commit d640113fe80e45ebd4a5b420b220d3f6bf37f682 upstream.
For UP processor, it is likely that no _MAT method or MADT table defined.
So currently acpi_get_cpuid(...) always return -1 for UP processor.
This is wrong. It should return valid value for CPU0.
In the other hand, BIOS may define multiple CPU handles even for UP
processor, for example
Scope (_PR)
Processor (CPU0, 0x00, 0x00000410, 0x06) {}
Processor (CPU1, 0x01, 0x00000410, 0x06) {}
Processor (CPU2, 0x02, 0x00000410, 0x06) {}
Processor (CPU3, 0x03, 0x00000410, 0x06) {}
We should only return valid value for CPU0's acpi handle.
And return invalid value for others.
http://marc.info/?t=132329819900003&r=1&w=2
Reported-and-tested-by: wallak@free.fr
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
Signed-off-by: Len Brown <len.brown@intel.com>
Usually, there are multiple processors defined in ACPI table, for
example
Scope (_PR)
processor_physically_present(...) will be called to check whether those
processors are physically present.
Currently we have below codes in processor_physically_present,
cpuid = acpi_get_cpuid(...);
if ((cpuid == -1) && (num_possible_cpus() > 1))
return false;
return true;
In UP kernel, acpi_get_cpuid(...) always return -1 and
num_possible_cpus() always return 1, so
processor_physically_present(...) always returns true for all passed in
processor handles.
This is wrong for UP processor or SMP processor running UP kernel.
This patch removes the !SMP version of acpi_get_cpuid(), so both UP and
SMP kernel use the same acpi_get_cpuid function.
And for UP kernel, only processor 0 is valid.
https://bugzilla.kernel.org/show_bug.cgi?id=16548
https://bugzilla.kernel.org/show_bug.cgi?id=16357
Tested-by: Anton Kochkov <anton.kochkov@gmail.com>
Tested-by: Ambroz Bizjak <ambrop7@gmail.com>
Once acpi_map_lsapic() in ia64 follows how x86 treats it wrt section
placement, the whole tree from acpi_processor_set_pdc() can become
__cpuinit.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Acked-by: Tony Luck <tony.luck@intel.com>
Use __init for several functions, remove an unnecessary export and a
stray use of __ref.
Having four variables for the same thing:
idle_halt, idle_nomwait, force_mwait and boot_option_idle_overrides
is rather confusing and unnecessary complex.
if idle= boot param is passed, only set up one variable:
Introduces following functional changes/fixes:
- intel_idle driver does not register if any idle=xy
boot param is passed.
- processor_idle.c will also not register a cpuidle driver
and get active if idle=halt is passed.
Before a cpuidle driver with one (C1, halt) state got registered
Now the default_idle function will be used which finally uses
the same idle call to enter sleep state (safe_halt()), but
without registering a whole cpuidle driver.
That means idle= param will always avoid cpuidle drivers to register
with one exception (same behavior as before):
idle=nomwait
may still register acpi_idle cpuidle driver, but C1 will not use
mwait, but hlt. This can be a workaround for IO based deeper sleep
states where C1 mwait causes problems.
Signed-off-by: Thomas Renninger <trenn@suse.de>
cc: x86@kernel.org
After
| commit d8191fa4a33fdc817277da4f2b7f771ff605a41c
| Author: Alex Chiang <achiang@hp.com>
| Date: Mon Feb 22 12:11:39 2010 -0700
| ACPI: processor: driver doesn't need to evaluate _PDC
| Now that the early _PDC evaluation path knows how to correctly
| evaluate _PDC on only physically present processors, there's no
| need for the processor driver to evaluate it later when it loads.
| To cover the hotplug case, push _PDC evaluation down into the
| hotplug paths.
only cpu with Processor Statement get processed with _PDC
If bios is using Device object instead of Processor statement.
SSDTs for Pstate/Cstate/Tstate can not be loaded dynamically.
Need to try to scan ACPI0007 in addition to Processor.
