commit 64a32307b710c100beb101e9c78f8022f0e8ba61 upstream.
per comments in the bug report, this entry
seems to hurt at much as it helps.
https://bugzilla.kernel.org/show_bug.cgi?id=10807
Signed-off-by: Len Brown <len.brown@intel.com>
Annote acpi_processor_add with cpuinit since it calls a cpuinit function
acpi_processor_power_init and fixes a section mismatch warning.
We were warned by the following warning:
LD drivers/acpi/processor.o
WARNING: drivers/acpi/processor.o(.text+0x1829): Section mismatch in
reference from the function acpi_processor_add() to the function
.cpuinit.text:acpi_processor_power_init()
The function acpi_processor_add() references
the function __cpuinit acpi_processor_power_init().
This is often because acpi_processor_add lacks a __cpuinit
annotation or the annotation of acpi_processor_power_init is wrong.
Signed-off-by: Rakib Mullick <rakib.mullick@gmail.com>
I was recently lucky enough to get a 64-CPU system. The processors
actually have T-states, so my kernel log ends up with 64 lines like:
ACPI: Processor [CPU0] (supports xx throttling states)
This is pretty useless clutter because
- this info is already available after boot from
/proc/acpi/processor/CPUnn/throttling
- there's also an ACPI_DEBUG_PRINT() in processor_throttling.c that
gives the same info on boot for anyone who *really* cares.
So just delete the code that prints the throttling states in
processor_core.c.
Signed-off-by: Roland Dreier <rolandd@cisco.com>
Linux/ACPI core files using internal.h all PREFIX "ACPI: ",
however, not all ACPI drivers use/want it -- and they
should not have to #undef PREFIX to define their own.
Add GPL commment to internal.h while we are there.
This does not change any actual console output,
asside from a whitespace fix.
Jens reported early_ioremap messages with old ASUS board...
> [ 1.507461] pci 0000:00:09.0: Firmware left e100 interrupts enabled; disabling
> [ 1.532778] early_ioremap(3fffd080, 0000005c) [0] => Pid: 1, comm: swapper Not tainted 2.6.31-rc4 #36
> [ 1.561007] Call Trace:
> [ 1.568638] [<c136e48b>] ? printk+0x18/0x1d
> [ 1.581734] [<c15513ff>] __early_ioremap+0x74/0x1e9
> [ 1.596898] [<c15515aa>] early_ioremap+0x1a/0x1c
> [ 1.611270] [<c154a187>] __acpi_map_table+0x18/0x1a
> [ 1.626451] [<c135a7f8>] acpi_os_map_memory+0x1d/0x25
> [ 1.642129] [<c119459c>] acpi_tb_verify_table+0x20/0x49
> [ 1.658321] [<c1193e50>] acpi_get_table_with_size+0x53/0xa1
> [ 1.675553] [<c1193eae>] acpi_get_table+0x10/0x15
> [ 1.690192] [<c155cc19>] acpi_processor_init+0x23/0xab
> [ 1.706126] [<c1001043>] do_one_initcall+0x33/0x180
> [ 1.721279] [<c155cbf6>] ? acpi_processor_init+0x0/0xab
> [ 1.737479] [<c106893a>] ? register_irq_proc+0xaa/0xc0
> [ 1.753411] [<c10689b7>] ? init_irq_proc+0x67/0x80
> [ 1.768316] [<c15405e7>] kernel_init+0x120/0x176
> [ 1.782678] [<c15404c7>] ? kernel_init+0x0/0x176
> [ 1.797062] [<c10038b7>] kernel_thread_helper+0x7/0x10
> [ 1.812984] 00000080 + ffe00000
that is rather later.
acpi_gbl_permanent_mmap should be set in acpi_early_init()
if acpi is not disabled
and we have
> [ 0.000000] ASUS P2B-DS detected: force use of acpi=ht
just don't load acpi_processor_init...
Reported-and-tested-by: Jens Rosenboom <jens@leia.mcbone.net>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Cc: Len Brown <lenb@kernel.org>
This patch folds the .start() method into .add().
acpi_processor_start() is always called immediately after
acpi_processor_add(), so there's really no point in having them be
separate methods.
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Reviewed-by: Alex Chiang <achiang@hp.com>
CC: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
CC: Zhao Yakui <yakui.zhao@intel.com>
Move acpi_processor_start() to just after acpi_processor_add().
A subsequent patch will merge them.
Code movement only; no functional change.
We used to leave crud around if things failed in acpi_processor_start().
