Based on 3 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license as published by
the free software foundation either version 2 of the license or at
your option any later version this program is distributed in the
hope that it will be useful but without any warranty without even
the implied warranty of merchantability or fitness for a particular
purpose see the gnu general public license for more details
your option any later version [author] [kishon] [vijay] [abraham]
[i] [kishon]@[ti] [com] this program is distributed in the hope that
it will be useful but without any warranty without even the implied
warranty of merchantability or fitness for a particular purpose see
your option any later version [author] [graeme] [gregory]
[gg]@[slimlogic] [co] [uk] [author] [kishon] [vijay] [abraham] [i]
[kishon]@[ti] [com] [based] [on] [twl6030]_[usb] [c] [author] [hema]
[hk] [hemahk]@[ti] [com] this program is distributed in the hope
that it will be useful but without any warranty without even the
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 1105 file(s).
Reviewed-by: Allison Randal <allison@lohutok.net>
Reviewed-by: Richard Fontana <rfontana@redhat.com>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190527070033.202006027@linutronix.de
The ACPI idle driver will fallback to using the legacy P_LVL* SystemIO
method of entering C-states if the _CST method is disabled and P_BLK is
defined. However, in this case the C2 and C3 states won't have a
description set, so the user will see "<null>" when reading the
description from sysfs.
Give each of these states a description.
Signed-off-by: Yazen Ghannam <yazen.ghannam@amd.com>
The Hygon Dhyana CPU has NONSTOP TSC feature, so enable the ACPI driver
support to it.
Signed-off-by: Pu Wen <puwen@hygon.cn>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Cc: rjw@rjwysocki.net
Cc: tglx@linutronix.de
Cc: mingo@redhat.com
Cc: hpa@zytor.com
Cc: x86@kernel.org
Cc: thomas.lendacky@amd.com
Cc: lenb@kernel.org
Cc: rafael@kernel.org
Cc: linux-acpi@vger.kernel.org
Link: https://lkml.kernel.org/r/cce6ee26f4e2ebbab493433264d89d7cea661284.1537533369.git.puwen@hygon.cn
Pull more ACPI updates from Rafael Wysocki:
"These are mostly fixes and cleanups, a few new quirks, a couple of
updates related to the handling of ACPI tables and ACPICA copyrights
refreshment.
Specifics:
- Update the ACPICA kernel code to upstream revision 20180105
including:
* Assorted fixes (Jung-uk Kim)
* Support for X32 ABI compilation (Anuj Mittal)
* Update of ACPICA copyrights to 2018 (Bob Moore)
- Prepare for future modifications to avoid executing the _STA
control method too early (Hans de Goede)
- Make the processor performance control library code ignore _PPC
notifications if they cannot be handled and fix up the C1 idle
state definition when it is used as a fallback state (Chen Yu,
Yazen Ghannam)
- Make it possible to use the SPCR table on x86 and to replace the
original IORT table with a new one from initrd (Prarit Bhargava,
Shunyong Yang)
- Add battery-related quirks for Asus UX360UA and UX410UAK and add
quirks for table parsing on Dell XPS 9570 and Precision M5530 (Kai
Heng Feng)
- Address static checker warnings in the CPPC code (Gustavo Silva)
- Avoid printing a raw pointer to the kernel log in the smart battery
driver (Greg Kroah-Hartman)"
* tag 'acpi-part2-4.16-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
ACPI: sbshc: remove raw pointer from printk() message
ACPI: SPCR: Make SPCR available to x86
ACPI / CPPC: Use 64-bit arithmetic instead of 32-bit
ACPI / tables: Add IORT to injectable table list
ACPI / bus: Parse tables as term_list for Dell XPS 9570 and Precision M5530
ACPICA: Update version to 20180105
ACPICA: All acpica: Update copyrights to 2018
ACPI / processor: Set default C1 idle state description
ACPI / battery: Add quirk for Asus UX360UA and UX410UAK
ACPI: processor_perflib: Do not send _PPC change notification if not ready
ACPI / scan: Use acpi_bus_get_status() to initialize ACPI_TYPE_DEVICE devs
ACPI / bus: Do not call _STA on battery devices with unmet dependencies
PCI: acpiphp_ibm: prepare for acpi_get_object_info() no longer returning status
ACPI: export acpi_bus_get_status_handle()
ACPICA: Add a missing pair of parentheses
ACPICA: Prefer ACPI_TO_POINTER() over ACPI_ADD_PTR()
ACPICA: Avoid NULL pointer arithmetic
ACPICA: Linux: add support for X32 ABI compilation
ACPI / video: Use true for boolean value
The ACPI idle driver will default to ACPI_CSTATE_HALT for C1 if a _CST
object for C1 is not defined. However, the description will not be set,
so users will see "<null>" when reading the description from sysfs.
Set the C1 state description when defaulting to ACPI_CSTATE_HALT.
Centaur CPU has a constant frequency TSC and that TSC does not stop in
C-States. But because the corresponding TSC feature flags are not set for
that CPU, the TSC is treated as not constant frequency and assumed to stop
in C-States, which makes it an unreliable and unusable clock source.
Setting those flags tells the kernel that the TSC is usable, so it will
select it over HPET. The effect of this is that reading time stamps (from
kernel or user space) will be faster and more efficent.
Signed-off-by: davidwang <davidwang@zhaoxin.com>
Cc: qiyuanwang@zhaoxin.com
Cc: linux-pm@vger.kernel.org
Cc: brucechang@via-alliance.com
Cc: cooperyan@zhaoxin.com
Cc: benjaminpan@viatech.com
Link: https://lkml.kernel.org/r/1516616057-5158-1-git-send-email-davidwang@zhaoxin.com
This reverts commit 43858b4f25cf0adc5c2ca9cf5ce5fdf2532941e5.
