path: root/drivers/acpi/system.c
2010-08-15ACPI: remove deprecated ACPI procfs I/FZhang Rui
Rmove deprecated ACPI procfs I/F, including /proc/acpi/debug_layer /proc/acpi/debug_level /proc/acpi/info /proc/acpi/dsdt /proc/acpi/fadt /proc/acpi/sleep because the sysfs I/F is already available and has been working well for years. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-08-15ACPI: introduce drivers/acpi/sysfs.cZhang Rui
Introduce drivers/acpi/sysfs.c. code for ACPI sysfs I/F, including #ifdef ACPI_DEBUG /sys/module/acpi/parameters/debug_layer /sys/module/acpi/parameters/debug_level /sys/module/acpi/parameters/trace_method_name /sys/module/acpi/parameters/trace_debug_layer /sys/module/acpi/parameters/trace_debug_level /sys/module/acpi/parameters/trace_state #endif /sys/module/acpi/parameters/acpica_version /sys/firmware/acpi/tables/ /sys/firmware/acpi/interrupts/ is moved to this file. No function change in this patch. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-07-06ACPICA: Remove wakeup GPE reference counting which is not usedRafael J. Wysocki
After the previous patch that introduced acpi_gpe_wakeup() and modified the ACPI suspend and wakeup code to use it, the third argument of acpi_{enable|disable}_gpe() and the GPE wakeup reference counter are not necessary any more. Remove them and modify all of the users of acpi_{enable|disable}_gpe() accordingly. Also drop GPE type constants that aren't used any more. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-06-12Merge branch 'gpe-regression-fixes' into releaseLen Brown
2010-06-12ACPI / ACPICA: Fix sysfs GPE interfaceRafael J. Wysocki
The sysfs interface allowing user space to disable/enable GPEs doesn't work correctly, because a GPE disabled this way will be re-enabled shortly by acpi_ev_asynch_enable_gpe() if it was previosuly enabled by acpi_enable_gpe() (in which case the corresponding bit in its enable register's enable_for_run mask is set). To address this issue make the sysfs GPE interface use acpi_enable_gpe() and acpi_disable_gpe() instead of acpi_set_gpe() so that GPE reference counters are modified by it along with the values of GPE enable registers. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2010-05-21sysfs: add struct file* to bin_attr callbacksChris Wright
This allows bin_attr->read,write,mmap callbacks to check file specific data (such as inode owner) as part of any privilege validation. Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-20ACPICA: Minimize the differences between linux GPE code and ACPICA code baseLin Ming
We have ported Rafael's major GPE changes (ACPI: Use GPE reference counting to support shared GPEs) into ACPICA code base. But the port and Rafael's original patch have some differences, so we made below patch to make linux GPE code consistent with ACPICA code base. Most changes are about comments and coding styles. Other noticeable changes are based on: Rafael: Reduce code duplication related to GPE lookup https://patchwork.kernel.org/patch/86237/ Rafael: Always use the same lock for GPE locking https://patchwork.kernel.org/patch/90471/ A new field gpe_count in struct acpi_gpe_block_info to record the number of individual GPEs in block. Rename acpi_ev_save_method_info to acpi_ev_match_gpe_method. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Robert Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-07sysfs: Use sysfs_attr_init and sysfs_bin_attr_init on dynamic attributesEric W. Biederman
These are the non-static sysfs attributes that exist on my test machine. Fix them to use sysfs_attr_init or sysfs_bin_attr_init as appropriate. It simply requires making a sysfs attribute present to see this. So this is a little bit tedious but otherwise not too bad. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-02-22ACPI: Use GPE reference counting to support shared GPEsRafael J. Wysocki
ACPI GPEs may map to multiple devices. The current GPE interface only provides a mechanism for enabling and disabling GPEs, making it difficult to change the state of GPEs at runtime without extensive cooperation between devices. Add an API to allow devices to indicate whether or not they want their device's GPE to be enabled for both runtime and wakeup events. Remove the old GPE type handling entirely, which gets rid of various quirks, like the implicit disabling with GPE type setting. This requires a small amount of rework in order to ensure that non-wake GPEs are enabled by default to preserve existing behaviour. Based on patches from Matthew Garrett <mjg@redhat.com>. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-08-28ACPI: Move definition of PREFIX from acpi_bus.h to internal..hLen Brown
Linux/ACPI core files using internal.h all PREFIX "ACPI: ", however, not all ACPI drivers use/want it -- and they should not have to #undef PREFIX to define their own. Add GPL commment to internal.h while we are there. This does not change any actual console output, asside from a whitespace fix. Signed-off-by: Len Brown <len.brown@intel.com>
2009-08-02ACPI: root-only read protection on /sys/firmware/acpi/tables/*Len Brown