This patch cleans up as much as we can before returning.
This patch removes the KOBJ_ONLINE/KOBJ_OFFLINE events the driver used
to generate for CPU hotplug. As far as I know, nobody consumes these.
The driver core still generates KOBJ_ADD and KOBJ_REMOVE, of course.
CC: Matthew Garrett <mjg@redhat.com>
CC: Thomas Renninger <trenn@suse.de>
CC: Dave Jones <davej@codemonkey.org.uk>
CC: Kay Sievers <kay.sievers@vrfy.org>
CC: Greg Kroah-Hartman <gregkh@suse.de>
'bugzilla-12904', 'bugzilla-13121', 'bugzilla-13396', 'bugzilla-13533', 'bugzilla-13612', 'c3_lock', 'hid-cleanups', 'misc-2.6.31', 'pdc-leak-fix', 'pnpacpi', 'power_nocheck', 'thinkpad_acpi', 'video' and 'wmi' into release
Some BIOS re-use the same processor bus id
in different scope:
\_SB.SCK0.CPU0
\_SB.SCK1.CPU0
But the (deprecated) /proc/acpi/ interface
assumes the bus-id's are unique, resulting in an OOPS
when the processor driver is loaded:
WARNING: at fs/proc/generic.c:590 proc_register+0x148/0x180()
Hardware name: Sunrise Ridge
proc_dir_entry 'processor/CPU0' already registered
Call Trace:
[<ffffffff8023f7ef>] warn_slowpath+0xb1/0xe5
[<ffffffff8036243b>] ? ida_get_new_above+0x190/0x1b1
[<ffffffff803625a8>] ? idr_pre_get+0x5f/0x75
[<ffffffff8030b2f6>] proc_register+0x148/0x180
[<ffffffff8030b4ff>] proc_mkdir_mode+0x3d/0x52
[<ffffffff8030b525>] proc_mkdir+0x11/0x13
[<ffffffffa0014b89>] acpi_processor_start+0x755/0x9bc [processor]
Rename the processor device bus id. And the new bus id will be
generated as the following format:
CPU+ CPU ID
For example: If the cpu ID is 5, then the bus ID will be "CPU5".
If the CPU ID is 10, then the bus ID will be "CPUA".
Yes, this will change the directory names seen
in /proc/acpi/processor/* on some systems.
Before this patch, those directory names where
totally arbitrary strings based on the interal AML device strings.
http://bugzilla.kernel.org/show_bug.cgi?id=13612
Signed-off-by: Zhao Yakui <yakui.zhao@intel.com>
Now whether the ACPI processor proc I/F is registered depends on the
CONFIG_PROC. It had better depend on the CONFIG_ACPI_PROCFS.
When the CONFIG_ACPI_PROCFS is unset in kernel configuration, the
ACPI processor proc I/F won't be registered.
arch_acpi_processor_cleanup_pdc() in x86 and ia64 results in memory allocated
for _PDC objects that is never freed and will cause memory leak in case of
physical CPU remove and add. Patch fixes the memory leak by freeing the
objects soon after _PDC is evaluated.
Reported-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
These are defined as static cpumask_var_t so if MAXSMP is not used,
they are cleared already. Avoid surprises when MAXSMP is enabled.
Signed-off-by: Yinghai Lu <yinghai.lu@kernel.org>
The ACPI0007 _HID used for processor "Device" objects in the namespace
is not needed outside the processor driver, so move it there. Also, the
#define is only used once, so just remove it and hard-code "ACPI0007".
This patch inverts the logic that distinguishes "Processor" statements
from "Device" statements, so we now check explicitly for "Processor" and
default to "Device". This removes the only real use of ACPI_PROCESSOR_HID,
so we can then remove the #define. It also has the theoretical advantage
that if a new processor _HID were ever added, we wouldn't have to change
the code here.
This patch adds a .notify() method. The presence of .notify() causes
Linux/ACPI to manage event handlers and notify handlers on our behalf,
so we don't have to install and remove them ourselves.
CC: Zhang Rui <rui.zhang@intel.com>
CC: Venki Pallipadi <venkatesh.pallipadi@intel.com>
CC: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com>
arch/x86/kernel/cpu/cpufreq/longhaul.c
All logical processors with APIC ID values of 255 and greater will have their
APIC reported through Processor X2APIC structure (type-9 entry type) and all
logical processors with APIC ID less than 255 will have their APIC reported
through legacy Processor Local APIC (type-0 entry type) only. This is the
same case even for NMI structure reporting.