The reason I removed the leave_mm() calls in question is because the
heuristic wasn't needed after that patch. With the original version
of my PCID series, we never flushed a "lazy cpu" (i.e. a CPU running
kernel thread) due a flush on the loaded mm.
Unfortunately, that caused architectural issues, so now I've
reinstated these flushes on non-PCID systems in:
commit b956575bed91 ("x86/mm: Flush more aggressively in lazy TLB mode").
That, in turn, gives us a power management and occasionally
performance regression as compared to old kernels: a process that
goes into a deep idle state on a given CPU and gets its mm flushed
due to activity on a different CPU will wake the idle CPU.
Reinstate the old ugly heuristic: if a CPU goes into ACPI C3 or an
intel_idle state that is likely to cause a TLB flush gets its mm
switched to init_mm before going idle.
FWIW, this heuristic is lousy. Whether we should change CR3 before
idle isn't a good hint except insofar as the performance hit is a bit
lower if the TLB is getting flushed by the idle code anyway. What we
really want to know is whether we anticipate being idle long enough
that the mm is likely to be flushed before we wake up. This is more a
matter of the expected latency than the idle state that gets chosen.
This heuristic also completely fails on systems that don't know
whether the TLB will be flushed (e.g. AMD systems?). OTOH it may be a
bit obsolete anyway -- PCID systems don't presently benefit from this
heuristic at all.
We also shouldn't do this callback from innermost bit of the idle code
due to the RCU nastiness it causes. All the information need is
available before rcu_idle_enter() needs to happen.
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Cc: Borislav Petkov <bpetkov@suse.de>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Fixes: 43858b4f25cf "x86/mm: Stop calling leave_mm() in idle code"
Link: http://lkml.kernel.org/r/c513bbd4e653747213e05bc7062de000bf0202a5.1509793738.git.luto@kernel.org
Pull power management updates from Rafael Wysocki:
"This time (again) cpufreq gets the majority of changes which mostly
are driver updates (including a major consolidation of intel_pstate),
some schedutil governor modifications and core cleanups.
There also are some changes in the system suspend area, mostly related
to diagnostics and debug messages plus some renames of things related
to suspend-to-idle. One major change here is that suspend-to-idle is
now going to be preferred over S3 on systems where the ACPI tables
indicate to do so and provide requsite support (the Low Power Idle S0
_DSM in particular). The system sleep documentation and the tools
related to it are updated too.
The rest is a few cpuidle changes (nothing major), devfreq updates,
generic power domains (genpd) framework updates and a few assorted
modifications elsewhere.
Specifics:
- Drop the P-state selection algorithm based on a PID controller from
intel_pstate and make it use the same P-state selection method
(based on the CPU load) for all types of systems in the active mode
(Rafael Wysocki, Srinivas Pandruvada).
- Rework the cpufreq core and governors to make it possible to take
cross-CPU utilization updates into account and modify the schedutil
governor to actually do so (Viresh Kumar).
- Clean up the handling of transition latency information in the
cpufreq core and untangle it from the information on which drivers
cannot do dynamic frequency switching (Viresh Kumar).
- Add support for new SoCs (MT2701/MT7623 and MT7622) to the mediatek
cpufreq driver and update its DT bindings (Sean Wang).
- Modify the cpufreq dt-platdev driver to autimatically create
cpufreq devices for the new (v2) Operating Performance Points (OPP)
DT bindings and update its whitelist of supported systems (Viresh
Kumar, Shubhrajyoti Datta, Marc Gonzalez, Khiem Nguyen, Finley
Xiao).
- Add support for Ux500 to the cpufreq-dt driver and drop the
obsolete dbx500 cpufreq driver (Linus Walleij, Arnd Bergmann).
- Add new SoC (R8A7795) support to the cpufreq rcar driver (Khiem
Nguyen).
- Fix and clean up assorted issues in the cpufreq drivers and core
(Arvind Yadav, Christophe Jaillet, Colin Ian King, Gustavo Silva,
Julia Lawall, Leonard Crestez, Rob Herring, Sudeep Holla).
- Update the IO-wait boost handling in the schedutil governor to make
it less aggressive (Joel Fernandes).
- Rework system suspend diagnostics to make it print fewer messages
to the kernel log by default, add a sysfs knob to allow more
suspend-related messages to be printed and add Low Power S0 Idle
constraints checks to the ACPI suspend-to-idle code (Rafael
- Prefer suspend-to-idle over S3 on ACPI-based systems with the
ACPI_FADT_LOW_POWER_S0 flag set and the Low Power Idle S0 _DSM
interface present in the ACPI tables (Rafael Wysocki).
- Update documentation related to system sleep and rename a number of
items in the code to make it cleare that they are related to
suspend-to-idle (Rafael Wysocki).
- Export a variable allowing device drivers to check the target
system sleep state from the core system suspend code (Florian
Fainelli).
- Clean up the cpuidle subsystem to handle the polling state on x86
in a more straightforward way and to use %pOF instead of full_name
(Rafael Wysocki, Rob Herring).
- Update the devfreq framework to fix and clean up a few minor issues
(Chanwoo Choi, Rob Herring).
- Extend diagnostics in the generic power domains (genpd) framework
and clean it up slightly (Thara Gopinath, Rob Herring).
- Fix and clean up a couple of issues in the operating performance
points (OPP) framework (Viresh Kumar, Waldemar Rymarkiewicz).
- Add support for RV1108 to the rockchip-io Adaptive Voltage Scaling
(AVS) driver (David Wu).
