path: root/drivers/acpi/osi.c
2019-05-30treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 157Thomas Gleixner
Based on 3 normalized pattern(s): this program is free software you can redistribute it and or modify it under the terms of the gnu general public license as published by the free software foundation either version 2 of the license or at your option any later version this program is distributed in the hope that it will be useful but without any warranty without even the implied warranty of merchantability or fitness for a particular purpose see the gnu general public license for more details this program is free software you can redistribute it and or modify it under the terms of the gnu general public license as published by the free software foundation either version 2 of the license or at your option any later version [author] [kishon] [vijay] [abraham] [i] [kishon]@[ti] [com] this program is distributed in the hope that it will be useful but without any warranty without even the implied warranty of merchantability or fitness for a particular purpose see the gnu general public license for more details this program is free software you can redistribute it and or modify it under the terms of the gnu general public license as published by the free software foundation either version 2 of the license or at your option any later version [author] [graeme] [gregory] [gg]@[slimlogic] [co] [uk] [author] [kishon] [vijay] [abraham] [i] [kishon]@[ti] [com] [based] [on] [twl6030]_[usb] [c] [author] [hema] [hk] [hemahk]@[ti] [com] this program is distributed in the hope that it will be useful but without any warranty without even the implied warranty of merchantability or fitness for a particular purpose see the gnu general public license for more details extracted by the scancode license scanner the SPDX license identifier GPL-2.0-or-later has been chosen to replace the boilerplate/reference in 1105 file(s). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Allison Randal <allison@lohutok.net> Reviewed-by: Richard Fontana <rfontana@redhat.com> Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Cc: linux-spdx@vger.kernel.org Link: https://lkml.kernel.org/r/20190527070033.202006027@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-12-18ACPI / OSI: Add OEM _OSI string to enable dGPU direct outputAlex Hung
For HP Inc. mobile workstation with hybrid graphics support, dGPU can directly output to external monitors; however, Nvidia and AMD's Linux drivers aren't able to support this feature. The OEM _OSI string "Linux-HPI-Hybrid-Graphics" is used by BIOS to implement dGPU direct output to external monitors. The form of the OEM _OSI strings is defined by each OEMs and is discussed in Documentation/acpi/osi.txt. Signed-off-by: Alex Hung <alex.hung@canonical.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2018-07-20ACPI / OSI: Add OEM _OSI string to enable NVidia HDMI audioAlex Hung
Some ThinkPad systems have a power-saving feature that turns off HDMI audio device in Windows, but NVidia Linux driver does not support this feature. As a result, HDMI audio will not work on Linux. A BIOS workaround is added with an OEM_OSI string "Linux-Lenovo-NV-HDMI-Audio" to power on NVidia HDMI audio when booting. The form of the OEM _OSI strings is defined by each OEMs and is discussed in Documentation/acpi/osi.txt. Signed-off-by: Alex Hung <alex.hung@canonical.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2018-03-18ACPI / OSI: Add OEM _OSI strings to disable NVidia RTD3Alex Hung
A number of Dell systems require an OEM _OSI string "Linux-Dell-Video" as a BIOS workaround to disable RTD3 which causes systems hangs when NVidia graphics cards are installed. The affected Dell systems are with system IDs: 0818, 0819, 0820, 0850, 0851, 086F, 0870, 0885 and 0886. The form of the OEM _OSI strings is defined by each OEMs and is discussed in Documentation/acpi/osi.txt. Signed-off-by: Alex Hung <alex.hung@canonical.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2017-09-14dmi: Mark all struct dmi_system_id instances constChristoph Hellwig
... and __initconst if applicable. Based on similar work for an older kernel in the Grsecurity patch. [JD: fix toshiba-wmi build] [JD: add htcpen] [JD: move __initconst where checkscript wants it] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jean Delvare <jdelvare@suse.de>
2017-08-03treewide: Consolidate Apple DMI checksLukas Wunner
We're about to amend ACPI bus scan with DMI checks whether we're running on a Mac to support Apple device properties in AML. The DMI checks are performed for every single device, adding overhead for everything x86 that isn't Apple, which is the majority. Rafael and Andy therefore request to perform the DMI match only once and cache the result. Outside of ACPI various other Apple DMI checks exist and it seems reasonable to use the cached value there as well. Rafael, Andy and Darren suggest performing the DMI check in arch code and making it available with a header in include/linux/platform_data/x86/. To this end, add early_platform_quirks() to arch/x86/kernel/quirks.c to perform the DMI check and invoke it from setup_arch(). Switch over all existing Apple DMI checks, thereby fixing two deficiencies: * They are now #defined to false on non-x86 arches and can thus be optimized away if they're located in cross-arch code. * Some of them only match "Apple Inc." but not "Apple Computer, Inc.", which is used by BIOSes released between January 2006 (when the first x86 Macs started shipping) and January 2007 (when the company name changed upon introduction of the iPhone). Suggested-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Suggested-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Suggested-by: Darren Hart <dvhart@infradead.org> Signed-off-by: Lukas Wunner <lukas@wunner.de> Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2017-07-04ACPI / osi: Make local function acpi_osi_dmi_linux() staticColin Ian King
The function acpi_osi_dmi_linux() is local and does not need to be in global scope, so make it static. Cleans up sparse warning: "symbol 'acpi_osi_dmi_linux' was not declared. Should it be static?" Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-05-05ACPI / osi: Collect _OSI handling into one single fileLv Zheng
_OSI handling code grows giant and it's time to move them into one file. This patch collects all _OSI handling code into one single file. So that we only have the following functions to be used externally: early_acpi_osi_init(): Used by DMI detections; acpi_osi_init(): Used to initialize OSI command line settings and install Linux specific _OSI handler; acpi_osi_setup(): The API that should be used by the external quirks. acpi_osi_is_win8(): The API is used by the external drivers to determine if BIOS supports Win8. CONFIG_DMI is not useful as stub dmi_check_system() can make everything stub because of strip. No functional changes. Tested-by: Lukas Wunner <lukas@wunner.de> Tested-by: Chen Yu <yu.c.chen@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