The Processor X2APIC Affinity structure provides the association between the
X2APIC ID of a logical processor and the proximity domain to which the logical
processor belongs.
For OSPM, Procssor IDs outside the 0-254 range are to be declared as Device()
objects in the ACPI namespace.
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Setting ->owner as done currently (pde->owner = THIS_MODULE) is racy
as correctly noted at bug #12454. Someone can lookup entry with NULL
->owner, thus not pinning enything, and release it later resulting
in module refcount underflow.
We can keep ->owner and supply it at registration time like ->proc_fops
and ->data.
But this leaves ->owner as easy-manipulative field (just one C assignment)
and somebody will forget to unpin previous/pin current module when
switching ->owner. ->proc_fops is declared as "const" which should give
some thoughts.
->read_proc/->write_proc were just fixed to not require ->owner for
protection.
rmmod'ed directories will be empty and return "." and ".." -- no harm.
And directories with tricky enough readdir and lookup shouldn't be modular.
We definitely don't want such modular code.
Removing ->owner will also make PDE smaller.
So, let's nuke it.
Kudos to Jeff Layton for reminding about this, let's say, oversight.
http://bugzilla.kernel.org/show_bug.cgi?id=12454
Impact: Reduce memory usage, use new API.
This is part of an effort to reduce structure sizes for machines
configured with large NR_CPUS. cpumask_t gets replaced by
cpumask_var_t, which is either struct cpumask[1] (small NR_CPUS) or
struct cpumask * (large NR_CPUS).
(Changes to powernow-k* by <travis>.)
Signed-off-by: Mike Travis <travis@sgi.com>
Move all the component definitions for drivers to a single shared place,
include/acpi/acpi_drivers.h.
This patch is part of a larger patch series which will remove
the "char bus_id[20]" name string from struct device. The device
name is managed in the kobject anyway, and without any size
limitation, and just needlessly copied into "struct device".
To set and read the device name dev_name(dev) and dev_set_name(dev)
must be used. If your code uses static kobjects, which it shouldn't
do, "const char *init_name" can be used to statically provide the
name the registered device should have. At registration time, the
init_name field is cleared, to enforce the use of dev_name(dev) to
access the device name at a later time.
We need to get rid of all occurrences of bus_id in the entire tree
to be able to enable the new interface. Please apply this patch,
and possibly convert any remaining remaining occurrences of bus_id.
We want to submit a patch to -next, which will remove bus_id from
"struct device", to find the remaining pieces to convert, and finally
switch over to the new api, which will remove the 20 bytes array
and does no longer have a size limitation.
Signed-Off-By: Kay Sievers <kay.sievers@vrfy.org>
Signed-off-by: Myron Stowe <myron.stowe@hp.com>
Associating a Local SAPIC with a processor object is dependent upon the
processor object's definition type. CPUs declared as "Processor" should
use the Local SAPIC's 'processor_id', and CPUs declared as "Device"
should use the 'uid'. Note that for "Processor" declarations, even if a
'_UID' child object exists, it has no bearing with respect to mapping
Local SAPICs (see section 5.2.11.13 - Local SAPIC Structure; "Advanced
Configuration and Power Interface Specification", Revision 3.0b).
This patch changes the lsapic mapping logic to rely on the distinction of
how the processor object was declared - the mapping can't just try both
types of matches regardless of declaration type and rely on one failing
as is currently being done.
Declaring processors in ACPI namespace can be done using either a
"Processor" definition or a "Device" definition (see section 8.4 -
Declaring Processors; "Advanced Configuration and Power Interface
Specification", Revision 3.0b). Currently the two processor
declaration types are conflated.
This patch disambiguates the processor declaration's definition type
enabling subsequent code to behave uniquely based explicitly on the
declaration's type.
drivers/acpi/bay.c
drivers/acpi/dock.c
drivers/ata/libata-acpi.c
As of version 2.0, ACPI can return 64-bit integers. The current
acpi_evaluate_integer only supports 64-bit integers on 64-bit platforms.
Change the argument to take a pointer to an acpi_integer so we support
64-bit integers on all platforms.
lenb: replaced use of "acpi_integer" with "unsigned long long"
lenb: fixed bug in acpi_thermal_trips_update()
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
Catch attempts to use of acpi_driver_data on pointers of wrong type.
akpm: rewritten to use proper C typechecking and remove the
"function"-used-as-lvalue thing.
Signed-off-by: Pavel Machek <pavel@suse.cz>
This fixes a typo in commit 2a2a64714d9c40f7705c4de1e79a5b855c7211a9 "Disable MWAIT via DMI on broken Compal board".