they were world readable. Signed-off-by: Len Brown <len.brown@intel.com>
2009-04-21ACPI: add /sys/firmware/acpi/interrupts/sci_not counterLen Brown
This counter may prove useful in debugging some spurious interrupt issues seen in the field. Signed-off-by: Len Brown <len.brown@intel.com>
2009-04-05Merge branch 'acpi-modparam' into releaseLen Brown
Conflicts: drivers/acpi/Makefile Signed-off-by: Len Brown <len.brown@intel.com>
2009-04-05Merge branch 'dynamic-ssdt' into releaseLen Brown
2009-04-02ACPI: simplify module_param namespaceRusty Russell
Impact: cleanup Rather than overriding MODULE_PARAM_PREFIX, build via acpi.o so KBUILD_MODNAME is set to "acpi". This is the logical way to do it, even though acpi cannot be a module due to these config options being bool. Those parts of ACPI which can be modular are not built into the acpi "module". Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Len Brown <len.brown@intel.com>
2009-03-27ACPI: call acpi_system_init() explicitly rather than as initcallBjorn Helgaas
This patch makes acpi_init() call acpi_system_init() directly. Previously, both were subsys_initcalls. acpi_system_init() must happen after acpi_init(), and it's better to call it explicitly rather than rely on link ordering. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-02-26ACPI: introduce sysfs I/F for dynamic tablesZhang Rui
SSDT tables may be loaded at runtime. create sysfs I/F for these dynamic tables in /sys/firmware/acpi/tables/dynamic/. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-12-31ACPICA: New: acpi_get_gpe_device interfaceBob Moore
This function maps an input GPE index to a GPE block device. Also Added acpi_current_gpe_count to track the current number of GPEs that are being managed by the ACPICA core (both FADT-based GPEs and the GPEs contained in GPE block devices.) Modify drivers/acpi/system.c to use these 2 new interfaces Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-11-11Merge branch 'ec' into releaseLen Brown
2008-11-11Merge branch 'bugzilla-11539' into releaseLen Brown
2008-11-11ACPICA: Use spinlock for acpi_{en|dis}able_gpeAlexey Starikovskiy
Disabling gpe might interfere with gpe detection/handling, thus producing "interrupt not handled" errors. Ironically, disabling of GPE from interrupt context is already under spinlock, so only userspace needs to start using it. Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2008-11-06ACPI: avoid empty file name in sysfsPeter Gruber
Since commit bc45b1d39a925b56796bebf8a397a0491489d85c acpi tables are allowed to have an empty signature and /sys/firmware/acpi/tables uses the signature as filename. Applications using naive recursion through /sys loop forever. A possible solution would be: (replacing the zero length filename with the string "NULL") http://bugzilla.kernel.org/show_bug.cgi?id=11539 Acked-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-28ACPI: bugfix reporting of event handler statusZhang Rui
Introduce a new flag showing whether the event has an event handler/method. For all the GPEs and Fixed Events, 1. ACPI_EVENT_FLAG_HANDLE is cleared, it's an "invalid" ACPI event. 2. Both ACPI_EVENT_FLAG_HANDLE and ACPI_EVENT_FLAG_DISABLE are set, it's "disabled". 3. Both ACPI_EVENT_FLAG_HANDLE and ACPI_EVENT_FLAG_ENABLE are set, it's "enabled". 4. Both ACPI_EVENT_FLAG_HANDLE and ACPI_EVENT_FLAG_WAKE_ENABLE are set, it's "wake_enabled". Among other things, this prevents incorrect reporting of ACPI events as being "invalid" when it's really just (temporarily) "disabled". Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-23Merge branch 'linus' into testLen Brown
Conflicts: MAINTAINERS arch/x86/kernel/acpi/boot.c arch/x86/kernel/acpi/sleep.c drivers/acpi/Kconfig drivers/pnp/Makefile drivers/pnp/quirks.c Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-22ACPI: replace ACPI_DEBUG_PRINT((ACPI_DB_ERROR, ...) with printkLin Ming
ACPI_DB_ERROR and ACPI_DB_WARN were removed from ACPICA core. So replace ACPI_DEBUG_PRINT((ACPI_DB_ERROR, ...) with printk(KERN_ERR PREFIX ...) and ACPI_DEBUG_PRINT((ACPI_DB_WARN, ...) with printk(KERN_WARNING PREFIX ...) We do not use ACPI_ERROR/ACPI_WARNING since they're not exported, see ------------------------------------------------------------- commit 6468463abd7051fcc29f3ee7c931f9bbbb26f5a4 Author: Len Brown <len.brown@intel.com> Date: Mon Jun 26 23:41:38 2006 -0400 ACPI: un-export ACPI_ERROR() -- use printk(KERN_ERR...) Signed-off-by: Len Brown <len.brown@intel.com> ------------------------------------------------------------- Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-20x86: sysfs: kill owner field from attributeParag Warudkar
