctime. If efi_pstore supported just one log, type and id were enough. However, in case of supporting multiple logs, it doesn't work because it can't distinguish each entry without ctime at erasing time. <Example> As you can see below, efi_pstore can't differentiate first event from second one without ctime. a variable name of first event: dump-type0-1-12345678 a variable name of second event: dump-type0-1-23456789 type:0 id:1 ctime:12345678, 23456789 [Solution] This patch adds ctime to an argument of an erase callback. It works across reboots because ctime of pstore means the date that the record was originally stored. To do this, efi_pstore saves the ctime to variable name at writing time and passes it to pstore at reading time. Signed-off-by: Seiji Aguchi <seiji.aguchi@hds.com> Acked-by: Mike Waychison <mikew@google.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2012-03-30ACPI, APEI, Fix ERST header length checkJiang Liu
This fixes a trivial copy & paste error in ERST header length check. It's just for future safety because sizeof(struct acpi_table_einj) equals to sizeof(struct acpi_table_erst) with current ACPI5.0 specification. It applies to v3.3-rc6. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Acked-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-18Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux This includes initial support for the recently published ACPI 5.0 spec. In particular, support for the "hardware-reduced" bit that eliminates the dependency on legacy hardware. APEI has patches resulting from testing on real hardware. Plus other random fixes. * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: (52 commits) acpi/apei/einj: Add extensions to EINJ from rev 5.0 of acpi spec intel_idle: Split up and provide per CPU initialization func ACPI processor: Remove unneeded variable passed by acpi_processor_hotadd_init V2 ACPI processor: Remove unneeded cpuidle_unregister_driver call intel idle: Make idle driver more robust intel_idle: Fix a cast to pointer from integer of different size warning in intel_idle ACPI: kernel-parameters.txt : Add intel_idle.max_cstate intel_idle: remove redundant local_irq_disable() call ACPI processor: Fix error path, also remove sysdev link ACPI: processor: fix acpi_get_cpuid for UP processor intel_idle: fix API misuse ACPI APEI: Convert atomicio routines ACPI: Export interfaces for ioremapping/iounmapping ACPI registers ACPI: Fix possible alignment issues with GAS 'address' references ACPI, ia64: Use SRAT table rev to use 8bit or 16/32bit PXM fields (ia64) ACPI, x86: Use SRAT table rev to use 8bit or 32bit PXM fields (x86/x86-64) ACPI: Store SRAT table revision ACPI, APEI, Resolve false conflict between ACPI NVS and APEI ACPI, Record ACPI NVS regions ACPI, APEI, EINJ, Refine the fix of resource conflict ...
2012-01-17ACPI, APEI, Remove table not found messageHuang Ying
Because APEI tables are optional, these message may confuse users, for example, https://bugs.launchpad.net/ubuntu/+source/linux/+bug/599715 Reported-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-11-17pstore: pass reason to backend write callbackKees Cook
This allows a backend to filter on the dmesg reason as well as the pstore reason. When ramoops is switched to pstore, this is needed since it has no interest in storing non-crash dmesg details. Drop pstore_write() as it has no users, and handling the "reason" here has no obviously correct value. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-11-17pstore: pass allocated memory region back to callerKees Cook
The buf_lock cannot be held while populating the inodes, so make the backend pass forward an allocated and filled buffer instead. This solves the following backtrace. The effect is that "buf" is only ever used to notify the backends that something was written to it, and shouldn't be used in the read path. To replace the buf_lock during the read path, isolate the open/read/close loop with a separate mutex to maintain serialized access to the backend. Note that is is up to the pstore backend to cope if the (*write)() path is called in the middle of the read path. [ 59.691019] BUG: sleeping function called from invalid context at .../mm/slub.c:847 [ 59.691019] in_atomic(): 0, irqs_disabled(): 1, pid: 1819, name: mount [ 59.691019] Pid: 1819, comm: mount Not tainted 3.0.8 #1 [ 59.691019] Call Trace: [ 59.691019] [<810252d5>] __might_sleep+0xc3/0xca [ 59.691019] [<810a26e6>] kmem_cache_alloc+0x32/0xf3 [ 59.691019] [<810b53ac>] ? __d_lookup_rcu+0x6f/0xf4 [ 59.691019] [<810b68b1>] alloc_inode+0x2a/0x64 [ 59.691019] [<810b6903>] new_inode+0x18/0x43 [ 59.691019] [<81142447>] pstore_get_inode.isra.1+0x11/0x98 [ 59.691019] [<81142623>] pstore_mkfile+0xae/0x26f [ 59.691019] [<810a2a66>] ? kmem_cache_free+0x19/0xb1 [ 59.691019] [<8116c821>] ? ida_get_new_above+0x140/0x158 [ 59.691019] [<811708ea>] ? __init_rwsem+0x1e/0x2c [ 59.691019] [<810b67e8>] ? inode_init_always+0x111/0x1b0 [ 59.691019] [<8102127e>] ? should_resched+0xd/0x27 [ 59.691019] [<8137977f>] ? _cond_resched+0xd/0x21 [ 59.691019] [<81142abf>] pstore_get_records+0x52/0xa7 [ 59.691019] [<8114254b>] pstore_fill_super+0x7d/0x91 [ 59.691019] [<810a7ff5>] mount_single+0x46/0x82 [ 59.691019] [<8114231a>] pstore_mount+0x15/0x17 [ 59.691019] [<811424ce>] ? pstore_get_inode.isra.1+0x98/0x98 [ 59.691019] [<810a8199>] mount_fs+0x5a/0x12d [ 59.691019] [<810b9174>] ? alloc_vfsmnt+0xa4/0x14a [ 59.691019] [<810b9474>] vfs_kern_mount+0x4f/0x7d [ 59.691019] [<810b9d7e>] do_kern_mount+0x34/0xb2 [ 59.691019] [<810bb15f>] do_mount+0x5fc/0x64a [ 59.691019] [<810912fb>] ? strndup_user+0x2e/0x3f [ 59.691019] [<810bb3cb>] sys_mount+0x66/0x99 [ 59.691019] [<8137b537>] sysenter_do_call+0x12/0x26 Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-10-12pstore: make pstore write function return normal success/fail valueChen Gong