- Fix the usage of notifiers in CPU power management on some
platforms (Alex Shi).
- Update the pm-graph system suspend/hibernation and boot profiling
utility (Todd Brandt).
- Make it possible to run the cpupower utility without CPU0 (Prarit
Bhargava)"
* tag 'pm-4.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (87 commits)
cpuidle: Make drivers initialize polling state
cpuidle: Move polling state initialization code to separate file
cpuidle: Eliminate the CPUIDLE_DRIVER_STATE_START symbol
cpufreq: imx6q: Fix imx6sx low frequency support
cpufreq: speedstep-lib: make several arrays static, makes code smaller
PM: docs: Delete the obsolete states.txt document
PM: docs: Describe high-level PM strategies and sleep states
PM / devfreq: Fix memory leak when fail to register device
PM / devfreq: Add dependency on PM_OPP
PM / devfreq: Move private devfreq_update_stats() into devfreq
PM / devfreq: Convert to using %pOF instead of full_name
PM / AVS: rockchip-io: add io selectors and supplies for RV1108
cpufreq: ti: Fix 'of_node_put' being called twice in error handling path
cpufreq: dt-platdev: Drop few entries from whitelist
cpufreq: dt-platdev: Automatically create cpufreq device with OPP v2
ARM: ux500: don't select CPUFREQ_DT
cpuidle: Convert to using %pOF instead of full_name
cpufreq: Convert to using %pOF instead of full_name
PM / Domains: Convert to using %pOF instead of full_name
cpufreq: Cap the default transition delay value to 10 ms
* pm-sleep:
ACPI / PM: Check low power idle constraints for debug only
PM / s2idle: Rename platform operations structure
PM / s2idle: Rename ->enter_freeze to ->enter_s2idle
PM / s2idle: Rename freeze_state enum and related items
PM / s2idle: Rename PM_SUSPEND_FREEZE to PM_SUSPEND_TO_IDLE
ACPI / PM: Prefer suspend-to-idle over S3 on some systems
platform/x86: intel-hid: Wake up Dell Latitude 7275 from suspend-to-idle
PM / suspend: Define pr_fmt() in suspend.c
PM / suspend: Use mem_sleep_labels[] strings in messages
PM / sleep: Put pm_test under CONFIG_PM_SLEEP_DEBUG
PM / sleep: Check pm_wakeup_pending() in __device_suspend_noirq()
PM / core: Add error argument to dpm_show_time()
PM / core: Split dpm_suspend_noirq() and dpm_resume_noirq()
PM / s2idle: Rearrange the main suspend-to-idle loop
PM / timekeeping: Print debug messages when requested
PM / sleep: Mark suspend/hibernation start and finish
PM / sleep: Do not print debug messages by default
PM / suspend: Export pm_suspend_target_state
Make the drivers that want to include the polling state into their
states table initialize it explicitly and drop the initialization of
it (which in fact is conditional, but that is not obvious from the
code) from the core.
Tested-by: Sudeep Holla <sudeep.holla@arm.com>
Acked-by: Daniel Lezcano <daniel.lezcano@linaro.org>
On some architectures the first (index 0) idle state is a polling
one and it doesn't really save energy, so there is the
CPUIDLE_DRIVER_STATE_START symbol allowing some pieces of
cpuidle code to avoid using that state.
However, this makes the code rather hard to follow. It is better
to explicitly avoid the polling state, so add a new cpuidle state
flag CPUIDLE_FLAG_POLLING to mark it and make the relevant code
check that flag for the first state instead of using the
CPUIDLE_DRIVER_STATE_START symbol.
In the ACPI processor driver that cannot always rely on the state
flags (like before the states table has been set up) define
a new internal symbol ACPI_IDLE_STATE_START equivalent to the
CPUIDLE_DRIVER_STATE_START one and drop the latter.
Rename the ->enter_freeze cpuidle driver callback to ->enter_s2idle
to make it clear that it is used for entering suspend-to-idle and
rename the related functions, variables and so on accordingly.
Now that lazy TLB suppresses all flush IPIs (as opposed to all but
the first), there's no need to leave_mm() when going idle.
This means we can get rid of the rcuidle hack in
switch_mm_irqs_off() and we can unexport leave_mm().
This also removes acpi_unlazy_tlb() from the x86 and ia64 headers,
since it has no callers any more.
Reviewed-by: Nadav Amit <nadav.amit@gmail.com>
Reviewed-by: Borislav Petkov <bp@suse.de>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: linux-mm@kvack.org
Link: http://lkml.kernel.org/r/03c699cfd6021e467be650d6b73deaccfe4b4bd7.1498751203.git.luto@kernel.org
Reorganize the E400 detection now that we have everything in place:
switch the CPUs to broadcast mode after the LAPIC has been initialized
and remove the facilities that were used previously on the idle path.
Unfortunately static_cpu_has_bug() cannpt be used in the E400 idle routine
because alternatives have been applied when the actual detection happens,
so the static switching does not take effect and the test will stay
false. Use boot_cpu_has_bug() instead which is definitely an improvement
over the RDMSR and the cpumask handling.
Suggested-by: Thomas Gleixner <tglx@linutronix.de>
Cc: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/20161209182912.2726-5-bp@alien8.de
When doing an nmi backtrace of many cores, most of which are idle, the
output is a little overwhelming and very uninformative. Suppress
messages for cpus that are idling when they are interrupted and just
emit one line, "NMI backtrace for N skipped: idling at pc 0xNNN".
We do this by grouping all the cpuidle code together into a new
.cpuidle.text section, and then checking the address of the interrupted
PC to see if it lies within that section.