Tejun's commit 7b595756ec1f49e0049a9e01a1298d53a7faaa15 made sysfs attribute->owner unnecessary. But the field was left in the structure to ease the merge. It's been over a year since that change and it is now time to start killing attribute->owner along with its users - one arch at a time! This patch is attempt #1 to get rid of attribute->owner only for CONFIG_X86_64 or CONFIG_X86_32 . We will deal with other arches later on as and when possible - avr32 will be the next since that is something I can test. Compile (make allyesconfig / make allmodconfig / custom config) and boot tested. akpm: the idea is that we put the declaration of sttribute.owner inside `#ifndef CONFIG_X86'. But that proved to be too ambitious for now because new usages kept on turning up in subsystem trees. [akpm: remove the ifdef for now] Signed-off-by: Parag Warudkar <parag.lkml@gmail.com> Cc: Greg KH <greg@kroah.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Tejun Heo <htejun@gmail.com> Cc: Len Brown <lenb@kernel.org> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Jean Delvare <khali@linux-fr.org> Cc: Roland Dreier <rolandd@cisco.com> Cc: David Brownell <david-b@pacbell.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24move memory_read_from_buffer() from fs.h to string.hAkinobu Mita
James Bottomley warns that inclusion of linux/fs.h in a low level driver was always a danger signal. This patch moves memory_read_from_buffer() from fs.h to string.h and fixes includes in existing memory_read_from_buffer() users. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: James Bottomley <James.Bottomley@hansenpartnership.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Zhang Rui <rui.zhang@intel.com> Cc: Bob Moore <robert.moore@intel.com> Cc: Thomas Renninger <trenn@suse.de> Cc: Len Brown <lenb@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-16ACPI: Enhance /sys/firmware/interrupts to allow enable/disable/clear from ↵Zhang Rui
user-space Allow users to enable/disable/clear a specific & valid GPE/Fixed Event in user space. This is useful for debugging, especially for some interrupt storm issues. All wakeup GPEs are disabled and they can not be enabled at runtime, and we mark them as invalid. All GPEs that don't have a _Lxx/_Exx method are marked as invalid. All Fixed Events that don't have an event handler are marked as invalid and they can't be enabled until an event handler is registered. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Ling Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-06-11ACPI: use memory_read_from_buffer()Akinobu Mita
Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-29acpi: use non-racy method for proc entries creationDenis V. Lunev
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Add correct ->owner to proc_fops to fix reading/module unloading race. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Len Brown <lenb@kernel.org> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-12ACPI: buffer array too short in drivers/acpi/system.cJohann Felix Soden
Since "ff_gbl_lock" has a length of 11 chars and is copied with sprintf to char buffer[10], there is a problem. We need char buffer[12] because of the closing zero byte. Signed-off-by: Johann Felix Soden <johfel@users.sourceforge.net> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-07ACPI: fix build warningLen Brown
drivers/acpi/system.c:360: warning: ignoring return value of ‘sysfs_create_group’, declared with attribute warn_unused_result Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-06ACPI: create /sys/firmware/acpi/interruptsLen Brown
See Documentation/ABI/testing/sysfs-firmware-acpi Based-on-original-patch-by: Luming Yu <luming.yu@intel.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2008-01-24Kobject: change drivers/acpi/system.c to use kobject_create_and_addGreg Kroah-Hartman
Stop using kobject_register for this static kobject, as it's overkill. This way is much simpler. Cc: Len Brown <len.brown@intel.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kobject: convert /sys/firmware/acpi/ to use kobject_createGreg Kroah-Hartman
We don't need a kset here, a simple kobject will do just fine, so dynamically create the kobject and use it. Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Len Brown <lenb@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-22ACPI: Populate /sys/firmware/acpi/tables/Zhang Rui
The file name is the signature, such as DSDT, and the contents are the binary table image. Some tables, such as the SSDT, can have multiple instances. If just one, the file is SSDT, but if 3 instances, for example, it will be SSDT1, SSDT2, SSDT3 All static tables (besides teh RSDP and RSDT themselves are exported. Dynamic tables, such as SSDT op-regions that are not declared in the RSDT, will be added in a subsequent patch. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-12ACPI: delete extra #defines in /drivers/acpi/ driversLen Brown
Cosmetic only. Except in a single case, #define ACPI_*_DRIVER_NAME were invoked 0 or 1 times. Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-12ACPI: clean up ACPI_MODULE_NAME() useLen Brown
cosmetic only Make "module name" actually match the file name. Invoke with ';' as leaving it off confuses Lindent and gcc doesn't care. Fix indentation where Lindent did get confused. Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-03Pull sysfs into test branchLen Brown
Conflicts: Documentation/feature-removal-schedule.txt include/acpi/acpi_drivers.h Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-02ACPICA: minimal patch to integrate new tables into LinuxAlexey Starikovskiy
2007-01-28ACPI: add ACPICA version in sysfsZhang Rui