That commit is between 2.6.34-rc1 and 2.6.34-rc2, so stable tree for 2.6.34+
need this patch.
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Reviewed-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
per comments in the bug report, this entry
seems to hurt at much as it helps.
https://bugzilla.kernel.org/show_bug.cgi?id=10807
The commit 5d554a7bb06 (ACPI: processor: add internal
processor_physically_present()) is broken on uniprocessor (UP)
configurations, as acpi_get_cpuid() will always return -1.
We use the value of num_possible_cpus() to tell us whether we got
an invalid cpuid from acpi_get_cpuid() in the SMP case, or if
instead, we are UP, in which case num_possible_cpus() is #defined
as 1.
We use num_possible_cpus() instead of num_online_cpus() to
protect ourselves against the scenario of CPU hotplug, and we've
taken down all the CPUs except one.
Thanks to Jan Pogadl for initial report and analysis and Chen
Gong for review.
Reported-by: Jan Pogadl <pogadl.jan@googlemail.com>:
Reviewed-by: Chen Gong <gong.chen@linux.intel.com>
Signed-off-by: Alex Chiang <achiang@canonical.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
There's no real need for a pointer to the MADT to be global. The only
function who uses it is map_madt_entry.
This allows us to remove some more ugly #ifdefs.
Acked-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Signed-off-by: Alex Chiang <achiang@hp.com>
Un-nest the if statements for readability.
Remove comments that re-state the obvious.
Change the control flow so that we no longer need a temp variable.
Untangle the nested if conditions to make this function look
more similar to the other map_*apic_id() functions.
Untangle the if() statement a little for readability.
hotplug paths.
Cc: x86@kernel.org
Now that we check for physically present processors before blindly
evaluating _PDC, we no longer need to maintain a DMI opt-in table
nor a kernel param.
Detect if a processor is physically present before evaluating _PDC.
We want this because some BIOS will provide a _PDC even for processors
that are not present. These bogus _PDC methods then attempt to load
non-existent tables, which causes problems.
Avoid those bogus landmines.
Enumerating processors (via MADT/_MAT) belongs in the processor core,
which is always built-in, rather than living in the processor driver
which may not be built.
We've renamed the old processor_core.c to processor_driver.c, to
convey the idea that it can be built modular and has driver-like
bits.
Now let's re-create a processor_core.c for the bits needed
statically by the rest of the kernel. The contents of processor_pdc.c
are a good starting spot, so let's just rename that file and
complete our three card monte.
The ACPI processor driver can be built as a module. But it has
pieces of code that should always be built statically into the
kernel.
The plan is for processor_core.c to contain the static bits while
processor_driver.c contains the module-like bits.
Since the bulk of the code in the current processor_core.c is
module-like, first step is to rename the file to processor_driver.c
Next step will re-create processor_core.c and cherry-pick out
the static bits.
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq:
[CPUFREQ] Fix cast warning in pcc driver.
[CPUFREQ] Processor Clocking Control interface driver
Processor Clocking Control (PCC) is an interface between the BIOS and OSPM.
Based on the server workload, OSPM can request what frequency it expects
from a logical CPU, and the BIOS will achieve that frequency transparently.
This patch introduces driver support for PCC. OSPM uses the PCC driver to
communicate with the BIOS via the PCC interface.
There is a Documentation file that provides a link to the PCC
Specification, and also provides a summary of the PCC interface.
Currently, certain HP ProLiant platforms implement the PCC interface. However,
any platform whose BIOS implements the PCC Specification, can utilize this
driver.
V2 --> V1 changes (based on Dominik's suggestions):
- Removed the dependency on CPU_FREQ_TABLE
- "cpufreq_stats" will no longer PANIC. Actually, it will not load anymore
because it is not applicable.
- Removed the sanity check for target frequency in the ->target routine.
NOTE: A patch to sanitize the target frequency requested by "ondemand" is
needed to ensure that the target freq < policy->min.
Can this driver be queued up for the 2.6.33 tree?