This commit suitably tags x86 and tile idle routines, and only adds in
the minimal framework for other architectures.
Link: http://lkml.kernel.org/r/1472487169-14923-5-git-send-email-cmetcalf@mellanox.com
Signed-off-by: Chris Metcalf <cmetcalf@mellanox.com>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Tested-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Tested-by: Daniel Thompson <daniel.thompson@linaro.org> [arm]
Tested-by: Petr Mladek <pmladek@suse.com>
Cc: Aaron Tomlin <atomlin@redhat.com>
Cc: Peter Zijlstra (Intel) <peterz@infradead.org>
Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net>
ACPI 6.0 introduced an optional object _LPI that provides an alternate
method to describe Low Power Idle states. It defines the local power
states for each node in a hierarchical processor topology. The OSPM can
use _LPI object to select a local power state for each level of processor
hierarchy in the system. They used to produce a composite power state
request that is presented to the platform by the OSPM.
Since multiple processors affect the idle state for any non-leaf hierarchy
node, coordination of idle state requests between the processors is
required. ACPI supports two different coordination schemes: Platform
coordinated and OS initiated.
This patch adds initial support for Platform coordination scheme of LPI.
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
ACPI 6.0 adds a new method to specify the CPU idle states(C-states)
called Low Power Idle(LPI) states. Since new architectures like ARM64
use only LPIs, introduce ACPI_PROCESSOR_CSTATE to encapsulate all the
code supporting the old style C-states(_CST).
This patch will help to extend the processor_idle module to support
LPI.
Pull power management and ACPI updates from Rafael Wysocki:
"This time the majority of changes go into cpufreq and they are
significant.
First off, the way CPU frequency updates are triggered is different
now. Instead of having to set up and manage a deferrable timer for
each CPU in the system to evaluate and possibly change its frequency
periodically, cpufreq governors set up callbacks to be invoked by the
scheduler on a regular basis (basically on utilization updates). The
"old" governors, "ondemand" and "conservative", still do all of their
work in process context (although that is triggered by the scheduler
now), but intel_pstate does it all in the callback invoked by the
scheduler with no need for any additional asynchronous processing.
Of course, this eliminates the overhead related to the management of
all those timers, but also it allows the cpufreq governor code to be
simplified quite a bit. On top of that, the common code and data
structures used by the "ondemand" and "conservative" governors are
cleaned up and made more straightforward and some long-standing and
quite annoying problems are addressed. In particular, the handling of
governor sysfs attributes is modified and the related locking becomes
more fine grained which allows some concurrency problems to be avoided
(particularly deadlocks with the core cpufreq code).
In principle, the new mechanism for triggering frequency updates
allows utilization information to be passed from the scheduler to
cpufreq. Although the current code doesn't make use of it, in the
works is a new cpufreq governor that will make decisions based on the
scheduler's utilization data. That should allow the scheduler and
cpufreq to work more closely together in the long run.
In addition to the core and governor changes, cpufreq drivers are
updated too. Fixes and optimizations go into intel_pstate, the
cpufreq-dt driver is updated on top of some modification in the
Operating Performance Points (OPP) framework and there are fixes and
other updates in the powernv cpufreq driver.
Apart from the cpufreq updates there is some new ACPICA material,
including a fix for a problem introduced by previous ACPICA updates,
and some less significant changes in the ACPI code, like CPPC code
optimizations, ACPI processor driver cleanups and support for loading
ACPI tables from initrd.
Also updated are the generic power domains framework, the Intel RAPL
power capping driver and the turbostat utility and we have a bunch of
traditional assorted fixes and cleanups.
Specifics:
- Redesign of cpufreq governors and the intel_pstate driver to make
them use callbacks invoked by the scheduler to trigger CPU
frequency evaluation instead of using per-CPU deferrable timers for
that purpose (Rafael Wysocki).
- Reorganization and cleanup of cpufreq governor code to make it more
straightforward and fix some concurrency problems in it (Rafael
Wysocki, Viresh Kumar).
- Cleanup and improvements of locking in the cpufreq core (Viresh
Kumar).
- Assorted cleanups in the cpufreq core (Rafael Wysocki, Viresh
Kumar, Eric Biggers).
- intel_pstate driver updates including fixes, optimizations and a
modification to make it enable enable hardware-coordinated P-state
selection (HWP) by default if supported by the processor (Philippe
Longepe, Srinivas Pandruvada, Rafael Wysocki, Viresh Kumar, Felipe
Franciosi).
- Operating Performance Points (OPP) framework updates to improve its
handling of voltage regulators and device clocks and updates of the
cpufreq-dt driver on top of that (Viresh Kumar, Jon Hunter).
- Updates of the powernv cpufreq driver to fix initialization and
cleanup problems in it and correct its worker thread handling with
respect to CPU offline, new powernv_throttle tracepoint (Shilpasri
Bhat).
- ACPI cpufreq driver optimization and cleanup (Rafael Wysocki).
- ACPICA updates including one fix for a regression introduced by
previos changes in the ACPICA code (Bob Moore, Lv Zheng, David Box,
Colin Ian King).
- Support for installing ACPI tables from initrd (Lv Zheng).
- Optimizations of the ACPI CPPC code (Prashanth Prakash, Ashwin
Chaugule).
- Support for _HID(ACPI0010) devices (ACPI processor containers) and
ACPI processor driver cleanups (Sudeep Holla).
- Support for ACPI-based enumeration of the AMBA bus (Graeme Gregory,
Aleksey Makarov).
- Modification of the ACPI PCI IRQ management code to make it treat
255 in the Interrupt Line register as "not connected" on x86 (as
per the specification) and avoid attempts to use that value as a
valid interrupt vector (Chen Fan).