Currently pstore write interface employs record id as return value, but it is not enough because it can't tell caller if the write operation is successful. Pass the record id back via an argument pointer and return zero for success, non-zero for failure. Signed-off-by: Chen Gong <gong.chen@linux.intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-08-16pstore: change mutex locking to spin_locksDon Zickus
pstore was using mutex locking to protect read/write access to the backend plug-ins. This causes problems when pstore is executed in an NMI context through panic() -> kmsg_dump(). This patch changes the mutex to a spin_lock_irqsave then also checks to see if we are in an NMI context. If we are in an NMI and can't get the lock, just print a message stating that and blow by the locking. All this is probably a hack around the bigger locking problem but it solves my current situation of trying to sleep in an NMI context. Tested by loading the lkdtm module and executing a HARDLOCKUP which will cause the machine to panic inside the nmi handler. Signed-off-by: Don Zickus <dzickus@redhat.com> Acked-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-08-03Merge branch 'apei' into apei-releaseLen Brown
Some trivial conflicts due to other various merges adding to the end of common lists sooner than this one. arch/ia64/Kconfig arch/powerpc/Kconfig arch/x86/Kconfig lib/Kconfig lib/Makefile Signed-off-by: Len Brown <len.brown@intel.com>
2011-07-22pstore: Make "part" unsignedMatthew Garrett
We'll never have a negative part, so just make this an unsigned int. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-07-22pstore: Add extra context for writes and erasesMatthew Garrett
EFI only provides small amounts of individual storage, and conventionally puts metadata in the storage variable name. Rather than add a metadata header to the (already limited) variable storage, it's easier for us to modify pstore to pass all the information we need to construct a unique variable name to the appropriate functions. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-07-22pstore: Extend API for more flexibility in new backendsMatthew Garrett
Some pstore implementations may not have a static context, so extend the API to pass the pstore_info struct to all calls and allow for a context pointer. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-07-13ACPI, APEI, Use apei_exec_run_optional in APEI EINJ and ERSTHuang Ying
This patch changes APEI EINJ and ERST to use apei_exec_run for mandatory actions, and apei_exec_run_optional for optional actions. Cc: Thomas Renninger <trenn@novell.com> Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-05-16pstore: fix potential logic issue in pstore read interfaceChen Gong
1) in the calling of erst_read, the parameter of buffer size maybe overflows and cause crash 2) the return value of erst_read should be checked more strictly Signed-off-by: Chen Gong <gong.chen@linux.intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-05-16pstore: fix pstore filesystem mount/remount issueChen Gong
Currently after mount/remount operation on pstore filesystem, the content on pstore will be lost. It is because current ERST implementation doesn't support multi-user usage, which moves internal pointer to the end after accessing it. Adding multi-user support for pstore usage. Signed-off-by: Chen Gong <gong.chen@linux.intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-05-16pstore: fix one type of return value in pstoreChen Gong
the return type of function _read_ in pstore is size_t, but in the callback function of _read_, the logic doesn't consider it too much, which means if negative value (assuming error here) is returned, it will be converted to positive because of type casting. ssize_t is enough for this function. Signed-off-by: Chen Gong <gong.chen@linux.intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-03-23Merge branch 'linus' into releaseLen Brown
Conflicts: arch/x86/kernel/acpi/sleep.c Signed-off-by: Len Brown <len.brown@intel.com>
2011-03-21ACPI, APEI, Add ERST record ID cacheHuang Ying