Signed-off-by: Naga Chumbalkar <nagananda.chumbalkar@hp.com>
Signed-off-by: Dave Jones <davej@redhat.com>
When calling _PDC, we really only need the handle to the processor
to call the method; we don't look at any other parts of the
struct acpi_processor * given to us.
In the early path, when we walk the namespace, we are given the
handle directly, so just pass it through to acpi_processor_set_pdc()
without stuffing it into a wasteful struct acpi_processor allocated
on the stack each time
This saves 2834 bytes of stack.
Update the interface accordingly.
We discovered that at least one machine (HP Envy), methods in the DSDT
attempt to call external methods defined in a dynamically loaded SSDT.
Unfortunately, the DSDT methods we are trying to call are part of the
EC initialization, which happens very early, and the the dynamic SSDT
is only loaded when a processor _PDC method runs much later.
This results in namespace lookup errors for the (as of yet) undefined
methods.
Since Windows doesn't have any issues with this machine, we take it
as a hint that they must be evaluating _PDC much earlier than we are.
Thus, the proper thing for Linux to do should be to match the Windows
implementation more closely.
Provide a mechanism to call _PDC before we enable the EC. Doing so loads
the dynamic tables, and allows the EC to be enabled correctly.
The ACPI processor driver will still evaluate _PDC in its .add() method
to cover the hotplug case.
Resolves: http://bugzilla.kernel.org/show_bug.cgi?id=14824
Cc: ming.m.lin@intel.com
Due to the merge of processor_start() (declared with __cpuinit) into
processor_add(), a section mismatch warning appears:
WARNING: drivers/built-in.o(.text+0x4d59d): Section mismatch in reference
from the function acpi_processor_add() to the function
.cpuinit.text:acpi_processor_power_init()
This patch fixes the warning by declaring processor_add() as __cpuinit
and also declares acpi_processor_add_fs() as __cpuinit as it is only
used in acpi_processor_add().
include/acpi/processor.h
This message shows up for each cpu. Print as debug messages.
[ 12.893967] processor ACPI0007:00: registered as cooling_device0
[ 12.907838] processor ACPI0007:01: registered as cooling_device1
Signed-off-by: Mike Travis <travis@sgi.com>
Cc: linux-acpi@vger.kernel.org
The existing interface only has a pre-order callback. This change
adds an additional parameter for a post-order callback which will
be more useful for bus scans. ACPICA BZ 779.
Also update the external calls to acpi_walk_namespace.
http://www.acpica.org/bugzilla/show_bug.cgi?id=779
Signed-off-by: Bob Moore <robert.moore@intel.com>
According to the ACPI spec(section 8.4.4.3) OSPM should convey the _PPC
evaluations status to the platform if there exists the _OST object.
The _OST contains two arguments:
The first is the PERFORMANCE notificatin event.
The second is the status of _PPC object.
OSPM will convey the _PPC evaluation status to the platform.
Of course when the module parameter of "ignore_ppc" is added, OSPM won't
evaluate the _PPC object. But it will call the _OST object.
At the same time the _OST object will be evaluated only when the PERFORMANCE
notification event is received.
Signed-off-by: Zhao Yakui <yakui.zhao@intel.com>
Annote acpi_processor_add with cpuinit since it calls a cpuinit function
acpi_processor_power_init and fixes a section mismatch warning.
We were warned by the following warning:
LD drivers/acpi/processor.o
WARNING: drivers/acpi/processor.o(.text+0x1829): Section mismatch in
reference from the function acpi_processor_add() to the function
The function acpi_processor_add() references
the function __cpuinit acpi_processor_power_init().
This is often because acpi_processor_add lacks a __cpuinit
annotation or the annotation of acpi_processor_power_init is wrong.
Signed-off-by: Rakib Mullick <rakib.mullick@gmail.com>
I was recently lucky enough to get a 64-CPU system. The processors
actually have T-states, so my kernel log ends up with 64 lines like:
ACPI: Processor [CPU0] (supports xx throttling states)
This is pretty useless clutter because
- this info is already available after boot from
/proc/acpi/processor/CPUnn/throttling
- there's also an ACPI_DEBUG_PRINT() in processor_throttling.c that
gives the same info on boot for anyone who *really* cares.