- ACPI APEI fixes related to resource leaks (Josh Hunt).
- Removal of modularity from a few ACPI drivers (BGRT, GHES,
intel_pmic_crc) that cannot be built as modules in practice (Paul
Gortmaker).
- PNP framework update to make it treat ACPI_RESOURCE_TYPE_SERIAL_BUS
as a valid resource type (Harb Abdulhamid).
- New device ID (future AMD I2C controller) in the ACPI driver for
AMD SoCs (APD) and in the designware I2C driver (Xiangliang Yu).
- Assorted ACPI cleanups (Colin Ian King, Kaiyen Chang, Oleg Drokin).
- cpuidle menu governor optimization to avoid a square root
computation in it (Rasmus Villemoes).
- Fix for potential use-after-free in the generic device properties
framework (Heikki Krogerus).
- Updates of the generic power domains (genpd) framework including
support for multiple power states of a domain, fixes and debugfs
output improvements (Axel Haslam, Jon Hunter, Laurent Pinchart,
Geert Uytterhoeven).
- Intel RAPL power capping driver updates to reduce IPI overhead in
it (Jacob Pan).
- System suspend/hibernation code cleanups (Eric Biggers, Saurabh
Sengar).
- Year 2038 fix for the process freezer (Abhilash Jindal).
- turbostat utility updates including new features (decoding of more
registers and CPUID fields, sub-second intervals support, GFX MHz
and RC6 printout, --out command line option), fixes (syscall jitter
detection and workaround, reductioin of the number of syscalls
made, fixes related to Xeon x200 processors, compiler warning
fixes) and cleanups (Len Brown, Hubert Chrzaniuk, Chen Yu)"
* tag 'pm+acpi-4.6-rc1-1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (182 commits)
tools/power turbostat: bugfix: TDP MSRs print bits fixing
tools/power turbostat: correct output for MSR_NHM_SNB_PKG_CST_CFG_CTL dump
tools/power turbostat: call __cpuid() instead of __get_cpuid()
tools/power turbostat: indicate SMX and SGX support
tools/power turbostat: detect and work around syscall jitter
tools/power turbostat: show GFX%rc6
tools/power turbostat: show GFXMHz
tools/power turbostat: show IRQs per CPU
tools/power turbostat: make fewer systems calls
tools/power turbostat: fix compiler warnings
tools/power turbostat: add --out option for saving output in a file
tools/power turbostat: re-name "%Busy" field to "Busy%"
tools/power turbostat: Intel Xeon x200: fix turbo-ratio decoding
tools/power turbostat: Intel Xeon x200: fix erroneous bclk value
tools/power turbostat: allow sub-sec intervals
ACPI / APEI: ERST: Fixed leaked resources in erst_init
ACPI / APEI: Fix leaked resources
intel_pstate: Do not skip samples partially
intel_pstate: Remove freq calculation from intel_pstate_calc_busy()
intel_pstate: Move intel_pstate_calc_busy() into get_target_pstate_use_performance()
$ make tags
GEN tags
ctags: Warning: drivers/acpi/processor_idle.c:64: null expansion of name pattern "\1"
ctags: Warning: drivers/xen/events/events_2l.c:41: null expansion of name pattern "\1"
ctags: Warning: kernel/locking/lockdep.c:151: null expansion of name pattern "\1"
ctags: Warning: kernel/rcu/rcutorture.c:133: null expansion of name pattern "\1"
ctags: Warning: kernel/rcu/rcutorture.c:135: null expansion of name pattern "\1"
ctags: Warning: kernel/workqueue.c:323: null expansion of name pattern "\1"
ctags: Warning: net/ipv4/syncookies.c:53: null expansion of name pattern "\1"
ctags: Warning: net/ipv6/syncookies.c:44: null expansion of name pattern "\1"
ctags: Warning: net/rds/page.c:45: null expansion of name pattern "\1"
Which are all the result of the DEFINE_PER_CPU pattern:
scripts/tags.sh:200: '/\<DEFINE_PER_CPU([^,]*, *\([[:alnum:]_]*\)/\1/v/'
scripts/tags.sh:201: '/\<DEFINE_PER_CPU_SHARED_ALIGNED([^,]*, *\([[:alnum:]_]*\)/\1/v/'
The below cures them. All except the workqueue one are within reasonable
distance of the 80 char limit. TJ do you have any preference on how to
fix the wq one, or shall we just not care its too long?
Cc: Tejun Heo <tj@kernel.org>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
acpi_processor_sleep is neither related nor used by CPUIdle framework.
It's used in system suspend/resume path as a syscore operation. It makes
more sense to move it to acpi/sleep.c where all the S-state transition
(a.k.a. Linux system suspend/hiberate) related code are present.
Also make it depend on CONFIG_ACPI_SYSTEM_POWER_STATES_SUPPORT so that
it's not compiled on architecture like ARM64 where S-states are not
yet defined in ACPI.
Like few of the other ACPI modules, replace PREFIX with pr_fmt and
change all the printk call sites to use pr_* companion functions
in processor_idle.
There is no need to carry potentially outdated Free Software Foundation
mailing address in file headers since the COPYING file includes it.
Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
There is no need to have processor_power_dmi_table[] writeable, constify
it.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Pull timer updates from Ingo Molnar:
"The main changes in this cycle were:
- clockevents state machine cleanups and enhancements (Viresh Kumar)
- clockevents broadcast notifier horror to state machine conversion
and related cleanups (Thomas Gleixner, Rafael J Wysocki)
- clocksource and timekeeping core updates (John Stultz)
- clocksource driver updates and fixes (Ben Dooks, Dmitry Osipenko,
Hans de Goede, Laurent Pinchart, Maxime Ripard, Xunlei Pang)
- y2038 fixes (Xunlei Pang, John Stultz)
- NMI-safe ktime_get_raw_fast() and general refactoring of the clock
code, in preparation to perf's per event clock ID support (Peter
Zijlstra)
- generic sched/clock fixes, optimizations and cleanups (Daniel
Thompson)
- clockevents cpu_down() race fix (Preeti U Murthy)"
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (94 commits)
timers/PM: Drop unnecessary braces from tick_freeze()
timers/PM: Fix up tick_unfreeze()
timekeeping: Get rid of stale comment
clockevents: Cleanup dead cpu explicitely
clockevents: Make tick handover explicit
clockevents: Remove broadcast oneshot control leftovers
sched/idle: Use explicit broadcast oneshot control function
ARM: Tegra: Use explicit broadcast oneshot control function
ARM: OMAP: Use explicit broadcast oneshot control function
intel_idle: Use explicit broadcast oneshot control function
ACPI/idle: Use explicit broadcast control function
ACPI/PAD: Use explicit broadcast oneshot control function
x86/amd/idle, clockevents: Use explicit broadcast oneshot control functions
clockevents: Provide explicit broadcast oneshot control functions
clockevents: Remove the broadcast control leftovers
ARM: OMAP: Use explicit broadcast control function
intel_idle: Use explicit broadcast control function
cpuidle: Use explicit broadcast control function
ACPI/processor: Use explicit broadcast control function
ACPI/PAD: Use explicit broadcast control function
Fix a bug that leads to showing the name and description of C-state C0
as "<null>" in sysfs after the ACPI C-states changed (e.g. after AC->DC
or DC->AC
transition).
The function poll_idle_init() in drivers/cpuidle/driver.c initializes the
state 0 during cpuidle_register_driver(), so we better do not overwrite it
again with '\0' during acpi_processor_cst_has_changed().
Signed-off-by: Thomas Schlichter <thomas.schlichter@web.de>
Reviewed-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Cc: 3.13+ <stable@vger.kernel.org> # 3.13+
Replace the clockevents_notify() call with an explicit function call.
Link: http://lkml.kernel.org/r/2653377.MSAlfA939I@vostro.rjw.lan
Link: http://lkml.kernel.org/r/25071624.dkenaL3SGT@vostro.rjw.lan
Add an ->enter_freeze callback routine, acpi_idle_enter_freeze(), to
the ACPI cpuidle driver and point ->enter_freeze to it for all the
C2-type and C3-type states that don't need to fall back to C1
(which may be halt-induced and that will re-enable interrupts on
exit from idle, which ->enter_freeze cannot do).
Introduce a common ->enter callback routine for the ACPI cpuidle
driver, acpi_idle_enter(), which helps to reduce code complexity,
size and duplication and prevents theoretically possible failues that
an incorrect routine may be run to enter the given idle state due to
a firmware bug (eg. when _CST returns a different set of states for
each processor).
acpi_idle_enter_c1() and acpi_idle_enter_simple() are close enough to
each other that they can be merged into one function which reduces
duplication of code quite a bit.
Since acpi_idle_enter_bm() is only used if flags.bm_check is set for
the given acpi_processor object, it doesn't make sense to check that
flag in there.
For this reason, drop flags.bm_check tests (and some code depending
on them) from acpi_idle_enter_bm().
White space in the switch statement in acpi_processor_setup_cpuidle_states()
does not adhere to the kernel coding style and that makes the code
difficult to read. Clean that up.
The comment about bus master disable in acpi_idle_enter_simple() is
irrelevant, because the function doesn't disable bus mastering, so
drop it.
acpi_idle_enter_simple() and acpi_idle_enter_bm() both check
if C2/C3 type entry is supported on MP in the same way, so move
those checks to a separate function and call it from both
places (and it doesn't need to check if the state type is not
C1, because the functions in question won't be called otherwise).
While at it, use IS_ENABLED() for the CONFIG_HOTPLUG_CPU check.
acpi_idle_enter_simple() and acpi_idle_enter_bm() don't need to
call sched_clock_idle_sleep/wakeup_event(), because that's taken
care of by the core already. Namely, sched_clock_idle_sleep_event()
is called by tick_nohz_start_idle() called by __tick_nohz_idle_enter()
which in turn is called by tick_nohz_idle_enter() and that is called
by cpu_idle_loop(). Analogously for sched_clock_idle_wakeup_event().
For this reason, drop those calls from the ACPI cpuidle driver's
->enter callback routines.
Since the cpuidle core calls stop_critical_timings() and
start_critical_timings() around the execution of ->enter callbacks,
acpi_idle_do_entry() doesn't need to do that (and really shouldn't).
Also using "inline" on it is pointless and the kerneldoc entry does
not reflect the actual situation any more.
Fix all of the above.
* pm-cpufreq:
cpufreq: fix a NULL pointer dereference in __cpufreq_governor()
cpufreq-dt: defer probing if OPP table is not ready
* pm-cpuidle:
cpuidle / ACPI: remove unused CPUIDLE_FLAG_TIME_INVALID
cpuidle: ladder: Better idle duration measurement without using CPUIDLE_FLAG_TIME_INVALID
cpuidle: menu: Better idle duration measurement without using CPUIDLE_FLAG_TIME_INVALID
CPUIDLE_FLAG_TIME_INVALID is no longer checked
by menu or ladder cpuidle governors, so don't
bother setting or defining it.
It was originally invented to account for the fact that
acpi_safe_halt() enables interrupts to invoke HLT.