APEI ERST firmware interface and implementation has no multiple users in mind. For example, if there is four records in storage with ID: 1, 2, 3 and 4, if two ERST readers enumerate the records via GET_NEXT_RECORD_ID as follow, reader 1 reader 2 1 2 3 4 -1 -1 where -1 signals there is no more record ID. Reader 1 has no chance to check record 2 and 4, while reader 2 has no chance to check record 1 and 3. And any other GET_NEXT_RECORD_ID will return -1, that is, other readers will has no chance to check any record even they are not cleared by anyone. This makes raw GET_NEXT_RECORD_ID not suitable for used by multiple users. To solve the issue, an in-memory ERST record ID cache is designed and implemented. When enumerating record ID, the ID returned by GET_NEXT_RECORD_ID is added into cache in addition to be returned to caller. So other readers can check the cache to get all record ID available. Signed-off-by: Huang Ying <ying.huang@intel.com> Reviewed-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-03-16Pull pstorev4 into release branchTony Luck
2011-01-03pstore: X86 platform interface using ACPI/APEI/ERSTTony Luck
The 'error record serialization table' in ACPI provides a suitable amount of persistent storage for use by the pstore filesystem. Signed-off-by: Tony Luck <tony.luck@intel.com>
2011-01-03Fix spelling mistakes in commentsStefan Weil
milisecond -> millisecond meassge -> message Cc: Kalle Valo <kvalo@adurom.com> Cc: Jiri Kosina <trivial@kernel.org> Cc: linux-kernel@vger.kernel.org Signed-off-by: Stefan Weil <weil@mail.berlios.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-12-11ACPI, APEI, use raw spinlock in ERSTHuang Ying
ERST writing may be used in NMI or Machine Check Exception handler. So it need to use raw spinlock instead of normal spinlock. This patch fixes it. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-09-29Merge branches 'apei', 'battery-mwh-fix', 'bugzilla-10807', ↵Len Brown
'bugzilla-14736', 'bugzilla-14679', 'bugzilla-16396', 'launchpad-613381' and 'misc' into release
2010-09-29ACPI, APEI, Fix ERST MOVE_DATA instruction implementationHuang Ying
The src_base and dst_base fields in apei_exec_context are physical address, so they should be ioremaped before being used in ERST MOVE_DATA instruction. Reported-by: Javier Martinez Canillas <martinez.javier@gmail.com> Reported-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-09-29ACPI, APEI, Fix APEI related table size checkingHuang Ying
On Huang Ying's machine: erst_tab->header_length == sizeof(struct acpi_table_einj) but Yinghai reported that on his machine, erst_tab->header_length == sizeof(struct acpi_table_einj) - sizeof(struct acpi_table_header) To make erst table size checking code works on all systems, both testing are treated as PASS. Same situation applies to einj_tab->header_length, so corresponding table size checking is changed in similar way too. v2: - Treat both table size as valid Originally-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-09-28ACPI: Fix typosLucas De Marchi
2010-08-12acpi: fix bogus preemption logicThomas Gleixner
The ACPI_PREEMPTION_POINT() logic was introduced in commit 8bd108d (ACPICA: add preemption point after each opcode parse). The follow up commits abe1dfab6, 138d15692, c084ca70 tried to fix the preemption logic back and forth, but nobody noticed that the usage of in_atomic_preempt_off() in that context is wrong. The check which guards the call of cond_resched() is: if (!in_atomic_preempt_off() && !irqs_disabled()) in_atomic_preempt_off() is not intended for general use as the comment above the macro definition clearly says: * Check whether we were atomic before we did preempt_disable(): * (used by the scheduler, *after* releasing the kernel lock) On a CONFIG_PREEMPT=n kernel the usage of in_atomic_preempt_off() works by accident, but with CONFIG_PREEMPT=y it's just broken. The whole purpose of the ACPI_PREEMPTION_POINT() is to reduce the latency on a CONFIG_PREEMPT=n kernel, so make ACPI_PREEMPTION_POINT() depend on CONFIG_PREEMPT=n and remove the in_atomic_preempt_off() check. Addresses https://bugzilla.kernel.org/show_bug.cgi?id=16210 [akpm@linux-foundation.org: fix build] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Len Brown <lenb@kernel.org> Cc: Francois Valenduc <francois.valenduc@tvcablenet.be> Cc: Lin Ming <ming.m.lin@intel.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-07-01correct console log level when ERST ACPI table is not foundDaniel J Blueman
When booting 2.6.35-rc3 on a x86 system without an ERST ACPI table with the 'quiet' option, we still observe an "ERST: Table is not found!" warning. Quiesce it to the same info log level as the other 'table not found' warnings. Signed-off-by: Daniel J Blueman <daniel.blueman@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-19ACPI, APEI, Error Record Serialization Table (ERST) supportHuang Ying
ERST is a way provided by APEI to save and retrieve hardware error record to and from some simple persistent storage (such as flash). The Linux kernel support implementation is quite simple and workable in NMI context. So it can be used to save hardware error record into flash in hardware error exception or NMI handler, where other more complex persistent storage such as disk is not usable. After saving hardware error records via ERST in hardware error exception or NMI handler, the error records can be retrieved and logged into disk or network after a clean reboot. For more information about ERST, please refer to ACPI Specification version 4.0, section 17.4. This patch incorporate fixes from Jin Dongming. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> CC: Jin Dongming <jin.dongming@np.css.fujitsu.com> Signed-off-by: Len Brown <len.brown@intel.com>