It allows the nomwait dmi check to actually detect the Acer 5220.
Signed-off-by: Dennis Jansen <dennis.jansen@web.de>
Tested-by: Dennis Jansen <dennis.jansen@web.de>
Acked-by: Zhao Yakui <yakui.zhao@intel.com>
Trivial cleanups for ACPI. Fix misspelling in printk(), fix mismerge,
add file header.
AK: removed file header
We have the dev_printk() variants for this kind of thing, use them
instead of directly trying to access the bus_id field of struct device.
This is done in order to remove bus_id entirely.
Cc: Kay Sievers <kay.sievers@vrfy.org>
If a system matches in this DMI table,
Linux will disable MWAIT support for idle.
ie. "idle=nomwait" is automatically invoked
and C1_FFH and C2C3_FFH access mode are disabled.
http://bugzilla.kernel.org/show_bug.cgi?id=10807
http://bugzilla.kernel.org/show_bug.cgi?id=10914
Signed-off-by: Li Shaohua <shaohua.li@intel.com>
"idle=nomwait" disables the use of the MWAIT
instruction from both C1 (C1_FFH) and deeper (C2C3_FFH)
C-states.
When MWAIT is unavailable, the BIOS and OS generally
negotiate to use the HALT instruction for C1,
and use IO accesses for deeper C-states.
This option is useful for power and performance
comparisons, and also to work around BIOS bugs
where broken MWAIT support is advertised.
Change processors from an array sized by NR_CPUS to a per_cpu variable.
Sys I/F under acpi device node and sysdev device node are both
needed for cpu hot-removal. User space need this link so that
they know they are poking the sys I/F for the same cpu.
http://bugzilla.kernel.org/show_bug.cgi?id=9772
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
The ACPI device node for the cpu has already been unregistered
when acpi_processor_handle_eject is called.
Thus we should offline the cpu and continue, rather than a failure here.
This patch adds a proper prototype for acpi_processor_tstate_has_changed()
in include/acpi/processor.h
Signed-off-by: Adrian Bunk <bunk@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (179 commits)
ACPI: Fix acpi_processor_idle and idle= boot parameters interaction
acpi: fix section mismatch warning in pnpacpi
intel_menlo: fix build warning
ACPI: Cleanup: Remove unneeded, multiple local dummy variables
ACPI: video - fix permissions on some proc entries
ACPI: video - properly handle errors when registering proc elements
ACPI: video - do not store invalid entries in attached_array list
ACPI: re-name acpi_pm_ops to acpi_suspend_ops
ACER_WMI/ASUS_LAPTOP: fix build bug
thinkpad_acpi: fix possible NULL pointer dereference if kstrdup failed
ACPI: check a return value correctly in acpi_power_get_context()
#if 0 acpi/bay.c:eject_removable_drive()
eeepc-laptop: add hwmon fan control
eeepc-laptop: add backlight
eeepc-laptop: add base driver
ACPI: thinkpad-acpi: bump up version to 0.20
ACPI: thinkpad-acpi: fix selects in Kconfig
ACPI: thinkpad-acpi: use a private workqueue
ACPI: thinkpad-acpi: fluff really minor fix
ACPI: thinkpad-acpi: use uppercase for "LED" on user documentation
Fixed conflicts in drivers/acpi/video.c and drivers/misc/intel_menlow.c
manually.
Legacy HP ia64 platforms currently cannot provide
/proc/cpuinfo/physical_id due to legacy SAL/PAL implementations.
However, that physical topology information can be obtained
via ACPI.
Provide an interface that gives ACPI one last chance to provide
physical_id for these legacy platforms. This logic only comes
into play iff:
- ACPI actually provides slot information for the CPU
- we lack a valid socket_id
Otherwise, we don't do anything.
Since x86 uses the ACPI processor driver as well, we provide a nop
stub function for arch_fix_phys_package_id() in asm-x86/topology.h
Signed-off-by: Alex Chiang <achiang@hp.com>
Signed-off-by: Tony Luck <tony.luck@intel.com>
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data
be setup before gluing PDE to main tree.
Add correct ->owner to proc_fops to fix reading/module unloading race.
Signed-off-by: Denis V. Lunev <den@openvz.org>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
thermal_cooling_device_register used to return NULL if THERMAL is "n".
As the ACPI fan, processor and video drivers SELECT the generic
thermal in PATCH 01, this is not a problem any more.