That would allow interrupt service routines to be included
in the last_idle duration measurements made in cpuidle_enter_state(),
potentially returning a duration much larger than reality.
But menu and ladder can gracefully handle erroneously large duration
intervals without checking for CPUIDLE_FLAG_TIME_INVALID.
Further, if they don't check CPUIDLE_FLAG_TIME_INVALID, they
can also benefit from the instances when the duration interval
is not erroneously large.
Signed-off-by: Len Brown <len.brown@intel.com>
* pm-cpuidle:
cpuidle: add MAINTAINERS entry for ARM Exynos cpuidle driver
drivers: cpuidle: Remove cpuidle-arm64 duplicate error messages
drivers: cpuidle: Add idle-state-name description to ARM idle states
drivers: cpuidle: Add status property to ARM idle states
cpuidle: Invert CPUIDLE_FLAG_TIME_VALID logic
It's incorrect to assign a signed value to an unsigned acpi_status
variable. This patch fixes it by using a signed integer to return
error values.
The only place where the time is invalid is when the ACPI_CSTATE_FFH entry
method is not set. Otherwise for all the drivers, the time can be correctly
measured.
Instead of duplicating the CPUIDLE_FLAG_TIME_VALID flag in all the drivers
for all the states, just invert the logic by replacing it by the flag
CPUIDLE_FLAG_TIME_INVALID, hence we can set this flag only for the acpi idle
driver, remove the former flag from all the drivers and invert the logic with
this flag in the different governor.
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
There is a following AB-BA dependency between cpu_hotplug.lock and
cpuidle_lock:
1) cpu_hotplug.lock -> cpuidle_lock
enable_nonboot_cpus()
_cpu_up()
cpu_hotplug_begin()
LOCK(cpu_hotplug.lock)
cpu_notify()
acpi_processor_hotplug()
cpuidle_pause_and_lock()
LOCK(cpuidle_lock)
2) cpuidle_lock -> cpu_hotplug.lock
acpi_os_execute_deferred() workqueue
LOCK(cpuidle_lock)
get_online_cpus()
Fix this by reversing the order acpi_processor_cst_has_changed() does
thigs -- let it first execute the protection against CPU hotplug by
calling get_online_cpus() and obtain the cpuidle lock only after that (and
perform the symmentric change when allowing CPUs hotplug again and
dropping cpuidle lock).
Spotted by lockdep.
Cc: All applicable <stable@vger.kernel.org>
Pull ACPI and power management updates from Rafael Wysocki:
"As far as the number of commits goes, the top spot belongs to ACPI
this time with cpufreq in the second position and a handful of PM
core, PNP and cpuidle updates. They are fixes and cleanups mostly, as
usual, with a couple of new features in the mix.
The most visible change is probably that we will create struct
acpi_device objects (visible in sysfs) for all devices represented in
the ACPI tables regardless of their status and there will be a new
sysfs attribute under those objects allowing user space to check that
status via _STA.
Consequently, ACPI device eject or generally hot-removal will not
delete those objects, unless the table containing the corresponding
namespace nodes is unloaded, which is extremely rare. Also ACPI
container hotplug will be handled quite a bit differently and cpufreq
will support CPU boost ("turbo") generically and not only in the
acpi-cpufreq driver.
Specifics:
- ACPI core changes to make it create a struct acpi_device object for
every device represented in the ACPI tables during all namespace
scans regardless of the current status of that device. In
accordance with this, ACPI hotplug operations will not delete those
objects, unless the underlying ACPI tables go away.
- On top of the above, new sysfs attribute for ACPI device objects
allowing user space to check device status by triggering the
execution of _STA for its ACPI object. From Srinivas Pandruvada.
- ACPI core hotplug changes reducing code duplication, integrating
the PCI root hotplug with the core and reworking container hotplug.
- ACPI core simplifications making it use ACPI_COMPANION() in the
code "glueing" ACPI device objects to "physical" devices.
- ACPICA update to upstream version 20131218. This adds support for
the DBG2 and PCCT tables to ACPICA, fixes some bugs and improves
debug facilities. From Bob Moore, Lv Zheng and Betty Dall.
- Init code change to carry out the early ACPI initialization
earlier. That should allow us to use ACPI during the timekeeping
initialization and possibly to simplify the EFI initialization too.
From Chun-Yi Lee.
- Clenups of the inclusions of ACPI headers in many places all over
from Lv Zheng and Rashika Kheria (work in progress).
- New helper for ACPI _DSM execution and rework of the code in
drivers that uses _DSM to execute it via the new helper. From
Jiang Liu.
- New Win8 OSI blacklist entries from Takashi Iwai.
- Assorted ACPI fixes and cleanups from Al Stone, Emil Goode, Hanjun
Guo, Lan Tianyu, Masanari Iida, Oliver Neukum, Prarit Bhargava,
Rashika Kheria, Tang Chen, Zhang Rui.
- intel_pstate driver updates, including proper Baytrail support,
from Dirk Brandewie and intel_pstate documentation from Ramkumar
Ramachandra.
- Generic CPU boost ("turbo") support for cpufreq from Lukasz
Majewski.
- powernow-k6 cpufreq driver fixes from Mikulas Patocka.
- cpufreq core fixes and cleanups from Viresh Kumar, Jane Li, Mark
Brown.
- Assorted cpufreq drivers fixes and cleanups from Anson Huang, John
Tobias, Paul Bolle, Paul Walmsley, Sachin Kamat, Shawn Guo, Viresh
Kumar.
- cpuidle cleanups from Bartlomiej Zolnierkiewicz.
- Support for hibernation APM events from Bin Shi.
- Hibernation fix to avoid bringing up nonboot CPUs with ACPI EC
disabled during thaw transitions from Bjørn Mork.