So just delete the code that prints the throttling states in
processor_core.c.
Signed-off-by: Roland Dreier <rolandd@cisco.com>
Linux/ACPI core files using internal.h all PREFIX "ACPI: ",
however, not all ACPI drivers use/want it -- and they
should not have to #undef PREFIX to define their own.
Add GPL commment to internal.h while we are there.
This does not change any actual console output,
asside from a whitespace fix.
Jens reported early_ioremap messages with old ASUS board...
> [ 1.507461] pci 0000:00:09.0: Firmware left e100 interrupts enabled; disabling
> [ 1.532778] early_ioremap(3fffd080, 0000005c) [0] => Pid: 1, comm: swapper Not tainted 2.6.31-rc4 #36
> [ 1.561007] Call Trace:
> [ 1.568638] [<c136e48b>] ? printk+0x18/0x1d
> [ 1.581734] [<c15513ff>] __early_ioremap+0x74/0x1e9
> [ 1.596898] [<c15515aa>] early_ioremap+0x1a/0x1c
> [ 1.611270] [<c154a187>] __acpi_map_table+0x18/0x1a
> [ 1.626451] [<c135a7f8>] acpi_os_map_memory+0x1d/0x25
> [ 1.642129] [<c119459c>] acpi_tb_verify_table+0x20/0x49
> [ 1.658321] [<c1193e50>] acpi_get_table_with_size+0x53/0xa1
> [ 1.675553] [<c1193eae>] acpi_get_table+0x10/0x15
> [ 1.690192] [<c155cc19>] acpi_processor_init+0x23/0xab
> [ 1.706126] [<c1001043>] do_one_initcall+0x33/0x180
> [ 1.721279] [<c155cbf6>] ? acpi_processor_init+0x0/0xab
> [ 1.737479] [<c106893a>] ? register_irq_proc+0xaa/0xc0
> [ 1.753411] [<c10689b7>] ? init_irq_proc+0x67/0x80
> [ 1.768316] [<c15405e7>] kernel_init+0x120/0x176
> [ 1.782678] [<c15404c7>] ? kernel_init+0x0/0x176
> [ 1.797062] [<c10038b7>] kernel_thread_helper+0x7/0x10
> [ 1.812984] 00000080 + ffe00000
that is rather later.
acpi_gbl_permanent_mmap should be set in acpi_early_init()
if acpi is not disabled
and we have
> [ 0.000000] ASUS P2B-DS detected: force use of acpi=ht
just don't load acpi_processor_init...
Reported-and-tested-by: Jens Rosenboom <jens@leia.mcbone.net>
Cc: Len Brown <lenb@kernel.org>
This patch folds the .start() method into .add().
acpi_processor_start() is always called immediately after
acpi_processor_add(), so there's really no point in having them be
separate methods.
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Reviewed-by: Alex Chiang <achiang@hp.com>
CC: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
CC: Zhao Yakui <yakui.zhao@intel.com>
Move acpi_processor_start() to just after acpi_processor_add().
A subsequent patch will merge them.
Code movement only; no functional change.
We used to leave crud around if things failed in acpi_processor_start().
This patch cleans up as much as we can before returning.
This patch removes the KOBJ_ONLINE/KOBJ_OFFLINE events the driver used
to generate for CPU hotplug. As far as I know, nobody consumes these.
The driver core still generates KOBJ_ADD and KOBJ_REMOVE, of course.