Fixes a BUG in ACPI hotplugging.
processor_device_array[pr->id] needs to be set to NULL when removing a CPU.
Else the "buggy BIOS check" in acpi_processor_start mistakenly fires when a
CPU is removed from the system and then later re-added.
Signed-off-by: Alok N Kataria <akataria@vmware.com>
Signed-off-by: Dan Arai <arai@vmware.com>
Cc: <stable@kernel.org>
Revert commit 1192aeb957402b45f311895f124e4ca41206843c ("ACPI:
drivers/acpi: elide a non-zero test on a result that is never 0")
because it turns out that thermal_cooling_device_register() does
actually return NULL if CONFIG_THERMAL is turned off (then the routine
turns into a dummy inline routine in the header files that returns NULL
unconditionally).
This was found with randconfig testing, causing a crash during bootup:
initcall 0x78878534 ran for 13 msecs: acpi_button_init+0x0/0x51()
Calling initcall 0x78878585: acpi_fan_init+0x0/0x2c()
BUG: unable to handle kernel NULL pointer dereference at 00000000
IP: [<782b8ad0>] acpi_fan_add+0x7d/0xfd
*pde = 00000000
Oops: 0000 [#1]
Modules linked in:
Pid: 1, comm: swapper Not tainted (2.6.25-rc7-sched-devel.git-x86-latest.git #14)
EIP: 0060:[<782b8ad0>] EFLAGS: 00010246 CPU: 0
EIP is at acpi_fan_add+0x7d/0xfd
EAX: b787c718 EBX: b787c400 ECX: b782ceb4 EDX: 00000007
ESI: 00000000 EDI: b787c6f4 EBP: b782cee0 ESP: b782cecc
DS: 007b ES: 007b FS: 0000 GS: 0000 SS: 0068
Process swapper (pid: 1, ti=b782c000 task=b7846000 task.ti=b782c000)
Stack: b787c459 00000000 b787c400 78790888 b787c60c b782cef8 782b6fb8 ffffffda
b787c60c 00000000 78790958 b782cf0c 783005d7 b787c60c 78790958 78790584
b782cf1c 783007f6 b782cf28 00000000 b782cf40 782ffc4a 78790958 b794d558
Call Trace:
[<782b6fb8>] ? acpi_device_probe+0x3e/0xdb
[<783005d7>] ? driver_probe_device+0x82/0xfc
[<783007f6>] ? __driver_attach+0x3a/0x70
[<782ffc4a>] ? bus_for_each_dev+0x3e/0x60
[<7830048c>] ? driver_attach+0x14/0x16
[<783007bc>] ? __driver_attach+0x0/0x70
[<7830006a>] ? bus_add_driver+0x9d/0x1b0
[<783008c3>] ? driver_register+0x47/0xa3
[<7813db00>] ? timespec_to_ktime+0x9/0xc
[<782b7331>] ? acpi_bus_register_driver+0x3a/0x3c
[<78878592>] ? acpi_fan_init+0xd/0x2c
[<78863656>] ? kernel_init+0xac/0x1f9
[<788635aa>] ? kernel_init+0x0/0x1f9
[<78114563>] ? kernel_thread_helper+0x7/0x10
Code: 6e 78 e8 57 44 e7 ff 58 e9 93 00 00 00 8b 55 f0 8d bb f4 02 00 00 80 4b 2d 10 8b 03 e8 87 cb ff ff 8d 83 18 03 00 00 80 63 2d ef <ff> 35 00 00 00 00 50 68 e8 9c 6e 78 e8 22 44 e7 ff b9 b6 9c 6e
EIP: [<782b8ad0>] acpi_fan_add+0x7d/0xfd SS:ESP 0068:b782cecc
---[ end trace 778e504de7e3b1e3 ]---
Kernel panic - not syncing: Attempted to kill init!
Acked-by: Julia Lawall <julia@diku.dk>
The function thermal_cooling_device_register always returns either a valid
pointer or a value made with ERR_PTR, so a test for non-zero on the result
will always succeed.
The problem was found using the following semantic match.
(http://www.emn.fr/x-info/coccinelle/)
//<smpl>
@a@
expression E, E1;
statement S,S1;
position p;
E = thermal_cooling_device_register(...)
... when != E = E1
if@p (E) S else S1
@n@
position a.p;
expression E,E1;
statement S,S1;
E = NULL
... when != E = E1
if@p (E) S else S1
@depends on !n@
expression E;
statement S,S1;
position a.p;
* if@p (E)
S else S1
//</smpl>
and 'toshiba' into release