Add an ACPI attribute to indicate ACPICA version. /proc/acpi/version is deprecated by /sys/module/acpi/parameters/acpica_version. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-07-10ACPI: add 'const' to several ACPI file_operationsArjan van de Ven
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-30ACPI: delete acpi_os_free(), use kfree() directlyLen Brown
2006-06-27ACPI: delete tracing macros from drivers/acpi/*.cPatrick Mochel
2006-06-26ACPI: Enable ACPI error messages w/o CONFIG_ACPI_DEBUGThomas Renninger
Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-14ACPI: ACPICA 20060421Bob Moore
Removed a device initialization optimization introduced in 20051216 where the _STA method was not run unless an _INI was also present for the same device. This optimization could cause problems because it could allow _INI methods to be run within a not-present device subtree (If a not-present device had no _INI, _STA would not be run, the not-present status would not be discovered, and the children of the device would be incorrectly traversed.) Implemented a new _STA optimization where namespace subtrees that do not contain _INI are identified and ignored during device initialization. Selectively running _STA can significantly improve boot time on large machines (with assistance from Len Brown.) Implemented support for the device initialization case where the returned _STA flags indicate a device not-present but functioning. In this case, _INI is not run, but the device children are examined for presence, as per the ACPI specification. Implemented an additional change to the IndexField support in order to conform to MS behavior. The value written to the Index Register is not simply a byte offset, it is a byte offset in units of the access width of the parent Index Field. (Fiodor Suietov) Defined and deployed a new OSL interface, acpi_os_validate_address(). This interface is called during the creation of all AML operation regions, and allows the host OS to exert control over what addresses it will allow the AML code to access. Operation Regions whose addresses are disallowed will cause a runtime exception when they are actually accessed (will not affect or abort table loading.) Defined and deployed a new OSL interface, acpi_os_validate_interface(). This interface allows the host OS to match the various "optional" interface/behavior strings for the _OSI predefined control method as appropriate (with assistance from Bjorn Helgaas.) Restructured and corrected various problems in the exception handling code paths within DsCallControlMethod and DsTerminateControlMethod in dsmethod (with assistance from Takayoshi Kochi.) Modified the Linux source converter to ignore quoted string literals while converting identifiers from mixed to lower case. This will correct problems with the disassembler and other areas where such strings must not be modified. The ACPI_FUNCTION_* macros no longer require quotes around the function name. This allows the Linux source converter to convert the names, now that the converter ignores quoted strings. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-14ACPI: ACPICA 20060331Bob Moore
Implemented header file support for the following additional ACPI tables: ASF!, BOOT, CPEP, DBGP, MCFG, SPCR, SPMI, TCPA, and WDRT. With this support, all current and known ACPI tables are now defined in the ACPICA headers and are available for use by device drivers and other software. Implemented support to allow tables that contain ACPI names with invalid characters to be loaded. Previously, this would cause the table load to fail, but since there are several known cases of such tables on existing machines, this change was made to enable ACPI support for them. Also, this matches the behavior of the Microsoft ACPI implementation. https://bugzilla.novell.com/show_bug.cgi?id=147621 Fixed a couple regressions introduced during the memory optimization in the 20060317 release. The namespace node definition required additional reorganization and an internal datatype that had been changed to 8-bit was restored to 32-bit. (Valery Podrezov) Fixed a problem where a null pointer passed to acpi_ut_delete_generic_state() could be passed through to acpi_os_release_object which is unexpected. Such null pointers are now trapped and ignored, matching the behavior of the previous implementation before the deployment of acpi_os_release_object(). (Valery Podrezov, Fiodor Suietov) Fixed a memory mapping leak during the deletion of a SystemMemory operation region where a cached memory mapping was not deleted. This became a noticeable problem for operation regions that are defined within frequently used control methods. (Dana Meyers) Reorganized the ACPI table header files into two main files: one for the ACPI tables consumed by the ACPICA core, and another for the miscellaneous ACPI tables that are consumed by the drivers and other software. The various FADT definitions were merged into one common section and three different tables (ACPI 1.0, 1.0+, and 2.0) Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-08-05[ACPI] Lindent all ACPI filesLen Brown