- PM core fixes and cleanups from Ben Dooks, Leonardo Potenza, Ulf
Hansson.
- PNP subsystem fixes and cleanups from Dmitry Torokhov, Levente
Kurusa, Rashika Kheria.
- New tool for profiling system suspend from Todd E Brandt and a
cpupower tool cleanup from One Thousand Gnomes"
* tag 'pm+acpi-3.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (153 commits)
thermal: exynos: boost: Automatic enable/disable of BOOST feature (at Exynos4412)
cpufreq: exynos4x12: Change L0 driver data to CPUFREQ_BOOST_FREQ
Documentation: cpufreq / boost: Update BOOST documentation
cpufreq: exynos: Extend Exynos cpufreq driver to support boost
cpufreq / boost: Kconfig: Support for software-managed BOOST
acpi-cpufreq: Adjust the code to use the common boost attribute
cpufreq: Add boost frequency support in core
intel_pstate: Add trace point to report internal state.
cpufreq: introduce cpufreq_generic_get() routine
ARM: SA1100: Create dummy clk_get_rate() to avoid build failures
cpufreq: stats: create sysfs entries when cpufreq_stats is a module
cpufreq: stats: free table and remove sysfs entry in a single routine
cpufreq: stats: remove hotplug notifiers
cpufreq: stats: handle cpufreq_unregister_driver() and suspend/resume properly
cpufreq: speedstep: remove unused speedstep_get_state
platform: introduce OF style 'modalias' support for platform bus
PM / tools: new tool for suspend/resume performance optimization
ACPI: fix module autoloading for ACPI enumerated devices
ACPI: add module autoloading support for ACPI enumerated devices
ACPI: fix create_modalias() return value handling
* pm-cpuidle:
intel_idle: remove superfluous dev->state_count initialization
intel_idle: do C1E promotion disable quirk for hotplugged CPUs
ACPI / cpuidle: remove dev->state_count setting
ACPI / cpuidle: fix max idle state handling with hotplug CPU support
POWERPC: pseries: cpuidle: use the common cpuidle_[un]register() routines
POWERPC: pseries: cpuidle: remove superfluous dev->state_count initialization
ARM: EXYNOS: cpuidle: fix AFTR mode check
dev->state_count is now always equal to drv->state_count and
drv->state_count no longer can change during driver's lifetime so
the default dev->state_count initialization in cpuidle_enable_device()
(called from cpuidle_register_device()) can be used instead.
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Cc: Len Brown <lenb@kernel.org>
acpi_processor_hotplug() calls acpi_processor_setup_cpuidle_cx()
without calling acpi_processor_setup_cpuidle_states() first so it
is possible that dev->state_count becomes different from
drv->state_count (in case of SMP system with unsupported C2/C3
states + enabled CPU hotplug and num_online_cpus() becoming > 1).
The driver code assumes that cpuidle core will handle such cases
but currently this is untrue (dev->state_count is used only for
handling cpuidle state sysfs entries and drv->state_count is used
for all other cases) and will not be fixed in the future as
dev->state_count is planned to be removed.
Fix the issue by checking for the max supported idle state in
C2/C3 state's ->enter handler (acpi_idle_enter_simple() for C2/C3
and acpi_idle_enter_bm() for C3 + bm_check flag set) and setting
the C1 state (instead of higher states) when needed.
Also remove no longer needed max idle state checks from
acpi_processor_setup_cpuidle_[states,cx]().
People seem to delight in writing wrong and broken mwait idle routines;
collapse the lot.
This leaves mwait_play_dead() the sole remaining user of __mwait() and
new __mwait() users are probably doing it wrong.
Also remove __sti_mwait() as its unused.
Cc: Jacob Jun Pan <jacob.jun.pan@linux.intel.com>
Cc: Mike Galbraith <bitbucket@online.de>
Cc: Rui Zhang <rui.zhang@intel.com>
Acked-by: Rafael Wysocki <rafael.j.wysocki@intel.com>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/20131212141654.616820819@infradead.org
In acpi_processor_resume(), the variable resumed_bm_rld is being
used without being initialized, so initialize it.
Signed-off-by: Al Stone <al.stone@linaro.org>
Minor cleanup: remove some extra trailing white space.
Replace direct inclusions of <acpi/acpi.h>, <acpi/acpi_bus.h> and
<acpi/acpi_drivers.h>, which are incorrect, with <linux/acpi.h>
inclusions and remove some inclusions of those files that aren't
necessary.
First of all, <acpi/acpi.h>, <acpi/acpi_bus.h> and <acpi/acpi_drivers.h>
should not be included directly from any files that are built for
CONFIG_ACPI unset, because that generally leads to build warnings about
undefined symbols in !CONFIG_ACPI builds. For CONFIG_ACPI set,
<linux/acpi.h> includes those files and for CONFIG_ACPI unset it
provides stub ACPI symbols to be used in that case.
Second, there are ordering dependencies between those files that always
have to be met. Namely, it is required that <acpi/acpi_bus.h> be included
prior to <acpi/acpi_drivers.h> so that the acpi_pci_root declarations the
latter depends on are always there. And <acpi/acpi.h> which provides
basic ACPICA type declarations should always be included prior to any other
ACPI headers in CONFIG_ACPI builds. That also is taken care of including
<linux/acpi.h> as appropriate.
Signed-off-by: Lv Zheng <lv.zheng@intel.com>
Cc: Matthew Garrett <mjg59@srcf.ucam.org>
Acked-by: Bjorn Helgaas <bhelgaas@google.com> (drivers/pci stuff)
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> (Xen stuff)