CC: Matthew Garrett <mjg@redhat.com>
CC: Thomas Renninger <trenn@suse.de>
CC: Dave Jones <davej@codemonkey.org.uk>
CC: Kay Sievers <kay.sievers@vrfy.org>
CC: Greg Kroah-Hartman <gregkh@suse.de>
'bugzilla-12904', 'bugzilla-13121', 'bugzilla-13396', 'bugzilla-13533', 'bugzilla-13612', 'c3_lock', 'hid-cleanups', 'misc-2.6.31', 'pdc-leak-fix', 'pnpacpi', 'power_nocheck', 'thinkpad_acpi', 'video' and 'wmi' into release
Some BIOS re-use the same processor bus id
in different scope:
\_SB.SCK0.CPU0
\_SB.SCK1.CPU0
But the (deprecated) /proc/acpi/ interface
assumes the bus-id's are unique, resulting in an OOPS
when the processor driver is loaded:
WARNING: at fs/proc/generic.c:590 proc_register+0x148/0x180()
Hardware name: Sunrise Ridge
proc_dir_entry 'processor/CPU0' already registered
Call Trace:
[<ffffffff8023f7ef>] warn_slowpath+0xb1/0xe5
[<ffffffff8036243b>] ? ida_get_new_above+0x190/0x1b1
[<ffffffff803625a8>] ? idr_pre_get+0x5f/0x75
[<ffffffff8030b2f6>] proc_register+0x148/0x180
[<ffffffff8030b4ff>] proc_mkdir_mode+0x3d/0x52
[<ffffffff8030b525>] proc_mkdir+0x11/0x13
[<ffffffffa0014b89>] acpi_processor_start+0x755/0x9bc [processor]
Rename the processor device bus id. And the new bus id will be
generated as the following format:
CPU+ CPU ID
For example: If the cpu ID is 5, then the bus ID will be "CPU5".
If the CPU ID is 10, then the bus ID will be "CPUA".
Yes, this will change the directory names seen
in /proc/acpi/processor/* on some systems.
Before this patch, those directory names where
totally arbitrary strings based on the interal AML device strings.
http://bugzilla.kernel.org/show_bug.cgi?id=13612
Now whether the ACPI processor proc I/F is registered depends on the
CONFIG_PROC. It had better depend on the CONFIG_ACPI_PROCFS.
When the CONFIG_ACPI_PROCFS is unset in kernel configuration, the
ACPI processor proc I/F won't be registered.
arch_acpi_processor_cleanup_pdc() in x86 and ia64 results in memory allocated
for _PDC objects that is never freed and will cause memory leak in case of
physical CPU remove and add. Patch fixes the memory leak by freeing the
objects soon after _PDC is evaluated.
Reported-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
These are defined as static cpumask_var_t so if MAXSMP is not used,
they are cleared already. Avoid surprises when MAXSMP is enabled.
Signed-off-by: Yinghai Lu <yinghai.lu@kernel.org>
The ACPI0007 _HID used for processor "Device" objects in the namespace
is not needed outside the processor driver, so move it there. Also, the
#define is only used once, so just remove it and hard-code "ACPI0007".
This patch inverts the logic that distinguishes "Processor" statements
from "Device" statements, so we now check explicitly for "Processor" and
default to "Device". This removes the only real use of ACPI_PROCESSOR_HID,
so we can then remove the #define. It also has the theoretical advantage
that if a new processor _HID were ever added, we wouldn't have to change
the code here.
This patch adds a .notify() method. The presence of .notify() causes
Linux/ACPI to manage event handlers and notify handlers on our behalf,
so we don't have to install and remove them ourselves.
CC: Zhang Rui <rui.zhang@intel.com>
CC: Venki Pallipadi <venkatesh.pallipadi@intel.com>
CC: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com>
arch/x86/kernel/cpu/cpufreq/longhaul.c
All logical processors with APIC ID values of 255 and greater will have their
APIC reported through Processor X2APIC structure (type-9 entry type) and all
logical processors with APIC ID less than 255 will have their APIC reported
through legacy Processor Local APIC (type-0 entry type) only. This is the
same case even for NMI structure reporting.
The Processor X2APIC Affinity structure provides the association between the
X2APIC ID of a logical processor and the proximity domain to which the logical
processor belongs.
For OSPM, Procssor IDs outside the 0-254 range are to be declared as Device()
objects in the ACPI namespace.
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
